[U-Boot] [u-boot 2/2] drivers/fsl-mc: Support DPSPARSER object and apply spb command
Add support for DPSPARSER object (create/destroy, open/close, apply spb) required to configure Soft Parser by using MC. Also add uboot command to apply a Soft Parser Blob by using a command like: fsl_mc apply spb <spb_load_addr>
Signed-off-by: Florinel Iordache florinel.iordache@nxp.com --- drivers/net/fsl-mc/Kconfig | 12 ++ drivers/net/fsl-mc/Makefile | 4 +- drivers/net/fsl-mc/dpsparser.c | 138 ++++++++++++++++++++ drivers/net/fsl-mc/mc.c | 272 +++++++++++++++++++++++++++++++++++++--- include/fsl-mc/fsl_dpsparser.h | 208 ++++++++++++++++++++++++++++++ include/fsl-mc/fsl_mc_private.h | 17 ++- 6 files changed, 629 insertions(+), 22 deletions(-) create mode 100644 drivers/net/fsl-mc/dpsparser.c create mode 100644 include/fsl-mc/fsl_dpsparser.h
diff --git a/drivers/net/fsl-mc/Kconfig b/drivers/net/fsl-mc/Kconfig index 25a2cb8..2cf651d 100644 --- a/drivers/net/fsl-mc/Kconfig +++ b/drivers/net/fsl-mc/Kconfig @@ -22,4 +22,16 @@ config SYS_MC_RSV_MEM_ALIGN Reserved memory needs to be aligned for MC to use. Default value is 512MB.
+config MC_DRAM_SPB_OFFSET + hex "Soft Parser SPB DRAM offset" + default 0x00F40000 + help + Set the DRAM offset for Soft Parser Blob. + +config MC_SPB_MAX_SIZE + hex "Soft Parser SPB maximum size" + default 0x00020000 + help + Set the maximum size for Soft Parser Blob. + endif # FSL_MC_ENET diff --git a/drivers/net/fsl-mc/Makefile b/drivers/net/fsl-mc/Makefile index 1b1b4a7..5a1acd5 100644 --- a/drivers/net/fsl-mc/Makefile +++ b/drivers/net/fsl-mc/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright 2014 Freescale Semiconductor, Inc. +# Copyright 2018 NXP
# Layerscape MC driver obj-y += mc.o \ @@ -9,5 +10,6 @@ obj-y += mc.o \ dprc.o \ dpbp.o \ dpni.o \ - dpmac.o + dpmac.o \ + dpsparser.o obj-y += dpio/ diff --git a/drivers/net/fsl-mc/dpsparser.c b/drivers/net/fsl-mc/dpsparser.c new file mode 100644 index 0000000..cfd1ba6 --- /dev/null +++ b/drivers/net/fsl-mc/dpsparser.c @@ -0,0 +1,138 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Data Path Soft Parser + * + * Copyright 2018 NXP + */ +#include <fsl-mc/fsl_mc_sys.h> +#include <fsl-mc/fsl_mc_cmd.h> +#include <fsl-mc/fsl_dpsparser.h> + +int dpsparser_open(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 *token) +{ + struct mc_command cmd = { 0 }; + int err; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_OPEN, + cmd_flags, + 0); + + /* send command to mc*/ + err = mc_send_command(mc_io, &cmd); + if (err) + return err; + + /* retrieve response parameters */ + *token = MC_CMD_HDR_READ_TOKEN(cmd.header); + + return err; +} + +int dpsparser_close(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 token) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_CLOSE, cmd_flags, + token); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} + +int dpsparser_create(struct fsl_mc_io *mc_io, + u16 token, + u32 cmd_flags, + u32 *obj_id) +{ + struct mc_command cmd = { 0 }; + int err; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_CREATE, + cmd_flags, + token); + + /* send command to mc*/ + err = mc_send_command(mc_io, &cmd); + if (err) + return err; + + /* retrieve response parameters */ + MC_CMD_READ_OBJ_ID(cmd, *obj_id); + + return 