[U-Boot] [PATCH] dm: atmel: Add driver model support for the ehci driver
Add driver model support while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
drivers/usb/host/Kconfig | 7 +++ drivers/usb/host/ehci-atmel.c | 108 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 115 insertions(+)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index d2363c8..ed36bac 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -60,6 +60,13 @@ config USB_EHCI
if USB_EHCI_HCD
+config USB_EHCI_ATMEL + bool "Support for Atmel on-chip EHCI USB controller" + depends on ARCH_AT91 + default y + ---help--- + Enables support for the on-chip EHCI controller on Atmel chips. + config USB_EHCI_MARVELL bool "Support for MVEBU (AXP / A38x) on-chip EHCI USB controller" depends on ARCH_MVEBU diff --git a/drivers/usb/host/ehci-atmel.c b/drivers/usb/host/ehci-atmel.c index 1d7d280..94f3927 100644 --- a/drivers/usb/host/ehci-atmel.c +++ b/drivers/usb/host/ehci-atmel.c @@ -7,12 +7,18 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> #include <usb.h> #include <asm/io.h> #include <asm/arch/clk.h>
#include "ehci.h"
+DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_DM_USB + int ehci_hcd_init(int index, enum usb_init_type init, struct ehci_hccr **hccr, struct ehci_hcor **hcor) { @@ -41,3 +47,105 @@ int ehci_hcd_stop(int index)
return 0; } + +#else + +struct ehci_atmel_priv { + struct ehci_ctrl ehci; +}; + +static int ehci_atmel_enable_clk(struct udevice *dev) +{ + struct udevice *clkdev; + int periph; + int ret; + + ret = clk_get_by_index(dev, 0, &clkdev); + if (ret) + return ret; + + ret = clk_enable(clkdev, 0); + if (ret) + return ret; + + ret = clk_get_by_index(dev, 1, &clkdev); + if (ret) + return -EINVAL; + + periph = fdtdec_get_uint(gd->fdt_blob, clkdev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + clkdev = dev_get_parent(clkdev); + if (!clkdev) + return -ENODEV; + + ret = clk_enable(clkdev, periph); + if (ret) + return ret; + + return 0; +} + +static int ehci_atmel_probe(struct udevice *dev) +{ + struct ehci_hccr *hccr; + struct ehci_hcor *hcor; + fdt_addr_t hcd_base; + int ret; + + ret = ehci_atmel_enable_clk(dev); + if (ret) { + debug("Failed to enable USB Host clock\n"); + return ret; + } + + /* + * Get the base address for EHCI controller from the device node + */ + hcd_base = dev_get_addr(dev); + if (hcd_base == FDT_ADDR_T_NONE) { + debug("Can't get the EHCI register base address\n"); + return -ENXIO; + } + + hccr = (struct ehci_hccr *)hcd_base; + hcor = (struct ehci_hcor *) + ((u32)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + debug("echi-atmel: init hccr %x and hcor %x hc_length %d\n", + (u32)hccr, (u32)hcor, + (u32)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); +} + +static int ehci_atmel_remove(struct udevice *dev) +{ + int ret; + + ret = ehci_deregister(dev); + if (ret) + return ret; + + return 0; +} + +static const struct udevice_id ehci_usb_ids[] = { + { .compatible = "atmel,at91sam9g45-ehci", }, + { } +}; + +U_BOOT_DRIVER(ehci_atmel) = { + .name = "ehci_atmel", + .id = UCLASS_USB, + .of_match = ehci_usb_ids, + .probe = ehci_atmel_probe, + .remove = ehci_atmel_remove, + .ops = &ehci_usb_ops, + .platdata_auto_alloc_size = sizeof(struct usb_platdata), + .priv_auto_alloc_size = sizeof(struct ehci_atmel_priv), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; + +#endif
+Stephen
But note that this may require a rebase due to:
Wenyou Yang
