[PATCH v1 00/10] net: mvpp2: Sync Marvell mvpp2 driver with Marvell version
This patchset adds the missing ethernet mvpp2 patches from the Marvell U-Boot SDK version to support and fix higher connection speeds. This is done in preparation for the integration of the Octeon TX2 CN913x support, which uses the updated version of this code.
Please note that I explicitly did not remove the incorrectly used PHY_INTERFACE_MODE_SGMII_2500 changes from these patches. This makes it easier to follow the Marvell downstream code. SGMII_2500 will be removed by the follow-up patch, that I already did send a bit earlier today. Sorry, I forgot to send this series earlier.
Thanks, Stefan
Ben Peled (3): net: mvpp2: AN Bypass in 1000 and 2500 basex mode net: mvpp2: remove unused define MVPP22_SMI_PHY_ADDR_REG net: mvpp2: fix missing switch case break
Marcin Wojtas (2): net: mvpp2: remove redundant SMI address configuration net: mvpp2: add explicit sgmii-2500 support
Stefan Chulski (5): phy: introduce 1000BaseX and 2500BaseX modes net: mvpp2: add CP115 port1 10G/5G SFI support net: mvpp2: add 1000BaseX and 2500BaseX ppv2 support net: mvpp2: Fix 2.5G GMII_SPEED configurations net: mvpp2: allow MDIO registration for fixed links
drivers/net/mvpp2.c | 257 +++++++++++++++++++++++++--------------- include/phy_interface.h | 4 + 2 files changed, 163 insertions(+), 98 deletions(-)
Signed-off-by: Stefan Chulski stefanc@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
include/phy_interface.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/phy_interface.h b/include/phy_interface.h index 841ade311efb..ebb18ecd40c0 100644 --- a/include/phy_interface.h +++ b/include/phy_interface.h @@ -25,6 +25,8 @@ typedef enum { PHY_INTERFACE_MODE_RGMII_RXID, PHY_INTERFACE_MODE_RGMII_TXID, PHY_INTERFACE_MODE_RTBI, + PHY_INTERFACE_MODE_1000BASEX, + PHY_INTERFACE_MODE_2500BASEX, PHY_INTERFACE_MODE_XGMII, PHY_INTERFACE_MODE_XAUI, PHY_INTERFACE_MODE_RXAUI, @@ -55,6 +57,8 @@ static const char * const phy_interface_strings[] = { [PHY_INTERFACE_MODE_RGMII_RXID] = "rgmii-rxid", [PHY_INTERFACE_MODE_RGMII_TXID] = "rgmii-txid", [PHY_INTERFACE_MODE_RTBI] = "rtbi", + [PHY_INTERFACE_MODE_1000BASEX] = "1000base-x", + [PHY_INTERFACE_MODE_2500BASEX] = "2500base-x", [PHY_INTERFACE_MODE_XGMII] = "xgmii", [PHY_INTERFACE_MODE_XAUI] = "xaui", [PHY_INTERFACE_MODE_RXAUI] = "rxaui",
1. Differ between Port1 RGMII and SFI modes in Netcomplex config. 2. Remove XPCS config from SFI mode. Port1 doesn't XPCS domain, XPCS config should be removed. Access to Port1 XPCS can cause stall. 3. Add Port1 MPCS configurations.
