[U-Boot] [PATCH v4 0/4] arm: socfpga: Convert drivers from struct to defines
This is 4th version of patchset to convert reset, system and clock manager drivers to use #define instead of struct. This patchset get managers' base address from DT node instead of using #define.
Patch 1 unchanged, patch 2,3,4 update commit message.
Tested on Cyclone 5, Arria 10 and Stratix 10 devices.
Changes in v4: - Patch 2,3,4: Update commit message. History: v1: https://patchwork.ozlabs.org/cover/1149731/ v2: https://patchwork.ozlabs.org/cover/1160079/ v3: https://patchwork.ozlabs.org/cover/1174327/
Ley Foon Tan (4): arm: dts: socfpga: Add u-boot,dm-pre-reloc for sysmgr and clkmgr nodes arm: socfpga: Convert reset manager from struct to defines arm: socfpga: Convert system manager from struct to defines arm: socfpga: Convert clock manager from struct to defines
arch/arm/dts/socfpga-common-u-boot.dtsi | 8 + arch/arm/dts/socfpga.dtsi | 2 +- arch/arm/dts/socfpga_arria10.dtsi | 2 +- arch/arm/dts/socfpga_arria10_socdk.dtsi | 8 + arch/arm/dts/socfpga_stratix10.dtsi | 2 +- .../dts/socfpga_stratix10_socdk-u-boot.dtsi | 8 + arch/arm/mach-socfpga/clock_manager.c | 12 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 156 +++++++------ arch/arm/mach-socfpga/clock_manager_gen5.c | 199 +++++++++-------- arch/arm/mach-socfpga/clock_manager_s10.c | 210 ++++++++++-------- .../mach-socfpga/include/mach/clock_manager.h | 2 + .../include/mach/clock_manager_arria10.h | 133 +++++------ .../include/mach/clock_manager_gen5.h | 112 ++++------ .../include/mach/clock_manager_s10.h | 115 ++++------ arch/arm/mach-socfpga/include/mach/misc.h | 1 + .../mach-socfpga/include/mach/reset_manager.h | 2 + .../include/mach/reset_manager_arria10.h | 43 +--- .../include/mach/reset_manager_gen5.h | 22 +- .../include/mach/reset_manager_s10.h | 33 +-- .../include/mach/system_manager.h | 2 + .../include/mach/system_manager_arria10.h | 94 +++----- .../include/mach/system_manager_gen5.h | 123 ++-------- .../include/mach/system_manager_s10.h | 184 ++++++--------- arch/arm/mach-socfpga/mailbox_s10.c | 6 +- arch/arm/mach-socfpga/misc.c | 42 ++++ arch/arm/mach-socfpga/misc_arria10.c | 9 +- arch/arm/mach-socfpga/misc_gen5.c | 29 +-- arch/arm/mach-socfpga/misc_s10.c | 9 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 71 +++--- arch/arm/mach-socfpga/reset_manager_gen5.c | 35 ++- arch/arm/mach-socfpga/reset_manager_s10.c | 52 +++-- arch/arm/mach-socfpga/scan_manager.c | 6 +- arch/arm/mach-socfpga/spl_a10.c | 12 +- arch/arm/mach-socfpga/spl_gen5.c | 23 +- arch/arm/mach-socfpga/spl_s10.c | 24 +- arch/arm/mach-socfpga/system_manager_gen5.c | 38 ++-- arch/arm/mach-socfpga/system_manager_s10.c | 39 ++-- arch/arm/mach-socfpga/wrap_pll_config_s10.c | 11 +- drivers/ddr/altera/sdram_gen5.c | 10 +- drivers/ddr/altera/sdram_s10.c | 6 +- drivers/fpga/socfpga_arria10.c | 7 +- drivers/fpga/socfpga_gen5.c | 4 +- drivers/mmc/socfpga_dw_mmc.c | 17 +- drivers/sysreset/sysreset_socfpga.c | 6 +- 44 files changed, 880 insertions(+), 1049 deletions(-)
Add u-boot,dm-pre-reloc for sysmgr and clkmgr nodes to use it in SPL. In preparation to get base address from DT.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
--- v3: - Fix missing '0' in clkmgr@ffd10000 node. --- arch/arm/dts/socfpga-common-u-boot.dtsi | 8 ++++++++ arch/arm/dts/socfpga.dtsi | 2 +- arch/arm/dts/socfpga_arria10.dtsi | 2 +- arch/arm/dts/socfpga_arria10_socdk.dtsi | 8 ++++++++ arch/arm/dts/socfpga_stratix10.dtsi | 2 +- arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi | 8 ++++++++ 6 files changed, 27 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/socfpga-common-u-boot.dtsi b/arch/arm/dts/socfpga-common-u-boot.dtsi index 322c858c4b..d55460755f 100644 --- a/arch/arm/dts/socfpga-common-u-boot.dtsi +++ b/arch/arm/dts/socfpga-common-u-boot.dtsi @@ -10,6 +10,10 @@ }; };
+&clkmgr { + u-boot,dm-pre-reloc; +}; + &rst { u-boot,dm-pre-reloc; }; @@ -17,3 +21,7 @@ &sdr { u-boot,dm-pre-reloc; }; + +&sysmgr { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 51a6a51b53..eda558f2fe 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -114,7 +114,7 @@ status = "disabled"; };
- clkmgr@ffd04000 { + clkmgr: clkmgr@ffd04000 { compatible = "altr,clk-mgr"; reg = <0xffd04000 0x1000>;
diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi index c11a5c0cc1..cc529bcd11 100644 --- a/arch/arm/dts/socfpga_arria10.dtsi +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -96,7 +96,7 @@ fpga-mgr = <&fpga_mgr>; };
- clkmgr@ffd04000 { + clkmgr: clkmgr@ffd04000 { compatible = "altr,clk-mgr"; reg = <0xffd04000 0x1000>; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/socfpga_arria10_socdk.dtsi b/arch/arm/dts/socfpga_arria10_socdk.dtsi index 6e5578d7bd..ef10708ee8 100644 --- a/arch/arm/dts/socfpga_arria10_socdk.dtsi +++ b/arch/arm/dts/socfpga_arria10_socdk.dtsi @@ -180,3 +180,11 @@ &l4_sp_clk { u-boot,dm-pre-reloc; }; + +&clkmgr { + u-boot,dm-pre-reloc; +}; + +&sysmgr { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_stratix10.dtsi b/arch/arm/dts/socfpga_stratix10.dtsi index bd68a78a37..a8e61cf728 100755 --- a/arch/arm/dts/socfpga_stratix10.dtsi +++ b/arch/arm/dts/socfpga_stratix10.dtsi @@ -82,7 +82,7 @@ ranges = <0 0 0 0xffffffff>; u-boot,dm-pre-reloc;
- clkmgr@ffd1000 { + clkmgr: clkmgr@ffd10000 { compatible = "altr,clk-mgr"; reg = <0xffd10000 0x1000>; }; diff --git a/arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi index e1cfb522bf..38855aecd7 100755 --- a/arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_stratix10_socdk-u-boot.dtsi @@ -11,6 +11,10 @@ }; };
+&clkmgr { + u-boot,dm-pre-reloc; +}; + &qspi { status = "okay"; u-boot,dm-pre-reloc; @@ -23,3 +27,7 @@ spi-rx-bus-width = <4>; u-boot,dm-pre-reloc; }; + +&sysmgr { + u-boot,dm-pre-reloc; +};
Convert reset manager for Gen5, Arria 10 and Stratix 10 from struct to defines.
Change to get reset manager base address from DT node instead of using #define.
--- v4: - Update commit message about get base address from DT node.
v3: - Remove "No functional change" in commit description.
v2: - Get base address from DT - Revert to use writel(), readl(), setbits_le32() and clrbits_le32(). - Add prefix to defines. --- arch/arm/mach-socfpga/include/mach/misc.h | 1 + .../mach-socfpga/include/mach/reset_manager.h | 2 + .../include/mach/reset_manager_arria10.h | 43 ++++------------- .../include/mach/reset_manager_gen5.h | 22 ++++----- .../include/mach/reset_manager_s10.h | 33 ++----------- arch/arm/mach-socfpga/misc.c | 32 +++++++++++++ arch/arm/mach-socfpga/misc_gen5.c | 7 ++- arch/arm/mach-socfpga/reset_manager_arria10.c | 47 ++++++++++--------- arch/arm/mach-socfpga/reset_manager_gen5.c | 28 +++++------ arch/arm/mach-socfpga/reset_manager_s10.c | 34 +++++++------- arch/arm/mach-socfpga/spl_a10.c | 7 ++- arch/arm/mach-socfpga/spl_gen5.c | 12 ++--- arch/arm/mach-socfpga/spl_s10.c | 12 +++-- drivers/sysreset/sysreset_socfpga.c | 6 +-- 14 files changed, 137 insertions(+), 149 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 27d0b6a370..a29b049742 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -41,5 +41,6 @@ void socfpga_sdram_remap_zero(void);
void do_bridge_reset(int enable, unsigned int mask); void socfpga_pl310_clear(void); +void socfpga_get_manager_addr(void);
#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 6ad037e325..a5b6931350 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -6,6 +6,8 @@ #ifndef _RESET_MANAGER_H_ #define _RESET_MANAGER_H_
+extern phys_addr_t socfpga_rstmgr_base; + void reset_cpu(ulong addr);
void socfpga_per_reset(u32 reset, int set); diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h index 6623ebee65..41169aa677 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -14,40 +14,15 @@ int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_deassert_osc1wd0(void); int socfpga_bridges_reset(void);
-struct socfpga_reset_manager { - u32 stat; - u32 ramstat; - u32 miscstat; - u32 ctrl; - u32 hdsken; - u32 hdskreq; - u32 hdskack; - u32 counts; - u32 mpumodrst; - u32 per0modrst; - u32 per1modrst; - u32 brgmodrst; - u32 sysmodrst; - u32 coldmodrst; - u32 nrstmodrst; - u32 dbgmodrst; - u32 mpuwarmmask; - u32 per0warmmask; - u32 per1warmmask; - u32 brgwarmmask; - u32 syswarmmask; - u32 nrstwarmmask; - u32 l3warmmask; - u32 tststa; - u32 tstscratch; - u32 hdsktimeout; - u32 hmcintr; - u32 hmcintren; - u32 hmcintrens; - u32 hmcintrenr; - u32 hmcgpout; - u32 hmcgpin; -}; +#define RSTMGR_A10_STATUS 0 +#define RSTMGR_A10_CTRL 0xc +#define RSTMGR_A10_MPUMODRST 0x20 +#define RSTMGR_A10_PER0MODRST 0x24 +#define RSTMGR_A10_PER1MODRST 0x28 +#define RSTMGR_A10_BRGMODRST 0x2c +#define RSTMGR_A10_SYSMODRST 0x30 + +#define RSTMGR_CTRL RSTMGR_A10_CTRL
/* * SocFPGA Arria10 reset IDs, bank mapping is as follows: diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h index f4dcb14623..e51ebfd08f 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h @@ -11,19 +11,15 @@ void socfpga_bridges_set_handoff_regs(bool h2f, bool lwh2f, bool f2h); void socfpga_bridges_reset(int enable);
-struct socfpga_reset_manager { - u32 status; - u32 ctrl; - u32 counts; - u32 padding1; - u32 mpu_mod_reset; - u32 per_mod_reset; - u32 per2_mod_reset; - u32 brg_mod_reset; - u32 misc_mod_reset; - u32 padding2[12]; - u32 tstscratch; -}; +#define RSTMGR_GEN5_STATUS 0 +#define RSTMGR_GEN5_CTRL 4 +#define RSTMGR_GEN5_MPUMODRST 0x10 +#define RSTMGR_GEN5_PERMODRST 0x14 +#define RSTMGR_GEN5_PER2MODRST 0x18 +#define RSTMGR_GEN5_BRGMODRST 0x1c +#define RSTMGR_GEN5_MISCMODRST 0x20 + +#define RSTMGR_CTRL RSTMGR_GEN5_CTRL
/* * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h index 452147b017..b602129656 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h @@ -15,34 +15,11 @@ void socfpga_bridges_reset(int enable); void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
-struct socfpga_reset_manager { - u32 status; - u32 mpu_rst_stat; - u32 misc_stat; - u32 padding1; - u32 hdsk_en; - u32 hdsk_req; - u32 hdsk_ack; - u32 hdsk_stall; - u32 mpumodrst; - u32 per0modrst; - u32 per1modrst; - u32 brgmodrst; - u32 padding2; - u32 cold_mod_reset; - u32 padding3; - u32 dbg_mod_reset; - u32 tap_mod_reset; - u32 padding4; - u32 padding5; - u32 brg_warm_mask; - u32 padding6[3]; - u32 tst_stat; - u32 padding7; - u32 hdsk_timeout; - u32 mpul2flushtimeout; - u32 dbghdsktimeout; -}; +#define RSTMGR_S10_STATUS 0 +#define RSTMGR_S10_MPUMODRST 0x20 +#define RSTMGR_S10_PER0MODRST 0x24 +#define RSTMGR_S10_PER1MODRST 0x28 +#define RSTMGR_S10_BRGMODRST 0x2c
#define RSTMGR_MPUMODRST_CORE0 0 #define RSTMGR_PER0MODRST_OCP_MASK 0x0020bf00 diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 49dadd4c3d..901c432f82 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -22,6 +22,8 @@
DECLARE_GLOBAL_DATA_PTR;
+phys_addr_t socfpga_rstmgr_base __section(".data"); + #ifdef CONFIG_SYS_L2_PL310 static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; @@ -145,6 +147,8 @@ void socfpga_fpga_add(void *fpga_desc)
int arch_cpu_init(void) { + socfpga_get_manager_addr(); + #ifdef CONFIG_HW_WATCHDOG /* * In case the watchdog is enabled, make sure to (re-)configure it @@ -202,3 +206,31 @@ U_BOOT_CMD(bridge, 3, 1, do_bridge, );
#endif + +static phys_addr_t socfpga_get_base_addr(const char *compat) +{ + const void *blob = gd->fdt_blob; + struct fdt_resource r; + int node; + int ret; + + node = fdt_node_offset_by_compatible(blob, -1, compat); + if (node < 0) + return 0; + + if (!fdtdec_get_is_enabled(blob, node)) + return 0; + + ret = fdt_get_resource(blob, node, "reg", 0, &r); + if (ret) + return 0; + + return (phys_addr_t)r.start; +} + +void socfpga_get_manager_addr(void) +{ + socfpga_rstmgr_base = socfpga_get_base_addr("altr,rst-mgr"); + if (!socfpga_rstmgr_base) + hang(); +} diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 31681b799d..b39a66562d 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -206,8 +206,6 @@ int arch_early_init_r(void) }
#ifndef CONFIG_SPL_BUILD -static struct socfpga_reset_manager *reset_manager_base = - (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; static struct socfpga_sdr_ctrl *sdr_ctrl = (struct socfpga_sdr_ctrl *)SDR_CTRLGRP_ADDRESS;
@@ -226,12 +224,13 @@ void do_bridge_reset(int enable, unsigned int mask)
writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); writel(iswgrp_handoff[3], &sdr_ctrl->fpgaport_rst); - writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); + writel(iswgrp_handoff[0], + socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(iswgrp_handoff[1], &nic301_regs->remap); } else { writel(0, &sysmgr_regs->fpgaintfgrp_module); writel(0, &sdr_ctrl->fpgaport_rst); - writel(0, &reset_manager_base->brg_mod_reset); + writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(1, &nic301_regs->remap); } } diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index 471a3045af..4553653992 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -15,8 +15,6 @@
-static const struct socfpga_reset_manager *reset_manager_base = - (void *)SOCFPGA_RSTMGR_ADDRESS; static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
@@ -63,14 +61,14 @@ static const struct bridge_cfg bridge_cfg_tbl[] = { void socfpga_watchdog_disable(void) { /* assert reset for watchdog */ - setbits_le32(&reset_manager_base->per1modrst, + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); }
/* Release NOC ddr scheduler from reset */ void socfpga_reset_deassert_noc_ddr_scheduler(void) { - clrbits_le32(&reset_manager_base->brgmodrst, + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); }
@@ -103,7 +101,7 @@ int socfpga_reset_deassert_bridges_handoff(void) setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc);
/* Release bridges from reset state per handoff value */ - clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, mask_rstmgr);
/* Poll until all idleack to 0, timeout at 1000ms */ return wait_for_bit_le32(&sysmgr_regs->noc_idleack, mask_noc, @@ -113,7 +111,7 @@ int socfpga_reset_deassert_bridges_handoff(void) /* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ void socfpga_reset_deassert_osc1wd0(void) { - clrbits_le32(&reset_manager_base->per1modrst, + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); }
@@ -122,24 +120,24 @@ void socfpga_reset_deassert_osc1wd0(void) */ void socfpga_per_reset(u32 reset, int set) { - const u32 *reg; + unsigned long reg; u32 rstmgr_bank = RSTMGR_BANK(reset);
switch (rstmgr_bank) { case 0: - reg = &reset_manager_base->mpumodrst; + reg = RSTMGR_A10_MPUMODRST; break; case 1: - reg = &reset_manager_base->per0modrst; + reg = RSTMGR_A10_PER0MODRST; break; case 2: - reg = &reset_manager_base->per1modrst; + reg = RSTMGR_A10_PER1MODRST; break; case 3: - reg = &reset_manager_base->brgmodrst; + reg = RSTMGR_A10_BRGMODRST; break; case 4: - reg = &reset_manager_base->sysmodrst; + reg = RSTMGR_A10_SYSMODRST; break;
default: @@ -147,9 +145,11 @@ void socfpga_per_reset(u32 reset, int set) }
if (set) - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + setbits_le32(socfpga_rstmgr_base + reg, + 1 << RSTMGR_RESET(reset)); else - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); + clrbits_le32(socfpga_rstmgr_base + reg, + 1 << RSTMGR_RESET(reset)); }
/* @@ -174,11 +174,12 @@ void socfpga_per_reset_all(void) ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK;
/* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ - writel(~l4wd0, &reset_manager_base->per1modrst); - setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST); + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER0MODRST, + ~mask_ecc_ocp);
/* Finally disable the ECC_OCP */ - setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER0MODRST, mask_ecc_ocp); }
int socfpga_bridges_reset(void) @@ -224,13 +225,13 @@ int socfpga_bridges_reset(void) return ret;
/* Put all bridges (except NOR DDR scheduler) into reset state */ - setbits_le32(&reset_manager_base->brgmodrst, + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | - ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | - ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | - ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | - ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | - ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK));
/* Disable NOC timeout */ writel(0, &sysmgr_regs->noc_timeout); diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c index 9a32f5abfe..ad31214711 100644 --- a/arch/arm/mach-socfpga/reset_manager_gen5.c +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -10,32 +10,30 @@ #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
/* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { - const u32 *reg; + unsigned long reg; u32 rstmgr_bank = RSTMGR_BANK(reset);
switch (rstmgr_bank) { case 0: - reg = &reset_manager_base->mpu_mod_reset; + reg = RSTMGR_GEN5_MPUMODRST; break; case 1: - reg = &reset_manager_base->per_mod_reset; + reg = RSTMGR_GEN5_PERMODRST; break; case 2: - reg = &reset_manager_base->per2_mod_reset; + reg = RSTMGR_GEN5_PER2MODRST; break; case 3: - reg = &reset_manager_base->brg_mod_reset; + reg = RSTMGR_GEN5_BRGMODRST; break; case 4: - reg = &reset_manager_base->misc_mod_reset; + reg = RSTMGR_GEN5_MISCMODRST; break;
default: @@ -43,9 +41,11 @@ void socfpga_per_reset(u32 reset, int set) }
/* @@ -57,8 +57,8 @@ void socfpga_per_reset_all(void) { const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0));
- writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_GEN5_PERMODRST); + writel(0xffffffff, socfpga_rstmgr_base + RSTMGR_GEN5_PER2MODRST); }
#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 @@ -95,7 +95,7 @@ void socfpga_bridges_reset(int enable)
if (enable) { /* brdmodrst */ - writel(0x7, &reset_manager_base->brg_mod_reset); + writel(0x7, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(L3REGS_REMAP_OCRAM_MASK, SOCFPGA_L3REGS_ADDRESS); } else { socfpga_bridges_set_handoff_regs(false, false, false); @@ -109,7 +109,7 @@ void socfpga_bridges_reset(int enable) }
/* brdmodrst */ - writel(0, &reset_manager_base->brg_mod_reset); + writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST);
/* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c index 499a84aff5..b196d58d3d 100644 --- a/arch/arm/mach-socfpga/reset_manager_s10.c +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -12,31 +12,31 @@
-static const struct socfpga_reset_manager *reset_manager_base = - (void *)SOCFPGA_RSTMGR_ADDRESS; static const struct socfpga_system_manager *system_manager_base = (void *)SOCFPGA_SYSMGR_ADDRESS;
/* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { - const void *reg; + unsigned long reg;
if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpumodrst; + reg = RSTMGR_S10_MPUMODRST; else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per0modrst; + reg = RSTMGR_S10_PER0MODRST; else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per1modrst; + reg = RSTMGR_S10_PER1MODRST; else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brgmodrst; + reg = RSTMGR_S10_BRGMODRST; else /* Invalid reset register, do nothing */ return;
/* @@ -50,9 +50,9 @@ void socfpga_per_reset_all(void)
/* disable all except OCP and l4wd0. OCP disable later */ writel(~(l4wd0 | RSTMGR_PER0MODRST_OCP_MASK), - &reset_manager_base->per0modrst); - writel(~l4wd0, &reset_manager_base->per0modrst); - writel(0xffffffff, &reset_manager_base->per1modrst); + socfpga_rstmgr_base + RSTMGR_S10_PER0MODRST); + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_S10_PER0MODRST); + writel(0xffffffff, socfpga_rstmgr_base + RSTMGR_S10_PER1MODRST); }
void socfpga_bridges_reset(int enable) @@ -62,7 +62,7 @@ void socfpga_bridges_reset(int enable) setbits_le32(&system_manager_base->noc_idlereq_clr, ~0);
/* Release all bridges from reset state */ - clrbits_le32(&reset_manager_base->brgmodrst, ~0); + clrbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, ~0);
/* Poll until all idleack to 0 */ while (readl(&system_manager_base->noc_idleack)) @@ -85,9 +85,9 @@ void socfpga_bridges_reset(int enable) ;
/* Reset all bridges (except NOR DDR scheduler & F2S) */ - setbits_le32(&reset_manager_base->brgmodrst, + setbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, ~(RSTMGR_BRGMODRST_DDRSCH_MASK | - RSTMGR_BRGMODRST_FPGA2SOC_MASK)); + RSTMGR_BRGMODRST_FPGA2SOC_MASK));
/* Disable NOC timeout */ writel(0, &system_manager_base->noc_timeout); @@ -99,6 +99,6 @@ void socfpga_bridges_reset(int enable) */ int cpu_has_been_warmreset(void) { - return readl(&reset_manager_base->status) & - RSTMGR_L4WD_MPU_WARMRESET_MASK; + return readl(socfpga_rstmgr_base + RSTMGR_S10_STATUS) & + RSTMGR_L4WD_MPU_WARMRESET_MASK; } diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index b820cb0673..a0d80fd47e 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -106,6 +106,11 @@ void spl_board_init(void)
void board_init_f(ulong dummy) { + if (spl_early_init()) + hang(); + + socfpga_get_manager_addr(); + dcache_disable();
socfpga_init_security_policies(); @@ -116,8 +121,6 @@ void board_init_f(ulong dummy) socfpga_per_reset_all(); socfpga_watchdog_disable();
- spl_early_init(); - /* Configure the clock based on handoff */ cm_basic_init(gd->fdt_blob);
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 47e63709ad..9ee053da3a 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -67,6 +67,12 @@ void board_init_f(ulong dummy) int ret; struct udevice *dev;
+ ret = spl_early_init(); + if (ret) + hang(); + + socfpga_get_manager_addr(); + /* * First C code to run. Clear fake OCRAM ECC first as SBE * and DBE might triggered during power on @@ -128,12 +134,6 @@ void board_init_f(ulong dummy) debug_uart_init(); #endif
- ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - } - ret = uclass_get_device(UCLASS_RESET, 0, &dev); if (ret) debug("Reset init failed: %d\n", ret); diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index ec65e1ce64..9a97a84e1e 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -14,6 +14,7 @@ #include <asm/arch/clock_manager.h> #include <asm/arch/firewall_s10.h> #include <asm/arch/mailbox_s10.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> #include <watchdog.h> @@ -120,6 +121,12 @@ void board_init_f(ulong dummy) const struct cm_config *cm_default_cfg = cm_get_default_config(); int ret;
+ ret = spl_early_init(); + if (ret) + hang(); + + socfpga_get_manager_addr(); + #ifdef CONFIG_HW_WATCHDOG /* Ensure watchdog is paused when debugging is happening */ writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, &sysmgr_regs->wddbg); @@ -145,11 +152,6 @@ void board_init_f(ulong dummy) socfpga_per_reset(SOCFPGA_RESET(UART0), 0); debug_uart_init(); #endif - ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - }
preloader_console_init(); cm_print_clock_quick_summary(); diff --git a/drivers/sysreset/sysreset_socfpga.c b/drivers/sysreset/sysreset_socfpga.c index d6c26a5b23..3390b7bdc2 100644 --- a/drivers/sysreset/sysreset_socfpga.c +++ b/drivers/sysreset/sysreset_socfpga.c @@ -12,7 +12,7 @@ #include <asm/arch/reset_manager.h>
struct socfpga_sysreset_data { - struct socfpga_reset_manager *rstmgr_base; + void __iomem *rstmgr_base; };
static int socfpga_sysreset_request(struct udevice *dev, @@ -23,11 +23,11 @@ static int socfpga_sysreset_request(struct udevice *dev, switch (type) { case SYSRESET_WARM: writel(BIT(RSTMGR_CTRL_SWWARMRSTREQ_LSB), - &data->rstmgr_base->ctrl); + data->rstmgr_base + RSTMGR_CTRL); break; case SYSRESET_COLD: writel(BIT(RSTMGR_CTRL_SWCOLDRSTREQ_LSB), - &data->rstmgr_base->ctrl); + data->rstmgr_base + RSTMGR_CTRL); break; default: return -EPROTONOSUPPORT;
Am 10.10.2019 um 09:37 schrieb Ley Foon Tan:
v4:
v3:
v2:
Did I write before that I think this is an ugly hack that should be removed in the future by converting *all* drivers to DM? :-)
- u32 stat;
- u32 ramstat;
- u32 miscstat;
- u32 ctrl;
- u32 hdsken;
- u32 hdskreq;
- u32 hdskack;
- u32 counts;
- u32 mpumodrst;
- u32 per0modrst;
- u32 per1modrst;
- u32 brgmodrst;
- u32 sysmodrst;
- u32 coldmodrst;
- u32 nrstmodrst;
- u32 dbgmodrst;
- u32 mpuwarmmask;
- u32 per0warmmask;
- u32 per1warmmask;
- u32 brgwarmmask;
- u32 syswarmmask;
- u32 nrstwarmmask;
- u32 l3warmmask;
- u32 tststa;
- u32 tstscratch;
- u32 hdsktimeout;
- u32 hmcintr;
- u32 hmcintren;
- u32 hmcintrens;
- u32 hmcintrenr;
- u32 hmcgpout;
- u32 hmcgpin;
Please fix the format here: all defines should be formatted the same way (i.e. here: 0x00, 0x0c, 0x20 etc) to make the code easier to read.
