[PATCH v1] Revert "x86: use invd instead of wbinvd in real mode start code"
This reverts commit 0d67fac29f3187e67f4fd3ef15f73e91be2fad12.
As real hardware testing (*) shows the above mentioned commit breaks U-Boot on it. Revert for the upcoming release. We may get more information in the future and optimize the code accordingly.
(*) om Intel Edison board.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- arch/x86/cpu/start.S | 2 +- arch/x86/cpu/start16.S | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/start.S b/arch/x86/cpu/start.S index 26cf995db2..01524635e9 100644 --- a/arch/x86/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -50,7 +50,7 @@ _x86boot_start: movl %cr0, %eax orl $(X86_CR0_NW | X86_CR0_CD), %eax movl %eax, %cr0 - invd + wbinvd
/* * Zero the BIST (Built-In Self Test) value since we don't have it. diff --git a/arch/x86/cpu/start16.S b/arch/x86/cpu/start16.S index 292e750508..54f4ff6662 100644 --- a/arch/x86/cpu/start16.S +++ b/arch/x86/cpu/start16.S @@ -28,7 +28,7 @@ start16: movl %cr0, %eax orl $(X86_CR0_NW | X86_CR0_CD), %eax movl %eax, %cr0 - invd + wbinvd
/* load the temporary Global Descriptor Table */ data32 cs lidt idt_ptr
On Mon, Feb 17, 2020 at 11:30 PM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
on?
Acked-by: Bin Meng bmeng.cn@gmail.com
on?
Right. Should I resend or you can fix when apply?
Thanks!
On Tue, Feb 18, 2020 at 5:37 PM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
on?
No, I fixed it when applying,
applied to u-boot-x86, thanks!
Hi Andy,
On Tue, Feb 18, 2020 at 12:30 AM Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Reverting arch/x86/cpu/start.S is enough, isn't it?
arch/x86/cpu/start16.S is not compiled for the Edison board.
start16.S is the start of the Real Mode, and we are sure no program was running before U-Boot.
invd
wbinvd /* * Zero the BIST (Built-In Self Test) value since we don't have it.
invd
wbinvd /* load the temporary Global Descriptor Table */
2.25.0
Had you tested on real hardware?
Since Qemu ~= "no test" for the available hardware, I can't answer to this.
To be on the safer side I prefer to revert completely. Then you may come up with a new patch with better commit message and testing. To me it sounds fair.
Andy Shevchenko
Bin Meng
Masahiro Yamada
