[U-Boot-Users] [PATCH 3/4 resubmit] PPC4xx: Add configuration file for Korat board
This patch supplies the configuration file for the Korat PPC440EPx processor board.
Signed-off-by: Larry Johnson lrj@acm.org ---
include/configs/korat.h | 381 +++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 381 insertions(+), 0 deletions(-)
diff --git a/include/configs/korat.h b/include/configs/korat.h new file mode 100644 index 0000000..f78696c --- /dev/null +++ b/include/configs/korat.h @@ -0,0 +1,381 @@ +/* + * (C) Copyright 2006-2007 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2006 + * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * korat.h - configuration for Korat board + ***********************************************************************/ +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +#define CONFIG_440EPX 1 /* Specific PPC440EPx */ +#define CONFIG_4xx 1 /* ... PPC4xx family */ +#define CONFIG_SYS_CLK_FREQ 33333333 + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ + +/*----------------------------------------------------------------------- + * Manufacturer's information serial EEPROM parameters + *----------------------------------------------------------------------*/ +#define MAN_DATA_EEPROM_ADDR 0x53 /* EEPROM I2C address */ +#define MAN_SERIAL_NO_FIELD 2 +#define MAN_SERIAL_NO_LENGTH 13 +#define MAN_MAC_ADDR_FIELD 3 +#define MAN_MAC_ADDR_LENGTH 17 + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Monitor */ +#define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */ + +#define CFG_BOOT_BASE_ADDR 0xf0000000 +#define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ +#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_OCM_BASE 0xe0010000 /* ocm */ +#define CFG_OCM_DATA_ADDR CFG_OCM_BASE +#define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ +#define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ +#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 +#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 +#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000 + +/* Don't change either of these */ +#define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ + +#define CFG_USB2D0_BASE 0xe0000100 +#define CFG_USB_DEVICE 0xe0000000 +#define CFG_USB_HOST 0xe0000400 +#define CFG_CPLD_BASE 0xc0000000 + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer + *----------------------------------------------------------------------*/ +/* 440EPx has 16KB of internal SRAM, so no need for D-Cache */ +#undef CFG_INIT_RAM_DCACHE +#define CFG_INIT_RAM_ADDR CFG_OCM_BASE /* OCM */ +#define CFG_INIT_RAM_END (4 << 10) +#define CFG_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_POST_WORD_ADDR + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +#define CFG_EXT_SERIAL_CLOCK 11059200 /* ext. 11.059MHz clk */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SERIAL_MULTI 1 +/* define this if you want console on UART1 */ +#undef CONFIG_UART1_CONSOLE + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ +#define CFG_ENV_IS_IN_FLASH 1 /* use FLASH for environ vars */ + +/*----------------------------------------------------------------------- + * FLASH related + *----------------------------------------------------------------------*/ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } + +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ + +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */ + +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ + +#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) + +/*----------------------------------------------------------------------- + * DDR SDRAM + *----------------------------------------------------------------------*/ +#define CFG_MBYTES_SDRAM (512) /* 512 MiB TODO: remove */ +#define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ +#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for setup */ +#define CONFIG_ZERO_SDRAM /* Zero SDRAM after setup */ +#define CONFIG_DDR_ECC /* Use ECC when available */ +#define SPD_EEPROM_ADDRESS {0x50} +#define CONFIG_PROG_SDRAM_TLB +#define CFG_DRAM_TEST + +/*----------------------------------------------------------------------- + * I2C + *----------------------------------------------------------------------*/ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F + +#define CFG_I2C_MULTI_EEPROMS +#define CFG_I2C_EEPROM_ADDR (0xa8>>1) +#define CFG_I2C_EEPROM_ADDR_LEN 1 +#define CFG_EEPROM_PAGE_WRITE_ENABLE +#define CFG_EEPROM_PAGE_WRITE_BITS 3 +#define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* I2C RTC */ +#define CONFIG_RTC_M41T60 1 +#define CFG_I2C_RTC_ADDR 0x68 + +/* I2C SYSMON (LM73) */ +#define CONFIG_DTT_LM73 1 /* National Semi's LM73 */ +#define CONFIG_DTT_SENSORS {2} /* Sensor addresses */ +#define CFG_DTT_MAX_TEMP 70 +#define CFG_DTT_MIN_TEMP -30 + +#define CONFIG_PREBOOT "echo;" \ + "echo Type "run flash_nfs" to mount root filesystem over NFS;" \ + "echo" + +#undef CONFIG_BOOTARGS + +/* Setup some board specific values for the default environment variables */ +#define CONFIG_HOSTNAME korat +#define CFG_BOOTFILE "bootfile=/tftpboot/korat/uImage\0" +#define CFG_ROOTPATH "rootpath=/opt/eldk/ppc_4xxFP\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + CFG_BOOTFILE \ + CFG_ROOTPATH \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "flash_nfs=run nfsargs addip addtty;" \ + "bootm ${kernel_addr}\0" \ + "flash_self=run ramargs addip addtty;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "net_nfs=tftp 200000 ${bootfile};run nfsargs addip addtty;" \ + "bootm\0" \ + "kernel_addr=FC000000\0" \ + "ramdisk_addr=FC180000\0" \ + "load=tftp 200000 /tftpboot/${hostname}/u-boot.bin\0" \ + "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \ + "cp.b 200000 FFFA0000 60000\0" \ + "upd=run load;run update\0" \ + "" +#define CONFIG_BOOTCOMMAND "run flash_self" + +#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_PHY_ADDR 2 /* PHY address, See schematics */ +#define CONFIG_PHY_DYNAMIC_ANEG 1 + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ + +#define CONFIG_HAS_ETH0 +#define CFG_RX_ETH_BUFFER 32 /* Number of ethernet rx buffers & descriptors */ + +#define CONFIG_NET_MULTI 1 +#define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ +#define CONFIG_PHY1_ADDR 3 + +/* USB */ +#define CONFIG_USB_OHCI +#define CONFIG_USB_STORAGE + +/* Comment this out to enable USB 1.1 device */ +#define USB_2_0_DEVICE + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_I2C_CMD_TREE +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_USB + +/* POST support */ +#define CONFIG_POST (CFG_POST_CACHE | \ + CFG_POST_CPU | \ + CFG_POST_ECC | \ + CFG_POST_ETHER | \ + CFG_POST_FPU | \ + CFG_POST_I2C | \ + CFG_POST_MEMORY | \ + CFG_POST_RTC | \ + CFG_POST_SPR | \ + CFG_POST_UART) + +#define CFG_POST_WORD_ADDR (CFG_GBL_DATA_OFFSET - 0x4) +#define CONFIG_LOGBUFFER +#define CFG_POST_CACHE_ADDR 0xC8000000 /* free virtual address */ + +#define CFG_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ + +#define CONFIG_SUPPORT_VFAT + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + *----------------------------------------------------------------------*/ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x0400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ +#define CFG_EXTBDINFO 1 /* To use extended board_into (bd_t) */ + +#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */ + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CFG_PCI_CACHE_LINE_SIZE 0 /* to avoid problems with PNP */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CFG_PCI_TARGBASE 0x80000000 /* PCIaddr mapped to CFG_PCI_MEMBASE */ + +/* Board-specific PCI */ +#define CFG_PCI_TARGET_INIT +#define CFG_PCI_MASTER_INIT + +#define CFG_PCI_SUBSYS_VENDORID 0x10e8 /* AMCC */ +#define CFG_PCI_SUBSYS_ID 0xcafe /* Whatever */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ + +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CFG_EBC_PB0AP 0x04017300 +#define CFG_EBC_PB0CR (CFG_FLASH_BASE | 0x000DA000) + +/* Memory Bank 1 (NOR-FLASH) initialization */ +#define CFG_EBC_PB1AP 0x04017300 +#define CFG_EBC_PB1CR (0xF8000000 | 0x000DA000) + +/* Memory Bank 2 (CPLD) initialization */ +#define CFG_EBC_PB2AP 0x04017300 +#define CFG_EBC_PB2CR (CFG_CPLD_BASE | 0x00038000) + +/*----------------------------------------------------------------------- + * Cache Configuration + *----------------------------------------------------------------------*/ +#define CFG_DCACHE_SIZE (32<<10) /* For AMCC 440 CPUs */ +#define CFG_CACHELINE_SIZE 32 /* ... */ +#if defined(CONFIG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /* log2 of the above value */ +#endif + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif +#endif /* __CONFIG_H */
Larry Johnson
