[PATCH V3 1/9] uclass: cpu: Add new API to get udevice for current CPU
When running on SoC with multiple clusters, the boot CPU may not be fixed, saying booting from cluster A or cluster B. Add a API that can return the udevice for current boot CPU. Cpu driver needs to implement is_current_cpu interface for this feature, otherwise the API only returns the first udevice in cpu uclass.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com --- V3: Drop ops check. Add R-b
V2: Per Simon's comment, - Add cpu_is_current - use uclass_foreach_dev_probe - Update code comment
drivers/cpu/cpu-uclass.c | 34 ++++++++++++++++++++++++++++++++++ include/cpu.h | 23 +++++++++++++++++++++++ 2 files changed, 57 insertions(+)
diff --git a/drivers/cpu/cpu-uclass.c b/drivers/cpu/cpu-uclass.c index 457f77b7c8..8352e2eb0b 100644 --- a/drivers/cpu/cpu-uclass.c +++ b/drivers/cpu/cpu-uclass.c @@ -10,6 +10,7 @@ #include <errno.h> #include <dm/lists.h> #include <dm/root.h> +#include <linux/err.h>
int cpu_probe_all(void) { @@ -34,6 +35,39 @@ int cpu_probe_all(void) return 0; }
+int cpu_is_current(struct udevice *cpu) +{ + struct cpu_ops *ops = cpu_get_ops(cpu); + + if (ops->is_current) { + if (ops->is_current(cpu)) + return 1; + } + + return -ENOSYS; +} + +struct udevice *cpu_get_current_dev(void) +{ + struct udevice *cpu; + int ret; + + uclass_foreach_dev_probe(UCLASS_CPU, cpu) { + if (cpu_is_current(cpu) > 0) + return cpu; + } + + /* If can't find current cpu device, use the first dev instead */ + ret = uclass_first_device_err(UCLASS_CPU, &cpu); + if (ret) { + debug("%s: Could not get CPU device (err = %d)\n", + __func__, ret); + return NULL; + } + + return cpu; +} + int cpu_get_desc(struct udevice *dev, char *buf, int size) { struct cpu_ops *ops = cpu_get_ops(dev); diff --git a/include/cpu.h b/include/cpu.h index 6b1b6b37b3..2f283fe244 100644 --- a/include/cpu.h +++ b/include/cpu.h @@ -89,6 +89,15 @@ struct cpu_ops { * @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error */ int (*get_vendor)(struct udevice *dev, char *buf, int size); + + /** + * is_current() - Check if the CPU that U-Boot is currently running from + * + * @dev: Device to check (UCLASS_CPU) + * @return 1 if the CPU that U-Boot is currently running from, 0 + * if not. + */ + int (*is_current)(struct udevice *dev); };
#define cpu_get_ops(dev) ((struct cpu_ops *)(dev)->driver->ops) @@ -137,4 +146,18 @@ int cpu_get_vendor(struct udevice *dev, char *buf, int size); */ int cpu_probe_all(void);
+/** + * cpu_is_current() - Check if the CPU that U-Boot is currently running from + * + * Return: 1 if yes, - 0 if not + */ +int cpu_is_current(struct udevice *cpu); + +/** + * cpu_get_current_dev() - Get CPU udevice for current CPU + * + * Return: udevice if OK, - NULL on error + */ +struct udevice *cpu_get_current_dev(void); + #endif
Support querying whether U-Boot is running on current cpu
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com --- V3: Add R-b V2: New
drivers/cpu/cpu_sandbox.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/cpu/cpu_sandbox.c b/drivers/cpu/cpu_sandbox.c index 05b384f6a4..30a12e5a53 100644 --- a/drivers/cpu/cpu_sandbox.c +++ b/drivers/cpu/cpu_sandbox.c @@ -36,11 +36,20 @@ int cpu_sandbox_get_vendor(struct udevice *dev, char *buf, int size) return 0; }
+int cpu_sandbox_is_current(struct udevice *dev) +{ + if (!strcmp(dev->name, "cpu-test1")) + return 1; + + return 0; +} + static const struct cpu_ops cpu_sandbox_ops = { .get_desc = cpu_sandbox_get_desc, .get_info = cpu_sandbox_get_info, .get_count = cpu_sandbox_get_count, .get_vendor = cpu_sandbox_get_vendor, + .is_current = cpu_sandbox_is_current, };
int cpu_sandbox_probe(struct udevice *dev)
Support querying whether U-Boot is running on current cpu Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Add test whether the CPU is U-Boot is running from.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com --- V3: Add R-b tag V2: New
test/dm/cpu.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/dm/cpu.c b/test/dm/cpu.c index e6dc576ea3..def9b64a28 100644 --- a/test/dm/cpu.c +++ b/test/dm/cpu.c @@ -26,6 +26,8 @@ static int dm_test_cpu(struct unit_test_state *uts) ut_assert(dev->flags & DM_FLAG_ACTIVATED);
ut_assertok(uclass_get_device_by_name(UCLASS_CPU, "cpu-test1", &dev)); + ut_asserteq_ptr(cpu_get_current_dev(), dev); + ut_asserteq(cpu_is_current(dev), 1);
ut_assertok(cpu_get_desc(dev, text, sizeof(text))); ut_assertok(strcmp(text, "LEG Inc. SuperMegaUltraTurbo CPU No. 1"));
Add test whether the CPU is U-Boot is running from. Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com
Current print_cpuinfo gets the first udevice in CPU class to return the cpu info. This has problem if the boot CPU is not fixed.
