[PATCH v2 0/7] Add video damage tracking
This patch set speeds up graphics output on ARM by a factor of 60x.
On most ARM SBCs, we keep the frame buffer in DRAM and map it as cached, but need it accessible by the display controller which reads directly from a later point of consistency. Hence, we flush the frame buffer to DRAM on every change. The full frame buffer.
Unfortunately, with the advent of 4k displays, we are seeing frame buffers that can take a while to flush out. This was reported by Da Xue with grub, which happily print 1000s of spaces on the screen to draw a menu. Every printed space triggers a cache flush.
This patch set implements the easiest mitigation against this problem: Damage tracking. We remember the lowest common denominator region that was touched since the last video_sync() call and only flush that. The most typical writer to the frame buffer is the video console, which always writes rectangles of characters on the screen and syncs afterwards.
With this patch set applied, we reduce drawing a large grub menu (with serial console attached for size information) on an RK3399-ROC system at 1440p from 55 seconds to less than 1 second.
Version 2 also implements VIDEO_COPY using this mechanism, reducing its overhead compared to before as well. So even x86 systems should be faster with this now :).
Alternatives considered:
1) Lazy sync - Sandbox does this. It only calls video_sync(true) ever so often. We are missing timers to do this generically.
2) Double buffering - We could try to identify whether anything changed at all and only draw to the FB if it did. That would require maintaining a second buffer that we need to scan.
3) Text buffer - Maintain a buffer of all text printed on the screen with respective location. Don't write if the old and new character are identical. This would limit applicability to text only and is an optimization on top of this patch set.
4) Hash screen lines - Create a hash (sha256?) over every line when it changes. Only flush when it does. I'm not sure if this would waste more time, memory and cache than the current approach. It would make full screen updates much more expensive.
v1 -> v2:
- new patch: video: Use VIDEO_DAMAGE for VIDEO_COPY - Remove ifdefs - Fix dcache range; we were flushing too much before - Fix ranges in truetype target - Limit rotate to necessary damange
Alexander Graf (7): dm: video: Add damage tracking API dm: video: Add damage notification on display clear vidconsole: Add damage notifications to all vidconsole drivers video: Add damage notification on bmp display efi_loader: GOP: Add damage notification on BLT video: Only dcache flush damaged lines video: Use VIDEO_DAMAGE for VIDEO_COPY
configs/chromebook_coral_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/video/Kconfig | 21 ++- drivers/video/console_normal.c | 22 ++-- drivers/video/console_rotate.c | 87 ++++++++----- drivers/video/console_truetype.c | 30 +++-- drivers/video/vidconsole-uclass.c | 16 --- drivers/video/video-uclass.c | 185 ++++++++++++++++----------- drivers/video/video_bmp.c | 7 +- include/video.h | 54 +++----- include/video_console.h | 49 ------- lib/efi_loader/efi_gop.c | 7 +- 16 files changed, 247 insertions(+), 237 deletions(-)
We are going to introduce image damage tracking to fasten up screen refresh on large displays. This patch adds damage tracking for up to one rectangle of the screen which is typically enough to hold blt or text print updates. Callers into this API and a reduced dcache flush code path will follow in later patches.
Signed-off-by: Alexander Graf agraf@csgraf.de Reported-by: Da Xue da@libre.computer
v1 -> v2:
- Remove ifdefs --- drivers/video/Kconfig | 15 +++++++++++++ drivers/video/video-uclass.c | 41 ++++++++++++++++++++++++++++++++++++ include/video.h | 29 +++++++++++++++++++++++-- 3 files changed, 83 insertions(+), 2 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 965b587927..9e1c409b37 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -64,6 +64,21 @@ config VIDEO_COPY To use this, your video driver must set @copy_base in struct video_uc_plat.
