[U-Boot] [PATCH v1 0/3] video: add STM32 LTDC display controller
Version 1: - Initial commit
The purpose of this set of patches is to add the STM32 LTDC display controller support. In preamble, a configuration switch is added for pwm-based backlights and a new gpio-based backlight driver is proposed.
Patrick Delaunay (2): dm: backlight: Add CONFIG_BACKLIGHT_PWM dm: backlight: Add a driver for GPIO backlight
Philippe CORNU (1): video: add STM32 LTDC display controller
drivers/video/Kconfig | 23 +++ drivers/video/Makefile | 6 +- drivers/video/backlight_gpio.c | 74 +++++++ drivers/video/stm32/Kconfig | 44 +++++ drivers/video/stm32/Makefile | 10 + drivers/video/stm32/stm32_ltdc.c | 406 +++++++++++++++++++++++++++++++++++++++ 6 files changed, 560 insertions(+), 3 deletions(-) create mode 100644 drivers/video/backlight_gpio.c create mode 100644 drivers/video/stm32/Kconfig create mode 100644 drivers/video/stm32/Makefile create mode 100644 drivers/video/stm32/stm32_ltdc.c
Add a config to select individually the driver for PWM backlights. Manage "depends on" to be backyard compatible.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- drivers/video/Kconfig | 11 +++++++++++ drivers/video/Makefile | 4 +--- 2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 61dfed8..da23d39 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -14,6 +14,17 @@ config DM_VIDEO option compiles in the video uclass and routes all LCD/video access through this.
+config BACKLIGHT_PWM + bool "Generic PWM based Backlight Driver" + depends on DM_VIDEO && DM_PWM + default y + help + If you have a LCD backlight adjustable by PWM, say Y to enable + this driver. + This driver can be use with "simple-panel" and + it understands the standard device tree + (leds/backlight/pwm-backlight.txt) + config VIDEO_BPP8 bool "Support 8-bit-per-pixel displays" depends on DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index ac5371f..3839433 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -11,9 +11,7 @@ obj-$(CONFIG_DM_VIDEO) += backlight-uclass.o obj-$(CONFIG_DM_VIDEO) += panel-uclass.o simple_panel.o obj-$(CONFIG_DM_VIDEO) += video-uclass.o vidconsole-uclass.o obj-$(CONFIG_DM_VIDEO) += video_bmp.o -ifdef CONFIG_DM_VIDEO -obj-$(CONFIG_DM_PWM) += pwm_backlight.o -endif +obj-$(CONFIG_BACKLIGHT_PWM) += pwm_backlight.o obj-$(CONFIG_CONSOLE_NORMAL) += console_normal.o obj-$(CONFIG_CONSOLE_ROTATION) += console_rotate.o obj-$(CONFIG_CONSOLE_TRUETYPE) += console_truetype.o fonts/
Add a driver for GPIO backlights. It understands the standard device tree binding. It can be used with simple-panel when PWM is not necessary.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- drivers/video/Kconfig | 10 ++++++ drivers/video/Makefile | 1 + drivers/video/backlight_gpio.c | 74 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 85 insertions(+) create mode 100644 drivers/video/backlight_gpio.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index da23d39..32dc8ea 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -25,6 +25,16 @@ config BACKLIGHT_PWM it understands the standard device tree (leds/backlight/pwm-backlight.txt)
+config BACKLIGHT_GPIO + bool "Generic GPIO based Backlight Driver" + depends on DM_VIDEO + help + If you have a LCD backlight adjustable by GPIO, say Y to enable + this driver. + This driver can be used with "simple-panel" and + it understands the standard device tree + (leds/backlight/gpio-backlight.txt) + config VIDEO_BPP8 bool "Support 8-bit-per-pixel displays" depends on DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 3839433..d6df709 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_DM_VIDEO) += panel-uclass.o simple_panel.o obj-$(CONFIG_DM_VIDEO) += video-uclass.o vidconsole-uclass.o