[U-Boot] [PATCH v2 00/19] First step towards Kbuild: Use Kbuild style makefiles
Kbuild in U-Boot has been talked for a while and RFC patches were posted by Simon Glass.
(Refer to "RFC: Add Kbuild system to U-Boot" posted by Simon, May 12, 2013)
Simon's effort is a good start point but varous critical features were missing from his patch series.
I have also been eager to introduce Kbuild to U-Boot. So I have been working on this task for a while with a little different migration path from Simon's way. At last I succeeded to build a few boards with support of SPL build, Out-of-tree build, correct output file names, which were missing from Simon's patches.
While I were working on my local branch, the build system and makefiles in U-Boot master repository always kept changing, of course.
Now my fruit got too old to fit with the current u-boot/master anymore. But if someone is interested in my work, I can push my local branch to somewhere in my GitHub space. (RFC quality, but might be helpful for just discussions)
I recognize those patches are so rough that they could support only a few ARM boards. Perfectly covering all architectures and all boards without breaking any U-Boot features is a too big task for a sigle indivisual.
Even if I could do that, the patch series would be extremely big size and the adjustment for U-Boot would be complecated. So the review would probably take very long time. Along with the review process, as time goes by, the posted patches would become not appled to the master branch.
So we would need to repeat post, review, fix, rebase on the master and post again, review, ... again and again for a very big patch series.
I began to be wondering whether it is really possible to switch to Kbuild in this way.
So I decided to begin with what I can do, one by one. By stepping little by litte, we can get close to Kbuild and finally we will arrive at our goal. I think this strategy is more realistic rather than adding a big change at one time.
Before importing a real Kbuild, I'd like to adjust our makefiles in the form suitable for Kbuild.
First of all, this series converts makefiles in sub directories to Kbuild style.
What this series do is quite simple: - Moving common lines in sub makefiles to a new file 'scripts/Makefile.build' - Renaming COBJS-y and SOBJS-y to obj-y in each sub makefile. - A little bit more tweaks
That's all.
01/19 creates scripts/Makefile.build and tweaks Makefile and spl/Makefile to use scripts/Makefile.build.
U-Boot conventional makefiles are like this:
include $(TOPDIR)/config.mk
LIB = $(obj)libfoo.o
COBJS := ... COBJS += ... SOBJS := ...
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
all: $(obj).depend $(LIB)
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
include $(SRCTREE)/rules.mk
sinclude $(obj).depend
Top and bottom parts are common in almost all makefiles. Writing those lines in all makefiles is a big waste. So common lines have been pushed into scripts/Makefile.build. In addition, scripts/Makefile.build includes a glue code for supporting 'obj-y'. Be aware U-Boot conventional (non-Kbuild) makefile sytle is still supported. So we can change sub makefiles little by little in the following patches.
02/19-19/19 change sub makefiles into a Kbuild suitable form using obj-y. In order to avoid creating a big patch file, they are divided by CPU architectures and categories.
02/19-07/19: refactor under arch/arm/ 08/19-16/19: refactor libraries which are commonly used for all architectures 17/19 : refactor under arch/sandbox 18/19 : refactor under arch/powerpc/ 19/19 : refactor under board/ti/
Conversion rule is pretty easy:
(1) Delete common parts at top and bottom. (2) Rename COBJS -> obj-y SOBJS -> obj-y COBJS-$(CONFIG_FOO) -> obj-$(CONFIG_FOO) SOBJS-$(CONFIG_FOO) -> obj-$(CONFIG_FOO) START -> extra-y
We can convert almost automatically althogh in some cases we may need to tweak a little.
I refactored more than 150 makefiles in this series. But we still have more than 600 makefiles. (Most of them reside under board/ directory) We can convert them lator little by little. Your contribution is welcome! :-)
Note1: This series breaks _NO_ features in U-Boot beucase it just moves common parts into scripts/Makefile.build
In order to prove this series does no harm, I compiled all boards excepts nds32 and nios2 architectures and checked md5sum matching for ./u-boot (and spl/u-boot-spl if it exists).
I tried md5sum for version 1 and I did the same thing again for version 2. I confirmed md5sum perfectly matched.
For the detailed steps how to compare md5sum, please refer to the discussion in version 1: [U-Boot] [PATCH 00/19] First step towards Kbuild: Use Kbuild style makefiles
Note2: This series is _NOT_ RFC. I believe what these patches are doing is clear. 01/19 changes less than 100 lines. 02/19-19/19 changes lots of makefiles, but the conversion rule is simple.
So, I expect this series will be reviewed in a few weeks and applied to master when the next merge window opens or hopefully included into u-boot-2013.10 release.
Note3: obj-y := foo/ (descending into foo sub directory) syntax is not supprted in this series. It is implemented in upcoming patch series. The reason why I postpone this feature is I don't want to add a big change at one time. Adjusting for Kbuild little by litte is my strategy here for easy review.
Note4: Of course, scripts/Makefile.build added by 01/19 patch is temporary. It shall be replaced with the one of Linux Kernel in future.
Note5: 01/19 is a prerequisite for 02/19 to 19/19. But 02/19 thru 19/19 are order-independent. If some of 02/19-19/19 becomes not applied to u-boot/master, they can be omitted.
Changes for v2: 01/19: fix commit log (purely cosmetic) 02/19: updated 3 files to rebase on the master arch/arm/cpu/armv7/mx6/Makefile arch/arm/cpu/armv7/socfpga/Makefile arch/arm/cpu/armv7/zynq/Makefile 03/19-10/19: No change 11/19: updated 6 files to rebase on the master drivers/serial/Makefile drivers/mmc/Makefile drivers/video/Makefile drivers/watchdog/Makefile drivers/rtc/Makefile drivers/i2c/Makefile 12/19-17/19: No change 18/19: fixed one file arch/powerpc/cpu/mpc8260/Makefile (See version 1 thread for detailed readon why this file should be fixed) 19/19: No change
Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com Cc: Gerhard Sittig gsi@denx.de
Masahiro Yamada (19): Makefile: prepare for using Kbuild-style Makefile armv7: convert makefiles to Kbuild style arm926ejs: convert makefiles to Kbuild style arm920t: convert makefiles to Kbuild style arm720t: convert makefiles to Kbuild style ARM: convert makefiles to Kbuild style ARM: imx-common: convert makefiles to Kbuild style drivers: net: convert makefiles to Kbuild style drivers: mtd: convert makefiles to Kbuild style drivers: usb: convert makefiles to Kbuild style drivers: convert makefiles to Kbuild style fs: convert makefiles to Kbuild style common: convert makefiles to Kbuild style net: convert a makefile to Kbuild style lib: convert makefiles to Kbuild style disk: convert a makefile to Kbuild style sandbox: convert makefiles to Kbuild style powerpc: convert makefiles to Kbuild style board: ti: convert makefiles to Kbuild style
Makefile | 42 +++- arch/arm/cpu/arm1136/Makefile | 26 +- arch/arm/cpu/arm1136/mx31/Makefile | 27 +- arch/arm/cpu/arm1136/mx35/Makefile | 28 +-- arch/arm/cpu/arm1176/Makefile | 26 +- arch/arm/cpu/arm1176/bcm2835/Makefile | 25 +- arch/arm/cpu/arm1176/tnetv107x/Makefile | 27 +- arch/arm/cpu/arm720t/Makefile | 26 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 25 +- arch/arm/cpu/arm720t/tegra114/Makefile | 25 +- arch/arm/cpu/arm720t/tegra20/Makefile | 23 +- arch/arm/cpu/arm720t/tegra30/Makefile | 23 +- arch/arm/cpu/arm920t/Makefile | 28 +-- arch/arm/cpu/arm920t/a320/Makefile | 25 +- arch/arm/cpu/arm920t/at91/Makefile | 33 +-- arch/arm/cpu/arm920t/ep93xx/Makefile | 24 +- arch/arm/cpu/arm920t/imx/Makefile | 27 +- arch/arm/cpu/arm920t/ks8695/Makefile | 26 +- arch/arm/cpu/arm920t/s3c24x0/Makefile | 29 +-- arch/arm/cpu/arm925t/Makefile | 30 +-- arch/arm/cpu/arm926ejs/Makefile | 28 +-- arch/arm/cpu/arm926ejs/armada100/Makefile | 23 +- arch/arm/cpu/arm926ejs/at91/Makefile | 59 ++--- arch/arm/cpu/arm926ejs/davinci/Makefile | 48 +--- arch/arm/cpu/arm926ejs/kirkwood/Makefile | 31 +-- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 23 +- arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 25 +- arch/arm/cpu/arm926ejs/mx25/Makefile | 23 +- arch/arm/cpu/arm926ejs/mx27/Makefile | 23 +- arch/arm/cpu/arm926ejs/mxs/Makefile | 26 +- arch/arm/cpu/arm926ejs/nomadik/Makefile | 25 +- arch/arm/cpu/arm926ejs/omap/Makefile | 26 +- arch/arm/cpu/arm926ejs/orion5x/Makefile | 29 +-- arch/arm/cpu/arm926ejs/pantheon/Makefile | 23 +- arch/arm/cpu/arm926ejs/spear/Makefile | 36 +-- arch/arm/cpu/arm926ejs/versatile/Makefile | 26 +- arch/arm/cpu/arm946es/Makefile | 26 +- arch/arm/cpu/arm_intcm/Makefile | 26 +- arch/arm/cpu/armv7/Makefile | 32 +-- arch/arm/cpu/armv7/am33xx/Makefile | 51 +--- arch/arm/cpu/armv7/at91/Makefile | 31 +-- arch/arm/cpu/armv7/exynos/Makefile | 34 +-- arch/arm/cpu/armv7/highbank/Makefile | 24 +- arch/arm/cpu/armv7/mx5/Makefile | 25 +- arch/arm/cpu/armv7/mx6/Makefile | 25 +- arch/arm/cpu/armv7/omap-common/Makefile | 43 +--- arch/arm/cpu/armv7/omap3/Makefile | 41 +-- arch/arm/cpu/armv7/omap4/Makefile | 31 +-- arch/arm/cpu/armv7/omap5/Makefile | 33 +-- arch/arm/cpu/armv7/rmobile/Makefile | 51 +--- arch/arm/cpu/armv7/s5p-common/Makefile | 29 +-- arch/arm/cpu/armv7/s5pc1xx/Makefile | 27 +- arch/arm/cpu/armv7/socfpga/Makefile | 29 +-- arch/arm/cpu/armv7/tegra-common/Makefile | 24 +- arch/arm/cpu/armv7/tegra114/Makefile | 22 +- arch/arm/cpu/armv7/tegra20/Makefile | 26 +- arch/arm/cpu/armv7/tegra30/Makefile | 22 +- arch/arm/cpu/armv7/u8500/Makefile | 25 +- arch/arm/cpu/armv7/vf610/Makefile | 25 +- arch/arm/cpu/armv7/zynq/Makefile | 31 +-- arch/arm/cpu/ixp/Makefile | 30 +-- arch/arm/cpu/pxa/Makefile | 36 +-- arch/arm/cpu/sa1100/Makefile | 28 +-- arch/arm/cpu/tegra-common/Makefile | 25 +- arch/arm/cpu/tegra114-common/Makefile | 23 +- arch/arm/cpu/tegra20-common/Makefile | 29 +-- arch/arm/cpu/tegra30-common/Makefile | 26 +- arch/arm/imx-common/Makefile | 35 +-- arch/arm/lib/Makefile | 86 ++----- arch/powerpc/cpu/74xx_7xx/Makefile | 28 +-- arch/powerpc/cpu/mpc512x/Makefile | 51 ++-- arch/powerpc/cpu/mpc5xx/Makefile | 27 +- arch/powerpc/cpu/mpc5xxx/Makefile | 54 ++-- arch/powerpc/cpu/mpc824x/Makefile | 28 +-- arch/powerpc/cpu/mpc8260/Makefile | 32 +-- arch/powerpc/cpu/mpc83xx/Makefile | 58 ++--- arch/powerpc/cpu/mpc85xx/Makefile | 233 ++++++++--------- arch/powerpc/cpu/mpc86xx/Makefile | 50 ++-- arch/powerpc/cpu/mpc8xx/Makefile | 58 ++--- arch/powerpc/cpu/mpc8xxx/Makefile | 30 +-- arch/powerpc/cpu/mpc8xxx/ddr/Makefile | 30 +-- arch/powerpc/cpu/ppc4xx/Makefile | 90 +++---- arch/powerpc/lib/Makefile | 78 ++---- arch/sandbox/cpu/Makefile | 23 +- arch/sandbox/lib/Makefile | 25 +- board/ti/am335x/Makefile | 29 +-- board/ti/am3517crane/Makefile | 19 +- board/ti/am43xx/Makefile | 29 +-- board/ti/beagle/Makefile | 24 +- board/ti/dra7xx/Makefile | 27 +- board/ti/evm/Makefile | 19 +- board/ti/omap1510inn/Makefile | 24 +- board/ti/omap5912osk/Makefile | 24 +- board/ti/omap5_uevm/Makefile | 27 +- board/ti/omap730p2/Makefile | 24 +- board/ti/panda/Makefile | 21 +- board/ti/sdp3430/Makefile | 21 +- board/ti/sdp4430/Makefile | 23 +- board/ti/ti814x/Makefile | 29 +-- board/ti/ti816x/Makefile | 27 +- board/ti/tnetv107xevm/Makefile | 25 +- common/Makefile | 389 ++++++++++++++--------------- common/spl/Makefile | 36 +-- disk/Makefile | 34 +-- drivers/bios_emulator/Makefile | 23 +- drivers/block/Makefile | 52 ++-- drivers/bootcount/Makefile | 30 +-- drivers/crypto/Makefile | 25 +- drivers/dfu/Makefile | 25 +- drivers/dma/Makefile | 30 +-- drivers/fpga/Makefile | 44 +--- drivers/gpio/Makefile | 73 ++---- drivers/hwmon/Makefile | 40 +-- drivers/i2c/Makefile | 68 ++--- drivers/input/Makefile | 36 +-- drivers/misc/Makefile | 52 ++-- drivers/mmc/Makefile | 71 ++---- drivers/mtd/Makefile | 44 +--- drivers/mtd/nand/Makefile | 102 +++----- drivers/mtd/onenand/Makefile | 27 +- drivers/mtd/spi/Makefile | 48 +--- drivers/mtd/ubi/Makefile | 28 +-- drivers/net/Makefile | 136 +++++----- drivers/net/fm/Makefile | 59 ++--- drivers/net/npe/Makefile | 24 +- drivers/net/phy/Makefile | 60 ++--- drivers/pci/Makefile | 44 +--- drivers/pcmcia/Makefile | 34 +-- drivers/power/Makefile | 47 +--- drivers/power/battery/Makefile | 25 +- drivers/power/fuel_gauge/Makefile | 25 +- drivers/power/pmic/Makefile | 31 +-- drivers/qe/Makefile | 25 +- drivers/rtc/Makefile | 108 ++++---- drivers/serial/Makefile | 82 +++--- drivers/sound/Makefile | 30 +-- drivers/spi/Makefile | 82 +++--- drivers/tpm/Makefile | 29 +-- drivers/twserial/Makefile | 24 +- drivers/usb/eth/Makefile | 28 +-- drivers/usb/gadget/Makefile | 54 ++-- drivers/usb/host/Makefile | 74 ++---- drivers/usb/musb-new/Makefile | 36 +-- drivers/usb/musb/Makefile | 36 +-- drivers/usb/phy/Makefile | 24 +- drivers/usb/ulpi/Makefile | 28 +-- drivers/video/Makefile | 86 +++---- drivers/watchdog/Makefile | 38 +-- fs/Makefile | 24 +- fs/cbfs/Makefile | 24 +- fs/cramfs/Makefile | 29 +-- fs/ext4/Makefile | 27 +- fs/fat/Makefile | 31 +-- fs/fdos/Makefile | 27 +- fs/jffs2/Makefile | 38 +-- fs/reiserfs/Makefile | 26 +- fs/sandbox/Makefile | 23 +- fs/ubifs/Makefile | 29 +-- fs/yaffs2/Makefile | 33 +-- fs/zfs/Makefile | 25 +- lib/Makefile | 114 ++++----- lib/libfdt/Makefile | 27 +- lib/lzma/Makefile | 24 +- lib/lzo/Makefile | 24 +- lib/rsa/Makefile | 22 +- lib/tizen/Makefile | 24 +- lib/zlib/Makefile | 22 +- net/Makefile | 46 +--- scripts/Makefile.build | 48 ++++ spl/Makefile | 24 +- 170 files changed, 1515 insertions(+), 5099 deletions(-) create mode 100644 scripts/Makefile.build
In every sub directory, Makefile is like follows:
Top and bottom parts are common in almost all sub-makefiles. This is a big waste. This commit pushes common parts of makefiles into script/Makefile.build.
Going forward sub-makefiles only need to describe this part:
But, script/Makefile.build includes the glue code to support obj-y, the following style (the same as Kbuild) is preferable:
obj-y := ... obj-$(CONFIG_FOO) += ... obj-$(CONFIG_BAR) += ...
The conventional (non-Kbuild) Makefile style is still supported. This is achieved by greping the Makefile before entering into it. U-Boot conventional sub makefiles always include some other makefiles. So the build system searches a line beginning with "include" keyword in the makefile in order to distinguish which style it is. If the Makefile include a "include" line, we assume it is a conventional U-Boot style. Otherwise, it is treated as a Kbuild-style makefile.
(At first, I tried to grep "rules.mk" keyword instead, but I found it does not work. Almost all sub makefiles include "rules.mk", but there exist three exception: - board/avnet/fx12mm/Makefile - board/avnet/v5fx30teval/Makefile - board/xilinx/ml507/Makefile These three makefiles include "rules.mk" indirectly. Anyway, they look weird, so they should be fixed lator.)
With this tweak, we can switch sub-makefiles from U-Boot style to Kbuild style little by little.
This refactoring of sub makefiles is the first step towards Kbuild, and makes it easy to import a "real" Kbuild from Linux Kernel.
Note that this refactoring breaks nothing because it just moves the common parts into scripts/Makefile.build.
Note one more thing:
obj-y := foo/ # descending into foo sub directory
syntax is not supported yet. (This feature will be implemented in the upcoming commit.)
Of course, scripts/Makefile.build added by this commit is temporary. It shall be replaced with the one of Linux Kernel in future.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com ---
Changes for v2: - fix commit log (purely cosmetic)
Makefile | 34 ++++++++++++++++++++++++++++++---- scripts/Makefile.build | 48 ++++++++++++++++++++++++++++++++++++++++++++++++ spl/Makefile | 20 ++++++++++++++++++-- 3 files changed, 96 insertions(+), 6 deletions(-) create mode 100644 scripts/Makefile.build
diff --git a/Makefile b/Makefile index 07abef4..36bbd09 100644 --- a/Makefile +++ b/Makefile @@ -593,14 +593,35 @@ ifeq ($(CONFIG_KALLSYMS),y) $(GEN_UBOOT) $(obj)common/system_map.o endif
+# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles +# U-Boot conventional sub makefiles always include some other makefiles. +# So, the build system searches a line beginning with "include" before entering into the sub makefile +# in order to distinguish which style it is. +# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. +# Otherwise, it is treated as a Kbuild-style makefile. + +# We do not need to build $(OBJS) explicitly. +# It is built while we are at $(CPUDIR)/lib$(CPU).o build. $(OBJS): depend - $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)) + if grep -q "^include" $(CPUDIR)/Makefile; then \ + $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)); \ + fi
$(LIBS): depend $(SUBDIR_TOOLS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + if grep -q "^include" $(dir $(subst $(obj),,$@))Makefile; then \ + $(MAKE) -C $(dir $(subst $(obj),,$@)); \ + else \ + $(MAKE) -C $(dir $(subst $(obj),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(LIBBOARD): depend $(LIBS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + if grep -q "^include" $(dir $(subst $(obj),,$@))/Makefile; then \ + $(MAKE) -C $(dir $(subst $(obj),,$@)); \ + else \ + $(MAKE) -C $(dir $(subst $(obj),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(SUBDIRS): depend $(MAKE) -C $@ all @@ -637,7 +658,12 @@ depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ $(obj)include/generated/generic-asm-offsets.h \ $(obj)include/generated/asm-offsets.h for dir in $(SUBDIRS) $(CPUDIR) $(LDSCRIPT_MAKEFILE_DIR) ; do \ - $(MAKE) -C $$dir _depend ; done + if grep -q "^include" $$dir/Makefile; then \ + $(MAKE) -C $$dir _depend ; \ + else \ + $(MAKE) -C $$dir -f $(TOPDIR)/scripts/Makefile.build _depend; \ + fi; \ + done
TAG_SUBDIRS = $(SUBDIRS) TAG_SUBDIRS += $(dir $(__LIBS)) diff --git a/scripts/Makefile.build b/scripts/Makefile.build new file mode 100644 index 0000000..f969ec5 --- /dev/null +++ b/scripts/Makefile.build @@ -0,0 +1,48 @@ +# our default target +.PHONY: all +all: + +include $(TOPDIR)/config.mk + +LIB := $(obj)built-in.o +LIBGCC = $(obj)libgcc.o +SRCS := + +include Makefile + +# Backward compatible: obj-y is preferable +COBJS := $(sort $(COBJS) $(COBJS-y)) +SOBJS := $(sort $(SOBJS) $(SOBJS-y)) + +# Going forward use the following +obj-y := $(sort $(obj-y)) +extra-y := $(sort $(extra-y)) +lib-y := $(sort $(lib-y)) + +SRCS += $(COBJS:.o=.c) $(SOBJS:.o=.S) \ + $(wildcard $(obj-y:.o=.c) $(obj-y:.o=.S) $(lib-y:.o=.c) $(lib-y:.o=.S) $(extra-y:.o=.c) $(extra-y:.o=.S)) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS) $(obj-y)) + +LGOBJS := $(addprefix $(obj),$(sort $(GLSOBJS) $(GLCOBJS)) $(lib-y)) + +all: $(LIB) $(addprefix $(obj),$(extra-y)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +ifneq ($(strip $(lib-y)),) +all: $(LIBGCC) + +$(LIBGCC): $(obj).depend $(LGOBJS) + $(call cmd_link_o_target, $(LGOBJS)) +endif + +######################################################################### + +# defines $(obj).depend target + +include $(TOPDIR)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/spl/Makefile b/spl/Makefile index 174d0a7..48f2c65 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -199,11 +199,27 @@ GEN_UBOOT = \ $(obj)$(SPL_BIN): depend $(START) $(LIBS) $(obj)u-boot-spl.lds $(GEN_UBOOT)
+# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles +# U-Boot conventional sub makefiles always include some other makefiles. +# So, the build system searches a line beginning with "include" before entering into the sub makefile +# in order to distinguish which style it is. +# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. +# Otherwise, it is treated as a Kbuild-style makefile. + +# We do not need to build $(START) explicitly. +# It is built while we are at $(CPUDIR)/lib$(CPU).o build. $(START): depend - $(MAKE) -C $(SRCTREE)/$(START_PATH) $@ + if grep -q "^include" $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))Makefile; then \ + $(MAKE) -C $(SRCTREE)/$(START_PATH) $@; \ + fi
$(LIBS): depend - $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)) + if grep -q "^include" $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))Makefile; then \ + $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)); \ + else \ + $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(obj)u-boot-spl.lds: $(LDSCRIPT) depend $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj). -ansi -D__ASSEMBLY__ -P - < $< > $@
On Thu, Sep 26, 2013 at 5:51 AM, Masahiro Yamada yamada.m@jp.panasonic.comwrote:
include $(TOPDIR)/config.mk LIB = $(obj)libfoo.o COBJS := ... COBJS += ... SOBJS := ... SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) all: $(obj).depend $(LIB) $(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
include $(SRCTREE)/rules.mk sinclude $(obj).depend
Changes for v2:
Would looking for obj- be better or worse?
an indent might help here, and below.
fi
then \
This check seems to appear a lot - could it become a $(call ...) perhaps?
else \
fi
then \
else \
fi
else \
$(MAKE) -C $$dir -f
fi; \
done
+include Makefile
- $(wildcard $(obj-y:.o=.c) $(obj-y:.o=.S) $(lib-y:.o=.c) $(lib-y:.o=.S)
+endif
fi
$(LIBS): depend
else \
fi
-- 1.8.1.2
Re testing, I used:
$ ./tools/buildman/buildman -b try-kbuild -k
and confirmed that the binaries do change, for example, with cm41xx:
$ wc ... 1348 5418 123176 try-kbuild/01_of_20_g0c5274e6_Prepare-v2013.04-rc4/cm41xx/u-boot.bin 1348 5417 123188 try-kbuild/02_of_20_gd3068182_Makefile--prepare-fo/cm41xx/u-boot.bin
The change may well be harmless though.
It would be nice to add a feature to buildman to compare binaries. Of course we would need to add a Makefile option to disable the timestamp embedding first, since all binaries are different because of that.
Hello Simon
At first I thought of this but I was kind of worried whether all makefiles should forcibly have obj-y or obj-.
arch/arm/cpu/armv7/tegra114/ arch/arm/cpu/armv7/tegra30/ directories have no source files but only a Makefile.
After all, I simply added obj- := line in them, so I think your suggestion will work.
If you prefer to search obj-, I will consider to change at version 3.
In any case, this ugly grep switch is tentative. I want to refactor all makefiles and delete this switch as soon as possible.
I will fix at v3.
fi
then \
I did not care so much about this part becuase it is temporary. But re-writing it shortly with $(call ...) is not difficult. I will try at v3. Thanks for your advice.
Re testing, I used:
It is probably because of include/generated/version_autogenerated.h
The length of PLAIN_VERSION and U_BOOT_VERSION changes because the output `git describe` command is used for here.
Actually I gave it a try.
For master branch (Prepare v2013.04-rc4), I got:
#define PLAIN_VERSION "2013.10-rc4" #define U_BOOT_VERSION "U-Boot 2013.10-rc4" #define CC_VERSION_STRING "arm-linux-gnueabi-gcc (Ubuntu/Linaro 4.7.3-1ubuntu1) 4.7.3" #define LD_VERSION_STRING "GNU ld (GNU Binutils for Ubuntu) 2.23.2"
For try-kbuild branch (Makefile: prepare for using Kbuild-style Makefile) I got:
#define PLAIN_VERSION "2013.10-rc4-00001-gc31a399" #define U_BOOT_VERSION "U-Boot 2013.10-rc4-00001-gc31a399" #define CC_VERSION_STRING "arm-linux-gnueabi-gcc (Ubuntu/Linaro 4.7.3-1ubuntu1) 4.7.3" #define LD_VERSION_STRING "GNU ld (GNU Binutils for Ubuntu) 2.23.2"
For the list of things you should take into account to get identical output files, please refer the thread of version1 of this series: [U-Boot] [PATCH 00/19] First step towards Kbuild: Use Kbuild style makefiles Message-Id: 20130917093533.738A.AA925319@jp.panasonic.com
(2) Git commit hash
Git commit hash is contained in include/generated/version_autogenerated.h. So, I also modified include/version.h not to include it as follows:
#ifndef DO_DEPS_ONLY -#include "generated/version_autogenerated.h" +/* #include "generated/version_autogenerated.h" */ +#define PLAIN_VERSION "__DUMMY__" +#define U_BOOT_VERSION "__DUMMY__" +#define CC_VERSION_STRING "__DUMMY__" +#define LD_VERSION_STRING "__DUMMY__" #endif
This is what I did when I compared md5sum. After applying above as a prerequisite commit, I tried 'tools/buildman/buildman -b try-kbuild -k' again and I got the same size for cm41xx/u-boot.bin
If you compare the size of u-boot.bin, please take care of the order of object files too.