0; +} + +int dpsparser_destroy(struct fsl_mc_io *mc_io, + u16 token, + u32 cmd_flags, + u32 obj_id) +{ + struct mc_command cmd = { 0 }; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_DESTROY, + cmd_flags, + token); + + /* set object id to destroy */ + CMD_DESTROY_SET_OBJ_ID_PARAM0(cmd, obj_id); + + /* send command to mc*/ + return mc_send_command(mc_io, &cmd); +} + +int dpsparser_apply_spb(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 token, + u64 blob_addr, + u16 *error) +{ + struct mc_command cmd = { 0 }; + int err; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_APPLY_SPB, + cmd_flags, + token); + DPSPARSER_CMD_BLOB_SET_ADDR(cmd, blob_addr); + + /* send command to mc*/ + err = mc_send_command(mc_io, &cmd); + if (err) + return err; + + /* retrieve response parameters: MC error code */ + DPSPARSER_CMD_BLOB_REPORT_ERROR(cmd, *error); + + return 0; +} + +int dpsparser_get_api_version(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 *major_ver, + u16 *minor_ver) +{ + struct mc_command cmd = { 0 }; + int err; + + /* prepare command */ + cmd.header = mc_encode_cmd_header(DPSPARSER_CMDID_GET_API_VERSION, + cmd_flags, 0); + + /* send command to mc */ + err = mc_send_command(mc_io, &cmd); + if (err) + return err; + + /* retrieve response parameters */ + mc_cmd_read_api_version(&cmd, major_ver, minor_ver); + + return 0; +} diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index cc59b21..ab269b5 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -1,7 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2017 NXP * Copyright 2017-2018 NXP */ #include <common.h> @@ -18,6 +17,7 @@ #include <fsl-mc/fsl_dprc.h> #include <fsl-mc/fsl_dpio.h> #include <fsl-mc/fsl_dpni.h> +#include <fsl-mc/fsl_dpsparser.h> #include <fsl-mc/fsl_qbman_portal.h> #include <fsl-mc/ldpaa_wriop.h>
@@ -32,6 +32,7 @@
DECLARE_GLOBAL_DATA_PTR; static int mc_memset_resv_ram; +static struct mc_version mc_ver_info; static int mc_boot_status = -1; static int mc_dpl_applied = -1; #ifdef CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET @@ -46,6 +47,9 @@ struct fsl_dpbp_obj *dflt_dpbp = NULL; struct fsl_dpio_obj *dflt_dpio = NULL; struct fsl_dpni_obj *dflt_dpni = NULL; static u64 mc_lazy_dpl_addr; +static u32 dpsparser_obj_id; +static u16 dpsparser_handle; +static char *mc_err_msg_apply_spb[] = MC_ERROR_MSG_APPLY_SPB;
#ifdef DEBUG void dump_ram_words(const char *title, void *addr) @@ -281,6 +285,16 @@ static int mc_fixup_dpl_mac_addr(void *blob, int dpmac_id, MC_FIXUP_DPL); }
+void fdt_fixup_mc_ddr(u64 *base, u64 *size) +{ + u64 mc_size = mc_get_dram_block_size(); + + if (mc_size < MC_DRAM_BLOCK_DEFAULT_SIZE) { + *base = mc_get_dram_addr() + mc_size; + *size = MC_DRAM_BLOCK_DEFAULT_SIZE - mc_size; + } +} + void fdt_fsl_mc_fixup_iommu_map_entry(void *blob) { u32 *prop; @@ -678,7 +692,6 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) const void *raw_image_addr; size_t raw_image_size = 0; #endif - struct mc_version mc_ver_info; u8 mc_ram_num_256mb_blocks; size_t mc_ram_size = mc_get_dram_block_size();
@@ -1434,6 +1447,170 @@ err: return err; }