obj-$(CONFIG_DM_VIDEO) += video_bmp.o obj-$(CONFIG_BACKLIGHT_PWM) += pwm_backlight.o +obj-$(CONFIG_BACKLIGHT_GPIO) += backlight_gpio.o obj-$(CONFIG_CONSOLE_NORMAL) += console_normal.o obj-$(CONFIG_CONSOLE_ROTATION) += console_rotate.o obj-$(CONFIG_CONSOLE_TRUETYPE) += console_truetype.o fonts/ diff --git a/drivers/video/backlight_gpio.c b/drivers/video/backlight_gpio.c new file mode 100644 index 0000000..772df5d --- /dev/null +++ b/drivers/video/backlight_gpio.c @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2017, STMicroelectronics - All Rights Reserved + * Author: Patrick Delaunay patrick.delaunay@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <backlight.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct gpio_backlight_priv { + struct gpio_desc gpio; + bool def_value; +}; + +static int gpio_backlight_enable(struct udevice *dev) +{ + struct gpio_backlight_priv *priv = dev_get_priv(dev); + + dm_gpio_set_value(&priv->gpio, 1); + + return 0; +} + +static int gpio_backlight_ofdata_to_platdata(struct udevice *dev) +{ + struct gpio_backlight_priv *priv = dev_get_priv(dev); + int ret; + + ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, + GPIOD_IS_OUT); + if (ret) { + debug("%s: Warning: cannot get GPIO: ret=%d\n", + __func__, ret); + return ret; + } + + priv->def_value = dev_read_bool(dev, "default-on"); + + return 0; +} + +static int gpio_backlight_probe(struct udevice *dev) +{ + struct gpio_backlight_priv *priv = dev_get_priv(dev); + + if (priv->def_value) + gpio_backlight_enable(dev); + + return 0; +} + +static const struct backlight_ops gpio_backlight_ops = { + .enable = gpio_backlight_enable, +}; + +static const struct udevice_id gpio_backlight_ids[] = { + { .compatible = "gpio-backlight" }, + { } +}; + +U_BOOT_DRIVER(gpio_backlight) = { + .name = "gpio_backlight", + .id = UCLASS_PANEL_BACKLIGHT, + .of_match = gpio_backlight_ids, + .ops = &gpio_backlight_ops, + .ofdata_to_platdata = gpio_backlight_ofdata_to_platdata, + .probe = gpio_backlight_probe, + .priv_auto_alloc_size = sizeof(struct gpio_backlight_priv), +};
The STM32 LTDC display controller provides a parallel digital RGB and signals for horizontal, vertical synchronization, Pixel Clock and Data Enable as output to interface directly to a variety of LCD and TFT panels.
The LTDC main features are: - 24-bit RGB Parallel Pixel Output, Programmable timings & polarity for HSync, VSync and Data Enable. - 2 layers with Blending, Color Keying, Window position & size, Dithering, Background color, Color Look-Up Table (CLUT). - Supported layer color formats: ARGB8888, RGB888, RGB565, ARGB1555, ARGB4444, L8 CLUT, AL44 & AL88
This LTDC driver: - supports: RGB parallel output with timings & polarity, 1 layer in RGB565. - supports but with hard-coded configurations: blending, window position & size (crop), background color. - does not support yet: rgb888, argb8888, 8-bit clut, dithering.
This LTDC driver is compatible with all stm32 platforms with the LTDC IP and has been tested on stm32 f746-disco board.
Signed-off-by: Philippe CORNU philippe.cornu@st.com --- drivers/video/Kconfig | 2 + drivers/video/Makefile | 1 + drivers/video/stm32/Kconfig | 44 +++++ drivers/video/stm32/Makefile | 10 + drivers/video/stm32/stm32_ltdc.c | 406 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 463 insertions(+) create mode 100644 drivers/video/stm32/Kconfig create mode 100644 drivers/video/stm32/Makefile create mode 100644 drivers/video/stm32/stm32_ltdc.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 32dc8ea..ecaf613 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -457,6 +457,8 @@ config VIDEO_SANDBOX_SDL console device and can display stdout output. Within U-Boot is is a normal bitmap display and can display images as well as text.