I also mentioned this in the thread of v1.
Sounds a good idea. I will take a look when I have time.
Best Regards Masahiro Yamada
Hi Masahiro,
On Fri, Oct 4, 2013 at 3:59 AM, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Simon
No, it doesn't matter, it sounds like what you are doing is just as good, and it is temporary as you say. I wonder how temporary?
I will fix at v3.
fi
then \
Re testing, I used:
(2) Git commit hash
Hello, Simon.
I posted a new series "Third step towards Kbuild: Convert rest of makefiles" (consists of 18 patch files) The series deletes the temporary grep switch.
Altough it is Tom who decides when the series should be applied, I hope it is not so late.
Hi Masahiro,
On Sun, Oct 20, 2013 at 10:56 PM, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello, Simon.
The merge window only opened recently so it should be fine.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes for v2: -2/19: updated 3 files to rebase on the master arch/arm/cpu/armv7/mx6/Makefile arch/arm/cpu/armv7/socfpga/Makefile arch/arm/cpu/armv7/zynq/Makefile
arch/arm/cpu/armv7/Makefile | 32 ++++---------------- arch/arm/cpu/armv7/am33xx/Makefile | 51 ++++++++------------------------ arch/arm/cpu/armv7/at91/Makefile | 31 ++++--------------- arch/arm/cpu/armv7/exynos/Makefile | 34 ++++----------------- arch/arm/cpu/armv7/highbank/Makefile | 24 +-------------- arch/arm/cpu/armv7/mx5/Makefile | 25 ++-------------- arch/arm/cpu/armv7/mx6/Makefile | 25 ++-------------- arch/arm/cpu/armv7/omap-common/Makefile | 43 +++++++-------------------- arch/arm/cpu/armv7/omap3/Makefile | 41 +++++++------------------ arch/arm/cpu/armv7/omap4/Makefile | 31 ++++--------------- arch/arm/cpu/armv7/omap5/Makefile | 33 ++++----------------- arch/arm/cpu/armv7/rmobile/Makefile | 51 ++++++++------------------------ arch/arm/cpu/armv7/s5p-common/Makefile | 29 +++--------------- arch/arm/cpu/armv7/s5pc1xx/Makefile | 27 ++--------------- arch/arm/cpu/armv7/socfpga/Makefile | 29 ++---------------- arch/arm/cpu/armv7/tegra-common/Makefile | 24 +-------------- arch/arm/cpu/armv7/tegra114/Makefile | 22 +------------- arch/arm/cpu/armv7/tegra20/Makefile | 26 ++-------------- arch/arm/cpu/armv7/tegra30/Makefile | 22 +------------- arch/arm/cpu/armv7/u8500/Makefile | 25 ++-------------- arch/arm/cpu/armv7/vf610/Makefile | 25 ++-------------- arch/arm/cpu/armv7/zynq/Makefile | 31 +++---------------- 22 files changed, 101 insertions(+), 580 deletions(-)
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index b723e22..75fac4b 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -5,35 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y := start.o
-LIB = $(obj)lib$(CPU).o +obj-y += cache_v7.o
-START := start.o - -COBJS += cache_v7.o - -COBJS += cpu.o -COBJS += syslib.o +obj-y += cpu.o +obj-y += syslib.o
ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX),) -SOBJS += lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(START:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/am33xx/Makefile b/arch/arm/cpu/armv7/am33xx/Makefile index f6a297c..966fcab 100644 --- a/arch/arm/cpu/armv7/am33xx/Makefile +++ b/arch/arm/cpu/armv7/am33xx/Makefile @@ -4,46 +4,19 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_AM33XX) += clock_am33xx.o -COBJS-$(CONFIG_TI814X) += clock_ti814x.o -COBJS-$(CONFIG_AM43XX) += clock_am43xx.o +obj-$(CONFIG_AM33XX) += clock_am33xx.o +obj-$(CONFIG_TI814X) += clock_ti814x.o +obj-$(CONFIG_AM43XX) += clock_am43xx.o
ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX),) -COBJS += clock.o +obj-y += clock.o endif
-COBJS-$(CONFIG_TI816X) += clock_ti816x.o -COBJS += sys_info.o -COBJS += mem.o -COBJS += ddr.o -COBJS += emif4.o -COBJS += board.o -COBJS += mux.o -COBJS-$(CONFIG_NAND_OMAP_GPMC) += elm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TI816X) += clock_ti816x.o +obj-y += sys_info.o +obj-y += mem.o +obj-y += ddr.o +obj-y += emif4.o +obj-y += board.o +obj-y += mux.o +obj-$(CONFIG_NAND_OMAP_GPMC) += elm.o diff --git a/arch/arm/cpu/armv7/at91/Makefile b/arch/arm/cpu/armv7/at91/Makefile index 90b9bd6..0a2e48d 100644 --- a/arch/arm/cpu/armv7/at91/Makefile +++ b/arch/arm/cpu/armv7/at91/Makefile @@ -8,29 +8,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_SAMA5D3) += sama5d3_devices.o -COBJS-y += clock.o -COBJS-y += cpu.o -COBJS-y += reset.o -COBJS-y += timer.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SAMA5D3) += sama5d3_devices.o +obj-y += clock.o +obj-y += cpu.o +obj-y += reset.o +obj-y += timer.o diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index eb1633f..e207bd6 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -5,34 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += clock.o power.o soc.o system.o pinmux.o tzpc.o +obj-y += clock.o power.o soc.o system.o pinmux.o tzpc.o
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_EXYNOS5) += clock_init_exynos5.o -COBJS-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o -COBJS-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o -COBJS-y += spl_boot.o -COBJS-y += lowlevel_init.o +obj-$(CONFIG_EXYNOS5) += clock_init_exynos5.o +obj-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o +obj-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o +obj-y += spl_boot.o +obj-y += lowlevel_init.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/highbank/Makefile b/arch/arm/cpu/armv7/highbank/Makefile index 22e3b72..876099d 100644 --- a/arch/arm/cpu/armv7/highbank/Makefile +++ b/arch/arm/cpu/armv7/highbank/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := timer.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o diff --git a/arch/arm/cpu/armv7/mx5/Makefile b/arch/arm/cpu/armv7/mx5/Makefile index 7c86ae3..d021842 100644 --- a/arch/arm/cpu/armv7/mx5/Makefile +++ b/arch/arm/cpu/armv7/mx5/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = soc.o clock.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := soc.o clock.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/armv7/mx6/Makefile b/arch/arm/cpu/armv7/mx6/Makefile index 6d73617..d7285fc 100644 --- a/arch/arm/cpu/armv7/mx6/Makefile +++ b/arch/arm/cpu/armv7/mx6/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = soc.o clock.o -COBJS-$(CONFIG_SECURE_BOOT) += hab.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := soc.o clock.o +obj-$(CONFIG_SECURE_BOOT) += hab.o diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 75b3753..4d3a165 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -5,46 +5,25 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libomap-common.o - -COBJS := reset.o -COBJS += timer.o -COBJS += utils.o +obj-y := reset.o +obj-y += timer.o +obj-y += utils.o
ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) -COBJS += hwinit-common.o -COBJS += clocks-common.o -COBJS += emif-common.o -COBJS += vc.o -COBJS += abb.o +obj-y += hwinit-common.o +obj-y += clocks-common.o +obj-y += emif-common.o +obj-y += vc.o +obj-y += abb.o endif
ifeq ($(CONFIG_OMAP34XX),) -COBJS += boot-common.o -SOBJS += lowlevel_init.o +obj-y += boot-common.o +obj-y += lowlevel_init.o endif
ifndef CONFIG_SPL_BUILD ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) -COBJS += mem-common.o +obj-y += mem-common.o endif endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/omap3/Makefile b/arch/arm/cpu/armv7/omap3/Makefile index f070c18..39ff257 100644 --- a/arch/arm/cpu/armv7/omap3/Makefile +++ b/arch/arm/cpu/armv7/omap3/Makefile @@ -5,38 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := lowlevel_init.o
-LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o - -COBJS += board.o -COBJS += clock.o -COBJS += mem.o -COBJS += sys_info.o +obj-y += board.o +obj-y += clock.o +obj-y += mem.o +obj-y += sys_info.o ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_OMAP3_ID_NAND) += spl_id_nand.o +obj-$(CONFIG_SPL_OMAP3_ID_NAND) += spl_id_nand.o endif
-COBJS-$(CONFIG_DRIVER_TI_EMAC) += emac.o -COBJS-$(CONFIG_EMIF4) += emif4.o -COBJS-$(CONFIG_SDRC) += sdrc.o -COBJS-$(CONFIG_USB_MUSB_AM35X) += am35x_musb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DRIVER_TI_EMAC) += emac.o +obj-$(CONFIG_EMIF4) += emif4.o +obj-$(CONFIG_SDRC) += sdrc.o +obj-$(CONFIG_USB_MUSB_AM35X) += am35x_musb.o diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index fc6e2dd..76a032a 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -5,29 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += sdram_elpida.o -COBJS += hwinit.o -COBJS += emif.o -COBJS += prcm-regs.o -COBJS += hw_data.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sdram_elpida.o +obj-y += hwinit.o +obj-y += emif.o +obj-y += prcm-regs.o +obj-y += hw_data.o diff --git a/arch/arm/cpu/armv7/omap5/Makefile b/arch/arm/cpu/armv7/omap5/Makefile index 168302d..64c6879 100644 --- a/arch/arm/cpu/armv7/omap5/Makefile +++ b/arch/arm/cpu/armv7/omap5/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += hwinit.o -COBJS += emif.o -COBJS += sdram.o -COBJS += prcm-regs.o -COBJS += hw_data.o -COBJS += abb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += hwinit.o +obj-y += emif.o +obj-y += sdram.o +obj-y += prcm-regs.o +obj-y += hw_data.o +obj-y += abb.o diff --git a/arch/arm/cpu/armv7/rmobile/Makefile b/arch/arm/cpu/armv7/rmobile/Makefile index 3168e97..8f4cf3a 100644 --- a/arch/arm/cpu/armv7/rmobile/Makefile +++ b/arch/arm/cpu/armv7/rmobile/Makefile @@ -5,45 +5,20 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = lowlevel_init.o -COBJS-y += cpu_info.o -COBJS-y += emac.o - -COBJS-$(CONFIG_DISPLAY_BOARDINFO) += board.o -COBJS-$(CONFIG_GLOBAL_TIMER) += timer.o -COBJS-$(CONFIG_R8A7740) += cpu_info-r8a7740.o -COBJS-$(CONFIG_R8A7740) += pfc-r8a7740.o -COBJS-$(CONFIG_SH73A0) += cpu_info-sh73a0.o -COBJS-$(CONFIG_SH73A0) += pfc-sh73a0.o -COBJS_LN-$(CONFIG_TMU_TIMER) += sh_timer.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN-y:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - +obj-y = lowlevel_init.o +obj-y += cpu_info.o +obj-y += emac.o + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board.o +obj-$(CONFIG_GLOBAL_TIMER) += timer.o +obj-$(CONFIG_R8A7740) += cpu_info-r8a7740.o +obj-$(CONFIG_R8A7740) += pfc-r8a7740.o +obj-$(CONFIG_SH73A0) += cpu_info-sh73a0.o +obj-$(CONFIG_SH73A0) += pfc-sh73a0.o +obj-$(CONFIG_TMU_TIMER) += sh_timer.o + +SRCS += $(obj)sh_timer.c # from arch/sh/lib/ directory $(obj)sh_timer.c: @rm -f $(obj)sh_timer.c ln -s $(SRCTREE)/arch/sh/lib/time.c $(obj)sh_timer.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### - diff --git a/arch/arm/cpu/armv7/s5p-common/Makefile b/arch/arm/cpu/armv7/s5p-common/Makefile index fd7290c..f571d8a 100644 --- a/arch/arm/cpu/armv7/s5p-common/Makefile +++ b/arch/arm/cpu/armv7/s5p-common/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libs5p-common.o - -COBJS-y += cpu_info.o +obj-y += cpu_info.o ifndef CONFIG_SPL_BUILD -COBJS-y += timer.o -COBJS-y += sromc.o -COBJS-$(CONFIG_PWM) += pwm.o +obj-y += timer.o +obj-y += sromc.o +obj-$(CONFIG_PWM) += pwm.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/s5pc1xx/Makefile b/arch/arm/cpu/armv7/s5pc1xx/Makefile index 09fed66..9f43ded 100644 --- a/arch/arm/cpu/armv7/s5pc1xx/Makefile +++ b/arch/arm/cpu/armv7/s5pc1xx/Makefile @@ -8,28 +8,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y = cache.o +obj-y += reset.o
-LIB = $(obj)lib$(SOC).o - -SOBJS = cache.o -SOBJS += reset.o - -COBJS += clock.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/cpu/armv7/socfpga/Makefile index 5024fc5..d361b78 100644 --- a/arch/arm/cpu/armv7/socfpga/Makefile +++ b/arch/arm/cpu/armv7/socfpga/Makefile @@ -7,29 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
- -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o -COBJS-y := misc.o timer.o reset_manager.o -COBJS-$(CONFIG_SPL_BUILD) += spl.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lowlevel_init.o +obj-y += misc.o timer.o reset_manager.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/cpu/armv7/tegra-common/Makefile b/arch/arm/cpu/armv7/tegra-common/Makefile index d97542d..463c260 100644 --- a/arch/arm/cpu/armv7/tegra-common/Makefile +++ b/arch/arm/cpu/armv7/tegra-common/Makefile @@ -7,26 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtegra-common.o - -COBJS-$(CONFIG_CMD_ENTERRCM) += cmd_enterrcm.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_ENTERRCM) += cmd_enterrcm.o diff --git a/arch/arm/cpu/armv7/tegra114/Makefile b/arch/arm/cpu/armv7/tegra114/Makefile index eb98c8e..886b509 100644 --- a/arch/arm/cpu/armv7/tegra114/Makefile +++ b/arch/arm/cpu/armv7/tegra114/Makefile @@ -17,24 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj- := diff --git a/arch/arm/cpu/armv7/tegra20/Makefile b/arch/arm/cpu/armv7/tegra20/Makefile index 4ee8e5b..9b4295c 100644 --- a/arch/arm/cpu/armv7/tegra20/Makefile +++ b/arch/arm/cpu/armv7/tegra20/Makefile @@ -7,27 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_PWM_TEGRA) += pwm.o -COBJS-$(CONFIG_VIDEO_TEGRA) += display.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_PWM_TEGRA) += pwm.o +obj-$(CONFIG_VIDEO_TEGRA) += display.o diff --git a/arch/arm/cpu/armv7/tegra30/Makefile b/arch/arm/cpu/armv7/tegra30/Makefile index 04adb52..518d6d1 100644 --- a/arch/arm/cpu/armv7/tegra30/Makefile +++ b/arch/arm/cpu/armv7/tegra30/Makefile @@ -17,24 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj- := diff --git a/arch/arm/cpu/armv7/u8500/Makefile b/arch/arm/cpu/armv7/u8500/Makefile index 3d7a592..fad9d4a 100644 --- a/arch/arm/cpu/armv7/u8500/Makefile +++ b/arch/arm/cpu/armv7/u8500/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o clock.o prcmu.o cpu.o -SOBJS = lowlevel.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o clock.o prcmu.o cpu.o +obj-y += lowlevel.o diff --git a/arch/arm/cpu/armv7/vf610/Makefile b/arch/arm/cpu/armv7/vf610/Makefile index 7d3c454..68cb756 100644 --- a/arch/arm/cpu/armv7/vf610/Makefile +++ b/arch/arm/cpu/armv7/vf610/Makefile @@ -4,26 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o diff --git a/arch/arm/cpu/armv7/zynq/Makefile b/arch/arm/cpu/armv7/zynq/Makefile index de6b081..d382d49 100644 --- a/arch/arm/cpu/armv7/zynq/Makefile +++ b/arch/arm/cpu/armv7/zynq/Makefile @@ -8,30 +8,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y := timer.o -COBJS-y += cpu.o -COBJS-y += ddrc.o -COBJS-y += slcr.o - -COBJS := $(COBJS-y) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o +obj-y += cpu.o +obj-y += ddrc.o +obj-y += slcr.o
Note1: In arch/arm/cpu/arm926ejs/spear/Makefile START := start.o was changed extra-$(CONFIG_SPL_BUILD) := start.o because spear/start.o is only used for SPL.
Note2: START := start.o was missing from arch/arm/cpu/arm926ejs/mxs/Makefile. This commit simply adds extra-$(CONFIG_SPL_BUILD) := start.o
Changes for v2 - No change
arch/arm/cpu/arm926ejs/Makefile | 28 ++------------- arch/arm/cpu/arm926ejs/armada100/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/at91/Makefile | 59 ++++++++++--------------------- arch/arm/cpu/arm926ejs/davinci/Makefile | 48 +++++++------------------ arch/arm/cpu/arm926ejs/kirkwood/Makefile | 31 +++------------- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 25 +------------ arch/arm/cpu/arm926ejs/mx25/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mx27/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mxs/Makefile | 26 ++------------ arch/arm/cpu/arm926ejs/nomadik/Makefile | 25 ++----------- arch/arm/cpu/arm926ejs/omap/Makefile | 26 ++------------ arch/arm/cpu/arm926ejs/orion5x/Makefile | 29 +++------------ arch/arm/cpu/arm926ejs/pantheon/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/spear/Makefile | 36 +++++-------------- arch/arm/cpu/arm926ejs/versatile/Makefile | 26 ++------------ 16 files changed, 67 insertions(+), 407 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index b4c214c..1252995 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -5,33 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o cache.o +extra-y = start.o +obj-y = cpu.o cache.o
ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_NO_CPU_SUPPORT_CODE -START := +extra-y := endif endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/armada100/Makefile b/arch/arm/cpu/arm926ejs/armada100/Makefile index a1a6df0..fca98ef 100644 --- a/arch/arm/cpu/arm926ejs/armada100/Makefile +++ b/arch/arm/cpu/arm926ejs/armada100/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o timer.o dram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o timer.o dram.o diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 9faec91..698a28d 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -5,46 +5,25 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_AT91CAP9) += at91cap9_devices.o -COBJS-$(CONFIG_AT91SAM9260) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9G20) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9XE) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9261) += at91sam9261_devices.o -COBJS-$(CONFIG_AT91SAM9G10) += at91sam9261_devices.o -COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o -COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o -COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o -COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o -COBJS-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o -COBJS-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o -COBJS-$(CONFIG_AT91_EFLASH) += eflash.o -COBJS-$(CONFIG_AT91_LED) += led.o -COBJS-y += clock.o -COBJS-y += cpu.o -COBJS-y += reset.o -COBJS-y += timer.o +obj-$(CONFIG_AT91CAP9) += at91cap9_devices.o +obj-$(CONFIG_AT91SAM9260) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9G20) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9XE) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9261) += at91sam9261_devices.o +obj-$(CONFIG_AT91SAM9G10) += at91sam9261_devices.o +obj-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o +obj-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o +obj-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o +obj-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +obj-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o +obj-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o +obj-$(CONFIG_AT91_EFLASH) += eflash.o +obj-$(CONFIG_AT91_LED) += led.o +obj-y += clock.o +obj-y += cpu.o +obj-y += reset.o +obj-y += timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS-y := lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/davinci/Makefile b/arch/arm/cpu/arm926ejs/davinci/Makefile index b596818..7d67191 100644 --- a/arch/arm/cpu/arm926ejs/davinci/Makefile +++ b/arch/arm/cpu/arm926ejs/davinci/Makefile @@ -7,44 +7,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o -COBJS-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o -COBJS-$(CONFIG_SOC_DM355) += dm355.o -COBJS-$(CONFIG_SOC_DM365) += dm365.o -COBJS-$(CONFIG_SOC_DM644X) += dm644x.o -COBJS-$(CONFIG_SOC_DM646X) += dm646x.o -COBJS-$(CONFIG_SOC_DA830) += da830_pinmux.o -COBJS-$(CONFIG_SOC_DA850) += da850_pinmux.o -COBJS-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o et1011c.o ksz8873.o +obj-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o +obj-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o +obj-$(CONFIG_SOC_DM355) += dm355.o +obj-$(CONFIG_SOC_DM365) += dm365.o +obj-$(CONFIG_SOC_DM644X) += dm644x.o +obj-$(CONFIG_SOC_DM646X) += dm646x.o +obj-$(CONFIG_SOC_DA830) += da830_pinmux.o +obj-$(CONFIG_SOC_DA850) += da850_pinmux.o +obj-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o et1011c.o ksz8873.o
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o -COBJS-$(CONFIG_SOC_DM365) += dm365_lowlevel.o -COBJS-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SOC_DM365) += dm365_lowlevel.o +obj-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o endif
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS += lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/kirkwood/Makefile b/arch/arm/cpu/arm926ejs/kirkwood/Makefile index 20ccf20..c230ce8 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/Makefile +++ b/arch/arm/cpu/arm926ejs/kirkwood/Makefile @@ -6,29 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o -COBJS-y += dram.o -COBJS-y += mpp.o -COBJS-y += timer.o -COBJS-y += cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o +obj-y += dram.o +obj-y += mpp.o +obj-y += timer.o +obj-y += cache.o diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile index 603051a..314f004 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile +++ b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = cpu.o clk.o devices.o timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o clk.o devices.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/Makefile b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile index a780dfe..365892c 100644 --- a/arch/arm/cpu/arm926ejs/mb86r0x/Makefile +++ b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = clock.o reset.o timer.o -SOBJS = - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = clock.o reset.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mx25/Makefile b/arch/arm/cpu/arm926ejs/mx25/Makefile index 75a09ff..134c69d 100644 --- a/arch/arm/cpu/arm926ejs/mx25/Makefile +++ b/arch/arm/cpu/arm926ejs/mx25/Makefile @@ -4,25 +4,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = generic.o timer.o reset.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = generic.o timer.o reset.o diff --git a/arch/arm/cpu/arm926ejs/mx27/Makefile b/arch/arm/cpu/arm926ejs/mx27/Makefile index 53ffaf2..4976bbb 100644 --- a/arch/arm/cpu/arm926ejs/mx27/Makefile +++ b/arch/arm/cpu/arm926ejs/mx27/Makefile @@ -4,25 +4,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = generic.o reset.o timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = generic.o reset.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index 3d66892..13b5a54 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -5,25 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-$(CONFIG_SPL_BUILD) := start.o
-LIB = $(obj)lib$(SOC).o - -COBJS = clock.o mxs.o iomux.o timer.o +obj-y = clock.o mxs.o iomux.o timer.o
ifdef CONFIG_SPL_BUILD -COBJS += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o +obj-y += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o endif
-SRCS := $(START:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - # Specify the target for use in elftosb call ELFTOSB_TARGET-$(CONFIG_MX23) = imx23 ELFTOSB_TARGET-$(CONFIG_MX28) = imx28 @@ -33,12 +22,3 @@ $(OBJTREE)/u-boot.bd: $(SRCTREE)/$(CPUDIR)/$(SOC)/u-boot-$(ELFTOSB_TARGET-y).bd
$(OBJTREE)/u-boot.sb: $(OBJTREE)/u-boot.bin $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/u-boot.bd elftosb -zf $(ELFTOSB_TARGET-y) -c $(OBJTREE)/u-boot.bd -o $(OBJTREE)/u-boot.sb - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/nomadik/Makefile b/arch/arm/cpu/arm926ejs/nomadik/Makefile index 8896b0b..cdf1345 100644 --- a/arch/arm/cpu/arm926ejs/nomadik/Makefile +++ b/arch/arm/cpu/arm926ejs/nomadik/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o gpio.o -SOBJS = reset.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) $(addprefix $(obj),$(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o gpio.o +obj-y += reset.o diff --git a/arch/arm/cpu/arm926ejs/omap/Makefile b/arch/arm/cpu/arm926ejs/omap/Makefile index b519477..bd0a2fb 100644 --- a/arch/arm/cpu/arm926ejs/omap/Makefile +++ b/arch/arm/cpu/arm926ejs/omap/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o cpuinfo.o -SOBJS = reset.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o cpuinfo.o +obj-y += reset.o diff --git a/arch/arm/cpu/arm926ejs/orion5x/Makefile b/arch/arm/cpu/arm926ejs/orion5x/Makefile index 8f36dc0..546ebcb 100644 --- a/arch/arm/cpu/arm926ejs/orion5x/Makefile +++ b/arch/arm/cpu/arm926ejs/orion5x/Makefile @@ -9,31 +9,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o -COBJS-y += dram.o -COBJS-y += timer.o +obj-y = cpu.o +obj-y += dram.o +obj-y += timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS := lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/pantheon/Makefile b/arch/arm/cpu/arm926ejs/pantheon/Makefile index fb6bf63..988341f 100644 --- a/arch/arm/cpu/arm926ejs/pantheon/Makefile +++ b/arch/arm/cpu/arm926ejs/pantheon/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o timer.o dram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o timer.o dram.o diff --git a/arch/arm/cpu/arm926ejs/spear/Makefile b/arch/arm/cpu/arm926ejs/spear/Makefile index 3006cd6..3f190bc 100644 --- a/arch/arm/cpu/arm926ejs/spear/Makefile +++ b/arch/arm/cpu/arm926ejs/spear/Makefile @@ -5,37 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y := cpu.o \ +obj-y := cpu.o \ reset.o \ timer.o
ifdef CONFIG_SPL_BUILD -COBJS-y += spl.o spl_boot.o -COBJS-$(CONFIG_SPEAR600) += spear600.o -COBJS-$(CONFIG_DDR_MT47H64M16) += spr600_mt47h64m16_3_333_cl5_psync.o -COBJS-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_333_cl5_psync.o -COBJS-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_37e_166_cl4_sync.o -COBJS-$(CONFIG_DDR_MT47H128M8) += spr600_mt47h128m8_3_266_cl5_async.o +obj-y += spl.o spl_boot.o +obj-$(CONFIG_SPEAR600) += spear600.o +obj-$(CONFIG_DDR_MT47H64M16) += spr600_mt47h64m16_3_333_cl5_psync.o +obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_333_cl5_psync.o +obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_37e_166_cl4_sync.o +obj-$(CONFIG_DDR_MT47H128M8) += spr600_mt47h128m8_3_266_cl5_async.o endif
-SRCS := $(START:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-$(CONFIG_SPL_BUILD) := start.o diff --git a/arch/arm/cpu/arm926ejs/versatile/Makefile b/arch/arm/cpu/arm926ejs/versatile/Makefile index d4659f9..907f516 100644 --- a/arch/arm/cpu/arm926ejs/versatile/Makefile +++ b/arch/arm/cpu/arm926ejs/versatile/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o -SOBJS = reset.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o +obj-y += reset.o
arch/arm/cpu/arm920t/Makefile | 28 +++------------------------- arch/arm/cpu/arm920t/a320/Makefile | 25 ++----------------------- arch/arm/cpu/arm920t/at91/Makefile | 33 ++++++--------------------------- arch/arm/cpu/arm920t/ep93xx/Makefile | 24 ++---------------------- arch/arm/cpu/arm920t/imx/Makefile | 27 +++------------------------ arch/arm/cpu/arm920t/ks8695/Makefile | 26 ++------------------------ arch/arm/cpu/arm920t/s3c24x0/Makefile | 29 ++++------------------------- 7 files changed, 22 insertions(+), 170 deletions(-)