+static bool is_dpsparser_supported(void) +{ + /* dpsparser support was first introduced in MC version: 10.12.0 */ + if (mc_ver_info.major < 10) + return false; + if (mc_ver_info.major == 10) + return (mc_ver_info.minor >= 12); + return true; +} + +static int dpsparser_version_check(struct fsl_mc_io *mc_io) +{ + int error; + u16 major_ver, minor_ver; + + if (!is_dpsparser_supported()) + return 0; + + error = dpsparser_get_api_version(mc_io, 0, + &major_ver, + &minor_ver); + if (error < 0) { + printf("dpsparser_get_api_version() failed: %d\n", error); + return error; + } + + if (major_ver < DPSPARSER_VER_MAJOR || (major_ver == + DPSPARSER_VER_MAJOR && minor_ver < DPSPARSER_VER_MINOR)) { + printf("DPSPARSER version mismatch found %u.%u,", + major_ver, minor_ver); + printf("supported version is %u.%u\n", + DPSPARSER_VER_MAJOR, DPSPARSER_VER_MINOR); + } + + return error; +} + +static int dpsparser_init(void) +{ + int err = 0; + + if (!is_dpsparser_supported()) + return 0; + + err = dpsparser_create(dflt_mc_io, + dflt_dprc_handle, + MC_CMD_NO_FLAGS, + &dpsparser_obj_id); + if (err) + printf("dpsparser_create() failed\n"); + + err = dpsparser_version_check(dflt_mc_io); + if (err < 0) { + printf("dpsparser_version_check() failed: %d\n", err); + goto err_version_check; + } + + err = dpsparser_open(dflt_mc_io, + MC_CMD_NO_FLAGS, + &dpsparser_handle); + if (err < 0) { + printf("dpsparser_open() failed: %d\n", err); + goto err_open; + } + + return err; + +err_open: +err_version_check: + dpsparser_destroy(dflt_mc_io, + dflt_dprc_handle, + MC_CMD_NO_FLAGS, dpsparser_obj_id); + + return err; +} + +#ifdef DPSPARSER_DESTROY +/* TODO: refactoring needed in the future to allow DPSPARSER object destroy + * Workaround: DO NOT destroy DPSPARSER object because it needs to be available + * on Apply DPL + */ +static int dpsparser_exit(void) +{ + int err; + + if (!is_dpsparser_supported()) + return 0; + + dpsparser_close(dflt_mc_io, MC_CMD_NO_FLAGS, dpsparser_handle); + if (err < 0) { + printf("dpsparser_close() failed: %d\n", err); + goto err; + } + + err = dpsparser_destroy(dflt_mc_io, dflt_dprc_handle, + MC_CMD_NO_FLAGS, dpsparser_obj_id); + if (err < 0) { + printf("dpsparser_destroy() failed: %d\n", err); + goto err; + } + return 0; + +err: + return err; +} +#endif + +int mc_apply_spb(u64 mc_spb_addr) +{ + int err = 0; + u16 error, err_arr_size; + u64 mc_spb_offset; + u32 spb_size; + struct sp_blob_header *sp_blob; + u64 mc_ram_addr = mc_get_dram_addr(); + + if (!is_dpsparser_supported()) + return 0; + + if (!mc_spb_addr) { + printf("fsl-mc: Invalid Blob address\n"); + return -1; + } + +#ifdef CONFIG_MC_DRAM_SPB_OFFSET + mc_spb_offset = CONFIG_MC_DRAM_SPB_OFFSET; +#else +#error "CONFIG_MC_DRAM_SPB_OFFSET not defined" +#endif + + // Read blob header and get size of SPB blob + sp_blob = (struct sp_blob_header *)mc_spb_addr; + spb_size = le32_to_cpu(sp_blob->length); + if (spb_size > CONFIG_MC_SPB_MAX_SIZE) { + printf("\nfsl-mc: ERROR: Bad SPB image (too large: %d)\n", + spb_size); + return -EINVAL; + } + + mc_copy_image("MC SP Blob", mc_spb_addr, spb_size, + mc_ram_addr + mc_spb_offset); + + //Invoke MC command to apply SPB blob + printf("fsl-mc: Applying soft parser blob... "); + err = dpsparser_apply_spb(dflt_mc_io, MC_CMD_NO_FLAGS, dpsparser_handle, + mc_spb_offset, &error); + if (err) + return err; + + if (error == 0) { + printf("SUCCESS\n"); + } else { + printf("FAILED with error code = %d:\n", error); + err_arr_size = (u16)ARRAY_SIZE(mc_err_msg_apply_spb); + + if (error > 0 && error < err_arr_size) + printf(mc_err_msg_apply_spb[error]); + else + printf(MC_ERROR_MSG_SPB_UNKNOWN); + } + + return err; +} + static int mc_init_object(void) { int err = 0; @@ -1462,6 +1639,12 @@ static int mc_init_object(void) goto err; }
