[U-Boot] [PATCH 2/8 V2] add at91 SoC access with c structures
* add at91 soc to arm920t, needs to join at91rm9200 into at91 arch
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- cpu/arm920t/at91/Makefile | 47 ++++++++++ cpu/arm920t/at91/lowlevel_init.S | 177 ++++++++++++++++++++++++++++++++++++++ cpu/arm920t/at91/reset.c | 58 ++++++++++++ cpu/arm920t/at91/timer.c | 166 +++++++++++++++++++++++++++++++++++ 4 files changed, 448 insertions(+), 0 deletions(-) create mode 100644 cpu/arm920t/at91/Makefile create mode 100644 cpu/arm920t/at91/lowlevel_init.S create mode 100644 cpu/arm920t/at91/reset.c create mode 100644 cpu/arm920t/at91/timer.c
diff --git a/cpu/arm920t/at91/Makefile b/cpu/arm920t/at91/Makefile new file mode 100644 index 0000000..6e683f6 --- /dev/null +++ b/cpu/arm920t/at91/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +SOBJS += lowlevel_init.o +COBJS += reset.o +COBJS += timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm920t/at91/lowlevel_init.S b/cpu/arm920t/at91/lowlevel_init.S new file mode 100644 index 0000000..8e081dc --- /dev/null +++ b/cpu/arm920t/at91/lowlevel_init.S @@ -0,0 +1,177 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and + * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) + * + * Modified for the at91rm9200dk board by + * (C) Copyright 2004 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + +#define AT91_PMC_MOR 0xFFFFFC20 /* Main oscillator register */ +#define AT91_PMC_PLLAR 0xFFFFFC28 +#define AT91_PMC_PLLBR 0xFFFFFC2C +#define AT91_PMC_MCKR 0xFFFFFC30 + +#define AT91_PIOC_ASR 0xFFFFF870 +#define AT91_PIOC_BSR 0xFFFFF874 +#define AT91_PIOC_PDR 0xFFFFF804 + +#define AT91_MC_EBI_CSA 0xFFFFFF60 +#define AT91_MC_EBI_CFG 0xFFFFFF64 +#define AT91_MC_SMC_CSR0 0xFFFFFF70 + +#define AT91_MC_SDRAMC_MR 0xFFFFFF90 +#define AT91_MC_SDRAMC_TR 0xFFFFFF94 +#define AT91_MC_SDRAMC_CR 0xFFFFFF98 + +_MTEXT_BASE: +#undef START_FROM_MEM +#ifdef START_FROM_MEM + .word TEXT_BASE-PHYS_FLASH_1 +#else + .word TEXT_BASE +#endif + +.globl lowlevel_init +lowlevel_init: + ldr r1, =AT91_PMC_MOR + /* Main oscillator Enable register */ +#ifdef CONFIG_SYS_USE_MAIN_OSCILLATOR + ldr r0, =0x0000FF01 /* Enable main oscillator, OSCOUNT = 0xFF */ +#else + ldr r0, =0x0000FF00 /* Disable main oscillator, OSCOUNT = 0xFF */ +#endif + str r0, [r1] /*AT91C_CKGR_MOR] */ + /* Add loop to compensate Main Oscillator startup time */ + ldr r0, =0x00000010 +LoopOsc: + subs r0, r0, #1 + bhi LoopOsc + + /* memory control configuration */ + /* this isn't very elegant, but what the heck */ + ldr r0, =SMRDATA + ldr r1, _MTEXT_BASE + sub r0, r0, r1 + add r2, r0, #80 +0: + /* the address */ + ldr r1, [r0], #4 + /* the value */ + ldr r3, [r0], #4 + str r3, [r1] + cmp r2, r0 + bne 0b + /* delay - this is all done by guess */ + ldr r0, =0x00010000 + /* (vs reading PMC_SR for LOCKA, LOCKB ... or MOSCS earlier) */ +1: + subs r0, r0, #1 + bhi 1b + ldr r0, =SMRDATA1 + ldr r1, _MTEXT_BASE + sub r0, r0, r1 + add r2, r0, #176 +2: + /* the address */ + ldr r1, [r0], #4 + /* the value */ + ldr r3, [r0], #4 + str r3, [r1] + cmp r2, r0 + bne 2b + + /* switch from FastBus to Asynchronous clock mode */ + mrc p15, 0, r0, c1, c0, 0 + orr r0, r0, #0xC0000000 @ set bit 31 (iA) and 30 (nF) + mcr p15, 0, r0, c1, c0, 0 + + /* everything is fine now */ + mov pc, lr + + .ltorg + +SMRDATA: + .word AT91_MC_EBI_CFG + .word CONFIG_SYS_EBI_CFGR_VAL + .word AT91_MC_SMC_CSR0 + .word CONFIG_SYS_SMC_CSR0_VAL + .word AT91_PMC_PLLAR + .word CONFIG_SYS_PLLAR_VAL + .word AT91_PMC_PLLBR + .word CONFIG_SYS_PLLBR_VAL + .word AT91_PMC_MCKR + .word CONFIG_SYS_MCKR_VAL + /* here there's a delay */ +SMRDATA1: + .word AT91_PIOC_ASR + .word CONFIG_SYS_PIOC_ASR_VAL + .word AT91_PIOC_BSR + .word CONFIG_SYS_PIOC_BSR_VAL + .word AT91_PIOC_PDR + .word CONFIG_SYS_PIOC_PDR_VAL + .word AT91_MC_EBI_CSA + .word CONFIG_SYS_EBI_CSA_VAL + .word AT91_MC_SDRAMC_CR + .word CONFIG_SYS_SDRC_CR_VAL + .word AT91_MC_SDRAMC_MR + .word CONFIG_SYS_SDRC_MR_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word AT91_MC_SDRAMC_MR + .word CONFIG_SYS_SDRC_MR_VAL1 + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word AT91_MC_SDRAMC_MR + .word CONFIG_SYS_SDRC_MR_VAL2 + .word CONFIG_SYS_SDRAM1 + .word CONFIG_SYS_SDRAM_VAL + .word AT91_MC_SDRAMC_TR + .word CONFIG_SYS_SDRC_TR_VAL + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + .word AT91_MC_SDRAMC_MR + .word CONFIG_SYS_SDRC_MR_VAL3 + .word CONFIG_SYS_SDRAM + .word CONFIG_SYS_SDRAM_VAL + /* SMRDATA1 is 176 bytes long */ +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ diff --git a/cpu/arm920t/at91/reset.c b/cpu/arm920t/at91/reset.c new file mode 100644 index 0000000..ab05167 --- /dev/null +++ b/cpu/arm920t/at91/reset.c @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2002 + * Lineo, Inc. <www.lineo.com> + * Bernhard Kuhn bkuhn@lineo.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_st.h> + +void board_reset(void) __attribute__((__weak__)); + +void reset_cpu (ulong ignored) +{ + at91_st_t *st = (at91_st_t *) AT91_ST_BASE; +#if defined(CONFIG_AT91RM9200_USART) || defined(CONFIG_AT91_USART) + /*shutdown the console to avoid strange chars during reset */ + serial_exit(); +#endif + + if (board_reset) + board_reset(); + + /* Reset the cpu by setting up the watchdog timer */ + writel(AT91_ST_WDMR_RSTEN | AT91_ST_WDMR_EXTEN | AT91_ST_WDMR_WDV(2), + &st->wdmr); + writel(AT91_ST_CR_WDRST, &st->cr); + /* and let him time out */ + while (1); + /* Never reached */ +} diff --git a/cpu/arm920t/at91/timer.c b/cpu/arm920t/at91/timer.c new file mode 100644 index 0000000..ea7698a --- /dev/null +++ b/cpu/arm920t/at91/timer.c @@ -0,0 +1,166 @@ +/* + * (C) Copyright 2002 + * Lineo, Inc. <www.lineo.com> + * Bernhard Kuhn bkuhn@lineo.