[U-Boot] [PATCH v2 3/5] x86: qemu: Create separate i440fx and q35 device trees
Although the two qemu-x86 targets (i440fx and q35) share a lot in common, they still have something that cannot easily handled in one single device tree). Split to create two dedicated device tree files and make the i440fx be the default build target.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Still use one board configuration file qemu-x86.h
arch/x86/dts/Makefile | 3 ++- arch/x86/dts/qemu-x86_i440fx.dts | 34 +++++++++++++++++++++++++ arch/x86/dts/{qemu-x86.dts => qemu-x86_q35.dts} | 2 +- board/coreboot/coreboot/Kconfig | 2 +- configs/qemu-x86_defconfig | 3 +-- doc/README.x86 | 10 +++++++- 6 files changed, 48 insertions(+), 6 deletions(-) create mode 100644 arch/x86/dts/qemu-x86_i440fx.dts rename arch/x86/dts/{qemu-x86.dts => qemu-x86_q35.dts} (95%)
diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile index ca2eab3..f86514c 100644 --- a/arch/x86/dts/Makefile +++ b/arch/x86/dts/Makefile @@ -3,7 +3,8 @@ dtb-y += chromebook_link.dtb \ crownbay.dtb \ galileo.dtb \ minnowmax.dtb \ - qemu-x86.dtb + qemu-x86_i440fx.dtb \ + qemu-x86_q35.dtb
targets += $(dtb-y)
diff --git a/arch/x86/dts/qemu-x86_i440fx.dts b/arch/x86/dts/qemu-x86_i440fx.dts new file mode 100644 index 0000000..4cf843b --- /dev/null +++ b/arch/x86/dts/qemu-x86_i440fx.dts @@ -0,0 +1,34 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +/include/ "skeleton.dtsi" +/include/ "serial.dtsi" + +/ { + model = "QEMU x86 (I440FX)"; + compatible = "qemu,x86"; + + config { + silent_console = <0>; + }; + + chosen { + stdout-path = "/serial"; + }; + + pci { + compatible = "pci-x86"; + #address-cells = <3>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0xc0000000 0xc0000000 0 0x10000000 + 0x42000000 0x0 0xd0000000 0xd0000000 0 0x10000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>; + }; + +}; diff --git a/arch/x86/dts/qemu-x86.dts b/arch/x86/dts/qemu-x86_q35.dts similarity index 95% rename from arch/x86/dts/qemu-x86.dts rename to arch/x86/dts/qemu-x86_q35.dts index f1291b5..6c89283 100644 --- a/arch/x86/dts/qemu-x86.dts +++ b/arch/x86/dts/qemu-x86_q35.dts @@ -10,7 +10,7 @@ /include/ "serial.dtsi"
/ { - model = "QEMU x86"; + model = "QEMU x86 (Q35)"; compatible = "qemu,x86";
config { diff --git a/board/coreboot/coreboot/Kconfig b/board/coreboot/coreboot/Kconfig index 69e3437..3ff64f4 100644 --- a/board/coreboot/coreboot/Kconfig +++ b/board/coreboot/coreboot/Kconfig @@ -23,7 +23,7 @@ config SYS_CONFIG_NAME
config DEFAULT_DEVICE_TREE string "Board Device Tree Source (dts) file" - default "qemu-x86" + default "qemu-x86_i440fx" help This option selects the board Device Tree Source (dts) file in arch/x86/dts/ directory to be used to build U-Boot for coreboot. diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4509d52..0959a98 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -1,10 +1,9 @@ CONFIG_X86=y CONFIG_VENDOR_EMULATION=y +CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_TARGET_QEMU_X86=y CONFIG_CMD_NET=y CONFIG_OF_CONTROL=y -CONFIG_OF_SEPARATE=y -CONFIG_DEFAULT_DEVICE_TREE="qemu-x86" CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/doc/README.x86 b/doc/README.x86 index 0726205..c19f4a0 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -40,7 +40,7 @@ configuration during the 'make menuconfig' process. x86 architecture ---> ... (qemu-x86) Board configuration file - (qemu-x86) Board Device Tree Source (dts) file + (qemu-x86_i440fx) Board Device Tree Source (dts) file (0x01920000) Board specific Cache-As-RAM (CAR) address (0x4000) Board specific Cache-As-RAM (CAR) size
@@ -186,6 +186,14 @@ To build u-boot.rom for QEMU x86 targets, just simply run $ make qemu-x86_defconfig $ make all
+Note this default configuration will build a U-Boot for the QEMU x86 i440FX +board. To build a U-Boot against QEMU x86 Q35 board, you can change the build +configuration during the 'make menuconfig' process like below: + +Device Tree Control ---> + ... + (qemu-x86_q35) Default Device Tree for DT control + Test with coreboot ------------------ For testing U-Boot as the coreboot payload, there are things that need be paid
Changes in v2:
Changes in v2:
Applied to u-boot-x86, thanks!
Bin Meng
