[U-Boot] [PATCH v2] tools: imximage: Load a size that is multiple of 512
In order to mx53 ROM to properly load the U-boot image, its header size should be multiple of 512 bytes.
This issue was observed with gcc 4.6.2/4.7.3, which caused data aborts:
U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28)
Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.1 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device
Hit any key to stop autoboot: 0 data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<aff72220>] lr : [<aff721fc>] sp : af565e20 ip : af566918 fp : 00000000 r10: 00000003 r9 : affabb5b r8 : af565f58 r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8 Flags: NzcV IRQs off FIQs off Mode SVC_32 Resetting CPU ...
resetting ...
,and this patch fixes it.
Also, even though the ROUND macro is already defined in common.h, the reason for redefining it in image.h is explained by Stefano Babic:
"I will remark a previous comment - even if including common.h seems a good idea to avoid duplications, it makes tools like mkimage to depend on the selected board, because <board>_config must run. Even if this is not a problem for us u-boot developers, it becomes an issue when these tools are included in distros (like u-boot-tools in Ubuntu) and cannot be packaged."
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Improvec commit log include/image.h | 3 +++ tools/imximage.c | 9 ++++++++- 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/include/image.h b/include/image.h index f54d983..e1e83b4 100644 --- a/include/image.h +++ b/include/image.h @@ -179,6 +179,9 @@ #define IH_MAGIC 0x27051956 /* Image Magic Number */ #define IH_NMLEN 32 /* Image Name Length */
+/* Reused from common.h */ +#define ROUND(a, b) (((a) + (b) - 1) & ~((b) - 1)) + /* * Legacy format image header, * all data in network byte order (aka natural aka bigendian). diff --git a/tools/imximage.c b/tools/imximage.c index 63f88b6..a93d7eb 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -515,7 +515,14 @@ static void imximage_set_header(void *ptr, struct stat *sbuf, int ifd,
/* Set the imx header */ (*set_imx_hdr)(imxhdr, dcd_len, params->ep, imxhdr->flash_offset); - *header_size_ptr = sbuf->st_size + imxhdr->flash_offset; + + /* + * ROM bug alert + * mx53 only loads 512 byte multiples. + * The remaining fraction of a block bytes would + * not be loaded. + */ + *header_size_ptr = ROUND(sbuf->st_size + imxhdr->flash_offset, 512); }
int imximage_check_params(struct mkimage_params *params)
Changes since v1:
- Legacy format image header,
- all data in network byte order (aka natural aka bigendian).
* ROM bug alert
Is this i.MX53 specific or is this valid for i.MX6, too?
Best regards
Dirk
Hi Dirk,
Changes since v1:
* ROM bug alert
It seems that i.MX6 is not afflicted by this issue. For i.MX6 it adds only some padding to the resulting image.
Best regards, Stefano Babic
Correct, I also tested this change on mx25/mx51/mx6 and they all boot fine.
It is safe to apply this patch into 2012.01.
Regards,
Fabio Estevam
Sorry, I meant 2013.01
resetting ...
Applied to u-boot-imx, thanks.
Dirk Behme
Fabio Estevam
Fabio Estevam
Stefano Babic