diff --git a/arch/arm/cpu/arm920t/Makefile b/arch/arm/cpu/arm920t/Makefile index 4758f02..aac8043 100644 --- a/arch/arm/cpu/arm920t/Makefile +++ b/arch/arm/cpu/arm920t/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y = start.o
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS-y += cpu.o -COBJS-$(CONFIG_USE_IRQ) += interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-$(CONFIG_USE_IRQ) += interrupts.o diff --git a/arch/arm/cpu/arm920t/a320/Makefile b/arch/arm/cpu/arm920t/a320/Makefile index 88c7d9b..bbdab58 100644 --- a/arch/arm/cpu/arm920t/a320/Makefile +++ b/arch/arm/cpu/arm920t/a320/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS += reset.o -COBJS += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += reset.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/at91/Makefile b/arch/arm/cpu/arm920t/at91/Makefile index b2b1e56..561b4b4 100644 --- a/arch/arm/cpu/arm920t/at91/Makefile +++ b/arch/arm/cpu/arm920t/at91/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS += lowlevel_init.o -COBJS += reset.o -COBJS += timer.o -COBJS += clock.o -COBJS += cpu.o -COBJS += at91rm9200_devices.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += lowlevel_init.o +obj-y += reset.o +obj-y += timer.o +obj-y += clock.o +obj-y += cpu.o +obj-y += at91rm9200_devices.o diff --git a/arch/arm/cpu/arm920t/ep93xx/Makefile b/arch/arm/cpu/arm920t/ep93xx/Makefile index 7a75c86..638333a 100644 --- a/arch/arm/cpu/arm920t/ep93xx/Makefile +++ b/arch/arm/cpu/arm920t/ep93xx/Makefile @@ -16,26 +16,6 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = $(obj)lib$(SOC).o - -COBJS = cpu.o led.o speed.o timer.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o led.o speed.o timer.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/arm920t/imx/Makefile b/arch/arm/cpu/arm920t/imx/Makefile index c9c85b8..54ce646 100644 --- a/arch/arm/cpu/arm920t/imx/Makefile +++ b/arch/arm/cpu/arm920t/imx/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += speed.o -COBJS += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += speed.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/ks8695/Makefile b/arch/arm/cpu/arm920t/ks8695/Makefile index eef0530..400aa89 100644 --- a/arch/arm/cpu/arm920t/ks8695/Makefile +++ b/arch/arm/cpu/arm920t/ks8695/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = lowlevel_init.o - -COBJS = timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = lowlevel_init.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/s3c24x0/Makefile b/arch/arm/cpu/arm920t/s3c24x0/Makefile index 9717533..e44c549 100644 --- a/arch/arm/cpu/arm920t/s3c24x0/Makefile +++ b/arch/arm/cpu/arm920t/s3c24x0/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_USE_IRQ) += interrupts.o -COBJS-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o -COBJS-y += speed.o -COBJS-y += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USE_IRQ) += interrupts.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-y += speed.o +obj-y += timer.o
arch/arm/cpu/arm720t/Makefile | 26 ++------------------------ arch/arm/cpu/arm720t/tegra-common/Makefile | 25 ++----------------------- arch/arm/cpu/arm720t/tegra114/Makefile | 25 ++----------------------- arch/arm/cpu/arm720t/tegra20/Makefile | 23 +---------------------- arch/arm/cpu/arm720t/tegra30/Makefile | 23 +---------------------- 5 files changed, 8 insertions(+), 114 deletions(-)
diff --git a/arch/arm/cpu/arm720t/Makefile b/arch/arm/cpu/arm720t/Makefile index 73e1635..243a123 100644 --- a/arch/arm/cpu/arm720t/Makefile +++ b/arch/arm/cpu/arm720t/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = interrupts.o cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = interrupts.o cpu.o diff --git a/arch/arm/cpu/arm720t/tegra-common/Makefile b/arch/arm/cpu/arm720t/tegra-common/Makefile index 37ec43f..a9c2b67 100644 --- a/arch/arm/cpu/arm720t/tegra-common/Makefile +++ b/arch/arm/cpu/arm720t/tegra-common/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtegra-common.o - -COBJS-$(CONFIG_SPL_BUILD) += spl.o -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SPL_BUILD) += spl.o +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra114/Makefile b/arch/arm/cpu/arm720t/tegra114/Makefile index 6cf7fe9..ea3e55e 100644 --- a/arch/arm/cpu/arm720t/tegra114/Makefile +++ b/arch/arm/cpu/arm720t/tegra114/Makefile @@ -17,26 +17,5 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -#COBJS-y += cpu.o t11x.o -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +#obj-y += cpu.o t11x.o +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra20/Makefile b/arch/arm/cpu/arm720t/tegra20/Makefile index eef5922..12243fa 100644 --- a/arch/arm/cpu/arm720t/tegra20/Makefile +++ b/arch/arm/cpu/arm720t/tegra20/Makefile @@ -7,25 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra30/Makefile b/arch/arm/cpu/arm720t/tegra30/Makefile index bd96997..6ff4c55 100644 --- a/arch/arm/cpu/arm720t/tegra30/Makefile +++ b/arch/arm/cpu/arm720t/tegra30/Makefile @@ -17,25 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
arch/arm/cpu/arm1136/Makefile | 26 +--------- arch/arm/cpu/arm1136/mx31/Makefile | 27 ++--------- arch/arm/cpu/arm1136/mx35/Makefile | 28 ++--------- arch/arm/cpu/arm1176/Makefile | 26 +--------- arch/arm/cpu/arm1176/bcm2835/Makefile | 25 +--------- arch/arm/cpu/arm1176/tnetv107x/Makefile | 27 +---------- arch/arm/cpu/arm925t/Makefile | 30 ++---------- arch/arm/cpu/arm946es/Makefile | 26 +--------- arch/arm/cpu/arm_intcm/Makefile | 26 +--------- arch/arm/cpu/ixp/Makefile | 30 ++---------- arch/arm/cpu/pxa/Makefile | 36 +++----------- arch/arm/cpu/sa1100/Makefile | 28 ++--------- arch/arm/cpu/tegra-common/Makefile | 25 +--------- arch/arm/cpu/tegra114-common/Makefile | 23 +-------- arch/arm/cpu/tegra20-common/Makefile | 29 ++--------- arch/arm/cpu/tegra30-common/Makefile | 26 +--------- arch/arm/lib/Makefile | 86 ++++++++++----------------------- 17 files changed, 69 insertions(+), 455 deletions(-)
diff --git a/arch/arm/cpu/arm1136/Makefile b/arch/arm/cpu/arm1136/Makefile index cc516f7..3279f12 100644 --- a/arch/arm/cpu/arm1136/Makefile +++ b/arch/arm/cpu/arm1136/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/arm1136/mx31/Makefile b/arch/arm/cpu/arm1136/mx31/Makefile index c75adec..9670ed9 100644 --- a/arch/arm/cpu/arm1136/mx31/Makefile +++ b/arch/arm/cpu/arm1136/mx31/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o -COBJS += devices.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o +obj-y += devices.o diff --git a/arch/arm/cpu/arm1136/mx35/Makefile b/arch/arm/cpu/arm1136/mx35/Makefile index ee534a9..c533215 100644 --- a/arch/arm/cpu/arm1136/mx35/Makefile +++ b/arch/arm/cpu/arm1136/mx35/Makefile @@ -7,28 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o -COBJS += mx35_sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o +obj-y += mx35_sdram.o diff --git a/arch/arm/cpu/arm1176/Makefile b/arch/arm/cpu/arm1176/Makefile index 5d451a7..deec427 100644 --- a/arch/arm/cpu/arm1176/Makefile +++ b/arch/arm/cpu/arm1176/Makefile @@ -8,27 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/arm1176/bcm2835/Makefile b/arch/arm/cpu/arm1176/bcm2835/Makefile index 135de42..0ad3690 100644 --- a/arch/arm/cpu/arm1176/bcm2835/Makefile +++ b/arch/arm/cpu/arm1176/bcm2835/Makefile @@ -12,26 +12,5 @@ # GNU General Public License for more details. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o -COBJS := init.o reset.o timer.o mbox.o - -SRCS := $(SOBJS:.o=.c) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lowlevel_init.o +obj-y += init.o reset.o timer.o mbox.o diff --git a/arch/arm/cpu/arm1176/tnetv107x/Makefile b/arch/arm/cpu/arm1176/tnetv107x/Makefile index 1eb27ed..a4c1edf 100644 --- a/arch/arm/cpu/arm1176/tnetv107x/Makefile +++ b/arch/arm/cpu/arm1176/tnetv107x/Makefile @@ -2,28 +2,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += aemif.o clock.o init.o mux.o timer.o -SOBJS += lowlevel_init.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) - -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += aemif.o clock.o init.o mux.o timer.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/arm925t/Makefile b/arch/arm/cpu/arm925t/Makefile index 40d2156..ffe2ff5 100644 --- a/arch/arm/cpu/arm925t/Makefile +++ b/arch/arm/cpu/arm925t/Makefile @@ -5,30 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS += cpu.o -COBJS += omap925.o -COBJS += timer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-y += omap925.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm946es/Makefile b/arch/arm/cpu/arm946es/Makefile index 87e6c65..a44bddc 100644 --- a/arch/arm/cpu/arm946es/Makefile +++ b/arch/arm/cpu/arm946es/Makefile @@ -5,28 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o diff --git a/arch/arm/cpu/arm_intcm/Makefile b/arch/arm/cpu/arm_intcm/Makefile index cc516f7..3279f12 100644 --- a/arch/arm/cpu/arm_intcm/Makefile +++ b/arch/arm/cpu/arm_intcm/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/ixp/Makefile b/arch/arm/cpu/ixp/Makefile index 788598e..4e66523 100644 --- a/arch/arm/cpu/ixp/Makefile +++ b/arch/arm/cpu/ixp/Makefile @@ -5,30 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS-y += cpu.o -COBJS-$(CONFIG_USE_IRQ) += interrupts.o -COBJS-y += timer.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-$(CONFIG_USE_IRQ) += interrupts.o +obj-y += timer.o diff --git a/arch/arm/cpu/pxa/Makefile b/arch/arm/cpu/pxa/Makefile index c84186a..8cd475e 100644 --- a/arch/arm/cpu/pxa/Makefile +++ b/arch/arm/cpu/pxa/Makefile @@ -5,35 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o +obj-$(CONFIG_CPU_PXA25X) += pxa2xx.o +obj-$(CONFIG_CPU_PXA27X) += pxa2xx.o
-START = start.o - -COBJS-$(CONFIG_CPU_PXA25X) = pxa2xx.o -COBJS-$(CONFIG_CPU_PXA27X) = pxa2xx.o - -COBJS-y += cpuinfo.o - -COBJS = $(COBJS-y) -COBJS += timer.o -COBJS += usb.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpuinfo.o +obj-y += timer.o +obj-y += usb.o diff --git a/arch/arm/cpu/sa1100/Makefile b/arch/arm/cpu/sa1100/Makefile index c84b7b9..85a0d28 100644 --- a/arch/arm/cpu/sa1100/Makefile +++ b/arch/arm/cpu/sa1100/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS += cpu.o -COBJS += timer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-y += timer.o diff --git a/arch/arm/cpu/tegra-common/Makefile b/arch/arm/cpu/tegra-common/Makefile index 1b6cdf7..3aac655 100644 --- a/arch/arm/cpu/tegra-common/Makefile +++ b/arch/arm/cpu/tegra-common/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcputegra-common.o - -SOBJS += lowlevel_init.o -COBJS-y += ap.o board.o sys_info.o timer.o clock.o cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += lowlevel_init.o +obj-y += ap.o board.o sys_info.o timer.o clock.o cache.o diff --git a/arch/arm/cpu/tegra114-common/Makefile b/arch/arm/cpu/tegra114-common/Makefile index 5b53a71..d959b57 100644 --- a/arch/arm/cpu/tegra114-common/Makefile +++ b/arch/arm/cpu/tegra114-common/Makefile @@ -17,25 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o diff --git a/arch/arm/cpu/tegra20-common/Makefile b/arch/arm/cpu/tegra20-common/Makefile index 175387f..32ddbda 100644 --- a/arch/arm/cpu/tegra20-common/Makefile +++ b/arch/arm/cpu/tegra20-common/Makefile @@ -7,32 +7,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # The AVP is ARMv4T architecture so we must use special compiler # flags for any startup files it might use. CFLAGS_arch/arm/cpu/tegra20-common/warmboot_avp.o += -march=armv4t
-LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o -COBJS-$(CONFIG_TEGRA_LP0) += warmboot.o crypto.o warmboot_avp.o -COBJS-$(CONFIG_TEGRA_CLOCK_SCALING) += emc.o -COBJS-$(CONFIG_TEGRA_PMU) += pmu.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o +obj-$(CONFIG_TEGRA_LP0) += warmboot.o crypto.o warmboot_avp.o +obj-$(CONFIG_TEGRA_CLOCK_SCALING) += emc.o +obj-$(CONFIG_TEGRA_PMU) += pmu.o diff --git a/arch/arm/cpu/tegra30-common/Makefile b/arch/arm/cpu/tegra30-common/Makefile index 75fef32..d2d616e 100644 --- a/arch/arm/cpu/tegra30-common/Makefile +++ b/arch/arm/cpu/tegra30-common/Makefile @@ -17,28 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -# The AVP is ARMv4T architecture so we must use special compiler -# flags for any startup files it might use. - -LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 4e78723..679f19a 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -5,77 +5,43 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o -LIBGCC = $(obj)libgcc.o - -GLSOBJS += _ashldi3.o -GLSOBJS += _ashrdi3.o -GLSOBJS += _divsi3.o -GLSOBJS += _lshrdi3.o -GLSOBJS += _modsi3.o -GLSOBJS += _udivsi3.o -GLSOBJS += _umodsi3.o - -GLCOBJS += div0.o +# Build private libgcc only when asked for +ifdef USE_PRIVATE_LIBGCC +lib-y += _ashldi3.o +lib-y += _ashrdi3.o +lib-y += _divsi3.o +lib-y += _lshrdi3.o +lib-y += _modsi3.o +lib-y += _udivsi3.o +lib-y += _umodsi3.o +lib-y += div0.o +endif
-SOBJS-y += crt0.o +obj-y += crt0.o
ifndef CONFIG_SPL_BUILD -SOBJS-y += relocate.o +obj-y += relocate.o ifndef CONFIG_SYS_GENERIC_BOARD -COBJS-y += board.o +obj-y += board.o endif -COBJS-y += sections.o +obj-y += sections.o
-COBJS-$(CONFIG_OF_LIBFDT) += bootm-fdt.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-$(CONFIG_SYS_L2_PL310) += cache-pl310.o -SOBJS-$(CONFIG_USE_ARCH_MEMSET) += memset.o -SOBJS-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o +obj-$(CONFIG_USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o else -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o endif
-COBJS-y += interrupts.o -COBJS-y += reset.o - -COBJS-y += cache.o -COBJS-y += cache-cp15.o - -SRCS := $(GLSOBJS:.o=.S) $(GLCOBJS:.o=.c) \ - $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ - $(addprefix $(obj),$(GLCOBJS)) +obj-y += interrupts.o +obj-y += reset.o
-# Always build libarm.o -TARGETS := $(LIB) - -# Build private libgcc only when asked for -ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) -endif +obj-y += cache.o +obj-y += cache-cp15.o
# For EABI conformant tool chains, provide eabi_compat() ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) -TARGETS += $(obj)eabi_compat.o +extra-y += eabi_compat.o endif - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Multiple targets are included in arch/arm/imx-common/Makefile In order to refactor it, we need to tweak Makefile and spl/Makefile.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Makefile | 8 +++++--- arch/arm/imx-common/Makefile | 35 ++++++----------------------------- spl/Makefile | 4 +++- 3 files changed, 14 insertions(+), 33 deletions(-)
diff --git a/Makefile b/Makefile index 36bbd09..66c8c66 100644 --- a/Makefile +++ b/Makefile @@ -414,6 +414,8 @@ ALL-y += $(obj)u-boot-nodtb-tegra.bin endif endif
+build := -f $(TOPDIR)/scripts/Makefile.build -C + all: $(ALL-y) $(SUBDIR_EXAMPLES)
$(obj)u-boot.dtb: checkdtc $(obj)u-boot @@ -461,7 +463,7 @@ $(obj)u-boot.img: $(obj)u-boot.bin -d $< $@
$(obj)u-boot.imx: $(obj)u-boot.bin depend - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $(OBJTREE)/u-boot.imx + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common $(OBJTREE)/u-boot.imx
$(obj)u-boot.kwb: $(obj)u-boot.bin $(obj)tools/mkimage -n $(CONFIG_SYS_KWD_CONFIG) -T kwbimage \ @@ -499,11 +501,11 @@ $(obj)tpl/u-boot-with-tpl.bin: $(obj)tpl/u-boot-tpl.bin $(obj)u-boot.bin $(call SPL_PAD_APPEND,$<,$(obj)u-boot.bin,tpl/u-boot-tpl-pad.bin,$(CONFIG_TPL_PAD_TO))
$(obj)u-boot-with-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common \ $(OBJTREE)/u-boot-with-spl.imx
$(obj)u-boot-with-nand-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common \ $(OBJTREE)/u-boot-with-nand-spl.imx
$(obj)u-boot.ubl: $(obj)u-boot-with-spl.bin diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 727a052..50873d8 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -7,31 +7,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libimx-common.o - ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 vf610)) -COBJS-y = iomux-v3.o +obj-y = iomux-v3.o endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) -COBJS-y += timer.o cpu.o speed.o -COBJS-$(CONFIG_I2C_MXC) += i2c-mxv7.o +obj-y += timer.o cpu.o speed.o +obj-$(CONFIG_I2C_MXC) += i2c-mxv7.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) -COBJS-y += misc.o +obj-y += misc.o endif -COBJS-$(CONFIG_CMD_BMODE) += cmd_bmode.o -COBJS-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o -COBJS := $(sort $(COBJS-y)) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o +obj-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o
$(OBJTREE)/$(patsubst "%",%,$(CONFIG_IMX_CONFIG)).cfgtmp: $(OBJTREE)/%.cfgtmp : $(SRCTREE)/% mkdir -p $(dir $@) @@ -67,13 +54,3 @@ $(OBJTREE)/u-boot-with-nand-spl.imx: $(OBJTREE)/SPL $(OBJTREE)/u-boot.bin $(OBJTREE)/u-boot.uim cat $(OBJTREE)/spl/u-boot-nand-spl-pad.imx $(OBJTREE)/u-boot.uim > $@ rm $(OBJTREE)/spl/u-boot-nand-spl-pad.imx $(OBJTREE)/u-boot.uim - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/spl/Makefile b/spl/Makefile index 48f2c65..3197d61 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -153,6 +153,8 @@ ifeq ($(wildcard $(LDSCRIPT)),) $(error could not find linker script) endif
+build := -f $(TOPDIR)/scripts/Makefile.build -C + # Special flags for CPP when processing the linker script. # Pass the version down so we can handle backwards compatibility # on the fly. @@ -172,7 +174,7 @@ $(OBJTREE)/MLO.byteswap: $(obj)u-boot-spl.bin -a $(CONFIG_SPL_TEXT_BASE) -d $< $@
$(OBJTREE)/SPL : $(obj)u-boot-spl.bin depend - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $@ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common $@
ALL-y += $(obj)$(SPL_BIN).bin
drivers/net/Makefile | 136 ++++++++++++++++++++--------------------------- drivers/net/fm/Makefile | 59 +++++++------------- drivers/net/npe/Makefile | 24 +-------- drivers/net/phy/Makefile | 60 +++++++-------------- 4 files changed, 96 insertions(+), 183 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 18fd54f..7f9ce90 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -5,83 +5,61 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnet.o - -COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o -COBJS-$(CONFIG_ALTERA_TSE) += altera_tse.o -COBJS-$(CONFIG_ARMADA100_FEC) += armada100_fec.o -COBJS-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o -COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o -COBJS-$(CONFIG_BFIN_MAC) += bfin_mac.o -COBJS-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o -COBJS-$(CONFIG_CS8900) += cs8900.o -COBJS-$(CONFIG_TULIP) += dc2114x.o -COBJS-$(CONFIG_DESIGNWARE_ETH) += designware.o -COBJS-$(CONFIG_DRIVER_DM9000) += dm9000x.o -COBJS-$(CONFIG_DNET) += dnet.o -COBJS-$(CONFIG_E1000) += e1000.o -COBJS-$(CONFIG_E1000_SPI) += e1000_spi.o -COBJS-$(CONFIG_EEPRO100) += eepro100.o -COBJS-$(CONFIG_ENC28J60) += enc28j60.o -COBJS-$(CONFIG_EP93XX) += ep93xx_eth.o -COBJS-$(CONFIG_ETHOC) += ethoc.o -COBJS-$(CONFIG_FEC_MXC) += fec_mxc.o -COBJS-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o -COBJS-$(CONFIG_FTGMAC100) += ftgmac100.o -COBJS-$(CONFIG_FTMAC110) += ftmac110.o -COBJS-$(CONFIG_FTMAC100) += ftmac100.o -COBJS-$(CONFIG_GRETH) += greth.o -COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o -COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o -COBJS-$(CONFIG_KS8851_MLL) += ks8851_mll.o -COBJS-$(CONFIG_LAN91C96) += lan91c96.o -COBJS-$(CONFIG_MACB) += macb.o -COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o -COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o -COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o -COBJS-$(CONFIG_MVGBE) += mvgbe.o -COBJS-$(CONFIG_NATSEMI) += natsemi.o -COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o -COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o -COBJS-$(CONFIG_NETCONSOLE) += netconsole.o -COBJS-$(CONFIG_NS8382X) += ns8382x.o -COBJS-$(CONFIG_PCNET) += pcnet.o -COBJS-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o -COBJS-$(CONFIG_RTL8139) += rtl8139.o -COBJS-$(CONFIG_RTL8169) += rtl8169.o -COBJS-$(CONFIG_SH_ETHER) += sh_eth.o -COBJS-$(CONFIG_SMC91111) += smc91111.o -COBJS-$(CONFIG_SMC911X) += smc911x.o -COBJS-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o -COBJS-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o -COBJS-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o -COBJS-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o -COBJS-$(CONFIG_FMAN_ENET) += fsl_mdio.o -COBJS-$(CONFIG_TSI108_ETH) += tsi108_eth.o -COBJS-$(CONFIG_ULI526X) += uli526x.o -COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o -COBJS-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o -COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o -COBJS-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ +obj-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o +obj-$(CONFIG_ALTERA_TSE) += altera_tse.o +obj-$(CONFIG_ARMADA100_FEC) += armada100_fec.o +obj-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o +obj-$(CONFIG_DRIVER_AX88180) += ax88180.o +obj-$(CONFIG_BFIN_MAC) += bfin_mac.o +obj-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o +obj-$(CONFIG_CS8900) += cs8900.o +obj-$(CONFIG_TULIP) += dc2114x.o +obj-$(CONFIG_DESIGNWARE_ETH) += designware.o +obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o +obj-$(CONFIG_DNET) += dnet.o +obj-$(CONFIG_E1000) += e1000.o +obj-$(CONFIG_E1000_SPI) += e1000_spi.o +obj-$(CONFIG_EEPRO100) += eepro100.o +obj-$(CONFIG_ENC28J60) += enc28j60.o +obj-$(CONFIG_EP93XX) += ep93xx_eth.o +obj-$(CONFIG_ETHOC) += ethoc.o +obj-$(CONFIG_FEC_MXC) += fec_mxc.o +obj-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o +obj-$(CONFIG_FTGMAC100) += ftgmac100.o +obj-$(CONFIG_FTMAC110) += ftmac110.o +obj-$(CONFIG_FTMAC100) += ftmac100.o +obj-$(CONFIG_GRETH) += greth.o +obj-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o +obj-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o +obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o +obj-$(CONFIG_LAN91C96) += lan91c96.o +obj-$(CONFIG_MACB) += macb.o +obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o +obj-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o +obj-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o +obj-$(CONFIG_MVGBE) += mvgbe.o +obj-$(CONFIG_NATSEMI) += natsemi.o +obj-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o +obj-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o +obj-$(CONFIG_NETCONSOLE) += netconsole.o +obj-$(CONFIG_NS8382X) += ns8382x.o +obj-$(CONFIG_PCNET) += pcnet.o +obj-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o +obj-$(CONFIG_RTL8139) += rtl8139.o +obj-$(CONFIG_RTL8169) += rtl8169.o +obj-$(CONFIG_SH_ETHER) += sh_eth.o +obj-$(CONFIG_SMC91111) += smc91111.o +obj-$(CONFIG_SMC911X) += smc911x.o +obj-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o +obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o +obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o +obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o +obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o +obj-$(CONFIG_TSI108_ETH) += tsi108_eth.o +obj-$(CONFIG_ULI526X) += uli526x.o +obj-$(CONFIG_VSC7385_ENET) += vsc7385.o +obj-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o +obj-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +obj-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o -COBJS-$(CONFIG_ZYNQ_GEM) += zynq_gem.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ZYNQ_GEM) += zynq_gem.o diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index 4edd849..75380a8 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -4,50 +4,29 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfm.o - ifdef CONFIG_FMAN_ENET -COBJS-y += dtsec.o -COBJS-y += eth.o -COBJS-y += fm.o -COBJS-y += init.o -COBJS-y += tgec.o -COBJS-y += tgec_phy.o +obj-y += dtsec.o +obj-y += eth.o +obj-y += fm.o +obj-y += init.o +obj-y += tgec.o +obj-y += tgec_phy.o
# Soc have FMAN v3 with mEMAC -COBJS-$(CONFIG_SYS_FMAN_V3) += memac_phy.o -COBJS-$(CONFIG_SYS_FMAN_V3) += memac.o +obj-$(CONFIG_SYS_FMAN_V3) += memac_phy.o +obj-$(CONFIG_SYS_FMAN_V3) += memac.o
# SoC specific SERDES support -COBJS-$(CONFIG_P1017) += p1023.o -COBJS-$(CONFIG_P1023) += p1023.o +obj-$(CONFIG_P1017) += p1023.o +obj-$(CONFIG_P1023) += p1023.o # The P204x, P304x, and P5020 are the same -COBJS-$(CONFIG_PPC_P2041) += p5020.o -COBJS-$(CONFIG_PPC_P3041) += p5020.o -COBJS-$(CONFIG_PPC_P4080) += p4080.o -COBJS-$(CONFIG_PPC_P5020) += p5020.o -COBJS-$(CONFIG_PPC_P5040) += p5040.o -COBJS-$(CONFIG_PPC_T4240) += t4240.o -COBJS-$(CONFIG_PPC_T4160) += t4240.o -COBJS-$(CONFIG_PPC_B4420) += b4860.o -COBJS-$(CONFIG_PPC_B4860) += b4860.o +obj-$(CONFIG_PPC_P2041) += p5020.o +obj-$(CONFIG_PPC_P3041) += p5020.o +obj-$(CONFIG_PPC_P4080) += p4080.o +obj-$(CONFIG_PPC_P5020) += p5020.o +obj-$(CONFIG_PPC_P5040) += p5040.o +obj-$(CONFIG_PPC_T4240) += t4240.o +obj-$(CONFIG_PPC_T4160) += t4240.o +obj-$(CONFIG_PPC_B4420) += b4860.o +obj-$(CONFIG_PPC_B4860) += b4860.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/net/npe/Makefile b/drivers/net/npe/Makefile index a982678..7fa5ea6 100644 --- a/drivers/net/npe/Makefile +++ b/drivers/net/npe/Makefile @@ -5,16 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnpe.o - LOCAL_CFLAGS += -I$(TOPDIR)/drivers/net/npe/include -DCONFIG_IXP425_COMPONENT_ETHDB -D__linux CFLAGS += $(LOCAL_CFLAGS) CPPFLAGS += $(LOCAL_CFLAGS) # needed for depend HOSTCFLAGS += $(LOCAL_CFLAGS)
-COBJS-$(CONFIG_IXP4XX_NPE) := npe.o \ +obj-$(CONFIG_IXP4XX_NPE) := npe.o \ miiphy.o \ IxOsalBufferMgt.o \ IxOsalIoMem.o \ @@ -63,21 +59,3 @@ COBJS-$(CONFIG_IXP4XX_NPE) := npe.o \ IxNpeMhSend.o \ IxNpeMhSolicitedCbMgr.o \ IxNpeMhUnsolicitedCbMgr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index fe762e9..dbf7bf7 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -5,44 +5,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libphy.o - -COBJS-$(CONFIG_BITBANGMII) += miiphybb.o -COBJS-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o -COBJS-$(CONFIG_MV88E6352_SWITCH) += mv88e6352.o - -COBJS-$(CONFIG_PHYLIB) += phy.o -COBJS-$(CONFIG_PHYLIB_10G) += generic_10g.o -COBJS-$(CONFIG_PHY_ATHEROS) += atheros.o -COBJS-$(CONFIG_PHY_BROADCOM) += broadcom.o -COBJS-$(CONFIG_PHY_DAVICOM) += davicom.o -COBJS-$(CONFIG_PHY_ET1011C) += et1011c.o -COBJS-$(CONFIG_PHY_ICPLUS) += icplus.o -COBJS-$(CONFIG_PHY_LXT) += lxt.o -COBJS-$(CONFIG_PHY_MARVELL) += marvell.o -COBJS-$(CONFIG_PHY_MICREL) += micrel.o -COBJS-$(CONFIG_PHY_NATSEMI) += natsemi.o -COBJS-$(CONFIG_PHY_REALTEK) += realtek.o -COBJS-$(CONFIG_PHY_SMSC) += smsc.o -COBJS-$(CONFIG_PHY_TERANETICS) += teranetics.o -COBJS-$(CONFIG_PHY_VITESSE) += vitesse.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_BITBANGMII) += miiphybb.o +obj-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o +obj-$(CONFIG_MV88E6352_SWITCH) += mv88e6352.o + +obj-$(CONFIG_PHYLIB) += phy.o +obj-$(CONFIG_PHYLIB_10G) += generic_10g.o +obj-$(CONFIG_PHY_ATHEROS) += atheros.o +obj-$(CONFIG_PHY_BROADCOM) += broadcom.o +obj-$(CONFIG_PHY_DAVICOM) += davicom.o +obj-$(CONFIG_PHY_ET1011C) += et1011c.o +obj-$(CONFIG_PHY_ICPLUS) += icplus.o +obj-$(CONFIG_PHY_LXT) += lxt.o +obj-$(CONFIG_PHY_MARVELL) += marvell.o +obj-$(CONFIG_PHY_MICREL) += micrel.o +obj-$(CONFIG_PHY_NATSEMI) += natsemi.o +obj-$(CONFIG_PHY_REALTEK) += realtek.o +obj-$(CONFIG_PHY_SMSC) += smsc.o +obj-$(CONFIG_PHY_TERANETICS) += teranetics.o +obj-$(CONFIG_PHY_VITESSE) += vitesse.o