drivers/net/mvpp2.c | 75 ++++++++++----------------------------------- 1 file changed, 17 insertions(+), 58 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 1cf522b8fe57..015f5329de74 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -520,8 +520,9 @@ do { \ /* Net Complex */ enum mv_netc_topology { MV_NETC_GE_MAC2_SGMII = BIT(0), - MV_NETC_GE_MAC3_SGMII = BIT(1), - MV_NETC_GE_MAC3_RGMII = BIT(2), + MV_NETC_GE_MAC2_RGMII = BIT(1), + MV_NETC_GE_MAC3_SGMII = BIT(2), + MV_NETC_GE_MAC3_RGMII = BIT(3), };
enum mv_netc_phase { @@ -3208,56 +3209,31 @@ static int gop_gpcs_reset(struct mvpp2_port *port, int reset) return 0; }
-/* Set the internal mux's to the required PCS in the PI */ -static int gop_xpcs_mode(struct mvpp2_port *port, int num_of_lanes) -{ - u32 val; - int lane; - - switch (num_of_lanes) { - case 1: - lane = 0; - break; - case 2: - lane = 1; - break; - case 4: - lane = 2; - break; - default: - return -1; - } - - /* configure XG MAC mode */ - val = readl(port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); - val &= ~MVPP22_XPCS_PCSMODE_MASK; - val &= ~MVPP22_XPCS_LANEACTIVE_MASK; - val |= (2 * lane) << MVPP22_XPCS_LANEACTIVE_OFFS; - writel(val, port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); - - return 0; -} - static int gop_mpcs_mode(struct mvpp2_port *port) { u32 val;
/* configure PCS40G COMMON CONTROL */ - val = readl(port->priv->mpcs_base + PCS40G_COMMON_CONTROL); + val = readl(port->priv->mpcs_base + port->gop_id * MVPP22_PORT_OFFSET + + PCS40G_COMMON_CONTROL); val &= ~FORWARD_ERROR_CORRECTION_MASK; - writel(val, port->priv->mpcs_base + PCS40G_COMMON_CONTROL); + writel(val, port->priv->mpcs_base + port->gop_id * MVPP22_PORT_OFFSET + + PCS40G_COMMON_CONTROL);
/* configure PCS CLOCK RESET */ - val = readl(port->priv->mpcs_base + PCS_CLOCK_RESET); + val = readl(port->priv->mpcs_base + port->gop_id * MVPP22_PORT_OFFSET + + PCS_CLOCK_RESET); val &= ~CLK_DIVISION_RATIO_MASK; val |= 1 << CLK_DIVISION_RATIO_OFFS; - writel(val, port->priv->mpcs_base + PCS_CLOCK_RESET); + writel(val, port->priv->mpcs_base + port->gop_id * MVPP22_PORT_OFFSET + + PCS_CLOCK_RESET);
val &= ~CLK_DIV_PHASE_SET_MASK; val |= MAC_CLK_RESET_MASK; val |= RX_SD_CLK_RESET_MASK; val |= TX_SD_CLK_RESET_MASK; - writel(val, port->priv->mpcs_base + PCS_CLOCK_RESET); + writel(val, port->priv->mpcs_base + port->gop_id * MVPP22_PORT_OFFSET + + PCS_CLOCK_RESET);
return 0; } @@ -3300,22 +3276,6 @@ static int gop_xlg_mac_mode_cfg(struct mvpp2_port *port, int num_of_act_lanes) return 0; }
-/* Set PCS to reset or exit from reset */ -static int gop_xpcs_reset(struct mvpp2_port *port, int reset) -{ - u32 val; - - /* read - modify - write */ - val = readl(port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); - if (reset) - val &= ~MVPP22_XPCS_PCSRESET; - else - val |= MVPP22_XPCS_PCSRESET; - writel(val, port->priv->xpcs_base + MVPP22_XPCS_GLOBAL_CFG_0_REG); - - return 0; -} - /* Set the MAC to reset or exit from reset */ static int gop_xlg_mac_reset(struct mvpp2_port *port, int reset) { @@ -3387,14 +3347,10 @@ static int gop_port_init(struct mvpp2_port *port) num_of_act_lanes = 2; mac_num = 0; /* configure PCS */ - gop_xpcs_mode(port, num_of_act_lanes); gop_mpcs_mode(port); /* configure MAC */ gop_xlg_mac_mode_cfg(port, num_of_act_lanes);
- /* pcs unreset */ - gop_xpcs_reset(port, 0); - /* mac unreset */ gop_xlg_mac_reset(port, 0); break; @@ -3465,6 +3421,9 @@ static u32 mvpp2_netc_cfg_create(int gop_id, phy_interface_t phy_type) if (gop_id == 2) { if (phy_type == PHY_INTERFACE_MODE_SGMII) val |= MV_NETC_GE_MAC2_SGMII; + else if (phy_type == PHY_INTERFACE_MODE_RGMII || + phy_type == PHY_INTERFACE_MODE_RGMII_ID) + val |= MV_NETC_GE_MAC2_RGMII; }
if (gop_id == 3) { @@ -3656,7 +3615,7 @@ static int gop_netc_init(struct mvpp2 *priv, enum mv_netc_phase phase)
if (c & MV_NETC_GE_MAC2_SGMII) gop_netc_mac_to_sgmii(priv, 2, phase); - else + else if (c & MV_NETC_GE_MAC2_RGMII) gop_netc_mac_to_xgmii(priv, 2, phase);
if (c & MV_NETC_GE_MAC3_SGMII) {
On Tue, Apr 27, 2021 at 4:27 PM Stefan Roese sr@denx.de wrote:
- Differ between Port1 RGMII and SFI modes in Netcomplex config.