+source "drivers/video/stm32/Kconfig" + config VIDEO_TEGRA20 bool "Enable LCD support on Tegra20" depends on OF_CONTROL diff --git a/drivers/video/Makefile b/drivers/video/Makefile index d6df709..a1a5309 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -60,6 +60,7 @@ obj-$(CONFIG_VIDEO_DW_HDMI) += dw_hdmi.o obj-${CONFIG_VIDEO_TEGRA124} += tegra124/ obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ +obj-${CONFIG_VIDEO_STM32} += stm32/
obj-y += bridge/ obj-y += sunxi/ diff --git a/drivers/video/stm32/Kconfig b/drivers/video/stm32/Kconfig new file mode 100644 index 0000000..113a2bb --- /dev/null +++ b/drivers/video/stm32/Kconfig @@ -0,0 +1,44 @@ +# +# Copyright (C) STMicroelectronics SA 2017 +# +# Authors: Philippe Cornu philippe.cornu@st.com +# Yannick Fertre yannick.fertre@st.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +menuconfig VIDEO_STM32 + bool "Enable STM32 video support" + depends on DM_VIDEO + help + STM32 supports many video output options including RGB and + DSI. This option enables these supports which can be used on + devices which have RGB TFT or DSI display connected. + +config VIDEO_STM32_MAX_XRES + int "Maximum horizontal resolution (for memory allocation purposes)" + depends on VIDEO_STM32 + default 640 + help + The maximum horizontal resolution to support for the framebuffer. + This configuration is used for reserving/allocating memory for the + framebuffer during device-model binding/probing. + +config VIDEO_STM32_MAX_YRES + int "Maximum vertical resolution (for memory allocation purposes)" + depends on VIDEO_STM32 + default 480 + help + The maximum vertical resolution to support for the framebuffer. + This configuration is used for reserving/allocating memory for the + framebuffer during device-model binding/probing. + +config VIDEO_STM32_MAX_BPP + int "Maximum bits per pixel (for memory allocation purposes)" + depends on VIDEO_STM32 + default 16 + help + The maximum bits per pixel to support for the framebuffer. + This configuration is used for reserving/allocating memory for the + framebuffer during device-model binding/probing. + diff --git a/drivers/video/stm32/Makefile b/drivers/video/stm32/Makefile new file mode 100644 index 0000000..372a2e1 --- /dev/null +++ b/drivers/video/stm32/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) STMicroelectronics SA 2017 +# +# Authors: Philippe Cornu philippe.cornu@st.com +# Yannick Fertre yannick.fertre@st.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-${CONFIG_VIDEO_STM32} = stm32_ltdc.o diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c new file mode 100644 index 0000000..b417ac2 --- /dev/null +++ b/drivers/video/stm32/stm32_ltdc.c @@ -0,0 +1,406 @@ +/* + * Copyright (C) STMicroelectronics SA 2017 + * + * Authors: Philippe Cornu philippe.cornu@st.com + * Yannick Fertre yannick.fertre@st.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <panel.h> +#include <video.