Pull request efi-2024-10-rc1-2
Dear Tom,
The following changes since commit b182816c1fb436916661949213c543bf4d42250b:
turris_1x: Normalize Kconfig usage (2024-07-13 10:42:15 -0600)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2024-10-rc1-2
for you to fetch changes up to da909648e13fdfb5306123f4bc2a89bf2cbf682e:
doc: add bootelf command documentation (2024-07-14 09:56:24 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/21597
---------------------------------------------------------------- Pull request efi-2024-10-rc1-2
Documentation:
* use current versions of certifi and urllib3 for building documentation * add bootelf command documentation * correct the description of the Goldfish RTC driver * correct heading level of itest examples
UEFI:
* print device-tree in dtbdump.efi * consider CONFIG_EFI_IGNORE_OSINDICATIONS in TestEfiCapsuleFirmwareRaw * correct cmd_capsule_esl_gen invocation in scripts/Makefile.lib * use capsule CRT instead of ESL file when building capsules
Others:
* let ENV_IS_IN_EXT4 enable SYS_MMC_ENV_DEV * check if CONFIG_SYS_MMC_ENV_DEV is defined in mmc_get_env_dev
---------------------------------------------------------------- Heinrich Schuchardt (5): efi_loader: print device-tree in dtbdump.efi rtc: fix the description of the Goldfish RTC driver doc: fix heading level of itest examples env: ENV_IS_IN_EXT4 should enable SYS_MMC_ENV_DEV sunxi: CONFIG_SYS_MMC_ENV_DEV undeclared
Ilias Apalodimas (1): test: test for ignore OsIndications
Jonathan Humphreys (2): scripts/Makefile.lib: fixes: Embed capsule public key in platform's dtb scripts/Makefile.lib: EFI: Use capsule CRT instead of ESL file
Maxim Moskalets (1): doc: add bootelf command documentation
Tom Rini (1): doc/sphinx/requirements.txt: Bump certifi and urllib3
board/sandbox/capsule_pub_esl_good.esl | Bin 831 -> 0 bytes board/sunxi/board.c | 2 +- configs/sandbox_defconfig | 2 +- configs/sandbox_flattree_defconfig | 2 +- doc/develop/uefi/uefi.rst | 8 +- doc/sphinx/requirements.txt | 4 +- doc/usage/cmd/bootelf.rst | 61 +++++ doc/usage/cmd/itest.rst | 2 +- doc/usage/index.rst | 1 + drivers/rtc/goldfish_rtc.c | 4 +- env/Kconfig | 2 +- lib/efi_loader/Kconfig | 12 +- lib/efi_loader/dtbdump.c | 261 +++++++++++++++++++++ scripts/Makefile.lib | 24 +- .../test_efi_capsule/test_capsule_firmware_raw.py | 21 +- 15 files changed, 375 insertions(+), 31 deletions(-) delete mode 100644 board/sandbox/capsule_pub_esl_good.esl create mode 100644 doc/usage/cmd/bootelf.rst
On Sun, Jul 14, 2024 at 12:53:43PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