- Remove XPCS config from SFI mode. Port1 doesn't XPCS domain, XPCS config should be removed. Access to Port1 XPCS can cause stall.
- Add Port1 MPCS configurations.
u32 val;
int lane;
case 1:
lane = 0;
break;
case 2:
lane = 1;
break;
case 4:
lane = 2;
break;
default:
return -1;
PCS40G_COMMON_CONTROL); /* configure PCS CLOCK RESET */
PCS_CLOCK_RESET); val &= ~CLK_DIV_PHASE_SET_MASK; val |= MAC_CLK_RESET_MASK; val |= RX_SD_CLK_RESET_MASK; val |= TX_SD_CLK_RESET_MASK;
PCS_CLOCK_RESET); return 0;
u32 val;
if (reset)
else
/* pcs unreset */
val |= MV_NETC_GE_MAC2_RGMII; } if (gop_id == 3) {
else
else if (c & MV_NETC_GE_MAC2_RGMII) gop_netc_mac_to_xgmii(priv, 2, phase); if (c & MV_NETC_GE_MAC3_SGMII) {
-- 2.31.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
drivers/net/mvpp2.c | 117 ++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 112 insertions(+), 5 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 015f5329de74..847007d5b487 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -2880,6 +2880,10 @@ static void mvpp2_port_mii_set(struct mvpp2_port *port) case PHY_INTERFACE_MODE_SGMII: val |= MVPP2_GMAC_INBAND_AN_MASK; break; + case PHY_INTERFACE_MODE_1000BASEX: + case PHY_INTERFACE_MODE_2500BASEX: + val &= ~MVPP2_GMAC_INBAND_AN_MASK; + break; case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: val |= MVPP2_GMAC_PORT_RGMII_MASK; @@ -2940,7 +2944,9 @@ static void mvpp2_port_loopback_set(struct mvpp2_port *port) else val &= ~MVPP2_GMAC_GMII_LB_EN_MASK;
- if (port->phy_interface == PHY_INTERFACE_MODE_SGMII) + if (port->phy_interface == PHY_INTERFACE_MODE_SGMII || + port->phy_interface == PHY_INTERFACE_MODE_1000BASEX || + port->phy_interface == PHY_INTERFACE_MODE_2500BASEX) val |= MVPP2_GMAC_PCS_LB_EN_MASK; else val &= ~MVPP2_GMAC_PCS_LB_EN_MASK; @@ -3051,10 +3057,10 @@ static void gop_gmac_sgmii2_5_cfg(struct mvpp2_port *port)
val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); /* - * Configure GIG MAC to 1000Base-X mode connected to a fiber + * Configure GIG MAC to SGMII mode connected to a fiber * transceiver */ - val |= MVPP2_GMAC_PORT_TYPE_MASK; + val &= ~MVPP2_GMAC_PORT_TYPE_MASK; writel(val, port->base + MVPP2_GMAC_CTRL_0_REG);
/* configure AN 0x9268 */ @@ -3106,6 +3112,89 @@ static void gop_gmac_sgmii_cfg(struct mvpp2_port *port) writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); }
+static void gop_gmac_2500basex_cfg(struct mvpp2_port *port) +{ + u32 val, thresh; + + /* + * Configure minimal level of the Tx FIFO before the lower part + * starts to read a packet + */ + thresh = MVPP2_SGMII2_5_TX_FIFO_MIN_TH; + val = readl(port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + val &= ~MVPP2_GMAC_TX_FIFO_MIN_TH_ALL_MASK; + val |= MVPP2_GMAC_TX_FIFO_MIN_TH_MASK(thresh); + writel(val, port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + + /* Disable bypass of sync module */ + val = readl(port->base + MVPP2_GMAC_CTRL_4_REG); + val |= MVPP2_GMAC_CTRL4_SYNC_BYPASS_MASK; + /* configure DP clock select according to mode */ + val |= MVPP2_GMAC_CTRL4_DP_CLK_SEL_MASK; + /* configure QSGMII bypass according to mode */ + val |= MVPP2_GMAC_CTRL4_QSGMII_BYPASS_ACTIVE_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_4_REG); + + val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); + /* + * Configure GIG MAC to 2500Base-X mode connected to a fiber + * transceiver + */ + val |= MVPP2_GMAC_PORT_TYPE_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); + + /* In 2500BaseX mode, we can't negotiate speed + * and we do not want InBand autoneg + * bypass enabled (link interrupt storm risk + * otherwise). + */ + val = MVPP2_GMAC_EN_PCS_AN | + MVPP2_GMAC_CONFIG_GMII_SPEED | + MVPP2_GMAC_CONFIG_FULL_DUPLEX | + MVPP2_GMAC_CHOOSE_SAMPLE_TX_CONFIG; + writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); +} + +static void gop_gmac_1000basex_cfg(struct mvpp2_port *port) +{ + u32 val, thresh; + + /* + * Configure minimal level of the Tx FIFO before the lower part + * starts to read a packet + */ + thresh = MVPP2_SGMII_TX_FIFO_MIN_TH; + val = readl(port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + val &= ~MVPP2_GMAC_TX_FIFO_MIN_TH_ALL_MASK; + val |= MVPP2_GMAC_TX_FIFO_MIN_TH_MASK(thresh); + writel(val, port->base + MVPP2_GMAC_PORT_FIFO_CFG_1_REG); + + /* Disable bypass of sync module */ + val = readl(port->base + MVPP2_GMAC_CTRL_4_REG); + val |= MVPP2_GMAC_CTRL4_SYNC_BYPASS_MASK; + /* configure DP clock select according to mode */ + val &= ~MVPP2_GMAC_CTRL4_DP_CLK_SEL_MASK; + /* configure QSGMII bypass according to mode */ + val |= MVPP2_GMAC_CTRL4_QSGMII_BYPASS_ACTIVE_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_4_REG); + + val = readl(port->base + MVPP2_GMAC_CTRL_0_REG); + /* configure GIG MAC to 1000BASEX mode */ + val |= MVPP2_GMAC_PORT_TYPE_MASK; + writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); + + /* In 1000BaseX mode, we can't negotiate speed (it's + * only 1000), and we do not want InBand autoneg + * bypass enabled (link interrupt storm risk + * otherwise). + */ + val = MVPP2_GMAC_EN_PCS_AN | + MVPP2_GMAC_CONFIG_GMII_SPEED | + MVPP2_GMAC_CONFIG_FULL_DUPLEX | + MVPP2_GMAC_CHOOSE_SAMPLE_TX_CONFIG; + writel(val, port->base + MVPP2_GMAC_AUTONEG_CONFIG); +} + static void gop_gmac_rgmii_cfg(struct mvpp2_port *port) { u32 val, thresh; @@ -3157,6 +3246,12 @@ static int gop_gmac_mode_cfg(struct mvpp2_port *port) gop_gmac_sgmii_cfg(port); break;
+ case PHY_INTERFACE_MODE_1000BASEX: + gop_gmac_1000basex_cfg(port); + + case PHY_INTERFACE_MODE_2500BASEX: + gop_gmac_2500basex_cfg(port); + case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: gop_gmac_rgmii_cfg(port); @@ -3329,6 +3424,8 @@ static int gop_port_init(struct mvpp2_port *port) break;
case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_1000BASEX: + case PHY_INTERFACE_MODE_2500BASEX: /* configure PCS */ gop_gpcs_mode_cfg(port, 1);
@@ -3386,6 +3483,8 @@ static void gop_port_enable(struct mvpp2_port *port, int enable) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_1000BASEX: + case PHY_INTERFACE_MODE_2500BASEX: if (enable) mvpp2_port_enable(port); else @@ -3419,7 +3518,9 @@ static u32 mvpp2_netc_cfg_create(int gop_id, phy_interface_t phy_type) u32 val = 0;
if (gop_id == 2) { - if (phy_type == PHY_INTERFACE_MODE_SGMII) + if (phy_type == PHY_INTERFACE_MODE_SGMII || + phy_type == PHY_INTERFACE_MODE_1000BASEX || + phy_type == PHY_INTERFACE_MODE_2500BASEX) val |= MV_NETC_GE_MAC2_SGMII; else if (phy_type == PHY_INTERFACE_MODE_RGMII || phy_type == PHY_INTERFACE_MODE_RGMII_ID) @@ -3427,7 +3528,9 @@ static u32 mvpp2_netc_cfg_create(int gop_id, phy_interface_t phy_type) }