+ err = dpsparser_init(); + if (err < 0) { + printf("dpsparser_init() failed: %d\n", err); + goto err; + } + return 0; err: return err; @@ -1595,39 +1778,87 @@ static int do_fsl_mc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } break;
- case 'l': + case 'l': { + /* lazyapply */ + u64 mc_dpl_addr; + + if (argc < 4) + goto usage; + + if (get_dpl_apply_status() == 0) { + printf("fsl-mc: DPL already applied\n"); + return err; + } + + mc_dpl_addr = simple_strtoull(argv[3], NULL, 16); + + if (get_mc_boot_status() != 0) { + printf("fsl-mc: Deploying data path layout .."); + printf("ERROR (MC is not booted)\n"); + return -ENODEV; + } + + /* + * We will do the actual dpaa exit and dpl apply + * later from announce_and_cleanup(). + */ + mc_lazy_dpl_addr = mc_dpl_addr; + break; + } + case 'a': { - u64 mc_dpl_addr; + /* apply */ + char sub_cmd; + u64 mc_apply_addr;
- if (argc < 4) - goto usage; + if (argc < 4) + goto usage; + + sub_cmd = argv[2][0];
+ switch (sub_cmd) { + case 'd': + case 'D': if (get_dpl_apply_status() == 0) { printf("fsl-mc: DPL already applied\n"); return err; } - - mc_dpl_addr = simple_strtoull(argv[3], NULL, - 16); - if (get_mc_boot_status() != 0) { printf("fsl-mc: Deploying data path layout .."); printf("ERROR (MC is not booted)\n"); return -ENODEV; }
- if (argv[1][0] == 'l') { - /* - * We will do the actual dpaa exit and dpl apply - * later from announce_and_cleanup(). - */ - mc_lazy_dpl_addr = mc_dpl_addr; - } else { - /* The user wants it applied now */ - if (!fsl_mc_ldpaa_exit(NULL)) - err = mc_apply_dpl(mc_dpl_addr); + mc_apply_addr = simple_strtoull(argv[3], NULL, 16); + + /* The user wants DPL applied now */ + if (!fsl_mc_ldpaa_exit(NULL)) + err = mc_apply_dpl(mc_apply_addr); + break; + + case 's': + if (!is_dpsparser_supported()) { + printf("fsl-mc: apply spb command .. "); + printf("ERROR: requires at least MC 10.12.0\n"); + return err; } + if (get_mc_boot_status() != 0) { + printf("fsl-mc: Deploying Soft Parser Blob..."); + printf("ERROR (MC is not booted)\n"); + return err; + } + + mc_apply_addr = simple_strtoull(argv[3], NULL, 16); + + /* Apply spb (Soft Parser Blob) */ + err = mc_apply_spb(mc_apply_addr); break; + + default: + printf("Invalid option: %s\n", argv[2]); + goto usage; + } + break; } default: printf("Invalid option: %s\n", argv[1]); @@ -1645,6 +1876,7 @@ U_BOOT_CMD( "start mc [FW_addr] [DPC_addr] - Start Management Complex\n" "fsl_mc apply DPL [DPL_addr] - Apply DPL file\n" "fsl_mc lazyapply DPL [DPL_addr] - Apply DPL file on exit\n" + "fsl_mc apply spb [spb_addr] - Apply SPB Soft Parser Blob\n" "fsl_mc start aiop [FW_addr] - Start AIOP\n" );