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct stm32_ltdc_priv { + void __iomem *regs; + struct display_timing timing; + enum video_log2_bpp l2bpp; + u32 bg_col_argb; + u32 crop_x, crop_y, crop_w, crop_h; + u32 alpha; +}; + +/* LTDC main registers */ +#define LTDC_IDR 0x00 /* IDentification */ +#define LTDC_LCR 0x04 /* Layer Count */ +#define LTDC_SSCR 0x08 /* Synchronization Size Configuration */ +#define LTDC_BPCR 0x0C /* Back Porch Configuration */ +#define LTDC_AWCR 0x10 /* Active Width Configuration */ +#define LTDC_TWCR 0x14 /* Total Width Configuration */ +#define LTDC_GCR 0x18 /* Global Control */ +#define LTDC_GC1R 0x1C /* Global Configuration 1 */ +#define LTDC_GC2R 0x20 /* Global Configuration 2 */ +#define LTDC_SRCR 0x24 /* Shadow Reload Configuration */ +#define LTDC_GACR 0x28 /* GAmma Correction */ +#define LTDC_BCCR 0x2C /* Background Color Configuration */ +#define LTDC_IER 0x34 /* Interrupt Enable */ +#define LTDC_ISR 0x38 /* Interrupt Status */ +#define LTDC_ICR 0x3C /* Interrupt Clear */ +#define LTDC_LIPCR 0x40 /* Line Interrupt Position Conf. */ +#define LTDC_CPSR 0x44 /* Current Position Status */ +#define LTDC_CDSR 0x48 /* Current Display Status */ + +/* LTDC layer 1 registers */ +#define LTDC_L1LC1R 0x80 /* L1 Layer Configuration 1 */ +#define LTDC_L1LC2R 0x84 /* L1 Layer Configuration 2 */ +#define LTDC_L1CR 0x84 /* L1 Control */ +#define LTDC_L1WHPCR 0x88 /* L1 Window Hor Position Config */ +#define LTDC_L1WVPCR 0x8C /* L1 Window Vert Position Config */ +#define LTDC_L1CKCR 0x90 /* L1 Color Keying Configuration */ +#define LTDC_L1PFCR 0x94 /* L1 Pixel Format Configuration */ +#define LTDC_L1CACR 0x98 /* L1 Constant Alpha Config */ +#define LTDC_L1DCCR 0x9C /* L1 Default Color Configuration */ +#define LTDC_L1BFCR 0xA0 /* L1 Blend Factors Configuration */ +#define LTDC_L1FBBCR 0xA4 /* L1 FrameBuffer Bus Control */ +#define LTDC_L1AFBCR 0xA8 /* L1 AuxFB Control */ +#define LTDC_L1CFBAR 0xAC /* L1 Color FrameBuffer Address */ +#define LTDC_L1CFBLR 0xB0 /* L1 Color FrameBuffer Length */ +#define LTDC_L1CFBLNR 0xB4 /* L1 Color FrameBuffer Line Nb */ +#define LTDC_L1AFBAR 0xB8 /* L1 AuxFB Address */ +#define LTDC_L1AFBLR 0xBC /* L1 AuxFB Length */ +#define LTDC_L1AFBLNR 0xC0 /* L1 AuxFB Line Number */ +#define LTDC_L1CLUTWR 0xC4 /* L1 CLUT Write */ + +/* Bit definitions */ +#define SSCR_VSH GENMASK(10, 0) /* Vertical Synchronization Height */ +#define SSCR_HSW GENMASK(27, 16) /* Horizontal Synchronization Width */ + +#define BPCR_AVBP GENMASK(10, 0) /* Accumulated Vertical Back Porch */ +#define BPCR_AHBP GENMASK(27, 16) /* Accumulated Horizontal Back Porch */ + +#define AWCR_AAH GENMASK(10, 0) /* Accumulated Active Height */ +#define AWCR_AAW GENMASK(27, 16) /* Accumulated Active Width */ + +#define TWCR_TOTALH GENMASK(10, 0) /* TOTAL Height */ +#define TWCR_TOTALW GENMASK(27, 16) /* TOTAL Width */ + +#define GCR_LTDCEN BIT(0) /* LTDC ENable */ +#define GCR_DEN BIT(16) /* Dither ENable */ +#define GCR_PCPOL BIT(28) /* Pixel Clock POLarity-Inverted */ +#define GCR_DEPOL BIT(29) /* Data Enable POLarity-High */ +#define GCR_VSPOL BIT(30) /* Vertical Synchro POLarity-High */ +#define GCR_HSPOL BIT(31) /* Horizontal Synchro POLarity-High */ + +#define GC1R_WBCH GENMASK(3, 0) /* Width of Blue CHannel output */ +#define GC1R_WGCH GENMASK(7, 4) /* Width of Green Channel output */ +#define GC1R_WRCH GENMASK(11, 8) /* Width of Red Channel output */ +#define GC1R_PBEN BIT(12) /* Precise Blending ENable */ +#define GC1R_DT GENMASK(15, 14) /* Dithering Technique */ +#define GC1R_GCT GENMASK(19, 17) /* Gamma Correction Technique */ +#define GC1R_SHREN