[PATCH 0/2] Introduce spl_arch_init() for architecture specific initialization
Currently some architectures use spl_board_init() for their architecture specific initialization. This prohibits board developers from adding board init code using said function. This series introduces a new function in order to separate arch init code from board init code.
Lukas Funke (2): spl: Introduce architecture specific init function arm64: zynq(mp): Rename spl_board_init() to spl_arch_init()
arch/arm/Kconfig | 4 ++-- arch/arm/mach-zynq/spl.c | 4 ++-- arch/arm/mach-zynqmp/spl.c | 4 ++-- common/spl/Kconfig | 7 +++++++ common/spl/spl.c | 3 +++ include/spl.h | 8 ++++++++ 6 files changed, 24 insertions(+), 6 deletions(-)
Some architectures use spl_board_init() in their architecture specific implementation. Board developers should be able to add board specific implementation via spl_board_init(). Hence, introduce a spl_arch_init() method which is called right before spl_board_init() for architecture specific implementation.
Signed-off-by: Lukas Funke lukas.funke@weidmueller.com ---
common/spl/Kconfig | 7 +++++++ common/spl/spl.c | 3 +++ include/spl.h | 8 ++++++++ 3 files changed, 18 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6405374bcc..1a987037bb 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -272,6 +272,13 @@ config SPL_TEXT_BASE help The address in memory that SPL will be running from.
+config SPL_ARCH_INIT + bool "Call arch-specific initialization in SPL" + help + If this option is enabled, U-Boot will call the function + spl_arch_init() from board_init_r(). This function should be + provided by the architecture. + config SPL_BOARD_INIT bool "Call board-specific initialization in SPL" help diff --git a/common/spl/spl.c b/common/spl/spl.c index b65c439e7a..2f2deae14f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -711,6 +711,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) } }
+ if (CONFIG_IS_ENABLED(ARCH_INIT)) + spl_arch_init(); + if (CONFIG_IS_ENABLED(BOARD_INIT)) spl_board_init();
diff --git a/include/spl.h b/include/spl.h index 043875f10f..2d23c8c0de 100644 --- a/include/spl.h +++ b/include/spl.h @@ -816,6 +816,14 @@ int spl_early_init(void); */ int spl_init(void);
+/* + * spl_arch_init() - Do architecture-specific init in SPL + * + * If SPL_ARCH_INIT is enabled, this is called from board_init_r() before + * jumping to the next phase. + */ +void spl_arch_init(void); + /* * spl_board_init() - Do board-specific init in SPL *
On Wed, Mar 20, 2024 at 02:19:26PM +0100, lukas.funke-oss@weidmueller.com wrote:
I think this could allow for other SoCs to clean up their existing ad-hoc mechanisms for SoC/architecture init and then board init, so this looks like a good idea to me.
Hi Tom, Lukas,
Thanks for the patch Lukas.
Does it make more sense to make this SoC specific then instead of arch specific to allow broader range of code?
For e.g., if we have something like spl_soc_init then it would help accommodate soc specific functionality too along with calling arch specific code ?
Also I see some vendors already having implemented spl_soc_init in their arch specific files [1], so I think it would be good if it is moved it to framework level.
[1] : https://source.denx.de/u-boot/u-boot/-/blob/master/arch/riscv/cpu/fu540/spl.... https://source.denx.de/u-boot/u-boot/-/blob/master/arch/riscv/include/asm/ar...
Regards Devarsh
On Wed, Mar 20, 2024 at 08:52:30PM +0530, Devarsh Thakkar wrote:
Hi Tom, Lukas,
"soc" and "arch" are somewhat interchangeable at times, so I think we can go one step at a time here and bring in this abstraction and see where everyone else is able to clean their code up to.