diff --git a/include/fsl-mc/fsl_dpsparser.h b/include/fsl-mc/fsl_dpsparser.h new file mode 100644 index 0000000..48fb495 --- /dev/null +++ b/include/fsl-mc/fsl_dpsparser.h @@ -0,0 +1,208 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Data Path Soft Parser API + * + * Copyright 2018 NXP + */ +#ifndef _FSL_DPSPARSER_H +#define _FSL_DPSPARSER_H + +/* DPSPARSER last supported API version */ +#define DPSPARSER_VER_MAJOR 1 +#define DPSPARSER_VER_MINOR 0 + +/* Command IDs */ +#define DPSPARSER_CMDID_CLOSE 0x8001 +#define DPSPARSER_CMDID_OPEN 0x8111 +#define DPSPARSER_CMDID_CREATE 0x9111 +#define DPSPARSER_CMDID_DESTROY 0x9911 +#define DPSPARSER_CMDID_GET_API_VERSION 0xa111 + +#define DPSPARSER_CMDID_APPLY_SPB 0x1181 + +/* cmd, param, offset, width, type, arg_name */ +#define DPSPARSER_CMD_BLOB_SET_ADDR(cmd, addr) \ + MC_CMD_OP(cmd, 0, 0, 64, u64, addr) + +/* cmd, param, offset, width, type, arg_name */ +#define DPSPARSER_CMD_BLOB_REPORT_ERROR(cmd, err) \ + MC_RSP_OP(cmd, 0, 0, 16, u16, err) + +/* Data Path Soft Parser API + * Contains initialization APIs and runtime control APIs for DPSPARSER + */ + +struct fsl_mc_io; + +/* MC Unknown error: */ +#define MC_ERROR_MSG_SPB_UNKNOWN "Unknown MC error\n" + +/* MC Error messages (in order for each error code defined above): */ +#define MC_ERROR_MSG_APPLY_SPB \ +{ \ + "OK\n", \ + "BLOB : Magic number does not match\n", \ + "BLOB : Version does not match MC API version\n", \ + "BLOB : IP revision does not match HW revision\n", \ + "BLOB : Blob length is not a multiple of 4\n", \ + "BLOB : Invalid length detected\n", \ + "BLOB : Name length < 0 in 'blob-name'\n", \ + "BLOB : Name length not a 4 multiple in 'blob-name'\n", \ + "BLOB : No target HW parser selected\n", \ + "BLOB : SP size is negative\n", \ + "BLOB : Size is zero\n", \ + "BLOB : Number of protocols is negative\n", \ + "BLOB : Zero protocols\n", \ + "BLOB : Protocol name is null\n", \ + "BLOB : SP 'seq-start' is not in [0x40, 0xffc0) range\n", \ + "BLOB : Invalid base protocol\n", \ + "BLOB : Invalid parameters section\n", \ + "BLOB : Invalid parameter\n", \ + "BLOB : Invalid parameter configuration\n", \ + "BLOB : Not aligned value\n", \ + "BLOB : Invalid section TAG detected\n", \ + "BLOB : Section size is zero\n", \ + "BLOB : Section size not a 4 multiple\n", \ + "BLOB : Section size is too big\n", \ + "BLOB : No 'bytecode' section before\n", \ + "BLOB : No 'sp-protocols' section before\n", \ + "BLOB : No 'bytecode' section defined\n", \ + "BLOB : No 'sp-protocols' section defined\n", \ + "BLOB : Soft Parser BLOB parsing : Error detected\n", \ + "apply spb : Soft Parser BLOB is already applied\n", \ + "apply spb : BLOB address is not set\n", \ + "BLOB : SP parameter offset is not a 4 multiple\n", \ + "BLOB : SP parameter offset can't be less than 0x40\n", \ + "BLOB : Bytecode size is not a 4 multiple\n", \ + "BLOB : Bytecode size cannot be zero\n", \ + "BLOB : Bytecode can't overwrite the 0xFFE address\n", \ + "BLOB : No hardware parser selected as target\n", \ + "BLOB : Bytecode overlap detected\n", \ + "BLOB : No parser support\n", \ + "BLOB : Too many bytecode sections on WRIOP ingress\n", \ + "BLOB : Too many bytecode sections on WRIOP egress\n", \ + "BLOB : Too many bytecode sections on AIOP\n", \ + "BLOB : Duplicated protocol is already registered\n", \ + "BLOB : Maximum number of allowed protocols was exceeded\n", \ + "BLOB : Protocols limit exceeded\n", \ + "BLOB : Protocol is linked twice\n", \ + "BLOB : Soft parser is linked twice\n", \ + "BLOB : Parameter offset exceeds the maximum parameters limit\n", \ + "BLOB : Parameter size can't be 0 or greater than 64\n", \ + "BLOB : Parameter offset plus size exceeds the maximum limit\n", \ + "BLOB : Parameters number exceeds the maximum limit\n", \ + "BLOB : Duplicated parameter name\n", \ + "BLOB : Parameters overlapped detected\n", \ + "apply spb : No dpsparser handle.