[U-Boot] [PATCH v2 1/2] x86: TunnelCreek: switch P state to the highest freq
Fixes performance related issue when running vxWorks 5/7 images. The overall memory performance (L1, L2 cache and ram) was measured with Bandwidth [0].
Without this patch we get following numbers: - sequential 128-bit reads: ~5.2 GB/s - sequential 128-bit copy: ~2.1 GB/s - random 32-bit writes: ~1.2 GB/s
With this patch patch we get the following numbers: - sequential 128-bit reads: ~18.0 GB/s - sequential 128-bit copy: ~9.5 GB/s - random 32-bit writes: ~5.0 GB/s
[0] https://zsmith.co/bandwidth.html
v1 -> v2: - incorporate feedback from Bin Meng
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- arch/x86/cpu/queensbay/Makefile | 2 +- arch/x86/cpu/queensbay/cpu.c | 58 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 59 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/queensbay/cpu.c
diff --git a/arch/x86/cpu/queensbay/Makefile b/arch/x86/cpu/queensbay/Makefile index c0681995bd..3dd23465d4 100644 --- a/arch/x86/cpu/queensbay/Makefile +++ b/arch/x86/cpu/queensbay/Makefile @@ -5,4 +5,4 @@ #
obj-y += fsp_configs.o irq.o -obj-y += tnc.o +obj-y += tnc.o cpu.o diff --git a/arch/x86/cpu/queensbay/cpu.c b/arch/x86/cpu/queensbay/cpu.c new file mode 100644 index 0000000000..805a94cc27 --- /dev/null +++ b/arch/x86/cpu/queensbay/cpu.c @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2018, Bachmann electronic GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <cpu.h> +#include <dm.h> +#include <asm/cpu.h> +#include <asm/cpu_x86.h> +#include <asm/msr.h> + +static void set_max_freq(void) +{ + msr_t msr; + + /* Enable enhanced speed step */ + msr = msr_read(MSR_IA32_MISC_ENABLES); + msr.lo |= (1 << 16); + msr_write(MSR_IA32_MISC_ENABLES, msr); + + /* Set new performance state */ + msr = msr_read(MSR_IA32_PERF_CTL); + msr.lo = 0x101f; + msr_write(MSR_IA32_PERF_CTL, msr); +} + +static int cpu_x86_tunnelcreek_probe(struct udevice *dev) +{ + if (!ll_boot_init()) + return 0; + debug("Init TunnelCreek core\n"); + + /* Set core to max frequency ratio */ + set_max_freq(); + + return 0; +} + +static const struct cpu_ops cpu_x86_tunnelcreek_ops = { + .get_desc = cpu_x86_get_desc, + .get_count = cpu_x86_get_count, +}; + +static const struct udevice_id cpu_x86_tunnelcreek_ids[] = { + { .compatible = "intel,tunnelcreek-cpu" }, + { } +}; + +U_BOOT_DRIVER(cpu_x86_tunnelcreek_drv) = { + .name = "cpu_x86_tunnelcreek", + .id = UCLASS_CPU, + .of_match = cpu_x86_tunnelcreek_ids, + .bind = cpu_x86_bind, + .probe = cpu_x86_tunnelcreek_probe, + .ops = &cpu_x86_tunnelcreek_ops, +};
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- arch/x86/dts/crownbay.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index 78a1ef415c..bb39a895f6 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -32,14 +32,14 @@
cpu@0 { device_type = "cpu"; - compatible = "cpu-x86"; + compatible = "intel,tunnelcreek-cpu"; reg = <0>; intel,apic-id = <0>; };
cpu@1 { device_type = "cpu"; - compatible = "cpu-x86"; + compatible = "intel,tunnelcreek-cpu"; reg = <1>; intel,apic-id = <1>; };
Hi Christian,
On Thu, Apr 12, 2018 at 4:07 PM, Christian Gmeiner christian.gmeiner@gmail.com wrote:
nits: vxWorks -> VxWorks
v1 -> v2:
This should not show in the commit message.
- Copyright (C) 2018, Bachmann electronic GmbH
msr_t msr;
msr.lo = 0x101f;
I tried to find any documentation that describes the performance state values of the TunnelCreek processor, but in vain. However when I read the doc, I do have a question here:
The enhanced speedstep technology is set to disabled by the processor after power-on, that means we don't need set the performance state (P-state) via the MSR_IA32_PERF_CTL and the processor itself should work under its maximum base frequency. So I believe this whole set_max_freq() is not needed. Can you clarify this?
set_max_freq();
.id = UCLASS_CPU,
Regards, Bin
Christian, I got some time to look at this old patch, and I see my last question remained unanswered.