- SocFPGA Arria10 reset IDs, bank mapping is as follows:
- u32 status;
- u32 ctrl;
- u32 counts;
- u32 padding1;
- u32 padding2[12];
- u32 tstscratch;
Same here. And in many other files.
- SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows:
- u32 status;
- u32 mpu_rst_stat;
- u32 misc_stat;
- u32 padding1;
- u32 hdsk_en;
- u32 hdsk_req;
- u32 hdsk_ack;
- u32 hdsk_stall;
- u32 mpumodrst;
- u32 per0modrst;
- u32 per1modrst;
- u32 brgmodrst;
- u32 padding2;
- u32 padding3;
- u32 padding4;
- u32 padding5;
- u32 padding6[3];
- u32 tst_stat;
- u32 padding7;
- u32 hdsk_timeout;
And again here. I'll stop nothing this now ;-)
This even gets uglier now by adding the section placement. I have a series (still not finished) to fully convert gen5 to driver model, where I will get rid of this, then we will get an #ifndef around this one that disables it for gen5.
Do you have any plans like that for a10/s10/agilex?
- #ifdef CONFIG_SYS_L2_PL310 static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE;
- socfpga_get_manager_addr();
- #ifdef CONFIG_HW_WATCHDOG /*
- In case the watchdog is enabled, make sure to (re-)configure it
#endif
- const void *blob = gd->fdt_blob;
- struct fdt_resource r;
- int node;
- int ret;
- node = fdt_node_offset_by_compatible(blob, -1, compat);
- if (node < 0)
- if (!fdtdec_get_is_enabled(blob, node))
- ret = fdt_get_resource(blob, node, "reg", 0, &r);
- if (ret)
- return (phys_addr_t)r.start;
- socfpga_rstmgr_base = socfpga_get_base_addr("altr,rst-mgr");
- if (!socfpga_rstmgr_base)
hang();
writel(iswgrp_handoff[1], &nic301_regs->remap); } else { writel(0, &sysmgr_regs->fpgaintfgrp_module); writel(0, &sdr_ctrl->fpgaport_rst);socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST);
writel(1, &nic301_regs->remap); } }writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST);
static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;(void *)SOCFPGA_RSTMGR_ADDRESS;
- clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); }
- clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); }
- const u32 *reg;
break; case 1:reg = RSTMGR_A10_MPUMODRST;
break; case 2:reg = RSTMGR_A10_PER0MODRST;
break; case 3:reg = RSTMGR_A10_PER1MODRST;
break; case 4:reg = RSTMGR_A10_BRGMODRST;
break;
default:
if (set)
else1 << RSTMGR_RESET(reset));
~mask_ecc_ocp);
- setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK |
const u32 *reg;
break; case 1:reg = RSTMGR_GEN5_MPUMODRST;
break; case 2:reg = RSTMGR_GEN5_PERMODRST;
break; case 3:reg = RSTMGR_GEN5_PER2MODRST;
break; case 4:reg = RSTMGR_GEN5_BRGMODRST;
break;
default:
if (set)
writel(L3REGS_REMAP_OCRAM_MASK, SOCFPGA_L3REGS_ADDRESS); } else { socfpga_bridges_set_handoff_regs(false, false, false);writel(0x7, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST);
/* brdmodrst */
const void *reg;
unsigned long reg;
else if (RSTMGR_BANK(reset) == 1)reg = RSTMGR_S10_MPUMODRST;
else if (RSTMGR_BANK(reset) == 2)reg = RSTMGR_S10_PER0MODRST;
else if (RSTMGR_BANK(reset) == 3)reg = RSTMGR_S10_PER1MODRST;
if (set)
- return readl(socfpga_rstmgr_base + RSTMGR_S10_STATUS) &
}RSTMGR_L4WD_MPU_WARMRESET_MASK;
hang();
dcache_disable();
- spl_early_init();
- if (ret)
hang();
- First C code to run. Clear fake OCRAM ECC first as SBE
Ehrm, does this work with ECC? At least this comment now seems wrong as you run a *lot* of code now before this. Since I don't have/use ECC, I can't tell what this code does, anyway... :-/
- if (ret) {
hang();
- if (ret)
hang();
- #ifdef CONFIG_HW_WATCHDOG /* Ensure watchdog is paused when debugging is happening */ writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, &sysmgr_regs->wddbg);
if (ret) {
hang();
break; case SYSRESET_COLD: writel(BIT(RSTMGR_CTRL_SWCOLDRSTREQ_LSB),data->rstmgr_base + RSTMGR_CTRL);
break; default: return -EPROTONOSUPPORT;data->rstmgr_base + RSTMGR_CTRL);
On Wed, Oct 23, 2019 at 2:11 AM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
v4:
v3:
v2:
Agreed, it is ugly. But, we still need it they convert to DM.
u32 stat;
u32 ramstat;
u32 miscstat;
u32 ctrl;
u32 hdsken;
u32 hdskreq;
u32 hdskack;
u32 counts;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 sysmodrst;
u32 coldmodrst;
u32 nrstmodrst;
u32 dbgmodrst;
u32 mpuwarmmask;
u32 per0warmmask;
u32 per1warmmask;
u32 brgwarmmask;
u32 syswarmmask;
u32 nrstwarmmask;
u32 l3warmmask;
u32 tststa;
u32 tstscratch;
u32 hdsktimeout;
u32 hmcintr;
u32 hmcintren;
u32 hmcintrens;
u32 hmcintrenr;
u32 hmcgpout;
u32 hmcgpin;
Okay.
u32 status;
u32 ctrl;
u32 counts;
u32 padding1;
u32 mpu_mod_reset;
u32 per_mod_reset;
u32 per2_mod_reset;
u32 brg_mod_reset;
u32 misc_mod_reset;
u32 padding2[12];
u32 tstscratch;
u32 status;
u32 mpu_rst_stat;
u32 misc_stat;
u32 padding1;
u32 hdsk_en;
u32 hdsk_req;
u32 hdsk_ack;
u32 hdsk_stall;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 padding2;
u32 cold_mod_reset;
u32 padding3;
u32 dbg_mod_reset;
u32 tap_mod_reset;
u32 padding4;
u32 padding5;
u32 brg_warm_mask;
u32 padding6[3];
u32 tst_stat;
u32 padding7;
u32 hdsk_timeout;
u32 dbghdsktimeout;
We need put it to .data section for SPL to have global variable. Did you convert system/reset/clock manager for Gen5? Many places (in different drivers) access to system manager register, how you access to system manger after convert to DM? What you mean by use #ifndef to disable it? Do you have example patch for doing it? Or can you send the patch to me and I can take a look.
- #ifdef CONFIG_HW_WATCHDOG /* * In case the watchdog is enabled, make sure to (re-)configure it
#endif
int node;
int ret;
if (node < 0)
if (ret)
hang();
static struct socfpga_sdr_ctrl *sdr_ctrl = (struct socfpga_sdr_ctrl *)SDR_CTRLGRP_ADDRESS;(struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS;
}writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(1, &nic301_regs->remap); }
}clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK);
clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, mask_rstmgr); /* Poll until all idleack to 0, timeout at 1000ms */ return wait_for_bit_le32(&sysmgr_regs->noc_idleack, mask_noc,
}clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, ALT_RSTMGR_PER1MODRST_WD0_SET_MSK);
const u32 *reg;
unsigned long reg; u32 rstmgr_bank = RSTMGR_BANK(reset); switch (rstmgr_bank) { case 0:
reg = RSTMGR_A10_SYSMODRST; break; default:
if (set)
~mask_ecc_ocp); /* Finally disable the ECC_OCP */
ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); /* Disable NOC timeout */ writel(0, &sysmgr_regs->noc_timeout);
const u32 *reg;
reg = RSTMGR_GEN5_MISCMODRST; break; default:
if (set)
/* brdmodrst */
writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS);
const void *reg;
unsigned long reg; if (RSTMGR_BANK(reset) == 0)
reg = RSTMGR_S10_BRGMODRST; else /* Invalid reset register, do nothing */ return; if (set)
clrbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, ~0); /* Poll until all idleack to 0 */ while (readl(&system_manager_base->noc_idleack))
RSTMGR_BRGMODRST_FPGA2SOC_MASK)); /* Disable NOC timeout */ writel(0, &system_manager_base->noc_timeout);
hang();
dcache_disable(); socfpga_init_security_policies();
spl_early_init();
if (ret)
hang();
Yes, you are right. I have moved some code before ECC clearing clode. But, we need to get system manager base address from DT before we can write to system manger to clear fake OCRAM ECC. In this case, this code need to use #define system manager base instead of base address from DT if it must at entry of the function.
if (ret) {
hang();
if (ret)
hang();
if (ret) {
hang();
} preloader_console_init(); cm_print_clock_quick_summary();
v4:
v3:
v2:
What do you mean, we still need it? I don't think so.
u32 stat;
u32 ramstat;
u32 miscstat;
u32 ctrl;
u32 hdsken;
u32 hdskreq;
u32 hdskack;
u32 counts;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 sysmodrst;
u32 coldmodrst;
u32 nrstmodrst;
u32 dbgmodrst;
u32 mpuwarmmask;
u32 per0warmmask;
u32 per1warmmask;
u32 brgwarmmask;
u32 syswarmmask;
u32 nrstwarmmask;
u32 l3warmmask;
u32 tststa;
u32 tstscratch;
u32 hdsktimeout;
u32 hmcintr;
u32 hmcintren;
u32 hmcintrens;
u32 hmcintrenr;
u32 hmcgpout;
u32 hmcgpin;
Okay.
u32 status;
u32 ctrl;
u32 counts;
u32 padding1;
u32 mpu_mod_reset;
u32 per_mod_reset;
u32 per2_mod_reset;
u32 brg_mod_reset;
u32 misc_mod_reset;
u32 padding2[12];
u32 tstscratch;
u32 status;
u32 mpu_rst_stat;
u32 misc_stat;
u32 padding1;
u32 hdsk_en;
u32 hdsk_req;
u32 hdsk_ack;
u32 hdsk_stall;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 padding2;
u32 cold_mod_reset;
u32 padding3;
u32 dbg_mod_reset;
u32 tap_mod_reset;
u32 padding4;
u32 padding5;
u32 brg_warm_mask;
u32 padding6[3];
u32 tst_stat;
u32 padding7;
u32 hdsk_timeout;
u32 dbghdsktimeout;
It's still not finished as I do that in my free time, but yes, I have a series in progress that converts *everything* for gen5 to DM. Resetmgr and clockmgr are straigthforward, systemmgr will be a 'misc' device that exposes functionality via calls or ioctls.
I think that makes it much cleaner since I now have a single place where to do things instead of just passing around the sysmgr base address everywhere...
I will post it here as soon as it is a bit more stable.
#endif
int node;
int ret;
if (node < 0)
if (ret)
hang();
const u32 *reg;
if (set)
const u32 *reg;
if (set)
/* brdmodrst */
const void *reg;
hang();
spl_early_init();
if (ret)
hang();
Well, I don't know if this must be at the start. That's why I asked. Since you only clear interrupt bits, it's probably OK like it is, but I can't really tell.
if (ret) {
hang();
if (ret)
hang();
if (ret) {
hang();
On Fri, Oct 25, 2019 at 5:37 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
v4:
v3:
v2:
What I mean is if we still use global variable for base address, but still need this externs.
u32 stat;
u32 ramstat;
u32 miscstat;
u32 ctrl;
u32 hdsken;
u32 hdskreq;
u32 hdskack;
u32 counts;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 sysmodrst;
u32 coldmodrst;
u32 nrstmodrst;
u32 dbgmodrst;
u32 mpuwarmmask;
u32 per0warmmask;
u32 per1warmmask;
u32 brgwarmmask;
u32 syswarmmask;
u32 nrstwarmmask;
u32 l3warmmask;
u32 tststa;
u32 tstscratch;
u32 hdsktimeout;
u32 hmcintr;
u32 hmcintren;
u32 hmcintrens;
u32 hmcintrenr;
u32 hmcgpout;
u32 hmcgpin;
Okay.
u32 status;
u32 ctrl;
u32 counts;
u32 padding1;
u32 mpu_mod_reset;
u32 per_mod_reset;
u32 per2_mod_reset;
u32 brg_mod_reset;
u32 misc_mod_reset;
u32 padding2[12];
u32 tstscratch;
u32 status;
u32 mpu_rst_stat;
u32 misc_stat;
u32 padding1;
u32 hdsk_en;
u32 hdsk_req;
u32 hdsk_ack;
u32 hdsk_stall;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 padding2;
u32 cold_mod_reset;
u32 padding3;
u32 dbg_mod_reset;
u32 tap_mod_reset;
u32 padding4;
u32 padding5;
u32 brg_warm_mask;
u32 padding6[3];
u32 tst_stat;
u32 padding7;
u32 hdsk_timeout;
u32 dbghdsktimeout;
Do you move reset bridge code to drivers/reset as well? Do you use global variable too after get struct udevice instance or get again device instance every time when need it?
If we don't want to add global variable to .data section, then we need convert all those drivers to DM for Gen5/A10/S10 as you did for Gen5. Otherwise, we can't get Agilex series patchset get merged to mainline, because it depends on this series.
#endif
int node;
int ret;
if (node < 0)
if (ret)
hang();
const u32 *reg;
if (set)
const u32 *reg;
if (set)
/* brdmodrst */
const void *reg;
hang();
spl_early_init();
if (ret)
hang();
Yes, I think it should be okay (not at entry of function) since it only clear interrupt.
Regards Ley Foon
if (ret) {
hang();
if (ret)
hang();
if (ret) {
hang();
Ley Foon Tan lftan.linux@gmail.com schrieb am Di., 29. Okt. 2019, 11:16:
using
#define.
v4:
v3:
v2:
clrbits_le32().
diff --git
u32 stat;
u32 ramstat;
u32 miscstat;
u32 ctrl;
u32 hdsken;
u32 hdskreq;
u32 hdskack;
u32 counts;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 sysmodrst;
u32 coldmodrst;
u32 nrstmodrst;
u32 dbgmodrst;
u32 mpuwarmmask;
u32 per0warmmask;
u32 per1warmmask;
u32 brgwarmmask;
u32 syswarmmask;
u32 nrstwarmmask;
u32 l3warmmask;
u32 tststa;
u32 tstscratch;
u32 hdsktimeout;
u32 hmcintr;
u32 hmcintren;
u32 hmcintrens;
u32 hmcintrenr;
u32 hmcgpout;
u32 hmcgpin;
way
Okay.
diff --git
f2h);
u32 status;
u32 ctrl;
u32 counts;
u32 padding1;
u32 mpu_mod_reset;
u32 per_mod_reset;
u32 per2_mod_reset;
u32 brg_mod_reset;
u32 misc_mod_reset;
u32 padding2[12];
u32 tstscratch;
follows:
diff --git
u32 status;
u32 mpu_rst_stat;
u32 misc_stat;
u32 padding1;
u32 hdsk_en;
u32 hdsk_req;
u32 hdsk_ack;
u32 hdsk_stall;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 padding2;
u32 cold_mod_reset;
u32 padding3;
u32 dbg_mod_reset;
u32 tap_mod_reset;
u32 padding4;
u32 padding5;
u32 brg_warm_mask;
u32 padding6[3];
u32 tst_stat;
u32 padding7;
u32 hdsk_timeout;
u32 dbghdsktimeout;
where
that
Yes, changing bridges is a function of sysmgr, callable via DM functions. So no global variable needed.
I hope to send this series soon.
As none of the sub arches is doing it like I plan for gen5 yet, it's probably ok to merge this. I only meant I will probably remove a for gen5 soon.
(re-)configure it
#endif
int node;
int ret;
if (node < 0)
if (ret)
hang();
int mask)
static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager(void *)SOCFPGA_RSTMGR_ADDRESS;
setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); /* Release bridges from reset state per handoff value */
mask_rstmgr);
manager */
const u32 *reg;
if (set)
WD0 */
mask_ecc_ocp);
state */
const u32 *reg;
if (set)
false);
/* brdmodrst */
const void *reg;
~0);
F2S) */
hang();
spl_early_init();
if (ret)
hang();
as
I
Regards Ley Foon
if (ret) {
hang();
int ret;
if (ret)
hang();
if (ret) {
hang();
udevice *dev,
On Tue, Oct 29, 2019 at 6:31 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
v4:
v3:
v2:
u32 stat;
u32 ramstat;
u32 miscstat;
u32 ctrl;
u32 hdsken;
u32 hdskreq;
u32 hdskack;
u32 counts;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 sysmodrst;
u32 coldmodrst;
u32 nrstmodrst;
u32 dbgmodrst;
u32 mpuwarmmask;
u32 per0warmmask;
u32 per1warmmask;
u32 brgwarmmask;
u32 syswarmmask;
u32 nrstwarmmask;
u32 l3warmmask;
u32 tststa;
u32 tstscratch;
u32 hdsktimeout;
u32 hmcintr;
u32 hmcintren;
u32 hmcintrens;
u32 hmcintrenr;
u32 hmcgpout;
u32 hmcgpin;
Okay.
u32 status;
u32 ctrl;
u32 counts;
u32 padding1;
u32 mpu_mod_reset;
u32 per_mod_reset;
u32 per2_mod_reset;
u32 brg_mod_reset;
u32 misc_mod_reset;
u32 padding2[12];
u32 tstscratch;
u32 status;
u32 mpu_rst_stat;
u32 misc_stat;
u32 padding1;
u32 hdsk_en;
u32 hdsk_req;
u32 hdsk_ack;
u32 hdsk_stall;
u32 mpumodrst;
u32 per0modrst;
u32 per1modrst;
u32 brgmodrst;
u32 padding2;
u32 cold_mod_reset;
u32 padding3;
u32 dbg_mod_reset;
u32 tap_mod_reset;
u32 padding4;
u32 padding5;
u32 brg_warm_mask;
u32 padding6[3];
u32 tst_stat;
u32 padding7;
u32 hdsk_timeout;
u32 dbghdsktimeout;
If you are okay for using .data section for global as for now, then I will send a new revision to fix the consistency for macros values with 0x.
Regards Ley Foon
#endif
int node;
int ret;
if (node < 0)
if (ret)
hang();
const u32 *reg;
if (set)
const u32 *reg;
if (set)
/* brdmodrst */
const void *reg;
hang();
spl_early_init();
if (ret)
hang();
Regards Ley Foon
if (ret) {
hang();
if (ret)
hang();
if (ret) {
hang();
Am 10.10.2019 um 09:37 schrieb Ley Foon Tan: > Convert reset manager for Gen5, Arria 10 and Stratix 10 from struct > to defines. > > Change to get reset manager base address from DT node instead of using > #define. > > Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com > > --- > v4: > - Update commit message about get base address from DT node. > > v3: > - Remove "No functional change" in commit description. > > v2: > - Get base address from DT > - Revert to use writel(), readl(), setbits_le32() and clrbits_le32(). > - Add prefix to defines. > --- > arch/arm/mach-socfpga/include/mach/misc.h | 1 + > .../mach-socfpga/include/mach/reset_manager.h | 2 + > .../include/mach/reset_manager_arria10.h | 43 ++++------------- > .../include/mach/reset_manager_gen5.h | 22 ++++----- > .../include/mach/reset_manager_s10.h | 33 ++----------- > arch/arm/mach-socfpga/misc.c | 32 +++++++++++++ > arch/arm/mach-socfpga/misc_gen5.c | 7 ++- > arch/arm/mach-socfpga/reset_manager_arria10.c | 47 ++++++++++--------- > arch/arm/mach-socfpga/reset_manager_gen5.c | 28 +++++------ > arch/arm/mach-socfpga/reset_manager_s10.c | 34 +++++++------- > arch/arm/mach-socfpga/spl_a10.c | 7 ++- > arch/arm/mach-socfpga/spl_gen5.c | 12 ++--- > arch/arm/mach-socfpga/spl_s10.c | 12 +++-- > drivers/sysreset/sysreset_socfpga.c | 6 +-- > 14 files changed, 137 insertions(+), 149 deletions(-) > > diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h > index 27d0b6a370..a29b049742 100644 > --- a/arch/arm/mach-socfpga/include/mach/misc.h > +++ b/arch/arm/mach-socfpga/include/mach/misc.h > @@ -41,5 +41,6 @@ void socfpga_sdram_remap_zero(void); > > void do_bridge_reset(int enable, unsigned int mask); > void socfpga_pl310_clear(void); > +void socfpga_get_manager_addr(void); > > #endif /* _MISC_H_ */ > diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h > index 6ad037e325..a5b6931350 100644 > --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h > +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h > @@ -6,6 +6,8 @@ > #ifndef _RESET_MANAGER_H_ > #define _RESET_MANAGER_H_ > > +extern phys_addr_t socfpga_rstmgr_base;
> + > void reset_cpu(ulong addr); > > void socfpga_per_reset(u32 reset, int set); > diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h > index 6623ebee65..41169aa677 100644 > --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h > +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h > @@ -14,40 +14,15 @@ int socfpga_reset_deassert_bridges_handoff(void); > void socfpga_reset_deassert_osc1wd0(void); > int socfpga_bridges_reset(void); > > -struct socfpga_reset_manager { > - u32 stat; > - u32 ramstat; > - u32 miscstat; > - u32 ctrl; > - u32 hdsken; > - u32 hdskreq; > - u32 hdskack; > - u32 counts; > - u32 mpumodrst; > - u32 per0modrst; > - u32 per1modrst; > - u32 brgmodrst; > - u32 sysmodrst; > - u32 coldmodrst; > - u32 nrstmodrst; > - u32 dbgmodrst; > - u32 mpuwarmmask; > - u32 per0warmmask; > - u32 per1warmmask; > - u32 brgwarmmask; > - u32 syswarmmask; > - u32 nrstwarmmask; > - u32 l3warmmask; > - u32 tststa; > - u32 tstscratch; > - u32 hdsktimeout; > - u32 hmcintr; > - u32 hmcintren; > - u32 hmcintrens; > - u32 hmcintrenr; > - u32 hmcgpout; > - u32 hmcgpin; > -}; > +#define RSTMGR_A10_STATUS 0 > +#define RSTMGR_A10_CTRL 0xc
Okay.
> +#define RSTMGR_A10_MPUMODRST 0x20 > +#define RSTMGR_A10_PER0MODRST 0x24 > +#define RSTMGR_A10_PER1MODRST 0x28 > +#define RSTMGR_A10_BRGMODRST 0x2c > +#define RSTMGR_A10_SYSMODRST 0x30 > + > +#define RSTMGR_CTRL RSTMGR_A10_CTRL > > /* > * SocFPGA Arria10 reset IDs, bank mapping is as follows: > diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h > index f4dcb14623..e51ebfd08f 100644 > --- a/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h > +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_gen5.h > @@ -11,19 +11,15 @@ > void socfpga_bridges_set_handoff_regs(bool h2f, bool lwh2f, bool f2h); > void socfpga_bridges_reset(int enable); > > -struct socfpga_reset_manager { > - u32 status; > - u32 ctrl; > - u32 counts; > - u32 padding1; > - u32 mpu_mod_reset; > - u32 per_mod_reset; > - u32 per2_mod_reset; > - u32 brg_mod_reset; > - u32 misc_mod_reset; > - u32 padding2[12]; > - u32 tstscratch; > -}; > +#define RSTMGR_GEN5_STATUS 0 > +#define RSTMGR_GEN5_CTRL 4
> +#define RSTMGR_GEN5_MPUMODRST 0x10 > +#define RSTMGR_GEN5_PERMODRST 0x14 > +#define RSTMGR_GEN5_PER2MODRST 0x18 > +#define RSTMGR_GEN5_BRGMODRST 0x1c > +#define RSTMGR_GEN5_MISCMODRST 0x20 > + > +#define RSTMGR_CTRL RSTMGR_GEN5_CTRL > > /* > * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: > diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h > index 452147b017..b602129656 100644 > --- a/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h > +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h > @@ -15,34 +15,11 @@ void socfpga_bridges_reset(int enable); > void socfpga_per_reset(u32 reset, int set); > void socfpga_per_reset_all(void); > > -struct socfpga_reset_manager { > - u32 status; > - u32 mpu_rst_stat; > - u32 misc_stat; > - u32 padding1; > - u32 hdsk_en; > - u32 hdsk_req; > - u32 hdsk_ack; > - u32 hdsk_stall; > - u32 mpumodrst; > - u32 per0modrst; > - u32 per1modrst; > - u32 brgmodrst; > - u32 padding2; > - u32 cold_mod_reset; > - u32 padding3; > - u32 dbg_mod_reset; > - u32 tap_mod_reset; > - u32 padding4; > - u32 padding5; > - u32 brg_warm_mask; > - u32 padding6[3]; > - u32 tst_stat; > - u32 padding7; > - u32 hdsk_timeout; > - u32 mpul2flushtimeout; > - u32 dbghdsktimeout; > -}; > +#define RSTMGR_S10_STATUS 0 > +#define RSTMGR_S10_MPUMODRST 0x20
> +#define RSTMGR_S10_PER0MODRST 0x24 > +#define RSTMGR_S10_PER1MODRST 0x28 > +#define RSTMGR_S10_BRGMODRST 0x2c > > #define RSTMGR_MPUMODRST_CORE0 0 > #define RSTMGR_PER0MODRST_OCP_MASK 0x0020bf00 > diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c > index 49dadd4c3d..901c432f82 100644 > --- a/arch/arm/mach-socfpga/misc.c > +++ b/arch/arm/mach-socfpga/misc.c > @@ -22,6 +22,8 @@ > > DECLARE_GLOBAL_DATA_PTR; > > +phys_addr_t socfpga_rstmgr_base __section(".data");
Sorry, I wasn't really online last week. Yes, it's ok for me for now.