+config VIDEO_DAMAGE + bool "Enable damage tracking of frame buffer regions" + depends on DM_VIDEO + default y if ARM && !SYS_DCACHE_OFF + help + On some machines (most ARM), the display frame buffer resides in + RAM. To make the display controller pick up screen updates, we + have to flush frame buffer contents from CPU caches into RAM which + can be a slow operation. + + This patch adds damage tracking to collect information about regions + that received updates. When we want to sync, we then only flush + regions of the frame buffer that were modified before, speeding up + screen refreshes significantly. + config BACKLIGHT_PWM bool "Generic PWM based Backlight Driver" depends on BACKLIGHT && DM_PWM diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 01e8af5ac6..17793490d1 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -21,6 +21,8 @@ #include <dm/device_compat.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> +#include <linux/types.h> +#include <linux/bitmap.h> #ifdef CONFIG_SANDBOX #include <asm/sdl.h> #endif @@ -180,6 +182,45 @@ void video_set_default_colors(struct udevice *dev, bool invert) priv->colour_bg = vid_console_color(priv, back); }
+/* Notify about changes in the frame buffer */ +int video_damage(struct udevice *vid, int x, int y, int width, int height) +{ + struct video_priv *priv = dev_get_uclass_priv(vid); + int endx = x + width; + int endy = y + height; + + if (!CONFIG_IS_ENABLED(VIDEO_DAMAGE)) + return 0; + + if (x > priv->xsize) + return 0; + + if (y > priv->ysize) + return 0; + + if (endx > priv->xsize) + endx = priv->xsize; + + if (endy > priv->ysize) + endy = priv->ysize; + + if (priv->damage.endx && priv->damage.endy) { + /* Span a rectangle across all old and new damage */ + priv->damage.x = min(x, priv->damage.x); + priv->damage.y = min(y, priv->damage.y); + priv->damage.endx = max(endx, priv->damage.endx); + priv->damage.endy = max(endy, priv->damage.endy); + } else { + /* First damage, setting the rectangle to span it */ + priv->damage.x = x; + priv->damage.y = y; + priv->damage.endx = endx; + priv->damage.endy = endy; + } + + return 0; +} + /* Flush video activity to the caches */ int video_sync(struct udevice *vid, bool force) { diff --git a/include/video.h b/include/video.h index 43e2c89977..acb65d70a2 100644 --- a/include/video.h +++ b/include/video.h @@ -109,6 +109,12 @@ struct video_priv { void *fb; int fb_size; void *copy_fb; + struct { + int x; + int y; + int endx; + int endy; + } damage; int line_length; u32 colour_fg; u32 colour_bg; @@ -167,8 +173,9 @@ int video_clear(struct udevice *dev); * @return: 0 on success, error code otherwise * * Some frame buffers are cached or have a secondary frame buffer. This - * function syncs these up so that the current contents of the U-Boot frame - * buffer are displayed to the user. + * function syncs the damaged parts of them up so that the current contents + * of the U-Boot frame buffer are displayed to the user. It clears the damage + * buffer. */ int video_sync(struct udevice *vid, bool force);
@@ -268,6 +275,24 @@ static inline int video_sync_copy_all(struct udevice *dev)
#endif
+/** + * video_damage() - Notify the video subsystem about screen updates. + * + * @vid: Device to sync + * @x: Upper left X coordinate of the damaged rectangle + * @y: Upper left Y coordinate of the damaged rectangle + * @width: Width of the damaged rectangle + * @height: Height of the damaged rectangle + * + * @return: 0 + * + * Some frame buffers are cached or have a secondary frame buffer. This + * function notifies the video subsystem about rectangles that were updated + * within the frame buffer. They may only get written to the screen on the + * next call to video_sync(). + */ +int video_damage(struct udevice *vid, int x, int y, int width, int height); + /** * video_is_active() - Test if one video device it active *
Let's report the video damage when we clear the screen. This way we can later lazily flush only relevant regions to hardware.
Signed-off-by: Alexander Graf agraf@csgraf.de Reported-by: Da Xue da@libre.computer --- drivers/video/video-uclass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 17793490d1..66df4c97ef 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -153,6 +153,8 @@ int video_clear(struct udevice *dev) if (ret) return ret;
+ video_damage(dev, 0, 0, priv->xsize, priv->ysize); + return video_sync(dev, false); }
Now that we have a damage tracking API, let's populate damage done by vidconsole drivers. We try to declare as little memory as damaged as possible, with the exception of rotated screens that I couldn't get my head wrapped around. On those, we revert to the old behavior and mark the full screen as damaged on every update.
