[U-Boot] [PATCH v4 0/6] Add ARMv8 PSCI framework
v3-v4 changes: - Re-added the 1/6 from v2, and move the newly re-named macro into Kconfig - Add "Reviewed-by: Tom Rini trini@konsulko.com" for patch 4/6 ~ 6/6.
v2-v3 changes: - Drop the previous 1/6, since the previous CONFIG_ARMV8_PSCI in common parts of codes also work for generic PSCI framework, so there are 5 patches in this iteration. - Add "Reviewed-by: Tom Rini trini@konsulko.com" for patches 1/5 and 2/5, which were 2/6 and 3/6. - Move config values for ls1043 from armv8/Kconfig to s1043ardb_defconfig.
v1-v2 changes: - The new config options are introduced in Kconfig when used for first time - Introduce new config options in armv8/Kconfig instead of LS1043 platform - Move previous patch 5/6 to current 2/6 place
v1 notes:
This patch set introduces ARMv8 PSCI framework, all the PSCI functions are implemented a default dummy one, it is up to each platform to implement their own specific ones.
The first 1/6 patch is a prepare clean up for adding ARMv8 PSCI. Patches 2/6 to 5/6 introduce new ARMv8 framework and set it up. The last 6/6 adds a most simple implementation on NXP LS1043 platform, to verify this framework.
This patch set mainly introduces ARMv8 PSCI framework, for easier review and merge, further PSCI implementation on LS1043 is coming later.
Hongbo Zhang (6): ARMv8: LS1043A: change macro CONFIG_ARMV8_PSCI definition ARMv8: Enable SMC instruction ARMv8: Add secure sections for PSCI text and data ARMv8: Add basic PSCI framework ARMv8: Setup PSCI memory and device tree ARMv8: LS1043A: Enable LS1043A default PSCI support
arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Kconfig | 41 ++++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/cpu-dt.c | 11 +- arch/arm/cpu/armv8/cpu.c | 22 ++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 20 ++ arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 3 +- arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S | 20 ++ arch/arm/cpu/armv8/psci.S | 286 +++++++++++++++++++++++ arch/arm/cpu/armv8/sec_firmware.c | 2 +- arch/arm/cpu/armv8/sec_firmware_asm.S | 2 +- arch/arm/cpu/armv8/u-boot.lds | 57 +++++ arch/arm/include/asm/armv8/sec_firmware.h | 2 +- arch/arm/include/asm/macro.h | 2 +- arch/arm/include/asm/psci.h | 15 ++ arch/arm/include/asm/secure.h | 2 +- arch/arm/include/asm/system.h | 11 + arch/arm/lib/bootm-fdt.c | 3 +- arch/arm/lib/bootm.c | 3 + arch/arm/lib/psci-dt.c | 5 +- board/freescale/ls1043ardb/Kconfig | 9 + configs/ls1043ardb_defconfig | 3 + include/configs/ls1043ardb.h | 1 - 25 files changed, 515 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S create mode 100644 arch/arm/cpu/armv8/psci.S
NXP/Freescale uses macro CONFIG_ARMV8_PSCI to enable their private PSCI implementation in PPA firmware, but this macro naming too generic, so this patch replaces it with a specic one CONFIG_FSL_PPA_ARMV8_PSCI. And this macro CONFIG_ARMV8_PSCI will be used for a generic PSCI for ARMv8 which will be added in following patchs.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com --- arch/arm/cpu/armv8/cpu-dt.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 20 ++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 ++- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 3 ++- arch/arm/cpu/armv8/sec_firmware.c | 2 +- arch/arm/cpu/armv8/sec_firmware_asm.S | 2 +- arch/arm/include/asm/armv8/sec_firmware.h | 2 +- arch/arm/lib/bootm-fdt.c | 2 +- arch/arm/lib/psci-dt.c | 2 +- include/configs/ls1043ardb.h | 1 - 10 files changed, 30 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c index 9ffb49c..659ec27 100644 --- a/arch/arm/cpu/armv8/cpu-dt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -13,7 +13,7 @@ int psci_update_dt(void *fdt) { #ifdef CONFIG_MP -#if defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT /* * If the PSCI in SEC Firmware didn't work, avoid to update the diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 94ec8d5..3179c2a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -44,6 +44,26 @@ config FSL_LSCH3 menu "Layerscape architecture" depends on FSL_LSCH2 || FSL_LSCH3
+menu "Layerscape PPA" +config FSL_LS_PPA + bool "FSL Layerscape PPA firmware support" + depends on ARCH_LS1043A || ARCH_LS1046A + select FSL_PPA_ARMV8_PSCI + help + The FSL Primary Protected Application (PPA) is a software component + which is loaded during boot stage, and then remains resident in RAM + and runs in the TrustZone after boot. + Say y to enable it. + +config FSL_PPA_ARMV8_PSCI + bool "PSCI implementation in PPA firmware" + depends on FSL_LS_PPA + help + This config enables the ARMv8 PSCI implementation in PPA firmware. + This is a private PSCI implementation and different from those + implemented under the common ARMv8 PSCI framework. +endmenu + config SYS_FSL_MMDC bool