\n", \ + \ + MC_ERROR_MSG_SPB_UNKNOWN, \ + NULL, \ +} + +/** + * dpsparser_open() - Open a control session for the specified object. + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @token: Returned token; use in subsequent API calls + * + * This function can be used to open a control session for an + * already created object; an object may have been declared in + * the DPL or by calling the dpsparser_create function. + * This function returns a unique authentication token, + * associated with the specific object ID and the specific MC + * portal; this token must be used in all subsequent commands for + * this specific object + * + * Return: '0' on Success; Error code otherwise. + */ +int dpsparser_open(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 *token); + +/** + * dpsparser_close() - Close the control session of the object + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @token: Token of DPSPARSER object + * + * After this function is called, no further operations are + * allowed on the object without opening a new control session. + * + * Return: '0' on Success; Error code otherwise. + */ +int dpsparser_close(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 token); + +/** + * dpsparser_create() - Create the DPSPARSER object. + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @token: Returned token; use in subsequent API calls + * + * Create the DPSPARSER object, allocate required resources and + * perform required initialization. + * + * The object can be created either by declaring it in the + * DPL file, or by calling this function. + * This function returns a unique authentication token, + * associated with the specific object ID and the specific MC + * portal; this token must be used in all subsequent calls to + * this specific object. For objects that are created using the + * DPL file, call dpsparser_open function to get an authentication + * token first. + * + * Return: '0' on Success; Error code otherwise. + */ +int dpsparser_create(struct fsl_mc_io *mc_io, + u16 token, + u32 cmd_flags, + u32 *obj_id); + +/** + * dpsparser_destroy() - Destroy the DPSPARSER object and release all its + * resources. + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @token: Token of DPSPARSER object + * + * Return: '0' on Success; error code otherwise. + */ +int dpsparser_destroy(struct fsl_mc_io *mc_io, + u16 token, + u32 cmd_flags, + u32 obj_id); + +/** + * dpsparser_apply_spb() - Applies the Soft Parser Blob loaded at specified + * address. + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @token: Token of DPSPARSER object + * @blob_addr: Blob loading address + * @error: Error reported by MC related to SP Blob parsing and apply + * + * Return: '0' on Success; error code otherwise. + */ +int