Regards Ley Foon
> + > #ifdef CONFIG_SYS_L2_PL310 > static const struct pl310_regs *const pl310 = > (struct pl310_regs *)CONFIG_SYS_PL310_BASE; > @@ -145,6 +147,8 @@ void socfpga_fpga_add(void *fpga_desc) > > int arch_cpu_init(void) > { > + socfpga_get_manager_addr(); > + > #ifdef CONFIG_HW_WATCHDOG > /* > * In case the watchdog is enabled, make sure to (re-)configure it > @@ -202,3 +206,31 @@ U_BOOT_CMD(bridge, 3, 1, do_bridge, > ); > > #endif > + > +static phys_addr_t socfpga_get_base_addr(const char *compat) > +{ > + const void *blob = gd->fdt_blob; > + struct fdt_resource r; > + int node; > + int ret; > + > + node = fdt_node_offset_by_compatible(blob, -1, compat); > + if (node < 0) > + return 0; > + > + if (!fdtdec_get_is_enabled(blob, node)) > + return 0; > + > + ret = fdt_get_resource(blob, node, "reg", 0, &r); > + if (ret) > + return 0; > + > + return (phys_addr_t)r.start; > +} > + > +void socfpga_get_manager_addr(void) > +{ > + socfpga_rstmgr_base = socfpga_get_base_addr("altr,rst-mgr"); > + if (!socfpga_rstmgr_base) > + hang(); > +} > diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c > index 31681b799d..b39a66562d 100644 > --- a/arch/arm/mach-socfpga/misc_gen5.c > +++ b/arch/arm/mach-socfpga/misc_gen5.c > @@ -206,8 +206,6 @@ int arch_early_init_r(void) > } > > #ifndef CONFIG_SPL_BUILD > -static struct socfpga_reset_manager *reset_manager_base = > - (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; > static struct socfpga_sdr_ctrl *sdr_ctrl = > (struct socfpga_sdr_ctrl *)SDR_CTRLGRP_ADDRESS; > > @@ -226,12 +224,13 @@ void do_bridge_reset(int enable, unsigned int mask) > > writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); > writel(iswgrp_handoff[3], &sdr_ctrl->fpgaport_rst); > - writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); > + writel(iswgrp_handoff[0], > + socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); > writel(iswgrp_handoff[1], &nic301_regs->remap); > } else { > writel(0, &sysmgr_regs->fpgaintfgrp_module); > writel(0, &sdr_ctrl->fpgaport_rst); > - writel(0, &reset_manager_base->brg_mod_reset); > + writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); > writel(1, &nic301_regs->remap); > } > } > diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c > index 471a3045af..4553653992 100644 > --- a/arch/arm/mach-socfpga/reset_manager_arria10.c > +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c > @@ -15,8 +15,6 @@ > > DECLARE_GLOBAL_DATA_PTR; > > -static const struct socfpga_reset_manager *reset_manager_base = > - (void *)SOCFPGA_RSTMGR_ADDRESS; > static const struct socfpga_system_manager *sysmgr_regs = > (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; > > @@ -63,14 +61,14 @@ static const struct bridge_cfg bridge_cfg_tbl[] = { > void socfpga_watchdog_disable(void) > { > /* assert reset for watchdog */ > - setbits_le32(&reset_manager_base->per1modrst, > + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, > ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); > } > > /* Release NOC ddr scheduler from reset */ > void socfpga_reset_deassert_noc_ddr_scheduler(void) > { > - clrbits_le32(&reset_manager_base->brgmodrst, > + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, > ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); > } > > @@ -103,7 +101,7 @@ int socfpga_reset_deassert_bridges_handoff(void) > setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); > > /* Release bridges from reset state per handoff value */ > - clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); > + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, mask_rstmgr); > > /* Poll until all idleack to 0, timeout at 1000ms */ > return wait_for_bit_le32(&sysmgr_regs->noc_idleack, mask_noc, > @@ -113,7 +111,7 @@ int socfpga_reset_deassert_bridges_handoff(void) > /* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ > void socfpga_reset_deassert_osc1wd0(void) > { > - clrbits_le32(&reset_manager_base->per1modrst, > + clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST, > ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); > } > > @@ -122,24 +120,24 @@ void socfpga_reset_deassert_osc1wd0(void) > */ > void socfpga_per_reset(u32 reset, int set) > { > - const u32 *reg; > + unsigned long reg; > u32 rstmgr_bank = RSTMGR_BANK(reset); > > switch (rstmgr_bank) { > case 0: > - reg = &reset_manager_base->mpumodrst; > + reg = RSTMGR_A10_MPUMODRST; > break; > case 1: > - reg = &reset_manager_base->per0modrst; > + reg = RSTMGR_A10_PER0MODRST; > break; > case 2: > - reg = &reset_manager_base->per1modrst; > + reg = RSTMGR_A10_PER1MODRST; > break; > case 3: > - reg = &reset_manager_base->brgmodrst; > + reg = RSTMGR_A10_BRGMODRST; > break; > case 4: > - reg = &reset_manager_base->sysmodrst; > + reg = RSTMGR_A10_SYSMODRST; > break; > > default: > @@ -147,9 +145,11 @@ void socfpga_per_reset(u32 reset, int set) > } > > if (set) > - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + setbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > else > - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + clrbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > } > > /* > @@ -174,11 +174,12 @@ void socfpga_per_reset_all(void) > ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; > > /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ > - writel(~l4wd0, &reset_manager_base->per1modrst); > - setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); > + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_A10_PER1MODRST); > + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER0MODRST, > + ~mask_ecc_ocp); > > /* Finally disable the ECC_OCP */ > - setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); > + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_PER0MODRST, mask_ecc_ocp); > } > > int socfpga_bridges_reset(void) > @@ -224,13 +225,13 @@ int socfpga_bridges_reset(void) > return ret; > > /* Put all bridges (except NOR DDR scheduler) into reset state */ > - setbits_le32(&reset_manager_base->brgmodrst, > + setbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, > (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | > - ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | > - ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | > - ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | > - ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | > - ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); > + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | > + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | > + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | > + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | > + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); > > /* Disable NOC timeout */ > writel(0, &sysmgr_regs->noc_timeout); > diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c > index 9a32f5abfe..ad31214711 100644 > --- a/arch/arm/mach-socfpga/reset_manager_gen5.c > +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c > @@ -10,32 +10,30 @@ > #include <asm/arch/reset_manager.h> > #include <asm/arch/system_manager.h> > > -static const struct socfpga_reset_manager *reset_manager_base = > - (void *)SOCFPGA_RSTMGR_ADDRESS; > static const struct socfpga_system_manager *sysmgr_regs = > (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; > > /* Assert or de-assert SoCFPGA reset manager reset. */ > void socfpga_per_reset(u32 reset, int set) > { > - const u32 *reg; > + unsigned long reg; > u32 rstmgr_bank = RSTMGR_BANK(reset); > > switch (rstmgr_bank) { > case 0: > - reg = &reset_manager_base->mpu_mod_reset; > + reg = RSTMGR_GEN5_MPUMODRST; > break; > case 1: > - reg = &reset_manager_base->per_mod_reset; > + reg = RSTMGR_GEN5_PERMODRST; > break; > case 2: > - reg = &reset_manager_base->per2_mod_reset; > + reg = RSTMGR_GEN5_PER2MODRST; > break; > case 3: > - reg = &reset_manager_base->brg_mod_reset; > + reg = RSTMGR_GEN5_BRGMODRST; > break; > case 4: > - reg = &reset_manager_base->misc_mod_reset; > + reg = RSTMGR_GEN5_MISCMODRST; > break; > > default: > @@ -43,9 +41,11 @@ void socfpga_per_reset(u32 reset, int set) > } > > if (set) > - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + setbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > else > - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + clrbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > } > > /* > @@ -57,8 +57,8 @@ void socfpga_per_reset_all(void) > { > const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); > > - writel(~l4wd0, &reset_manager_base->per_mod_reset); > - writel(0xffffffff, &reset_manager_base->per2_mod_reset); > + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_GEN5_PERMODRST); > + writel(0xffffffff, socfpga_rstmgr_base + RSTMGR_GEN5_PER2MODRST); > } > > #define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 > @@ -95,7 +95,7 @@ void socfpga_bridges_reset(int enable) > > if (enable) { > /* brdmodrst */ > - writel(0x7, &reset_manager_base->brg_mod_reset); > + writel(0x7, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); > writel(L3REGS_REMAP_OCRAM_MASK, SOCFPGA_L3REGS_ADDRESS); > } else { > socfpga_bridges_set_handoff_regs(false, false, false); > @@ -109,7 +109,7 @@ void socfpga_bridges_reset(int enable) > } > > /* brdmodrst */ > - writel(0, &reset_manager_base->brg_mod_reset); > + writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); > > /* Remap the bridges into memory map */ > writel(l3mask, SOCFPGA_L3REGS_ADDRESS); > diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c > index 499a84aff5..b196d58d3d 100644 > --- a/arch/arm/mach-socfpga/reset_manager_s10.c > +++ b/arch/arm/mach-socfpga/reset_manager_s10.c > @@ -12,31 +12,31 @@ > > DECLARE_GLOBAL_DATA_PTR; > > -static const struct socfpga_reset_manager *reset_manager_base = > - (void *)SOCFPGA_RSTMGR_ADDRESS; > static const struct socfpga_system_manager *system_manager_base = > (void *)SOCFPGA_SYSMGR_ADDRESS; > > /* Assert or de-assert SoCFPGA reset manager reset. */ > void socfpga_per_reset(u32 reset, int set) > { > - const void *reg; > + unsigned long reg; > > if (RSTMGR_BANK(reset) == 0) > - reg = &reset_manager_base->mpumodrst; > + reg = RSTMGR_S10_MPUMODRST; > else if (RSTMGR_BANK(reset) == 1) > - reg = &reset_manager_base->per0modrst; > + reg = RSTMGR_S10_PER0MODRST; > else if (RSTMGR_BANK(reset) == 2) > - reg = &reset_manager_base->per1modrst; > + reg = RSTMGR_S10_PER1MODRST; > else if (RSTMGR_BANK(reset) == 3) > - reg = &reset_manager_base->brgmodrst; > + reg = RSTMGR_S10_BRGMODRST; > else /* Invalid reset register, do nothing */ > return; > > if (set) > - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + setbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > else > - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); > + clrbits_le32(socfpga_rstmgr_base + reg, > + 1 << RSTMGR_RESET(reset)); > } > > /* > @@ -50,9 +50,9 @@ void socfpga_per_reset_all(void) > > /* disable all except OCP and l4wd0. OCP disable later */ > writel(~(l4wd0 | RSTMGR_PER0MODRST_OCP_MASK), > - &reset_manager_base->per0modrst); > - writel(~l4wd0, &reset_manager_base->per0modrst); > - writel(0xffffffff, &reset_manager_base->per1modrst); > + socfpga_rstmgr_base + RSTMGR_S10_PER0MODRST); > + writel(~l4wd0, socfpga_rstmgr_base + RSTMGR_S10_PER0MODRST); > + writel(0xffffffff, socfpga_rstmgr_base + RSTMGR_S10_PER1MODRST); > } > > void socfpga_bridges_reset(int enable) > @@ -62,7 +62,7 @@ void socfpga_bridges_reset(int enable) > setbits_le32(&system_manager_base->noc_idlereq_clr, ~0); > > /* Release all bridges from reset state */ > - clrbits_le32(&reset_manager_base->brgmodrst, ~0); > + clrbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, ~0); > > /* Poll until all idleack to 0 */ > while (readl(&system_manager_base->noc_idleack)) > @@ -85,9 +85,9 @@ void socfpga_bridges_reset(int enable) > ; > > /* Reset all bridges (except NOR DDR scheduler & F2S) */ > - setbits_le32(&reset_manager_base->brgmodrst, > + setbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, > ~(RSTMGR_BRGMODRST_DDRSCH_MASK | > - RSTMGR_BRGMODRST_FPGA2SOC_MASK)); > + RSTMGR_BRGMODRST_FPGA2SOC_MASK)); > > /* Disable NOC timeout */ > writel(0, &system_manager_base->noc_timeout); > @@ -99,6 +99,6 @@ void socfpga_bridges_reset(int enable) > */ > int cpu_has_been_warmreset(void) > { > - return readl(&reset_manager_base->status) & > - RSTMGR_L4WD_MPU_WARMRESET_MASK; > + return readl(socfpga_rstmgr_base + RSTMGR_S10_STATUS) & > + RSTMGR_L4WD_MPU_WARMRESET_MASK; > } > diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c > index b820cb0673..a0d80fd47e 100644 > --- a/arch/arm/mach-socfpga/spl_a10.c > +++ b/arch/arm/mach-socfpga/spl_a10.c > @@ -106,6 +106,11 @@ void spl_board_init(void) > > void board_init_f(ulong dummy) > { > + if (spl_early_init()) > + hang(); > + > + socfpga_get_manager_addr(); > + > dcache_disable(); > > socfpga_init_security_policies(); > @@ -116,8 +121,6 @@ void board_init_f(ulong dummy) > socfpga_per_reset_all(); > socfpga_watchdog_disable(); > > - spl_early_init(); > - > /* Configure the clock based on handoff */ > cm_basic_init(gd->fdt_blob); > > diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c > index 47e63709ad..9ee053da3a 100644 > --- a/arch/arm/mach-socfpga/spl_gen5.c > +++ b/arch/arm/mach-socfpga/spl_gen5.c > @@ -67,6 +67,12 @@ void board_init_f(ulong dummy) > int ret; > struct udevice *dev; > > + ret = spl_early_init(); > + if (ret) > + hang(); > + > + socfpga_get_manager_addr(); > + > /* > * First C code to run. Clear fake OCRAM ECC first as SBE
Regards Ley Foon
> * and DBE might triggered during power on > @@ -128,12 +134,6 @@ void board_init_f(ulong dummy) > debug_uart_init(); > #endif > > - ret = spl_early_init(); > - if (ret) { > - debug("spl_early_init() failed: %d\n", ret); > - hang(); > - } > - > ret = uclass_get_device(UCLASS_RESET, 0, &dev); > if (ret) > debug("Reset init failed: %d\n", ret); > diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c > index ec65e1ce64..9a97a84e1e 100644 > --- a/arch/arm/mach-socfpga/spl_s10.c > +++ b/arch/arm/mach-socfpga/spl_s10.c > @@ -14,6 +14,7 @@ > #include <asm/arch/clock_manager.h> > #include <asm/arch/firewall_s10.h> > #include <asm/arch/mailbox_s10.h> > +#include <asm/arch/misc.h> > #include <asm/arch/reset_manager.h> > #include <asm/arch/system_manager.h> > #include <watchdog.h> > @@ -120,6 +121,12 @@ void board_init_f(ulong dummy) > const struct cm_config *cm_default_cfg = cm_get_default_config(); > int ret; > > + ret = spl_early_init(); > + if (ret) > + hang(); > + > + socfpga_get_manager_addr(); > + > #ifdef CONFIG_HW_WATCHDOG > /* Ensure watchdog is paused when debugging is happening */ > writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, &sysmgr_regs->wddbg); > @@ -145,11 +152,6 @@ void board_init_f(ulong dummy) > socfpga_per_reset(SOCFPGA_RESET(UART0), 0); > debug_uart_init(); > #endif > - ret = spl_early_init(); > - if (ret) { > - debug("spl_early_init() failed: %d\n", ret); > - hang(); > - } > > preloader_console_init(); > cm_print_clock_quick_summary(); > diff --git a/drivers/sysreset/sysreset_socfpga.c b/drivers/sysreset/sysreset_socfpga.c > index d6c26a5b23..3390b7bdc2 100644 > --- a/drivers/sysreset/sysreset_socfpga.c > +++ b/drivers/sysreset/sysreset_socfpga.c > @@ -12,7 +12,7 @@ > #include <asm/arch/reset_manager.h> > > struct socfpga_sysreset_data { > - struct socfpga_reset_manager *rstmgr_base; > + void __iomem *rstmgr_base; > }; > > static int socfpga_sysreset_request(struct udevice *dev, > @@ -23,11 +23,11 @@ static int socfpga_sysreset_request(struct udevice *dev, > switch (type) { > case SYSRESET_WARM: > writel(BIT(RSTMGR_CTRL_SWWARMRSTREQ_LSB), > - &data->rstmgr_base->ctrl); > + data->rstmgr_base + RSTMGR_CTRL); > break; > case SYSRESET_COLD: > writel(BIT(RSTMGR_CTRL_SWCOLDRSTREQ_LSB), > - &data->rstmgr_base->ctrl); > + data->rstmgr_base + RSTMGR_CTRL); > break; > default: > return -EPROTONOSUPPORT; >
Convert system manager for Gen5, Arria 10 and Stratix 10 from struct to defines.
Change to get system manager base address from DT node instead of using #define.
v2: - Revert to use writel(), readl() and etc. - Get base address from DT. - Add prefix to defines. --- arch/arm/mach-socfpga/clock_manager_s10.c | 4 +- .../include/mach/system_manager.h | 2 + .../include/mach/system_manager_arria10.h | 94 +++------ .../include/mach/system_manager_gen5.h | 123 +++--------- .../include/mach/system_manager_s10.h | 184 +++++++----------- arch/arm/mach-socfpga/mailbox_s10.c | 6 +- arch/arm/mach-socfpga/misc.c | 5 + arch/arm/mach-socfpga/misc_arria10.c | 9 +- arch/arm/mach-socfpga/misc_gen5.c | 22 ++- arch/arm/mach-socfpga/misc_s10.c | 9 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 24 +-- arch/arm/mach-socfpga/reset_manager_gen5.c | 7 +- arch/arm/mach-socfpga/reset_manager_s10.c | 18 +- arch/arm/mach-socfpga/scan_manager.c | 6 +- arch/arm/mach-socfpga/spl_a10.c | 5 +- arch/arm/mach-socfpga/spl_gen5.c | 11 +- arch/arm/mach-socfpga/spl_s10.c | 12 +- arch/arm/mach-socfpga/system_manager_gen5.c | 38 ++-- arch/arm/mach-socfpga/system_manager_s10.c | 39 ++-- arch/arm/mach-socfpga/wrap_pll_config_s10.c | 11 +- drivers/ddr/altera/sdram_gen5.c | 10 +- drivers/ddr/altera/sdram_s10.c | 6 +- drivers/fpga/socfpga_arria10.c | 7 +- drivers/fpga/socfpga_gen5.c | 4 +- drivers/mmc/socfpga_dw_mmc.c | 6 +- 25 files changed, 240 insertions(+), 422 deletions(-)
diff --git a/arch/arm/mach-socfpga/clock_manager_s10.c b/arch/arm/mach-socfpga/clock_manager_s10.c index 3ba2a00c02..6cbf07ac6f 100644 --- a/arch/arm/mach-socfpga/clock_manager_s10.c +++ b/arch/arm/mach-socfpga/clock_manager_s10.c @@ -14,8 +14,6 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; -static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/* * function to write the bypass register which requires a poll of the @@ -351,7 +349,7 @@ unsigned int cm_get_l4_sp_clk_hz(void)
unsigned int cm_get_qspi_controller_clk_hz(void) { - return readl(&sysmgr_regs->boot_scratch_cold0); + return readl(socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD0); }
unsigned int cm_get_spi_controller_clk_hz(void) diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 7e76df74b7..803305eb35 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -6,6 +6,8 @@ #ifndef _SYSTEM_MANAGER_H_ #define _SYSTEM_MANAGER_H_
+extern phys_addr_t socfpga_sysmgr_base; + #if defined(CONFIG_TARGET_SOCFPGA_STRATIX10) #include <asm/arch/system_manager_s10.h> #else diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h index 14052b957c..1a45c0f134 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_arria10.h @@ -6,73 +6,33 @@ #ifndef _SYSTEM_MANAGER_ARRIA10_H_ #define _SYSTEM_MANAGER_ARRIA10_H_
-struct socfpga_system_manager { - u32 siliconid1; - u32 siliconid2; - u32 wddbg; - u32 bootinfo; - u32 mpu_ctrl_l2_ecc; - u32 _pad_0x14_0x1f[3]; - u32 dma; - u32 dma_periph; - u32 sdmmcgrp_ctrl; - u32 sdmmc_l3master; - u32 nand_bootstrap; - u32 nand_l3master; - u32 usb0_l3master; - u32 usb1_l3master; - u32 emac_global; - u32 emac[3]; - u32 _pad_0x50_0x5f[4]; - u32 fpgaintf_en_global; - u32 fpgaintf_en_0; - u32 fpgaintf_en_1; - u32 fpgaintf_en_2; - u32 fpgaintf_en_3; - u32 _pad_0x74_0x7f[3]; - u32 noc_addr_remap_value; - u32 noc_addr_remap_set; - u32 noc_addr_remap_clear; - u32 _pad_0x8c_0x8f; - u32 ecc_intmask_value; - u32 ecc_intmask_set; - u32 ecc_intmask_clr; - u32 ecc_intstatus_serr; - u32 ecc_intstatus_derr; - u32 mpu_status_l2_ecc; - u32 mpu_clear_l2_ecc; - u32 mpu_status_l1_parity; - u32 mpu_clear_l1_parity; - u32 mpu_set_l1_parity; - u32 _pad_0xb8_0xbf[2]; - u32 noc_timeout; - u32 noc_idlereq_set; - u32 noc_idlereq_clr; - u32 noc_idlereq_value; - u32 noc_idleack; - u32 noc_idlestatus; - u32 fpga2soc_ctrl; - u32 _pad_0xdc_0xff[9]; - u32 tsmc_tsel_0; - u32 tsmc_tsel_1; - u32 tsmc_tsel_2; - u32 tsmc_tsel_3; - u32 _pad_0x110_0x200[60]; - u32 romhw_ctrl; - u32 romcode_ctrl; - u32 romcode_cpu1startaddr; - u32 romcode_initswstate; - u32 romcode_initswlastld; - u32 _pad_0x214_0x217; - u32 warmram_enable; - u32 warmram_datastart; - u32 warmram_length; - u32 warmram_execution; - u32 warmram_crc; - u32 _pad_0x22c_0x22f; - u32 isw_handoff[8]; - u32 romcode_bootromswstate[8]; -}; +#define SYSMGR_A10_WDDBG 0x8 +#define SYSMGR_A10_BOOTINFO 0xc +#define SYSMGR_A10_DMA 0x20 +#define SYSMGR_A10_DMA_PERIPH 0x24 +#define SYSMGR_A10_SDMMC 0x28 +#define SYSMGR_A10_SDMMC_L3MASTER 0x2c +#define SYSMGR_A10_EMAC_GLOBAL 0x40 +#define SYSMGR_A10_EMAC0 0x44 +#define SYSMGR_A10_EMAC1 0x48 +#define SYSMGR_A10_EMAC2 0x4c +#define SYSMGR_A10_FPGAINTF_EN_GLOBAL 0x60 +#define SYSMGR_A10_FPGAINTF_EN0 0x64 +#define SYSMGR_A10_FPGAINTF_EN1 0x68 +#define SYSMGR_A10_FPGAINTF_EN2 0x6c +#define SYSMGR_A10_FPGAINTF_EN3 0x70 +#define SYSMGR_A10_ECC_INTMASK_VAL 0x90 +#define SYSMGR_A10_ECC_INTMASK_SET 0x94 +#define SYSMGR_A10_ECC_INTMASK_CLR 0x98 +#define SYSMGR_A10_NOC_TIMEOUT 0xc0 +#define SYSMGR_A10_NOC_IDLEREQ_SET 0xc4 +#define SYSMGR_A10_NOC_IDLEREQ_CLR 0xc8 +#define SYSMGR_A10_NOC_IDLEREQ_VAL 0xcc +#define SYSMGR_A10_NOC_IDLEACK 0xd0 +#define SYSMGR_A10_NOC_IDLESTATUS 0xd4 +#define SYSMGR_A10_FPGA2SOC_CTRL 0xd8 + +#define SYSMGR_SDMMC SYSMGR_A10_SDMMC
#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 #define SYSMGR_BOOTINFO_BSEL_SHIFT 12 diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h index 52e59df513..90cb465d13 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_gen5.h @@ -13,106 +13,29 @@ void sysmgr_config_warmrstcfgio(int enable);
