Re: [U-Boot] Building under Cygwin - "-ansi" flag?
On Sun, May 11, 2014 at 1:27 PM, Vasili Galka vvv444@gmail.com wrote:
On Fri, May 9, 2014 at 6:08 PM, Tom Rini trini@ti.com wrote:
On Thu, May 08, 2014 at 02:49:35PM +0300, Vasili Galka wrote:
I'm building u-boot (am335x_evm config) using arm-none-eabi toolchain under Cygwin. When trying to build unmodified v2014.04 tag I get some errors. However, if I remove the "-ansi" flag from the Makefile, everything builds fine:
-ifeq ($(HOSTOS),cygwin) -HOSTCFLAGS += -ansi -endif
I tried tracking down where those lines came from and why building under Cygwin requires separate treatment. I found our this originates from the following commit (dated Jan 2008):
SHA-1: 883e3925d99a8dd69c5b0201cba5b1887f88f95c
- Fix build problems under Cygwin
This patch allows u-boot to build without error in a cygwin environment. Cygwin does not define __u64 in it's include/asm/types.h file. The -idirafter flag in the u-boot build causes the inclusion of the cygwin types.h file as opposed to u-bot/include/asm/types.h file which does define __u64. Subsequently, sha1.c compile fails due to unknown symbol.
Signed-off-by: Brian Miller raptorbrino@netscape.net
This comment does not really explain why "-ansi" flag is required.
-ansi changes include order perhaps?
Personally, I don't see any reason for it.
Maybe it should be removed at all?
Yes, but can you please test a few more builds? If you're able to use MAKEALL, please run MAKEALL -a arm
-- Tom
Hi Tom,
There are indeed some errors, I look into it later and keep you updated.
Best, Vasili
Dear Tom,
I've finally found time to look deeper into this problem. Let me outline the situation: 1. The problems with Cygwin build arise in code built for the "host" architecture i.e. stuff in "tools" sub-directory. 2. Along the years, there were several commits targeting the problems. All were related to include search paths/their order: a. e1a3f6b (July 2004): U-Boot include paths for "tools" build were changed to "-idirafter", i.e. host headers were given higher priority than headers in U-Boot tree. b. 883e392 (Jan 2008): The above patch caused "asm/types.h" shipped with Cygwin to be included. Turned out Cygwin does not define __u64, so this patch tried to workaround it by adding the "-ansi" flag. This flag dropped some include search paths effectively returning the use of "asm/types.h" from U-Boot tree. c. 669dfc2 (March 2013): Yet another header was included from the host paths and caused problems: "libfdt_env.h". This time it was worked around by adding the following flag to override it: "-include $(SRCTREE)/include/libfdt_env.h" 3. Currently all builds fine on Linux. However, on Cygwin some configs fail to build since not all the code complies with the ANSI standard. On the other hand, removing the "-ansi" flag causes build errors in other configs due to reasons explained above.
Now my thoughts on the situation: 1. Requesting compliance of U-Boot code with the ANSI standard is an overshoot. It was used as a workaround to a problem and a different solution shall be found. There is already a code that does not compile with it. Speaking of it, is there a policy about U-Boot code compliance to some standard? C99? GNU99? If not, I think it's important to define one and stick to it. This will eliminate uncertainty and simplify things in the future. 2. I see a reoccurring pattern of some headers being used from the host, causing mismatches and arising build errors. Then some way is sought to include headers from U-Boot tree prior to them which solves the problem. This happens for both Linux and Cygwin. This pattern is a result of the original decision from 2004 to prioritize the host include paths over the paths from U-Boot tree. I see this happening again and again with different headers in the future. So here comes the question, is it really the right thing prioritize the include paths this way? Why do host paths MUST come first? I'll try reverting this locally and looking what breaks and what alternative solutions exist.
P.S. I'm building all with arm-none-eabi toolchain. I set up powerpc-none-eabi toolchain under Linux and got some build errors. I'll open a separate thread about it.
Best regards, Vasili
Dear Vasili,
On ma, 2014-05-19 at 12:45 +0300, Vasili Galka wrote: [...]
- I see a reoccurring pattern of some headers being used from the host, causing mismatches and arising build errors. Then some way is sought to include headers from U-Boot tree prior to them which solves the problem. This happens for both Linux and Cygwin.
you can add FreeBSD to the list as well, see [1]
any reference?
I have no idea why it is the way it is, but keep in mind that e.g. stdio headers in u-boot is quite something different then stdio for the target userland.
Regards, Jeroen
[1] http://lists.denx.de/pipermail/u-boot/2014-May/179301.html
Hi Jeroen,
On Tue, May 20, 2014 at 9:06 PM, Jeroen Hofstee dasuboot@myspectrum.nl wrote:
Dear Vasili,
Thanks! This supports my point that we have a reoccurring problem here that requires a more general solution.
any reference?
This decision is a part of the above mentioned commit: e1a3f6b (July 2004) I don't know how much the original committer was aware of its long term implications.