if (gop_id == 3) { - if (phy_type == PHY_INTERFACE_MODE_SGMII) + if (phy_type == PHY_INTERFACE_MODE_SGMII || + phy_type == PHY_INTERFACE_MODE_1000BASEX || + phy_type == PHY_INTERFACE_MODE_2500BASEX) val |= MV_NETC_GE_MAC3_SGMII; else if (phy_type == PHY_INTERFACE_MODE_RGMII || phy_type == PHY_INTERFACE_MODE_RGMII_ID) @@ -4423,6 +4526,8 @@ static void mvpp2_start_dev(struct mvpp2_port *port) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_1000BASEX: + case PHY_INTERFACE_MODE_2500BASEX: mvpp2_gmac_max_rx_size_set(port); default: break; @@ -5159,6 +5264,8 @@ static int mvpp2_start(struct udevice *dev) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_1000BASEX: + case PHY_INTERFACE_MODE_2500BASEX: mvpp2_port_power_up(port); default: break;
val &= ~MVPP2_GMAC_PORT_TYPE_MASK; writel(val, port->base + MVPP2_GMAC_CTRL_0_REG); /* configure AN 0x9268 */
u32 val, thresh;
* transceiver
* otherwise).
u32 val, thresh;
* otherwise).
if (gop_id == 2) {
if (gop_id == 3) {
-- 2.31.1
Because the mvpp2 driver now relies on the PHYLIB and the external MDIO driver, configuring low level SMI bus settings is redundant.
Signed-off-by: Marcin Wojtas mw@semihalf.com Tested-by: sa_ip-sw-jenkins sa_ip-sw-jenkins@marvell.com Reviewed-by: Kostya Porotchkin kostap@marvell.com Reviewed-by: Stefan Chulski stefanc@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
drivers/net/mvpp2.c | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 847007d5b487..2043bdf10aa4 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -5292,14 +5292,6 @@ static int mvpp2_write_hwaddr(struct udevice *dev) return mvpp2_prs_update_mac_da(port, port->dev_addr); }
-static int mvpp22_smi_phy_addr_cfg(struct mvpp2_port *port) -{ - writel(port->phyaddr, port->priv->iface_base + - MVPP22_SMI_PHY_ADDR_REG(port->gop_id)); - - return 0; -} - static int mvpp2_base_probe(struct udevice *dev) { struct mvpp2 *priv = dev_get_priv(dev); @@ -5422,10 +5414,6 @@ static int mvpp2_probe(struct udevice *dev) port->base = priv->iface_base + MVPP22_PORT_BASE + port->gop_id * MVPP22_PORT_OFFSET;
- /* Set phy address of the port */ - if (port->phyaddr < PHY_MAX_ADDR) - mvpp22_smi_phy_addr_cfg(port); - /* GoP Init */ gop_port_init(port); }
-- 2.31.1
GMII_SPEED should be enabled for 2.5G speed
Signed-off-by: Stefan Chulski stefanc@marvell.com Reviewed-by: Yan Markman ymarkman@marvell.com Reviewed-by: Kostya Porotchkin kostap@marvell.com Tested-by: sa_ip-sw-jenkins sa_ip-sw-jenkins@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
drivers/net/mvpp2.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 2043bdf10aa4..ec7cb89a94c8 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -4445,7 +4445,8 @@ static void mvpp2_link_event(struct mvpp2_port *port) if (phydev->duplex) val |= MVPP2_GMAC_CONFIG_FULL_DUPLEX;
- if (phydev->speed == SPEED_1000) + if (phydev->speed == SPEED_1000 || + phydev->speed == 2500) val |= MVPP2_GMAC_CONFIG_GMII_SPEED; else if (phydev->speed == SPEED_100) val |= MVPP2_GMAC_CONFIG_MII_SPEED;
Hi, Stefan,
-----Original Message----- From: Stefan Roese sr@denx.de Sent: Tuesday, April 27, 2021 16:27 To: u-boot@lists.denx.de Cc: Stefan Chulski stefanc@marvell.com; Marcin Wojtas mw@semihalf.com; Nadav Haklai nadavh@marvell.com; Marek Behun marek.behun@nic.cz; Joe Hershberger joe.hershberger@ni.com; Kostya Porotchkin kostap@marvell.com; Yan Markman ymarkman@marvell.com; sa_ip-sw-jenkins <sa_ip-sw- jenkins@marvell.com> Subject: [EXT] [PATCH v1 05/10] net: mvpp2: Fix 2.5G GMII_SPEED configurations
External Email
[KP] Shouldn't it be "SPEED_2500"?