void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len);
-struct socfpga_system_manager { - /* System Manager Module */ - u32 siliconid1; /* 0x00 */ - u32 siliconid2; - u32 _pad_0x8_0xf[2]; - u32 wddbg; /* 0x10 */ - u32 bootinfo; - u32 hpsinfo; - u32 parityinj; - /* FPGA Interface Group */ - u32 fpgaintfgrp_gbl; /* 0x20 */ - u32 fpgaintfgrp_indiv; - u32 fpgaintfgrp_module; - u32 _pad_0x2c_0x2f; - /* Scan Manager Group */ - u32 scanmgrgrp_ctrl; /* 0x30 */ - u32 _pad_0x34_0x3f[3]; - /* Freeze Control Group */ - u32 frzctrl_vioctrl; /* 0x40 */ - u32 _pad_0x44_0x4f[3]; - u32 frzctrl_hioctrl; /* 0x50 */ - u32 frzctrl_src; - u32 frzctrl_hwctrl; - u32 _pad_0x5c_0x5f; - /* EMAC Group */ - u32 emacgrp_ctrl; /* 0x60 */ - u32 emacgrp_l3master; - u32 _pad_0x68_0x6f[2]; - /* DMA Controller Group */ - u32 dmagrp_ctrl; /* 0x70 */ - u32 dmagrp_persecurity; - u32 _pad_0x78_0x7f[2]; - /* Preloader (initial software) Group */ - u32 iswgrp_handoff[8]; /* 0x80 */ - u32 _pad_0xa0_0xbf[8]; /* 0xa0 */ - /* Boot ROM Code Register Group */ - u32 romcodegrp_ctrl; /* 0xc0 */ - u32 romcodegrp_cpu1startaddr; - u32 romcodegrp_initswstate; - u32 romcodegrp_initswlastld; - u32 romcodegrp_bootromswstate; /* 0xd0 */ - u32 __pad_0xd4_0xdf[3]; - /* Warm Boot from On-Chip RAM Group */ - u32 romcodegrp_warmramgrp_enable; /* 0xe0 */ - u32 romcodegrp_warmramgrp_datastart; - u32 romcodegrp_warmramgrp_length; - u32 romcodegrp_warmramgrp_execution; - u32 romcodegrp_warmramgrp_crc; /* 0xf0 */ - u32 __pad_0xf4_0xff[3]; - /* Boot ROM Hardware Register Group */ - u32 romhwgrp_ctrl; /* 0x100 */ - u32 _pad_0x104_0x107; - /* SDMMC Controller Group */ - u32 sdmmcgrp_ctrl; - u32 sdmmcgrp_l3master; - /* NAND Flash Controller Register Group */ - u32 nandgrp_bootstrap; /* 0x110 */ - u32 nandgrp_l3master; - /* USB Controller Group */ - u32 usbgrp_l3master; - u32 _pad_0x11c_0x13f[9]; - /* ECC Management Register Group */ - u32 eccgrp_l2; /* 0x140 */ - u32 eccgrp_ocram; - u32 eccgrp_usb0; - u32 eccgrp_usb1; - u32 eccgrp_emac0; /* 0x150 */ - u32 eccgrp_emac1; - u32 eccgrp_dma; - u32 eccgrp_can0; - u32 eccgrp_can1; /* 0x160 */ - u32 eccgrp_nand; - u32 eccgrp_qspi; - u32 eccgrp_sdmmc; - u32 _pad_0x170_0x3ff[164]; - /* Pin Mux Control Group */ - u32 emacio[20]; /* 0x400 */ - u32 flashio[12]; /* 0x450 */ - u32 generalio[28]; /* 0x480 */ - u32 _pad_0x4f0_0x4ff[4]; - u32 mixed1io[22]; /* 0x500 */ - u32 mixed2io[8]; /* 0x558 */ - u32 gplinmux[23]; /* 0x578 */ - u32 gplmux[71]; /* 0x5d4 */ - u32 nandusefpga; /* 0x6f0 */ - u32 _pad_0x6f4; - u32 rgmii1usefpga; /* 0x6f8 */ - u32 _pad_0x6fc_0x700[2]; - u32 i2c0usefpga; /* 0x704 */ - u32 sdmmcusefpga; /* 0x708 */ - u32 _pad_0x70c_0x710[2]; - u32 rgmii0usefpga; /* 0x714 */ - u32 _pad_0x718_0x720[3]; - u32 i2c3usefpga; /* 0x724 */ - u32 i2c2usefpga; /* 0x728 */ - u32 i2c1usefpga; /* 0x72c */ - u32 spim1usefpga; /* 0x730 */ - u32 _pad_0x734; - u32 spim0usefpga; /* 0x738 */ -}; +#define SYSMGR_GEN5_WDDBG 0x10 +#define SYSMGR_GEN5_BOOTINFO 0x14 +#define SYSMGR_GEN5_FPGAINFGRP_GBL 0x20 +#define SYSMGR_GEN5_FPGAINFGRP_INDIV 0x24 +#define SYSMGR_GEN5_FPGAINFGRP_MODULE 0x28 +#define SYSMGR_GEN5_SCANMGRGRP_CTRL 0x30 +#define SYSMGR_GEN5_ISWGRP_HANDOFF 0x80 +#define SYSMGR_GEN5_ROMCODEGRP_CTRL 0xc0 +#define SYSMGR_GEN5_WARMRAMGRP_EN 0xe0 +#define SYSMGR_GEN5_SDMMC 0x108 +#define SYSMGR_GEN5_ECCGRP_OCRAM 0x144 +#define SYSMGR_GEN5_EMACIO 0x400 +#define SYSMGR_GEN5_NAND_USEFPGA 0x6f0 +#define SYSMGR_GEN5_RGMII0_USEFPGA 0x6f8 +#define SYSMGR_GEN5_SDMMC_USEFPGA 0x708 +#define SYSMGR_GEN5_RGMII1_USEFPGA 0x704 +#define SYSMGR_GEN5_SPIM1_USEFPGA 0x730 +#define SYSMGR_GEN5_SPIM0_USEFPGA 0x738 + +#define SYSMGR_SDMMC SYSMGR_GEN5_SDMMC + +#define SYSMGR_ISWGRP_HANDOFF_OFFSET(i) \ + SYSMGR_GEN5_ISWGRP_HANDOFF + ((i) * sizeof(u32)) #endif
#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_s10.h b/arch/arm/mach-socfpga/include/mach/system_manager_s10.h index 297f9e1999..e68a8e730e 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager_s10.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_s10.h @@ -15,125 +15,73 @@ void sysmgr_pinmux_table_ctrl(const u32 **table, unsigned int *table_len); void sysmgr_pinmux_table_fpga(const u32 **table, unsigned int *table_len); void sysmgr_pinmux_table_delay(const u32 **table, unsigned int *table_len);
-struct socfpga_system_manager { - /* System Manager Module */ - u32 siliconid1; /* 0x00 */ - u32 siliconid2; - u32 wddbg; - u32 _pad_0xc; - u32 mpu_status; /* 0x10 */ - u32 mpu_ace; - u32 _pad_0x18_0x1c[2]; - u32 dma; /* 0x20 */ - u32 dma_periph; - /* SDMMC Controller Group */ - u32 sdmmcgrp_ctrl; - u32 sdmmcgrp_l3master; - /* NAND Flash Controller Register Group */ - u32 nandgrp_bootstrap; /* 0x30 */ - u32 nandgrp_l3master; - /* USB Controller Group */ - u32 usb0_l3master; - u32 usb1_l3master; - /* EMAC Group */ - u32 emac_gbl; /* 0x40 */ - u32 emac0; - u32 emac1; - u32 emac2; - u32 emac0_ace; /* 0x50 */ - u32 emac1_ace; - u32 emac2_ace; - u32 nand_axuser; - u32 _pad_0x60_0x64[2]; /* 0x60 */ - /* FPGA interface Group */ - u32 fpgaintf_en_1; - u32 fpgaintf_en_2; - u32 fpgaintf_en_3; /* 0x70 */ - u32 dma_l3master; - u32 etr_l3master; - u32 _pad_0x7c; - u32 sec_ctrl_slt; /* 0x80 */ - u32 osc_trim; - u32 _pad_0x88_0x8c[2]; - /* ECC Group */ - u32 ecc_intmask_value; /* 0x90 */ - u32 ecc_intmask_set; - u32 ecc_intmask_clr; - u32 ecc_intstatus_serr; - u32 ecc_intstatus_derr; /* 0xa0 */ - u32 _pad_0xa4_0xac[3]; - u32 noc_addr_remap; /* 0xb0 */ - u32 hmc_clk; - u32 io_pa_ctrl; - u32 _pad_0xbc; - /* NOC Group */ - u32 noc_timeout; /* 0xc0 */ - u32 noc_idlereq_set; - u32 noc_idlereq_clr; - u32 noc_idlereq_value; - u32 noc_idleack; /* 0xd0 */ - u32 noc_idlestatus; - u32 fpga2soc_ctrl; - u32 fpga_config; - u32 iocsrclk_gate; /* 0xe0 */ - u32 gpo; - u32 gpi; - u32 _pad_0xec; - u32 mpu; /* 0xf0 */ - u32 sdm_hps_spare; - u32 hps_sdm_spare; - u32 _pad_0xfc_0x1fc[65]; - /* Boot scratch register group */ - u32 boot_scratch_cold0; /* 0x200 */ - u32 boot_scratch_cold1; - u32 boot_scratch_cold2; - u32 boot_scratch_cold3; - u32 boot_scratch_cold4; /* 0x210 */ - u32 boot_scratch_cold5; - u32 boot_scratch_cold6; - u32 boot_scratch_cold7; - u32 boot_scratch_cold8; /* 0x220 */ - u32 boot_scratch_cold9; - u32 _pad_0x228_0xffc[886]; - /* Pin select and pin control group */ - u32 pinsel0[40]; /* 0x1000 */ - u32 _pad_0x10a0_0x10fc[24]; - u32 pinsel40[8]; - u32 _pad_0x1120_0x112c[4]; - u32 ioctrl0[28]; - u32 _pad_0x11a0_0x11fc[24]; - u32 ioctrl28[20]; - u32 _pad_0x1250_0x12fc[44]; - /* Use FPGA mux */ - u32 rgmii0usefpga; /* 0x1300 */ - u32 rgmii1usefpga; - u32 rgmii2usefpga; - u32 i2c0usefpga; - u32 i2c1usefpga; - u32 i2c_emac0_usefpga; - u32 i2c_emac1_usefpga; - u32 i2c_emac2_usefpga; - u32 nandusefpga; - u32 _pad_0x1324; - u32 spim0usefpga; - u32 spim1usefpga; - u32 spis0usefpga; - u32 spis1usefpga; - u32 uart0usefpga; - u32 uart1usefpga; - u32 mdio0usefpga; - u32 mdio1usefpga; - u32 mdio2usefpga; - u32 _pad_0x134c; - u32 jtagusefpga; - u32 sdmmcusefpga; - u32 hps_osc_clk; - u32 _pad_0x135c_0x13fc[41]; - u32 iodelay0[40]; - u32 _pad_0x14a0_0x14fc[24]; - u32 iodelay40[8]; +#define SYSMGR_S10_WDDBG 0x8 +#define SYSMGR_S10_DMA 0x20 +#define SYSMGR_S10_DMA_PERIPH 0x24 +#define SYSMGR_S10_SDMMC 0x28 +#define SYSMGR_S10_SDMMC_L3MASTER 0x2c +#define SYSMGR_S10_EMAC_GLOBAL 0x40 +#define SYSMGR_S10_EMAC0 0x44 +#define SYSMGR_S10_EMAC1 0x48 +#define SYSMGR_S10_EMAC2 0x4c +#define SYSMGR_S10_EMAC0_ACE 0x50 +#define SYSMGR_S10_EMAC1_ACE 0x54 +#define SYSMGR_S10_EMAC2_ACE 0x58 +#define SYSMGR_S10_NAND_AXUSER 0x5c +#define SYSMGR_S10_FPGAINTF_EN1 0x68 +#define SYSMGR_S10_FPGAINTF_EN2 0x6c +#define SYSMGR_S10_FPGAINTF_EN3 0x70 +#define SYSMGR_S10_DMA_L3MASTER 0x74 +#define SYSMGR_S10_HMC_CLK 0xb4 +#define SYSMGR_S10_IO_PA_CTRL 0xb8 +#define SYSMGR_S10_NOC_TIMEOUT 0xc0 +#define SYSMGR_S10_NOC_IDLEREQ_SET 0xc4 +#define SYSMGR_S10_NOC_IDLEREQ_CLR 0xc8 +#define SYSMGR_S10_NOC_IDLEREQ_VAL 0xcc +#define SYSMGR_S10_NOC_IDLEACK 0xd0 +#define SYSMGR_S10_NOC_IDLESTATUS 0xd4 +#define SYSMGR_S10_FPGA2SOC_CTRL 0xd8 +#define SYSMGR_S10_FPGA_CONFIG 0xdc +#define SYSMGR_S10_IOCSRCLK_GATE 0xe0 +#define SYSMGR_S10_GPO 0xe4 +#define SYSMGR_S10_GPI 0xe8 +#define SYSMGR_S10_MPU 0xf0 +#define SYSMGR_S10_BOOT_SCRATCH_COLD0 0x200 +#define SYSMGR_S10_BOOT_SCRATCH_COLD1 0x204 +#define SYSMGR_S10_BOOT_SCRATCH_COLD2 0x208 +#define SYSMGR_S10_BOOT_SCRATCH_COLD3 0x20c +#define SYSMGR_S10_BOOT_SCRATCH_COLD4 0x210 +#define SYSMGR_S10_BOOT_SCRATCH_COLD5 0x214 +#define SYSMGR_S10_BOOT_SCRATCH_COLD6 0x218 +#define SYSMGR_S10_BOOT_SCRATCH_COLD7 0x21c +#define SYSMGR_S10_BOOT_SCRATCH_COLD8 0x220 +#define SYSMGR_S10_BOOT_SCRATCH_COLD9 0x224 +#define SYSMGR_S10_PINSEL0 0x1000 +#define SYSMGR_S10_IOCTRL0 0x1130 +#define SYSMGR_S10_EMAC0_USEFPGA 0x1300 +#define SYSMGR_S10_EMAC1_USEFPGA 0x1304 +#define SYSMGR_S10_EMAC2_USEFPGA 0x1308 +#define SYSMGR_S10_I2C0_USEFPGA 0x130c +#define SYSMGR_S10_I2C1_USEFPGA 0x1310 +#define SYSMGR_S10_I2C_EMAC0_USEFPGA 0x1314 +#define SYSMGR_S10_I2C_EMAC1_USEFPGA 0x1318 +#define SYSMGR_S10_I2C_EMAC2_USEFPGA 0x131c +#define SYSMGR_S10_NAND_USEFPGA 0x1320 +#define SYSMGR_S10_SPIM0_USEFPGA 0x1328 +#define SYSMGR_S10_SPIM1_USEFPGA 0x132c +#define SYSMGR_S10_SPIS0_USEFPGA 0x1330 +#define SYSMGR_S10_SPIS1_USEFPGA 0x1334 +#define SYSMGR_S10_UART0_USEFPGA 0x1338 +#define SYSMGR_S10_UART1_USEFPGA 0x133c +#define SYSMGR_S10_MDIO0_USEFPGA 0x1340 +#define SYSMGR_S10_MDIO1_USEFPGA 0x1344 +#define SYSMGR_S10_MDIO2_USEFPGA 0x1348 +#define SYSMGR_S10_JTAG_USEFPGA 0x1350 +#define SYSMGR_S10_SDMMC_USEFPGA 0x1354 +#define SYSMGR_S10_HPS_OSC_CLK 0x1358 +#define SYSMGR_S10_IODELAY0 0x1400
-}; +#define SYSMGR_SDMMC SYSMGR_S10_SDMMC
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX BIT(0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO BIT(1) diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 4498ab55df..11b57361c7 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -287,9 +287,6 @@ int mbox_qspi_close(void)
int mbox_qspi_open(void) { - static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - int ret; u32 resp_buf[1]; u32 resp_buf_len; @@ -318,7 +315,8 @@ int mbox_qspi_open(void)
/* We are getting QSPI ref clock and set into sysmgr boot register */ printf("QSPI: Reference clock at %d Hz\n", resp_buf[0]); - writel(resp_buf[0], &sysmgr_regs->boot_scratch_cold0); + writel(resp_buf[0], + socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD0);
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 901c432f82..fcc53b6fbc 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -23,6 +23,7 @@ DECLARE_GLOBAL_DATA_PTR;
phys_addr_t socfpga_rstmgr_base __section(".data"); +phys_addr_t socfpga_sysmgr_base __section(".data");
#ifdef CONFIG_SYS_L2_PL310 static const struct pl310_regs *const pl310 = @@ -233,4 +234,8 @@ void socfpga_get_manager_addr(void) socfpga_rstmgr_base = socfpga_get_base_addr("altr,rst-mgr"); if (!socfpga_rstmgr_base) hang(); + + socfpga_sysmgr_base = socfpga_get_base_addr("altr,sys-mgr"); + if (!socfpga_sysmgr_base) + hang(); } diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c index 2e2a40b65d..ff6ab83441 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -28,9 +28,6 @@ #define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 0x78 #define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 0x98
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - /* * FPGA programming support for SoC FPGA Arria 10 */ @@ -81,7 +78,7 @@ void socfpga_init_security_policies(void) writel(~0, SOCFPGA_NOC_FW_H2F_SCR_OFST); writel(~0, SOCFPGA_NOC_FW_H2F_SCR_OFST + 4);
- writel(0x0007FFFF, &sysmgr_regs->ecc_intmask_set); + writel(0x0007FFFF, socfpga_sysmgr_base + SYSMGR_A10_ECC_INTMASK_SET); }
void socfpga_sdram_remap_zero(void) @@ -105,8 +102,8 @@ int arch_early_init_r(void) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - const u32 bsel = - SYSMGR_GET_BOOTINFO_BSEL(readl(&sysmgr_regs->bootinfo)); + u32 bootinfo = readl(socfpga_sysmgr_base + SYSMGR_A10_BOOTINFO); + const u32 bsel = SYSMGR_GET_BOOTINFO_BSEL(bootinfo);
puts("CPU: Altera SoCFPGA Arria 10\n");
diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index b39a66562d..7735958e9c 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -28,8 +28,6 @@ DECLARE_GLOBAL_DATA_PTR;
static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; static struct scu_registers *scu_regs = @@ -118,8 +116,8 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - const u32 bsel = - SYSMGR_GET_BOOTINFO_BSEL(readl(&sysmgr_regs->bootinfo)); + u32 bootinfo = readl(socfpga_sysmgr_base + SYSMGR_GEN5_BOOTINFO); + const u32 bsel = SYSMGR_GET_BOOTINFO_BSEL(bootinfo);
puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); @@ -132,7 +130,8 @@ int print_cpuinfo(void) #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) { - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; + const u32 bsel = readl(socfpga_sysmgr_base + + SYSMGR_GEN5_BOOTINFO) & 0x7; const int fpga_id = socfpga_fpga_id(0); env_set("bootmode", bsel_str[bsel].mode); if (fpga_id >= 0) @@ -190,10 +189,11 @@ int arch_early_init_r(void) * to support that old code, we write it here instead of in the * reset_cpu() function just before resetting the CPU. */ - writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable); + writel(0xae9efebc, socfpga_sysmgr_base + SYSMGR_GEN5_WARMRAMGRP_EN);
for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ - iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]); + iswgrp_handoff[i] = readl(socfpga_sysmgr_base + + SYSMGR_ISWGRP_HANDOFF_OFFSET(i));
socfpga_bridges_reset(1);
@@ -219,16 +219,18 @@ void do_bridge_reset(int enable, unsigned int mask) !(mask & BIT(2))); for (i = 0; i < 2; i++) { /* Reload SW setting cache */ iswgrp_handoff[i] = - readl(&sysmgr_regs->iswgrp_handoff[i]); + readl(socfpga_sysmgr_base + + SYSMGR_ISWGRP_HANDOFF_OFFSET(i)); }
- writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); + writel(iswgrp_handoff[2], + socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE); writel(iswgrp_handoff[3], &sdr_ctrl->fpgaport_rst); writel(iswgrp_handoff[0], socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(iswgrp_handoff[1], &nic301_regs->remap); } else { - writel(0, &sysmgr_regs->fpgaintfgrp_module); + writel(0, socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE); writel(0, &sdr_ctrl->fpgaport_rst); writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(1, &nic301_regs->remap); diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 0a5fab11c0..16fbf71599 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -23,9 +23,6 @@
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - /* * FPGA programming support for SoC FPGA Stratix 10 */ @@ -68,9 +65,9 @@ static u32 socfpga_phymode_setup(u32 gmac_index, const char *phymode) else return -EINVAL;
- clrsetbits_le32(&sysmgr_regs->emac0 + gmac_index, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, - modereg); + clrsetbits_le32((unsigned long)(socfpga_sysmgr_base + SYSMGR_S10_EMAC0 + + gmac_index), + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, modereg);
return 0; } diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index 4553653992..5611e784e6 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -15,9 +15,6 @@
-static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - struct bridge_cfg { int compat_id; u32 mask_noc; @@ -98,14 +95,16 @@ int socfpga_reset_deassert_bridges_handoff(void) }
/* clear idle request to all bridges */ - setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); + setbits_le32(socfpga_sysmgr_base + SYSMGR_A10_NOC_IDLEREQ_CLR, + mask_noc);
/* Release bridges from reset state per handoff value */ clrbits_le32(socfpga_rstmgr_base + RSTMGR_A10_BRGMODRST, mask_rstmgr);
/* Poll until all idleack to 0, timeout at 1000ms */ - return wait_for_bit_le32(&sysmgr_regs->noc_idleack, mask_noc, - false, 1000, false); + return wait_for_bit_le32((const void *)(socfpga_sysmgr_base + + SYSMGR_A10_NOC_IDLEACK), + mask_noc, false, 1000, false); }
/* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ @@ -195,13 +194,15 @@ int socfpga_bridges_reset(void) ALT_SYSMGR_NOC_F2SDR0_SET_MSK | ALT_SYSMGR_NOC_F2SDR1_SET_MSK | ALT_SYSMGR_NOC_F2SDR2_SET_MSK, - &sysmgr_regs->noc_idlereq_set); + socfpga_sysmgr_base + SYSMGR_A10_NOC_IDLEREQ_SET);
/* Enable the NOC timeout */ - writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, &sysmgr_regs->noc_timeout); + writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, + socfpga_sysmgr_base + SYSMGR_A10_NOC_TIMEOUT);
/* Poll until all idleack to 1 */ - ret = wait_for_bit_le32(&sysmgr_regs->noc_idleack, + ret = wait_for_bit_le32((const void *)(socfpga_sysmgr_base + + SYSMGR_A10_NOC_IDLEACK), ALT_SYSMGR_NOC_H2F_SET_MSK | ALT_SYSMGR_NOC_LWH2F_SET_MSK | ALT_SYSMGR_NOC_F2H_SET_MSK | @@ -213,7 +214,8 @@ int socfpga_bridges_reset(void) return ret;
/* Poll until all idlestatus to 1 */ - ret = wait_for_bit_le32(&sysmgr_regs->noc_idlestatus, + ret = wait_for_bit_le32((const void *)(socfpga_sysmgr_base + + SYSMGR_A10_NOC_IDLESTATUS), ALT_SYSMGR_NOC_H2F_SET_MSK | ALT_SYSMGR_NOC_LWH2F_SET_MSK | ALT_SYSMGR_NOC_F2H_SET_MSK | @@ -234,7 +236,7 @@ int socfpga_bridges_reset(void) ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK));
/* Disable NOC timeout */ - writel(0, &sysmgr_regs->noc_timeout); + writel(0, socfpga_sysmgr_base + SYSMGR_A10_NOC_TIMEOUT);
return 0; } diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c index ad31214711..6b617fd016 100644 --- a/arch/arm/mach-socfpga/reset_manager_gen5.c +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -10,9 +10,6 @@ #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
-static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - /* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { @@ -83,8 +80,8 @@ void socfpga_bridges_set_handoff_regs(bool h2f, bool lwh2f, bool f2h) if (f2h) brgmask |= BIT(2);
- writel(brgmask, &sysmgr_regs->iswgrp_handoff[0]); - writel(l3rmask, &sysmgr_regs->iswgrp_handoff[1]); + writel(brgmask, socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(0)); + writel(l3rmask, socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(1)); }
void socfpga_bridges_reset(int enable) diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c index b196d58d3d..50a2d80930 100644 --- a/arch/arm/mach-socfpga/reset_manager_s10.c +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -12,9 +12,6 @@
-static const struct socfpga_system_manager *system_manager_base = - (void *)SOCFPGA_SYSMGR_ADDRESS; - /* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { @@ -59,28 +56,29 @@ void socfpga_bridges_reset(int enable) { if (enable) { /* clear idle request to all bridges */ - setbits_le32(&system_manager_base->noc_idlereq_clr, ~0); + setbits_le32(socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLEREQ_CLR, + ~0);
/* Release all bridges from reset state */ clrbits_le32(socfpga_rstmgr_base + RSTMGR_S10_BRGMODRST, ~0);
/* Poll until all idleack to 0 */ - while (readl(&system_manager_base->noc_idleack)) + while (readl(socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLEACK)) ; } else { /* set idle request to all bridges */ - writel(~0, &system_manager_base->noc_idlereq_set); + writel(~0, socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLEREQ_SET);
/* Enable the NOC timeout */ - writel(1, &system_manager_base->noc_timeout); + writel(1, socfpga_sysmgr_base + SYSMGR_S10_NOC_TIMEOUT);
/* Poll until all idleack to 1 */ - while ((readl(&system_manager_base->noc_idleack) ^ + while ((readl(socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLEACK) ^ (SYSMGR_NOC_H2F_MSK | SYSMGR_NOC_LWH2F_MSK))) ;
/* Poll until all idlestatus to 1 */ - while ((readl(&system_manager_base->noc_idlestatus) ^ + while ((readl(socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLESTATUS) ^ (SYSMGR_NOC_H2F_MSK | SYSMGR_NOC_LWH2F_MSK))) ;
@@ -90,7 +88,7 @@ void socfpga_bridges_reset(int enable) RSTMGR_BRGMODRST_FPGA2SOC_MASK));
/* Disable NOC timeout */ - writel(0, &system_manager_base->noc_timeout); + writel(0, socfpga_sysmgr_base + SYSMGR_S10_NOC_TIMEOUT); } }
diff --git a/arch/arm/mach-socfpga/scan_manager.c b/arch/arm/mach-socfpga/scan_manager.c index 52175af48b..f1d5f69caa 100644 --- a/arch/arm/mach-socfpga/scan_manager.c +++ b/arch/arm/mach-socfpga/scan_manager.c @@ -31,8 +31,6 @@ static const struct socfpga_scan_manager *scan_manager_base = (void *)(SOCFPGA_SCANMGR_ADDRESS); static const struct socfpga_freeze_controller *freeze_controller_base = (void *)(SOCFPGA_SYSMGR_ADDRESS + SYSMGR_FRZCTRL_ADDRESS); -static struct socfpga_system_manager *sys_mgr_base = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/** * scan_chain_engine_is_idle() - Check if the JTAG scan chain is idle @@ -218,7 +216,7 @@ u32 scan_mgr_get_fpga_id(void) int ret;
/* Enable HPS to talk to JTAG in the FPGA through the System Manager */ - writel(0x1, &sys_mgr_base->scanmgrgrp_ctrl); + writel(0x1, socfpga_sysmgr_base + SYSMGR_GEN5_SCANMGRGRP_CTRL);
/* Enable port 7 */ writel(0x80, &scan_manager_base->en); @@ -253,7 +251,7 @@ u32 scan_mgr_get_fpga_id(void)
/* Disable all port */ writel(0, &scan_manager_base->en); - writel(0, &sys_mgr_base->scanmgrgrp_ctrl); + writel(0, socfpga_sysmgr_base + SYSMGR_GEN5_SCANMGRGRP_CTRL);
return id; } diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index a0d80fd47e..ee811e4ee9 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -31,12 +31,9 @@
-static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - u32 spl_boot_device(void) { - const u32 bsel = readl(&sysmgr_regs->bootinfo); + const u32 bsel = readl(socfpga_sysmgr_base + SYSMGR_A10_BOOTINFO);
switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 9ee053da3a..82d9fe0824 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -24,12 +24,9 @@
-static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - u32 spl_boot_device(void) { - const u32 bsel = readl(&sysmgr_regs->bootinfo); + const u32 bsel = readl(socfpga_sysmgr_base + SYSMGR_GEN5_BOOTINFO);
switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ @@ -77,13 +74,13 @@ void board_init_f(ulong dummy) * First C code to run. Clear fake OCRAM ECC first as SBE * and DBE might triggered during power on */ - reg = readl(&sysmgr_regs->eccgrp_ocram); + reg = readl(socfpga_sysmgr_base + SYSMGR_GEN5_ECCGRP_OCRAM); if (reg & SYSMGR_ECC_OCRAM_SERR) writel(SYSMGR_ECC_OCRAM_SERR | SYSMGR_ECC_OCRAM_EN, - &sysmgr_regs->eccgrp_ocram); + socfpga_sysmgr_base + SYSMGR_GEN5_ECCGRP_OCRAM); if (reg & SYSMGR_ECC_OCRAM_DERR) writel(SYSMGR_ECC_OCRAM_DERR | SYSMGR_ECC_OCRAM_EN, - &sysmgr_regs->eccgrp_ocram); + socfpga_sysmgr_base + SYSMGR_GEN5_ECCGRP_OCRAM);
socfpga_sdram_remap_zero(); socfpga_pl310_clear(); diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index 9a97a84e1e..16f19f901d 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -22,9 +22,6 @@
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - u32 spl_boot_device(void) { /* TODO: Get from SDM or handoff */ @@ -129,7 +126,8 @@ void board_init_f(ulong dummy)
#ifdef CONFIG_HW_WATCHDOG /* Ensure watchdog is paused when debugging is happening */ - writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, &sysmgr_regs->wddbg); + writel(SYSMGR_WDDBG_PAUSE_ALL_CPU, + socfpga_sysmgr_base + SYSMGR_S10_WDDBG);
/* Enable watchdog before initializing the HW */ socfpga_per_reset(SOCFPGA_RESET(L4WD0), 1); @@ -157,8 +155,10 @@ void board_init_f(ulong dummy) cm_print_clock_quick_summary();
/* enable non-secure interface to DMA330 DMA and peripherals */ - writel(SYSMGR_DMA_IRQ_NS | SYSMGR_DMA_MGR_NS, &sysmgr_regs->dma); - writel(SYSMGR_DMAPERIPH_ALL_NS, &sysmgr_regs->dma_periph); + writel(SYSMGR_DMA_IRQ_NS | SYSMGR_DMA_MGR_NS, + socfpga_sysmgr_base + SYSMGR_S10_DMA); + writel(SYSMGR_DMAPERIPH_ALL_NS, + socfpga_sysmgr_base + SYSMGR_S10_DMA_PERIPH);
spl_disable_firewall_l4_per();
diff --git a/arch/arm/mach-socfpga/system_manager_gen5.c b/arch/arm/mach-socfpga/system_manager_gen5.c index 9d04aea2a8..1053a47201 100644 --- a/arch/arm/mach-socfpga/system_manager_gen5.c +++ b/arch/arm/mach-socfpga/system_manager_gen5.c @@ -8,9 +8,6 @@ #include <asm/arch/system_manager.h> #include <asm/arch/fpga_manager.h>
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - /* * Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting. * The value is not wrote to SYSMGR.FPGAINTF.MODULE but @@ -21,30 +18,39 @@ static void populate_sysmgr_fpgaintf_module(void) u32 handoff_val = 0;
/* ISWGRP_HANDOFF_FPGAINTF */ - writel(0, &sysmgr_regs->iswgrp_handoff[2]); + writel(0, socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(2));
/* Enable the signal for those HPS peripherals that use FPGA. */ - if (readl(&sysmgr_regs->nandusefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_NAND_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_NAND; - if (readl(&sysmgr_regs->rgmii1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_RGMII1_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_EMAC1; - if (readl(&sysmgr_regs->sdmmcusefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_SDMMC_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SDMMC; - if (readl(&sysmgr_regs->rgmii0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_RGMII0_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_EMAC0; - if (readl(&sysmgr_regs->spim0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_SPIM0_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SPIM0; - if (readl(&sysmgr_regs->spim1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_SPIM1_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SPIM1;
/* populate (not writing) the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting */ - setbits_le32(&sysmgr_regs->iswgrp_handoff[2], handoff_val); + setbits_le32(socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(2), + handoff_val);
- handoff_val = readl(&sysmgr_regs->iswgrp_handoff[2]); + handoff_val = readl(socfpga_sysmgr_base + + SYSMGR_ISWGRP_HANDOFF_OFFSET(2)); if (fpgamgr_test_fpga_ready()) { /* Enable the required signals only */ - writel(handoff_val, &sysmgr_regs->fpgaintfgrp_module); + writel(handoff_val, + socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE); } }
@@ -53,7 +59,7 @@ static void populate_sysmgr_fpgaintf_module(void) */ void sysmgr_pinmux_init(void) { - u32 regs = (u32)&sysmgr_regs->emacio[0]; + u32 regs = (u32)socfpga_sysmgr_base + SYSMGR_GEN5_EMACIO; const u8 *sys_mgr_init_table; unsigned int len; int i; @@ -74,9 +80,9 @@ void sysmgr_pinmux_init(void) void sysmgr_config_warmrstcfgio(int enable) { if (enable) - setbits_le32(&sysmgr_regs->romcodegrp_ctrl, + setbits_le32(socfpga_sysmgr_base + SYSMGR_GEN5_ROMCODEGRP_CTRL, SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); else - clrbits_le32(&sysmgr_regs->romcodegrp_ctrl, + clrbits_le32(socfpga_sysmgr_base + SYSMGR_GEN5_ROMCODEGRP_CTRL, SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); } diff --git a/arch/arm/mach-socfpga/system_manager_s10.c b/arch/arm/mach-socfpga/system_manager_s10.c index 122828c9ce..c046bb17c9 100644 --- a/arch/arm/mach-socfpga/system_manager_s10.c +++ b/arch/arm/mach-socfpga/system_manager_s10.c @@ -10,9 +10,6 @@
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - /* * Configure all the pin muxes */ @@ -32,24 +29,31 @@ void populate_sysmgr_fpgaintf_module(void) u32 handoff_val = 0;
/* Enable the signal for those HPS peripherals that use FPGA. */ - if (readl(&sysmgr_regs->nandusefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_NAND_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_NAND; - if (readl(&sysmgr_regs->sdmmcusefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_SDMMC_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SDMMC; - if (readl(&sysmgr_regs->spim0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_SPIM0_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SPIM0; - if (readl(&sysmgr_regs->spim1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_SPIM1_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_SPIM1; - writel(handoff_val, &sysmgr_regs->fpgaintf_en_2); + writel(handoff_val, socfpga_sysmgr_base + SYSMGR_S10_FPGAINTF_EN2);
handoff_val = 0; - if (readl(&sysmgr_regs->rgmii0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC0_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_EMAC0; - if (readl(&sysmgr_regs->rgmii1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC1_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_EMAC1; - if (readl(&sysmgr_regs->rgmii2usefpga) == SYSMGR_FPGAINTF_USEFPGA) + if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC2_USEFPGA) == + SYSMGR_FPGAINTF_USEFPGA) handoff_val |= SYSMGR_FPGAINTF_EMAC2; - writel(handoff_val, &sysmgr_regs->fpgaintf_en_3); + writel(handoff_val, socfpga_sysmgr_base + SYSMGR_S10_FPGAINTF_EN3); }
/* @@ -64,14 +68,16 @@ void populate_sysmgr_pinmux(void) sysmgr_pinmux_table_sel(&sys_mgr_table_u32, &len); for (i = 0; i < len; i = i + 2) { writel(sys_mgr_table_u32[i + 1], - sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->pinsel0[0]); + sys_mgr_table_u32[i] + + (u8 *)socfpga_sysmgr_base + SYSMGR_S10_PINSEL0); }
/* setup the pin ctrl */ sysmgr_pinmux_table_ctrl(&sys_mgr_table_u32, &len); for (i = 0; i < len; i = i + 2) { writel(sys_mgr_table_u32[i + 1], - sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->ioctrl0[0]); + sys_mgr_table_u32[i] + + (u8 *)socfpga_sysmgr_base + SYSMGR_S10_IOCTRL0); }
/* setup the fpga use */ @@ -79,13 +85,14 @@ void populate_sysmgr_pinmux(void) for (i = 0; i < len; i = i + 2) { writel(sys_mgr_table_u32[i + 1], sys_mgr_table_u32[i] + - (u8 *)&sysmgr_regs->rgmii0usefpga); + (u8 *)socfpga_sysmgr_base + SYSMGR_S10_EMAC0_USEFPGA); }
/* setup the IO delay */ sysmgr_pinmux_table_delay(&sys_mgr_table_u32, &len); for (i = 0; i < len; i = i + 2) { writel(sys_mgr_table_u32[i + 1], - sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->iodelay0[0]); + sys_mgr_table_u32[i] + + (u8 *)socfpga_sysmgr_base + SYSMGR_S10_IODELAY0); } } diff --git a/arch/arm/mach-socfpga/wrap_pll_config_s10.c b/arch/arm/mach-socfpga/wrap_pll_config_s10.c index 7cafc7dcfc..c9570fea38 100644 --- a/arch/arm/mach-socfpga/wrap_pll_config_s10.c +++ b/arch/arm/mach-socfpga/wrap_pll_config_s10.c @@ -10,9 +10,6 @@ #include <asm/arch/handoff_s10.h> #include <asm/arch/system_manager.h>
-static const struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - const struct cm_config * const cm_get_default_config(void) { struct cm_config *cm_handoff_cfg = (struct cm_config *) @@ -38,9 +35,9 @@ const unsigned int cm_get_osc_clk_hz(void) #ifdef CONFIG_SPL_BUILD u32 clock = readl(S10_HANDOFF_CLOCK_OSC);
- writel(clock, &sysmgr_regs->boot_scratch_cold1); + writel(clock, socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD1); #endif - return readl(&sysmgr_regs->boot_scratch_cold1); + return readl(socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD1); }
const unsigned int cm_get_intosc_clk_hz(void) @@ -53,7 +50,7 @@ const unsigned int cm_get_fpga_clk_hz(void) #ifdef CONFIG_SPL_BUILD u32 clock = readl(S10_HANDOFF_CLOCK_FPGA);
- writel(clock, &sysmgr_regs->boot_scratch_cold2); + writel(clock, socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD2); #endif - return readl(&sysmgr_regs->boot_scratch_cold2); + return readl(socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD2); } diff --git a/drivers/ddr/altera/sdram_gen5.c b/drivers/ddr/altera/sdram_gen5.c index fcd89b619d..46a5c466a7 100644 --- a/drivers/ddr/altera/sdram_gen5.c +++ b/drivers/ddr/altera/sdram_gen5.c @@ -40,9 +40,6 @@ struct sdram_prot_rule { u32 hi_prot_id; };
-static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - static unsigned long sdram_calculate_size(struct socfpga_sdr_ctrl *sdr_ctrl);
/** @@ -455,12 +452,13 @@ int sdram_mmr_init_full(struct socfpga_sdr_ctrl *sdr_ctrl, SDR_CTRLGRP_DRAMADDRW_ROWBITS_LSB; int ret;
- writel(rows, &sysmgr_regs->iswgrp_handoff[4]); + writel(rows, socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(4));
sdr_load_regs(sdr_ctrl, cfg);
/* saving this value to SYSMGR.ISWGRP.HANDOFF.FPGA2SDR */ - writel(cfg->fpgaport_rst, &sysmgr_regs->iswgrp_handoff[3]); + writel(cfg->fpgaport_rst, + socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(3));
/* only enable if the FPGA is programmed */ if (fpgamgr_test_fpga_ready()) { @@ -516,7 +514,7 @@ static unsigned long sdram_calculate_size(struct socfpga_sdr_ctrl *sdr_ctrl) * since the FB specifies we modify ROWBITs to work around SDRAM * controller issue. */ - row = readl(&sysmgr_regs->iswgrp_handoff[4]); + row = readl(socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(4)); if (row == 0) row = rowbits; /* diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c index 56cbbac9fe..d5812f2fd7 100644 --- a/drivers/ddr/altera/sdram_s10.c +++ b/drivers/ddr/altera/sdram_s10.c @@ -32,9 +32,6 @@ struct altera_sdram_platdata {
-static const struct socfpga_system_manager *sysmgr_regs = - (void *)SOCFPGA_SYSMGR_ADDRESS; - #define DDR_CONFIG(A, B, C, R) (((A) << 24) | ((B) << 16) | ((C) << 8) | (R))
#define PGTABLE_OFF 0x4000 @@ -150,7 +147,8 @@ static int emif_reset(struct altera_sdram_platdata *plat)
static int poll_hmc_clock_status(void) { - return wait_for_bit_le32(&sysmgr_regs->hmc_clk, + return wait_for_bit_le32((const void *)(socfpga_sysmgr_base + + SYSMGR_S10_HMC_CLK), SYSMGR_HMC_CLK_STATUS_MSK, true, 1000, false); }
diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 5fb9d6a191..743326cdb3 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -30,9 +30,6 @@ DECLARE_GLOBAL_DATA_PTR; static const struct socfpga_fpga_manager *fpga_manager_base = (void *)SOCFPGA_FPGAMGRREGS_ADDRESS;
-static const struct socfpga_system_manager *system_manager_base = - (void *)SOCFPGA_SYSMGR_ADDRESS; - static void fpgamgr_set_cd_ratio(unsigned long ratio);
static uint32_t fpgamgr_get_msel(void) @@ -818,7 +815,7 @@ int socfpga_loadfs(fpga_fs_info *fpga_fsinfo, const void *buf, size_t bsize, }
/* Disable all signals from HPS peripheral controller to FPGA */ - writel(0, &system_manager_base->fpgaintf_en_global); + writel(0, socfpga_sysmgr_base + SYSMGR_A10_FPGAINTF_EN_GLOBAL);
/* Disable all axi bridges (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset(); @@ -910,7 +907,7 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) memset(&rbfinfo, 0, sizeof(rbfinfo));
/* Disable all signals from hps peripheral controller to fpga */ - writel(0, &system_manager_base->fpgaintf_en_global); + writel(0, socfpga_sysmgr_base + SYSMGR_A10_FPGAINTF_EN_GLOBAL);
/* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset(); diff --git a/drivers/fpga/socfpga_gen5.c b/drivers/fpga/socfpga_gen5.c index 6d16e0b37f..2b98572742 100644 --- a/drivers/fpga/socfpga_gen5.c +++ b/drivers/fpga/socfpga_gen5.c @@ -15,8 +15,6 @@
static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/* Set CD ratio */ static void fpgamgr_set_cd_ratio(unsigned long ratio) @@ -214,7 +212,7 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Prior programming the FPGA, all bridges need to be shut off */
/* Disable all signals from hps peripheral controller to fpga */ - writel(0, &sysmgr_regs->fpgaintfgrp_module); + writel(0, socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE);
/* Disable all signals from FPGA to HPS SDRAM */ #define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080 diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 739c1629a2..bdcd568d60 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -20,8 +20,6 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_clock_manager *clock_manager_base = (void *)SOCFPGA_CLKMGR_ADDRESS; -static const struct socfpga_system_manager *system_manager_base = - (void *)SOCFPGA_SYSMGR_ADDRESS;
struct socfpga_dwmci_plat { struct mmc_config cfg; @@ -61,10 +59,10 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host)
debug("%s: drvsel %d smplsel %d\n", __func__, priv->drvsel, priv->smplsel); - writel(sdmmc_mask, &system_manager_base->sdmmcgrp_ctrl); + writel(sdmmc_mask, socfpga_sysmgr_base + SYSMGR_SDMMC);
debug("%s: SYSMGR_SDMMCGRP_CTRL_REG = 0x%x\n", __func__, - readl(&system_manager_base->sdmmcgrp_ctrl)); + readl(socfpga_sysmgr_base + SYSMGR_SDMMC));
/* Enable SDMMC clock */ setbits_le32(&clock_manager_base->per_pll.en,
Am 10.10.2019 um 09:37 schrieb Ley Foon Tan:
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
v4:
- Update commit message about get base address from DT node.
v3:
- Remove "No functional change" in commit description.
v2:
- function to write the bypass register which requires a poll of the
- #if defined(CONFIG_TARGET_SOCFPGA_STRATIX10) #include <asm/arch/system_manager_s10.h> #else
- u32 siliconid1;
- u32 siliconid2;
- u32 wddbg;
- u32 bootinfo;
- u32 dma;
- u32 dma_periph;
- u32 emac_global;
- u32 emac[3];
- u32 noc_timeout;
- u32 noc_idleack;
- u32 tsmc_tsel_0;
- u32 tsmc_tsel_1;
- u32 tsmc_tsel_2;
- u32 tsmc_tsel_3;
- u32 romhw_ctrl;
- u32 romcode_ctrl;
- u32 warmram_crc;
Same formatting issues as in patch 2/4.
Rest seems to be ok. Although I still don't understand why converting from structs to defines cannot be in a seperate patch to loading the base address from dts... It's probably not worth changing this now, as the result is the same, but it would have greatly helped me understanding this series if it had been separated. Next time maybe ;-)
- u32 siliconid2;
- u32 bootinfo;
- u32 hpsinfo;
- u32 parityinj;
- u32 frzctrl_src;
- /* EMAC Group */
- u32 eccgrp_ocram;
- u32 eccgrp_usb0;
- u32 eccgrp_usb1;
- u32 eccgrp_emac1;
- u32 eccgrp_dma;
- u32 eccgrp_can0;
- u32 eccgrp_nand;
- u32 eccgrp_qspi;
- u32 eccgrp_sdmmc;
- u32 _pad_0x6f4;
- u32 _pad_0x734;
- u32 siliconid2;
- u32 wddbg;
- u32 _pad_0xc;
- u32 mpu_ace;
- u32 dma_periph;
- /* EMAC Group */
- u32 emac0;
- u32 emac1;
- u32 emac2;
- u32 emac1_ace;
- u32 emac2_ace;
- u32 nand_axuser;
- u32 dma_l3master;
- u32 etr_l3master;
- u32 _pad_0x7c;
- u32 osc_trim;
- /* ECC Group */
- u32 hmc_clk;
- u32 io_pa_ctrl;
- u32 _pad_0xbc;
- /* NOC Group */
- u32 fpga_config;
- u32 gpo;
- u32 gpi;
- u32 _pad_0xec;
- u32 pinsel40[8];
- u32 ioctrl0[28];
- u32 ioctrl28[20];
- u32 i2c0usefpga;
- u32 i2c1usefpga;
- u32 nandusefpga;
- u32 _pad_0x1324;
- u32 spim0usefpga;
- u32 spim1usefpga;
- u32 spis0usefpga;
- u32 spis1usefpga;
- u32 uart0usefpga;
- u32 uart1usefpga;
- u32 mdio0usefpga;
- u32 mdio1usefpga;
- u32 mdio2usefpga;
- u32 _pad_0x134c;
- u32 jtagusefpga;
- u32 sdmmcusefpga;
- u32 hps_osc_clk;
- u32 iodelay0[40];
- u32 iodelay40[8];
writel(resp_buf[0],
- socfpga_sysmgr_base = socfpga_get_base_addr("altr,sys-mgr");
- if (!socfpga_sysmgr_base)
}hang();
- FPGA programming support for SoC FPGA Arria 10
- const u32 bsel =
- const u32 bsel =
- const u32 bsel = readl(socfpga_sysmgr_base +
const int fpga_id = socfpga_fpga_id(0); env_set("bootmode", bsel_str[bsel].mode); if (fpga_id >= 0)SYSMGR_GEN5_BOOTINFO) & 0x7;
}SYSMGR_ISWGRP_HANDOFF_OFFSET(i));
writel(iswgrp_handoff[3], &sdr_ctrl->fpgaport_rst); writel(iswgrp_handoff[0], socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(iswgrp_handoff[1], &nic301_regs->remap); } else {socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE);
writel(0, &sdr_ctrl->fpgaport_rst); writel(0, socfpga_rstmgr_base + RSTMGR_GEN5_BRGMODRST); writel(1, &nic301_regs->remap);writel(0, socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE);
- FPGA programming support for SoC FPGA Stratix 10
modereg);
gmac_index),
return 0; }
mask_noc);
- ret = wait_for_bit_le32((const void *)(socfpga_sysmgr_base +
return 0; }
~0);
} else { /* set idle request to all bridges */while (readl(socfpga_sysmgr_base + SYSMGR_S10_NOC_IDLEACK)) ;
} }writel(0, socfpga_sysmgr_base + SYSMGR_S10_NOC_TIMEOUT);
- scan_chain_engine_is_idle() - Check if the JTAG scan chain is idle
return id; }
- reg = readl(socfpga_sysmgr_base + SYSMGR_GEN5_ECCGRP_OCRAM); if (reg & SYSMGR_ECC_OCRAM_SERR) writel(SYSMGR_ECC_OCRAM_SERR | SYSMGR_ECC_OCRAM_EN,
if (reg & SYSMGR_ECC_OCRAM_DERR) writel(SYSMGR_ECC_OCRAM_DERR | SYSMGR_ECC_OCRAM_EN,socfpga_sysmgr_base + SYSMGR_GEN5_ECCGRP_OCRAM);
- Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting.
- The value is not wrote to SYSMGR.FPGAINTF.MODULE but
- if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_NAND_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_NAND;SYSMGR_FPGAINTF_USEFPGA)
- if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_RGMII1_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_EMAC1;SYSMGR_FPGAINTF_USEFPGA)
- if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_SDMMC_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_SDMMC;SYSMGR_FPGAINTF_USEFPGA)
- if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_RGMII0_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_EMAC0;SYSMGR_FPGAINTF_USEFPGA)
- if (readl(socfpga_sysmgr_base + SYSMGR_GEN5_SPIM0_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_SPIM0;SYSMGR_FPGAINTF_USEFPGA)
- setbits_le32(socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(2),
handoff_val);
- handoff_val = readl(socfpga_sysmgr_base +
if (fpgamgr_test_fpga_ready()) { /* Enable the required signals only */SYSMGR_ISWGRP_HANDOFF_OFFSET(2));
writel(handoff_val,
} }socfpga_sysmgr_base + SYSMGR_GEN5_FPGAINFGRP_MODULE);
- u32 regs = (u32)socfpga_sysmgr_base + SYSMGR_GEN5_EMACIO; const u8 *sys_mgr_init_table; unsigned int len; int i;
elsesetbits_le32(socfpga_sysmgr_base + SYSMGR_GEN5_ROMCODEGRP_CTRL, SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO);
}clrbits_le32(socfpga_sysmgr_base + SYSMGR_GEN5_ROMCODEGRP_CTRL, SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO);
- Configure all the pin muxes
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_NAND_USEFPGA) ==
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_SDMMC_USEFPGA) ==
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_SPIM0_USEFPGA) ==
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_SPIM1_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_SPIM1;SYSMGR_FPGAINTF_USEFPGA)
handoff_val = 0;
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC0_USEFPGA) ==
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC1_USEFPGA) ==
- if (readl(socfpga_sysmgr_base + SYSMGR_S10_EMAC2_USEFPGA) ==
handoff_val |= SYSMGR_FPGAINTF_EMAC2;SYSMGR_FPGAINTF_USEFPGA)
} }(u8 *)socfpga_sysmgr_base + SYSMGR_S10_IODELAY0);
- writel(clock, socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD1); #endif
- writel(clock, socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD2); #endif
- return readl(socfpga_sysmgr_base + SYSMGR_S10_BOOT_SCRATCH_COLD2); }
- row = readl(socfpga_sysmgr_base + SYSMGR_ISWGRP_HANDOFF_OFFSET(4)); if (row == 0) row = rowbits; /*
- return wait_for_bit_le32((const void *)(socfpga_sysmgr_base +
}SYSMGR_S10_HMC_CLK), SYSMGR_HMC_CLK_STATUS_MSK, true, 1000, false);
Convert clock manager for Gen5, Arria 10 and Stratix 10 from struct to defines.
Change to get clock manager base address from DT node instead of using #define.
--- v4: - Update commit message about get base address from DT node.
v3: - Remove "No functional change" in commit description.