dpsparser_apply_spb(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 token, + u64 blob_addr, + u16 *error); + +/** + * dpsparser_get_api_version - Retrieve DPSPARSER Major and Minor version info. + * + * @mc_io: Pointer to MC portal's I/O object + * @cmd_flags: Command flags; one or more of 'MC_CMD_FLAG_' + * @major_ver: DPSPARSER major version + * @minor_ver: DPSPARSER minor version + * + * Return: '0' on Success; Error code otherwise. + */ +int dpsparser_get_api_version(struct fsl_mc_io *mc_io, + u32 cmd_flags, + u16 *major_ver, + u16 *minor_ver); + +#endif /* _FSL_DPSPARSER_H */ diff --git a/include/fsl-mc/fsl_mc_private.h b/include/fsl-mc/fsl_mc_private.h index ba0bc37..28b6d45 100644 --- a/include/fsl-mc/fsl_mc_private.h +++ b/include/fsl-mc/fsl_mc_private.h @@ -1,7 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2014-2016 Freescale Semiconductor, Inc. - * Copyright 2017 NXP + * Copyright 2017-2018 NXP */
#ifndef _FSL_MC_PRIVATE_H_ @@ -65,7 +65,22 @@ struct fsl_dpni_obj {
extern struct fsl_dpni_obj *dflt_dpni;
+/** + * struct sp_blob_header - SP Blob header structure + * @magic: SP Blob magic number + * @blob_ver: SP Blob version + * @ip_rev: SP IP revision + * @length: Length of the SP Blob + */ +struct sp_blob_header { + u32 magic; + u32 blob_ver; + u32 ip_rev; + u32 length; +}; + int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr); int ldpaa_eth_init(int dpmac_id, phy_interface_t enet_if); int mc_apply_dpl(u64 mc_dpl_addr); +int mc_apply_spb(u64 mc_spb_addr); #endif /* _FSL_MC_PRIVATE_H_ */
Dear Joe,
-----Original Message----- From: Florinel Iordache Sent: Wednesday, May 15, 2019 2:40 PM To: u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Florinel Iordache florinel.iordache@nxp.com Subject: [u-boot 2/2] drivers/fsl-mc: Support DPSPARSER object and apply spb command
<spb_load_addr>
drivers/net/fsl-mc/Kconfig | 12 ++ drivers/net/fsl-mc/Makefile | 4 +- drivers/net/fsl-mc/dpsparser.c | 138 ++++++++++++++++++++ drivers/net/fsl-mc/mc.c | 272 +++++++++++++++++++++++++++++++++++++--- include/fsl-mc/fsl_dpsparser.h | 208 ++++++++++++++++++++++++++++++ include/fsl-mc/fsl_mc_private.h | 17 ++- 6 files changed, 629 insertions(+), 22 deletions(-) create mode 100644 drivers/net/fsl-mc/dpsparser.c create mode 100644 include/fsl- mc/fsl_dpsparser.h
Can you please help with reviews and acceptance of this patch-set. I am delegating to you .
http://patchwork.ozlabs.org/patch/1099898/ http://patchwork.ozlabs.org/patch/1099900/
--pk
On Wed, May 15, 2019 at 4:10 AM Florinel Iordache florinel.iordache@nxp.com wrote:
<spb_load_addr>
<spb_load_addr>
int err = 0;
u64 mc_spb_offset;
u32 spb_size;
if (!mc_spb_addr) {
return -1;
spb_size);
return -EINVAL;
This function is only available #ifndef CONFIG_SYS_LS_MC_FW_IN_DDR
This is breaking the ls2080a_emu build.
if (err)
return err;
if (error == 0) {
} else {
else
return err;
On Tue, Jul 9, 2019 at 3:33 PM Joe Hershberger joe.hershberger@gmail.com wrote:
<spb_load_addr>
int err = 0;
u64 mc_spb_offset;
u32 spb_size;
if (!mc_spb_addr) {
return -1;
spb_size);
return -EINVAL;
Any update or should I drop this series from the release?
Thanks, -Joe
if (err)
return err;
if (error == 0) {
} else {
else
return err;
Florinel Iordache
Joe Hershberger
Prabhakar Kushwaha