BIT(21) /* SHadow Registers ENabled */ +#define GC1R_BCP BIT(22) /* Background Colour Programmable */ +#define GC1R_BBEN BIT(23) /* Background Blending ENabled */ +#define GC1R_LNIP BIT(24) /* Line Number IRQ Position */ +#define GC1R_TP BIT(25) /* Timing Programmable */ +#define GC1R_IPP BIT(26) /* IRQ Polarity Programmable */ +#define GC1R_SPP BIT(27) /* Sync Polarity Programmable */ +#define GC1R_DWP BIT(28) /* Dither Width Programmable */ +#define GC1R_STREN BIT(29) /* STatus Registers ENabled */ +#define GC1R_BMEN BIT(31) /* Blind Mode ENabled */ + +#define GC2R_EDCA BIT(0) /* External Display Control Ability */ +#define GC2R_STSAEN BIT(1) /* Slave Timing Sync Ability ENabled */ +#define GC2R_DVAEN BIT(2) /* Dual-View Ability ENabled */ +#define GC2R_DPAEN BIT(3) /* Dual-Port Ability ENabled */ +#define GC2R_BW GENMASK(6, 4) /* Bus Width (log2 of nb of bytes) */ +#define GC2R_EDCEN BIT(7) /* External Display Control ENabled */ + +#define SRCR_IMR BIT(0) /* IMmediate Reload */ +#define SRCR_VBR BIT(1) /* Vertical Blanking Reload */ + +#define LXCR_LEN BIT(0) /* Layer ENable */ +#define LXCR_COLKEN BIT(1) /* Color Keying Enable */ +#define LXCR_CLUTEN BIT(4) /* Color Look-Up Table ENable */ + +#define LXWHPCR_WHSTPOS GENMASK(11, 0) /* Window Horizontal StarT POSition */ +#define LXWHPCR_WHSPPOS GENMASK(27, 16) /* Window Horizontal StoP POSition */ + +#define LXWVPCR_WVSTPOS GENMASK(10, 0) /* Window Vertical StarT POSition */ +#define LXWVPCR_WVSPPOS GENMASK(26, 16) /* Window Vertical StoP POSition */ + +#define LXPFCR_PF GENMASK(2, 0) /* Pixel Format */ + +#define LXCACR_CONSTA GENMASK(7, 0) /* CONSTant Alpha */ + +#define LXBFCR_BF2 GENMASK(2, 0) /* Blending Factor 2 */ +#define LXBFCR_BF1 GENMASK(10, 8) /* Blending Factor 1 */ + +#define LXCFBLR_CFBLL GENMASK(12, 0) /* Color Frame Buffer Line Length */ +#define LXCFBLR_CFBP GENMASK(28, 16) /* Color Frame Buffer Pitch in bytes */ + +#define LXCFBLNR_CFBLN GENMASK(10, 0) /* Color Frame Buffer Line Number */ + +#define BF1_PAXCA 0x600 /* Pixel Alpha x Constant Alpha */ +#define BF2_1PAXCA 0x007 /* 1 - (Pixel Alpha x Constant Alpha) */ + +enum stm32_ltdc_pix_fmt { + PF_ARGB8888 = 0, + PF_RGB888, + PF_RGB565, + PF_ARGB1555, + PF_ARGB4444, + PF_L8, + PF_AL44, + PF_AL88 +}; + +/* TODO add more color format support */ +static u32 stm32_ltdc_get_pixel_format(enum video_log2_bpp l2bpp) +{ + enum stm32_ltdc_pix_fmt pf; + + switch (l2bpp) { + case VIDEO_BPP16: + pf = PF_RGB565; + break; + + case VIDEO_BPP1: + case VIDEO_BPP2: + case VIDEO_BPP4: + case VIDEO_BPP8: + case VIDEO_BPP32: + default: + debug("%s: warning %dbpp not supported yet, %dbpp instead\n", + __func__, VNBITS(l2bpp), VNBITS(VIDEO_BPP16)); + pf = PF_RGB565; + break; + } + + debug("%s: %d bpp -> ltdc pf %d\n", __func__, VNBITS(l2bpp), pf); + + return (u32)pf; +} + +static void stm32_ltdc_enable(struct stm32_ltdc_priv *priv) +{ + /* Reload configuration immediately & enable LTDC */ + setbits_le32(priv->regs + LTDC_SRCR, SRCR_IMR); + setbits_le32(priv->regs + LTDC_GCR, GCR_LTDCEN); +} + +static void stm32_ltdc_set_mode(struct stm32_ltdc_priv *priv) +{ + void __iomem *regs = priv->regs; + struct display_timing *timing = &priv->timing; + u32 hsync, vsync, acc_hbp, acc_vbp, acc_act_w, acc_act_h; + u32 