v1 -> v2:
- Fix ranges in truetype target - Limit rotate to necessary damange --- drivers/video/console_normal.c | 10 ++++++ drivers/video/console_rotate.c | 54 ++++++++++++++++++++++++++++++++ drivers/video/console_truetype.c | 15 +++++++++ 3 files changed, 79 insertions(+)
diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 04f022491e..5b5586fd3e 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -57,6 +57,9 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) if (ret) return ret;
+ video_damage(dev->parent, 0, VIDEO_FONT_HEIGHT * row, vid_priv->xsize, + VIDEO_FONT_HEIGHT); + return 0; }
@@ -76,6 +79,9 @@ static int console_normal_move_rows(struct udevice *dev, uint rowdst, if (ret) return ret;
+ video_damage(dev->parent, 0, VIDEO_FONT_HEIGHT * rowdst, vid_priv->xsize, + VIDEO_FONT_HEIGHT * count); + return 0; }
@@ -143,6 +149,10 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, } line += vid_priv->line_length; } + + video_damage(dev->parent, VID_TO_PIXEL(x_frac), y, VIDEO_FONT_WIDTH, + VIDEO_FONT_HEIGHT); + ret = vidconsole_sync_copy(dev, start, line); if (ret) return ret; diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 36c8d0609d..56e20bb4f3 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -57,6 +57,12 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) if (ret) return ret;
+ video_damage(dev->parent, + vid_priv->xsize - ((row + 1) * VIDEO_FONT_HEIGHT), + 0, + VIDEO_FONT_HEIGHT, + vid_priv->ysize); + return 0; }
@@ -83,6 +89,12 @@ static int console_move_rows_1(struct udevice *dev, uint rowdst, uint rowsrc, dst += vid_priv->line_length; }
+ video_damage(dev->parent, + vid_priv->xsize - ((rowdst + count) * VIDEO_FONT_HEIGHT), + 0, + count * VIDEO_FONT_HEIGHT, + vid_priv->ysize); + return 0; }
@@ -150,6 +162,12 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
+ video_damage(dev->parent, + vid_priv->xsize - y - VIDEO_FONT_HEIGHT - 1, + linenum - 1, + VIDEO_FONT_HEIGHT, + VIDEO_FONT_WIDTH); + return VID_TO_POS(VIDEO_FONT_WIDTH); }
@@ -199,6 +217,12 @@ static int console_set_row_2(struct udevice *dev, uint row, int clr) if (ret) return ret;
+ video_damage(dev->parent, + 0, + vid_priv->ysize - (row + 1) * VIDEO_FONT_HEIGHT, + vid_priv->xsize, + VIDEO_FONT_HEIGHT); + return 0; }
@@ -218,6 +242,12 @@ static int console_move_rows_2(struct udevice *dev, uint rowdst, uint rowsrc, vidconsole_memmove(dev, dst, src, VIDEO_FONT_HEIGHT * vid_priv->line_length * count);
+ video_damage(dev->parent, + 0, + vid_priv->ysize - (rowdst + count) * VIDEO_FONT_HEIGHT, + vid_priv->xsize, + count * VIDEO_FONT_HEIGHT); + return 0; }
@@ -288,6 +318,12 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
+ video_damage(dev->parent, + x - VIDEO_FONT_WIDTH, + linenum - VIDEO_FONT_HEIGHT + 1, + VIDEO_FONT_WIDTH, + VIDEO_FONT_HEIGHT); + return VID_TO_POS(VIDEO_FONT_WIDTH); }
@@ -335,6 +371,12 @@ static int console_set_row_3(struct udevice *dev, uint row, int clr) if (ret) return ret;
+ video_damage(dev->parent, + row * VIDEO_FONT_HEIGHT, + 0, + VIDEO_FONT_HEIGHT, + vid_priv->ysize); + return 0; }
@@ -359,6 +401,12 @@ static int console_move_rows_3(struct udevice *dev, uint rowdst, uint rowsrc, dst += vid_priv->line_length; }
+ video_damage(dev->parent, + rowdst * VIDEO_FONT_HEIGHT, + 0, + count * VIDEO_FONT_HEIGHT, + vid_priv->ysize); + return 0; }
@@ -424,6 +472,12 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
+ video_damage(dev->parent, + y, + x - VIDEO_FONT_WIDTH + 1, + VIDEO_FONT_HEIGHT, + VIDEO_FONT_WIDTH); + return VID_TO_POS(VIDEO_FONT_WIDTH); }
diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index c04b449a6d..cfeeed71db 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -126,6 +126,7 @@ struct console_tt_priv { static int console_truetype_set_row(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct console_tt_priv *priv = dev_get_priv(dev); void *end, *line; int ret; @@ -168,6 +169,9 @@ static int console_truetype_set_row(struct udevice *dev, uint row, int clr) if (ret) return ret;
+ video_damage(dev->parent, 0, vc_priv->y_charsize * row, vid_priv->xsize, + vc_priv->y_charsize); + return 0; }
@@ -175,6 +179,7 @@ static int console_truetype_move_rows(struct udevice *dev, uint rowdst, uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct console_tt_priv *priv = dev_get_priv(dev); void *dst; void *src; @@ -192,6 +197,9 @@ static int console_truetype_move_rows(struct udevice *dev, uint rowdst, for (i = 0; i < priv->pos_ptr; i++) priv->pos[i].ypos -= diff;
+ video_damage(dev->parent, 0, vc_priv->y_charsize * rowdst, vid_priv->xsize, + vc_priv->y_charsize * count); + return 0; }
@@ -348,6 +356,10 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y,
line += vid_priv->line_length; } + + video_damage(dev->parent, VID_TO_PIXEL(x) + xoff, + y + priv->baseline + yoff, width, height); + ret = vidconsole_sync_copy(dev, start, line); if (ret) return ret; @@ -415,6 +427,9 @@ static int console_truetype_erase(struct udevice *dev, int xstart, int ystart, } line += vid_priv->line_length; } + + video_damage(dev->parent, xstart, ystart, xend - xstart, yend - ystart); + ret = vidconsole_sync_copy(dev, start, line); if (ret) return ret;
Let's report the video damage when we draw a bitmap on the screen. This way we can later lazily flush only relevant regions to hardware.