-- 2.31.1
Hi Kosta,
On 27.04.21 15:48, Kostya Porotchkin wrote:
Hi, Stefan,
External Email
I agree in general. Please note that this is a verbatim copy from your SDK version. And checking, this is not a real issue as here the macros are defines as follows:
include/linux/ethtool.h
/* The forced speed, 10Mb, 100Mb, gigabit, 2.5Gb, 5Gb, 10GbE. */ #define SPEED_10 10 #define SPEED_100 100 #define SPEED_1000 1000 #define SPEED_2500 2500 #define SPEED_5000 5000 #define SPEED_10000 10000
We should perhaps change this some time though to always use the macro instead of the number.
Thanks, Stefan
Signed-off-by: Ben Peled bpeled@marvell.com Reviewed-by: Stefan Chulski stefanc@marvell.com Reviewed-by: Kostya Porotchkin kostap@marvell.com Tested-by: sa_ip-sw-jenkins sa_ip-sw-jenkins@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
drivers/net/mvpp2.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index ec7cb89a94c8..879289452b15 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -3148,7 +3148,8 @@ static void gop_gmac_2500basex_cfg(struct mvpp2_port *port) * bypass enabled (link interrupt storm risk * otherwise). */ - val = MVPP2_GMAC_EN_PCS_AN | + val = MVPP2_GMAC_AN_BYPASS_EN | + MVPP2_GMAC_EN_PCS_AN | MVPP2_GMAC_CONFIG_GMII_SPEED | MVPP2_GMAC_CONFIG_FULL_DUPLEX | MVPP2_GMAC_CHOOSE_SAMPLE_TX_CONFIG; @@ -3188,7 +3189,8 @@ static void gop_gmac_1000basex_cfg(struct mvpp2_port *port) * bypass enabled (link interrupt storm risk * otherwise). */ - val = MVPP2_GMAC_EN_PCS_AN | + val = MVPP2_GMAC_AN_BYPASS_EN | + MVPP2_GMAC_EN_PCS_AN | MVPP2_GMAC_CONFIG_GMII_SPEED | MVPP2_GMAC_CONFIG_FULL_DUPLEX | MVPP2_GMAC_CHOOSE_SAMPLE_TX_CONFIG;
drivers/net/mvpp2.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 879289452b15..61a0ea0894a7 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -490,9 +490,6 @@ do { \ #define MVPP22_SMI_MISC_CFG_REG (MVPP22_SMI + 0x04) #define MVPP22_SMI_POLLING_EN BIT(10)
-#define MVPP22_SMI_PHY_ADDR_REG(port) (MVPP22_SMI + 0x04 + \ - (0x4 * (port))) - #define MVPP2_CAUSE_TXQ_SENT_DESC_ALL_MASK 0xff
/* Descriptor ring Macros */
drivers/net/mvpp2.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 61a0ea0894a7..3d920e85ffef 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -3247,9 +3247,11 @@ static int gop_gmac_mode_cfg(struct mvpp2_port *port)
case PHY_INTERFACE_MODE_1000BASEX: gop_gmac_1000basex_cfg(port); + break;
case PHY_INTERFACE_MODE_2500BASEX: gop_gmac_2500basex_cfg(port); + break;
Please remove this, Jenkins is not a person.
break; case PHY_INTERFACE_MODE_2500BASEX: gop_gmac_2500basex_cfg(port);
-- 2.31.1
I've left these lines in because most of these patches are plain cherry-picked from the Marvell SDK.