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 0b516e3..e47219a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -403,7 +403,8 @@ int arch_early_init_r(void) #endif
#ifdef CONFIG_MP -#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) /* Check the psci version to determine if the psci is supported */ psci_ver = sec_firmware_support_psci_version(); #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 0dae5fa..c10ccf9 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -42,7 +42,8 @@ void ft_fixup_cpu(void *blob) int addr_cells; u64 val, core_id; size_t *boot_code_size = &(__secondary_boot_code_size); -#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) int node; u32 psci_ver;
diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c index 2ddd67e..0b973f0 100644 --- a/arch/arm/cpu/armv8/sec_firmware.c +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -209,7 +209,7 @@ __weak bool sec_firmware_is_valid(const void *sec_firmware_img) return true; }
-#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI /* * The PSCI_VERSION function is added from PSCI v0.2. When the PSCI * v0.1 received this function, the NOT_SUPPORTED (0xffff_ffff) error diff --git a/arch/arm/cpu/armv8/sec_firmware_asm.S b/arch/arm/cpu/armv8/sec_firmware_asm.S index 0c6a462..d4a26b4 100644 --- a/arch/arm/cpu/armv8/sec_firmware_asm.S +++ b/arch/arm/cpu/armv8/sec_firmware_asm.S @@ -41,7 +41,7 @@ WEAK(_sec_firmware_entry) ret ENDPROC(_sec_firmware_entry)
-#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI ENTRY(_sec_firmware_support_psci_version) mov x0, 0x84000000 mov x1, 0x0 diff --git a/arch/arm/include/asm/armv8/sec_firmware.h b/arch/arm/include/asm/armv8/sec_firmware.h index eb68185..a4e144b 100644 --- a/arch/arm/include/asm/armv8/sec_firmware.h +++ b/arch/arm/include/asm/armv8/sec_firmware.h @@ -14,7 +14,7 @@ int sec_firmware_init(const void *, u32 *, u32 *); int _sec_firmware_entry(const void *, u32 *, u32 *); bool sec_firmware_is_valid(const void *); -#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI unsigned int sec_firmware_support_psci_version(void); unsigned int _sec_firmware_support_psci_version(void); #endif diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index a517550..10a56e8 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -53,7 +53,7 @@ int arch_fixup_fdt(void *blob) return ret; #endif
-#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret; diff --git a/arch/arm/lib/psci-dt.c b/arch/arm/lib/psci-dt.c index baf6d70..41e139e 100644 --- a/arch/arm/lib/psci-dt.c +++ b/arch/arm/lib/psci-dt.c @@ -16,7 +16,7 @@
int fdt_psci(void *fdt) { -#if defined(CONFIG_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) +#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) int nodeoff; unsigned int psci_ver = 0; int tmp; diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 849a6cb..71c26bd 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -12,7 +12,6 @@ #if defined(CONFIG_FSL_LS_PPA) #define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #define SEC_FIRMWARE_ERET_ADDR_REVERT -#define CONFIG_ARMV8_PSCI
#define CONFIG_SYS_LS_PPA_FW_IN_XIP #ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP
PSCI implementation needs the SMC instruction to be enabled. Following the legacy codes pattern, no bit macro definition and bit operation are used, only the immediate data used in line is changed.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/macro.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index 9bb0efa..35ea002 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -137,7 +137,7 @@ lr .req x30
.macro armv8_switch_to_el2_m, xreg1 /* 64bit EL2 | HCE | SMD | RES1 (Bits[5:4]) | Non-secure EL0/EL1 */ - mov \xreg1, #0x5b1 + mov \xreg1, #0x531 msr scr_el3, \xreg1 msr cptr_el3, xzr /* Disable coprocessor traps to EL3 */ mov \xreg1, #0x33ff
- mov \xreg1, #0x531 msr scr_el3, \xreg1 msr cptr_el3, xzr /* Disable coprocessor traps to EL3 */ mov \xreg1, #0x33ff
Hongbo,
This has a conflict. Please work with Alison Wang to figure out the SMD bit as she has changed the code to deal with both 64- and 32-bit. I can guess a fix to this conflict, but rather to have her onboard.
York
OK.
And currently this series are against the community tree, and if this should go to your tree, I should rebase to yours, right?
mov \xreg1, #0x5b1
Hongbo,
York
On 11/30/2016 01:47 AM, Hongbo Zhang wrote:
OK.
No. Please use upstream master branch. I trye to keep my repo in sync but mostly it is behind by several merges.