Signed-off-by: Alexander Graf agraf@csgraf.de Reported-by: Da Xue da@libre.computer --- drivers/video/video_bmp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/video/video_bmp.c b/drivers/video/video_bmp.c index 4d2d961696..da8a7b3701 100644 --- a/drivers/video/video_bmp.c +++ b/drivers/video/video_bmp.c @@ -416,6 +416,8 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, break; };
+ video_damage(dev, x, y, width, height); + /* Find the position of the top left of the image in the framebuffer */ fb = (uchar *)(priv->fb + y * priv->line_length + x * bpix / 8); ret = video_sync_copy(dev, start, fb);
Now that we have a damage tracking API, let's populate damage done by UEFI payloads when they BLT data onto the screen.
v1 -> v2:
- Remove ifdefs from gop --- lib/efi_loader/efi_gop.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 2c81859807..ff08e97d93 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -33,6 +33,7 @@ struct efi_gop_obj { struct efi_gop ops; struct efi_gop_mode_info info; struct efi_gop_mode mode; + struct udevice *vdev; /* Fields we only have access to during init */ u32 bpix; void *fb; @@ -244,6 +245,9 @@ static __always_inline efi_status_t gop_blt_int(struct efi_gop *this, dlineoff += dwidth; }
+ if (IS_ENABLED(CONFIG_DM_VIDEO)) + video_damage(gopobj->vdev, dx, dy, width, height); + return EFI_SUCCESS; }
@@ -481,9 +485,9 @@ efi_status_t efi_gop_register(void) u64 fb_base, fb_size; void *fb; efi_status_t ret; + struct udevice *vdev = NULL;
#ifdef CONFIG_DM_VIDEO - struct udevice *vdev; struct video_priv *priv;
/* We only support a single video output device for now */ @@ -582,6 +586,7 @@ efi_status_t efi_gop_register(void) gopobj->info.pixels_per_scanline = col; gopobj->bpix = bpix; gopobj->fb = fb; + gopobj->vdev = vdev;
Now that we have a damage area tells us which parts of the frame buffer actually need updating, let's only dcache flush those on video_sync() calls. With this optimization in place, frame buffer updates - especially on large screen such as 4k displays - speed up significantly.
v1 -> v2:
- Fix dcache range; we were flushing too much before - Remove ifdefs --- drivers/video/video-uclass.c | 51 ++++++++++++++++++++++++++++++------ 1 file changed, 43 insertions(+), 8 deletions(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 66df4c97ef..95126b9bdb 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -223,9 +223,45 @@ int video_damage(struct udevice *vid, int x, int y, int width, int height) return 0; }
+#if defined(CONFIG_ARM) && !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) +static void video_flush_dcache(struct udevice *vid) +{ + struct video_priv *priv = dev_get_uclass_priv(vid); + + if (!priv->flush_dcache) + return; + + if (!CONFIG_IS_ENABLED(VIDEO_DAMAGE)) { + flush_dcache_range((ulong)priv->fb, + ALIGN((ulong)priv->fb + priv->fb_size, + CONFIG_SYS_CACHELINE_SIZE)); + + return; + } + + if (priv->damage.endx && priv->damage.endy) { + int lstart = priv->damage.x * VNBYTES(priv->bpix); + int lend = priv->damage.endx * VNBYTES(priv->bpix); + int y; + + for (y = priv->damage.y; y < priv->damage.endy; y++) { + ulong fb = (ulong)priv->fb; + ulong start = fb + (y * priv->line_length) + lstart; + ulong end = start + lend - lstart; + + start = ALIGN_DOWN(start, CONFIG_SYS_CACHELINE_SIZE); + end = ALIGN(end, CONFIG_SYS_CACHELINE_SIZE); + + flush_dcache_range(start, end); + } + } +} +#endif + /* Flush video activity to the caches */ int video_sync(struct udevice *vid, bool force) { + struct video_priv *priv = dev_get_uclass_priv(vid); struct video_ops *ops = video_get_ops(vid); int ret;
@@ -241,15 +277,8 @@ int video_sync(struct udevice *vid, bool force) * out whether it exists? For now, ARM is safe. */ #if defined(CONFIG_ARM) && !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) - struct video_priv *priv = dev_get_uclass_priv(vid); - - if (priv->flush_dcache) { - flush_dcache_range((ulong)priv->fb, - ALIGN((ulong)priv->fb + priv->fb_size, - CONFIG_SYS_CACHELINE_SIZE)); - } + video_flush_dcache(vid); #elif defined(CONFIG_VIDEO_SANDBOX_SDL) - struct video_priv *priv = dev_get_uclass_priv(vid); static ulong last_sync;
if (force || get_timer(last_sync) > 100) { @@ -257,6 +286,12 @@ int video_sync(struct udevice *vid, bool force) last_sync = get_timer(0); } #endif + + if (CONFIG_IS_ENABLED(VIDEO_DAMAGE)) { + priv->damage.endx = 0; + priv->damage.endy = 0; + } + return 0; }
CONFIG_VIDEO_COPY implemented a range based copying mechanism: If we print a single character, it will always copy the full range of bytes from the top left corner of the character to the lower right onto the uncached frame buffer. This includes pretty much the full line contents of the printed character.