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#include <asm/io.h> +#include <asm/hardware.h> +#include <asm/arch/at91_tc.h> +#include <asm/arch/at91_pmc.h> + +/* the number of clocks per CONFIG_SYS_HZ */ +#define TIMER_LOAD_VAL (CONFIG_SYS_HZ_CLOCK/CONFIG_SYS_HZ) + +/* macro to read the 16 bit timer */ +//#define READ_TIMER (tmr->TC_CV & 0x0000ffff) +/*#AT91PS_TC tmr; */ + +static u32 timestamp; +static u32 lastinc; + +int timer_init (void) +{ + at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + + /* enables TC1.0 clock */ + writel(1 << AT91_ID_TC0, &pmc->pcer); /* enable clock */ + + writel(0, &tc->bcr); + writel(AT91_TC_BMR_TC0XC0S_NONE | AT91_TC_BMR_TC1XC1S_NONE | + AT91_TC_BMR_TC2XC2S_NONE , &tc->bmr); + + writel(AT91_TC_CCR_CLKDIS, &tc->tc[0].ccr); + /* set to MCLK/2 and restart the timer when the vlaue in TC_RC is reached */ + writel(AT91_TC_CMR_TCCLKS_CLOCK1 | AT91_TC_CMR_CPCTRG, &tc->tc[0].cmr); + + writel(0xFFFFFFFF, &tc->tc[0].idr); /* disable interupts */ + writel(TIMER_LOAD_VAL, &tc->tc[0].rc); + + writel(AT91_TC_CCR_SWTRG | AT91_TC_CCR_CLKEN, &tc->tc[0].ccr); + lastinc = 0; + timestamp = 0; + + return (0); +} + +/* + * timer without interrupts + */ + +void reset_timer (void) +{ + reset_timer_masked (); +} + +ulong get_timer (ulong base) +{ + return get_timer_masked () - base; +} + +void set_timer (ulong t) +{ + timestamp = t; +} + +void __udelay (unsigned long usec) +{ + udelay_masked(usec); +} + +void reset_timer_masked (void) +{ + /* reset time */ + at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; + lastinc = readl(&tc->tc[0].cv) & 0x0000ffff; + timestamp = 0; +} + +ulong get_timer_raw (void) +{ + at91_tc_t *tc = (at91_tc_t *) AT91_TC_BASE; + u32 now; + + now = readl(&tc->tc[0].cv) & 0x0000ffff; + + if (now >= lastinc) { + /* normal mode */ + timestamp += now - lastinc; + } else { + /* we have an overflow ... */ + timestamp += now + TIMER_LOAD_VAL - lastinc; + } + lastinc = now; + + return timestamp; +} + +ulong get_timer_masked (void) +{ + return get_timer_raw()/TIMER_LOAD_VAL; +} + +void udelay_masked (unsigned long usec) +{ + u32 tmo; + u32 endtime; + signed long diff; + + tmo = CONFIG_SYS_HZ_CLOCK / 1000; + tmo *= usec; + tmo /= 1000; + + endtime = get_timer_raw () + tmo; + + do { + u32 now = get_timer_raw (); + diff = endtime - now; + } while (diff >= 0); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk (void) +{ + return CONFIG_SYS_HZ; +}
Jens Scharsig wrote:
- add at91 soc to arm920t, needs to join at91rm9200 into at91 arch
It is unclear why arm920t/at91rm9200 -> arm920t/at91 I am not in favor of renaming dirs or making multiple copies of the same file.
Please make your case on the list and in the commit log of the patch
Tom
Hello Tom
the intention is, the at91rm9200 integrates in at91 tree. So I create a new dir for files with c structur soc access.
If all boards converted to at91 new soc access, we can remove the at91rm9200 dir.
see also http://lists.denx.de/pipermail/u-boot/2009-December/065688.html
regards Jens
Jens Scharsig
Tom