York
This patch adds secure_text, secure_data and secure_stack sections for ARMv8 to hold PSCI text and data, and it is based on the legacy implementation of ARMv7.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/config.mk | 3 ++- arch/arm/cpu/armv8/Kconfig | 31 +++++++++++++++++++++++ arch/arm/cpu/armv8/u-boot.lds | 57 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 90 insertions(+), 1 deletion(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 008da39..3a81f13 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -121,7 +121,8 @@ endif
# limit ourselves to the sections we want in the .bin. ifdef CONFIG_ARM64 -OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list -j .rela.dyn +OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .data \ + -j .u_boot_list -j .rela.dyn else OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .hash \ -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 965a8d1..edae43d 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -40,4 +40,35 @@ config PSCI_RESET
Select Y here to make use of PSCI calls for system reset
+config ARMV8_PSCI + bool "Enable PSCI support" if EXPERT + default n + help + PSCI is Power State Coordination Interface defined by ARM. + The PSCI in U-boot provides a general framework and each platform + can implement their own specific PSCI functions. + Say Y here to enable PSCI support on ARMv8 platform. + +config ARMV8_PSCI_NR_CPUS + int "Maximum supported CPUs for PSCI" + depends on ARMV8_PSCI + default 4 + help + The maximum number of CPUs supported in the PSCI firmware. + It is no problem to set a larger value than the number of CPUs in + the actual hardware implementation. + +if SYS_HAS_ARMV8_SECURE_BASE + +config ARMV8_SECURE_BASE + hex "Secure address for PSCI image" + depends on ARMV8_PSCI + help + Address for placing the PSCI text, data and stack sections. + If not defined, the PSCI sections are placed together with the u-boot + but platform can choose to place PSCI code image separately in other + places such as some secure RAM built-in SOC etc. + +endif + endif diff --git a/arch/arm/cpu/armv8/u-boot.lds b/arch/arm/cpu/armv8/u-boot.lds index fd15ad5..22195b8 100644 --- a/arch/arm/cpu/armv8/u-boot.lds +++ b/arch/arm/cpu/armv8/u-boot.lds @@ -8,11 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <config.h> +#include <asm/psci.h> + OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") OUTPUT_ARCH(aarch64) ENTRY(_start) SECTIONS { +#ifdef CONFIG_ARMV8_SECURE_BASE + /DISCARD/ : { *(.rela._secure*) } +#endif . = 0x00000000;
. = ALIGN(8); @@ -23,6 +29,57 @@ SECTIONS *(.text*) }
+#ifdef CONFIG_ARMV8_PSCI + .__secure_start : +#ifndef CONFIG_ARMV8_SECURE_BASE + ALIGN(CONSTANT(COMMONPAGESIZE)) +#endif + { + KEEP(*(.__secure_start)) + } + +#ifndef CONFIG_ARMV8_SECURE_BASE +#define CONFIG_ARMV8_SECURE_BASE +#define __ARMV8_PSCI_STACK_IN_RAM +#endif + .secure_text CONFIG_ARMV8_SECURE_BASE : + AT(ADDR(.__secure_start) + SIZEOF(.__secure_start)) + { + *(._secure.text) + } + + .secure_data : AT(LOADADDR(.secure_text) + SIZEOF(.secure_text)) + { + *(._secure.data) + } + + .secure_stack ALIGN(ADDR(.secure_data) + SIZEOF(.secure_data), + CONSTANT(COMMONPAGESIZE)) (NOLOAD) : +#ifdef __ARMV8_PSCI_STACK_IN_RAM + AT(ADDR(.secure_stack)) +#else + AT(LOADADDR(.secure_data) + SIZEOF(.secure_data)) +#endif + { + KEEP(*(.__secure_stack_start)) + + . = . + CONFIG_ARMV8_PSCI_NR_CPUS * ARM_PSCI_STACK_SIZE; + + . = ALIGN(CONSTANT(COMMONPAGESIZE)); + + KEEP(*(.__secure_stack_end)) + } + +#ifndef __ARMV8_PSCI_STACK_IN_RAM + . = LOADADDR(.secure_stack); +#endif + + .__secure_end : AT(ADDR(.__secure_end)) { + KEEP(*(.__secure_end)) + LONG(0x1d1071c); /* Must output something to reset LMA */ + } +#endif + . = ALIGN(8); .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) }
+config ARMV8_PSCI
- bool "Enable PSCI support" if EXPERT
- default n
- help
- int "Maximum supported CPUs for PSCI"
- depends on ARMV8_PSCI
- default 4
- help
- hex "Secure address for PSCI image"
- help
+endif
These changes to Kconfig is not related to the secure sections you described in the commit message.
York
+config ARMV8_PSCI
default n
help
default 4
help
help
+endif
These configs were originally in the patch of introducing generic PSCI framework, following Tom's suggest that configs should be introduced in Kconfig when they are used first time. I'll mention this in commit message to let it match.
York
This patch introduces a generic ARMv8 PSCI framework, with all functions returning a dummy ARM_PSCI_RET_NI (Not Implemented), then it is up to each platform to implement their own functions based on this framework.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/Kconfig | 10 ++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/psci.S | 286 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/psci.h | 15 +++ 4 files changed, 312 insertions(+) create mode 100644 arch/arm/cpu/armv8/psci.S
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index edae43d..22dce88 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -58,6 +58,16 @@ config ARMV8_PSCI_NR_CPUS It is no problem to set a larger value than the number of CPUs in the actual hardware implementation.