Since we now have proper damage tracking, let's make use of that to reduce the amount of data we need to copy. With this patch applied, we will only copy the tiny rectangle surrounding characters when we print them, speeding up the video console.
As a bonus, we remove a lot of code.
Signed-off-by: Alexander Graf agraf@csgraf.de --- configs/chromebook_coral_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/video/Kconfig | 8 ++- drivers/video/console_normal.c | 14 +---- drivers/video/console_rotate.c | 37 ++--------- drivers/video/console_truetype.c | 17 +----- drivers/video/vidconsole-uclass.c | 16 ----- drivers/video/video-uclass.c | 91 ++++++++-------------------- drivers/video/video_bmp.c | 7 --- include/video.h | 37 ----------- include/video_console.h | 49 --------------- 15 files changed, 44 insertions(+), 238 deletions(-)
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index 8269254207..21fb493236 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -113,6 +113,7 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_FS_CBFS=y CONFIG_SPL_FS_CBFS=y CONFIG_FAT_WRITE=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 9186621f8d..27578a04c8 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -71,6 +71,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_VIDEO_IVYBRIDGE_IGD=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 93f1d403fa..e913931996 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -75,6 +75,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_TPM=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index c051e00a6a..6a11944d91 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_GENERATE_ACPI_TABLE=y # CONFIG_GZIP is not set diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index c509a924e6..a104e9c9b8 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -292,6 +292,7 @@ CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 35894076c5..978e9ca40e 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -200,6 +200,7 @@ CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_DAMAGE=y CONFIG_DISPLAY=y CONFIG_VIDEO_SEPS525=y CONFIG_LCD=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 9e1c409b37..ebcb4f2707 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -54,12 +54,14 @@ config VIDEO_PCI_DEFAULT_FB_SIZE
config VIDEO_COPY bool "Enable copying the frame buffer to a hardware copy" - depends on DM_VIDEO + depends on DM_VIDEO && VIDEO_DAMAGE help On some machines (e.g. x86), reading from the frame buffer is very slow because it is uncached. To improve performance, this feature allows the frame buffer to be kept in cached memory (allocated by U-Boot) and then copied to the hardware frame-buffer as needed. + It uses the VIDEO_DAMAGE feature to keep track of regions to copy + and will only copy actually touched regions.
To use this, your video driver must set @copy_base in struct video_uc_plat. @@ -74,11 +76,13 @@ config VIDEO_DAMAGE have to flush frame buffer contents from CPU caches into RAM which can be a slow operation.
- This patch adds damage tracking to collect information about regions + This feature adds damage tracking to collect information about regions that received updates. When we want to sync, we then only flush regions of the frame buffer that were modified before, speeding up screen refreshes significantly.
