Re: [DNX#2006040142000044] [U-Boot-Users] [U-Boot-Users][Patch] Nand writing [...]
1 Apr
2006
1 Apr
'06
12:20 a.m.
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000044] was created:
<snip>
This patch fixes a problem when writing an amount of data superior to a block size. Writing part seems to be correct. But when re-booting the board, bad block scan is performed and blocks following the first one you wrote are marked bad...
The problem seems to be in nand_write_ecc function in drivers/nand/nand_base.c source file where oob variable is not reset after reaching a block boundary, so that wrong values are written in next block oobs.
Hope it's clear enough...
This patch is applied against testing-NAND git branch.
CHANGELOG Patch by Nicolas Lacressonniere 31 January 2006
- Fix bad block scan problem when writing an amount of data superior to
nand block size
</snip>
Your U-Boot support team
6980
DENX Support System