+Andy,
Hi Andy,
On Thu, May 24, 2018 at 12:00 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Christian,
v1 -> v2:
msr_t msr;
msr.lo = 0x101f;
I hope you can give some clarification about Enhanced Intel Speedstep (EIST) technology. I read Intel 64 and IA-32 Architectures SDM volume 3: chapter 14 "POWER AND THERMAL MANAGEMENT" and it does not say much about this EIST. Especially I want to know whether the process is running at the highest frequency if EIST is disabled which is the case after power-on (MSR_IA32_MISC_ENABLES bit[16] is 0).
A related discussion after Googling is: https://forums.anandtech.com/threads/actual-difference-between-speedstep-and... It says: "The base frequency is the highest P-state called P0, and every step below that using EIST goes P1, P2, etc. Turbo Mode only activates when the CPU is at P0 state, then every speed above the base clock is decided by the CPU."
So to me this seems to match my understanding about EIST. If this is true, then I can't explain why Christian's patch is needed since the EIST is disabled on TunnelCreek by default and the processor should already run at the highest performance.
Regards, Bin
The some internal documents I found suggesting that first what one needs to do is to be sure that EIST is enabled / disabled by reading a bit from CPUID.
(There is no mention of the exact bit, I'm guessing it might be X86_FEATURE_EST)
It also refers to IA32_MISC_ENABLE MSR, i.e. bit 20 (MSR_IA32_MISC_ENABLE_SPEEDSTEP_LOCK_BIT) and bit 16 (MSR_IA32_MISC_ENABLE_ENHANCED_SPEEDSTEP_BIT), that firmware can set up accordingly.
Hope this helps.
P.S. All names are implying Linux kernel source code.
Hi Andy,
On Wed, Mar 6, 2019 at 7:09 PM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Correct. This is documented in the public Intel SDM too.
Hope this helps.
Thanks for the help. But I was looking for clarification on what frequency the CPU is running at if EIST is disabled (the default power-up state). Especially I suspect the Intel CPU is running at the highest frequency when ESIT is disabled hence the highest performance. Such details are not documented in the public Intel SDM. :(
Regards, Bin
Hi all,
Am Mo., 11. März 2019 um 15:41 Uhr schrieb Bin Meng bmeng.cn@gmail.com:
Hi Andy,
Hope this helps.
I think I need to clarify how I came to this patch.
Back in the days when we used an Intel BLDK based BIOS solution we did some performance measurements and found out that the same device with an vendor BIOS is much faster. So we started to dig into the issue and used bandwidth to do our measurements. We contacted Intel to get support and after lot of ping-pong mails we got a solution.
We need to set these two msr registers to the values they provided to us. These msr register should be described in #29324.
Bin do you have hardware to reproduce this issue I have and what gets fixed with this patch?
Hi Christian,
On Wed, Mar 13, 2019 at 5:27 PM Christian Gmeiner christian.gmeiner@gmail.com wrote:
Hi all,
Hi Andy,
Hope this helps.
Could you please provide details about these 2 MSR registers? And is there any official document from Intel about what is the behavior of having EIST disabled?
Yes, I have the hardware to test. Is the test case able to run in U-Boot? I can have a test.
Regards, Bin
Hi Bin,
Am Fr., 15. März 2019 um 09:03 Uhr schrieb Bin Meng bmeng.cn@gmail.com:
Hi Christian,
Hi all,
Hi Andy,
Hope this helps.
I only got an excerpt of two pages describing these 2 MSR and I am quite sure I am not allowed to share these. As I wrote these MSR should be documented in #29324 (which I do not have access to).
Boot into linux and run https://zsmith.co/bandwidth.html
Hi Christian,
On Mon, Apr 1, 2019 at 3:48 PM Christian Gmeiner christian.gmeiner@gmail.com wrote:
Hi Bin,
Hi Christian,
Hi all,
Hi Andy,
On Thu, May 24, 2018 at 12:00 PM Bin Meng bmeng.cn@gmail.com wrote: > On Thu, Apr 12, 2018 at 4:07 PM, Christian Gmeiner > christian.gmeiner@gmail.com wrote:
Hope this helps.
Thanks for sharing the information.
Andy, do you have access to the #29324, and check whether it has some explanation about my assumption about Intel EIST?
Thanks. I will need run some testing when I get the board.
Regards, Bin
On Thu, Feb 28, 2019 at 11:29:50AM +0800, Bin Meng wrote: > On Thu, May 24, 2018 at 12:00 PM Bin Meng bmeng.cn@gmail.com wrote: > > On Thu, Apr 12, 2018 at 4:07 PM, Christian Gmeiner > > christian.gmeiner@gmail.com wrote:
I have no idea what that number means. Christian might sent me (*) at least a title of the document for easy search.
*) privately to @intel.com address, for example.
Andy Shevchenko
Bin Meng
Christian Gmeiner
