[U-Boot] please pull u-boot-samsung master
Dear Tom,
The following changes since commit 2086e388d56cbb0e3737a6276f04f00f74bf6723:
Merge branch 'master' of git://git.denx.de/u-boot-mpc85xx (2014-11-14 16:39:32 -0500)
http://git.denx.de/u-boot-samsung
for you to fetch changes up to 7741c8b8c9215c6def36f24ac0b2d71543dd47ab:
ORIGEN: Enhance origen config to be more flexible on boot. (2014-11-25 10:30:25 +0900)
---------------------------------------------------------------- Akshay Saraswat (5): Exynos5800: Introduce new proid for Exynos5800 Exynos5800: Add DTS for new board Peach-Pi Config: Exynos5800: Enable build for Peach-Pi Config: Exynos5420: Refactor SDRAM Bank and Size Exynos5: ddr3: Choose between single or double channel config
Alim Akhtar (1): DMC: Exynos5: Enable update mode for DREX controller
David Müller (ELSOFT AG) (1): SMDK2410: convert to generic board
Guillaume GARDET (1): ORIGEN: Enhance origen config to be more flexible on boot.
Ian Campbell (3): exynos: Enable config_distro_defaults.h exynos5: Use config_distro_bootcmd.h exynos: Increase command line buffer size (CONFIG_SYS_CBSIZE)
Sjoerd Simons (1): exynos: dts: Correct USB vbus-gpio numbering for Snow
Suriyan Ramasami (6): arm: odroid: pmic77686: allow buck voltage settings arm: odroid: enable/disable usb host phy for exynos4412 arm: odroid: usb: add support for usb host including ethernet odroid: Update README with USB host usage odroid: usbhost - Add missing gpio_request call odroid: Turn blue LED on
Vadim Bendebury (1): Peach-Pi: Use the enhanced usb_copy() prototype
arch/arm/cpu/armv7/exynos/Kconfig | 7 +- arch/arm/cpu/armv7/exynos/clock.c | 19 +-- arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 2 +- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 29 ++++ arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/cpu/armv7/exynos/power.c | 27 ++++ arch/arm/cpu/armv7/exynos/spl_boot.c | 10 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4412-odroid.dts | 11 ++ arch/arm/dts/exynos5250-snow.dts | 4 +- arch/arm/dts/exynos5800-peach-pi.dts | 157 ++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 10 +- arch/arm/include/asm/arch-exynos/dmc.h | 1 + arch/arm/include/asm/arch-exynos/ehci.h | 13 ++ arch/arm/include/asm/arch-exynos/gpio.h | 4 +- arch/arm/include/asm/arch-exynos/power.h | 7 + board/samsung/odroid/odroid.c | 46 +++++++ board/samsung/smdk5420/Kconfig | 16 +++ board/samsung/smdk5420/MAINTAINERS | 2 + configs/peach-pi_defconfig | 5 + doc/README.odroid | 169 ++++++++++++++++++++++++ drivers/power/pmic/pmic_max77686.c | 52 +++++++- drivers/usb/host/ehci-exynos.c | 55 ++++++-- include/configs/arndale.h | 5 +- include/configs/exynos-common.h | 17 +-- include/configs/exynos5-common.h | 56 +++++--- include/configs/exynos5-dt-common.h | 17 +-- include/configs/exynos5250-common.h | 2 - include/configs/exynos5420-common.h | 11 +- include/configs/odroid.h | 13 ++ include/configs/origen.h | 35 ++++- include/configs/peach-pi.h | 50 +++++++ include/configs/peach-pit.h | 8 +- include/configs/smdk2410.h | 2 + include/configs/smdk5420.h | 4 + include/power/max77686_pmic.h | 3 + 36 files changed, 787 insertions(+), 87 deletions(-) create mode 100644 arch/arm/dts/exynos5800-peach-pi.dts create mode 100644 configs/peach-pi_defconfig create mode 100644 include/configs/peach-pi.h
On Tue, Nov 25, 2014 at 09:28:56PM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