Changes for v2 - No change
drivers/mtd/Makefile | 44 +++++-------------- drivers/mtd/nand/Makefile | 102 +++++++++++++++++-------------------------- drivers/mtd/onenand/Makefile | 27 ++---------- drivers/mtd/spi/Makefile | 48 ++++++-------------- drivers/mtd/ubi/Makefile | 28 ++---------- 5 files changed, 70 insertions(+), 179 deletions(-)
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index d2c3bda..5467a95 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -5,38 +5,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmtd.o - ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND))) -COBJS-y += mtdcore.o +obj-y += mtdcore.o endif -COBJS-$(CONFIG_MTD_PARTITIONS) += mtdpart.o -COBJS-$(CONFIG_MTD_CONCAT) += mtdconcat.o -COBJS-$(CONFIG_HAS_DATAFLASH) += at45.o -COBJS-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o -COBJS-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o -COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o -COBJS-$(CONFIG_FTSMC020) += ftsmc020.o -COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o -COBJS-$(CONFIG_MW_EEPROM) += mw_eeprom.o -COBJS-$(CONFIG_ST_SMI) += st_smi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MTD_PARTITIONS) += mtdpart.o +obj-$(CONFIG_MTD_CONCAT) += mtdconcat.o +obj-$(CONFIG_HAS_DATAFLASH) += at45.o +obj-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o +obj-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o +obj-$(CONFIG_HAS_DATAFLASH) += dataflash.o +obj-$(CONFIG_FTSMC020) += ftsmc020.o +obj-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o +obj-$(CONFIG_MW_EEPROM) += mw_eeprom.o +obj-$(CONFIG_ST_SMI) += st_smi.o diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 366dee6..eb1eafa 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -5,10 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnand.o - ifdef CONFIG_CMD_NAND
ifdef CONFIG_SPL_BUILD @@ -17,77 +13,59 @@ ifdef CONFIG_SPL_NAND_DRIVERS NORMAL_DRIVERS=y endif
-COBJS-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o -COBJS-$(CONFIG_SPL_NAND_DOCG4) += docg4_spl.o -COBJS-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o -COBJS-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o -COBJS-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o -COBJS-$(CONFIG_SPL_NAND_BASE) += nand_base.o -COBJS-$(CONFIG_SPL_NAND_INIT) += nand.o +obj-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o +obj-$(CONFIG_SPL_NAND_DOCG4) += docg4_spl.o +obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o +obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o +obj-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o +obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o +obj-$(CONFIG_SPL_NAND_INIT) += nand.o
else # not spl
NORMAL_DRIVERS=y
-COBJS-y += nand.o -COBJS-y += nand_bbt.o -COBJS-y += nand_ids.o -COBJS-y += nand_util.o -COBJS-y += nand_ecc.o -COBJS-y += nand_base.o +obj-y += nand.o +obj-y += nand_bbt.o +obj-y += nand_ids.o +obj-y += nand_util.o +obj-y += nand_ecc.o +obj-y += nand_base.o
endif # not spl
ifdef NORMAL_DRIVERS
-COBJS-$(CONFIG_NAND_ECC_BCH) += nand_bch.o - -COBJS-$(CONFIG_NAND_ATMEL) += atmel_nand.o -COBJS-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o -COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o -COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o -COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o -COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o -COBJS-$(CONFIG_NAND_FSMC) += fsmc_nand.o -COBJS-$(CONFIG_NAND_JZ4740) += jz4740_nand.o -COBJS-$(CONFIG_NAND_KB9202) += kb9202_nand.o -COBJS-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o -COBJS-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o -COBJS-$(CONFIG_NAND_MPC5121_NFC) += mpc5121_nfc.o -COBJS-$(CONFIG_NAND_MXC) += mxc_nand.o -COBJS-$(CONFIG_NAND_MXS) += mxs_nand.o -COBJS-$(CONFIG_NAND_NDFC) += ndfc.o -COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o -COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o -COBJS-$(CONFIG_NAND_SPEAR) += spr_nand.o -COBJS-$(CONFIG_TEGRA_NAND) += tegra_nand.o -COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o -COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o -COBJS-$(CONFIG_NAND_DOCG4) += docg4.o +obj-$(CONFIG_NAND_ECC_BCH) += nand_bch.o + +obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o +obj-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o +obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o +obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o +obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o +obj-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o +obj-$(CONFIG_NAND_FSMC) += fsmc_nand.o +obj-$(CONFIG_NAND_JZ4740) += jz4740_nand.o +obj-$(CONFIG_NAND_KB9202) += kb9202_nand.o +obj-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o +obj-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o +obj-$(CONFIG_NAND_MPC5121_NFC) += mpc5121_nfc.o +obj-$(CONFIG_NAND_MXC) += mxc_nand.o +obj-$(CONFIG_NAND_MXS) += mxs_nand.o +obj-$(CONFIG_NAND_NDFC) += ndfc.o +obj-$(CONFIG_NAND_NOMADIK) += nomadik.o +obj-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o +obj-$(CONFIG_NAND_SPEAR) += spr_nand.o +obj-$(CONFIG_TEGRA_NAND) += tegra_nand.o +obj-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o +obj-$(CONFIG_NAND_PLAT) += nand_plat.o +obj-$(CONFIG_NAND_DOCG4) += docg4.o
else # minimal SPL drivers
-COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o -COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o -COBJS-$(CONFIG_NAND_MXC) += mxc_nand_spl.o +obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o +obj-$(CONFIG_NAND_MXC) += mxc_nand_spl.o
endif # drivers endif # nand - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/mtd/onenand/Makefile b/drivers/mtd/onenand/Makefile index 993d317..b249348 100644 --- a/drivers/mtd/onenand/Makefile +++ b/drivers/mtd/onenand/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libonenand.o - ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o -COBJS-$(CONFIG_SAMSUNG_ONENAND) += samsung.o +obj-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o +obj-$(CONFIG_SAMSUNG_ONENAND) += samsung.o else -COBJS-y := onenand_spl.o +obj-y := onenand_spl.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 191138a..4173b5f 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -5,41 +5,19 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libspi_flash.o - ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o -COBJS-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o +obj-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o +obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
-COBJS-$(CONFIG_SPI_FLASH) += spi_flash.o -COBJS-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o -COBJS-$(CONFIG_SPI_FLASH_EON) += eon.o -COBJS-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o -COBJS-$(CONFIG_SPI_FLASH_MACRONIX) += macronix.o -COBJS-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o -COBJS-$(CONFIG_SPI_FLASH_SST) += sst.o -COBJS-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o -COBJS-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o -COBJS-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o -COBJS-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SPI_FLASH) += spi_flash.o +obj-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o +obj-$(CONFIG_SPI_FLASH_EON) += eon.o +obj-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o +obj-$(CONFIG_SPI_FLASH_MACRONIX) += macronix.o +obj-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o +obj-$(CONFIG_SPI_FLASH_SST) += sst.o +obj-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o +obj-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o +obj-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o +obj-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o diff --git a/drivers/mtd/ubi/Makefile b/drivers/mtd/ubi/Makefile index 1a88e94..e1f3a24 100644 --- a/drivers/mtd/ubi/Makefile +++ b/drivers/mtd/ubi/Makefile @@ -5,31 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libubi.o - ifdef CONFIG_CMD_UBI -COBJS-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o +obj-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o
-COBJS-y += misc.o -COBJS-y += debug.o +obj-y += misc.o +obj-y += debug.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
drivers/usb/eth/Makefile | 28 ++-------------- drivers/usb/gadget/Makefile | 54 ++++++++++--------------------- drivers/usb/host/Makefile | 74 +++++++++++++++---------------------------- drivers/usb/musb-new/Makefile | 36 ++++----------------- drivers/usb/musb/Makefile | 36 ++++----------------- drivers/usb/phy/Makefile | 24 +------------- drivers/usb/ulpi/Makefile | 28 ++-------------- 7 files changed, 62 insertions(+), 218 deletions(-)
diff --git a/drivers/usb/eth/Makefile b/drivers/usb/eth/Makefile index 04a8b58..03f5474 100644 --- a/drivers/usb/eth/Makefile +++ b/drivers/usb/eth/Makefile @@ -3,31 +3,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_eth.o - # new USB host ethernet layer dependencies -COBJS-$(CONFIG_USB_HOST_ETHER) += usb_ether.o +obj-$(CONFIG_USB_HOST_ETHER) += usb_ether.o ifdef CONFIG_USB_ETHER_ASIX -COBJS-y += asix.o +obj-y += asix.o endif -COBJS-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 4c2a39a..276ad6e 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -5,56 +5,34 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_gadget.o - # if defined(CONFIG_USB_GADGET) || defined(CONFIG_USB_ETHER) # Everytime you forget how crufty makefiles can get things like # this remind you... ifneq (,$(CONFIG_USB_GADGET)$(CONFIG_USB_ETHER)) -COBJS-y += epautoconf.o config.o usbstring.o +obj-y += epautoconf.o config.o usbstring.o endif
# new USB gadget layer dependencies ifdef CONFIG_USB_GADGET -COBJS-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o -COBJS-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o -COBJS-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o -COBJS-$(CONFIG_DFU_FUNCTION) += f_dfu.o +obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o +obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o +obj-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o +obj-$(CONFIG_DFU_FUNCTION) += f_dfu.o endif ifdef CONFIG_USB_ETHER -COBJS-y += ether.o -COBJS-$(CONFIG_USB_ETH_RNDIS) += rndis.o -COBJS-$(CONFIG_MV_UDC) += mv_udc.o -COBJS-$(CONFIG_CPU_PXA25X) += pxa25x_udc.o +obj-y += ether.o +obj-$(CONFIG_USB_ETH_RNDIS) += rndis.o +obj-$(CONFIG_MV_UDC) += mv_udc.o +obj-$(CONFIG_CPU_PXA25X) += pxa25x_udc.o else # Devices not related to the new gadget layer depend on CONFIG_USB_DEVICE ifdef CONFIG_USB_DEVICE -COBJS-y += core.o -COBJS-y += ep0.o -COBJS-$(CONFIG_DW_UDC) += designware_udc.o -COBJS-$(CONFIG_OMAP1510) += omap1510_udc.o -COBJS-$(CONFIG_OMAP1610) += omap1510_udc.o -COBJS-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o -COBJS-$(CONFIG_CPU_PXA27X) += pxa27x_udc.o +obj-y += core.o +obj-y += ep0.o +obj-$(CONFIG_DW_UDC) += designware_udc.o +obj-$(CONFIG_OMAP1510) += omap1510_udc.o +obj-$(CONFIG_OMAP1610) += omap1510_udc.o +obj-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o +obj-$(CONFIG_CPU_PXA27X) += pxa27x_udc.o endif endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index ff6c80e..674508a 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -5,57 +5,35 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_host.o - # ohci -COBJS-$(CONFIG_USB_OHCI_NEW) += ohci-hcd.o -COBJS-$(CONFIG_USB_ATMEL) += ohci-at91.o -COBJS-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o -COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o -COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o -COBJS-$(CONFIG_USB_SL811HS) += sl811-hcd.o -COBJS-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o +obj-$(CONFIG_USB_OHCI_NEW) += ohci-hcd.o +obj-$(CONFIG_USB_ATMEL) += ohci-at91.o +obj-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o +obj-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o +obj-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o +obj-$(CONFIG_USB_SL811HS) += sl811-hcd.o +obj-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o
# echi -COBJS-$(CONFIG_USB_EHCI) += ehci-hcd.o -COBJS-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi-armada100.o -COBJS-$(CONFIG_USB_EHCI_ATMEL) += ehci-atmel.o +obj-$(CONFIG_USB_EHCI) += ehci-hcd.o +obj-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi-armada100.o +obj-$(CONFIG_USB_EHCI_ATMEL) += ehci-atmel.o ifdef CONFIG_MPC512X -COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o +obj-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o else -COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o +obj-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o endif -COBJS-$(CONFIG_USB_EHCI_FARADAY) += ehci-faraday.o -COBJS-$(CONFIG_USB_EHCI_EXYNOS) += ehci-exynos.o -COBJS-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o -COBJS-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o -COBJS-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o -COBJS-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o -COBJS-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o -COBJS-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o -COBJS-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o -COBJS-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o -COBJS-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o -COBJS-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o -COBJS-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o -COBJS-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_EHCI_FARADAY) += ehci-faraday.o +obj-$(CONFIG_USB_EHCI_EXYNOS) += ehci-exynos.o +obj-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o +obj-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o +obj-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o +obj-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o +obj-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o +obj-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o +obj-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o +obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o +obj-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o +obj-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o +obj-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o +obj-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o diff --git a/drivers/usb/musb-new/Makefile b/drivers/usb/musb-new/Makefile index c23bef1..ba72348 100644 --- a/drivers/usb/musb-new/Makefile +++ b/drivers/usb/musb-new/Makefile @@ -2,38 +2,14 @@ # for USB OTG silicon based on Mentor Graphics INVENTRA designs #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_musb-new.o - -COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o -COBJS-$(CONFIG_MUSB_GADGET) += musb_uboot.o -COBJS-$(CONFIG_MUSB_HOST) += musb_host.o musb_core.o musb_uboot.o -COBJS-$(CONFIG_USB_MUSB_DSPS) += musb_dsps.o -COBJS-$(CONFIG_USB_MUSB_AM35X) += am35x.o -COBJS-$(CONFIG_USB_MUSB_OMAP2PLUS) += omap2430.o +obj-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o +obj-$(CONFIG_MUSB_GADGET) += musb_uboot.o +obj-$(CONFIG_MUSB_HOST) += musb_host.o musb_core.o musb_uboot.o +obj-$(CONFIG_USB_MUSB_DSPS) += musb_dsps.o +obj-$(CONFIG_USB_MUSB_AM35X) += am35x.o +obj-$(CONFIG_USB_MUSB_OMAP2PLUS) += omap2430.o
CFLAGS_NO_WARN := $(call cc-option,-Wno-unused-variable) \ $(call cc-option,-Wno-unused-but-set-variable) \ $(call cc-option,-Wno-unused-label) CFLAGS += $(CFLAGS_NO_WARN) - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -#$(LIB): $(OBJS) -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### - diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index aa2126d..3c9ed98 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -5,32 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_musb.o - -COBJS-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o -COBJS-$(CONFIG_MUSB_UDC) += musb_udc.o musb_core.o -COBJS-$(CONFIG_USB_BLACKFIN) += blackfin_usb.o -COBJS-$(CONFIG_USB_DAVINCI) += davinci.o -COBJS-$(CONFIG_USB_OMAP3) += omap3.o -COBJS-$(CONFIG_USB_DA8XX) += da8xx.o -COBJS-$(CONFIG_USB_AM35X) += am35x.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o +obj-$(CONFIG_MUSB_UDC) += musb_udc.o musb_core.o +obj-$(CONFIG_USB_BLACKFIN) += blackfin_usb.o +obj-$(CONFIG_USB_DAVINCI) += davinci.o +obj-$(CONFIG_USB_OMAP3) += omap3.o +obj-$(CONFIG_USB_DA8XX) += da8xx.o +obj-$(CONFIG_USB_AM35X) += am35x.o diff --git a/drivers/usb/phy/Makefile b/drivers/usb/phy/Makefile index f93121a..535cf51 100644 --- a/drivers/usb/phy/Makefile +++ b/drivers/usb/phy/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_phy.o - -COBJS-$(CONFIG_TWL4030_USB) += twl4030.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TWL4030_USB) += twl4030.o diff --git a/drivers/usb/ulpi/Makefile b/drivers/usb/ulpi/Makefile index ba5a1ab..a21fe2c 100644 --- a/drivers/usb/ulpi/Makefile +++ b/drivers/usb/ulpi/Makefile @@ -4,28 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_ulpi.o - -COBJS-$(CONFIG_USB_ULPI) += ulpi.o -COBJS-$(CONFIG_USB_ULPI_VIEWPORT) += ulpi-viewport.o -COBJS-$(CONFIG_USB_ULPI_VIEWPORT_OMAP) += omap-ulpi-viewport.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_ULPI) += ulpi.o +obj-$(CONFIG_USB_ULPI_VIEWPORT) += ulpi-viewport.o +obj-$(CONFIG_USB_ULPI_VIEWPORT_OMAP) += omap-ulpi-viewport.o
Changed for v2:
- updated 6 files to rebase on the master drivers/serial/Makefile drivers/mmc/Makefile drivers/video/Makefile drivers/watchdog/Makefile drivers/rtc/Makefile drivers/i2c/Makefile
drivers/bios_emulator/Makefile | 23 +------- drivers/block/Makefile | 52 ++++++------------ drivers/bootcount/Makefile | 30 ++--------- drivers/crypto/Makefile | 25 +-------- drivers/dfu/Makefile | 25 ++------- drivers/dma/Makefile | 30 ++--------- drivers/fpga/Makefile | 44 ++++------------ drivers/gpio/Makefile | 73 +++++++++----------------- drivers/hwmon/Makefile | 40 ++++---------- drivers/i2c/Makefile | 68 ++++++++---------------- drivers/input/Makefile | 36 +++---------- drivers/misc/Makefile | 52 ++++++------------ drivers/mmc/Makefile | 71 +++++++++---------------- drivers/pci/Makefile | 44 ++++------------ drivers/pcmcia/Makefile | 34 +++--------- drivers/power/Makefile | 47 +++++------------ drivers/power/battery/Makefile | 25 +-------- drivers/power/fuel_gauge/Makefile | 25 +-------- drivers/power/pmic/Makefile | 31 ++--------- drivers/qe/Makefile | 25 +-------- drivers/rtc/Makefile | 108 +++++++++++++++----------------------- drivers/serial/Makefile | 82 +++++++++++------------------ drivers/sound/Makefile | 30 ++--------- drivers/spi/Makefile | 82 +++++++++++------------------ drivers/tpm/Makefile | 29 ++-------- drivers/twserial/Makefile | 24 +-------- drivers/video/Makefile | 86 +++++++++++------------------- drivers/watchdog/Makefile | 38 +++----------- 28 files changed, 332 insertions(+), 947 deletions(-)
diff --git a/drivers/bios_emulator/Makefile b/drivers/bios_emulator/Makefile index d94a144..dd42e0f 100644 --- a/drivers/bios_emulator/Makefile +++ b/drivers/bios_emulator/Makefile @@ -1,12 +1,8 @@ -include $(TOPDIR)/config.mk - -LIB := $(obj)libatibiosemu.o - X86DIR = x86emu
$(shell mkdir -p $(obj)$(X86DIR))
-COBJS-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ +obj-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/decode.o \ $(X86DIR)/ops2.o \ $(X86DIR)/ops.o \ @@ -14,26 +10,9 @@ COBJS-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/sys.o \ $(X86DIR)/debug.o
-COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - EXTRA_CFLAGS += -I. -I./include -I$(TOPDIR)/include \ -D__PPC__ -D__BIG_ENDIAN__
CFLAGS += $(EXTRA_CFLAGS) HOSTCFLAGS += $(EXTRA_CFLAGS) CPPFLAGS += $(EXTRA_CFLAGS) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 2016e98..4e94378 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libblock.o - -COBJS-$(CONFIG_SCSI_AHCI) += ahci.o -COBJS-$(CONFIG_ATA_PIIX) += ata_piix.o -COBJS-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o -COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o -COBJS-$(CONFIG_IDE_FTIDE020) += ftide020.o -COBJS-$(CONFIG_LIBATA) += libata.o -COBJS-$(CONFIG_MVSATA_IDE) += mvsata_ide.o -COBJS-$(CONFIG_MX51_PATA) += mxc_ata.o -COBJS-$(CONFIG_PATA_BFIN) += pata_bfin.o -COBJS-$(CONFIG_SATA_DWC) += sata_dwc.o -COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o -COBJS-$(CONFIG_SATA_SIL) += sata_sil.o -COBJS-$(CONFIG_IDE_SIL680) += sil680.o -COBJS-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o -COBJS-$(CONFIG_SYSTEMACE) += systemace.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SCSI_AHCI) += ahci.o +obj-$(CONFIG_ATA_PIIX) += ata_piix.o +obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o +obj-$(CONFIG_FSL_SATA) += fsl_sata.o +obj-$(CONFIG_IDE_FTIDE020) += ftide020.o +obj-$(CONFIG_LIBATA) += libata.o +obj-$(CONFIG_MVSATA_IDE) += mvsata_ide.o +obj-$(CONFIG_MX51_PATA) += mxc_ata.o +obj-$(CONFIG_PATA_BFIN) += pata_bfin.o +obj-$(CONFIG_SATA_DWC) += sata_dwc.o +obj-$(CONFIG_SATA_SIL3114) += sata_sil3114.o +obj-$(CONFIG_SATA_SIL) += sata_sil.o +obj-$(CONFIG_IDE_SIL680) += sil680.o +obj-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o +obj-$(CONFIG_SYSTEMACE) += systemace.o diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index 2b517b6..012acef 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -2,28 +2,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libbootcount.o - -COBJS-y += bootcount.o -COBJS-$(CONFIG_AT91SAM9XE) += bootcount_at91.o -COBJS-$(CONFIG_BLACKFIN) += bootcount_blackfin.o -COBJS-$(CONFIG_SOC_DA8XX) += bootcount_davinci.o -COBJS-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-y += bootcount.o +obj-$(CONFIG_AT91SAM9XE) += bootcount_at91.o +obj-$(CONFIG_BLACKFIN) += bootcount_blackfin.o +obj-$(CONFIG_SOC_DA8XX) += bootcount_davinci.o +obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile index 02c53bf..b807795 100644 --- a/drivers/crypto/Makefile +++ b/drivers/crypto/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libcrypto.o - -COBJS-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index fca370a..f7b7014 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -5,25 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libdfu.o - -COBJS-$(CONFIG_DFU_FUNCTION) += dfu.o -COBJS-$(CONFIG_DFU_MMC) += dfu_mmc.o -COBJS-$(CONFIG_DFU_NAND) += dfu_nand.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DFU_FUNCTION) += dfu.o +obj-$(CONFIG_DFU_MMC) += dfu_mmc.o +obj-$(CONFIG_DFU_NAND) += dfu_nand.o diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile index a6132e2..8b2821b 100644 --- a/drivers/dma/Makefile +++ b/drivers/dma/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libdma.o - -COBJS-$(CONFIG_FSLDMAFEC) += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o -COBJS-$(CONFIG_APBH_DMA) += apbh_dma.o -COBJS-$(CONFIG_FSL_DMA) += fsl_dma.o -COBJS-$(CONFIG_OMAP3_DMA) += omap3_dma.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FSLDMAFEC) += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o +obj-$(CONFIG_APBH_DMA) += apbh_dma.o +obj-$(CONFIG_FSL_DMA) += fsl_dma.o +obj-$(CONFIG_OMAP3_DMA) += omap3_dma.o diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index a1a0602..4fcdf40 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfpga.o - ifdef CONFIG_FPGA -COBJS-y += fpga.o -COBJS-$(CONFIG_FPGA_SPARTAN2) += spartan2.o -COBJS-$(CONFIG_FPGA_SPARTAN3) += spartan3.o -COBJS-$(CONFIG_FPGA_VIRTEX2) += virtex2.o -COBJS-$(CONFIG_FPGA_ZYNQPL) += zynqpl.o -COBJS-$(CONFIG_FPGA_XILINX) += xilinx.o -COBJS-$(CONFIG_FPGA_LATTICE) += ivm_core.o lattice.o +obj-y += fpga.o +obj-$(CONFIG_FPGA_SPARTAN2) += spartan2.o +obj-$(CONFIG_FPGA_SPARTAN3) += spartan3.o +obj-$(CONFIG_FPGA_VIRTEX2) += virtex2.o +obj-$(CONFIG_FPGA_ZYNQPL) += zynqpl.o +obj-$(CONFIG_FPGA_XILINX) += xilinx.o +obj-$(CONFIG_FPGA_LATTICE) += ivm_core.o lattice.o ifdef CONFIG_FPGA_ALTERA -COBJS-y += altera.o -COBJS-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o -COBJS-$(CONFIG_FPGA_CYCLON2) += cyclon2.o -COBJS-$(CONFIG_FPGA_STRATIX_II) += stratixII.o +obj-y += altera.o +obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o +obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o +obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o endif endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 71ddb00..1165793 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -5,51 +5,28 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libgpio.o - -COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o -COBJS-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o -COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o -COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o -COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o -COBJS-$(CONFIG_MXC_GPIO) += mxc_gpio.o -COBJS-$(CONFIG_MXS_GPIO) += mxs_gpio.o -COBJS-$(CONFIG_PCA953X) += pca953x.o -COBJS-$(CONFIG_PCA9698) += pca9698.o -COBJS-$(CONFIG_S5P) += s5p_gpio.o -COBJS-$(CONFIG_SANDBOX_GPIO) += sandbox.o -COBJS-$(CONFIG_SPEAR_GPIO) += spear_gpio.o -COBJS-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o -COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o -COBJS-$(CONFIG_DM644X_GPIO) += da8xx_gpio.o -COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o -COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o -COBJS-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o -COBJS-$(CONFIG_OMAP_GPIO) += omap_gpio.o -COBJS-$(CONFIG_DB8500_GPIO) += db8500_gpio.o -COBJS-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o -COBJS-$(CONFIG_S3C2440_GPIO) += s3c2440_gpio.o -COBJS-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o -COBJS-$(CONFIG_ADI_GPIO2) += adi_gpio2.o -COBJS-$(CONFIG_TCA642X) += tca642x.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_AT91_GPIO) += at91_gpio.o +obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o +obj-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o +obj-$(CONFIG_MARVELL_GPIO) += mvgpio.o +obj-$(CONFIG_MARVELL_MFP) += mvmfp.o +obj-$(CONFIG_MXC_GPIO) += mxc_gpio.o +obj-$(CONFIG_MXS_GPIO) += mxs_gpio.o +obj-$(CONFIG_PCA953X) += pca953x.o +obj-$(CONFIG_PCA9698) += pca9698.o +obj-$(CONFIG_S5P) += s5p_gpio.o +obj-$(CONFIG_SANDBOX_GPIO) += sandbox.o +obj-$(CONFIG_SPEAR_GPIO) += spear_gpio.o +obj-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o +obj-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o +obj-$(CONFIG_DM644X_GPIO) += da8xx_gpio.o +obj-$(CONFIG_ALTERA_PIO) += altera_pio.o +obj-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +obj-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o +obj-$(CONFIG_OMAP_GPIO) += omap_gpio.o +obj-$(CONFIG_DB8500_GPIO) += db8500_gpio.o +obj-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o +obj-$(CONFIG_S3C2440_GPIO) += s3c2440_gpio.o +obj-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o +obj-$(CONFIG_ADI_GPIO2) += adi_gpio2.o +obj-$(CONFIG_TCA642X) += tca642x.o diff --git a/drivers/hwmon/Makefile b/drivers/hwmon/Makefile index 6e203a3..a78a724 100644 --- a/drivers/hwmon/Makefile +++ b/drivers/hwmon/Makefile @@ -8,36 +8,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - #CFLAGS += -DDEBUG
