[U-Boot] commit 9a9d66f5ef break U-Boot Env
Hello Horatiu,
just tried current mainline U-Boot on imx6ull based board with Env in SPI NOR. Your commit "9a9d66f5eff0"
env: add spi_flash_read_env function
breaks reading Env from SPI NOR in my case...
If I interprete your patch correct, you only read until the 2 0x0 in the env ... but for the env crc, the hole CONFIG_ENV_SIZE must be read ... else missing for crc calculation ...
Hmm... following patch fixes for me the issue:
hs@threadripper:git [master] $ git diff env/sf.c diff --git a/env/sf.c b/env/sf.c index b3dec82c35..dc4b56d4a4 100644 --- a/env/sf.c +++ b/env/sf.c @@ -98,7 +104,7 @@ static int spi_flash_read_env(struct spi_flash *flash, u32 offset, size_t len, u32 addr = 0; u32 page_size = flash->page_size;
- memset(buf, 0x0, len); + memset(buf, 0xff, len); for (int i = 0; i < len / page_size; ++i) { int ret = spi_flash_read(flash, offset, page_size, &((char *)buf)[addr]);
But if I make a bigger ENV_SIZE this may break again...
bye, Heiko
Hi Heiko,
The 01/18/2019 09:34, Heiko Schocher wrote:
Hello Horatiu,
That's correct, the buf should be initialized to 0xff.
But I don't see why increasing the ENV_SIZE would break it again. Can you explain it why? Thank you.
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-52 Fax: +49-8142-66989-80 Email: hs@denx.de
Hello Horatiu,
Am 18.01.2019 um 10:18 schrieb Horatiu Vultur:
Hi Heiko,
Hello Horatiu,
No, you are correct. CONFIG_ENV_SIZE is passed to spi_flash_read_env() so this should be fine.
I send a patch...
bye, Heiko
Heiko Schocher
Horatiu Vultur
