[U-Boot] [PATCH v3] ppc4xx fix unstable 440EPx bootstrap options
440EPx fixed bootstrap options A, B, D, and E sets PLL FWDVA to a value = 1. This results in the PLLOUTB being greater than the CPU clock frequency resulting unstable 440EPx operation resulting in various software hang conditions.
This patch reprograms the FWDVA satisfying the requirement of setting FWDVB to a value greater than 1 while using one of the four deafult bootstrap options.
Signed-off-by: Rupjyoti Sarmah rsarmah@amcc.com Acked-by : Victor Gallardo vgallardo@appliedmicro.com --- cpu/ppc4xx/cpu_init.c | 65 +++++++++++++++++++++++++++++++++++++++++++++---- include/ppc440.h | 6 ++++ 2 files changed, 66 insertions(+), 5 deletions(-)
diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index ccd9993..8a6e545 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -111,17 +111,72 @@ void reconfigure_pll(u32 new_cpu_freq) mtcpr(CPR0_SPCID, reg); reset_needed = 1; } + } + + /* Get current value of FWDVA.*/ + mfcpr(CPR0_PLLD, reg); + temp = (reg & PLLD_FWDVA_MASK) >> 16;
- /* Set reload inhibit so configuration will persist across - * processor resets */ + /* + * Check to see if FWDVA has been set to value of 1. if it has we must + * modify it. + */ + if (temp == 1) { + mfcpr(CPR0_PLLD, reg); + /* Get current value of fbdv. */ + temp = (reg & PLLD_FBDV_MASK) >> 24; + fbdv = temp ? temp : 32; + /* Get current value of lfbdv. */ + temp = (reg & PLLD_LFBDV_MASK); + lfbdv = temp ? temp : 64; + /* + * Load register that contains current boot strapping option. + */ + mfcpr(CPR0_ICFG, reg); + /* Shift strapping option into low 3 bits.*/ + reg = (reg >> 28); + + if ((reg == BOOT_STRAP_OPTION_A) || (reg == BOOT_STRAP_OPTION_B) || + (reg == BOOT_STRAP_OPTION_D) || (reg == BOOT_STRAP_OPTION_E)) { + /* + * Get current value of FWDVA. Assign current FWDVA to + * new FWDVB. + */ + mfcpr(CPR0_PLLD, reg); + target_fwdvb = (reg & PLLD_FWDVA_MASK) >> 16; + fwdvb = target_fwdvb ? target_fwdvb : 8; + /* + * Get current value of FWDVB. Assign current FWDVB to + * new FWDVA. + */ + target_fwdva = (reg & PLLD_FWDVB_MASK) >> 8; + fwdva = target_fwdva ? target_fwdva : 16; + /* + * Update CPR0_PLLD with switched FWDVA and FWDVB. + */ + reg &= ~(PLLD_FWDVA_MASK | PLLD_FWDVB_MASK | + PLLD_FBDV_MASK | PLLD_LFBDV_MASK); + reg |= ((fwdva == 16 ? 0 : fwdva) << 16) | + ((fwdvb == 8 ? 0 : fwdvb) << 8) | + ((fbdv == 32 ? 0 : fbdv) << 24) | + (lfbdv == 64 ? 0 : lfbdv); + mtcpr(CPR0_PLLD, reg); + /* Acknowledge that a reset is required. */ + reset_needed = 1; + } + } + + if (reset_needed) { + /* + * Set reload inhibit so configuration will persist across + * processor resets + */ mfcpr(CPR0_ICFG, reg); reg &= ~CPR0_ICFG_RLI_MASK; reg |= 1 << 31; mtcpr(CPR0_ICFG, reg); - }
- /* Reset processor if configuration changed */ - if (reset_needed) { + /* Reset processor if configuration changed */ __asm__ __volatile__ ("sync; isync"); mtspr(SPRN_DBCR0, 0x20000000); } diff --git a/include/ppc440.h b/include/ppc440.h index e60fa13..5f87d2c 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -68,6 +68,12 @@ #define CPR0_SPCID 0x0120 #define CPR0_ICFG 0x0140
+/* 440EPX boot strap options */ +#define BOOT_STRAP_OPTION_A 0x00000000 +#define BOOT_STRAP_OPTION_B 0x00000001 +#define BOOT_STRAP_OPTION_D 0x00000003 +#define BOOT_STRAP_OPTION_E 0x00000004 + /* 440gx sdr register definations */ #define SDR0_SDSTP0 0x0020 /* */ #define SDR0_SDSTP1 0x0021 /* */
Hi Rup,
- This results in the PLLOUTB being greater than the CPU clock frequency
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Rupjyoti Sarmah
Stefan Roese