-LIB = $(obj)libhwmon.o - -COBJS-$(CONFIG_DTT_ADM1021) += adm1021.o -COBJS-$(CONFIG_DTT_ADT7460) += adt7460.o -COBJS-$(CONFIG_DTT_DS1621) += ds1621.o -COBJS-$(CONFIG_DTT_DS1722) += ds1722.o -COBJS-$(CONFIG_DTT_DS1775) += ds1775.o -COBJS-$(CONFIG_DTT_LM63) += lm63.o -COBJS-$(CONFIG_DTT_LM73) += lm73.o -COBJS-$(CONFIG_DTT_LM75) += lm75.o -COBJS-$(CONFIG_DTT_LM81) += lm81.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DTT_ADM1021) += adm1021.o +obj-$(CONFIG_DTT_ADT7460) += adt7460.o +obj-$(CONFIG_DTT_DS1621) += ds1621.o +obj-$(CONFIG_DTT_DS1722) += ds1722.o +obj-$(CONFIG_DTT_DS1775) += ds1775.o +obj-$(CONFIG_DTT_LM63) += lm63.o +obj-$(CONFIG_DTT_LM73) += lm73.o +obj-$(CONFIG_DTT_LM75) += lm75.o +obj-$(CONFIG_DTT_LM81) += lm81.o diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index df3092e..4b8b75c 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -5,48 +5,26 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libi2c.o - -COBJS-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o -COBJS-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o -COBJS-$(CONFIG_DW_I2C) += designware_i2c.o -COBJS-$(CONFIG_I2C_MVTWSI) += mvtwsi.o -COBJS-$(CONFIG_I2C_MV) += mv_i2c.o -COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o -COBJS-$(CONFIG_I2C_MXS) += mxs_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o -COBJS-$(CONFIG_PCA9564_I2C) += pca9564_i2c.o -COBJS-$(CONFIG_DRIVER_S3C24X0_I2C) += s3c24x0_i2c.o -COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o -COBJS-$(CONFIG_U8500_I2C) += u8500_i2c.o -COBJS-$(CONFIG_SH_I2C) += sh_i2c.o -COBJS-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o -COBJS-$(CONFIG_SYS_I2C) += i2c_core.o -COBJS-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o -COBJS-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o -COBJS-$(CONFIG_SYS_I2C_PPC4XX) += ppc4xx_i2c.o -COBJS-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o -COBJS-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o -COBJS-$(CONFIG_ZYNQ_I2C) += zynq_i2c.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o +obj-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o +obj-$(CONFIG_DW_I2C) += designware_i2c.o +obj-$(CONFIG_I2C_MVTWSI) += mvtwsi.o +obj-$(CONFIG_I2C_MV) += mv_i2c.o +obj-$(CONFIG_I2C_MXC) += mxc_i2c.o +obj-$(CONFIG_I2C_MXS) += mxs_i2c.o +obj-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o +obj-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o +obj-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o +obj-$(CONFIG_PCA9564_I2C) += pca9564_i2c.o +obj-$(CONFIG_DRIVER_S3C24X0_I2C) += s3c24x0_i2c.o +obj-$(CONFIG_TSI108_I2C) += tsi108_i2c.o +obj-$(CONFIG_U8500_I2C) += u8500_i2c.o +obj-$(CONFIG_SH_I2C) += sh_i2c.o +obj-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o +obj-$(CONFIG_SYS_I2C) += i2c_core.o +obj-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o +obj-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o +obj-$(CONFIG_SYS_I2C_PPC4XX) += ppc4xx_i2c.o +obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o +obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o +obj-$(CONFIG_ZYNQ_I2C) += zynq_i2c.o diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 7885403..a8e9be2 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -5,34 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libinput.o - -COBJS-$(CONFIG_I8042_KBD) += i8042.o -COBJS-$(CONFIG_TEGRA_KEYBOARD) += tegra-kbc.o -COBJS-$(CONFIG_CROS_EC_KEYB) += cros_ec_keyb.o +obj-$(CONFIG_I8042_KBD) += i8042.o +obj-$(CONFIG_TEGRA_KEYBOARD) += tegra-kbc.o +obj-$(CONFIG_CROS_EC_KEYB) += cros_ec_keyb.o ifdef CONFIG_PS2KBD -COBJS-y += keyboard.o pc_keyb.o -COBJS-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o +obj-y += keyboard.o pc_keyb.o +obj-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o endif -COBJS-y += input.o -COBJS-$(CONFIG_OF_CONTROL) += key_matrix.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += input.o +obj-$(CONFIG_OF_CONTROL) += key_matrix.o diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 08828ee..d8ff9c6 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmisc.o - -COBJS-$(CONFIG_ALI152X) += ali512x.o -COBJS-$(CONFIG_DS4510) += ds4510.o -COBJS-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o -COBJS-$(CONFIG_CROS_EC) += cros_ec.o -COBJS-$(CONFIG_CROS_EC_LPC) += cros_ec_lpc.o -COBJS-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o -COBJS-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o -COBJS-$(CONFIG_FSL_IIM) += fsl_iim.o -COBJS-$(CONFIG_GPIO_LED) += gpio_led.o -COBJS-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o -COBJS-$(CONFIG_MXC_OCOTP) += mxc_ocotp.o -COBJS-$(CONFIG_NS87308) += ns87308.o -COBJS-$(CONFIG_PDSP188x) += pdsp188x.o -COBJS-$(CONFIG_STATUS_LED) += status_led.o -COBJS-$(CONFIG_TWL4030_LED) += twl4030_led.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_DS4510) += ds4510.o +obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o +obj-$(CONFIG_CROS_EC) += cros_ec.o +obj-$(CONFIG_CROS_EC_LPC) += cros_ec_lpc.o +obj-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o +obj-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o +obj-$(CONFIG_FSL_IIM) += fsl_iim.o +obj-$(CONFIG_GPIO_LED) += gpio_led.o +obj-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o +obj-$(CONFIG_MXC_OCOTP) += mxc_ocotp.o +obj-$(CONFIG_NS87308) += ns87308.o +obj-$(CONFIG_PDSP188x) += pdsp188x.o +obj-$(CONFIG_STATUS_LED) += status_led.o +obj-$(CONFIG_TWL4030_LED) += twl4030_led.o diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 06280d1..a7ae38d 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -5,53 +5,30 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmmc.o - - -COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o -COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o -COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o -COBJS-$(CONFIG_FTSDC010) += ftsdc010_mci.o -COBJS-$(CONFIG_GENERIC_MMC) += mmc.o -COBJS-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o -COBJS-$(CONFIG_MMC_SPI) += mmc_spi.o -COBJS-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o -COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o -COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o -COBJS-$(CONFIG_MXS_MMC) += mxsmmc.o -COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o -COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o -COBJS-$(CONFIG_SDHCI) += sdhci.o -COBJS-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o -COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o -COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o -COBJS-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o -COBJS-$(CONFIG_TEGRA_MMC) += tegra_mmc.o -COBJS-$(CONFIG_DWMMC) += dw_mmc.o -COBJS-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o -COBJS-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o +obj-$(CONFIG_BFIN_SDH) += bfin_sdh.o +obj-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +obj-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o +obj-$(CONFIG_FTSDC010) += ftsdc010_mci.o +obj-$(CONFIG_GENERIC_MMC) += mmc.o +obj-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o +obj-$(CONFIG_MMC_SPI) += mmc_spi.o +obj-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o +obj-$(CONFIG_MV_SDHCI) += mv_sdhci.o +obj-$(CONFIG_MXC_MMC) += mxcmmc.o +obj-$(CONFIG_MXS_MMC) += mxsmmc.o +obj-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o +obj-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o +obj-$(CONFIG_SDHCI) += sdhci.o +obj-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o +obj-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o +obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o +obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o +obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o +obj-$(CONFIG_DWMMC) += dw_mmc.o +obj-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o +obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o +obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else -COBJS-$(CONFIG_GENERIC_MMC) += mmc_write.o +obj-$(CONFIG_GENERIC_MMC) += mmc_write.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index be26b60..99d51a6 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -5,36 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpci.o - -COBJS-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o -COBJS-$(CONFIG_PCI) += pci.o pci_auto.o -COBJS-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o -COBJS-$(CONFIG_PCI_GT64120) += pci_gt64120.o -COBJS-$(CONFIG_FTPCI100) += pci_ftpci100.o -COBJS-$(CONFIG_IXP_PCI) += pci_ixp.o -COBJS-$(CONFIG_SH4_PCI) += pci_sh4.o -COBJS-$(CONFIG_SH7751_PCI) +=pci_sh7751.o -COBJS-$(CONFIG_SH7780_PCI) +=pci_sh7780.o -COBJS-$(CONFIG_TSI108_PCI) += tsi108_pci.o -COBJS-$(CONFIG_WINBOND_83C553) += w83c553f.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o +obj-$(CONFIG_PCI) += pci.o pci_auto.o +obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o +obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o +obj-$(CONFIG_FTPCI100) += pci_ftpci100.o +obj-$(CONFIG_IXP_PCI) += pci_ixp.o +obj-$(CONFIG_SH4_PCI) += pci_sh4.o +obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o +obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o +obj-$(CONFIG_TSI108_PCI) += tsi108_pci.o +obj-$(CONFIG_WINBOND_83C553) += w83c553f.o diff --git a/drivers/pcmcia/Makefile b/drivers/pcmcia/Makefile index 80a132e..ae3cafb 100644 --- a/drivers/pcmcia/Makefile +++ b/drivers/pcmcia/Makefile @@ -5,31 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpcmcia.o - -COBJS-$(CONFIG_I82365) += i82365.o -COBJS-$(CONFIG_8xx) += mpc8xx_pcmcia.o -COBJS-y += rpx_pcmcia.o -COBJS-$(CONFIG_IDE_TI_CARDBUS) += ti_pci1410a.o -COBJS-y += tqm8xx_pcmcia.o -COBJS-$(CONFIG_MARUBUN_PCCARD) += marubun_pcmcia.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_I82365) += i82365.o +obj-$(CONFIG_8xx) += mpc8xx_pcmcia.o +obj-y += rpx_pcmcia.o +obj-$(CONFIG_IDE_TI_CARDBUS) += ti_pci1410a.o +obj-y += tqm8xx_pcmcia.o +obj-$(CONFIG_MARUBUN_PCCARD) += marubun_pcmcia.o diff --git a/drivers/power/Makefile b/drivers/power/Makefile index b2812dc..53ff97d 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -5,38 +5,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpower.o - -COBJS-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o -COBJS-$(CONFIG_FTPMU010_POWER) += ftpmu010.o -COBJS-$(CONFIG_TPS6586X_POWER) += tps6586x.o -COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o -COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o -COBJS-$(CONFIG_PALMAS_POWER) += palmas.o - -COBJS-$(CONFIG_POWER) += power_core.o -COBJS-$(CONFIG_DIALOG_POWER) += power_dialog.o -COBJS-$(CONFIG_POWER_FSL) += power_fsl.o -COBJS-$(CONFIG_POWER_I2C) += power_i2c.o -COBJS-$(CONFIG_POWER_SPI) += power_spi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o +obj-$(CONFIG_FTPMU010_POWER) += ftpmu010.o +obj-$(CONFIG_TPS6586X_POWER) += tps6586x.o +obj-$(CONFIG_TWL4030_POWER) += twl4030.o +obj-$(CONFIG_TWL6030_POWER) += twl6030.o +obj-$(CONFIG_PALMAS_POWER) += palmas.o + +obj-$(CONFIG_POWER) += power_core.o +obj-$(CONFIG_DIALOG_POWER) += power_dialog.o +obj-$(CONFIG_POWER_FSL) += power_fsl.o +obj-$(CONFIG_POWER_I2C) += power_i2c.o +obj-$(CONFIG_POWER_SPI) += power_spi.o diff --git a/drivers/power/battery/Makefile b/drivers/power/battery/Makefile index 637d1ff..a1f6ad9 100644 --- a/drivers/power/battery/Makefile +++ b/drivers/power/battery/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libbattery.o - -COBJS-$(CONFIG_POWER_BATTERY_TRATS) += bat_trats.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_BATTERY_TRATS) += bat_trats.o diff --git a/drivers/power/fuel_gauge/Makefile b/drivers/power/fuel_gauge/Makefile index 5166a30..3b349f9 100644 --- a/drivers/power/fuel_gauge/Makefile +++ b/drivers/power/fuel_gauge/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfuel_gauge.o - -COBJS-$(CONFIG_POWER_FG_MAX17042) += fg_max17042.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_FG_MAX17042) += fg_max17042.o diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index f054470..476cae5 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -5,30 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpmic.o - -COBJS-$(CONFIG_POWER_MAX8998) += pmic_max8998.o -COBJS-$(CONFIG_POWER_MAX8997) += pmic_max8997.o -COBJS-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o -COBJS-$(CONFIG_POWER_MAX77686) += pmic_max77686.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o +obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o +obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o +obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o diff --git a/drivers/qe/Makefile b/drivers/qe/Makefile index 3aaf757..b8c15f8 100644 --- a/drivers/qe/Makefile +++ b/drivers/qe/Makefile @@ -4,26 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libqe.o - -COBJS-$(and $(CONFIG_QE),$(CONFIG_OF_LIBFDT)) += fdt.o -COBJS-$(CONFIG_QE) += qe.o uccf.o uec.o uec_phy.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(and $(CONFIG_QE),$(CONFIG_OF_LIBFDT)) += fdt.o +obj-$(CONFIG_QE) += qe.o uccf.o uec.o uec_phy.o diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index dcc0632..d5a2725 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -5,70 +5,48 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)librtc.o - -COBJS-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o -COBJS-$(CONFIG_RTC_BFIN) += bfin_rtc.o -COBJS-y += date.o -COBJS-$(CONFIG_RTC_DAVINCI) += davinci.o -COBJS-$(CONFIG_RTC_DS12887) += ds12887.o -COBJS-$(CONFIG_RTC_DS1302) += ds1302.o -COBJS-$(CONFIG_RTC_DS1306) += ds1306.o -COBJS-$(CONFIG_RTC_DS1307) += ds1307.o -COBJS-$(CONFIG_RTC_DS1338) += ds1307.o -COBJS-$(CONFIG_RTC_DS1337) += ds1337.o -COBJS-$(CONFIG_RTC_DS1374) += ds1374.o -COBJS-$(CONFIG_RTC_DS1388) += ds1337.o -COBJS-$(CONFIG_RTC_DS1556) += ds1556.o -COBJS-$(CONFIG_RTC_DS164x) += ds164x.o -COBJS-$(CONFIG_RTC_DS174x) += ds174x.o -COBJS-$(CONFIG_RTC_DS3231) += ds3231.o -COBJS-$(CONFIG_RTC_FTRTC010) += ftrtc010.o -COBJS-$(CONFIG_RTC_IMXDI) += imxdi.o -COBJS-$(CONFIG_RTC_ISL1208) += isl1208.o -COBJS-$(CONFIG_RTC_M41T11) += m41t11.o -COBJS-$(CONFIG_RTC_M41T60) += m41t60.o -COBJS-$(CONFIG_RTC_M41T62) += m41t62.o -COBJS-$(CONFIG_RTC_M41T94) += m41t94.o -COBJS-$(CONFIG_RTC_M48T35A) += m48t35ax.o -COBJS-$(CONFIG_RTC_MAX6900) += max6900.o -COBJS-$(CONFIG_RTC_MC13XXX) += mc13xxx-rtc.o -COBJS-$(CONFIG_RTC_MC146818) += mc146818.o -COBJS-$(CONFIG_MCFRTC) += mcfrtc.o -COBJS-$(CONFIG_RTC_MK48T59) += mk48t59.o -COBJS-$(CONFIG_RTC_MPC5200) += mpc5xxx.o -COBJS-$(CONFIG_RTC_MPC8xx) += mpc8xx.o -COBJS-$(CONFIG_RTC_MV) += mvrtc.o -COBJS-$(CONFIG_RTC_MX27) += mx27rtc.o -COBJS-$(CONFIG_RTC_MXS) += mxsrtc.o -COBJS-$(CONFIG_RTC_PCF8563) += pcf8563.o -COBJS-$(CONFIG_RTC_PL031) += pl031.o -COBJS-$(CONFIG_RTC_PT7C4338) += pt7c4338.o -COBJS-$(CONFIG_RTC_RS5C372A) += rs5c372.o -COBJS-$(CONFIG_RTC_RTC4543) += rtc4543.o -COBJS-$(CONFIG_RTC_RV3029) += rv3029.o -COBJS-$(CONFIG_RTC_RX8025) += rx8025.o -COBJS-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o -COBJS-$(CONFIG_RTC_X1205) += x1205.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o +obj-$(CONFIG_RTC_BFIN) += bfin_rtc.o +obj-y += date.o +obj-$(CONFIG_RTC_DAVINCI) += davinci.o +obj-$(CONFIG_RTC_DS12887) += ds12887.o +obj-$(CONFIG_RTC_DS1302) += ds1302.o +obj-$(CONFIG_RTC_DS1306) += ds1306.o +obj-$(CONFIG_RTC_DS1307) += ds1307.o +obj-$(CONFIG_RTC_DS1338) += ds1307.o +obj-$(CONFIG_RTC_DS1337) += ds1337.o +obj-$(CONFIG_RTC_DS1374) += ds1374.o +obj-$(CONFIG_RTC_DS1388) += ds1337.o +obj-$(CONFIG_RTC_DS1556) += ds1556.o +obj-$(CONFIG_RTC_DS164x) += ds164x.o +obj-$(CONFIG_RTC_DS174x) += ds174x.o +obj-$(CONFIG_RTC_DS3231) += ds3231.o +obj-$(CONFIG_RTC_FTRTC010) += ftrtc010.o +obj-$(CONFIG_RTC_IMXDI) += imxdi.o +obj-$(CONFIG_RTC_ISL1208) += isl1208.o +obj-$(CONFIG_RTC_M41T11) += m41t11.o +obj-$(CONFIG_RTC_M41T60) += m41t60.o +obj-$(CONFIG_RTC_M41T62) += m41t62.o +obj-$(CONFIG_RTC_M41T94) += m41t94.o +obj-$(CONFIG_RTC_M48T35A) += m48t35ax.o +obj-$(CONFIG_RTC_MAX6900) += max6900.o +obj-$(CONFIG_RTC_MC13XXX) += mc13xxx-rtc.o +obj-$(CONFIG_RTC_MC146818) += mc146818.o +obj-$(CONFIG_MCFRTC) += mcfrtc.o +obj-$(CONFIG_RTC_MK48T59) += mk48t59.o +obj-$(CONFIG_RTC_MPC5200) += mpc5xxx.o +obj-$(CONFIG_RTC_MPC8xx) += mpc8xx.o +obj-$(CONFIG_RTC_MV) += mvrtc.o +obj-$(CONFIG_RTC_MX27) += mx27rtc.o +obj-$(CONFIG_RTC_MXS) += mxsrtc.o +obj-$(CONFIG_RTC_PCF8563) += pcf8563.o +obj-$(CONFIG_RTC_PL031) += pl031.o +obj-$(CONFIG_RTC_PT7C4338) += pt7c4338.o +obj-$(CONFIG_RTC_RS5C372A) += rs5c372.o +obj-$(CONFIG_RTC_RTC4543) += rtc4543.o +obj-$(CONFIG_RTC_RV3029) += rv3029.o +obj-$(CONFIG_RTC_RX8025) += rx8025.o +obj-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o +obj-$(CONFIG_RTC_X1205) += x1205.o diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index e1fd7a5..6b4cade 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -5,58 +5,36 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libserial.o - -COBJS-y += serial.o - -COBJS-$(CONFIG_ALTERA_UART) += altera_uart.o -COBJS-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o -COBJS-$(CONFIG_ARM_DCC) += arm_dcc.o -COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o -COBJS-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o -COBJS-$(CONFIG_MCFUART) += mcfuart.o -COBJS-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o -COBJS-$(CONFIG_SYS_NS16550) += ns16550.o -COBJS-$(CONFIG_S5P) += serial_s5p.o -COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o -COBJS-$(CONFIG_IMX_SERIAL) += serial_imx.o -COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o -COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o -COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o -COBJS-$(CONFIG_MXC_UART) += serial_mxc.o -COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o -COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o -COBJS-$(CONFIG_PXA_SERIAL) += serial_pxa.o -COBJS-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o -COBJS-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o -COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o -COBJS-$(CONFIG_SANDBOX_SERIAL) += sandbox.o -COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o -COBJS-$(CONFIG_ZYNQ_SERIAL) += serial_zynq.o -COBJS-$(CONFIG_BFIN_SERIAL) += serial_bfin.o -COBJS-$(CONFIG_FSL_LPUART) += serial_lpuart.o -COBJS-$(CONFIG_MXS_AUART) += mxs_auart.o +obj-y += serial.o + +obj-$(CONFIG_ALTERA_UART) += altera_uart.o +obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o +obj-$(CONFIG_ARM_DCC) += arm_dcc.o +obj-$(CONFIG_ATMEL_USART) += atmel_usart.o +obj-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o +obj-$(CONFIG_MCFUART) += mcfuart.o +obj-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o +obj-$(CONFIG_SYS_NS16550) += ns16550.o +obj-$(CONFIG_S5P) += serial_s5p.o +obj-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o +obj-$(CONFIG_IMX_SERIAL) += serial_imx.o +obj-$(CONFIG_IXP_SERIAL) += serial_ixp.o +obj-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o +obj-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o +obj-$(CONFIG_MXC_UART) += serial_mxc.o +obj-$(CONFIG_PL010_SERIAL) += serial_pl01x.o +obj-$(CONFIG_PL011_SERIAL) += serial_pl01x.o +obj-$(CONFIG_PXA_SERIAL) += serial_pxa.o +obj-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o +obj-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o +obj-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o +obj-$(CONFIG_SANDBOX_SERIAL) += sandbox.o +obj-$(CONFIG_SCIF_CONSOLE) += serial_sh.o +obj-$(CONFIG_ZYNQ_SERIAL) += serial_zynq.o +obj-$(CONFIG_BFIN_SERIAL) += serial_bfin.o +obj-$(CONFIG_FSL_LPUART) += serial_lpuart.o +obj-$(CONFIG_MXS_AUART) += mxs_auart.o
ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_USB_TTY) += usbtty.o +obj-$(CONFIG_USB_TTY) += usbtty.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index c50dd15..6d25292 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libsound.o - -COBJS-$(CONFIG_SOUND) += sound.o -COBJS-$(CONFIG_I2S) += samsung-i2s.o -COBJS-$(CONFIG_SOUND_WM8994) += wm8994.o -COBJS-$(CONFIG_SOUND_MAX98095) += max98095.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -# +obj-$(CONFIG_SOUND) += sound.o +obj-$(CONFIG_I2S) += samsung-i2s.o +obj-$(CONFIG_SOUND_WM8994) += wm8994.o +obj-$(CONFIG_SOUND_MAX98095) += max98095.o diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 91d24ce..83a36bc 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -5,56 +5,34 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libspi.o - # There are many options which enable SPI, so make this library available -COBJS-y += spi.o - -COBJS-$(CONFIG_ALTERA_SPI) += altera_spi.o -COBJS-$(CONFIG_ANDES_SPI) += andes_spi.o -COBJS-$(CONFIG_ARMADA100_SPI) += armada100_spi.o -COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o -COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o -COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o -COBJS-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o -COBJS-$(CONFIG_CF_SPI) += cf_spi.o -COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o -COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o -COBJS-$(CONFIG_EXYNOS_SPI) += exynos_spi.o -COBJS-$(CONFIG_ICH_SPI) += ich.o -COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o -COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o -COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o -COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o -COBJS-$(CONFIG_MXS_SPI) += mxs_spi.o -COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o -COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o -COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o -COBJS-$(CONFIG_SH_SPI) += sh_spi.o -COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o -COBJS-$(CONFIG_FDT_SPI) += fdt_spi.o -COBJS-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o -COBJS-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o -COBJS-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o -COBJS-$(CONFIG_XILINX_SPI) += xilinx_spi.o -COBJS-$(CONFIG_ZYNQ_SPI) += zynq_spi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += spi.o + +obj-$(CONFIG_ALTERA_SPI) += altera_spi.o +obj-$(CONFIG_ANDES_SPI) += andes_spi.o +obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o +obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o +obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o +obj-$(CONFIG_BFIN_SPI) += bfin_spi.o +obj-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o +obj-$(CONFIG_CF_SPI) += cf_spi.o +obj-$(CONFIG_CF_QSPI) += cf_qspi.o +obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o +obj-$(CONFIG_ICH_SPI) += ich.o +obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o +obj-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o +obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o +obj-$(CONFIG_MXC_SPI) += mxc_spi.o +obj-$(CONFIG_MXS_SPI) += mxs_spi.o +obj-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o +obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o +obj-$(CONFIG_SOFT_SPI) += soft_spi.o +obj-$(CONFIG_SH_SPI) += sh_spi.o +obj-$(CONFIG_FSL_ESPI) += fsl_espi.o +obj-$(CONFIG_FDT_SPI) += fdt_spi.o +obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o +obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o +obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o +obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o +obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 4457a78..4b8cbec 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -3,31 +3,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libtpm.o - $(shell mkdir -p $(obj)slb9635_i2c)
