[U-Boot] [PATCH v4] u-boot: remove driver lookup loop from env_save()
When called with ENVOP_SAVE, env_get_location() only returns the gd->env_load_location variable without actually checking for the environment location and priority.
This behaviour causes env_save() to fall into an infinite loop when the low-level drv->save() call fails.
The env_save() function should not loop through the environment location list but it should save the environment into the location stored in gd->env_load_location by the last env_load() call.
Signed-off-by: Nicholas Faustini nicholas.faustini@azcomtech.com Reviewed-by: Simon Goldschmidt goldsimon@gmx.de
Changes in v4: - Remove env_load_location from gd_t since it is not used anymore
Changes in v3: - Add comment when env_load() fails and the env location is restored - Introduce env_load_prio into gd struct. It stores the current priority of the environment location. Refactor of env_get_location() which acts the same on all the 'env_operation'
Changes in v2: - Restore gd->env_load_location to the highest priority location when env_load() fails
env/env.c | 34 ++++++++++++++++------------------ include/asm-generic/global_data.h | 2 +- 2 files changed, 17 insertions(+), 19 deletions(-)
diff --git a/env/env.c b/env/env.c index 5c0842a..e033b46 100644 --- a/env/env.c +++ b/env/env.c @@ -119,21 +119,12 @@ static void env_set_inited(enum env_location location) */ __weak enum env_location env_get_location(enum env_operation op, int prio) { - switch (op) { - case ENVOP_GET_CHAR: - case ENVOP_INIT: - case ENVOP_LOAD: - if (prio >= ARRAY_SIZE(env_locations)) - return ENVL_UNKNOWN; - - gd->env_load_location = env_locations[prio]; - return gd->env_load_location; - - case ENVOP_SAVE: - return gd->env_load_location; - } + if (prio >= ARRAY_SIZE(env_locations)) + return ENVL_UNKNOWN; + + gd->env_load_prio = prio;
- return ENVL_UNKNOWN; + return env_locations[prio]; }
@@ -205,22 +196,29 @@ int env_load(void) return 0; }
+ /* + * In case of invalid environment, we set the 'default' env location + * to the highest priority. In this way, next calls to env_save() + * will restore the environment at the right place. + */ + env_get_location(ENVOP_LOAD, 0); + return -ENODEV; }
int env_save(void) { struct env_driver *drv; - int prio;
- for (prio = 0; (drv = env_driver_lookup(ENVOP_SAVE, prio)); prio++) { + drv = env_driver_lookup(ENVOP_SAVE, gd->env_load_prio); + if (drv) { int ret;
if (!drv->save) - continue; + return -ENODEV;
if (!env_has_inited(drv->location)) - continue; + return -ENODEV;
printf("Saving Environment to %s... ", drv->name); ret = drv->save(); diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 0fd4900..c83fc01 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -50,7 +50,7 @@ typedef struct global_data { unsigned long env_addr; /* Address of Environment struct */ unsigned long env_valid; /* Environment valid? enum env_valid */ unsigned long env_has_init; /* Bitmask of boolean of struct env_location offsets */ - int env_load_location; + int env_load_prio; /* Priority of the loaded environment */
unsigned long ram_base; /* Base address of RAM used by U-Boot */ unsigned long ram_top; /* Top address of RAM used by U-Boot */
Oh no, I just noticed that was my private mail, not this one, sorry for that. But OTOH, I don't really mind...
Simon
Changes in v4:
Changes in v3:
Changes in v2:
- switch (op) {
- case ENVOP_INIT:
- case ENVOP_LOAD:
- case ENVOP_SAVE:
- gd->env_load_prio = prio;
- return env_locations[prio]; }
return -ENODEV; }
int prio;
if (drv) { int ret;
if (!drv->save)
continue;
return -ENODEV;
continue;
return -ENODEV;
Nicholas Faustini
Simon Goldschmidt