+config ARMV8_PSCI_CPUS_PER_CLUSTER + int "Number of CPUs per cluster" + depends on ARMV8_PSCI + default 0 + help + The number of CPUs per cluster, suppose each cluster has same number + of CPU cores, platforms with asymmetric clusters don't apply here. + A value 0 or no definition of it works for single cluster system. + System with multi-cluster should difine their own exact value. + if SYS_HAS_ARMV8_SECURE_BASE
config ARMV8_SECURE_BASE diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index dea1465..28ba786 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -25,3 +25,4 @@ obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_S32V234) += s32v234/ obj-$(CONFIG_ARCH_ZYNQMP) += zynqmp/ obj-$(CONFIG_TARGET_HIKEY) += hisilicon/ +obj-$(CONFIG_ARMV8_PSCI) += psci.o diff --git a/arch/arm/cpu/armv8/psci.S b/arch/arm/cpu/armv8/psci.S new file mode 100644 index 0000000..43d5d6b --- /dev/null +++ b/arch/arm/cpu/armv8/psci.S @@ -0,0 +1,286 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Author: Hongbo Zhang hongbo.zhang@nxp.com + * + * SPDX-License-Identifier: GPL-2.0+ + * This file implements LS102X platform PSCI SYSTEM-SUSPEND function + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/psci.h> + +/* Default PSCI function, return -1, Not Implemented */ +#define PSCI_DEFAULT(__fn) \ + ENTRY(__fn); \ + mov w0, #ARM_PSCI_RET_NI; \ + ret; \ + ENDPROC(__fn); \ + .weak __fn + +/* PSCI function and ID table definition*/ +#define PSCI_TABLE(__id, __fn) \ + .word __id; \ + .word __fn + +.pushsection ._secure.text, "ax" + +/* 32 bits PSCI default functions */ +PSCI_DEFAULT(psci_version) +PSCI_DEFAULT(psci_cpu_suspend) +PSCI_DEFAULT(psci_cpu_off) +PSCI_DEFAULT(psci_cpu_on) +PSCI_DEFAULT(psci_affinity_info) +PSCI_DEFAULT(psci_migrate) +PSCI_DEFAULT(psci_migrate_info_type) +PSCI_DEFAULT(psci_migrate_info_up_cpu) +PSCI_DEFAULT(psci_system_off) +PSCI_DEFAULT(psci_system_reset) +PSCI_DEFAULT(psci_features) +PSCI_DEFAULT(psci_cpu_freeze) +PSCI_DEFAULT(psci_cpu_default_suspend) +PSCI_DEFAULT(psci_node_hw_state) +PSCI_DEFAULT(psci_system_suspend) +PSCI_DEFAULT(psci_set_suspend_mode) +PSCI_DEFAULT(psi_stat_residency) +PSCI_DEFAULT(psci_stat_count) + +.align 3 +_psci_32_table: +PSCI_TABLE(ARM_PSCI_FN_CPU_SUSPEND, psci_cpu_suspend) +PSCI_TABLE(ARM_PSCI_FN_CPU_OFF, psci_cpu_off) +PSCI_TABLE(ARM_PSCI_FN_CPU_ON, psci_cpu_on) +PSCI_TABLE(ARM_PSCI_FN_MIGRATE, psci_migrate) +PSCI_TABLE(ARM_PSCI_0_2_FN_PSCI_VERSION, psci_version) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_SUSPEND, psci_cpu_suspend) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_OFF, psci_cpu_off) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_ON, psci_cpu_on) +PSCI_TABLE(ARM_PSCI_0_2_FN_AFFINITY_INFO, psci_affinity_info) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE, psci_migrate) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE_INFO_TYPE, psci_migrate_info_type) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE_INFO_UP_CPU, psci_migrate_info_up_cpu) +PSCI_TABLE(ARM_PSCI_0_2_FN_SYSTEM_OFF, psci_system_off) +PSCI_TABLE(ARM_PSCI_0_2_FN_SYSTEM_RESET, psci_system_reset) +PSCI_TABLE(ARM_PSCI_1_0_FN_PSCI_FEATURES, psci_features) +PSCI_TABLE(ARM_PSCI_1_0_FN_CPU_FREEZE, psci_cpu_freeze) +PSCI_TABLE(ARM_PSCI_1_0_FN_CPU_DEFAULT_SUSPEND, psci_cpu_default_suspend) +PSCI_TABLE(ARM_PSCI_1_0_FN_NODE_HW_STATE, psci_node_hw_state) +PSCI_TABLE(ARM_PSCI_1_0_FN_SYSTEM_SUSPEND, psci_system_suspend) +PSCI_TABLE(ARM_PSCI_1_0_FN_SET_SUSPEND_MODE, psci_set_suspend_mode) +PSCI_TABLE(ARM_PSCI_1_0_FN_STAT_RESIDENCY, psi_stat_residency) +PSCI_TABLE(ARM_PSCI_1_0_FN_STAT_COUNT, psci_stat_count) +PSCI_TABLE(0, 0) + +/* 64 bits PSCI default functions */ +PSCI_DEFAULT(psci_cpu_suspend_64) +PSCI_DEFAULT(psci_cpu_on_64) +PSCI_DEFAULT(psci_affinity_info_64) +PSCI_DEFAULT(psci_migrate_64) +PSCI_DEFAULT(psci_migrate_info_up_cpu_64) +PSCI_DEFAULT(psci_cpu_default_suspend_64) +PSCI_DEFAULT(psci_node_hw_state_64) +PSCI_DEFAULT(psci_system_suspend_64) +PSCI_DEFAULT(psci_stat_residency_64) +PSCI_DEFAULT(psci_stat_count_64) + +.align 