# TODO: Merge tpm_tis_lpc.c with tpm.c -COBJS-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o -COBJS-$(CONFIG_TPM_TIS_I2C) += tpm.o -COBJS-$(CONFIG_TPM_TIS_I2C) += tpm_tis_i2c.o -COBJS-$(CONFIG_TPM_TIS_LPC) += tpm_tis_lpc.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o +obj-$(CONFIG_TPM_TIS_I2C) += tpm.o +obj-$(CONFIG_TPM_TIS_I2C) += tpm_tis_i2c.o +obj-$(CONFIG_TPM_TIS_LPC) += tpm_tis_lpc.o diff --git a/drivers/twserial/Makefile b/drivers/twserial/Makefile index ac22735..7cc7c4d 100644 --- a/drivers/twserial/Makefile +++ b/drivers/twserial/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libtws.o - -COBJS-$(CONFIG_SOFT_TWS) += soft_tws.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SOFT_TWS) += soft_tws.o diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 6c208c5..fed1c9c 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -5,58 +5,36 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libvideo.o - -COBJS-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o videomodes.o -COBJS-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o -COBJS-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o -COBJS-$(CONFIG_CFB_CONSOLE) += cfb_console.o -COBJS-$(CONFIG_EXYNOS_DP) += exynos_dp.o exynos_dp_lowlevel.o -COBJS-$(CONFIG_EXYNOS_FB) += exynos_fb.o exynos_fimd.o -COBJS-$(CONFIG_EXYNOS_MIPI_DSIM) += exynos_mipi_dsi.o exynos_mipi_dsi_common.o \ +obj-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o videomodes.o +obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o +obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o +obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o +obj-$(CONFIG_EXYNOS_DP) += exynos_dp.o exynos_dp_lowlevel.o +obj-$(CONFIG_EXYNOS_FB) += exynos_fb.o exynos_fimd.o +obj-$(CONFIG_EXYNOS_MIPI_DSIM) += exynos_mipi_dsi.o exynos_mipi_dsi_common.o \ exynos_mipi_dsi_lowlevel.o -COBJS-$(CONFIG_EXYNOS_PWM_BL) += exynos_pwm_bl.o -COBJS-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o -COBJS-$(CONFIG_L5F31188) += l5f31188.o -COBJS-$(CONFIG_MPC8XX_LCD) += mpc8xx_lcd.o -COBJS-$(CONFIG_PXA_LCD) += pxa_lcd.o -COBJS-$(CONFIG_S6E8AX0) += s6e8ax0.o -COBJS-$(CONFIG_S6E63D6) += s6e63d6.o -COBJS-$(CONFIG_LD9040) += ld9040.o -COBJS-$(CONFIG_SED156X) += sed156x.o -COBJS-$(CONFIG_VIDEO_BCM2835) += bcm2835.o -COBJS-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o -COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o -COBJS-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o -COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o -COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o -COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o -COBJS-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o -COBJS-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o -COBJS-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o -COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o -COBJS-$(CONFIG_VIDEO_SM501) += sm501.o -COBJS-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o -COBJS-$(CONFIG_VIDEO_TEGRA) += tegra.o -COBJS-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o -COBJS-$(CONFIG_FORMIKE) += formike.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_EXYNOS_PWM_BL) += exynos_pwm_bl.o +obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o +obj-$(CONFIG_L5F31188) += l5f31188.o +obj-$(CONFIG_MPC8XX_LCD) += mpc8xx_lcd.o +obj-$(CONFIG_PXA_LCD) += pxa_lcd.o +obj-$(CONFIG_S6E8AX0) += s6e8ax0.o +obj-$(CONFIG_S6E63D6) += s6e63d6.o +obj-$(CONFIG_LD9040) += ld9040.o +obj-$(CONFIG_SED156X) += sed156x.o +obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o +obj-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o +obj-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o +obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o +obj-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o +obj-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o +obj-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o +obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o +obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o +obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o +obj-$(CONFIG_VIDEO_SED13806) += sed13806.o +obj-$(CONFIG_VIDEO_SM501) += sm501.o +obj-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o +obj-$(CONFIG_VIDEO_TEGRA) += tegra.o +obj-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o +obj-$(CONFIG_FORMIKE) += formike.o diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 3ade624..06ced10 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -5,35 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libwatchdog.o - -COBJS-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o -COBJS-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o +obj-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o +obj-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 vf610)) -COBJS-y += imx_watchdog.o +obj-y += imx_watchdog.o endif -COBJS-$(CONFIG_TNETV107X_WATCHDOG) += tnetv107x_wdt.o -COBJS-$(CONFIG_S5P) += s5p_wdt.o -COBJS-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o -COBJS-$(CONFIG_BFIN_WATCHDOG) += bfin_wdt.o -COBJS-$(CONFIG_OMAP_WATCHDOG) += omap_wdt.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TNETV107X_WATCHDOG) += tnetv107x_wdt.o +obj-$(CONFIG_S5P) += s5p_wdt.o +obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o +obj-$(CONFIG_BFIN_WATCHDOG) += bfin_wdt.o +obj-$(CONFIG_OMAP_WATCHDOG) += omap_wdt.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes for v2 - No change
fs/Makefile | 24 +----------------------- fs/cbfs/Makefile | 24 +----------------------- fs/cramfs/Makefile | 29 ++--------------------------- fs/ext4/Makefile | 27 ++------------------------- fs/fat/Makefile | 31 +++---------------------------- fs/fdos/Makefile | 27 +-------------------------- fs/jffs2/Makefile | 38 ++++++-------------------------------- fs/reiserfs/Makefile | 26 +------------------------- fs/sandbox/Makefile | 23 +---------------------- fs/ubifs/Makefile | 29 ++++------------------------- fs/yaffs2/Makefile | 33 +-------------------------------- fs/zfs/Makefile | 25 +------------------------ 12 files changed, 24 insertions(+), 312 deletions(-)
diff --git a/fs/Makefile b/fs/Makefile index 7e753e9..ea2eb09 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -6,26 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfs.o - -COBJS-y += fs.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += fs.o diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile index 190fd8e..6f33d28 100644 --- a/fs/cbfs/Makefile +++ b/fs/cbfs/Makefile @@ -3,26 +3,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcbfs.o - -COBJS-$(CONFIG_CMD_CBFS) := cbfs.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_CBFS) := cbfs.o diff --git a/fs/cramfs/Makefile b/fs/cramfs/Makefile index 9b1a3d7..e2b2c73 100644 --- a/fs/cramfs/Makefile +++ b/fs/cramfs/Makefile @@ -5,30 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcramfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_CRAMFS) := cramfs.o -COBJS-$(CONFIG_CMD_CRAMFS) += uncompress.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_CRAMFS) := cramfs.o +obj-$(CONFIG_CMD_CRAMFS) += uncompress.o diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile index f45bb32..0f5d399 100644 --- a/fs/ext4/Makefile +++ b/fs/ext4/Makefile @@ -9,28 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libext4fs.o - -AOBJS = -COBJS-$(CONFIG_FS_EXT4) := ext4fs.o ext4_common.o dev.o -COBJS-$(CONFIG_EXT4_WRITE) += ext4_write.o ext4_journal.o crc16.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FS_EXT4) := ext4fs.o ext4_common.o dev.o +obj-$(CONFIG_EXT4_WRITE) += ext4_write.o ext4_journal.o crc16.o diff --git a/fs/fat/Makefile b/fs/fat/Makefile index c00681f..b60e848 100644 --- a/fs/fat/Makefile +++ b/fs/fat/Makefile @@ -3,34 +3,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfat.o - -AOBJS = -COBJS-$(CONFIG_FS_FAT) := fat.o -COBJS-$(CONFIG_FAT_WRITE):= fat_write.o +obj-$(CONFIG_FS_FAT) := fat.o +obj-$(CONFIG_FAT_WRITE):= fat_write.o
ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_FS_FAT) += file.o +obj-$(CONFIG_FS_FAT) += file.o endif - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -# SEE README.arm-unaligned-accesses -$(obj)file.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/fdos/Makefile b/fs/fdos/Makefile index 867c5ca..95480af 100644 --- a/fs/fdos/Makefile +++ b/fs/fdos/Makefile @@ -10,29 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfdos.o - -AOBJS = -COBJS-$(CONFIG_CMD_FDOS) := fat.o vfat.o dev.o fdos.o fs.o subdir.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_FDOS) := fat.o vfat.o dev.o fdos.o fs.o subdir.o diff --git a/fs/jffs2/Makefile b/fs/jffs2/Makefile index a11ca32..02e481f 100644 --- a/fs/jffs2/Makefile +++ b/fs/jffs2/Makefile @@ -5,37 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libjffs2.o - -AOBJS = ifdef CONFIG_CMD_JFFS2 -COBJS-$(CONFIG_JFFS2_LZO) += compr_lzo.o -COBJS-y += compr_rtime.o -COBJS-y += compr_rubin.o -COBJS-y += compr_zlib.o -COBJS-y += jffs2_1pass.o -COBJS-y += mini_inflate.o +obj-$(CONFIG_JFFS2_LZO) += compr_lzo.o +obj-y += compr_rtime.o +obj-y += compr_rubin.o +obj-y += compr_zlib.o +obj-y += jffs2_1pass.o +obj-y += mini_inflate.o endif - -COBJS := $(COBJS-y) -SRCS := $(AOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/reiserfs/Makefile b/fs/reiserfs/Makefile index d81d71d..55f70b1 100644 --- a/fs/reiserfs/Makefile +++ b/fs/reiserfs/Makefile @@ -9,28 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libreiserfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_REISER) := reiserfs.o dev.o mode_string.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_REISER) := reiserfs.o dev.o mode_string.o diff --git a/fs/sandbox/Makefile b/fs/sandbox/Makefile index df2fc32..faa7c16 100644 --- a/fs/sandbox/Makefile +++ b/fs/sandbox/Makefile @@ -10,25 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libsandboxfs.o - -COBJS-$(CONFIG_SANDBOX) := sandboxfs.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SANDBOX) := sandboxfs.o diff --git a/fs/ubifs/Makefile b/fs/ubifs/Makefile index 47949c1..47d5a8f 100644 --- a/fs/ubifs/Makefile +++ b/fs/ubifs/Makefile @@ -9,31 +9,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libubifs.o - -COBJS-$(CONFIG_CMD_UBIFS) := ubifs.o io.o super.o sb.o master.o lpt.o -COBJS-$(CONFIG_CMD_UBIFS) += lpt_commit.o scan.o lprops.o -COBJS-$(CONFIG_CMD_UBIFS) += tnc.o tnc_misc.o debug.o crc16.o budget.o -COBJS-$(CONFIG_CMD_UBIFS) += log.o orphan.o recovery.o replay.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_CMD_UBIFS) := ubifs.o io.o super.o sb.o master.o lpt.o +obj-$(CONFIG_CMD_UBIFS) += lpt_commit.o scan.o lprops.o +obj-$(CONFIG_CMD_UBIFS) += tnc.o tnc_misc.o debug.o crc16.o budget.o +obj-$(CONFIG_CMD_UBIFS) += log.o orphan.o recovery.o replay.o
# SEE README.arm-unaligned-accesses $(obj)super.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/yaffs2/Makefile b/fs/yaffs2/Makefile index 9b29d22..077af78 100644 --- a/fs/yaffs2/Makefile +++ b/fs/yaffs2/Makefile @@ -16,11 +16,7 @@ # # $Id: Makefile,v 1.15 2007/07/18 19:40:38 charles Exp $
-include $(TOPDIR)/config.mk - -LIB = $(obj)libyaffs2.o - -COBJS-$(CONFIG_YAFFS2) := \ +obj-$(CONFIG_YAFFS2) := \ yaffs_allocator.o yaffs_attribs.o yaffs_bitmap.o yaffs_uboot_glue.o\ yaffs_checkptrw.o yaffs_ecc.o yaffs_error.o \ yaffsfs.o yaffs_guts.o yaffs_nameval.o yaffs_nand.o\ @@ -28,36 +24,9 @@ COBJS-$(CONFIG_YAFFS2) := \ yaffs_summary.o yaffs_tagscompat.o yaffs_verify.o yaffs_yaffs1.o \ yaffs_yaffs2.o yaffs_mtdif.o yaffs_mtdif2.o
-SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - YCFLAGS = -DCONFIG_YAFFS_DIRECT -DCONFIG_YAFFS_SHORT_NAMES_IN_RAM YCFLAGS += -DCONFIG_YAFFS_YAFFS2 -DNO_Y_INLINE YCFLAGS += -DCONFIG_YAFFS_PROVIDE_DEFS -DCONFIG_YAFFSFS_PROVIDE_VALUES
CFLAGS += $(YCFLAGS) CPPFLAGS += $(YCFLAGS) - -all: $(LIB) - -$(obj)libyaffs2.a: $(obj).depend $(OBJS) - $(AR) $(ARFLAGS) $@ $(OBJS) - -$(obj)libyaffs2.o: $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -.PHONY: clean distclean -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/zfs/Makefile b/fs/zfs/Makefile index 32070de..7090416 100644 --- a/fs/zfs/Makefile +++ b/fs/zfs/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libzfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_ZFS) := dev.o zfs.o zfs_fletcher.o zfs_sha256.o zfs_lzjb.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_ZFS) := dev.o zfs.o zfs_fletcher.o zfs_sha256.o zfs_lzjb.o
common/Makefile | 389 ++++++++++++++++++++++++---------------------------- common/spl/Makefile | 36 +---- 2 files changed, 189 insertions(+), 236 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 288690b..745d447 100644 --- a/common/Makefile +++ b/common/Makefile @@ -5,215 +5,211 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcommon.o - # core ifndef CONFIG_SPL_BUILD -COBJS-y += main.o -COBJS-y += command.o -COBJS-y += exports.o -COBJS-y += hash.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += hush.o -COBJS-y += s_record.o -COBJS-y += xyzModem.o -COBJS-y += cmd_disk.o +obj-y += main.o +obj-y += command.o +obj-y += exports.o +obj-y += hash.o +obj-$(CONFIG_SYS_HUSH_PARSER) += hush.o +obj-y += s_record.o +obj-y += xyzModem.o +obj-y += cmd_disk.o
# boards -COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_f.o -COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o +obj-$(CONFIG_SYS_GENERIC_BOARD) += board_f.o +obj-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o
# core command -COBJS-y += cmd_boot.o -COBJS-$(CONFIG_CMD_BOOTM) += cmd_bootm.o -COBJS-y += cmd_help.o -COBJS-y += cmd_version.o +obj-y += cmd_boot.o +obj-$(CONFIG_CMD_BOOTM) += cmd_bootm.o +obj-y += cmd_help.o +obj-y += cmd_version.o
# environment -COBJS-y += env_attr.o -COBJS-y += env_callback.o -COBJS-y += env_flags.o -COBJS-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o -XCOBJS-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o -XCOBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -COBJS-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o -COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o -COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o -COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -COBJS-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o -COBJS-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o -COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o +obj-y += env_attr.o +obj-y += env_callback.o +obj-y += env_flags.o +obj-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o +extra-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o +extra-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o +obj-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o +obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o +obj-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o +obj-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o +obj-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o +obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command -COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o -COBJS-$(CONFIG_SOURCE) += cmd_source.o -COBJS-$(CONFIG_CMD_SOURCE) += cmd_source.o -COBJS-$(CONFIG_CMD_BDI) += cmd_bdinfo.o -COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o -COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o -COBJS-$(CONFIG_CMD_BOOTMENU) += cmd_bootmenu.o -COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o -COBJS-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o -COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o -COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o -COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o -COBJS-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o -COBJS-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o -COBJS-$(CONFIG_CMD_DATE) += cmd_date.o -COBJS-$(CONFIG_CMD_SOUND) += cmd_sound.o +obj-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o +obj-$(CONFIG_SOURCE) += cmd_source.o +obj-$(CONFIG_CMD_SOURCE) += cmd_source.o +obj-$(CONFIG_CMD_BDI) += cmd_bdinfo.o +obj-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o +obj-$(CONFIG_CMD_BMP) += cmd_bmp.o +obj-$(CONFIG_CMD_BOOTMENU) += cmd_bootmenu.o +obj-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o +obj-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o +obj-$(CONFIG_CMD_CACHE) += cmd_cache.o +obj-$(CONFIG_CMD_CBFS) += cmd_cbfs.o +obj-$(CONFIG_CMD_CONSOLE) += cmd_console.o +obj-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o +obj-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o +obj-$(CONFIG_CMD_DATE) += cmd_date.o +obj-$(CONFIG_CMD_SOUND) += cmd_sound.o ifdef CONFIG_4xx -COBJS-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o +obj-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o endif ifdef CONFIG_POST -COBJS-$(CONFIG_CMD_DIAG) += cmd_diag.o +obj-$(CONFIG_CMD_DIAG) += cmd_diag.o endif -COBJS-$(CONFIG_CMD_DISPLAY) += cmd_display.o -COBJS-$(CONFIG_CMD_DTT) += cmd_dtt.o -COBJS-$(CONFIG_CMD_ECHO) += cmd_echo.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o -COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o -COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o -COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o -COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o -COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o -COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o -COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o -COBJS-$(CONFIG_CMD_FDOS) += cmd_fdos.o -COBJS-$(CONFIG_CMD_FITUPD) += cmd_fitupd.o -COBJS-$(CONFIG_CMD_FLASH) += cmd_flash.o +obj-$(CONFIG_CMD_DISPLAY) += cmd_display.o +obj-$(CONFIG_CMD_DTT) += cmd_dtt.o +obj-$(CONFIG_CMD_ECHO) += cmd_echo.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o +obj-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o +obj-$(CONFIG_CMD_ELF) += cmd_elf.o +obj-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +obj-$(CONFIG_CMD_EXT4) += cmd_ext4.o +obj-$(CONFIG_CMD_EXT2) += cmd_ext2.o +obj-$(CONFIG_CMD_FAT) += cmd_fat.o +obj-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o +obj-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o +obj-$(CONFIG_CMD_FDOS) += cmd_fdos.o +obj-$(CONFIG_CMD_FITUPD) += cmd_fitupd.o +obj-$(CONFIG_CMD_FLASH) += cmd_flash.o ifdef CONFIG_FPGA -COBJS-$(CONFIG_CMD_FPGA) += cmd_fpga.o +obj-$(CONFIG_CMD_FPGA) += cmd_fpga.o endif -COBJS-$(CONFIG_CMD_FPGAD) += cmd_fpgad.o -COBJS-$(CONFIG_CMD_FS_GENERIC) += cmd_fs.o -COBJS-$(CONFIG_CMD_FUSE) += cmd_fuse.o -COBJS-$(CONFIG_CMD_GETTIME) += cmd_gettime.o -COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o -COBJS-$(CONFIG_CMD_I2C) += cmd_i2c.o -COBJS-$(CONFIG_CMD_HASH) += cmd_hash.o -COBJS-$(CONFIG_CMD_IDE) += cmd_ide.o -COBJS-$(CONFIG_CMD_IMMAP) += cmd_immap.o -COBJS-$(CONFIG_CMD_INI) += cmd_ini.o -COBJS-$(CONFIG_CMD_IRQ) += cmd_irq.o -COBJS-$(CONFIG_CMD_ITEST) += cmd_itest.o -COBJS-$(CONFIG_CMD_JFFS2) += cmd_jffs2.o -COBJS-$(CONFIG_CMD_CRAMFS) += cmd_cramfs.o -COBJS-$(CONFIG_CMD_LDRINFO) += cmd_ldrinfo.o -COBJS-$(CONFIG_CMD_LED) += cmd_led.o -COBJS-$(CONFIG_CMD_LICENSE) += cmd_license.o -COBJS-y += cmd_load.o -COBJS-$(CONFIG_LOGBUFFER) += cmd_log.o -COBJS-$(CONFIG_ID_EEPROM) += cmd_mac.o -COBJS-$(CONFIG_CMD_MD5SUM) += cmd_md5sum.o -COBJS-$(CONFIG_CMD_MEMORY) += cmd_mem.o -COBJS-$(CONFIG_CMD_IO) += cmd_io.o -COBJS-$(CONFIG_CMD_MFSL) += cmd_mfsl.o -COBJS-$(CONFIG_MII) += miiphyutil.o -COBJS-$(CONFIG_CMD_MII) += miiphyutil.o -COBJS-$(CONFIG_PHYLIB) += miiphyutil.o -COBJS-$(CONFIG_CMD_MII) += cmd_mii.o +obj-$(CONFIG_CMD_FPGAD) += cmd_fpgad.o +obj-$(CONFIG_CMD_FS_GENERIC) += cmd_fs.o +obj-$(CONFIG_CMD_FUSE) += cmd_fuse.o +obj-$(CONFIG_CMD_GETTIME) += cmd_gettime.o +obj-$(CONFIG_CMD_GPIO) += cmd_gpio.o +obj-$(CONFIG_CMD_I2C) += cmd_i2c.o +obj-$(CONFIG_CMD_HASH) += cmd_hash.o +obj-$(CONFIG_CMD_IDE) += cmd_ide.o +obj-$(CONFIG_CMD_IMMAP) += cmd_immap.o +obj-$(CONFIG_CMD_INI) += cmd_ini.o +obj-$(CONFIG_CMD_IRQ) += cmd_irq.o +obj-$(CONFIG_CMD_ITEST) += cmd_itest.o +obj-$(CONFIG_CMD_JFFS2) += cmd_jffs2.o +obj-$(CONFIG_CMD_CRAMFS) += cmd_cramfs.o +obj-$(CONFIG_CMD_LDRINFO) += cmd_ldrinfo.o +obj-$(CONFIG_CMD_LED) += cmd_led.o +obj-$(CONFIG_CMD_LICENSE) += cmd_license.o +obj-y += cmd_load.o +obj-$(CONFIG_LOGBUFFER) += cmd_log.o +obj-$(CONFIG_ID_EEPROM) += cmd_mac.o +obj-$(CONFIG_CMD_MD5SUM) += cmd_md5sum.o +obj-$(CONFIG_CMD_MEMORY) += cmd_mem.o +obj-$(CONFIG_CMD_IO) += cmd_io.o +obj-$(CONFIG_CMD_MFSL) += cmd_mfsl.o +obj-$(CONFIG_MII) += miiphyutil.o +obj-$(CONFIG_CMD_MII) += miiphyutil.o +obj-$(CONFIG_PHYLIB) += miiphyutil.o +obj-$(CONFIG_CMD_MII) += cmd_mii.o ifdef CONFIG_PHYLIB -COBJS-$(CONFIG_CMD_MII) += cmd_mdio.o +obj-$(CONFIG_CMD_MII) += cmd_mdio.o endif -COBJS-$(CONFIG_CMD_MISC) += cmd_misc.o -COBJS-$(CONFIG_CMD_MMC) += cmd_mmc.o -COBJS-$(CONFIG_CMD_MMC_SPI) += cmd_mmc_spi.o -COBJS-$(CONFIG_MP) += cmd_mp.o -COBJS-$(CONFIG_CMD_MTDPARTS) += cmd_mtdparts.o -COBJS-$(CONFIG_CMD_NAND) += cmd_nand.o -COBJS-$(CONFIG_CMD_NET) += cmd_net.o -COBJS-$(CONFIG_CMD_ONENAND) += cmd_onenand.o -COBJS-$(CONFIG_CMD_OTP) += cmd_otp.o -COBJS-$(CONFIG_CMD_PART) += cmd_part.o +obj-$(CONFIG_CMD_MISC) += cmd_misc.o +obj-$(CONFIG_CMD_MMC) += cmd_mmc.o +obj-$(CONFIG_CMD_MMC_SPI) += cmd_mmc_spi.o +obj-$(CONFIG_MP) += cmd_mp.o +obj-$(CONFIG_CMD_MTDPARTS) += cmd_mtdparts.o +obj-$(CONFIG_CMD_NAND) += cmd_nand.o +obj-$(CONFIG_CMD_NET) += cmd_net.o +obj-$(CONFIG_CMD_ONENAND) += cmd_onenand.o +obj-$(CONFIG_CMD_OTP) += cmd_otp.o +obj-$(CONFIG_CMD_PART) += cmd_part.o ifdef CONFIG_PCI -COBJS-$(CONFIG_CMD_PCI) += cmd_pci.o +obj-$(CONFIG_CMD_PCI) += cmd_pci.o endif -COBJS-y += cmd_pcmcia.o -COBJS-$(CONFIG_CMD_PORTIO) += cmd_portio.o -COBJS-$(CONFIG_CMD_PXE) += cmd_pxe.o -COBJS-$(CONFIG_CMD_READ) += cmd_read.o -COBJS-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o -COBJS-$(CONFIG_CMD_REISER) += cmd_reiser.o -COBJS-$(CONFIG_SANDBOX) += cmd_sandbox.o -COBJS-$(CONFIG_CMD_SATA) += cmd_sata.o -COBJS-$(CONFIG_CMD_SF) += cmd_sf.o -COBJS-$(CONFIG_CMD_SCSI) += cmd_scsi.o -COBJS-$(CONFIG_CMD_SHA1SUM) += cmd_sha1sum.o -COBJS-$(CONFIG_CMD_SETEXPR) += cmd_setexpr.o -COBJS-$(CONFIG_CMD_SOFTSWITCH) += cmd_softswitch.o -COBJS-$(CONFIG_CMD_SPI) += cmd_spi.o -COBJS-$(CONFIG_CMD_SPIBOOTLDR) += cmd_spibootldr.o -COBJS-$(CONFIG_CMD_STRINGS) += cmd_strings.o -COBJS-$(CONFIG_CMD_TERMINAL) += cmd_terminal.o -COBJS-$(CONFIG_CMD_TIME) += cmd_time.o -COBJS-$(CONFIG_CMD_TRACE) += cmd_trace.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_test.o -COBJS-$(CONFIG_CMD_TPM) += cmd_tpm.o -COBJS-$(CONFIG_CMD_TSI148) += cmd_tsi148.o -COBJS-$(CONFIG_CMD_UBI) += cmd_ubi.o -COBJS-$(CONFIG_CMD_UBIFS) += cmd_ubifs.o -COBJS-$(CONFIG_CMD_UNIVERSE) += cmd_universe.o -COBJS-$(CONFIG_CMD_UNZIP) += cmd_unzip.o +obj-y += cmd_pcmcia.o +obj-$(CONFIG_CMD_PORTIO) += cmd_portio.o +obj-$(CONFIG_CMD_PXE) += cmd_pxe.o +obj-$(CONFIG_CMD_READ) += cmd_read.o +obj-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o +obj-$(CONFIG_CMD_REISER) += cmd_reiser.o +obj-$(CONFIG_SANDBOX) += cmd_sandbox.o +obj-$(CONFIG_CMD_SATA) += cmd_sata.o +obj-$(CONFIG_CMD_SF) += cmd_sf.o +obj-$(CONFIG_CMD_SCSI) += cmd_scsi.o +obj-$(CONFIG_CMD_SHA1SUM) += cmd_sha1sum.o +obj-$(CONFIG_CMD_SETEXPR) += cmd_setexpr.o +obj-$(CONFIG_CMD_SOFTSWITCH) += cmd_softswitch.o +obj-$(CONFIG_CMD_SPI) += cmd_spi.o +obj-$(CONFIG_CMD_SPIBOOTLDR) += cmd_spibootldr.o +obj-$(CONFIG_CMD_STRINGS) += cmd_strings.o +obj-$(CONFIG_CMD_TERMINAL) += cmd_terminal.o +obj-$(CONFIG_CMD_TIME) += cmd_time.o +obj-$(CONFIG_CMD_TRACE) += cmd_trace.o +obj-$(CONFIG_SYS_HUSH_PARSER) += cmd_test.o +obj-$(CONFIG_CMD_TPM) += cmd_tpm.o +obj-$(CONFIG_CMD_TSI148) += cmd_tsi148.o +obj-$(CONFIG_CMD_UBI) += cmd_ubi.o +obj-$(CONFIG_CMD_UBIFS) += cmd_ubifs.o +obj-$(CONFIG_CMD_UNIVERSE) += cmd_universe.o +obj-$(CONFIG_CMD_UNZIP) += cmd_unzip.o ifdef CONFIG_CMD_USB -COBJS-y += cmd_usb.o -COBJS-y += usb.o usb_hub.o -COBJS-$(CONFIG_USB_STORAGE) += usb_storage.o +obj-y += cmd_usb.o +obj-y += usb.o usb_hub.o +obj-$(CONFIG_USB_STORAGE) += usb_storage.o endif -COBJS-$(CONFIG_CMD_USB_MASS_STORAGE) += cmd_usb_mass_storage.o -COBJS-$(CONFIG_CMD_XIMG) += cmd_ximg.o -COBJS-$(CONFIG_YAFFS2) += cmd_yaffs2.o -COBJS-$(CONFIG_CMD_SPL) += cmd_spl.o -COBJS-$(CONFIG_CMD_ZIP) += cmd_zip.o -COBJS-$(CONFIG_CMD_ZFS) += cmd_zfs.o +obj-$(CONFIG_CMD_USB_MASS_STORAGE) += cmd_usb_mass_storage.o +obj-$(CONFIG_CMD_XIMG) += cmd_ximg.o +obj-$(CONFIG_YAFFS2) += cmd_yaffs2.o +obj-$(CONFIG_CMD_SPL) += cmd_spl.o +obj-$(CONFIG_CMD_ZIP) += cmd_zip.o +obj-$(CONFIG_CMD_ZFS) += cmd_zfs.o
# others -COBJS-$(CONFIG_BOOTSTAGE) += bootstage.o -COBJS-$(CONFIG_CONSOLE_MUX) += iomux.o -COBJS-y += flash.o -COBJS-$(CONFIG_CMD_KGDB) += kgdb.o kgdb_stubs.o -COBJS-$(CONFIG_I2C_EDID) += edid.o -COBJS-$(CONFIG_KALLSYMS) += kallsyms.o -COBJS-y += splash.o -COBJS-$(CONFIG_LCD) += lcd.o -COBJS-$(CONFIG_LYNXKDI) += lynxkdi.o -COBJS-$(CONFIG_MENU) += menu.o -COBJS-$(CONFIG_MODEM_SUPPORT) += modem.o -COBJS-$(CONFIG_UPDATE_TFTP) += update.o -COBJS-$(CONFIG_USB_KEYBOARD) += usb_kbd.o -COBJS-$(CONFIG_CMD_DFU) += cmd_dfu.o -COBJS-$(CONFIG_CMD_GPT) += cmd_gpt.o +obj-$(CONFIG_BOOTSTAGE) += bootstage.o +obj-$(CONFIG_CONSOLE_MUX) += iomux.o +obj-y += flash.o +obj-$(CONFIG_CMD_KGDB) += kgdb.o kgdb_stubs.o +obj-$(CONFIG_I2C_EDID) += edid.o +obj-$(CONFIG_KALLSYMS) += kallsyms.o +obj-y += splash.o +obj-$(CONFIG_LCD) += lcd.o +obj-$(CONFIG_LYNXKDI) += lynxkdi.o +obj-$(CONFIG_MENU) += menu.o +obj-$(CONFIG_MODEM_SUPPORT) += modem.o +obj-$(CONFIG_UPDATE_TFTP) += update.o +obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o +obj-$(CONFIG_CMD_DFU) += cmd_dfu.o +obj-$(CONFIG_CMD_GPT) += cmd_gpt.o endif
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o +obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o # environment -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o ifneq ($(CONFIG_SPL_NET_SUPPORT),y) -COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o -COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o +obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o +obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o else -COBJS-y += env_nowhere.o +obj-y += env_nowhere.o endif endif # core command -COBJS-y += cmd_nvedit.o +obj-y += cmd_nvedit.o #environment -COBJS-y += env_common.o +obj-y += env_common.o #others ifdef CONFIG_DDR_SPD SPD := y @@ -221,32 +217,20 @@ endif ifdef CONFIG_SPD_EEPROM SPD := y endif -COBJS-$(SPD) += ddr_spd.o -COBJS-$(CONFIG_HWCONFIG) += hwconfig.o -COBJS-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o -COBJS-y += console.o -COBJS-y += dlmalloc.o -COBJS-y += image.o -COBJS-$(CONFIG_OF_LIBFDT) += image-fdt.o -COBJS-$(CONFIG_FIT) += image-fit.o -COBJS-$(CONFIG_FIT_SIGNATURE) += image-sig.o -COBJS-y += memsize.o -COBJS-y += stdio.o - - -COBJS := $(sort $(COBJS-y)) -XCOBJS := $(sort $(XCOBJS-y)) -SRCS := $(COBJS:.o=.c) $(XCOBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -XOBJS := $(addprefix $(obj),$(XCOBJS)) +obj-$(SPD) += ddr_spd.o +obj-$(CONFIG_HWCONFIG) += hwconfig.o +obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o +obj-y += console.o +obj-y += dlmalloc.o +obj-y += image.o +obj-$(CONFIG_OF_LIBFDT) += image-fdt.o +obj-$(CONFIG_FIT) += image-fit.o +obj-$(CONFIG_FIT_SIGNATURE) += image-sig.o +obj-y += memsize.o +obj-y += stdio.o
CPPFLAGS += -I..