v2: - Revert to use writel(), readl() and etc. - Get base address from DT. - Add prefix to defines. --- arch/arm/mach-socfpga/clock_manager.c | 12 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 156 +++++++------ arch/arm/mach-socfpga/clock_manager_gen5.c | 199 +++++++++-------- arch/arm/mach-socfpga/clock_manager_s10.c | 206 ++++++++++-------- .../mach-socfpga/include/mach/clock_manager.h | 2 + .../include/mach/clock_manager_arria10.h | 133 +++++------ .../include/mach/clock_manager_gen5.h | 112 ++++------ .../include/mach/clock_manager_s10.h | 115 ++++------ arch/arm/mach-socfpga/misc.c | 5 + drivers/mmc/socfpga_dw_mmc.c | 11 +- 10 files changed, 476 insertions(+), 475 deletions(-)
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 9f3c643df8..09857dc37b 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -10,18 +10,15 @@
-static const struct socfpga_clock_manager *clock_manager_base = - (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; - void cm_wait_for_lock(u32 mask) { u32 inter_val; u32 retry = 0; do { #if defined(CONFIG_TARGET_SOCFPGA_GEN5) - inter_val = readl(&clock_manager_base->inter) & mask; + inter_val = readl(socfpga_clkmgr_base + CLKMGR_INTER) & mask; #else - inter_val = readl(&clock_manager_base->stat) & mask; + inter_val = readl(socfpga_clkmgr_base + CLKMGR_STAT) & mask; #endif /* Wait for stable lock */ if (inter_val == mask) @@ -36,8 +33,9 @@ void cm_wait_for_lock(u32 mask) /* function to poll in the fsm busy bit */ int cm_wait_for_fsm(void) { - return wait_for_bit_le32(&clock_manager_base->stat, - CLKMGR_STAT_BUSY, false, 20000, false); + return wait_for_bit_le32((const void *)(socfpga_clkmgr_base + + CLKMGR_STAT), CLKMGR_STAT_BUSY, false, 20000, + false); }
int set_cpu_clk_info(void) diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index 334a79fd9c..33aebd4f47 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -231,9 +231,6 @@ static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, return 0; }
-static const struct socfpga_clock_manager *clock_manager_base = - (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; - /* calculate the intended main VCO frequency based on handoff */ static unsigned int cm_calc_handoff_main_vco_clk_hz (struct mainpll_cfg *main_cfg) @@ -551,12 +548,13 @@ static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(0, main_cfg, per_cfg, clk_hz), - &clock_manager_base->main_pll.vco1); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1); mdelay(1); cm_wait_for_lock(LOCKED_MASK); } writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | - main_cfg->vco1_numer, &clock_manager_base->main_pll.vco1); + main_cfg->vco1_numer, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1); mdelay(1); cm_wait_for_lock(LOCKED_MASK); } @@ -579,14 +577,17 @@ static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, /* execute the ramping here */ for (clk_hz = pll_ramp_periph_hz + clk_incr_hz; clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { - writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | - cm_calc_safe_pll_numer(1, main_cfg, per_cfg, clk_hz), - &clock_manager_base->per_pll.vco1); + writel((per_cfg->vco1_denom << + CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, + clk_hz), + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1); mdelay(1); cm_wait_for_lock(LOCKED_MASK); } writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | - per_cfg->vco1_numer, &clock_manager_base->per_pll.vco1); + per_cfg->vco1_numer, + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1); mdelay(1); cm_wait_for_lock(LOCKED_MASK); } @@ -638,16 +639,16 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) /* gate off all mainpll clock excpet HW managed clock */ writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, - &clock_manager_base->main_pll.enr); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_ENR);
/* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll.en); + writel(0, socfpga_clkmgr_base + CLKMGR_A10_PERPLL_EN);
/* Put all plls in external bypass */ writel(CLKMGR_MAINPLL_BYPASS_RESET, - &clock_manager_base->main_pll.bypasss); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_BYPASSS); writel(CLKMGR_PERPLL_BYPASS_RESET, - &clock_manager_base->per_pll.bypasss); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_BYPASSS);
/* * Put all plls VCO registers back to reset value. @@ -657,15 +658,17 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) writel(CLKMGR_MAINPLL_VCO0_RESET | CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK | (main_cfg->vco0_psrc << CLKMGR_MAINPLL_VCO0_PSRC_LSB), - &clock_manager_base->main_pll.vco0); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0);
writel(CLKMGR_PERPLL_VCO0_RESET | CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK | (per_cfg->vco0_psrc << CLKMGR_PERPLL_VCO0_PSRC_LSB), - &clock_manager_base->per_pll.vco0); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0);
- writel(CLKMGR_MAINPLL_VCO1_RESET, &clock_manager_base->main_pll.vco1); - writel(CLKMGR_PERPLL_VCO1_RESET, &clock_manager_base->per_pll.vco1); + writel(CLKMGR_MAINPLL_VCO1_RESET, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1); + writel(CLKMGR_PERPLL_VCO1_RESET, + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1);
/* clear the interrupt register status register */ writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | @@ -676,7 +679,7 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK | CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK | CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK, - &clock_manager_base->intr); + socfpga_clkmgr_base + CLKMGR_A10_INTR);
/* Program VCO Numerator and Denominator for main PLL */ ramp_required = cm_is_pll_ramp_required(0, main_cfg, per_cfg); @@ -687,14 +690,16 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) else if (ramp_required == 2) pll_ramp_main_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ;
- writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + writel((main_cfg->vco1_denom << + CLKMGR_MAINPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(0, main_cfg, per_cfg, pll_ramp_main_hz), - &clock_manager_base->main_pll.vco1); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1); } else - writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | - main_cfg->vco1_numer, - &clock_manager_base->main_pll.vco1); + writel((main_cfg->vco1_denom << + CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1);
/* Program VCO Numerator and Denominator for periph PLL */ ramp_required = cm_is_pll_ramp_required(1, main_cfg, per_cfg); @@ -707,23 +712,25 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) pll_ramp_periph_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ;
- writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + writel((per_cfg->vco1_denom << + CLKMGR_PERPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(1, main_cfg, per_cfg, pll_ramp_periph_hz), - &clock_manager_base->per_pll.vco1); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1); } else - writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + writel((per_cfg->vco1_denom << + CLKMGR_PERPLL_VCO1_DENOM_LSB) | per_cfg->vco1_numer, - &clock_manager_base->per_pll.vco1); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1);
/* Wait for at least 5 us */ udelay(5);
/* Now deassert BGPWRDN and PWRDN */ - clrbits_le32(&clock_manager_base->main_pll.vco0, + clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK | CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK); - clrbits_le32(&clock_manager_base->per_pll.vco0, + clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0, CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK | CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK);
@@ -731,84 +738,90 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) udelay(7);
/* enable the VCO and disable the external regulator to PLL */ - writel((readl(&clock_manager_base->main_pll.vco0) & + writel((readl(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0) & ~CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK) | CLKMGR_MAINPLL_VCO0_EN_SET_MSK, - &clock_manager_base->main_pll.vco0); - writel((readl(&clock_manager_base->per_pll.vco0) & + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0); + writel((readl(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0) & ~CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK) | CLKMGR_PERPLL_VCO0_EN_SET_MSK, - &clock_manager_base->per_pll.vco0); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0);
/* setup all the main PLL counter and clock source */ - writel(main_cfg->nocclk, - SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET); - writel(main_cfg->mpuclk, - SOCFPGA_CLKMGR_ADDRESS + CLKMGR_ALTERAGRP_MPU_CLK_OFFSET); + writel(main_cfg->nocclk, socfpga_clkmgr_base + CLKMGR_A10_ALTR_NOCCLK); + writel(main_cfg->mpuclk, socfpga_clkmgr_base + CLKMGR_A10_ALTR_MPUCLK);
/* main_emaca_clk divider */ - writel(main_cfg->cntr2clk_cnt, &clock_manager_base->main_pll.cntr2clk); + writel(main_cfg->cntr2clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR2CLK); /* main_emacb_clk divider */ - writel(main_cfg->cntr3clk_cnt, &clock_manager_base->main_pll.cntr3clk); + writel(main_cfg->cntr3clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR3CLK); /* main_emac_ptp_clk divider */ - writel(main_cfg->cntr4clk_cnt, &clock_manager_base->main_pll.cntr4clk); + writel(main_cfg->cntr4clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR4CLK); /* main_gpio_db_clk divider */ - writel(main_cfg->cntr5clk_cnt, &clock_manager_base->main_pll.cntr5clk); + writel(main_cfg->cntr5clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR5CLK); /* main_sdmmc_clk divider */ - writel(main_cfg->cntr6clk_cnt, &clock_manager_base->main_pll.cntr6clk); + writel(main_cfg->cntr6clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR6CLK); /* main_s2f_user0_clk divider */ writel(main_cfg->cntr7clk_cnt | (main_cfg->cntr7clk_src << CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB), - &clock_manager_base->main_pll.cntr7clk); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR7CLK); /* main_s2f_user1_clk divider */ - writel(main_cfg->cntr8clk_cnt, &clock_manager_base->main_pll.cntr8clk); + writel(main_cfg->cntr8clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR8CLK); /* main_hmc_pll_clk divider */ writel(main_cfg->cntr9clk_cnt | (main_cfg->cntr9clk_src << CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB), - &clock_manager_base->main_pll.cntr9clk); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR9CLK); /* main_periph_ref_clk divider */ writel(main_cfg->cntr15clk_cnt, - &clock_manager_base->main_pll.cntr15clk); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR15CLK);
/* setup all the peripheral PLL counter and clock source */ /* peri_emaca_clk divider */ writel(per_cfg->cntr2clk_cnt | (per_cfg->cntr2clk_src << CLKMGR_PERPLL_CNTR2CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr2clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR2CLK); /* peri_emacb_clk divider */ writel(per_cfg->cntr3clk_cnt | (per_cfg->cntr3clk_src << CLKMGR_PERPLL_CNTR3CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr3clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR3CLK); /* peri_emac_ptp_clk divider */ writel(per_cfg->cntr4clk_cnt | (per_cfg->cntr4clk_src << CLKMGR_PERPLL_CNTR4CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr4clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR4CLK); /* peri_gpio_db_clk divider */ writel(per_cfg->cntr5clk_cnt | (per_cfg->cntr5clk_src << CLKMGR_PERPLL_CNTR5CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr5clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR5CLK); /* peri_sdmmc_clk divider */ writel(per_cfg->cntr6clk_cnt | (per_cfg->cntr6clk_src << CLKMGR_PERPLL_CNTR6CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr6clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR6CLK); /* peri_s2f_user0_clk divider */ - writel(per_cfg->cntr7clk_cnt, &clock_manager_base->per_pll.cntr7clk); + writel(per_cfg->cntr7clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR7CLK); /* peri_s2f_user1_clk divider */ writel(per_cfg->cntr8clk_cnt | (per_cfg->cntr8clk_src << CLKMGR_PERPLL_CNTR8CLK_SRC_LSB), - &clock_manager_base->per_pll.cntr8clk); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR8CLK); /* peri_hmc_pll_clk divider */ - writel(per_cfg->cntr9clk_cnt, &clock_manager_base->per_pll.cntr9clk); + writel(per_cfg->cntr9clk_cnt, + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR9CLK);
/* setup all the external PLL counter */ /* mpu wrapper / external divider */ writel(main_cfg->mpuclk_cnt | (main_cfg->mpuclk_src << CLKMGR_MAINPLL_MPUCLK_SRC_LSB), - &clock_manager_base->main_pll.mpuclk); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_MPUCLK); /* NOC wrapper / external divider */ writel(main_cfg->nocclk_cnt | (main_cfg->nocclk_src << CLKMGR_MAINPLL_NOCCLK_SRC_LSB), - &clock_manager_base->main_pll.nocclk); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_NOCCLK); /* NOC subclock divider such as l4 */ writel(main_cfg->nocdiv_l4mainclk | (main_cfg->nocdiv_l4mpclk << @@ -821,10 +834,10 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB) | (main_cfg->nocdiv_cspdbclk << CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB), - &clock_manager_base->main_pll.nocdiv); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_NOCDIV); /* gpio_db external divider */ writel(per_cfg->gpiodiv_gpiodbclk, - &clock_manager_base->per_pll.gpiodiv); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_GPIOFIV);
/* setup the EMAC clock mux select */ writel((per_cfg->emacctl_emac0sel << @@ -833,7 +846,7 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB) | (per_cfg->emacctl_emac2sel << CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB), - &clock_manager_base->per_pll.emacctl); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_EMACCTL);
/* at this stage, check for PLL lock status */ cm_wait_for_lock(LOCKED_MASK); @@ -843,33 +856,33 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) * assert/deassert outresetall */ /* assert mainpll outresetall */ - setbits_le32(&clock_manager_base->main_pll.vco0, + setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); /* assert perpll outresetall */ - setbits_le32(&clock_manager_base->per_pll.vco0, + setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0, CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); /* de-assert mainpll outresetall */ - clrbits_le32(&clock_manager_base->main_pll.vco0, + clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); /* de-assert perpll outresetall */ - clrbits_le32(&clock_manager_base->per_pll.vco0, + clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0, CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK);
/* Take all PLLs out of bypass when boot mode is cleared. */ /* release mainpll from bypass */ writel(CLKMGR_MAINPLL_BYPASS_RESET, - &clock_manager_base->main_pll.bypassr); + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_BYPASSR); /* wait till Clock Manager is not busy */ cm_wait_for_fsm();
/* release perpll from bypass */ writel(CLKMGR_PERPLL_BYPASS_RESET, - &clock_manager_base->per_pll.bypassr); + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_BYPASSR); /* wait till Clock Manager is not busy */ cm_wait_for_fsm();
/* clear boot mode */ - clrbits_le32(&clock_manager_base->ctrl, + clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_CTRL, CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK); /* wait till Clock Manager is not busy */ cm_wait_for_fsm(); @@ -882,9 +895,10 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg)
/* Now ungate non-hw-managed clocks */ writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | - CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, - &clock_manager_base->main_pll.ens); - writel(CLKMGR_PERPLL_EN_RESET, &clock_manager_base->per_pll.ens); + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_ENS); + writel(CLKMGR_PERPLL_EN_RESET, + socfpga_clkmgr_base + CLKMGR_A10_PERPLL_ENS);
/* Clear the loss lock and slip bits as they might set during clock reconfiguration */ @@ -894,14 +908,14 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK, - &clock_manager_base->intr); + socfpga_clkmgr_base + CLKMGR_A10_INTR);
return 0; }
static void cm_use_intosc(void) { - setbits_le32(&clock_manager_base->ctrl, + setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_CTRL, CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK); }
diff --git a/arch/arm/mach-socfpga/clock_manager_gen5.c b/arch/arm/mach-socfpga/clock_manager_gen5.c index 3a64600861..c9990af46f 100644 --- a/arch/arm/mach-socfpga/clock_manager_gen5.c +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -9,23 +9,20 @@ #include <asm/arch/clock_manager.h> #include <wait_bit.h>
-static const struct socfpga_clock_manager *clock_manager_base = - (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; - /* * function to write the bypass register which requires a poll of the * busy bit */ static void cm_write_bypass(u32 val) { - writel(val, &clock_manager_base->bypass); + writel(val, socfpga_clkmgr_base + CLKMGR_GEN5_BYPASS); cm_wait_for_fsm(); }
/* function to write the ctrl register which requires a poll of the busy bit */ static void cm_write_ctrl(u32 val) { - writel(val, &clock_manager_base->ctrl); + writel(val, socfpga_clkmgr_base + CLKMGR_GEN5_CTRL); cm_wait_for_fsm(); }
@@ -79,8 +76,8 @@ int cm_basic_init(const struct cm_config * const cfg) * gatting off the rest of the periperal clocks. */ writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & - readl(&clock_manager_base->per_pll.en), - &clock_manager_base->per_pll.en); + readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EN), + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EN);
/* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | @@ -89,12 +86,12 @@ int cm_basic_init(const struct cm_config * const cfg) CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, - &clock_manager_base->main_pll.en); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_EN);
- writel(0, &clock_manager_base->sdr_pll.en); + writel(0, socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_EN);
/* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll.en); + writel(0, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EN);
/* Put all plls in bypass */ cm_write_bypass(CLKMGR_BYPASS_PERPLL | CLKMGR_BYPASS_SDRPLL | @@ -103,13 +100,13 @@ int cm_basic_init(const struct cm_config * const cfg) /* Put all plls VCO registers back to reset value. */ writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE & ~CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->main_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO); writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->per_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->sdr_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* * The clocks to the flash devices and the L4_MAIN clocks can @@ -119,23 +116,26 @@ int cm_basic_init(const struct cm_config * const cfg) * after exiting safe mode but before ungating the clocks. */ writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, - &clock_manager_base->per_pll.src); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, - &clock_manager_base->main_pll.l4src); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_L4SRC);
/* read back for the required 5 us delay. */ - readl(&clock_manager_base->main_pll.vco); - readl(&clock_manager_base->per_pll.vco); - readl(&clock_manager_base->sdr_pll.vco); + readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO); + readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); + readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* * We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN * with numerator and denominator. */ - writel(cfg->main_vco_base, &clock_manager_base->main_pll.vco); - writel(cfg->peri_vco_base, &clock_manager_base->per_pll.vco); - writel(cfg->sdram_vco_base, &clock_manager_base->sdr_pll.vco); + writel(cfg->main_vco_base, + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO); + writel(cfg->peri_vco_base, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); + writel(cfg->sdram_vco_base, + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* * Time starts here. Must wait 7 us from @@ -144,44 +144,53 @@ int cm_basic_init(const struct cm_config * const cfg) end = timer_get_us() + 7;
/* main mpu */ - writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk); + writel(cfg->mpuclk, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MPUCLK);
/* altera group mpuclk */ - writel(cfg->altera_grp_mpuclk, &clock_manager_base->altera.mpuclk); + writel(cfg->altera_grp_mpuclk, + socfpga_clkmgr_base + CLKMGR_GEN5_ALTR_MPUCLK);
/* main main clock */ - writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk); + writel(cfg->mainclk, + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINCLK);
/* main for dbg */ - writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk); + writel(cfg->dbgatclk, + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_DBGATCLK);
/* main for cfgs2fuser0clk */ writel(cfg->cfg2fuser0clk, - &clock_manager_base->main_pll.cfgs2fuser0clk); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_CFGS2FUSER0CLK);
/* Peri emac0 50 MHz default to RMII */ - writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk); + writel(cfg->emac0clk, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EMAC0CLK);
/* Peri emac1 50 MHz default to RMII */ - writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk); + writel(cfg->emac1clk, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EMAC1CLK);
/* Peri QSPI */ - writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk); + writel(cfg->mainqspiclk, + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINQSPICLK);
- writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk); + writel(cfg->perqspiclk, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_PERQSPICLK);
/* Peri pernandsdmmcclk */ writel(cfg->mainnandsdmmcclk, - &clock_manager_base->main_pll.mainnandsdmmcclk); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINNANDSDMMCCLK);
writel(cfg->pernandsdmmcclk, - &clock_manager_base->per_pll.pernandsdmmcclk); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_PERNANDSDMMCCLK);
/* Peri perbaseclk */ - writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk); + writel(cfg->perbaseclk, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_PERBASECLK);
/* Peri s2fuser1clk */ - writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk); + writel(cfg->s2fuser1clk, + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_S2FUSER1CLK);
/* 7 us must have elapsed before we can enable the VCO */ while (timer_get_us() < end) @@ -190,101 +199,106 @@ int cm_basic_init(const struct cm_config * const cfg) /* Enable vco */ /* main pll vco */ writel(cfg->main_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->main_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO);
/* periferal pll */ writel(cfg->peri_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->per_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO);
/* sdram pll vco */ writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* L3 MP and L3 SP */ - writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv); + writel(cfg->maindiv, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINDIV);
- writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv); + writel(cfg->dbgdiv, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_DBGDIV);
- writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv); + writel(cfg->tracediv, + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_TRACEDIV);
/* L4 MP, L4 SP, can0, and can1 */ - writel(cfg->perdiv, &clock_manager_base->per_pll.div); + writel(cfg->perdiv, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_DIV);
- writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv); + writel(cfg->gpiodiv, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_GPIODIV);
/* write the sdram clock counters before toggling outreset all */ writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqsclk); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_DDRDQSCLK);
writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddr2xdqsclk); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_DDR2XDQSCLK);
writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqclk); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_DDRDQCLK);
writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, - &clock_manager_base->sdr_pll.s2fuser2clk); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_S2FUSER2CLK);
/* * after locking, but before taking out of bypass * assert/deassert outresetall */ - u32 mainvco = readl(&clock_manager_base->main_pll.vco); + u32 mainvco = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO);
/* assert main outresetall */ writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO);
- u32 periphvco = readl(&clock_manager_base->per_pll.vco); + u32 periphvco = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO);
/* assert pheriph outresetall */ writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO);
/* assert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN| - CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, - &clock_manager_base->sdr_pll.vco); + writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN | + CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* deassert main outresetall */ writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO);
/* deassert pheriph outresetall */ writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO);
/* deassert sdram outresetall */ writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); + socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO);
/* * now that we've toggled outreset all, all the clocks * are aligned nicely; so we can change any phase. */ ret = cm_write_with_phase(cfg->ddrdqsclk, - &clock_manager_base->sdr_pll.ddrdqsclk, + (const void *)(socfpga_clkmgr_base + + CLKMGR_GEN5_SDRPLL_DDRDQSCLK), CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); if (ret) return ret;
/* SDRAM DDR2XDQSCLK */ ret = cm_write_with_phase(cfg->ddr2xdqsclk, - &clock_manager_base->sdr_pll.ddr2xdqsclk, + (const void *)(socfpga_clkmgr_base + + CLKMGR_GEN5_SDRPLL_DDR2XDQSCLK), CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); if (ret) return ret;
ret = cm_write_with_phase(cfg->ddrdqclk, - &clock_manager_base->sdr_pll.ddrdqclk, + (const void *)(socfpga_clkmgr_base + + CLKMGR_GEN5_SDRPLL_DDRDQCLK), CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); if (ret) return ret;
ret = cm_write_with_phase(cfg->s2fuser2clk, - &clock_manager_base->sdr_pll.s2fuser2clk, + (const void *)(socfpga_clkmgr_base + + CLKMGR_GEN5_SDRPLL_S2FUSER2CLK), CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK); if (ret) return ret; @@ -293,24 +307,26 @@ int cm_basic_init(const struct cm_config * const cfg) cm_write_bypass(0);
/* clear safe mode */ - cm_write_ctrl(readl(&clock_manager_base->ctrl) | CLKMGR_CTRL_SAFEMODE); + cm_write_ctrl(readl(socfpga_clkmgr_base + CLKMGR_GEN5_CTRL) | + CLKMGR_CTRL_SAFEMODE);
/* * now that safe mode is clear with clocks gated * it safe to change the source mux for the flashes the the L4_MAIN */ - writel(cfg->persrc, &clock_manager_base->per_pll.src); - writel(cfg->l4src, &clock_manager_base->main_pll.l4src); + writel(cfg->persrc, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); + writel(cfg->l4src, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_L4SRC);
/* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll.en); - writel(~0, &clock_manager_base->per_pll.en); - writel(~0, &clock_manager_base->sdr_pll.en); + writel(~0, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_EN); + writel(~0, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_EN); + writel(~0, socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_EN);
/* Clear the loss of lock bits (write 1 to clear) */ - writel(CLKMGR_INTER_SDRPLLLOST_MASK | CLKMGR_INTER_PERPLLLOST_MASK | - CLKMGR_INTER_MAINPLLLOST_MASK, - &clock_manager_base->inter); + writel(CLKMGR_INTER_SDRPLLLOST_MASK | + CLKMGR_INTER_PERPLLLOST_MASK | + CLKMGR_INTER_MAINPLLLOST_MASK, + socfpga_clkmgr_base + CLKMGR_GEN5_INTER);
return 0; } @@ -320,7 +336,7 @@ static unsigned int cm_get_main_vco_clk_hz(void) u32 reg, clock;
/* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO); clock = cm_get_osc_clk_hz(1); clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; @@ -335,7 +351,7 @@ static unsigned int cm_get_per_vco_clk_hz(void) u32 reg, clock = 0;
/* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; if (reg == CLKMGR_VCO_SSRC_EOSC1) @@ -346,7 +362,7 @@ static unsigned int cm_get_per_vco_clk_hz(void) clock = cm_get_f2s_per_ref_clk_hz();
/* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> @@ -362,9 +378,9 @@ unsigned long cm_get_mpu_clk_hz(void) clock = cm_get_main_vco_clk_hz();
/* get the MPU clock */ - reg = readl(&clock_manager_base->altera.mpuclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_ALTR_MPUCLK); clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mpuclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MPUCLK); clock /= (reg + 1); return clock; } @@ -374,7 +390,7 @@ unsigned long cm_get_sdram_clk_hz(void) u32 reg, clock = 0;
/* identify SDRAM PLL clock source */ - reg = readl(&clock_manager_base->sdr_pll.vco); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO); reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; if (reg == CLKMGR_VCO_SSRC_EOSC1) @@ -385,14 +401,14 @@ unsigned long cm_get_sdram_clk_hz(void) clock = cm_get_f2s_sdr_ref_clk_hz();
/* get the SDRAM VCO clock */ - reg = readl(&clock_manager_base->sdr_pll.vco); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO); clock /= ((reg & CLKMGR_SDRPLLGRP_VCO_DENOM_MASK) >> CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET) + 1; clock *= ((reg & CLKMGR_SDRPLLGRP_VCO_NUMER_MASK) >> CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET) + 1;