total_w, total_h; + u32 val; + + /* Convert video timings to ltdc timings */ + hsync = timing->hsync_len.typ - 1; + vsync = timing->vsync_len.typ - 1; + acc_hbp = hsync + timing->hback_porch.typ; + acc_vbp = vsync + timing->vback_porch.typ; + acc_act_w = acc_hbp + timing->hactive.typ; + acc_act_h = acc_vbp + timing->vactive.typ; + total_w = acc_act_w + timing->hfront_porch.typ; + total_h = acc_act_h + timing->vfront_porch.typ; + + /* Synchronization sizes */ + val = (hsync << 16) | vsync; + clrsetbits_le32(regs + LTDC_SSCR, SSCR_VSH | SSCR_HSW, val); + + /* Accumulated back porch */ + val = (acc_hbp << 16) | acc_vbp; + clrsetbits_le32(regs + LTDC_BPCR, BPCR_AVBP | BPCR_AHBP, val); + + /* Accumulated active width */ + val = (acc_act_w << 16) | acc_act_h; + clrsetbits_le32(regs + LTDC_AWCR, AWCR_AAW | AWCR_AAH, val); + + /* Total width & height */ + val = (total_w << 16) | total_h; + clrsetbits_le32(regs + LTDC_TWCR, TWCR_TOTALH | TWCR_TOTALW, val); + + /* Signal polarities */ + val = 0; + debug("%s: timing->flags 0x%08x\n", __func__, timing->flags); + if (timing->flags & DISPLAY_FLAGS_HSYNC_HIGH) + val |= GCR_HSPOL; + if (timing->flags & DISPLAY_FLAGS_VSYNC_HIGH) + val |= GCR_VSPOL; + if (timing->flags & DISPLAY_FLAGS_DE_HIGH) + val |= GCR_DEPOL; + if (timing->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) + val |= GCR_PCPOL; + clrsetbits_le32(regs + LTDC_GCR, + GCR_HSPOL | GCR_VSPOL | GCR_DEPOL | GCR_PCPOL, val); + + /* Overall background color */ + writel(priv->bg_col_argb, priv->regs + LTDC_BCCR); +} + +static void stm32_ltdc_set_layer1(struct stm32_ltdc_priv *priv, ulong fb_addr) +{ + void __iomem *regs = priv->regs; + u32 x0, x1, y0, y1; + u32 pitch_in_bytes; + u32 line_length; + u32 bus_width; + u32 val, tmp, bpp; + + x0 = priv->crop_x; + x1 = priv->crop_x + priv->crop_w - 1; + y0 = priv->crop_y; + y1 = priv->crop_y + priv->crop_h - 1; + + /* Horizontal start and stop position */ + tmp = (readl(regs + LTDC_BPCR) & BPCR_AHBP) >> 16; + val = ((x1 + 1 + tmp) << 16) + (x0 + 1 + tmp); + clrsetbits_le32(regs + LTDC_L1WHPCR, LXWHPCR_WHSTPOS | LXWHPCR_WHSPPOS, + val); + + /* Vertical start & stop position */ + tmp = readl(regs + LTDC_BPCR) & BPCR_AVBP; + val = ((y1 + 1 + tmp) << 16) + (y0 + 1 + tmp); + clrsetbits_le32(regs + LTDC_L1WVPCR, LXWVPCR_WVSTPOS | LXWVPCR_WVSPPOS, + val); + + /* Layer background color */ + writel(priv->bg_col_argb, regs + LTDC_L1DCCR); + + /* Color frame buffer pitch in bytes & line length */ + bpp = VNBITS(priv->l2bpp); + pitch_in_bytes = priv->crop_w * (bpp >> 3); + bus_width = 8 << ((readl(regs + LTDC_GC2R) & GC2R_BW) >> 4); + line_length = ((bpp >> 3) * priv->crop_w) + (bus_width >> 3) - 1; + val = (pitch_in_bytes << 16) | line_length; + clrsetbits_le32(regs + LTDC_L1CFBLR, LXCFBLR_CFBLL | LXCFBLR_CFBP, val); + + /* Pixel format */ + val = stm32_ltdc_get_pixel_format(priv->l2bpp); + clrsetbits_le32(regs + LTDC_L1PFCR, LXPFCR_PF, val); + + /* Constant alpha value */ + clrsetbits_le32(regs + LTDC_L1CACR, LXCACR_CONSTA, priv->alpha); + + /* Blending factors */ + clrsetbits_le32(regs + LTDC_L1BFCR, LXBFCR_BF2 | LXBFCR_BF1, + BF1_PAXCA | BF2_1PAXCA); + + /* Frame buffer line number */ + clrsetbits_le32(regs + LTDC_L1CFBLNR, LXCFBLNR_CFBLN, priv->crop_h); + + /* Frame buffer address */ + writel(fb_addr, regs + LTDC_L1CFBAR); + + /* Enable layer 1 */ + setbits_le32(priv->regs + LTDC_L1CR, LXCR_LEN); +} + +static int stm32_ltdc_probe(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct stm32_ltdc_priv *priv = dev_get_priv(dev); + struct udevice *panel; + struct clk pclk, pxclk; + int ret; + + priv->regs = (void *)dev_read_addr(dev); + if ((fdt_addr_t)priv->regs == FDT_ADDR_T_NONE) { + debug("%s: ltdc dt register address error\n", __func__); + return -EINVAL; + } + + ret = uclass_first_device(UCLASS_PANEL, &panel); + if (ret) { + debug("%s: panel device error %d\n", __func__, ret); + return ret; + } + + ret = panel_enable_backlight(panel); + if (ret) { + debug("%s: panel %s enable backlight error %d\n", + __func__, panel->name, ret); + return ret; + } + + ret = fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(dev), + 0, &priv->timing); + if (ret) { + debug("%s: decode display timing error %d\n", __func__, ret); + return -EINVAL; + } + + ret = clk_get_by_name(dev, "pclk", &pclk); + if (ret) { + debug("%s: peripheral clock get error %d\n", __func__, ret); + return ret; + } + + ret = clk_enable(&pclk); + if (ret) { + debug("%s: peripheral clock enable error %d\n", __func__, ret); + return ret; + } + + /* Verify pixel clock value if any & inform user accordingly */ + ret = clk_get_by_name(dev, "pxclk", &pxclk); + if (!ret) { + if (clk_get_rate(&pxclk) != priv->timing.pixelclock.typ) + printf("Warning: please adjust ltdc pixel clock\n"); + } + + /* TODO Below parameters are hard-coded for the moment... */ + priv->l2bpp = VIDEO_BPP16; + priv->bg_col_argb = 0xFFFFFFFF; /* white no transparency */ + priv->crop_x = 0; + priv->crop_y = 0; + priv->crop_w = priv->timing.hactive.typ; + priv->crop_h = priv->timing.vactive.typ; + priv->alpha = 0xFF; + + debug("%s: %dx%d %dbpp frame buffer at 0x%lx\n", __func__, + priv->timing.hactive.typ, priv->timing.vactive.typ, + VNBITS(priv->l2bpp), uc_plat->base); + debug("%s: crop %d,%d %dx%d bg 0x%08x alpha %d\n", __func__, + priv->crop_x, priv->crop_y, priv->crop_w, priv->crop_h, + priv->bg_col_argb, priv->alpha); + + /* Configure & start LTDC */ + stm32_ltdc_set_mode(priv); + stm32_ltdc_set_layer1(priv, uc_plat->base); + stm32_ltdc_enable(priv); + + uc_priv->xsize = priv->timing.hactive.typ; + uc_priv->ysize = priv->timing.vactive.typ; + uc_priv->bpix = priv->l2bpp; + + video_set_flush_dcache(dev, true); + + return 0; +} + +static int stm32_ltdc_bind(struct udevice *dev) +{ + struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); + + uc_plat->size = CONFIG_VIDEO_STM32_MAX_XRES * + CONFIG_VIDEO_STM32_MAX_YRES * + (CONFIG_VIDEO_STM32_MAX_BPP >> 3); + debug("%s: frame buffer max size %d bytes\n", __func__, uc_plat->size); + + return 0; +} + +static const struct udevice_id stm32_ltdc_ids[] = { + { .compatible = "st,stm32-ltdc" }, + { } +}; + +U_BOOT_DRIVER(stm32_ltdc) = { + .name = "stm32_ltdc", + .id = UCLASS_VIDEO, + .of_match = stm32_ltdc_ids, + .probe = stm32_ltdc_probe, + .bind = stm32_ltdc_bind, + .priv_auto_alloc_size = sizeof(struct stm32_ltdc_priv), +};
Hi Philippe,
On Thu, 3 Aug 2017 12:36:05 +0200 Philippe CORNU philippe.cornu@st.com wrote:
Version 1:
- Initial commit
Series applied to u-boot-video/next. Thanks!
-- Anatolij
Anatolij Gustschin
Philippe CORNU