-all: $(LIB) $(XOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - $(obj)env_embedded.o: $(src)env_embedded.c $(obj)../tools/envcrc $(CC) $(AFLAGS) -Wa,--no-warn \ -DENV_CRC=$(shell $(obj)../tools/envcrc) \ @@ -258,12 +242,3 @@ $(obj)../tools/envcrc: # SEE README.arm-unaligned-accesses $(obj)hush.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) $(obj)fdt_support.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/common/spl/Makefile b/common/spl/Makefile index e8144f7..5c0637b 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -8,34 +8,12 @@ # Based on common/Makefile. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libspl.o - ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o -COBJS-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o -COBJS-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o -COBJS-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o -COBJS-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o +obj-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o +obj-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o +obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o +obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
net/Makefile | 46 ++++++++++++---------------------------------- 1 file changed, 12 insertions(+), 34 deletions(-)
diff --git a/net/Makefile b/net/Makefile index 4c9a97f..31aadc2 100644 --- a/net/Makefile +++ b/net/Makefile @@ -5,39 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # CFLAGS += -DDEBUG
-LIB = $(obj)libnet.o - -COBJS-$(CONFIG_CMD_NET) += arp.o -COBJS-$(CONFIG_CMD_NET) += bootp.o -COBJS-$(CONFIG_CMD_CDP) += cdp.o -COBJS-$(CONFIG_CMD_DNS) += dns.o -COBJS-$(CONFIG_CMD_NET) += eth.o -COBJS-$(CONFIG_CMD_LINK_LOCAL) += link_local.o -COBJS-$(CONFIG_CMD_NET) += net.o -COBJS-$(CONFIG_CMD_NFS) += nfs.o -COBJS-$(CONFIG_CMD_PING) += ping.o -COBJS-$(CONFIG_CMD_RARP) += rarp.o -COBJS-$(CONFIG_CMD_SNTP) += sntp.o -COBJS-$(CONFIG_CMD_NET) += tftp.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_NET) += arp.o +obj-$(CONFIG_CMD_NET) += bootp.o +obj-$(CONFIG_CMD_CDP) += cdp.o +obj-$(CONFIG_CMD_DNS) += dns.o +obj-$(CONFIG_CMD_NET) += eth.o +obj-$(CONFIG_CMD_LINK_LOCAL) += link_local.o +obj-$(CONFIG_CMD_NET) += net.o +obj-$(CONFIG_CMD_NFS) += nfs.o +obj-$(CONFIG_CMD_PING) += ping.o +obj-$(CONFIG_CMD_RARP) += rarp.o +obj-$(CONFIG_CMD_SNTP) += sntp.o +obj-$(CONFIG_CMD_NET) += tftp.o
lib/Makefile | 114 ++++++++++++++++++++++------------------------------ lib/libfdt/Makefile | 27 +------------ lib/lzma/Makefile | 24 +---------- lib/lzo/Makefile | 24 +---------- lib/rsa/Makefile | 22 +--------- lib/tizen/Makefile | 24 +---------- lib/zlib/Makefile | 22 +--------- 7 files changed, 54 insertions(+), 203 deletions(-)
diff --git a/lib/Makefile b/lib/Makefile index df0cdd4..4e3b500 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -5,78 +5,58 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libgeneric.o - ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_AES) += aes.o -COBJS-$(CONFIG_BZIP2) += bzlib.o -COBJS-$(CONFIG_BZIP2) += bzlib_crctable.o -COBJS-$(CONFIG_BZIP2) += bzlib_decompress.o -COBJS-$(CONFIG_BZIP2) += bzlib_randtable.o -COBJS-$(CONFIG_BZIP2) += bzlib_huffman.o -COBJS-$(CONFIG_USB_TTY) += circbuf.o -COBJS-y += crc7.o -COBJS-y += crc16.o -COBJS-$(CONFIG_OF_CONTROL) += fdtdec.o -COBJS-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o -COBJS-$(CONFIG_GZIP) += gunzip.o -COBJS-$(CONFIG_GZIP_COMPRESSED) += gzip.o -COBJS-y += initcall.o -COBJS-$(CONFIG_LMB) += lmb.o -COBJS-y += ldiv.o -COBJS-$(CONFIG_MD5) += md5.o -COBJS-y += net_utils.o -COBJS-$(CONFIG_PHYSMEM) += physmem.o -COBJS-y += qsort.o -COBJS-$(CONFIG_SHA1) += sha1.o -COBJS-$(CONFIG_SHA256) += sha256.o -COBJS-y += strmhz.o -COBJS-$(CONFIG_TPM) += tpm.o -COBJS-$(CONFIG_RBTREE) += rbtree.o -COBJS-$(CONFIG_BITREVERSE) += bitrev.o +obj-$(CONFIG_AES) += aes.o +obj-$(CONFIG_BZIP2) += bzlib.o +obj-$(CONFIG_BZIP2) += bzlib_crctable.o +obj-$(CONFIG_BZIP2) += bzlib_decompress.o +obj-$(CONFIG_BZIP2) += bzlib_randtable.o +obj-$(CONFIG_BZIP2) += bzlib_huffman.o +obj-$(CONFIG_USB_TTY) += circbuf.o +obj-y += crc7.o +obj-y += crc16.o +obj-$(CONFIG_OF_CONTROL) += fdtdec.o +obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o +obj-$(CONFIG_GZIP) += gunzip.o +obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o +obj-y += initcall.o +obj-$(CONFIG_LMB) += lmb.o +obj-y += ldiv.o +obj-$(CONFIG_MD5) += md5.o +obj-y += net_utils.o +obj-$(CONFIG_PHYSMEM) += physmem.o +obj-y += qsort.o +obj-$(CONFIG_SHA1) += sha1.o +obj-$(CONFIG_SHA256) += sha256.o +obj-y += strmhz.o +obj-$(CONFIG_TPM) += tpm.o +obj-$(CONFIG_RBTREE) += rbtree.o +obj-$(CONFIG_BITREVERSE) += bitrev.o endif
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o +obj-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o endif -COBJS-$(CONFIG_ADDR_MAP) += addr_map.o -COBJS-y += hashtable.o -COBJS-y += errno.o -COBJS-y += display_options.o -COBJS-$(CONFIG_BCH) += bch.o -COBJS-y += crc32.o -COBJS-y += ctype.o -COBJS-y += div64.o -COBJS-y += hang.o -COBJS-y += linux_string.o -COBJS-$(CONFIG_REGEX) += slre.o -COBJS-y += string.o -COBJS-y += time.o -COBJS-$(CONFIG_TRACE) += trace.o -COBJS-$(CONFIG_BOOTP_PXE) += uuid.o -COBJS-y += vsprintf.o -COBJS-$(CONFIG_RANDOM_MACADDR) += rand.o -COBJS-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o -COBJS-$(CONFIG_CMD_LINK_LOCAL) += rand.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_ADDR_MAP) += addr_map.o +obj-y += hashtable.o +obj-y += errno.o +obj-y += display_options.o +obj-$(CONFIG_BCH) += bch.o +obj-y += crc32.o +obj-y += ctype.o +obj-y += div64.o +obj-y += hang.o +obj-y += linux_string.o +obj-$(CONFIG_REGEX) += slre.o +obj-y += string.o +obj-y += time.o +obj-$(CONFIG_TRACE) += trace.o +obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-y += vsprintf.o +obj-$(CONFIG_RANDOM_MACADDR) += rand.o +obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o +obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o
# SEE README.arm-unaligned-accesses $(obj)bzlib.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 07373df..a02c9b0 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -5,30 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfdt.o - -SOBJS = - COBJS-libfdt += fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_sw.o fdt_wip.o fdt_empty_tree.o
-COBJS-$(CONFIG_OF_LIBFDT) += $(COBJS-libfdt) -COBJS-$(CONFIG_FIT) += $(COBJS-libfdt) - - -COBJS := $(sort $(COBJS-y)) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_OF_LIBFDT) += $(COBJS-libfdt) +obj-$(CONFIG_FIT) += $(COBJS-libfdt) diff --git a/lib/lzma/Makefile b/lib/lzma/Makefile index 412e187..25c6797 100644 --- a/lib/lzma/Makefile +++ b/lib/lzma/Makefile @@ -8,28 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)liblzma.o - -SOBJS = - CFLAGS += -D_LZMA_PROB32
-COBJS-$(CONFIG_LZMA) += LzmaDec.o LzmaTools.o - -COBJS = $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_LZMA) += LzmaDec.o LzmaTools.o diff --git a/lib/lzo/Makefile b/lib/lzo/Makefile index 516519a..dd853ea 100644 --- a/lib/lzo/Makefile +++ b/lib/lzo/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)liblzo.o - -SOBJS = - -COBJS-$(CONFIG_LZO) += lzo1x_decompress.o - -COBJS = $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_LZO) += lzo1x_decompress.o diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index decd6e5..693c745 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -7,26 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)librsa.o - ifdef CONFIG_FIT_SIGNATURE -COBJS-$(CONFIG_RSA) += rsa-verify.o +obj-$(CONFIG_RSA) += rsa-verify.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/lib/tizen/Makefile b/lib/tizen/Makefile index 80d76cf..e1a9cf4 100644 --- a/lib/tizen/Makefile +++ b/lib/tizen/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtizen.o - -SOBJS = - -COBJS-$(CONFIG_TIZEN) += tizen.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TIZEN) += tizen.o diff --git a/lib/zlib/Makefile b/lib/zlib/Makefile index b69e234..1e9e04d 100644 --- a/lib/zlib/Makefile +++ b/lib/zlib/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libz.o - -COBJS-$(CONFIG_ZLIB) += zlib.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ZLIB) += zlib.o
disk/Makefile | 34 ++++++---------------------------- 1 file changed, 6 insertions(+), 28 deletions(-)
diff --git a/disk/Makefile b/disk/Makefile index 2b04e03..48abec8 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -5,33 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - #CFLAGS += -DET_DEBUG -DDEBUG
-LIB = $(obj)libdisk.o - -COBJS-$(CONFIG_PARTITIONS) += part.o -COBJS-$(CONFIG_MAC_PARTITION) += part_mac.o -COBJS-$(CONFIG_DOS_PARTITION) += part_dos.o -COBJS-$(CONFIG_ISO_PARTITION) += part_iso.o -COBJS-$(CONFIG_AMIGA_PARTITION) += part_amiga.o -COBJS-$(CONFIG_EFI_PARTITION) += part_efi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_PARTITIONS) += part.o +obj-$(CONFIG_MAC_PARTITION) += part_mac.o +obj-$(CONFIG_DOS_PARTITION) += part_dos.o +obj-$(CONFIG_ISO_PARTITION) += part_iso.o +obj-$(CONFIG_AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_EFI_PARTITION) += part_efi.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org ---
arch/sandbox/cpu/Makefile | 23 +---------------------- arch/sandbox/lib/Makefile | 25 +------------------------ 2 files changed, 2 insertions(+), 46 deletions(-)
diff --git a/arch/sandbox/cpu/Makefile b/arch/sandbox/cpu/Makefile index e386867..404ff67 100644 --- a/arch/sandbox/cpu/Makefile +++ b/arch/sandbox/cpu/Makefile @@ -7,29 +7,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -COBJS := cpu.o os.o start.o state.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-y := cpu.o os.o start.o state.o
# os.c is build in the system environment, so needs standard includes $(obj)os.o: ALL_CFLAGS := $(filter-out -nostdinc,$(ALL_CFLAGS)) $(obj).depend.os: CPPFLAGS := $(filter-out -nostdinc,$(CPPFLAGS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index 993fb4e..4c1a38d 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -7,28 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(ARCH).o - -COBJS-y += interrupts.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -# Always build libsandbox.o -TARGETS := $(LIB) - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += interrupts.o
On Thu, Sep 26, 2013 at 5:51 AM, Masahiro Yamada yamada.m@jp.panasonic.comwrote:
Changes for v2
- No change
Seems to work for me.
Note: arch/powerpc/cpu/mpc8260/Makefile is originally like follows:
---<snip>--- START = start.o kgdb.o COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ ---<snip>--- COBJS-$(CONFIG_ETHER_ON_SCC) = ether_scc.o ---<snip>--- $(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)
The link rule `$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)' is weird. kbdg.o is not included in $(OBJS) but linked into $(LIB) and $(LIB) is not dependent on kgdb.o. (Broken dependency tracking)
So, START = start.o kgdb.o shoud have been START = start.o SOBJS = kgdb.o
That is why this commit adds kgdb.o to obj-y, not to extra-y.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de ---
Changed v2: - fix arch/powerpc/cpu/mpc8260/Makefile as shown above
arch/powerpc/cpu/74xx_7xx/Makefile | 28 +--- arch/powerpc/cpu/mpc512x/Makefile | 51 ++------ arch/powerpc/cpu/mpc5xx/Makefile | 27 +--- arch/powerpc/cpu/mpc5xxx/Makefile | 54 +++----- arch/powerpc/cpu/mpc824x/Makefile | 28 +--- arch/powerpc/cpu/mpc8260/Makefile | 32 +---- arch/powerpc/cpu/mpc83xx/Makefile | 58 +++------ arch/powerpc/cpu/mpc85xx/Makefile | 233 +++++++++++++++------------------- arch/powerpc/cpu/mpc86xx/Makefile | 50 ++------ arch/powerpc/cpu/mpc8xx/Makefile | 58 +++------ arch/powerpc/cpu/mpc8xxx/Makefile | 30 +---- arch/powerpc/cpu/mpc8xxx/ddr/Makefile | 30 +---- arch/powerpc/cpu/ppc4xx/Makefile | 90 +++++-------- arch/powerpc/lib/Makefile | 78 ++++-------- 14 files changed, 267 insertions(+), 580 deletions(-)
diff --git a/arch/powerpc/cpu/74xx_7xx/Makefile b/arch/powerpc/cpu/74xx_7xx/Makefile index de9b4a7..f31fe75 100644 --- a/arch/powerpc/cpu/74xx_7xx/Makefile +++ b/arch/powerpc/cpu/74xx_7xx/Makefile @@ -8,28 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = cache.o kgdb.o io.o -COBJS = traps.o cpu.o cpu_init.o speed.o interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cache.o kgdb.o io.o +obj-y += traps.o cpu.o cpu_init.o speed.o interrupts.o diff --git a/arch/powerpc/cpu/mpc512x/Makefile b/arch/powerpc/cpu/mpc512x/Makefile index 1af9ab1..f770350 100644 --- a/arch/powerpc/cpu/mpc512x/Makefile +++ b/arch/powerpc/cpu/mpc512x/Makefile @@ -4,44 +4,21 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(OBJTREE)/board/freescale/common)
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS-y := cpu.o -COBJS-y += traps.o -COBJS-y += cpu_init.o -COBJS-y += fixed_sdram.o -COBJS-y += i2c.o -COBJS-y += interrupts.o -COBJS-y += iopin.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-$(CONFIG_FSL_DIU_FB) += diu.o -COBJS-$(CONFIG_CMD_IDE) += ide.o -COBJS-$(CONFIG_PCI) += pci.o +extra-y = start.o +obj-y := cpu.o +obj-y += traps.o +obj-y += cpu_init.o +obj-y += fixed_sdram.o +obj-y += i2c.o +obj-y += interrupts.o +obj-y += iopin.o +obj-y += serial.o +obj-y += speed.o +obj-$(CONFIG_FSL_DIU_FB) += diu.o +obj-$(CONFIG_CMD_IDE) += ide.o +obj-$(CONFIG_PCI) += pci.o
# Stub implementations of cache management functions for USB -COBJS-$(CONFIG_USB_EHCI) += cache.o - -COBJS := $(COBJS-y) -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_EHCI) += cache.o diff --git a/arch/powerpc/cpu/mpc5xx/Makefile b/arch/powerpc/cpu/mpc5xx/Makefile index e3e50af..7b8826a 100644 --- a/arch/powerpc/cpu/mpc5xx/Makefile +++ b/arch/powerpc/cpu/mpc5xx/Makefile @@ -16,28 +16,5 @@ # uses the definitions made in arch/powerpc/cpu/mpc5xx/config.mk #
- -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = serial.o cpu.o cpu_init.o interrupts.o traps.o speed.o spi.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = serial.o cpu.o cpu_init.o interrupts.o traps.o speed.o spi.o diff --git a/arch/powerpc/cpu/mpc5xxx/Makefile b/arch/powerpc/cpu/mpc5xxx/Makefile index fc0b7a1..5c67e1d 100644 --- a/arch/powerpc/cpu/mpc5xxx/Makefile +++ b/arch/powerpc/cpu/mpc5xxx/Makefile @@ -5,44 +5,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -SSTART = start.o -CSTART = traps.o -SOBJS += io.o -SOBJS += firmware_sc_task_bestcomm.impl.o -COBJS-y += i2c.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += ide.o -COBJS-y += interrupts.o -COBJS-y += loadtask.o -COBJS-y += pci_mpc5200.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-$(CONFIG_CMD_USB) += usb_ohci.o -COBJS-$(CONFIG_CMD_USB) += usb.o +extra-y = start.o +extra-y += traps.o +obj-y += io.o +obj-y += firmware_sc_task_bestcomm.impl.o +obj-y += i2c.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += ide.o +obj-y += interrupts.o +obj-y += loadtask.o +obj-y += pci_mpc5200.o +obj-y += serial.o +obj-y += speed.o +obj-$(CONFIG_CMD_USB) += usb_ohci.o +obj-$(CONFIG_CMD_USB) += usb.o
ifdef CONFIG_SPL_BUILD -COBJS-y += spl_boot.o +obj-y += spl_boot.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART) $(CSTART)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc824x/Makefile b/arch/powerpc/cpu/mpc824x/Makefile index 8f27aac..67b0d17 100644 --- a/arch/powerpc/cpu/mpc824x/Makefile +++ b/arch/powerpc/cpu/mpc824x/Makefile @@ -5,35 +5,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)drivers/epic $(obj)drivers/i2c) endif
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = traps.o cpu.o cpu_init.o interrupts.o speed.o \ +extra-y = start.o +obj-y = traps.o cpu.o cpu_init.o interrupts.o speed.o \ drivers/epic/epic1.o drivers/i2c/i2c.o pci.o -COBJS_LN = bedbug_603e.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-y += bedbug_603e.o
+SRCS += $(obj)bedbug_603e.c $(obj)bedbug_603e.c: ln -sf $(src)../mpc8260/bedbug_603e.c $(obj)bedbug_603e.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc8260/Makefile b/arch/powerpc/cpu/mpc8260/Makefile index d87eff6..83adc4c 100644 --- a/arch/powerpc/cpu/mpc8260/Makefile +++ b/arch/powerpc/cpu/mpc8260/Makefile @@ -5,33 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o kgdb.o -COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ +extra-y = start.o +obj-y = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ interrupts.o ether_fcc.o i2c.o commproc.o \ - bedbug_603e.o pci.o spi.o - -COBJS-$(CONFIG_ETHER_ON_SCC) = ether_scc.o - -COBJS += $(COBJS-y) - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend + bedbug_603e.o pci.o spi.o kgdb.o
-######################################################################### +obj-$(CONFIG_ETHER_ON_SCC) += ether_scc.o diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 6341cd4..b7142f0 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -7,10 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -19,48 +15,39 @@ MINIMAL=y endif endif
-START = start.o +extra-y = start.o
ifdef MINIMAL
-COBJS-y += spl_minimal.o +obj-y += spl_minimal.o
else
-COBJS-y += traps.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += speed.o -COBJS-y += interrupts.o -COBJS-y += ecc.o -COBJS-$(CONFIG_QE) += qe_io.o -COBJS-$(CONFIG_FSL_SERDES) += serdes.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-$(CONFIG_PCIE) += pcie.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += traps.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += speed.o +obj-y += interrupts.o +obj-y += ecc.o +obj-$(CONFIG_QE) += qe_io.o +obj-$(CONFIG_FSL_SERDES) += serdes.o +obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_PCIE) += pcie.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o
# Stub implementations of cache management functions for USB -COBJS-y += cache.o +obj-y += cache.o
ifdef CONFIG_FSL_DDR2 -COBJS_LN-$(CONFIG_MPC8349) += ddr-gen2.o +obj-$(CONFIG_MPC8349) += ddr-gen2.o +SRCS += $(obj)ddr-gen2.c else -COBJS-y += spd_sdram.o +obj-y += spd_sdram.o endif -COBJS-$(CONFIG_FSL_DDR2) += law.o +obj-$(CONFIG_FSL_DDR2) += law.o
endif # not minimal
-COBJS := $(COBJS-y) -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN-y:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - $(obj)ddr-gen1.c: ln -sf $(SRCTREE)/arch/powerpc/cpu/mpc85xx/ddr-gen1.c $(obj)ddr-gen1.c
@@ -69,12 +56,3 @@ $(obj)ddr-gen2.c:
$(obj)ddr-gen3.c: ln -sf $(SRCTREE)/arch/powerpc/cpu/mpc85xx/ddr-gen3.c $(obj)ddr-gen3.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index f70f0d7..50ddb50 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -8,10 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef CONFIG_SPL_BUILD @@ -20,149 +16,128 @@ MINIMAL=y endif endif
-START = start.o resetvec.o +extra-y = start.o resetvec.o
ifdef MINIMAL
-COBJS-y += cpu_init_early.o tlb.o spl_minimal.o +obj-y += cpu_init_early.o tlb.o spl_minimal.o
else
-SOBJS-$(CONFIG_MP) += release.o -SOBJS = $(SOBJS-y) +obj-$(CONFIG_MP) += release.o
-COBJS-$(CONFIG_CMD_ERRATA) += cmd_errata.o -COBJS-$(CONFIG_CPM2) += commproc.o +obj-$(CONFIG_CMD_ERRATA) += cmd_errata.o +obj-$(CONFIG_CPM2) += commproc.o