/* get the SDRAM (DDR_DQS) clock */ - reg = readl(&clock_manager_base->sdr_pll.ddrdqsclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_DDRDQSCLK); reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; clock /= (reg + 1); @@ -405,7 +421,7 @@ unsigned int cm_get_l4_sp_clk_hz(void) u32 reg, clock = 0;
/* identify the source of L4 SP clock */ - reg = readl(&clock_manager_base->main_pll.l4src); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_L4SRC); reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET;
@@ -413,20 +429,21 @@ unsigned int cm_get_l4_sp_clk_hz(void) clock = cm_get_main_vco_clk_hz();
/* get the clock prior L4 SP divider (main clk) */ - reg = readl(&clock_manager_base->altera.mainclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_ALTR_MAINCLK); clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mainclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINCLK); clock /= (reg + 1); } else if (reg == CLKMGR_L4_SP_CLK_SRC_PERPLL) { clock = cm_get_per_vco_clk_hz();
/* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); + reg = readl(socfpga_clkmgr_base + + CLKMGR_GEN5_PERPLL_PERBASECLK); clock /= (reg + 1); }
/* get the L4 SP clock which supplied to UART */ - reg = readl(&clock_manager_base->main_pll.maindiv); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINDIV); reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; clock = clock / (1 << reg); @@ -439,7 +456,7 @@ unsigned int cm_get_mmc_controller_clk_hz(void) u32 reg, clock = 0;
/* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET;
@@ -449,13 +466,15 @@ unsigned int cm_get_mmc_controller_clk_hz(void) clock = cm_get_main_vco_clk_hz();
/* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); + reg = readl(socfpga_clkmgr_base + + CLKMGR_GEN5_MAINPLL_MAINNANDSDMMCCLK); clock /= (reg + 1); } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { clock = cm_get_per_vco_clk_hz();
/* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); + reg = readl(socfpga_clkmgr_base + + CLKMGR_GEN5_PERPLL_PERNANDSDMMCCLK); clock /= (reg + 1); }
@@ -469,7 +488,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void) u32 reg, clock = 0;
/* identify the source of QSPI clock */ - reg = readl(&clock_manager_base->per_pll.src); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET;
@@ -479,13 +498,15 @@ unsigned int cm_get_qspi_controller_clk_hz(void) clock = cm_get_main_vco_clk_hz();
/* get the qspi clock */ - reg = readl(&clock_manager_base->main_pll.mainqspiclk); + reg = readl(socfpga_clkmgr_base + + CLKMGR_GEN5_MAINPLL_MAINQSPICLK); clock /= (reg + 1); } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { clock = cm_get_per_vco_clk_hz();
/* get the qspi clock */ - reg = readl(&clock_manager_base->per_pll.perqspiclk); + reg = readl(socfpga_clkmgr_base + + CLKMGR_GEN5_PERPLL_PERQSPICLK); clock /= (reg + 1); }
@@ -499,7 +520,7 @@ unsigned int cm_get_spi_controller_clk_hz(void) clock = cm_get_per_vco_clk_hz();
/* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); + reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_PERBASECLK); clock /= (reg + 1);
return clock; diff --git a/arch/arm/mach-socfpga/clock_manager_s10.c b/arch/arm/mach-socfpga/clock_manager_s10.c index 6cbf07ac6f..c6269701f0 100644 --- a/arch/arm/mach-socfpga/clock_manager_s10.c +++ b/arch/arm/mach-socfpga/clock_manager_s10.c @@ -12,29 +12,26 @@
-static const struct socfpga_clock_manager *clock_manager_base = - (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; - /* * function to write the bypass register which requires a poll of the * busy bit */ static void cm_write_bypass_mainpll(u32 val) { - writel(val, &clock_manager_base->main_pll.bypass); + writel(val, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_BYPASS); cm_wait_for_fsm(); }
static void cm_write_bypass_perpll(u32 val) { - writel(val, &clock_manager_base->per_pll.bypass); + writel(val, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_BYPASS); cm_wait_for_fsm(); }
/* function to write the ctrl register which requires a poll of the busy bit */ static void cm_write_ctrl(u32 val) { - writel(val, &clock_manager_base->ctrl); + writel(val, socfpga_clkmgr_base + CLKMGR_S10_CTRL); cm_wait_for_fsm(); }
@@ -66,12 +63,17 @@ void cm_basic_init(const struct cm_config * const cfg)
writel((cfg->main_pll_pllglob & ~CLKMGR_PLLGLOB_PD_MASK & ~CLKMGR_PLLGLOB_RST_MASK), - &clock_manager_base->main_pll.pllglob); - writel(cfg->main_pll_fdbck, &clock_manager_base->main_pll.fdbck); - writel(vcocalib, &clock_manager_base->main_pll.vcocalib); - writel(cfg->main_pll_pllc0, &clock_manager_base->main_pll.pllc0); - writel(cfg->main_pll_pllc1, &clock_manager_base->main_pll.pllc1); - writel(cfg->main_pll_nocdiv, &clock_manager_base->main_pll.nocdiv); + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLGLOB); + writel(cfg->main_pll_fdbck, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_FDBCK); + writel(vcocalib, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_VCOCALIB); + writel(cfg->main_pll_pllc0, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLC0); + writel(cfg->main_pll_pllc1, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLC1); + writel(cfg->main_pll_nocdiv, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_NOCDIV);
/* setup peripheral PLL dividers */ /* calculate the vcocalib value */ @@ -88,18 +90,23 @@ void cm_basic_init(const struct cm_config * const cfg)
writel((cfg->per_pll_pllglob & ~CLKMGR_PLLGLOB_PD_MASK & ~CLKMGR_PLLGLOB_RST_MASK), - &clock_manager_base->per_pll.pllglob); - writel(cfg->per_pll_fdbck, &clock_manager_base->per_pll.fdbck); - writel(vcocalib, &clock_manager_base->per_pll.vcocalib); - writel(cfg->per_pll_pllc0, &clock_manager_base->per_pll.pllc0); - writel(cfg->per_pll_pllc1, &clock_manager_base->per_pll.pllc1); - writel(cfg->per_pll_emacctl, &clock_manager_base->per_pll.emacctl); - writel(cfg->per_pll_gpiodiv, &clock_manager_base->per_pll.gpiodiv); + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLGLOB); + writel(cfg->per_pll_fdbck, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_FDBCK); + writel(vcocalib, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_VCOCALIB); + writel(cfg->per_pll_pllc0, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLC0); + writel(cfg->per_pll_pllc1, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLC1); + writel(cfg->per_pll_emacctl, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_EMACCTL); + writel(cfg->per_pll_gpiodiv, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_GPIODIV);
/* Take both PLL out of reset and power up */ - setbits_le32(&clock_manager_base->main_pll.pllglob, + setbits_le32(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLGLOB, CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); - setbits_le32(&clock_manager_base->per_pll.pllglob, + setbits_le32(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLGLOB, CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK);
#define LOCKED_MASK \ @@ -113,66 +120,85 @@ void cm_basic_init(const struct cm_config * const cfg) * only take effect upon value change, we shall set a maximum value as * default value. */ - writel(0xff, &clock_manager_base->main_pll.mpuclk); - writel(0xff, &clock_manager_base->main_pll.nocclk); - writel(0xff, &clock_manager_base->main_pll.cntr2clk); - writel(0xff, &clock_manager_base->main_pll.cntr3clk); - writel(0xff, &clock_manager_base->main_pll.cntr4clk); - writel(0xff, &clock_manager_base->main_pll.cntr5clk); - writel(0xff, &clock_manager_base->main_pll.cntr6clk); - writel(0xff, &clock_manager_base->main_pll.cntr7clk); - writel(0xff, &clock_manager_base->main_pll.cntr8clk); - writel(0xff, &clock_manager_base->main_pll.cntr9clk); - writel(0xff, &clock_manager_base->per_pll.cntr2clk); - writel(0xff, &clock_manager_base->per_pll.cntr3clk); - writel(0xff, &clock_manager_base->per_pll.cntr4clk); - writel(0xff, &clock_manager_base->per_pll.cntr5clk); - writel(0xff, &clock_manager_base->per_pll.cntr6clk); - writel(0xff, &clock_manager_base->per_pll.cntr7clk); - writel(0xff, &clock_manager_base->per_pll.cntr8clk); - writel(0xff, &clock_manager_base->per_pll.cntr9clk); - - writel(cfg->main_pll_mpuclk, &clock_manager_base->main_pll.mpuclk); - writel(cfg->main_pll_nocclk, &clock_manager_base->main_pll.nocclk); - writel(cfg->main_pll_cntr2clk, &clock_manager_base->main_pll.cntr2clk); - writel(cfg->main_pll_cntr3clk, &clock_manager_base->main_pll.cntr3clk); - writel(cfg->main_pll_cntr4clk, &clock_manager_base->main_pll.cntr4clk); - writel(cfg->main_pll_cntr5clk, &clock_manager_base->main_pll.cntr5clk); - writel(cfg->main_pll_cntr6clk, &clock_manager_base->main_pll.cntr6clk); - writel(cfg->main_pll_cntr7clk, &clock_manager_base->main_pll.cntr7clk); - writel(cfg->main_pll_cntr8clk, &clock_manager_base->main_pll.cntr8clk); - writel(cfg->main_pll_cntr9clk, &clock_manager_base->main_pll.cntr9clk); - writel(cfg->per_pll_cntr2clk, &clock_manager_base->per_pll.cntr2clk); - writel(cfg->per_pll_cntr3clk, &clock_manager_base->per_pll.cntr3clk); - writel(cfg->per_pll_cntr4clk, &clock_manager_base->per_pll.cntr4clk); - writel(cfg->per_pll_cntr5clk, &clock_manager_base->per_pll.cntr5clk); - writel(cfg->per_pll_cntr6clk, &clock_manager_base->per_pll.cntr6clk); - writel(cfg->per_pll_cntr7clk, &clock_manager_base->per_pll.cntr7clk); - writel(cfg->per_pll_cntr8clk, &clock_manager_base->per_pll.cntr8clk); - writel(cfg->per_pll_cntr9clk, &clock_manager_base->per_pll.cntr9clk); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_MPUCLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_NOCCLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR2CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR3CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR4CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR5CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR6CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR7CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR8CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR9CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR2CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR3CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR4CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR5CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR6CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR7CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR8CLK); + writel(0xff, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR9CLK); + + writel(cfg->main_pll_mpuclk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_MPUCLK); + writel(cfg->main_pll_nocclk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_NOCCLK); + writel(cfg->main_pll_cntr2clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR2CLK); + writel(cfg->main_pll_cntr3clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR3CLK); + writel(cfg->main_pll_cntr4clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR4CLK); + writel(cfg->main_pll_cntr5clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR5CLK); + writel(cfg->main_pll_cntr6clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR6CLK); + writel(cfg->main_pll_cntr7clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR7CLK); + writel(cfg->main_pll_cntr8clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR8CLK); + writel(cfg->main_pll_cntr9clk, + socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_CNTR9CLK); + writel(cfg->per_pll_cntr2clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR2CLK); + writel(cfg->per_pll_cntr3clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR3CLK); + writel(cfg->per_pll_cntr4clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR4CLK); + writel(cfg->per_pll_cntr5clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR5CLK); + writel(cfg->per_pll_cntr6clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR6CLK); + writel(cfg->per_pll_cntr7clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR7CLK); + writel(cfg->per_pll_cntr8clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR8CLK); + writel(cfg->per_pll_cntr9clk, + socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR9CLK);
/* Take all PLLs out of bypass */ cm_write_bypass_mainpll(0); cm_write_bypass_perpll(0);
/* clear safe mode / out of boot mode */ - cm_write_ctrl(readl(&clock_manager_base->ctrl) - & ~(CLKMGR_CTRL_SAFEMODE)); + cm_write_ctrl(readl(socfpga_clkmgr_base + CLKMGR_S10_CTRL) & + ~(CLKMGR_CTRL_SAFEMODE));
/* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll.en); - writel(~0, &clock_manager_base->per_pll.en); + writel(~0, socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_EN); + writel(~0, socfpga_clkmgr_base + CLKMGR_S10_PERPLL_EN);
/* Clear the loss of lock bits (write 1 to clear) */ - writel(CLKMGR_INTER_PERPLLLOST_MASK | CLKMGR_INTER_MAINPLLLOST_MASK, - &clock_manager_base->intrclr); + writel(CLKMGR_INTER_PERPLLLOST_MASK | + CLKMGR_INTER_MAINPLLLOST_MASK, + socfpga_clkmgr_base + CLKMGR_S10_INTRCLR); }
static unsigned long cm_get_main_vco_clk_hz(void) { unsigned long fref, refdiv, mdiv, reg, vco;
- reg = readl(&clock_manager_base->main_pll.pllglob); + reg = readl(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLGLOB);
fref = (reg >> CLKMGR_PLLGLOB_VCO_PSRC_OFFSET) & CLKMGR_PLLGLOB_VCO_PSRC_MASK; @@ -191,7 +217,7 @@ static unsigned long cm_get_main_vco_clk_hz(void) refdiv = (reg >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & CLKMGR_PLLGLOB_REFCLKDIV_MASK;
- reg = readl(&clock_manager_base->main_pll.fdbck); + reg = readl(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_FDBCK); mdiv = (reg >> CLKMGR_FDBCK_MDIV_OFFSET) & CLKMGR_FDBCK_MDIV_MASK;
vco = fref / refdiv; @@ -203,7 +229,7 @@ static unsigned long cm_get_per_vco_clk_hz(void) { unsigned long fref, refdiv, mdiv, reg, vco;
- reg = readl(&clock_manager_base->per_pll.pllglob); + reg = readl(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLGLOB);
fref = (reg >> CLKMGR_PLLGLOB_VCO_PSRC_OFFSET) & CLKMGR_PLLGLOB_VCO_PSRC_MASK; @@ -222,7 +248,7 @@ static unsigned long cm_get_per_vco_clk_hz(void) refdiv = (reg >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & CLKMGR_PLLGLOB_REFCLKDIV_MASK;
- reg = readl(&clock_manager_base->per_pll.fdbck); + reg = readl(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_FDBCK); mdiv = (reg >> CLKMGR_FDBCK_MDIV_OFFSET) & CLKMGR_FDBCK_MDIV_MASK;
vco = fref / refdiv; @@ -232,20 +258,23 @@ static unsigned long cm_get_per_vco_clk_hz(void)
unsigned long cm_get_mpu_clk_hz(void) { - unsigned long clock = readl(&clock_manager_base->main_pll.mpuclk); + unsigned long clock = readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_MPUCLK);
clock = (clock >> CLKMGR_CLKSRC_OFFSET) & CLKMGR_CLKSRC_MASK;
switch (clock) { case CLKMGR_CLKSRC_MAIN: clock = cm_get_main_vco_clk_hz(); - clock /= (readl(&clock_manager_base->main_pll.pllc0) & + clock /= (readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_PLLC0) & CLKMGR_PLLC0_DIV_MASK); break;
case CLKMGR_CLKSRC_PER: clock = cm_get_per_vco_clk_hz(); - clock /= (readl(&clock_manager_base->per_pll.pllc0) & + clock /= (readl(socfpga_clkmgr_base + + CLKMGR_S10_PERPLL_PLLC0) & CLKMGR_CLKCNT_MSK); break;
@@ -262,27 +291,28 @@ unsigned long cm_get_mpu_clk_hz(void) break; }
- clock /= 1 + (readl(&clock_manager_base->main_pll.mpuclk) & - CLKMGR_CLKCNT_MSK); + clock /= 1 + (readl(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_MPUCLK) & + CLKMGR_CLKCNT_MSK); return clock; }
unsigned int cm_get_l3_main_clk_hz(void) { - u32 clock = readl(&clock_manager_base->main_pll.nocclk); + u32 clock = readl(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_NOCCLK);
switch (clock) { case CLKMGR_CLKSRC_MAIN: clock = cm_get_main_vco_clk_hz(); - clock /= (readl(&clock_manager_base->main_pll.pllc1) & + clock /= (readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_PLLC1) & CLKMGR_PLLC0_DIV_MASK); break;
case CLKMGR_CLKSRC_PER: clock = cm_get_per_vco_clk_hz(); - clock /= (readl(&clock_manager_base->per_pll.pllc1) & + clock /= (readl(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLC1) & CLKMGR_CLKCNT_MSK); break;
@@ -299,28 +329,30 @@ unsigned int cm_get_l3_main_clk_hz(void) break; }
- clock /= 1 + (readl(&clock_manager_base->main_pll.nocclk) & + clock /= 1 + (readl(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_NOCCLK) & CLKMGR_CLKCNT_MSK); return clock; }
unsigned int cm_get_mmc_controller_clk_hz(void) { - u32 clock = readl(&clock_manager_base->per_pll.cntr6clk); + u32 clock = readl(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_CNTR6CLK);
switch (clock) { case CLKMGR_CLKSRC_MAIN: clock = cm_get_l3_main_clk_hz(); - clock /= 1 + (readl(&clock_manager_base->main_pll.cntr6clk) & - CLKMGR_CLKCNT_MSK); + clock /= 1 + (readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_CNTR6CLK) & + CLKMGR_CLKCNT_MSK); break;
case CLKMGR_CLKSRC_PER: clock = cm_get_l3_main_clk_hz(); - clock /= 1 + (readl(&clock_manager_base->per_pll.cntr6clk) & - CLKMGR_CLKCNT_MSK); + clock /= 1 + (readl(socfpga_clkmgr_base + + CLKMGR_S10_PERPLL_CNTR6CLK) & + CLKMGR_CLKCNT_MSK); break;
case CLKMGR_CLKSRC_OSC1: @@ -342,8 +374,9 @@ unsigned int cm_get_l4_sp_clk_hz(void) { u32 clock = cm_get_l3_main_clk_hz();
- clock /= (1 << ((readl(&clock_manager_base->main_pll.nocdiv) >> - CLKMGR_NOCDIV_L4SPCLK_OFFSET) & CLKMGR_CLKCNT_MSK)); + clock /= (1 << ((readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4SPCLK_OFFSET) & CLKMGR_CLKCNT_MSK)); return clock; }
@@ -356,8 +389,9 @@ unsigned int cm_get_spi_controller_clk_hz(void) { u32 clock = cm_get_l3_main_clk_hz();
- clock /= (1 << ((readl(&clock_manager_base->main_pll.nocdiv) >> - CLKMGR_NOCDIV_L4MAIN_OFFSET) & CLKMGR_CLKCNT_MSK)); + clock /= (1 << ((readl(socfpga_clkmgr_base + + CLKMGR_S10_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4MAIN_OFFSET) & CLKMGR_CLKCNT_MSK)); return clock; }
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index dd80e3a767..4f9d10dd78 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -6,6 +6,8 @@ #ifndef _CLOCK_MANAGER_H_ #define _CLOCK_MANAGER_H_
+extern phys_addr_t socfpga_clkmgr_base; + #ifndef __ASSEMBLER__ void cm_wait_for_lock(u32 mask); int cm_wait_for_fsm(void); diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h index de8c22540f..52b579e6e1 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h @@ -8,86 +8,57 @@
-struct socfpga_clock_manager_main_pll { - u32 vco0; - u32 vco1; - u32 en; - u32 ens; - u32 enr; - u32 bypass; - u32 bypasss; - u32 bypassr; - u32 mpuclk; - u32 nocclk; - u32 cntr2clk; - u32 cntr3clk; - u32 cntr4clk; - u32 cntr5clk; - u32 cntr6clk; - u32 cntr7clk; - u32 cntr8clk; - u32 cntr9clk; - u32 pad_0x48_0x5b[5]; - u32 cntr15clk; - u32 outrst; - u32 outrststat; - u32 nocdiv; - u32 pad_0x6c_0x80[5]; -}; - -struct socfpga_clock_manager_per_pll { - u32 vco0; - u32 vco1; - u32 en; - u32 ens; - u32 enr; - u32 bypass; - u32 bypasss; - u32 bypassr; - u32 pad_0x20_0x27[2]; - u32 cntr2clk; - u32 cntr3clk; - u32 cntr4clk; - u32 cntr5clk; - u32 cntr6clk; - u32 cntr7clk; - u32 cntr8clk; - u32 cntr9clk; - u32 pad_0x48_0x5f[6]; - u32 outrst; - u32 outrststat; - u32 emacctl; - u32 gpiodiv; - u32 pad_0x70_0x80[4]; -}; - -struct socfpga_clock_manager_altera { - u32 mpuclk; - u32 nocclk; - u32 mainmisc0; - u32 mainmisc1; - u32 perimisc0; - u32 perimisc1; -}; - -struct socfpga_clock_manager { - /* clkmgr */ - u32 ctrl; - u32 intr; - u32 intrs; - u32 intrr; - u32 intren; - u32 intrens; - u32 intrenr; - u32 stat; - u32 testioctrl; - u32 _pad_0x24_0x40[7]; - /* mainpllgrp */ - struct socfpga_clock_manager_main_pll main_pll; - /* perpllgrp */ - struct socfpga_clock_manager_per_pll per_pll; - struct socfpga_clock_manager_altera altera; -}; +/* Clock manager group */ +#define CLKMGR_A10_CTRL 0 +#define CLKMGR_A10_INTR 4 +#define CLKMGR_A10_STAT 0x1c +/* MainPLL group */ +#define CLKMGR_A10_MAINPLL_VCO0 0x40 +#define CLKMGR_A10_MAINPLL_VCO1 0x44 +#define CLKMGR_A10_MAINPLL_EN 0x48 +#define CLKMGR_A10_MAINPLL_ENS 0x4c +#define CLKMGR_A10_MAINPLL_ENR 0x50 +#define CLKMGR_A10_MAINPLL_BYPASS 0x54 +#define CLKMGR_A10_MAINPLL_BYPASSS 0x58 +#define CLKMGR_A10_MAINPLL_BYPASSR 0x5c +#define CLKMGR_A10_MAINPLL_MPUCLK 0x60 +#define CLKMGR_A10_MAINPLL_NOCCLK 0x64 +#define CLKMGR_A10_MAINPLL_CNTR2CLK 0x68 +#define CLKMGR_A10_MAINPLL_CNTR3CLK 0x6c +#define CLKMGR_A10_MAINPLL_CNTR4CLK 0x70 +#define CLKMGR_A10_MAINPLL_CNTR5CLK 0x74 +#define CLKMGR_A10_MAINPLL_CNTR6CLK 0x78 +#define CLKMGR_A10_MAINPLL_CNTR7CLK 0x7c +#define CLKMGR_A10_MAINPLL_CNTR8CLK 0x80 +#define CLKMGR_A10_MAINPLL_CNTR9CLK 0x84 +#define CLKMGR_A10_MAINPLL_CNTR15CLK 0x9c +#define CLKMGR_A10_MAINPLL_NOCDIV 0xa8 +/* Peripheral PLL group */ +#define CLKMGR_A10_PERPLL_VCO0 0xc0 +#define CLKMGR_A10_PERPLL_VCO1 0xc4 +#define CLKMGR_A10_PERPLL_EN 0xc8 +#define CLKMGR_A10_PERPLL_ENS 0xcc +#define CLKMGR_A10_PERPLL_ENR 0xd0 +#define CLKMGR_A10_PERPLL_BYPASS 0xd4 +#define CLKMGR_A10_PERPLL_BYPASSS 0xd8 +#define CLKMGR_A10_PERPLL_BYPASSR 0xdc +#define CLKMGR_A10_PERPLL_CNTR2CLK 0xe8 +#define CLKMGR_A10_PERPLL_CNTR3CLK 0xec +#define CLKMGR_A10_PERPLL_CNTR4CLK 0xf0 +#define CLKMGR_A10_PERPLL_CNTR5CLK 0xf4 +#define CLKMGR_A10_PERPLL_CNTR6CLK 0xf8 +#define CLKMGR_A10_PERPLL_CNTR7CLK 0xfc +#define CLKMGR_A10_PERPLL_CNTR8CLK 0x100 +#define CLKMGR_A10_PERPLL_CNTR9CLK 0x104 +#define CLKMGR_A10_PERPLL_EMACCTL 0x128 +#define CLKMGR_A10_PERPLL_GPIOFIV 0x12c +/* Altera group */ +#define CLKMGR_A10_ALTR_MPUCLK 0x140 +#define CLKMGR_A10_ALTR_NOCCLK 0x144 + +#define CLKMGR_STAT CLKMGR_A10_STAT +#define CLKMGR_INTER CLKMGR_A10_INTER +#define CLKMGR_PERPLL_EN CLKMGR_A10_PERPLL_EN
#ifdef CONFIG_SPL_BUILD int cm_basic_init(const void *blob); @@ -100,8 +71,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void);
#endif /* __ASSEMBLER__ */
-#define CLKMGR_ALTERAGRP_MPU_CLK_OFFSET 0x140 -#define CLKMGR_MAINPLL_NOC_CLK_OFFSET 0x144 #define LOCKED_MASK (CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK | \ CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK)
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h index 5bedf28cf1..caa1231c69 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h @@ -45,71 +45,53 @@ struct cm_config { u32 altera_grp_mpuclk; };
-struct socfpga_clock_manager_main_pll { - u32 vco; - u32 misc; - u32 mpuclk; - u32 mainclk; - u32 dbgatclk; - u32 mainqspiclk; - u32 mainnandsdmmcclk; - u32 cfgs2fuser0clk; - u32 en; - u32 maindiv; - u32 dbgdiv; - u32 tracediv; - u32 l4src; - u32 stat; - u32 _pad_0x38_0x40[2]; -}; - -struct socfpga_clock_manager_per_pll { - u32 vco; - u32 misc; - u32 emac0clk; - u32 emac1clk; - u32 perqspiclk; - u32 pernandsdmmcclk; - u32 perbaseclk; - u32 s2fuser1clk; - u32 en; - u32 div; - u32 gpiodiv; - u32 src; - u32 stat; - u32 _pad_0x34_0x40[3]; -}; - -struct socfpga_clock_manager_sdr_pll { - u32 vco; - u32 ctrl; - u32 ddrdqsclk; - u32 ddr2xdqsclk; - u32 ddrdqclk; - u32 s2fuser2clk; - u32 en; - u32 stat; -}; - -struct socfpga_clock_manager_altera { - u32 mpuclk; - u32 mainclk; -}; - -struct socfpga_clock_manager { - u32 ctrl; - u32 bypass; - u32 inter; - u32 intren; - u32 dbctrl; - u32 stat; - u32 _pad_0x18_0x3f[10]; - struct socfpga_clock_manager_main_pll main_pll; - struct socfpga_clock_manager_per_pll per_pll; - struct socfpga_clock_manager_sdr_pll sdr_pll; - struct socfpga_clock_manager_altera altera; - u32 _pad_0xe8_0x200[70]; -}; +/* Clock manager group */ +#define CLKMGR_GEN5_CTRL 0 +#define CLKMGR_GEN5_BYPASS 4 +#define CLKMGR_GEN5_INTER 8 +#define CLKMGR_GEN5_STAT 0x14 +/* MainPLL group */ +#define CLKMGR_GEN5_MAINPLL_VCO 0x40 +#define CLKMGR_GEN5_MAINPLL_MISC 0x44 +#define CLKMGR_GEN5_MAINPLL_MPUCLK 0x48 +#define CLKMGR_GEN5_MAINPLL_MAINCLK 0x4c +#define CLKMGR_GEN5_MAINPLL_DBGATCLK 0x50 +#define CLKMGR_GEN5_MAINPLL_MAINQSPICLK 0x54 +#define CLKMGR_GEN5_MAINPLL_MAINNANDSDMMCCLK 0x58 +#define CLKMGR_GEN5_MAINPLL_CFGS2FUSER0CLK 0x5c +#define CLKMGR_GEN5_MAINPLL_EN 0x60 +#define CLKMGR_GEN5_MAINPLL_MAINDIV 0x64 +#define CLKMGR_GEN5_MAINPLL_DBGDIV 0x68 +#define CLKMGR_GEN5_MAINPLL_TRACEDIV 0x6c +#define CLKMGR_GEN5_MAINPLL_L4SRC 0x70 +/* Peripheral PLL group */ +#define CLKMGR_GEN5_PERPLL_VCO 0x80 +#define CLKMGR_GEN5_PERPLL_MISC 0x84 +#define CLKMGR_GEN5_PERPLL_EMAC0CLK 0x88 +#define CLKMGR_GEN5_PERPLL_EMAC1CLK 0x8c +#define CLKMGR_GEN5_PERPLL_PERQSPICLK 0x90 +#define CLKMGR_GEN5_PERPLL_PERNANDSDMMCCLK 0x94 +#define CLKMGR_GEN5_PERPLL_PERBASECLK 0x98 +#define CLKMGR_GEN5_PERPLL_S2FUSER1CLK 0x9c +#define CLKMGR_GEN5_PERPLL_EN 0xa0 +#define CLKMGR_GEN5_PERPLL_DIV 0xa4 +#define CLKMGR_GEN5_PERPLL_GPIODIV 0xa8 +#define CLKMGR_GEN5_PERPLL_SRC 0xac +/* SDRAM PLL group */ +#define CLKMGR_GEN5_SDRPLL_VCO 0xc0 +#define CLKMGR_GEN5_SDRPLL_CTRL 0xc4 +#define CLKMGR_GEN5_SDRPLL_DDRDQSCLK 0xc8 +#define CLKMGR_GEN5_SDRPLL_DDR2XDQSCLK 0xcc +#define CLKMGR_GEN5_SDRPLL_DDRDQCLK 0xd0 +#define CLKMGR_GEN5_SDRPLL_S2FUSER2CLK 0xd4 +#define CLKMGR_GEN5_SDRPLL_EN 0xd8 +/* Altera group */ +#define CLKMGR_GEN5_ALTR_MPUCLK 0xe0 +#define CLKMGR_GEN5_ALTR_MAINCLK 0xe4 + +#define CLKMGR_STAT CLKMGR_GEN5_STAT +#define CLKMGR_INTER CLKMGR_GEN5_INTER +#define CLKMGR_PERPLL_EN CLKMGR_GEN5_PERPLL_EN
/* Clock speed accessors */ unsigned long cm_get_mpu_clk_hz(void); diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h index 24b20de011..fa0ba26f09 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h @@ -69,75 +69,54 @@ struct cm_config {
void cm_basic_init(const struct cm_config * const cfg);
-struct socfpga_clock_manager_main_pll { - u32 en; - u32 ens; - u32 enr; - u32 bypass; - u32 bypasss; - u32 bypassr; - u32 mpuclk; - u32 nocclk; - u32 cntr2clk; - u32 cntr3clk; - u32 cntr4clk; - u32 cntr5clk; - u32 cntr6clk; - u32 cntr7clk; - u32 cntr8clk; - u32 cntr9clk; - u32 nocdiv; - u32 pllglob; - u32 fdbck; - u32 mem; - u32 memstat; - u32 pllc0; - u32 pllc1; - u32 vcocalib; - u32 _pad_0x90_0xA0[5]; -}; - -struct socfpga_clock_manager_per_pll { - u32 en; - u32 ens; - u32 enr; - u32 bypass; - u32 bypasss; - u32 bypassr; - u32 cntr2clk; - u32 cntr3clk; - u32 cntr4clk; - u32 cntr5clk; - u32 cntr6clk; - u32 cntr7clk; - u32 cntr8clk; - u32 cntr9clk; - u32 emacctl; - u32 gpiodiv; - u32 pllglob; - u32 fdbck; - u32 mem; - u32 memstat; - u32 pllc0; - u32 pllc1; - u32 vcocalib; - u32 _pad_0x100_0x124[10]; -}; +/* Control status */ +#define CLKMGR_S10_CTRL 0 +#define CLKMGR_S10_STAT 4 +#define CLKMGR_S10_INTRCLR 0x14 +/* Mainpll group */ +#define CLKMGR_S10_MAINPLL_EN 0x30 +#define CLKMGR_S10_MAINPLL_BYPASS 0x3c +#define CLKMGR_S10_MAINPLL_MPUCLK 0x48 +#define CLKMGR_S10_MAINPLL_NOCCLK 0x4c +#define CLKMGR_S10_MAINPLL_CNTR2CLK 0x50 +#define CLKMGR_S10_MAINPLL_CNTR3CLK 0x54 +#define CLKMGR_S10_MAINPLL_CNTR4CLK 0x58 +#define CLKMGR_S10_MAINPLL_CNTR5CLK 0x5c +#define CLKMGR_S10_MAINPLL_CNTR6CLK 0x60 +#define CLKMGR_S10_MAINPLL_CNTR7CLK 0x64 +#define CLKMGR_S10_MAINPLL_CNTR8CLK 0x68 +#define CLKMGR_S10_MAINPLL_CNTR9CLK 0x6c +#define CLKMGR_S10_MAINPLL_NOCDIV 0x70 +#define CLKMGR_S10_MAINPLL_PLLGLOB 0x74 +#define CLKMGR_S10_MAINPLL_FDBCK 0x78 +#define CLKMGR_S10_MAINPLL_MEMSTAT 0x80 +#define CLKMGR_S10_MAINPLL_PLLC0 0x84 +#define CLKMGR_S10_MAINPLL_PLLC1 0x88 +#define CLKMGR_S10_MAINPLL_VCOCALIB 0x8c +/* Periphpll group */ +#define CLKMGR_S10_PERPLL_EN 0xa4 +#define CLKMGR_S10_PERPLL_BYPASS 0xac +#define CLKMGR_S10_PERPLL_CNTR2CLK 0xbc +#define CLKMGR_S10_PERPLL_CNTR3CLK 0xc0 +#define CLKMGR_S10_PERPLL_CNTR4CLK 0xc4 +#define CLKMGR_S10_PERPLL_CNTR5CLK 0xc8 +#define CLKMGR_S10_PERPLL_CNTR6CLK 0xcc +#define CLKMGR_S10_PERPLL_CNTR7CLK 0xd0 +#define CLKMGR_S10_PERPLL_CNTR8CLK 0xd4 +#define CLKMGR_S10_PERPLL_CNTR9CLK 0xd8 +#define CLKMGR_S10_PERPLL_EMACCTL 0xdc +#define CLKMGR_S10_PERPLL_GPIODIV 0xe0 +#define CLKMGR_S10_PERPLL_PLLGLOB 0xe4 +#define CLKMGR_S10_PERPLL_FDBCK 0xe8 +#define CLKMGR_S10_PERPLL_MEMSTAT 0xf0 +#define CLKMGR_S10_PERPLL_PLLC0 0xf4 +#define CLKMGR_S10_PERPLL_PLLC1 0xf8 +#define CLKMGR_S10_PERPLL_VCOCALIB 0xfc + +#define CLKMGR_STAT CLKMGR_S10_STAT +#define CLKMGR_INTER CLKMGR_S10_INTER +#define CLKMGR_PERPLL_EN CLKMGR_S10_PERPLL_EN
-struct socfpga_clock_manager { - u32 ctrl; - u32 stat; - u32 testioctrl; - u32 intrgen; - u32 intrmsk; - u32 intrclr; - u32 intrsts; - u32 intrstk; - u32 intrraw; - u32 _pad_0x24_0x2c[3]; - struct socfpga_clock_manager_main_pll main_pll; - struct socfpga_clock_manager_per_pll per_pll; -};
#define CLKMGR_CTRL_SAFEMODE BIT(0) #define CLKMGR_BYPASS_MAINPLL_ALL 0x00000007 diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index fcc53b6fbc..dffd1b2e41 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -22,6 +22,7 @@
DECLARE_GLOBAL_DATA_PTR;
+phys_addr_t socfpga_clkmgr_base __section(".data"); phys_addr_t socfpga_rstmgr_base __section(".data"); phys_addr_t socfpga_sysmgr_base __section(".data");
@@ -238,4 +239,8 @@ void socfpga_get_manager_addr(void) socfpga_sysmgr_base = socfpga_get_base_addr("altr,sys-mgr"); if (!socfpga_sysmgr_base) hang(); + + socfpga_clkmgr_base = socfpga_get_base_addr("altr,clk-mgr"); + if (!socfpga_clkmgr_base) + hang(); } diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index bdcd568d60..aefcae8fb6 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -18,9 +18,6 @@
-static const struct socfpga_clock_manager *clock_manager_base = - (void *)SOCFPGA_CLKMGR_ADDRESS; - struct socfpga_dwmci_plat { struct mmc_config cfg; struct mmc mmc; @@ -54,8 +51,8 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host) ((priv->drvsel & 0x7) << SYSMGR_SDMMC_DRVSEL_SHIFT);
/* Disable SDMMC clock. */ - clrbits_le32(&clock_manager_base->per_pll.en, - CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); + clrbits_le32(socfpga_clkmgr_base + CLKMGR_PERPLL_EN, + CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK);
debug("%s: drvsel %d smplsel %d\n", __func__, priv->drvsel, priv->smplsel); @@ -65,8 +62,8 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host) readl(socfpga_sysmgr_base + SYSMGR_SDMMC));
/* Enable SDMMC clock */ - setbits_le32(&clock_manager_base->per_pll.en, - CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); + setbits_le32(socfpga_clkmgr_base + CLKMGR_PERPLL_EN, + CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK); }
static int socfpga_dwmmc_get_clk_rate(struct udevice *dev)
Am 10.10.2019 um 09:37 schrieb Ley Foon Tan:
Convert clock manager for Gen5, Arria 10 and Stratix 10 from struct to defines.
