[U-Boot-Users] u-boot-1.1.6 :"How to use Hardware Diagnose Commands?
I cross-compiled u-boot-1.1.6 with patch for BMW board(MPC-8245) as well as Montavista Kernel(linux 2.6.10_mv1401).Running fine on board.
Now I want to test "POST-hardware Diagnose Commands like watchgdog Timer Test?How will I use these commands?
Waiting for your reply.
--------------Boot Message----------------
U-Boot 1.1.6 (Oct 4 2007 - 17:24:54)
CPU: MPC8245 Revision 1.4 at 198.002 MHz: 16 kB I-Cache 16 kB D-Cache Board: BMW MPC8245/KAHLUA2 - CHRP (MAP B) HELLO BINAY........ Built: Oct 4 2007 at 17:24:57 Local Bus at 99.001 MHz DRAM: 256 MB FLASH: 512 kB In: serial Out: serial Err: serial DOC: No DiskOnChip found =>printenv bootdelay=5 baudrate=9600 ethaddr=00:10:18:82:40:99 bootargs=root=/dev/nfs rw nfsroot=192.168.11.6:/opt/montavista/pro/devkit/ppc/82xx/target/ nfsaddrs=192.168.11.32:192.168.11.6 filesize=3007b1 fileaddr=200000 netmask=255.255.255.0 ipaddr=192.168.11.32 serverip=192.168.11.6 gatewayip=192.168.11.1 stdin=serial stdout=serial stderr=serial
Environment size: 339/2044 bytes.
Thanks In advance Binay
In message 96c521590710102303x1879a0e5vebe8e2b2beccab8d@mail.gmail.com you wrote:
This is very, very old and hopefully obsolete code. You will find little support for it here.
May I suggest you start reading the documentation *before* posting?
Like doc/README.POST ?
Binay Kumar