# supports ddr1 -COBJS-$(CONFIG_MPC8540) += ddr-gen1.o -COBJS-$(CONFIG_MPC8560) += ddr-gen1.o -COBJS-$(CONFIG_MPC8541) += ddr-gen1.o -COBJS-$(CONFIG_MPC8555) += ddr-gen1.o +obj-$(CONFIG_MPC8540) += ddr-gen1.o +obj-$(CONFIG_MPC8560) += ddr-gen1.o +obj-$(CONFIG_MPC8541) += ddr-gen1.o +obj-$(CONFIG_MPC8555) += ddr-gen1.o
# supports ddr1/2 -COBJS-$(CONFIG_MPC8548) += ddr-gen2.o -COBJS-$(CONFIG_MPC8568) += ddr-gen2.o -COBJS-$(CONFIG_MPC8544) += ddr-gen2.o +obj-$(CONFIG_MPC8548) += ddr-gen2.o +obj-$(CONFIG_MPC8568) += ddr-gen2.o +obj-$(CONFIG_MPC8544) += ddr-gen2.o
# supports ddr1/2/3 -COBJS-$(CONFIG_PPC_C29X) += ddr-gen3.o -COBJS-$(CONFIG_MPC8572) += ddr-gen3.o -COBJS-$(CONFIG_MPC8536) += ddr-gen3.o -COBJS-$(CONFIG_MPC8569) += ddr-gen3.o -COBJS-$(CONFIG_P1010) += ddr-gen3.o -COBJS-$(CONFIG_P1011) += ddr-gen3.o -COBJS-$(CONFIG_P1012) += ddr-gen3.o -COBJS-$(CONFIG_P1013) += ddr-gen3.o -COBJS-$(CONFIG_P1014) += ddr-gen3.o -COBJS-$(CONFIG_P1020) += ddr-gen3.o -COBJS-$(CONFIG_P1021) += ddr-gen3.o -COBJS-$(CONFIG_P1022) += ddr-gen3.o -COBJS-$(CONFIG_P1023) += ddr-gen3.o -COBJS-$(CONFIG_P1024) += ddr-gen3.o -COBJS-$(CONFIG_P1025) += ddr-gen3.o -COBJS-$(CONFIG_P2010) += ddr-gen3.o -COBJS-$(CONFIG_P2020) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P2041) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P5040) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T4240) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T4160) += ddr-gen3.o -COBJS-$(CONFIG_PPC_B4420) += ddr-gen3.o -COBJS-$(CONFIG_PPC_B4860) += ddr-gen3.o -COBJS-$(CONFIG_BSC9131) += ddr-gen3.o -COBJS-$(CONFIG_BSC9132) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T1040) += ddr-gen3.o - -COBJS-$(CONFIG_CPM2) += ether_fcc.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-$(CONFIG_FSL_CORENET) += liodn.o -COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-$(CONFIG_SYS_DPAA_QBMAN) += portals.o +obj-$(CONFIG_PPC_C29X) += ddr-gen3.o +obj-$(CONFIG_MPC8572) += ddr-gen3.o +obj-$(CONFIG_MPC8536) += ddr-gen3.o +obj-$(CONFIG_MPC8569) += ddr-gen3.o +obj-$(CONFIG_P1010) += ddr-gen3.o +obj-$(CONFIG_P1011) += ddr-gen3.o +obj-$(CONFIG_P1012) += ddr-gen3.o +obj-$(CONFIG_P1013) += ddr-gen3.o +obj-$(CONFIG_P1014) += ddr-gen3.o +obj-$(CONFIG_P1020) += ddr-gen3.o +obj-$(CONFIG_P1021) += ddr-gen3.o +obj-$(CONFIG_P1022) += ddr-gen3.o +obj-$(CONFIG_P1023) += ddr-gen3.o +obj-$(CONFIG_P1024) += ddr-gen3.o +obj-$(CONFIG_P1025) += ddr-gen3.o +obj-$(CONFIG_P2010) += ddr-gen3.o +obj-$(CONFIG_P2020) += ddr-gen3.o +obj-$(CONFIG_PPC_P2041) += ddr-gen3.o +obj-$(CONFIG_PPC_P3041) += ddr-gen3.o +obj-$(CONFIG_PPC_P4080) += ddr-gen3.o +obj-$(CONFIG_PPC_P5020) += ddr-gen3.o +obj-$(CONFIG_PPC_P5040) += ddr-gen3.o +obj-$(CONFIG_PPC_T4240) += ddr-gen3.o +obj-$(CONFIG_PPC_T4160) += ddr-gen3.o +obj-$(CONFIG_PPC_B4420) += ddr-gen3.o +obj-$(CONFIG_PPC_B4860) += ddr-gen3.o +obj-$(CONFIG_BSC9131) += ddr-gen3.o +obj-$(CONFIG_BSC9132) += ddr-gen3.o +obj-$(CONFIG_PPC_T1040) += ddr-gen3.o + +obj-$(CONFIG_CPM2) += ether_fcc.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-$(CONFIG_FSL_CORENET) += liodn.o +obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_SYS_DPAA_QBMAN) += portals.o
# various SoC specific assignments -COBJS-$(CONFIG_PPC_P2041) += p2041_ids.o -COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o -COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o -COBJS-$(CONFIG_PPC_P5020) += p5020_ids.o -COBJS-$(CONFIG_PPC_P5040) += p5040_ids.o -COBJS-$(CONFIG_PPC_T4240) += t4240_ids.o -COBJS-$(CONFIG_PPC_T4160) += t4240_ids.o -COBJS-$(CONFIG_PPC_B4420) += b4860_ids.o -COBJS-$(CONFIG_PPC_B4860) += b4860_ids.o -COBJS-$(CONFIG_PPC_T1040) += t1040_ids.o - -COBJS-$(CONFIG_QE) += qe_io.o -COBJS-$(CONFIG_CPM2) += serial_scc.o -COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o -COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o +obj-$(CONFIG_PPC_P2041) += p2041_ids.o +obj-$(CONFIG_PPC_P3041) += p3041_ids.o +obj-$(CONFIG_PPC_P4080) += p4080_ids.o +obj-$(CONFIG_PPC_P5020) += p5020_ids.o +obj-$(CONFIG_PPC_P5040) += p5040_ids.o +obj-$(CONFIG_PPC_T4240) += t4240_ids.o +obj-$(CONFIG_PPC_T4160) += t4240_ids.o +obj-$(CONFIG_PPC_B4420) += b4860_ids.o +obj-$(CONFIG_PPC_B4860) += b4860_ids.o +obj-$(CONFIG_PPC_T1040) += t1040_ids.o + +obj-$(CONFIG_QE) += qe_io.o +obj-$(CONFIG_CPM2) += serial_scc.o +obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o +obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o
# SoC specific SERDES support -COBJS-$(CONFIG_PPC_C29X) += c29x_serdes.o -COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o -COBJS-$(CONFIG_MPC8544) += mpc8544_serdes.o -COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o -COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o -COBJS-$(CONFIG_MPC8569) += mpc8569_serdes.o -COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o -COBJS-$(CONFIG_P1010) += p1010_serdes.o -COBJS-$(CONFIG_P1011) += p1021_serdes.o -COBJS-$(CONFIG_P1012) += p1021_serdes.o -COBJS-$(CONFIG_P1013) += p1022_serdes.o -COBJS-$(CONFIG_P1014) += p1010_serdes.o -COBJS-$(CONFIG_P1017) += p1023_serdes.o -COBJS-$(CONFIG_P1020) += p1021_serdes.o -COBJS-$(CONFIG_P1021) += p1021_serdes.o -COBJS-$(CONFIG_P1022) += p1022_serdes.o -COBJS-$(CONFIG_P1023) += p1023_serdes.o -COBJS-$(CONFIG_P1024) += p1021_serdes.o -COBJS-$(CONFIG_P1025) += p1021_serdes.o -COBJS-$(CONFIG_P2010) += p2020_serdes.o -COBJS-$(CONFIG_P2020) += p2020_serdes.o -COBJS-$(CONFIG_PPC_P2041) += p2041_serdes.o -COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o -COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o -COBJS-$(CONFIG_PPC_P5020) += p5020_serdes.o -COBJS-$(CONFIG_PPC_P5040) += p5040_serdes.o -COBJS-$(CONFIG_PPC_T4240) += t4240_serdes.o -COBJS-$(CONFIG_PPC_T4160) += t4240_serdes.o -COBJS-$(CONFIG_PPC_B4420) += b4860_serdes.o -COBJS-$(CONFIG_PPC_B4860) += b4860_serdes.o -COBJS-$(CONFIG_BSC9132) += bsc9132_serdes.o -COBJS-$(CONFIG_PPC_T1040) += t1040_serdes.o - -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += cpu_init_early.o -COBJS-y += interrupts.o -COBJS-y += speed.o -COBJS-y += tlb.o -COBJS-y += traps.o +obj-$(CONFIG_PPC_C29X) += c29x_serdes.o +obj-$(CONFIG_MPC8536) += mpc8536_serdes.o +obj-$(CONFIG_MPC8544) += mpc8544_serdes.o +obj-$(CONFIG_MPC8548) += mpc8548_serdes.o +obj-$(CONFIG_MPC8568) += mpc8568_serdes.o +obj-$(CONFIG_MPC8569) += mpc8569_serdes.o +obj-$(CONFIG_MPC8572) += mpc8572_serdes.o +obj-$(CONFIG_P1010) += p1010_serdes.o +obj-$(CONFIG_P1011) += p1021_serdes.o +obj-$(CONFIG_P1012) += p1021_serdes.o +obj-$(CONFIG_P1013) += p1022_serdes.o +obj-$(CONFIG_P1014) += p1010_serdes.o +obj-$(CONFIG_P1017) += p1023_serdes.o +obj-$(CONFIG_P1020) += p1021_serdes.o +obj-$(CONFIG_P1021) += p1021_serdes.o +obj-$(CONFIG_P1022) += p1022_serdes.o +obj-$(CONFIG_P1023) += p1023_serdes.o +obj-$(CONFIG_P1024) += p1021_serdes.o +obj-$(CONFIG_P1025) += p1021_serdes.o +obj-$(CONFIG_P2010) += p2020_serdes.o +obj-$(CONFIG_P2020) += p2020_serdes.o +obj-$(CONFIG_PPC_P2041) += p2041_serdes.o +obj-$(CONFIG_PPC_P3041) += p3041_serdes.o +obj-$(CONFIG_PPC_P4080) += p4080_serdes.o +obj-$(CONFIG_PPC_P5020) += p5020_serdes.o +obj-$(CONFIG_PPC_P5040) += p5040_serdes.o +obj-$(CONFIG_PPC_T4240) += t4240_serdes.o +obj-$(CONFIG_PPC_T4160) += t4240_serdes.o +obj-$(CONFIG_PPC_B4420) += b4860_serdes.o +obj-$(CONFIG_PPC_B4860) += b4860_serdes.o +obj-$(CONFIG_BSC9132) += bsc9132_serdes.o +obj-$(CONFIG_PPC_T1040) += t1040_serdes.o + +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += cpu_init_early.o +obj-y += interrupts.o +obj-y += speed.o +obj-y += tlb.o +obj-y += traps.o
endif # not minimal - -COBJS = $(COBJS-y) - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc86xx/Makefile b/arch/powerpc/cpu/mpc86xx/Makefile index 04271b0..bcb786d 100644 --- a/arch/powerpc/cpu/mpc86xx/Makefile +++ b/arch/powerpc/cpu/mpc86xx/Makefile @@ -8,42 +8,20 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y = start.o +extra-y += traps.o
-LIB = $(obj)lib$(CPU).o +obj-y += cache.o +obj-$(CONFIG_MP) += release.o
-SSTART = start.o -CSTART = traps.o - -SOBJS-y += cache.o -SOBJS-$(CONFIG_MP) += release.o - -COBJS-y += cpu.o -COBJS-y += cpu_init.o +obj-y += cpu.o +obj-y += cpu_init.o # 8610 & 8641 are identical w/regards to DDR -COBJS-$(CONFIG_MPC8610) += ddr-8641.o -COBJS-$(CONFIG_MPC8641) += ddr-8641.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_MPC8610) += mpc8610_serdes.o -COBJS-$(CONFIG_MPC8641) += mpc8641_serdes.o -COBJS-y += speed.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART) $(CSTART)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MPC8610) += ddr-8641.o +obj-$(CONFIG_MPC8641) += ddr-8641.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += interrupts.o +obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_MPC8610) += mpc8610_serdes.o +obj-$(CONFIG_MPC8641) += mpc8641_serdes.o +obj-y += speed.o diff --git a/arch/powerpc/cpu/mpc8xx/Makefile b/arch/powerpc/cpu/mpc8xx/Makefile index 71d5e30..d40bdab 100644 --- a/arch/powerpc/cpu/mpc8xx/Makefile +++ b/arch/powerpc/cpu/mpc8xx/Makefile @@ -5,45 +5,23 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # CFLAGS += -DET_DEBUG
-LIB = $(obj)lib$(CPU).o - -SSTART-y += start.o -CSTART-y += traps.o -COBJS-y += bedbug_860.o -COBJS-y += commproc.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += fec.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-y += i2c.o -COBJS-y += interrupts.o -COBJS-y += scc.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-y += spi.o -COBJS-y += upatch.o -COBJS-y += video.o -SOBJS-y += kgdb.o -SOBJS-y += plprcr_write.o - -SRCS := $(SSTART-y:.o=.S) $(CSTART-y:.o=.c) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART-y) $(CSTART-y)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y += start.o +extra-y += traps.o +obj-y += bedbug_860.o +obj-y += commproc.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += fec.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += i2c.o +obj-y += interrupts.o +obj-y += scc.o +obj-y += serial.o +obj-y += speed.o +obj-y += spi.o +obj-y += upatch.o +obj-y += video.o +obj-y += kgdb.o +obj-y += plprcr_write.o diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index 3dc8e05..395fed1 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -6,10 +6,6 @@ # Version 2 as published by the Free Software Foundation. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib8xxx.o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -20,30 +16,18 @@ endif
ifdef MINIMAL
-COBJS-$(CONFIG_FSL_LAW) += law.o +obj-$(CONFIG_FSL_LAW) += law.o
else
ifneq ($(CPU),mpc83xx) -COBJS-y += cpu.o +obj-y += cpu.o endif
-COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-$(CONFIG_FSL_IFC) += fsl_ifc.o -COBJS-$(CONFIG_FSL_LBC) += fsl_lbc.o -COBJS-$(CONFIG_SYS_SRIO) += srio.o -COBJS-$(CONFIG_FSL_LAW) += law.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-$(CONFIG_FSL_IFC) += fsl_ifc.o +obj-$(CONFIG_FSL_LBC) += fsl_lbc.o +obj-$(CONFIG_SYS_SRIO) += srio.o +obj-$(CONFIG_FSL_LAW) += law.o
endif - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/Makefile b/arch/powerpc/cpu/mpc8xxx/ddr/Makefile index 29523aa..8cbc06c 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/ddr/Makefile @@ -6,17 +6,13 @@ # Version 2 as published by the Free Software Foundation. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libddr.o - -COBJS-$(CONFIG_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o
-COBJS-$(CONFIG_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o
-COBJS-$(CONFIG_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o ifdef CONFIG_DDR_SPD SPD := y @@ -25,21 +21,9 @@ ifdef CONFIG_SPD_EEPROM SPD := y endif ifdef SPD -COBJS-$(CONFIG_FSL_DDR1) += ddr1_dimm_params.o -COBJS-$(CONFIG_FSL_DDR2) += ddr2_dimm_params.o -COBJS-$(CONFIG_FSL_DDR3) += ddr3_dimm_params.o +obj-$(CONFIG_FSL_DDR1) += ddr1_dimm_params.o +obj-$(CONFIG_FSL_DDR2) += ddr2_dimm_params.o +obj-$(CONFIG_FSL_DDR3) += ddr3_dimm_params.o endif
-COBJS-$(CONFIG_FSL_DDR_INTERACTIVE) += interactive.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-$(CONFIG_FSL_DDR_INTERACTIVE) += interactive.o diff --git a/arch/powerpc/cpu/ppc4xx/Makefile b/arch/powerpc/cpu/ppc4xx/Makefile index d38b4aa..14b520f 100644 --- a/arch/powerpc/cpu/ppc4xx/Makefile +++ b/arch/powerpc/cpu/ppc4xx/Makefile @@ -5,71 +5,49 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y := resetvec.o +extra-y += start.o
-LIB = $(obj)lib$(CPU).o +obj-y := cache.o +obj-y += dcr.o +obj-y += kgdb.o
-START := resetvec.o -START += start.o - -SOBJS := cache.o -SOBJS += dcr.o -SOBJS += kgdb.o - -COBJS := 40x_spd_sdram.o +obj-y += 40x_spd_sdram.o
ifndef CONFIG_NAND_SPL ifndef CONFIG_NAND_U_BOOT -COBJS += 44x_spd_ddr.o +obj-y += 44x_spd_ddr.o endif endif -COBJS-$(CONFIG_SDRAM_PPC4xx_IBM_DDR2) += 44x_spd_ddr2.o -COBJS-$(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) += 4xx_ibm_ddr2_autocalib.o -COBJS += 4xx_pci.o -COBJS += 4xx_pcie.o -COBJS += bedbug_405.o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += cmd_chip_config.o -COBJS += cpu.o -COBJS += cpu_init.o -COBJS += denali_data_eye.o -COBJS += denali_spd_ddr2.o -COBJS += ecc.o -COBJS-$(CONFIG_CMD_ECCTEST) += cmd_ecctest.o -COBJS += fdt.o -COBJS += interrupts.o -COBJS-$(CONFIG_CMD_REGINFO) += reginfo.o -COBJS += sdram.o -COBJS += speed.o -COBJS += tlb.o -COBJS += traps.o -COBJS += usb.o -COBJS += usb_ohci.o -COBJS-$(CONFIG_XILINX_440) += xilinx_irq.o +obj-$(CONFIG_SDRAM_PPC4xx_IBM_DDR2) += 44x_spd_ddr2.o +obj-$(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) += 4xx_ibm_ddr2_autocalib.o +obj-y += 4xx_pci.o +obj-y += 4xx_pcie.o +obj-y += bedbug_405.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += cmd_chip_config.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += denali_data_eye.o +obj-y += denali_spd_ddr2.o +obj-y += ecc.o +obj-$(CONFIG_CMD_ECCTEST) += cmd_ecctest.o +obj-y += fdt.o +obj-y += interrupts.o +obj-$(CONFIG_CMD_REGINFO) += reginfo.o +obj-y += sdram.o +obj-y += speed.o +obj-y += tlb.o +obj-y += traps.o +obj-y += usb.o +obj-y += usb_ohci.o +obj-$(CONFIG_XILINX_440) += xilinx_irq.o ifndef CONFIG_XILINX_440 -COBJS += 4xx_uart.o -COBJS += gpio.o -COBJS += miiphy.o -COBJS += uic.o +obj-y += 4xx_uart.o +obj-y += gpio.o +obj-y += miiphy.o +obj-y += uic.o endif
ifdef CONFIG_SPL_BUILD -COBJS-y += spl_boot.o +obj-y += spl_boot.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 8815292..a706d3c 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -5,23 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - ## Build a couple of necessary functions into a private libgcc -LIBGCC = $(obj)libgcc.o -GLSOBJS += _ashldi3.o -GLSOBJS += _ashrdi3.o -GLSOBJS += _lshrdi3.o -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ - $(addprefix $(obj),$(GLCOBJS)) - -## But only build it if the user asked for it +## if the user asked for it ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) +lib-y += _ashldi3.o +lib-y += _ashrdi3.o +lib-y += _lshrdi3.o endif
-LIB = $(obj)lib$(ARCH).o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -31,29 +22,29 @@ endif endif
ifdef MINIMAL -COBJS-y += cache.o time.o -SOBJS-y += ticks.o +obj-y += cache.o time.o +obj-y += ticks.o else
-SOBJS-y += ppcstring.o +obj-y += ppcstring.o
-SOBJS-y += ppccache.o -SOBJS-y += ticks.o -SOBJS-y += reloc.o +obj-y += ppccache.o +obj-y += ticks.o +obj-y += reloc.o
-COBJS-$(CONFIG_BAT_RW) += bat_rw.o +obj-$(CONFIG_BAT_RW) += bat_rw.o ifndef CONFIG_SPL_BUILD ifndef CONFIG_SYS_GENERIC_BOARD -COBJS-y += board.o +obj-y += board.o endif endif -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += cache.o -COBJS-y += extable.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_CMD_KGDB) += kgdb.o -COBJS-${CONFIG_CMD_IDE} += ide.o -COBJS-y += time.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += cache.o +obj-y += extable.o +obj-y += interrupts.o +obj-$(CONFIG_CMD_KGDB) += kgdb.o +obj-$(CONFIG_CMD_IDE) += ide.o +obj-y += time.o
# Don't include the MPC5xxx special memcpy into the # SPL U-Boot image. memcpy is used in the SPL NOR @@ -64,41 +55,16 @@ ifndef CONFIG_SPL_BUILD # on MPC512x and MPC5200 ifdef CONFIG_MPC512X $(obj)ppcstring.o: AFLAGS += -Dmemcpy=__memcpy -COBJS-y += memcpy_mpc5200.o +obj-y += memcpy_mpc5200.o endif ifdef CONFIG_MPC5200 $(obj)ppcstring.o: AFLAGS += -Dmemcpy=__memcpy -COBJS-y += memcpy_mpc5200.o +obj-y += memcpy_mpc5200.o endif endif
endif # not minimal
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o endif - -COBJS += $(sort $(COBJS-y)) - -SRCS := $(GLSOBJS:.o=.S) $(GLCOBJS:.o=.c) \ - $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -TARGETS += $(LIB) - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Tom Rini trini@ti.com ---
Changes for v2 - No change
board/ti/am335x/Makefile | 29 ++--------------------------- board/ti/am3517crane/Makefile | 19 +------------------ board/ti/am43xx/Makefile | 29 ++--------------------------- board/ti/beagle/Makefile | 24 ++---------------------- board/ti/dra7xx/Makefile | 27 +-------------------------- board/ti/evm/Makefile | 19 +------------------ board/ti/omap1510inn/Makefile | 24 ++---------------------- board/ti/omap5912osk/Makefile | 24 ++---------------------- board/ti/omap5_uevm/Makefile | 27 +-------------------------- board/ti/omap730p2/Makefile | 24 ++---------------------- board/ti/panda/Makefile | 21 +-------------------- board/ti/sdp3430/Makefile | 21 +-------------------- board/ti/sdp4430/Makefile | 23 ++--------------------- board/ti/ti814x/Makefile | 29 ++--------------------------- board/ti/ti816x/Makefile | 27 +-------------------------- board/ti/tnetv107xevm/Makefile | 25 +------------------------ 16 files changed, 24 insertions(+), 368 deletions(-)
diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile index 3dbeeda..c8b4f9a 100644 --- a/board/ti/am335x/Makefile +++ b/board/ti/am335x/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_NOR_BOOT),y) -COBJS := mux.o +obj-y := mux.o endif
-COBJS += board.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/ti/am3517crane/Makefile b/board/ti/am3517crane/Makefile index d9ab72a..9da795d 100644 --- a/board/ti/am3517crane/Makefile +++ b/board/ti/am3517crane/Makefile @@ -8,21 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := am3517crane.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := am3517crane.o diff --git a/board/ti/am43xx/Makefile b/board/ti/am43xx/Makefile index 4a1bb7c..cb5fe88 100644 --- a/board/ti/am43xx/Makefile +++ b/board/ti/am43xx/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -COBJS := mux.o +obj-y := mux.o endif
-COBJS += board.o -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/ti/beagle/Makefile b/board/ti/beagle/Makefile index 3018f6c..9f55e8f 100644 --- a/board/ti/beagle/Makefile +++ b/board/ti/beagle/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_STATUS_LED) += led.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := $(BOARD).o +obj-$(CONFIG_STATUS_LED) += led.o diff --git a/board/ti/dra7xx/Makefile b/board/ti/dra7xx/Makefile index e558f4c..434e8d1 100644 --- a/board/ti/dra7xx/Makefile +++ b/board/ti/dra7xx/Makefile @@ -5,29 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/evm/Makefile b/board/ti/evm/Makefile index 0f8cf44..b88ab8f 100644 --- a/board/ti/evm/Makefile +++ b/board/ti/evm/Makefile @@ -5,21 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := evm.o diff --git a/board/ti/omap1510inn/Makefile b/board/ti/omap1510inn/Makefile index ad5a7eb..8256e81 100644 --- a/board/ti/omap1510inn/Makefile +++ b/board/ti/omap1510inn/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap1510innovator.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap1510innovator.o +obj-y += lowlevel_init.o diff --git a/board/ti/omap5912osk/Makefile b/board/ti/omap5912osk/Makefile index b2727de..d7c0ebd 100644 --- a/board/ti/omap5912osk/Makefile +++ b/board/ti/omap5912osk/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap5912osk.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap5912osk.o +obj-y += lowlevel_init.o diff --git a/board/ti/omap5_uevm/Makefile b/board/ti/omap5_uevm/Makefile index 2ab40e3..b88ab8f 100644 --- a/board/ti/omap5_uevm/Makefile +++ b/board/ti/omap5_uevm/Makefile @@ -5,29 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/omap730p2/Makefile b/board/ti/omap730p2/Makefile index 37a4d34..8242f3d 100644 --- a/board/ti/omap730p2/Makefile +++ b/board/ti/omap730p2/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap730p2.o flash.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap730p2.o flash.o +obj-y += lowlevel_init.o diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile index 1e489d2..c89f80d 100644 --- a/board/ti/panda/Makefile +++ b/board/ti/panda/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := panda.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := panda.o diff --git a/board/ti/sdp3430/Makefile b/board/ti/sdp3430/Makefile index e72485c..753f099 100644 --- a/board/ti/sdp3430/Makefile +++ b/board/ti/sdp3430/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sdp.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sdp.o diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile index c522a2b..79e67b6 100644 --- a/board/ti/sdp4430/Makefile +++ b/board/ti/sdp4430/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sdp.o +obj-y := sdp.o
ifndef CONFIG_SPL_BUILD -COBJS += cmd_bat.o +obj-y += cmd_bat.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/ti/ti814x/Makefile b/board/ti/ti814x/Makefile index 6059e20..93155de 100644 --- a/board/ti/ti814x/Makefile +++ b/board/ti/ti814x/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += evm.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += evm.o diff --git a/board/ti/ti816x/Makefile b/board/ti/ti816x/Makefile index 17ce72a..f1cc3d5 100644 --- a/board/ti/ti816x/Makefile +++ b/board/ti/ti816x/Makefile @@ -9,29 +9,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/tnetv107xevm/Makefile b/board/ti/tnetv107xevm/Makefile index 5b82e48..0a6128f 100644 --- a/board/ti/tnetv107xevm/Makefile +++ b/board/ti/tnetv107xevm/Makefile @@ -2,27 +2,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += sdb_board.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -.PHONY: all - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sdb_board.o
FYI:
In order to avoid git-pull conflict, this series uses http://patchwork.ozlabs.org/patch/268098/ http://patchwork.ozlabs.org/patch/268097/ http://patchwork.ozlabs.org/patch/268099/ as prerequisites.
Those three were accepted by Albert and now stay in u-boot-arm/master, but not exist in u-boot/master.
If you try applying these series, u-boot-arm/master must be merged into u-boot/master beforehand.
Best Regards Masahiro Yamada
Masahiro Yamada