Change to get clock manager base address from DT node instead of using #define.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
v4:
- Update commit message about get base address from DT node.
v3:
- Remove "No functional change" in commit description.
v2:
- Revert to use writel(), readl() and etc.
- Get base address from DT.
- Add prefix to defines.
arch/arm/mach-socfpga/clock_manager.c | 12 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 156 +++++++------ arch/arm/mach-socfpga/clock_manager_gen5.c | 199 +++++++++-------- arch/arm/mach-socfpga/clock_manager_s10.c | 206 ++++++++++-------- .../mach-socfpga/include/mach/clock_manager.h | 2 + .../include/mach/clock_manager_arria10.h | 133 +++++------ .../include/mach/clock_manager_gen5.h | 112 ++++------ .../include/mach/clock_manager_s10.h | 115 ++++------ arch/arm/mach-socfpga/misc.c | 5 + drivers/mmc/socfpga_dw_mmc.c | 11 +- 10 files changed, 476 insertions(+), 475 deletions(-)
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index 9f3c643df8..09857dc37b 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -10,18 +10,15 @@
- void cm_wait_for_lock(u32 mask) { u32 inter_val; u32 retry = 0; do { #if defined(CONFIG_TARGET_SOCFPGA_GEN5)
inter_val = readl(&clock_manager_base->inter) & mask;
#elseinter_val = readl(socfpga_clkmgr_base + CLKMGR_INTER) & mask;
inter_val = readl(&clock_manager_base->stat) & mask;
#endif /* Wait for stable lock */ if (inter_val == mask)inter_val = readl(socfpga_clkmgr_base + CLKMGR_STAT) & mask;
@@ -36,8 +33,9 @@ void cm_wait_for_lock(u32 mask) /* function to poll in the fsm busy bit */ int cm_wait_for_fsm(void) {
- return wait_for_bit_le32(&clock_manager_base->stat,
CLKMGR_STAT_BUSY, false, 20000, false);
return wait_for_bit_le32((const void *)(socfpga_clkmgr_base +
CLKMGR_STAT), CLKMGR_STAT_BUSY, false, 20000,
false);
int set_cpu_clk_info(void)
diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c index 334a79fd9c..33aebd4f47 100644 --- a/arch/arm/mach-socfpga/clock_manager_arria10.c +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -231,9 +231,6 @@ static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, return 0; }
- /* calculate the intended main VCO frequency based on handoff */ static unsigned int cm_calc_handoff_main_vco_clk_hz (struct mainpll_cfg *main_cfg)
@@ -551,12 +548,13 @@ static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(0, main_cfg, per_cfg, clk_hz),
mdelay(1); cm_wait_for_lock(LOCKED_MASK); } writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) |socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1);
main_cfg->vco1_numer, &clock_manager_base->main_pll.vco1);
mdelay(1); cm_wait_for_lock(LOCKED_MASK); }socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1);
@@ -579,14 +577,17 @@ static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, /* execute the ramping here */ for (clk_hz = pll_ramp_periph_hz + clk_incr_hz; clk_hz < clk_final_hz; clk_hz += clk_incr_hz) {
cm_calc_safe_pll_numer(1, main_cfg, per_cfg, clk_hz),
clk_hz),
mdelay(1); cm_wait_for_lock(LOCKED_MASK); } writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) |socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1);
per_cfg->vco1_numer, &clock_manager_base->per_pll.vco1);
mdelay(1); cm_wait_for_lock(LOCKED_MASK); }socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1);
@@ -638,16 +639,16 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) /* gate off all mainpll clock excpet HW managed clock */ writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK,
&clock_manager_base->main_pll.enr);
socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_ENR);
writel(0, socfpga_clkmgr_base + CLKMGR_A10_PERPLL_EN);
/* Put all plls in external bypass */ writel(CLKMGR_MAINPLL_BYPASS_RESET,
&clock_manager_base->main_pll.bypasss);
writel(CLKMGR_PERPLL_BYPASS_RESET,socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_BYPASSS);
&clock_manager_base->per_pll.bypasss);
socfpga_clkmgr_base + CLKMGR_A10_PERPLL_BYPASSS);
- Put all plls VCO registers back to reset value.
@@ -657,15 +658,17 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) writel(CLKMGR_MAINPLL_VCO0_RESET | CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK | (main_cfg->vco0_psrc << CLKMGR_MAINPLL_VCO0_PSRC_LSB),
writel(CLKMGR_PERPLL_VCO0_RESET | CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK | (per_cfg->vco0_psrc << CLKMGR_PERPLL_VCO0_PSRC_LSB),
- writel(CLKMGR_MAINPLL_VCO1_RESET, &clock_manager_base->main_pll.vco1);
- writel(CLKMGR_PERPLL_VCO1_RESET, &clock_manager_base->per_pll.vco1);
/* clear the interrupt register status register */ writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK |
@@ -676,7 +679,7 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK | CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK | CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK,
/* Program VCO Numerator and Denominator for main PLL */ ramp_required = cm_is_pll_ramp_required(0, main_cfg, per_cfg);
@@ -687,14 +690,16 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) else if (ramp_required == 2) pll_ramp_main_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ;
CLKMGR_MAINPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(0, main_cfg, per_cfg, pll_ramp_main_hz),
} elsesocfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO1);
/* Program VCO Numerator and Denominator for periph PLL */ ramp_required = cm_is_pll_ramp_required(1, main_cfg, per_cfg);
@@ -707,23 +712,25 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) pll_ramp_periph_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ;
CLKMGR_PERPLL_VCO1_DENOM_LSB) | cm_calc_safe_pll_numer(1, main_cfg, per_cfg, pll_ramp_periph_hz),
} elsesocfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO1);
CLKMGR_PERPLL_VCO1_DENOM_LSB) | per_cfg->vco1_numer,
/* Wait for at least 5 us */ udelay(5);
/* Now deassert BGPWRDN and PWRDN */
- clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK | CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK);
- clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0, CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK | CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK);
@@ -731,84 +738,90 @@ static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) udelay(7);
/* enable the VCO and disable the external regulator to PLL */
- writel((readl(&clock_manager_base->main_pll.vco0) &
- writel((readl(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0) & ~CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK) | CLKMGR_MAINPLL_VCO0_EN_SET_MSK,
&clock_manager_base->main_pll.vco0);
- writel((readl(&clock_manager_base->per_pll.vco0) &
socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0);
- writel((readl(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0) & ~CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK) | CLKMGR_PERPLL_VCO0_EN_SET_MSK,
&clock_manager_base->per_pll.vco0);
socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0);
/* setup all the main PLL counter and clock source */
- writel(main_cfg->nocclk,
SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET);
- writel(main_cfg->mpuclk,
SOCFPGA_CLKMGR_ADDRESS + CLKMGR_ALTERAGRP_MPU_CLK_OFFSET);
writel(main_cfg->nocclk, socfpga_clkmgr_base + CLKMGR_A10_ALTR_NOCCLK);
writel(main_cfg->mpuclk, socfpga_clkmgr_base + CLKMGR_A10_ALTR_MPUCLK);
/* main_emaca_clk divider */
- writel(main_cfg->cntr2clk_cnt, &clock_manager_base->main_pll.cntr2clk);
/* main_emacb_clk divider */socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR2CLK);
- writel(main_cfg->cntr3clk_cnt, &clock_manager_base->main_pll.cntr3clk);
/* main_emac_ptp_clk divider */socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR3CLK);
- writel(main_cfg->cntr4clk_cnt, &clock_manager_base->main_pll.cntr4clk);
/* main_gpio_db_clk divider */socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR4CLK);
- writel(main_cfg->cntr5clk_cnt, &clock_manager_base->main_pll.cntr5clk);
/* main_sdmmc_clk divider */socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR5CLK);
- writel(main_cfg->cntr6clk_cnt, &clock_manager_base->main_pll.cntr6clk);
/* main_s2f_user0_clk divider */ writel(main_cfg->cntr7clk_cnt | (main_cfg->cntr7clk_src << CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR6CLK);
/* main_s2f_user1_clk divider */socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR7CLK);
- writel(main_cfg->cntr8clk_cnt, &clock_manager_base->main_pll.cntr8clk);
/* main_hmc_pll_clk divider */ writel(main_cfg->cntr9clk_cnt | (main_cfg->cntr9clk_src << CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR8CLK);
/* main_periph_ref_clk divider */ writel(main_cfg->cntr15clk_cnt,socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR9CLK);
&clock_manager_base->main_pll.cntr15clk);
socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_CNTR15CLK);
/* setup all the peripheral PLL counter and clock source */ /* peri_emaca_clk divider */ writel(per_cfg->cntr2clk_cnt | (per_cfg->cntr2clk_src << CLKMGR_PERPLL_CNTR2CLK_SRC_LSB),
/* peri_emacb_clk divider */ writel(per_cfg->cntr3clk_cnt | (per_cfg->cntr3clk_src << CLKMGR_PERPLL_CNTR3CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR2CLK);
/* peri_emac_ptp_clk divider */ writel(per_cfg->cntr4clk_cnt | (per_cfg->cntr4clk_src << CLKMGR_PERPLL_CNTR4CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR3CLK);
/* peri_gpio_db_clk divider */ writel(per_cfg->cntr5clk_cnt | (per_cfg->cntr5clk_src << CLKMGR_PERPLL_CNTR5CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR4CLK);
/* peri_sdmmc_clk divider */ writel(per_cfg->cntr6clk_cnt | (per_cfg->cntr6clk_src << CLKMGR_PERPLL_CNTR6CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR5CLK);
/* peri_s2f_user0_clk divider */socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR6CLK);
- writel(per_cfg->cntr7clk_cnt, &clock_manager_base->per_pll.cntr7clk);
/* peri_s2f_user1_clk divider */ writel(per_cfg->cntr8clk_cnt | (per_cfg->cntr8clk_src << CLKMGR_PERPLL_CNTR8CLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR7CLK);
/* peri_hmc_pll_clk divider */socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR8CLK);
- writel(per_cfg->cntr9clk_cnt, &clock_manager_base->per_pll.cntr9clk);
socfpga_clkmgr_base + CLKMGR_A10_PERPLL_CNTR9CLK);
/* setup all the external PLL counter */ /* mpu wrapper / external divider */ writel(main_cfg->mpuclk_cnt | (main_cfg->mpuclk_src << CLKMGR_MAINPLL_MPUCLK_SRC_LSB),
/* NOC wrapper / external divider */ writel(main_cfg->nocclk_cnt | (main_cfg->nocclk_src << CLKMGR_MAINPLL_NOCCLK_SRC_LSB),socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_MPUCLK);
/* NOC subclock divider such as l4 */ writel(main_cfg->nocdiv_l4mainclk | (main_cfg->nocdiv_l4mpclk <<socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_NOCCLK);
/* gpio_db external divider */ writel(per_cfg->gpiodiv_gpiodbclk,socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_NOCDIV);
- setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); /* assert perpll outresetall */
- setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_PERPLL_VCO0, CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); /* de-assert mainpll outresetall */
- clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_MAINPLL_VCO0, CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); /* de-assert perpll outresetall */
- clrbits_le32(socfpga_clkmgr_base + CLKMGR_A10_CTRL, CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK); /* wait till Clock Manager is not busy */ cm_wait_for_fsm();
return 0; }
- setbits_le32(socfpga_clkmgr_base + CLKMGR_A10_CTRL, CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK); }
- function to write the bypass register which requires a poll of the
- busy bit
- writel(val, socfpga_clkmgr_base + CLKMGR_GEN5_CTRL); cm_wait_for_fsm(); }
writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK,socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO);
writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK,socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO);
- The clocks to the flash devices and the L4_MAIN clocks can
writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE,socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC);
- We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN
- with numerator and denominator.
- Time starts here. Must wait 7 us from
/* main mpu */
/* main for dbg */
/* Peri QSPI */
- writel(cfg->maindiv, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINDIV);
- writel(cfg->dbgdiv, socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_DBGDIV);
- writel(cfg->perdiv, socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_DIV);
- after locking, but before taking out of bypass
- assert/deassert outresetall
- now that we've toggled outreset all, all the clocks
- are aligned nicely; so we can change any phase.
if (ret) return ret;CLKMGR_GEN5_SDRPLL_S2FUSER2CLK), CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK);
- now that safe mode is clear with clocks gated
- it safe to change the source mux for the flashes the the L4_MAIN
return 0; }
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_VCO); clock = cm_get_osc_clk_hz(1); clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1;
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; if (reg == CLKMGR_VCO_SSRC_EOSC1)
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_VCO); clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >>
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_ALTR_MPUCLK); clock /= (reg + 1);
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MPUCLK); clock /= (reg + 1); return clock; }
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_VCO); reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; if (reg == CLKMGR_VCO_SSRC_EOSC1)
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_SDRPLL_DDRDQSCLK); reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; clock /= (reg + 1);
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_L4SRC); reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET;
clock /= (reg + 1);reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_ALTR_MAINCLK);
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_MAINPLL_MAINDIV); reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; clock = clock / (1 << reg);
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET;
clock /= (reg + 1); }CLKMGR_GEN5_PERPLL_PERNANDSDMMCCLK);
- reg = readl(socfpga_clkmgr_base + CLKMGR_GEN5_PERPLL_SRC); reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET;
clock /= (reg + 1); }CLKMGR_GEN5_PERPLL_PERQSPICLK);
return clock;
- busy bit
- writel(val, socfpga_clkmgr_base + CLKMGR_S10_CTRL); cm_wait_for_fsm(); }
writel(vcocalib,
- setbits_le32(socfpga_clkmgr_base + CLKMGR_S10_MAINPLL_PLLGLOB, CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK);
break;
break;CLKMGR_S10_PERPLL_PLLC0) & CLKMGR_CLKCNT_MSK);
CLKMGR_CLKCNT_MSK);
CLKMGR_CLKCNT_MSK);
return clock; }
break;
break;clock /= (readl(socfpga_clkmgr_base + CLKMGR_S10_PERPLL_PLLC1) & CLKMGR_CLKCNT_MSK);
CLKMGR_CLKCNT_MSK);
CLKMGR_CLKCNT_MSK);
break;
CLKMGR_CLKCNT_MSK);
CLKMGR_CLKCNT_MSK);
break;
- clock /= (1 << ((readl(socfpga_clkmgr_base +
return clock; }CLKMGR_NOCDIV_L4SPCLK_OFFSET) & CLKMGR_CLKCNT_MSK));
return clock; }CLKMGR_NOCDIV_L4MAIN_OFFSET) & CLKMGR_CLKCNT_MSK));
- #ifndef __ASSEMBLER__ void cm_wait_for_lock(u32 mask); int cm_wait_for_fsm(void);
- u32 vco0;
- u32 vco1;
- u32 en;
- u32 ens;
- u32 enr;
- u32 bypass;
- u32 bypasss;
- u32 bypassr;
- u32 mpuclk;
- u32 nocclk;
- u32 cntr2clk;
- u32 cntr3clk;
- u32 cntr4clk;
- u32 cntr5clk;
- u32 cntr6clk;
- u32 cntr7clk;
- u32 cntr8clk;
- u32 cntr9clk;
- u32 cntr15clk;
- u32 outrst;
- u32 outrststat;
- u32 nocdiv;
- u32 vco0;
- u32 vco1;
- u32 en;
- u32 ens;
- u32 enr;
- u32 bypass;
- u32 bypasss;
- u32 bypassr;
- u32 cntr2clk;
- u32 cntr3clk;
- u32 cntr4clk;
- u32 cntr5clk;
- u32 cntr6clk;
- u32 cntr7clk;
- u32 cntr8clk;
- u32 cntr9clk;
- u32 outrst;
- u32 outrststat;
- u32 emacctl;
- u32 gpiodiv;
- u32 mpuclk;
- u32 nocclk;
- u32 mainmisc0;
- u32 mainmisc1;
- u32 perimisc0;
- u32 perimisc1;
- /* clkmgr */
- u32 ctrl;
- u32 intr;
- u32 intrs;
- u32 intrr;
- u32 intren;
- u32 intrens;
- u32 intrenr;
- u32 stat;
- u32 testioctrl;
- /* mainpllgrp */
- /* perpllgrp */
Same formatting issue as in 2/4 and 3/4. I'll skip the same warning further below multiple times...
Based on the previous patches, the rest looks fine.
- u32 vco;
- u32 misc;
- u32 mpuclk;
- u32 mainclk;
- u32 dbgatclk;
- u32 mainqspiclk;
- u32 en;
- u32 maindiv;
- u32 dbgdiv;
- u32 tracediv;
- u32 l4src;
- u32 stat;
- u32 vco;
- u32 misc;
- u32 emac0clk;
- u32 emac1clk;
- u32 perqspiclk;
- u32 perbaseclk;
- u32 s2fuser1clk;
- u32 en;
- u32 div;
- u32 gpiodiv;
- u32 src;
- u32 stat;
- u32 vco;
- u32 ctrl;
- u32 ddrdqsclk;
- u32 ddr2xdqsclk;
- u32 ddrdqclk;
- u32 s2fuser2clk;
- u32 en;
- u32 stat;
- u32 mpuclk;
- u32 mainclk;
- u32 ctrl;
- u32 bypass;
- u32 inter;
- u32 intren;
- u32 dbctrl;
- u32 stat;
- u32 en;
- u32 ens;
- u32 enr;
- u32 bypass;
- u32 bypasss;
- u32 bypassr;
- u32 mpuclk;
- u32 nocclk;
- u32 cntr2clk;
- u32 cntr3clk;
- u32 cntr4clk;
- u32 cntr5clk;
- u32 cntr6clk;
- u32 cntr7clk;
- u32 cntr8clk;
- u32 cntr9clk;
- u32 nocdiv;
- u32 pllglob;
- u32 fdbck;
- u32 mem;
- u32 memstat;
- u32 pllc0;
- u32 pllc1;
- u32 vcocalib;
- u32 en;
- u32 ens;
- u32 enr;
- u32 bypass;
- u32 bypasss;
- u32 bypassr;
- u32 cntr2clk;
- u32 cntr3clk;
- u32 cntr4clk;
- u32 cntr5clk;
- u32 cntr6clk;
- u32 cntr7clk;
- u32 cntr8clk;
- u32 cntr9clk;
- u32 emacctl;
- u32 gpiodiv;
- u32 pllglob;
- u32 fdbck;
- u32 mem;
- u32 memstat;
- u32 pllc0;
- u32 pllc1;
- u32 vcocalib;
- u32 ctrl;
- u32 stat;
- u32 testioctrl;
- u32 intrgen;
- u32 intrmsk;
- u32 intrclr;
- u32 intrsts;
- u32 intrstk;
- u32 intrraw;
- socfpga_clkmgr_base = socfpga_get_base_addr("altr,clk-mgr");
- if (!socfpga_clkmgr_base)
}hang();
On Thu, Oct 10, 2019 at 3:37 PM Ley Foon Tan ley.foon.tan@intel.com wrote:
This is 4th version of patchset to convert reset, system and clock manager drivers to use #define instead of struct. This patchset get managers' base address from DT node instead of using #define.
Patch 1 unchanged, patch 2,3,4 update commit message.
Tested on Cyclone 5, Arria 10 and Stratix 10 devices.
Changes in v4:
- Patch 2,3,4: Update commit message.
History: v1: https://patchwork.ozlabs.org/cover/1149731/ v2: https://patchwork.ozlabs.org/cover/1160079/ v3: https://patchwork.ozlabs.org/cover/1174327/
Hi
Any further comments on this series?
Regards Ley Foon
Ley Foon Tan (4): arm: dts: socfpga: Add u-boot,dm-pre-reloc for sysmgr and clkmgr nodes arm: socfpga: Convert reset manager from struct to defines arm: socfpga: Convert system manager from struct to defines arm: socfpga: Convert clock manager from struct to defines
arch/arm/dts/socfpga-common-u-boot.dtsi | 8 + arch/arm/dts/socfpga.dtsi | 2 +- arch/arm/dts/socfpga_arria10.dtsi | 2 +- arch/arm/dts/socfpga_arria10_socdk.dtsi | 8 + arch/arm/dts/socfpga_stratix10.dtsi | 2 +- .../dts/socfpga_stratix10_socdk-u-boot.dtsi | 8 + arch/arm/mach-socfpga/clock_manager.c | 12 +- arch/arm/mach-socfpga/clock_manager_arria10.c | 156 +++++++------ arch/arm/mach-socfpga/clock_manager_gen5.c | 199 +++++++++-------- arch/arm/mach-socfpga/clock_manager_s10.c | 210 ++++++++++-------- .../mach-socfpga/include/mach/clock_manager.h | 2 + .../include/mach/clock_manager_arria10.h | 133 +++++------ .../include/mach/clock_manager_gen5.h | 112 ++++------ .../include/mach/clock_manager_s10.h | 115 ++++------ arch/arm/mach-socfpga/include/mach/misc.h | 1 + .../mach-socfpga/include/mach/reset_manager.h | 2 + .../include/mach/reset_manager_arria10.h | 43 +--- .../include/mach/reset_manager_gen5.h | 22 +- .../include/mach/reset_manager_s10.h | 33 +-- .../include/mach/system_manager.h | 2 + .../include/mach/system_manager_arria10.h | 94 +++----- .../include/mach/system_manager_gen5.h | 123 ++-------- .../include/mach/system_manager_s10.h | 184 ++++++--------- arch/arm/mach-socfpga/mailbox_s10.c | 6 +- arch/arm/mach-socfpga/misc.c | 42 ++++ arch/arm/mach-socfpga/misc_arria10.c | 9 +- arch/arm/mach-socfpga/misc_gen5.c | 29 +-- arch/arm/mach-socfpga/misc_s10.c | 9 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 71 +++--- arch/arm/mach-socfpga/reset_manager_gen5.c | 35 ++- arch/arm/mach-socfpga/reset_manager_s10.c | 52 +++-- arch/arm/mach-socfpga/scan_manager.c | 6 +- arch/arm/mach-socfpga/spl_a10.c | 12 +- arch/arm/mach-socfpga/spl_gen5.c | 23 +- arch/arm/mach-socfpga/spl_s10.c | 24 +- arch/arm/mach-socfpga/system_manager_gen5.c | 38 ++-- arch/arm/mach-socfpga/system_manager_s10.c | 39 ++-- arch/arm/mach-socfpga/wrap_pll_config_s10.c | 11 +- drivers/ddr/altera/sdram_gen5.c | 10 +- drivers/ddr/altera/sdram_s10.c | 6 +- drivers/fpga/socfpga_arria10.c | 7 +- drivers/fpga/socfpga_gen5.c | 4 +- drivers/mmc/socfpga_dw_mmc.c | 17 +- drivers/sysreset/sysreset_socfpga.c | 6 +- 44 files changed, 880 insertions(+), 1049 deletions(-)
-- 2.19.0
Ley Foon Tan
Ley Foon Tan
Simon Goldschmidt