Sure. I'll keep it in mind while I'm designing a solution here. I'm afraid there is no easy way to fix it though.
Regards, Jeroen
Best, Vasili
Hello Vasili,
any reference?
If the only valid reason is "Fix host tools building in Cygwin environment" as mentioned in the original commit, then I am all in favor of dropping it and finding a decent solution for cygwin.
This is easier than it sounds. U-boot is build with -nostdinc for the binary itself. And it tries to get the compiler related includes back with "isystem $(shell $(CC) -print-file-name=include". (and the printf declaration and friends are actually in common.h for the loader, which makes it even harder to do it wrong by accident).
Can you check what "arm-none-eabi-gcc -print-file-name=include" returns on cygwin?
mmm, this one might be also be a challenge for cygwin: "dirname `arm-none-eabi-gcc -print-libgcc-file-name`", but you will likely get linker errors if that contains spaces / backslashes or simply fails.
But perhaps even easier, can you post the problems you encounter if you remove the idirafter. Likely easier then guessing what can go wrong in a cygwin build.
Regards, Jeroen
Hi Jeroen,
On Thu, May 22, 2014 at 9:27 PM, Jeroen Hofstee dasuboot@myspectrum.nl wrote:
Hello Vasili,
any reference?
Regards, Jeroen
Let's suppose there is an application in tools directory that requires both "libfdt_env.h" (from uboot tree) and "errno.h" (from host environment). However, as both headers exist at both places, in the uboot tree and on the host environment, there is no way to solve this just by altering the include paths order. For any reshuffling both headers will be taken either from uboot or from host - which is undesired.
I can only think of one bulletproof solution that would fix the above problem. Unfortunately it's conceptual and requires much work: * Currently, almost all include derectives in in uboot code use <> style. I propose to modify this concept. * For each #include directive the developer shall decide from where the header file is obtained - U-Boot source tree or the host environment. * Depending on that, "" shall be used only for headers from U-Boot tree, <> shall be used only for all other (host provided in tools folder) * The -iquote compiler flag can be used for adding "" search paths. The -I flag for adding <> paths.
Of course that's just a draft of the idea. What do you think?
Best, Vasili
Hi.
True. What we should do is not to tweak the inclusion order.
I guess we should follow what happended in Linux Kernel world:
They split out the user-space API content in separated headers and put them into new include/uapi/ and arch/$(ARCH)/include/uapi/ directories.
So, the right direction we should go is:
- Define the exact tools-API which should be exported to host program space. (For ex. image structure)
- Put the tool-API headers into a new directory. (I have no idea about a good dir name. include/host-api/ ? ) This directory is added to include-path for both U-Boot and host programs.
include include U-Boot ----------> include/host-api/ <-------- Host programs
U-boot includes: include/host-api/ + include/ + arch/$ARCH/include/
Host programs include: include/host-api/ + headers provided by environments
Comments are welcome !
Best Regards Masahiro Yamada
Hi Masahiro,
include include
What you propose sounds good. But are you sure that no tools require a really deep details of U-Boot internals? In such case separating the details into an interface won't be possible. If (hopefully) that's not the case, interfaces seem to be the right direction. Although implementing them requires great work. In any case, as a new comer, I don't think I know U-Boot enough for such design decision. I would be glad to hear the opinion of other major developers.
As about the solution I initially thought of, here is a more detailed design: https://docs.google.com/document/d/1D86EedRrViJHsTZrf9bEQB-DYsEweHDKaJyZYI2Y... It does not contradict what you propose and these two can be used together. My proposal does not target only the specific compilation issues descussed here but the general ease of code understanding and navigation. I think it is much easier to implement and can provide a good short term solution. Since re-factoring host-api requires much effort and deep understanding of existing code. The only drawback of my proposal I see is the large patch footprint. But maybe you see other weaknesses. I'll be glad for your opinion.
Hi.
- The problems with Cygwin build arise in code built for the "host" architecture i.e. stuff in "tools" sub-directory.
- Along the years, there were several commits targeting the problems. All were related to include search paths/their order: a. e1a3f6b (July 2004): U-Boot include paths for "tools" build were changed to "-idirafter", i.e. host headers were given higher priority than headers in U-Boot tree. b. 883e392 (Jan 2008): The above patch caused "asm/types.h" shipped with Cygwin to be included. Turned out Cygwin does not define __u64, so this patch tried to workaround it by adding the "-ansi" flag. This flag dropped some include search paths effectively returning the use of "asm/types.h" from U-Boot tree.
So, with Sandbox configuration, host-tools include arch/sandbox/include/asm/types.h With beagle bone configuration, they include arch/arm/include/asm/type.h
How amazing!
Seems people are only adding new features with ridiculous workarounds, without refactrong the code, without thinking what the proper implementing is. Sadly.
Jeroen Hofstee
Masahiro Yamada
Vasili Galka