+ It is also used by VIDEO_COPY to identify which regions changed. + config BACKLIGHT_PWM bool "Generic PWM based Backlight Driver" depends on BACKLIGHT && DM_PWM diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 5b5586fd3e..625d14516f 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -18,7 +18,6 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); void *line, *end; int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; - int ret; int i;
line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * vid_priv->line_length; @@ -53,9 +52,6 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) default: return -ENOSYS; } - ret = vidconsole_sync_copy(dev, line, end); - if (ret) - return ret;
video_damage(dev->parent, 0, VIDEO_FONT_HEIGHT * row, vid_priv->xsize, VIDEO_FONT_HEIGHT); @@ -70,14 +66,11 @@ static int console_normal_move_rows(struct udevice *dev, uint rowdst, void *dst; void *src; int size; - int ret;
dst = vid_priv->fb + rowdst * VIDEO_FONT_HEIGHT * vid_priv->line_length; src = vid_priv->fb + rowsrc * VIDEO_FONT_HEIGHT * vid_priv->line_length; size = VIDEO_FONT_HEIGHT * vid_priv->line_length * count; - ret = vidconsole_memmove(dev, dst, src, size); - if (ret) - return ret; + memmove(dst, src, size);
video_damage(dev->parent, 0, VIDEO_FONT_HEIGHT * rowdst, vid_priv->xsize, VIDEO_FONT_HEIGHT * count); @@ -94,7 +87,6 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, int i, row; void *start; void *line; - int ret;
start = vid_priv->fb + y * vid_priv->line_length + VID_TO_PIXEL(x_frac) * VNBYTES(vid_priv->bpix); @@ -153,10 +145,6 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, video_damage(dev->parent, VID_TO_PIXEL(x_frac), y, VIDEO_FONT_WIDTH, VIDEO_FONT_HEIGHT);
- ret = vidconsole_sync_copy(dev, start, line); - if (ret) - return ret; - return VID_TO_POS(VIDEO_FONT_WIDTH); }
diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 56e20bb4f3..9b179a45b6 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -53,9 +53,6 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) } line += vid_priv->line_length; } - ret = vidconsole_sync_copy(dev, start, line); - if (ret) - return ret;
video_damage(dev->parent, vid_priv->xsize - ((row + 1) * VIDEO_FONT_HEIGHT), @@ -81,10 +78,7 @@ static int console_move_rows_1(struct udevice *dev, uint rowdst, uint rowsrc, (rowsrc + count) * VIDEO_FONT_HEIGHT * pbytes;
for (j = 0; j < vid_priv->ysize; j++) { - ret = vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * pbytes * count); - if (ret) - return ret; + memmove(dst, src, VIDEO_FONT_HEIGHT * pbytes * count); src += vid_priv->line_length; dst += vid_priv->line_length; } @@ -158,10 +152,6 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) mask >>= 1; } /* We draw backwards from 'start, so account for the first line */ - ret = vidconsole_sync_copy(dev, start - vid_priv->line_length, line); - if (ret) - return ret; - video_damage(dev->parent, vid_priv->xsize - y - VIDEO_FONT_HEIGHT - 1, linenum - 1, @@ -213,9 +203,6 @@ static int console_set_row_2(struct udevice *dev, uint row, int clr) default: return -ENOSYS; } - ret = vidconsole_sync_copy(dev, start, end); - if (ret) - return ret;
video_damage(dev->parent, 0, @@ -239,8 +226,8 @@ static int console_move_rows_2(struct udevice *dev, uint rowdst, uint rowsrc, vid_priv->line_length; src = end - (rowsrc + count) * VIDEO_FONT_HEIGHT * vid_priv->line_length; - vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * vid_priv->line_length * count); + memmove(dev, dst, src, VIDEO_FONT_HEIGHT * + vid_priv->line_length * count);
video_damage(dev->parent, 0, @@ -313,10 +300,6 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) } line -= vid_priv->line_length; } - /* Add 4 bytes to allow for the first pixel writen */ - ret = vidconsole_sync_copy(dev, start + 4, line); - if (ret) - return ret;
video_damage(dev->parent, x - VIDEO_FONT_WIDTH, @@ -367,9 +350,6 @@ static int console_set_row_3(struct udevice *dev, uint row, int clr) } line += vid_priv->line_length; } - ret = vidconsole_sync_copy(dev, start, line); - if (ret) - return ret;
video_damage(dev->parent, row * VIDEO_FONT_HEIGHT, @@ -387,16 +367,13 @@ static int console_move_rows_3(struct udevice *dev, uint rowdst, uint rowsrc, int pbytes = VNBYTES(vid_priv->bpix); void *dst; void *src; - int j, ret; + int j;
dst = vid_priv->fb + rowdst * VIDEO_FONT_HEIGHT * pbytes; src = vid_priv->fb + rowsrc * VIDEO_FONT_HEIGHT * pbytes;
