[U-Boot] [PATCH 1/2] linux/sizes.h: sync from kernel
The kernel added SZ_4G macro in commit f2b9ba871b (arm64/kernel: kaslr: reduce module randomization range to 4 GB).
Include common.h for _AC() instead of the kernel linux/const.h header.
Drop a local SZ_4G definition in tegra code.
Cc: Tom Warren twarren@nvidia.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/mach-tegra/tegra186/nvtboot_mem.c | 3 +-- include/linux/sizes.h | 4 ++++ 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c index 5c9467bfe8be..62142821a595 100644 --- a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c +++ b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c @@ -6,11 +6,10 @@ #include <common.h> #include <fdt_support.h> #include <fdtdec.h> +#include <linux/sizes.h> #include <asm/arch/tegra.h> #include <asm/armv8/mmu.h>
-#define SZ_4G 0x100000000ULL - /* * Size of a region that's large enough to hold the relocated U-Boot and all * other allocations made around it (stack, heap, page tables, etc.) diff --git a/include/linux/sizes.h b/include/linux/sizes.h index ce3e8150c174..9f3c13ee459b 100644 --- a/include/linux/sizes.h +++ b/include/linux/sizes.h @@ -8,6 +8,8 @@ #ifndef __LINUX_SIZES_H__ #define __LINUX_SIZES_H__
+#include <common.h> + #define SZ_1 0x00000001 #define SZ_2 0x00000002 #define SZ_4 0x00000004 @@ -44,4 +46,6 @@ #define SZ_1G 0x40000000 #define SZ_2G 0x80000000
+#define SZ_4G _AC(0x100000000, ULL) + #endif /* __LINUX_SIZES_H__ */
Some Armada 8K boards like Macchiatobin and Clearfog GT-8K use RAM from external DIMM. Hard coding the RAM size in the device-tree is not convenient. Fortunately, the ATF that initializes the RAM knows the size of RAM, and U-Boot can query the ATF using a SMC call.
This code in this commit is mostly taken from downstream Marvell U-Boot code by Grzegorz Jaszczyk.
CONFIG_NR_DRAM_BANKS must be set to 2 to use more than 3GB RAM.
Cc: Grzegorz Jaszczyk jaz@semihalf.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/mach-mvebu/arm64-common.c | 47 +++++++++++++++++++++++++++++- 1 file changed, 46 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index f47273fde9c6..7ba7301c7a8c 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -7,6 +7,7 @@ #include <dm.h> #include <fdtdec.h> #include <linux/libfdt.h> +#include <linux/sizes.h> #include <pci.h> #include <asm/io.h> #include <asm/system.h> @@ -45,15 +46,59 @@ const struct mbus_dram_target_info *mvebu_mbus_dram_info(void)
/* DRAM init code ... */
+#define MV_SIP_DRAM_SIZE 0x82000010 + +static u64 a8k_dram_scan_ap_sz(void) +{ + struct pt_regs pregs; + + pregs.regs[0] = MV_SIP_DRAM_SIZE; + pregs.regs[1] = SOC_REGS_PHY_BASE; + smc_call(&pregs); + + return pregs.regs[0]; +} + +static void a8k_dram_init_banksize(void) +{ + /* + * Config 2 DRAM banks: + * Bank 0 - max size 4G - 1G + * Bank 1 - ram size - 4G + 1G + */ + phys_size_t max_bank0_size = SZ_4G - SZ_1G; + + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + if (gd->ram_size <= max_bank0_size) { + gd->bd->bi_dram[0].size = gd->ram_size; + return; + } + + gd->bd->bi_dram[0].size = max_bank0_size; + if (CONFIG_NR_DRAM_BANKS > 1) { + gd->bd->bi_dram[1].start = SZ_4G; + gd->bd->bi_dram[1].size = gd->ram_size - max_bank0_size; + } +} + int dram_init_banksize(void) { - fdtdec_setup_memory_banksize(); + if (CONFIG_IS_ENABLED(ARMADA_8K)) + a8k_dram_init_banksize(); + else + fdtdec_setup_memory_banksize();
return 0; }
int dram_init(void) { + if (CONFIG_IS_ENABLED(ARMADA_8K)) { + gd->ram_size = a8k_dram_scan_ap_sz(); + if (gd->ram_size != 0) + return 0; + } + if (fdtdec_setup_mem_size_base() != 0) return -EINVAL;
- struct pt_regs pregs;
- pregs.regs[0] = MV_SIP_DRAM_SIZE;
- pregs.regs[1] = SOC_REGS_PHY_BASE;
- smc_call(&pregs);
- return pregs.regs[0];
- phys_size_t max_bank0_size = SZ_4G - SZ_1G;
- gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE;
- if (gd->ram_size <= max_bank0_size) {
return;
- gd->bd->bi_dram[0].size = max_bank0_size;
- if (CONFIG_NR_DRAM_BANKS > 1) {
Is CONFIG_NR_DRAM_BANKS > 2 possible on one of these platforms?
Also I find the splitting of the available RAM size (detected via ATF) onto the multiple banks not intuitive. Could you please explain the 1GiB hole in the bi_dram[x] struct? I suspect that this might have something to do with the internal register address space. But I fail to see, if this should be reflected in these bi_dram[x] values.
Thanks, Stefan
Hi Stefan,
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index f47273fde9c6..7ba7301c7a8c 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -7,6 +7,7 @@ #include <dm.h> #include <fdtdec.h> #include <linux/libfdt.h> +#include <linux/sizes.h> #include <pci.h> #include <asm/io.h> #include <asm/system.h> @@ -45,15 +46,59 @@ const struct mbus_dram_target_info *mvebu_mbus_dram_info(void) /* DRAM init code ... */ +#define MV_SIP_DRAM_SIZE 0x82000010
- smc_call(&pregs);
return;
I tested with a 16GB SO-DIMM on Clearfog GT-8K. Before this change only 2GB were visible to Linux. With this change, and with CONFIG_NR_DRAM_BANKS=2, I am able to lock 15.5GB of RAM for write/read using the memtester utility.
I didn't test on Macchaitobin because I don't have a >3GB DIMM handy.
As I understand, that is how the ATF code configures the hardware address space. Peripheral devices registers are in the 0xFxxxxxxx area, as you can see in the Armada 8040 components .dtsi.
Is there any other way to transfer this information to the kernel?
baruch
Hi Baruch,
On 31.10.18 15:50, Baruch Siach wrote:
Hi Stefan,
- smc_call(&pregs);
return;
It seems that I was wrong with my assumption that the DT blob fixup in U-Boot is made on the base of gd->ram_size. The changes to bi_dram[] are necessary for this DT fixup.
It would be great though, if you could add a comment mentioning the reason for the necessary gap in the memory layout in the commit text and the comment in the code though.
Thanks, Stefan
Baruch Siach
Stefan Roese