Changing to use new API cpu_get_current_dev to fix the issue.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com ---
V3: None V2: None
common/board_f.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 5c650f046c..5223453511 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -183,11 +183,11 @@ static int print_cpuinfo(void) char desc[512]; int ret;
- ret = uclass_first_device_err(UCLASS_CPU, &dev); - if (ret) { - debug("%s: Could not get CPU device (err = %d)\n", - __func__, ret); - return ret; + dev = cpu_get_current_dev(); + if (!dev) { + debug("%s: Could not get CPU device\n", + __func__); + return -ENODEV; }
ret = cpu_get_desc(dev, desc, sizeof(desc));
From: Ye Li ye.li@nxp.com Current print_cpuinfo gets the first udevice in CPU class to return the cpu info. This has problem if the boot CPU is not fixed. Changing to use new API cpu_get_current_dev to fix the issue. Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com
Return 4 is not correct on i.MX8DX/DXL/8QM and etc. we need to count available cpu node with device_type "cpu".
V3: None V2: Add R-b tag
drivers/cpu/imx8_cpu.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 95653683ac..7c54c290b8 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -118,7 +118,24 @@ static int cpu_imx_get_info(struct udevice *dev, struct cpu_info *info)
static int cpu_imx_get_count(struct udevice *dev) { - return 4; + ofnode node; + int num = 0; + + ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { + const char *device_type; + + if (!ofnode_is_available(node)) + continue; + + device_type = ofnode_read_string(node, "device_type"); + if (!device_type) + continue; + + if (!strcmp(device_type, "cpu")) + num++; + } + + return num; }
static int cpu_imx_get_vendor(struct udevice *dev, char *buf, int size)
Return 4 is not correct on i.MX8DX/DXL/8QM and etc. we need to count available cpu node with device_type "cpu". Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com
Support booting i.MX8QM with A72 as boot cpu
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com --- V3: None V2: Add R-b tag
drivers/cpu/imx8_cpu.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 7c54c290b8..c4679e1642 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -20,6 +20,7 @@ struct cpu_imx_platdata { const char *type; u32 cpurev; u32 freq_mhz; + u32 mpidr; };
const char *get_imx8_type(u32 imxtype) @@ -144,16 +145,28 @@ static int cpu_imx_get_vendor(struct udevice *dev, char *buf, int size) return 0; }
+static int cpu_imx_is_current(struct udevice *dev) +{ + struct cpu_imx_platdata *plat = dev_get_platdata(dev); + + if (plat->mpidr == (read_mpidr() & 0xffff)) + return 1; + + return 0; +} + static const struct cpu_ops cpu_imx8_ops = { .get_desc = cpu_imx_get_desc, .get_info = cpu_imx_get_info, .get_count = cpu_imx_get_count, .get_vendor = cpu_imx_get_vendor, + .is_current = cpu_imx_is_current, };
static const struct udevice_id cpu_imx8_ids[] = { { .compatible = "arm,cortex-a35" }, { .compatible = "arm,cortex-a53" }, + { .compatible = "arm,cortex-a72" }, { } };
@@ -185,6 +198,12 @@ static int imx8_cpu_probe(struct udevice *dev) plat->rev = get_imx8_rev(cpurev & 0xFFF); plat->type = get_imx8_type((cpurev & 0xFF000) >> 12); plat->freq_mhz = imx8_get_cpu_rate() / 1000000; + plat->mpidr = dev_read_addr(dev); + if (plat->mpidr == FDT_ADDR_T_NONE) { + printf("%s: Failed to get CPU reg property\n", __func__); + return -EINVAL; + } + return 0; }
Support booting i.MX8QM with A72 as boot cpu Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com
When current cpu is A53, using is_cortex_a53 could not detect A72 information, so check cpu device compatible property to get the correct information.