3 +_psci_64_table: +PSCI_TABLE(ARM_PSCI_0_2_FN64_CPU_SUSPEND, psci_cpu_suspend_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_CPU_ON, psci_cpu_on_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_AFFINITY_INFO, psci_affinity_info_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_MIGRATE, psci_migrate_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_MIGRATE_INFO_UP_CPU, psci_migrate_info_up_cpu_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_CPU_DEFAULT_SUSPEND, psci_cpu_default_suspend_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_NODE_HW_STATE, psci_node_hw_state_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_SYSTEM_SUSPEND, psci_system_suspend_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_STAT_RESIDENCY, psci_stat_residency_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_STAT_COUNT, psci_stat_count_64) +PSCI_TABLE(0, 0) + +.macro psci_enter + /* PSCI call is Fast Call(atomic), so mask DAIF */ + mrs x15, DAIF + stp x15, xzr, [sp, #-16]! + ldr x15, =0x3C0 + msr DAIF, x15 + /* SMC convention, x18 ~ x30 should be saved by callee */ + stp x29, x30, [sp, #-16]! + stp x27, x28, [sp, #-16]! + stp x25, x26, [sp, #-16]! + stp x23, x24, [sp, #-16]! + stp x21, x22, [sp, #-16]! + stp x19, x20, [sp, #-16]! + mrs x15, elr_el3 + stp x18, x15, [sp, #-16]! +.endm + +.macro psci_return + /* restore registers */ + ldp x18, x15, [sp], #16 + msr elr_el3, x15 + ldp x19, x20, [sp], #16 + ldp x21, x22, [sp], #16 + ldp x23, x24, [sp], #16 + ldp x25, x26, [sp], #16 + ldp x27, x28, [sp], #16 + ldp x29, x30, [sp], #16 + /* restore DAIF */ + ldp x15, xzr, [sp], #16 + msr DAIF, x15 + eret +.endm + +/* Caller must put PSCI function-ID table base in x9 */ +handle_psci: + psci_enter +1: ldr x10, [x9] /* Load PSCI function table */ + ubfx x11, x10, #32, #32 + ubfx x10, x10, #0, #32 + cbz x10, 3f /* If reach the end, bail out */ + cmp x10, x0 + b.eq 2f /* PSCI function found */ + add x9, x9, #8 /* If not match, try next entry */ + b 1b + +2: blr x11 /* Call PSCI function */ + psci_return + +3: mov x0, #ARM_PSCI_RET_NI + psci_return + +unknown_smc_id: + ldr x0, =0xFFFFFFFF + eret + +handle_smc32: + /* SMC function ID 0x84000000-0x8400001F: 32 bits PSCI */ + ldr w9, =0x8400001F + cmp w0, w9 + b.gt unknown_smc_id + ldr w9, =0x84000000 + cmp w0, w9 + b.lt unknown_smc_id + + adr x9, _psci_32_table + b handle_psci + +handle_smc64: + /* check SMC32 or SMC64 calls */ + ubfx x9, x0, #30, #1 + cbz x9, handle_smc32 + + /* SMC function ID 0xC4000000-0xC400001F: 64 bits PSCI */ + ldr x9, =0xC400001F + cmp x0, x9 + b.gt unknown_smc_id + ldr x9, =0xC4000000 + cmp x0, x9 + b.lt unknown_smc_id + + adr x9, _psci_64_table + b handle_psci + +/* + * Get CPU ID from MPIDR, suppose every cluster has same number of CPU cores, + * Platform with asymmetric clusters should implement their own interface. + * In case this function being called by other platform's C code, the ARM + * Architecture Procedure Call Standard is considered, e.g. register X0 is + * used for the return value, while in this PSCI environment, X0 usually holds + * the SMC function identifier, so X0 should be saved by caller function. + */ +ENTRY(psci_get_cpu_id) +#ifdef CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER + mrs x9, MPIDR_EL1 + ubfx x9, x9, #8, #8 + ldr x10, =CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER + mul x9, x10, x9 +#else + mov x9, xzr +#endif + mrs x10, MPIDR_EL1 + ubfx x10, x10, #0, #8 + add x0, x10, x9 + ret +ENDPROC(psci_get_cpu_id) +.weak psci_get_cpu_id + +/* CPU ID input in x0, stack top output in x0*/ +LENTRY(psci_get_cpu_stack_top) + adr x9, __secure_stack_end + lsl x0, x0, #ARM_PSCI_STACK_SHIFT + sub x0, x9, x0 + ret +ENDPROC(psci_get_cpu_stack_top) + +unhandled_exception: + b unhandled_exception /* simply dead loop */ + +handle_sync: + mov x15, x30 + mov x14, x0 + + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov x9, #1 + msr spsel, x9 + mov sp, x0 + + mov x0, x14 + mov x30, x15 + + mrs x9, esr_el3 + ubfx x9, x9, #26, #6 + cmp x9, #0x13 + b.eq handle_smc32 + cmp x9, #0x17 + b.eq handle_smc64 + + b unhandled_exception + + .align 11 + .globl el3_exception_vectors +el3_exception_vectors: + b unhandled_exception /* Sync, Current EL using SP0 */ + .align 7 + b unhandled_exception /* IRQ, Current EL using SP0 */ + .align 7 + b unhandled_exception /* FIQ, Current EL using SP0 */ + .align 7 + b unhandled_exception /* SError, Current EL using SP0 */ + .align 7 + b unhandled_exception /* Sync, Current EL using SPx */ + .align 7 + b unhandled_exception /* IRQ, Current EL using SPx */ + .align 7 + b unhandled_exception /* FIQ, Current EL using SPx */ + .align 7 + b unhandled_exception /* SError, Current EL using SPx */ + .align 7 + b handle_sync /* Sync, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* IRQ, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* FIQ, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* SError, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* Sync, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* IRQ, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* FIQ, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* SError, Lower EL using AArch32 */ + +ENTRY(psci_setup_vectors) + adr x0, el3_exception_vectors + msr vbar_el3, x0 + ret +ENDPROC(psci_setup_vectors) + +ENTRY(psci_arch_init) + ret +ENDPROC(psci_arch_init) +.weak psci_arch_init + +.popsection diff --git a/arch/arm/include/asm/psci.h b/arch/arm/include/asm/psci.h index 9f1f779..ac8b00d 100644 --- a/arch/arm/include/asm/psci.h +++ b/arch/arm/include/asm/psci.h @@ -45,6 +45,9 @@ #define ARM_PSCI_0_2_FN_BASE 0x84000000 #define ARM_PSCI_0_2_FN(n) (ARM_PSCI_0_2_FN_BASE + (n))
+#define ARM_PSCI_0_2_FN64_BASE 0xC4000000 +#define ARM_PSCI_0_2_FN64(n) (ARM_PSCI_0_2_FN64_BASE + (n)) + #define ARM_PSCI_0_2_FN_PSCI_VERSION ARM_PSCI_0_2_FN(0) #define ARM_PSCI_0_2_FN_CPU_SUSPEND ARM_PSCI_0_2_FN(1) #define ARM_PSCI_0_2_FN_CPU_OFF ARM_PSCI_0_2_FN(2) @@ -56,6 +59,12 @@ #define ARM_PSCI_0_2_FN_SYSTEM_OFF ARM_PSCI_0_2_FN(8) #define ARM_PSCI_0_2_FN_SYSTEM_RESET ARM_PSCI_0_2_FN(9)
+#define ARM_PSCI_0_2_FN64_CPU_SUSPEND ARM_PSCI_0_2_FN64(1) +#define ARM_PSCI_0_2_FN64_CPU_ON ARM_PSCI_0_2_FN64(3) +#define ARM_PSCI_0_2_FN64_AFFINITY_INFO ARM_PSCI_0_2_FN64(4) +#define ARM_PSCI_0_2_FN64_MIGRATE ARM_PSCI_0_2_FN64(5) +#define ARM_PSCI_0_2_FN64_MIGRATE_INFO_UP_CPU ARM_PSCI_0_2_FN64(7) + /* PSCI 1.0 interface */ #define ARM_PSCI_1_0_FN_PSCI_FEATURES ARM_PSCI_0_2_FN(10) #define ARM_PSCI_1_0_FN_CPU_FREEZE ARM_PSCI_0_2_FN(11) @@ -66,6 +75,12 @@ #define ARM_PSCI_1_0_FN_STAT_RESIDENCY ARM_PSCI_0_2_FN(16) #define ARM_PSCI_1_0_FN_STAT_COUNT ARM_PSCI_0_2_FN(17)
+#define ARM_PSCI_1_0_FN64_CPU_DEFAULT_SUSPEND ARM_PSCI_0_2_FN64(12) +#define ARM_PSCI_1_0_FN64_NODE_HW_STATE ARM_PSCI_0_2_FN64(13) +#define ARM_PSCI_1_0_FN64_SYSTEM_SUSPEND ARM_PSCI_0_2_FN64(14) +#define ARM_PSCI_1_0_FN64_STAT_RESIDENCY ARM_PSCI_0_2_FN64(16) +#define ARM_PSCI_1_0_FN64_STAT_COUNT ARM_PSCI_0_2_FN64(17) + /* 1KB stack per core */ #define ARM_PSCI_STACK_SHIFT 10 #define ARM_PSCI_STACK_SIZE (1 << ARM_PSCI_STACK_SHIFT)
Newly add ARMv8 PSCI needs to be initialized, be copied or reserved in right place, this patch does all the setup steps.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/cpu-dt.c | 11 ++++++++++- arch/arm/cpu/armv8/cpu.c | 22 ++++++++++++++++++++++ arch/arm/include/asm/secure.h | 2 +- arch/arm/include/asm/system.h | 11 +++++++++++ arch/arm/lib/bootm-fdt.c | 3 ++- arch/arm/lib/bootm.c | 3 +++ arch/arm/lib/psci-dt.c | 5 +++-- 7 files changed, 52 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c index 659ec27..d275cfa 100644 --- a/arch/arm/cpu/armv8/cpu-dt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/psci.h> +#include <asm/system.h> #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #include <asm/armv8/sec_firmware.h> #endif @@ -13,7 +14,8 @@ int psci_update_dt(void *fdt) { #ifdef CONFIG_MP -#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_PSCI) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) + #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT /* * If the PSCI in SEC Firmware didn't work, avoid to update the @@ -25,6 +27,13 @@ int psci_update_dt(void *fdt) return 0; #endif fdt_psci(fdt); + +#ifndef CONFIG_ARMV8_SECURE_BASE + /* secure code lives in RAM, keep it alive */ + fdt_add_mem_rsv(fdt, (unsigned long)__secure_start, + __secure_end - __secure_start); +#endif + #endif #endif return 0; diff --git a/arch/arm/cpu/armv8/cpu.c b/arch/arm/cpu/armv8/cpu.c index e06c3cc..5dcb5e2 100644 --- a/arch/arm/cpu/armv8/cpu.c +++ b/arch/arm/cpu/armv8/cpu.c @@ -14,6 +14,7 @@ #include <common.h> #include <command.h> #include <asm/system.h> +#include <asm/secure.h> #include <linux/compiler.h>
int cleanup_before_linux(void) @@ -41,3 +42,24 @@ int cleanup_before_linux(void)
return 0; } + +#ifdef CONFIG_ARMV8_PSCI +static void relocate_secure_section(void) +{ +#ifdef CONFIG_ARMV8_SECURE_BASE + size_t sz = __secure_end - __secure_start; + + memcpy((void *)CONFIG_ARMV8_SECURE_BASE, __secure_start, sz); + flush_dcache_range(CONFIG_ARMV8_SECURE_BASE, + CONFIG_ARMV8_SECURE_BASE + sz + 1); + invalidate_icache_all(); +#endif +} + +void armv8_setup_psci(void) +{ + relocate_secure_section(); + secure_ram_addr(psci_setup_vectors)(); + secure_ram_addr(psci_arch_init)(); +} +#endif diff --git a/arch/arm/include/asm/secure.h b/arch/arm/include/asm/secure.h index 5a403bc..d23044a 100644 --- a/arch/arm/include/asm/secure.h +++ b/arch/arm/include/asm/secure.h @@ -6,7 +6,7 @@ #define __secure __attribute__ ((section ("._secure.text"))) #define __secure_data __attribute__ ((section ("._secure.data")))
-#ifdef CONFIG_ARMV7_SECURE_BASE +#if defined(CONFIG_ARMV7_SECURE_BASE) || defined(CONFIG_ARMV8_SECURE_BASE) /* * Warning, horror ahead. * diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 574a0e7..3f8e133 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -120,6 +120,17 @@ void smc_call(struct pt_regs *args); void __noreturn psci_system_reset(void); void __noreturn psci_system_off(void);
+#ifdef CONFIG_ARMV8_PSCI +extern char __secure_start[]; +extern char __secure_end[]; +extern char __secure_stack_start[]; +extern char __secure_stack_end[]; + +void armv8_setup_psci(void); +void psci_setup_vectors(void); +void psci_arch_init(void); +#endif + #endif /* __ASSEMBLY__ */
#else /* CONFIG_ARM64 */ diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 10a56e8..2c111bc 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -53,7 +53,8 @@ int arch_fixup_fdt(void *blob) return ret; #endif
-#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) || \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret; diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index dedcd1e..88919db 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -298,6 +298,9 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) announce_and_cleanup(fake);
if (!fake) { +#ifdef CONFIG_ARMV8_PSCI + armv8_setup_psci(); +#endif do_nonsec_virt_switch(); kernel_entry(images->ft_addr, NULL, NULL, NULL); } diff --git a/arch/arm/lib/psci-dt.c b/arch/arm/lib/psci-dt.c index 41e139e..45af037 100644 --- a/arch/arm/lib/psci-dt.c +++ b/arch/arm/lib/psci-dt.c @@ -16,7 +16,8 @@
int fdt_psci(void *fdt) { -#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) +#if defined(CONFIG_ARMV7_PSCI) || defined(CONFIG_ARMV8_PSCI) || \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) int nodeoff; unsigned int psci_ver = 0; int tmp; @@ -65,7 +66,7 @@ int fdt_psci(void *fdt) init_psci_node: #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT psci_ver = sec_firmware_support_psci_version(); -#elif defined(CONFIG_ARMV7_PSCI_1_0) +#elif defined(CONFIG_ARMV7_PSCI_1_0) || defined(CONFIG_ARMV8_PSCI) psci_ver = ARM_PSCI_VER_1_0; #endif switch (psci_ver) {