Hi Tom, Lukas,
Isn't "arch" ambiguous anyway? I connect that with CPU architecture, as in x86, ARM, RISC-V. And we have that in the top level directories: arch/arm, etc. But here it's one level below, isn't it? Where "platform" (or "plat") would be a more suiting term to describe a SoC family, like xilinx or sunxi? So the hierarchy would be really: arch -> plat -> soc -> board?
Or am I confused here?
Cheers, Andre
Hi Tom, Lukas,
No. But in some cases the 'platform' level is missing: for xilinx it's "arch->arm->mach-zynq-><impl>", for rockchip it's "arch->arm->plat->soc", i.e. "arch->arm->mach-rockchip->rk3399-><impl>". If we follow your proposed rule it should be: arch->arm->mach-xilinx->zynq-><impl>. Maybe this is an idea for the next cleanup round?
Regarding the patch:
I'd agree that the init code is not (cpu)architecture dependent. Some vendors init the console, some init the ddr, some init the leds and so on. Thus, we should go one level upwards and change it to "spl_soc_init()" if everyone is okay with it?
Best regards, Lukas
Cheers, Andre
čt 21. 3. 2024 v 8:55 odesílatel Lukas Funke < lukas.funke-oss@weidmueller.com> napsal:
Hi Tom, Lukas,
specific
spl_arch_init()
in
arch/arm,
In our case soc and plat are the same. Arch is clear that's armv7/v8, socs/platform are zynq/zynqmp/versal/versal-net And boards are generic/kria or antminer, syzygy, topic, etc.
And agree that we should do some cleanup in this.
Thanks, Michal
Rename spl_board_init() to spl_arch_init(). Architecture specific implementation should be separated from board specific implementation in order to be extended by board developers.
arch/arm/Kconfig | 4 ++-- arch/arm/mach-zynq/spl.c | 4 ++-- arch/arm/mach-zynqmp/spl.c | 4 ++-- 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01d6556c42..4ea889d09b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1275,7 +1275,7 @@ config ARCH_ZYNQ select OF_CONTROL select MTD select SPI - select SPL_BOARD_INIT if SPL + select SPL_ARCH_INIT if SPL select SPL_CLK if SPL select SPL_DM if SPL select SPL_DM_SPI if SPL @@ -1318,7 +1318,7 @@ config ARCH_ZYNQMP imply FIRMWARE select GICV2 select OF_CONTROL - select SPL_BOARD_INIT if SPL + select SPL_ARCH_INIT if SPL select SPL_CLK if SPL select SPL_DM if SPL select SPL_DM_SPI if SPI && SPL_DM diff --git a/arch/arm/mach-zynq/spl.c b/arch/arm/mach-zynq/spl.c index fea1c9b12a..0cae792e21 100644 --- a/arch/arm/mach-zynq/spl.c +++ b/arch/arm/mach-zynq/spl.c @@ -32,8 +32,8 @@ void board_init_f(ulong dummy) arch_cpu_init(); }
-#ifdef CONFIG_SPL_BOARD_INIT -void spl_board_init(void) +#ifdef CONFIG_SPL_ARCH_INIT +void spl_arch_init(void) { preloader_console_init(); #if defined(CONFIG_ARCH_EARLY_INIT_R) && defined(CONFIG_SPL_FPGA) diff --git a/arch/arm/mach-zynqmp/spl.c b/arch/arm/mach-zynqmp/spl.c index a0f35f36fa..03a45173e6 100644 --- a/arch/arm/mach-zynqmp/spl.c +++ b/arch/arm/mach-zynqmp/spl.c @@ -56,8 +56,8 @@ static void ps_mode_reset(ulong mode) # define MODE_RESET PS_MODE1 #endif
-#ifdef CONFIG_SPL_BOARD_INIT -void spl_board_init(void) +#ifdef CONFIG_SPL_ARCH_INIT +void spl_arch_init(void) { preloader_console_init(); ps_mode_reset(MODE_RESET);
participants (6)
Andre Przywara
Devarsh Thakkar
Lukas Funke
Michal Simek