drivers/cpu/imx8_cpu.c | 27 +++++++++++++++++---------- 1 file changed, 17 insertions(+), 10 deletions(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index c4679e1642..cd11b78d06 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -48,13 +48,13 @@ const char *get_imx8_rev(u32 rev) } }
-const char *get_core_name(void) +const char *get_core_name(struct udevice *dev) { - if (is_cortex_a35()) + if (!device_is_compatible(dev, "arm,cortex-a35")) return "A35"; - else if (is_cortex_a53()) + else if (!device_is_compatible(dev, "arm,cortex-a53")) return "A53"; - else if (is_cortex_a72()) + else if (!device_is_compatible(dev, "arm,cortex-a72")) return "A72"; else return "?"; @@ -170,12 +170,19 @@ static const struct udevice_id cpu_imx8_ids[] = { { } };
-static ulong imx8_get_cpu_rate(void) +static ulong imx8_get_cpu_rate(struct udevice *dev) { ulong rate; - int ret; - int type = is_cortex_a35() ? SC_R_A35 : is_cortex_a53() ? - SC_R_A53 : SC_R_A72; + int ret, type; + + if (!device_is_compatible(dev, "arm,cortex-a35")) + type = SC_R_A35; + else if (!device_is_compatible(dev, "arm,cortex-a53")) + type = SC_R_A53; + else if (!device_is_compatible(dev, "arm,cortex-a72")) + type = SC_R_A72; + else + return 0;
ret = sc_pm_get_clock_rate(-1, type, SC_PM_CLK_CPU, (sc_pm_clock_rate_t *)&rate); @@ -194,10 +201,10 @@ static int imx8_cpu_probe(struct udevice *dev)
cpurev = get_cpu_rev(); plat->cpurev = cpurev; - plat->name = get_core_name(); + plat->name = get_core_name(dev); plat->rev = get_imx8_rev(cpurev & 0xFFF); plat->type = get_imx8_type((cpurev & 0xFF000) >> 12); - plat->freq_mhz = imx8_get_cpu_rate() / 1000000; + plat->freq_mhz = imx8_get_cpu_rate(dev) / 1000000; plat->mpidr = dev_read_addr(dev); if (plat->mpidr == FDT_ADDR_T_NONE) { printf("%s: Failed to get CPU reg property\n", __func__);
When current cpu is A53, using is_cortex_a53 could not detect A72 information, so check cpu device compatible property to get the correct information. Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com
iMX8QM registers two thermal devices for CPUs, get the temperature from "cpu-thermal1" device for A72
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- V3: None V2: Per Simon's comments, use uclass_get_device
drivers/cpu/imx8_cpu.c | 18 ++++++++++++------ 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index cd11b78d06..85ba7b7df2 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -61,13 +61,15 @@ const char *get_core_name(struct udevice *dev) }
#if IS_ENABLED(CONFIG_IMX_SCU_THERMAL) -static int cpu_imx_get_temp(void) +static int cpu_imx_get_temp(struct cpu_imx_platdata *plat) { struct udevice *thermal_dev; int cpu_tmp, ret;
- ret = uclass_get_device_by_name(UCLASS_THERMAL, "cpu-thermal0", - &thermal_dev); + if (!strcmp(plat->name, "A72")) + ret = uclass_get_device(UCLASS_THERMAL, 1, &thermal_dev); + else + ret = uclass_get_device(UCLASS_THERMAL, 0, &thermal_dev);
if (!ret) { ret = thermal_get_temp(thermal_dev, &cpu_tmp); @@ -80,7 +82,7 @@ static int cpu_imx_get_temp(void) return cpu_tmp; } #else -static int cpu_imx_get_temp(void) +static int cpu_imx_get_temp(struct cpu_imx_platdata *plat) { return 0; } @@ -89,7 +91,7 @@ static int cpu_imx_get_temp(void) int cpu_imx_get_desc(struct udevice *dev, char *buf, int size) { struct cpu_imx_platdata *plat = dev_get_platdata(dev); - int ret; + int ret, temp;
if (size < 100) return -ENOSPC; @@ -98,9 +100,13 @@ int cpu_imx_get_desc(struct udevice *dev, char *buf, int size) plat->type, plat->rev, plat->name, plat->freq_mhz);
if (IS_ENABLED(CONFIG_IMX_SCU_THERMAL)) { + temp = cpu_imx_get_temp(plat); buf = buf + ret; size = size - ret; - ret = snprintf(buf, size, " at %dC", cpu_imx_get_temp()); + if (temp != 0xdeadbeef) + ret = snprintf(buf, size, " at %dC", temp); + else + ret = snprintf(buf, size, " - invalid sensor data"); }
snprintf(buf + ret, size - ret, "\n");
From: Ye Li ye.li@nxp.com iMX8QM registers two thermal devices for CPUs, get the temperature from "cpu-thermal1" device for A72 Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com
Add REVC informaiton.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Frank Li Frank.Li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com ---
arch/arm/include/asm/arch-imx/cpu.h | 1 + drivers/cpu/imx8_cpu.c | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 5ade63665a..06b8122e7c 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -57,6 +57,7 @@
#define CHIP_REV_A 0x0 #define CHIP_REV_B 0x1 +#define CHIP_REV_C 0x2
#define BOARD_REV_1_0 0x0 #define BOARD_REV_2_0 0x1 diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 85ba7b7df2..95c14c98d8 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -43,6 +43,8 @@ const char *get_imx8_rev(u32 rev) return "A"; case CHIP_REV_B: return "B"; + case CHIP_REV_C: + return "C"; default: return "?"; }
From: Frank Li Frank.Li@nxp.com Add REVC informaiton. Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Frank Li Frank.Li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com
When running on SoC with multiple clusters, the boot CPU may not be fixed, saying booting from cluster A or cluster B. Add a API that can return the udevice for current boot CPU. Cpu driver needs to implement is_current_cpu interface for this feature, otherwise the API only returns the first udevice in cpu uclass. Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com
Peng Fan
sbabic@denx.de