for (j = 0; j < vid_priv->ysize; j++) { - ret = vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * pbytes * count); - if (ret) - return ret; + memmove(dev, dst, src, VIDEO_FONT_HEIGHT * pbytes * count); src += vid_priv->line_length; dst += vid_priv->line_length; } @@ -468,10 +445,6 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) mask >>= 1; } /* Add a line to allow for the first pixels writen */ - ret = vidconsole_sync_copy(dev, start + vid_priv->line_length, line); - if (ret) - return ret; - video_damage(dev->parent, y, x - VIDEO_FONT_WIDTH + 1, diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index cfeeed71db..beaea07a1d 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -165,9 +165,6 @@ static int console_truetype_set_row(struct udevice *dev, uint row, int clr) default: return -ENOSYS; } - ret = vidconsole_sync_copy(dev, line, end); - if (ret) - return ret;
video_damage(dev->parent, 0, vc_priv->y_charsize * row, vid_priv->xsize, vc_priv->y_charsize); @@ -183,14 +180,11 @@ static int console_truetype_move_rows(struct udevice *dev, uint rowdst, struct console_tt_priv *priv = dev_get_priv(dev); void *dst; void *src; - int i, diff, ret; + int i, diff;
dst = vid_priv->fb + rowdst * priv->font_size * vid_priv->line_length; src = vid_priv->fb + rowsrc * priv->font_size * vid_priv->line_length; - ret = vidconsole_memmove(dev, dst, src, priv->font_size * - vid_priv->line_length * count); - if (ret) - return ret; + memmove(dev, dst, src, priv->font_size * vid_priv->line_length * count);
/* Scroll up our position history */ diff = (rowsrc - rowdst) * priv->font_size; @@ -360,9 +354,6 @@ static int console_truetype_putc_xy(struct udevice *dev, uint x, uint y, video_damage(dev->parent, VID_TO_PIXEL(x) + xoff, y + priv->baseline + yoff, width, height);
- ret = vidconsole_sync_copy(dev, start, line); - if (ret) - return ret; free(data);
return width_frac; @@ -430,10 +421,6 @@ static int console_truetype_erase(struct udevice *dev, int xstart, int ystart,
- ret = vidconsole_sync_copy(dev, start, line); - if (ret) - return ret; - return 0; }
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index f42db40d4c..6292777c7a 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -656,22 +656,6 @@ UCLASS_DRIVER(vidconsole) = { .per_device_auto = sizeof(struct vidconsole_priv), };
-#ifdef CONFIG_VIDEO_COPY -int vidconsole_sync_copy(struct udevice *dev, void *from, void *to) -{ - struct udevice *vid = dev_get_parent(dev); - - return video_sync_copy(vid, from, to); -} - -int vidconsole_memmove(struct udevice *dev, void *dst, const void *src, - int size) -{ - memmove(dst, src, size); - return vidconsole_sync_copy(dev, dst, dst + size); -} -#endif - #if CONFIG_IS_ENABLED(CMD_VIDCONSOLE) void vidconsole_position_cursor(struct udevice *dev, unsigned col, unsigned row) { diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 95126b9bdb..6dffa5be81 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -124,7 +124,6 @@ int video_reserve(ulong *addrp) int video_clear(struct udevice *dev) { struct video_priv *priv = dev_get_uclass_priv(dev); - int ret;
switch (priv->bpix) { case VIDEO_BPP16: @@ -149,9 +148,6 @@ int video_clear(struct udevice *dev) memset(priv->fb, priv->colour_bg, priv->fb_size); break; } - ret = video_sync_copy(dev, priv->fb, priv->fb + priv->fb_size); - if (ret) - return ret;
@@ -258,6 +254,27 @@ static void video_flush_dcache(struct udevice *vid) } #endif
+static void video_flush_copy(struct udevice *vid) +{ + struct video_priv *priv = dev_get_uclass_priv(vid); + + if (!priv->copy_fb) + return; + + if (priv->damage.endx && priv->damage.endy) { + int lstart = priv->damage.x * VNBYTES(priv->bpix); + int lend = priv->damage.endx * VNBYTES(priv->bpix); + int y; + + for (y = priv->damage.y; y < priv->damage.endy; y++) { + ulong offset = (y * priv->line_length) + lstart; + ulong len = lend - lstart; + + memcpy(priv->copy_fb + offset, priv->fb + offset, len); + } + } +} + /* Flush video activity to the caches */ int video_sync(struct udevice *vid, bool force) { @@ -265,6 +282,9 @@ int video_sync(struct udevice *vid, bool force) struct video_ops *ops = video_get_ops(vid); int ret;
+ if (CONFIG_IS_ENABLED(VIDEO_COPY)) + video_flush_copy(vid); + if (ops && ops->video_sync) { ret = ops->video_sync(vid); if (ret) @@ -339,69 +359,6 @@ int video_get_ysize(struct udevice *dev) return priv->ysize; }
-#ifdef CONFIG_VIDEO_COPY -int video_sync_copy(struct udevice *dev, void *from, void *to) -{ - struct video_priv *priv = dev_get_uclass_priv(dev); - - if (priv->copy_fb) { - long offset, size; - - /* Find the offset of the first byte to copy */ - if ((ulong)to > (ulong)from) { - size = to - from; - offset = from - priv->fb; - } else { - size = from - to; - offset = to - priv->fb; - } - - /* - * Allow a bit of leeway for valid requests somewhere near the - * frame buffer - */ - if (offset < -priv->fb_size || offset > 2 * priv->fb_size) { -#ifdef DEBUG - char str[120]; - - snprintf(str, sizeof(str), - "[** FAULT sync_copy fb=%p, from=%p, to=%p, offset=%lx]", - priv->fb, from, to, offset); - console_puts_select_stderr(true, str); -#endif - return -EFAULT; - } - - /* - * Silently crop the memcpy. This allows callers to avoid doing - * this