Should I resubmit this patch only or the complete patchset? Or could you perhaps remove this line while collecting the patches for a pull request?
Thanks, Stefan
-- 2.31.1
Viele Grüße, Stefan
Please submit the patchset again.
Hi Ramon,
Done. I just now noticed, that I forgot to add your RB tags. Should I send v3 with the RB tags?
Thanks, Stefan
On Mon, May 3, 2021 at 9:13 AM Stefan Roese sr@denx.de wrote:
Hi Ramon,
No, that's fine.
Currently, there are 2 valid cases for interface, PHY and mdio relation: - If an interface has PHY handler, it'll call mdio_mii_bus_get_from_phy(), which will register MDIO bus. - If we want to use fixed-link for an interface, PHY handle is not defined in the DTS, and no MDIO is registered.
There is a third case, for some boards (with switch), the MDIO is used for switch configuration, but the interface itself uses fixed link. This patch allows this option by checking if fixed-link subnode is defined, in this case, MDIO bus is registers, but the PHY address is set to PHY_MAX_ADDR for this interface, so this interface will not try to access the PHY later on.
drivers/net/mvpp2.c | 17 +++++++++++++---- 1 file changed, 13 insertions(+), 4 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 3d920e85ffef..c5bfe41281d6 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -4787,16 +4787,25 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) u32 id; u32 phyaddr = 0; int phy_mode = -1; + int fixed_link = 0; int ret;
phy_node = fdtdec_lookup_phandle(gd->fdt_blob, port_node, "phy"); + fixed_link = fdt_subnode_offset(gd->fdt_blob, port_node, "fixed-link");
if (phy_node > 0) { int parent; - phyaddr = fdtdec_get_int(gd->fdt_blob, phy_node, "reg", 0); - if (phyaddr < 0) { - dev_err(dev, "could not find phy address\n"); - return -1; + + if (fixed_link != -FDT_ERR_NOTFOUND) { + /* phy_addr is set to invalid value for fixed links */ + phyaddr = PHY_MAX_ADDR; + } else { + phyaddr = fdtdec_get_int(gd->fdt_blob, phy_node, + "reg", 0); + if (phyaddr < 0) { + dev_err(dev, "could not find phy address\n"); + return -1; + } } parent = fdt_parent_offset(gd->fdt_blob, phy_node); ret = uclass_get_device_by_of_offset(UCLASS_MDIO, parent,
int fixed_link = 0; int ret; phy_node = fdtdec_lookup_phandle(gd->fdt_blob, port_node, "phy");
fixed_link = fdt_subnode_offset(gd->fdt_blob, port_node, "fixed-link"); if (phy_node > 0) { int parent;
if (phyaddr < 0) {
return -1;
} else {
"reg", 0);
if (phyaddr < 0) {
return -1;
-- 2.31.1
Until now the mvpp2 driver used an extra 'phy-speed' DT property in order to differentiate between the SGMII and SGMII @2.5GHz. As there is a dedicated PHY_INTERFACE_MODE_SGMII_2500 flag to mark the latter start using it and drop the custom flag.