A most basic PSCI implementation with only one psci_version is added for LS1043A, this can verify the generic PSCI framework, and more platform specific implementation will be added later.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S | 20 ++++++++++++++++++++ board/freescale/ls1043ardb/Kconfig | 9 +++++++++ configs/ls1043ardb_defconfig | 3 +++ 4 files changed, 33 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 51c1cee..423b4b3 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -28,6 +28,7 @@ endif
ifneq ($(CONFIG_LS1043A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1043a_serdes.o +obj-$(CONFIG_ARMV8_PSCI) += ls1043a_psci.o endif
ifneq ($(CONFIG_ARCH_LS1012A),) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S new file mode 100644 index 0000000..86045ac --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S @@ -0,0 +1,20 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Author: Hongbo Zhang hongbo.zhang@nxp.com + * + * SPDX-License-Identifier: GPL-2.0+ + * This file implements LS102X platform PSCI SYSTEM-SUSPEND function + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + +.globl psci_version +psci_version: + ldr w0, =0x00010000 /* PSCI v1.0 */ + ret + + .popsection diff --git a/board/freescale/ls1043ardb/Kconfig b/board/freescale/ls1043ardb/Kconfig index 51818ec..0c596f9 100644 --- a/board/freescale/ls1043ardb/Kconfig +++ b/board/freescale/ls1043ardb/Kconfig @@ -13,4 +13,13 @@ config SYS_SOC config SYS_CONFIG_NAME default "ls1043ardb"
+config SYS_HAS_ARMV8_SECURE_BASE + bool "Enable secure RAM for PSCI image" + depends on ARMV8_PSCI + default y + help + PSCI image can be re-located to secure RAM. + If enabled, please also define the value for ARMV8_SECURE_BASE, + for LS1043ARDB, it is address in OCRAM. + endif diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 79a4eb2..cb189f3 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -28,3 +28,6 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_ARMV8_PSCI=y +CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER=4 +CONFIG_ARMV8_SECURE_BASE=0x10010000
- Copyright 2016 Freescale Semiconductor, Inc.
- Author: Hongbo Zhang hongbo.zhang@nxp.com
- This file implements LS102X platform PSCI SYSTEM-SUSPEND function
- .pushsection ._secure.text, "ax"
- ldr w0, =0x00010000 /* PSCI v1.0 */
- ret
- .popsection
- bool "Enable secure RAM for PSCI image"
- default y
- help
You enabled this generic PSCI support for LS1043A. How do you use PPA then?
York
Oops. I did remove this generic PSCI for LS platform since we have our specific PPA, but that change wasn't included at last, I'll update this.
ret
.popsection
default y
help
York
v3-v4 changes:
v2-v3 changes:
v1-v2 changes:
v1 notes:
Hongbo,
Can you educate me how this generic PSCI framework co-exist with PPA or other secure firmware?
York
Hi York, This generic PSCI is controlled by CONFIG_ARMV8_PSCI, if enabled, any platform can implement their own PSCI functions under this framework, this is all similar with ARMv7's.
While PPA is controlled by CONFIG_FSL_LS_PPA, and the private PSCI inside the PPA is controlled by FSL_PPA_ARMV8_PSCI, this macro depends on and selected by CONFIG_FSL_LS_PPA.
That is to say, they are using separate configs, and only one of them can be enabled at one time.
v3-v4 changes:
v2-v3 changes:
v1-v2 changes:
v1 notes:
Hongbo,
York
That's what I am looking for. So these two options are mutually exclusive. But you don't have that in Kconfig. I can run menuconfig and get this result in .config file
# # Layerscape PPA # CONFIG_FSL_LS_PPA=y CONFIG_FSL_PPA_ARMV8_PSCI=y CONFIG_SYS_FSL_ERRATUM_A010539=y CONFIG_ARMV8_MULTIENTRY=y # CONFIG_ARMV8_SPIN_TABLE is not set CONFIG_ARMV8_PSCI=y CONFIG_ARMV8_PSCI_NR_CPUS=4 CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER=0 CONFIG_IDENT_STRING="" # CONFIG_PRE_CONSOLE_BUFFER is not set # CONFIG_VIDEO is not set
You can see both options can be enabled from menuconfig. Please see comments in other patches as well.
York
Will add "depends on !ARMV8_PSCI" for FSL_LS_PPA and "depends on !FSL_LS_PPA" for ARMV8_PSCI
Thanks.
York
Hongbo Zhang
york sun