themselves. It is common for the end pointer to go a - * few lines after the end of the frame buffer, since most of - * the update algorithms terminate a line after their last write - */ - if (offset + size > priv->fb_size) { - size = priv->fb_size - offset; - } else if (offset < 0) { - size += offset; - offset = 0; - } - - memcpy(priv->copy_fb + offset, priv->fb + offset, size); - } - - return 0; -} - -int video_sync_copy_all(struct udevice *dev) -{ - struct video_priv *priv = dev_get_uclass_priv(dev); - - video_sync_copy(dev, priv->fb, priv->fb + priv->fb_size); - - return 0; -} - -#endif - #define SPLASH_DECL(_name) \ extern u8 __splash_ ## _name ## _begin[]; \ extern u8 __splash_ ## _name ## _end[] diff --git a/drivers/video/video_bmp.c b/drivers/video/video_bmp.c index da8a7b3701..8281a83449 100644 --- a/drivers/video/video_bmp.c +++ b/drivers/video/video_bmp.c @@ -244,7 +244,6 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, enum video_format eformat; struct bmp_color_table_entry *palette; int hdr_size; - int ret;
if (!bmp || !(bmp->header.signature[0] == 'B' && bmp->header.signature[1] == 'M')) { @@ -418,11 +417,5 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y,
- /* Find the position of the top left of the image in the framebuffer */ - fb = (uchar *)(priv->fb + y * priv->line_length + x * bpix / 8); - ret = video_sync_copy(dev, start, fb); - if (ret) - return log_ret(ret); - return video_sync(dev, false); } diff --git a/include/video.h b/include/video.h index acb65d70a2..11b81952f5 100644 --- a/include/video.h +++ b/include/video.h @@ -238,43 +238,6 @@ void video_set_flush_dcache(struct udevice *dev, bool flush); */ void video_set_default_colors(struct udevice *dev, bool invert);
-#ifdef CONFIG_VIDEO_COPY -/** - * vidconsole_sync_copy() - Sync back to the copy framebuffer - * - * This ensures that the copy framebuffer has the same data as the framebuffer - * for a particular region. It should be called after the framebuffer is updated - * - * @from and @to can be in either order. The region between them is synced. - * - * @dev: Vidconsole device being updated - * @from: Start/end address within the framebuffer (->fb) - * @to: Other address within the frame buffer - * Return: 0 if OK, -EFAULT if the start address is before the start of the - * frame buffer start - */ -int video_sync_copy(struct udevice *dev, void *from, void *to); - -/** - * video_sync_copy_all() - Sync the entire framebuffer to the copy - * - * @dev: Vidconsole device being updated - * Return: 0 (always) - */ -int video_sync_copy_all(struct udevice *dev); -#else -static inline int video_sync_copy(struct udevice *dev, void *from, void *to) -{ - return 0; -} - -static inline int video_sync_copy_all(struct udevice *dev) -{ - return 0; -} - -#endif - /** * video_damage() - Notify the video subsystem about screen updates. * diff --git a/include/video_console.h b/include/video_console.h index 5921767fbf..ff674821f8 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -256,53 +256,4 @@ void vidconsole_position_cursor(struct udevice *dev, unsigned col, */ u32 vid_console_color(struct video_priv *priv, unsigned int idx);
-#ifdef CONFIG_VIDEO_COPY -/** - * vidconsole_sync_copy() - Sync back to the copy framebuffer - * - * This ensures that the copy framebuffer has the same data as the framebuffer - * for a particular region. It should be called after the framebuffer is updated - * - * @from and @to can be in either order. The region between them is synced. - * - * @dev: Vidconsole device being updated - * @from: Start/end address within the framebuffer (->fb) - * @to: Other address within the frame buffer - * Return: 0 if OK, -EFAULT if the start address is before the start of the - * frame buffer start - */ -int vidconsole_sync_copy(struct udevice *dev, void *from, void *to); - -/** - * vidconsole_memmove() - Perform a memmove() within the frame buffer - * - * This handles a memmove(), e.g. for scrolling. It also updates the copy - * framebuffer. - * - * @dev: Vidconsole device being updated - * @dst: Destination address within the framebuffer (->fb) - * @src: Source address within the framebuffer (->fb) - * @size: Number of bytes to transfer - * Return: 0 if OK, -EFAULT if the start address is before the start of the - * frame buffer start - */ -int vidconsole_memmove(struct udevice *dev, void *dst, const void *src, - int size); -#else -static inline int vidconsole_sync_copy(struct udevice *dev, void *from, - void *to) -{ - return 0; -} - -static inline int vidconsole_memmove(struct udevice *dev, void *dst, - const void *src, int size) -{ - memmove(dst, src, size); - - return 0; -} - -#endif - #endif
Series tested on RPi4, thanks a lot!
Tested-by: Matthias Brugger mbrugger@suse.com
v1 -> v2:
- Remove ifdefs
Alexander Graf
Matthias Brugger