Signed-off-by: Marcin Wojtas mw@semihalf.com Reviewed-by: Stefan Chulski stefanc@marvell.com Reviewed-by: Nadav Haklai nadavh@marvell.com Tested-by: Nadav Haklai nadavh@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
drivers/net/mvpp2.c | 28 ++++++++++++---------------- 1 file changed, 12 insertions(+), 16 deletions(-)
diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index c5bfe41281d6..4c0a7b0a9f5c 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -976,8 +976,6 @@ struct mvpp2_port { unsigned int duplex; unsigned int speed;
- unsigned int phy_speed; /* SGMII 1Gbps vs 2.5Gbps */ - struct mvpp2_bm_pool *pool_long; struct mvpp2_bm_pool *pool_short;
@@ -2875,6 +2873,7 @@ static void mvpp2_port_mii_set(struct mvpp2_port *port)
switch (port->phy_interface) { case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: val |= MVPP2_GMAC_INBAND_AN_MASK; break; case PHY_INTERFACE_MODE_1000BASEX: @@ -2942,6 +2941,7 @@ static void mvpp2_port_loopback_set(struct mvpp2_port *port) val &= ~MVPP2_GMAC_GMII_LB_EN_MASK;
if (port->phy_interface == PHY_INTERFACE_MODE_SGMII || + port->phy_interface == PHY_INTERFACE_MODE_SGMII_2500 || port->phy_interface == PHY_INTERFACE_MODE_1000BASEX || port->phy_interface == PHY_INTERFACE_MODE_2500BASEX) val |= MVPP2_GMAC_PCS_LB_EN_MASK; @@ -3239,12 +3239,11 @@ static int gop_gmac_mode_cfg(struct mvpp2_port *port) /* Set TX FIFO thresholds */ switch (port->phy_interface) { case PHY_INTERFACE_MODE_SGMII: - if (port->phy_speed == 2500) - gop_gmac_sgmii2_5_cfg(port); - else - gop_gmac_sgmii_cfg(port); + gop_gmac_sgmii_cfg(port); + break; + case PHY_INTERFACE_MODE_SGMII_2500: + gop_gmac_sgmii2_5_cfg(port); break; - case PHY_INTERFACE_MODE_1000BASEX: gop_gmac_1000basex_cfg(port); break; @@ -3425,6 +3424,7 @@ static int gop_port_init(struct mvpp2_port *port) break;
case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: case PHY_INTERFACE_MODE_1000BASEX: case PHY_INTERFACE_MODE_2500BASEX: /* configure PCS */ @@ -3484,6 +3484,7 @@ static void gop_port_enable(struct mvpp2_port *port, int enable) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: case PHY_INTERFACE_MODE_1000BASEX: case PHY_INTERFACE_MODE_2500BASEX: if (enable) @@ -3520,6 +3521,7 @@ static u32 mvpp2_netc_cfg_create(int gop_id, phy_interface_t phy_type)
if (gop_id == 2) { if (phy_type == PHY_INTERFACE_MODE_SGMII || + phy_type == PHY_INTERFACE_MODE_SGMII_2500 || phy_type == PHY_INTERFACE_MODE_1000BASEX || phy_type == PHY_INTERFACE_MODE_2500BASEX) val |= MV_NETC_GE_MAC2_SGMII; @@ -3530,6 +3532,7 @@ static u32 mvpp2_netc_cfg_create(int gop_id, phy_interface_t phy_type)
if (gop_id == 3) { if (phy_type == PHY_INTERFACE_MODE_SGMII || + phy_type == PHY_INTERFACE_MODE_SGMII_2500 || phy_type == PHY_INTERFACE_MODE_1000BASEX || phy_type == PHY_INTERFACE_MODE_2500BASEX) val |= MV_NETC_GE_MAC3_SGMII; @@ -4528,6 +4531,7 @@ static void mvpp2_start_dev(struct mvpp2_port *port) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: case PHY_INTERFACE_MODE_1000BASEX: case PHY_INTERFACE_MODE_2500BASEX: mvpp2_gmac_max_rx_size_set(port); @@ -4838,15 +4842,6 @@ static int phy_info_parse(struct udevice *dev, struct mvpp2_port *port) &port->phy_tx_disable_gpio, GPIOD_IS_OUT); #endif
- /* - * ToDo: - * Not sure if this DT property "phy-speed" will get accepted, so - * this might change later - */ - /* Get phy-speed for SGMII 2.5Gbps vs 1Gbps setup */ - port->phy_speed = fdtdec_get_int(gd->fdt_blob, port_node, - "phy-speed", 1000); - port->id = id; if (port->priv->hw_version == MVPP21) port->first_rxq = port->id * rxq_number; @@ -5275,6 +5270,7 @@ static int mvpp2_start(struct udevice *dev) case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: case PHY_INTERFACE_MODE_1000BASEX: case PHY_INTERFACE_MODE_2500BASEX: mvpp2_port_power_up(port);
else
break;
* ToDo:
"phy-speed", 1000);
-- 2.31.1
Kostya Porotchkin
Ramon Fried
Stefan Roese
