[PATCH v1] env: setenv add resolve value option
Add possibility setup env variable with additional resolving vars inside value.
Usage examples
=> setenv a hello => setenv b world => setenv c '${a} ${b}' => setenv -r d '${c}! ${a}...' => printenv d d=hello world! hello...
/* internal usage example */ env_resolve("d", "${c}! ${a}..."); /* d="hello world! hello..." */
Notes
Resolving works only for ${var} "bracket" and didn't workd for "unbracket" $var
=> setenv -r d '$c! $a...' => printenv d d=$c! $a...
Signed-off-by: Artem Lapkin art@khadas.com --- cmd/nvedit.c | 42 +++++++++++++++++++++++++++++++++++++++++- include/_exports.h | 1 + include/env.h | 11 +++++++++++ include/exports.h | 1 + 4 files changed, 54 insertions(+), 1 deletion(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 3bb6e764c0..6608932dc0 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -229,6 +229,7 @@ static int _do_env_set(int flag, int argc, char *const argv[], int env_flag) int i, len; char *name, *value, *s; struct env_entry e, *ep; + bool resolve = 0;
debug("Initial value for argc=%d\n", argc);
@@ -246,6 +247,9 @@ static int _do_env_set(int flag, int argc, char *const argv[], int env_flag) case 'f': /* force */ env_flag |= H_FORCE; break; + case 'r': /* resolve */ + resolve = 1; + break; default: return CMD_RET_USAGE; } @@ -291,6 +295,26 @@ static int _do_env_set(int flag, int argc, char *const argv[], int env_flag) if (s != value) *--s = '\0';
+ /* + * deep resolve value vars + */ + if (resolve) { + int max_loop = 32; + char value2[CONFIG_SYS_CBSIZE]; + + do { + cli_simple_process_macros(value, value2, CONFIG_SYS_CBSIZE); + if (!strcmp(value, value2)) + break; + value = realloc(value, strlen(value2)); + if (!value) { + printf("## Can't realloc %d bytes\n", len); + return 1; + } + strcpy(value, value2); + } while (max_loop--); + } + e.key = name; e.data = value; hsearch_r(e, ENV_ENTER, &ep, &env_htab, env_flag); @@ -304,6 +328,20 @@ static int _do_env_set(int flag, int argc, char *const argv[], int env_flag) return 0; }
+int env_resolve(const char *varname, const char *varvalue) +{ + const char * const argv[5] = { "setenv", "-r", varname, varvalue, NULL }; + + /* before import into hashtable */ + if (!(gd->flags & GD_FLG_ENV_READY)) + return 1; + + if (!varvalue || varvalue[0] == '\0') + return _do_env_set(0, 3, (char * const *)argv, H_PROGRAMMATIC); + else + return _do_env_set(0, 4, (char * const *)argv, H_PROGRAMMATIC); +} + int env_set(const char *varname, const char *varvalue) { const char * const argv[4] = { "setenv", varname, varvalue, NULL }; @@ -1371,7 +1409,9 @@ U_BOOT_CMD_COMPLETE( "setenv [-f] name value ...\n" " - [forcibly] set environment variable 'name' to 'value ...'\n" "setenv [-f] name\n" - " - [forcibly] delete environment variable 'name'", + " - [forcibly] delete environment variable 'name'\n" + "setenv [-r] name value ...\n" + " - [resolve] resolve 'value ...' to environment variable\n", var_complete );
diff --git a/include/_exports.h b/include/_exports.h index 8030d70c0b..86bc07f051 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -32,6 +32,7 @@ EXPORT_FUNC(do_reset, int, do_reset, struct cmd_tbl *, int , int , char * const []) EXPORT_FUNC(env_get, char *, env_get, const char*) + EXPORT_FUNC(env_resolve, int, env_resolve, const char *, const char *) EXPORT_FUNC(env_set, int, env_set, const char *, const char *) EXPORT_FUNC(simple_strtoul, unsigned long, simple_strtoul, const char *, char **, unsigned int) diff --git a/include/env.h b/include/env.h index ee5e30d036..c4efc5b7e5 100644 --- a/include/env.h +++ b/include/env.h @@ -133,6 +133,17 @@ int env_get_f(const char *name, char *buf, unsigned int len); */ int env_get_yesno(const char *var);
+/** + * env_resolve() - resolve to environment variable + * + * Same as env_set but make deep resolve for variable + * + * @varname: Variable to adjust + * @value: Value to resolve for the variable, or NULL or "" to delete the variable + * @return 0 if OK, 1 on error + */ +int env_resolve(const char *varname, const char *value); + /** * env_set() - set an environment variable * diff --git a/include/exports.h b/include/exports.h index 550cafdc7a..a54b997988 100644 --- a/include/exports.h +++ b/include/exports.h @@ -44,6 +44,7 @@ int vprintf(const char *, va_list); unsigned long simple_strtoul(const char *cp, char **endp, unsigned int base); int strict_strtoul(const char *cp, unsigned int base, unsigned long *res); char *env_get(const char *name); +int env_resolve(const char *varname, const char *value); int env_set(const char *varname, const char *value); long simple_strtol(const char *cp, char **endp, unsigned int base); int strcmp(const char *cs, const char *ct);
Hi Artem,
Usage examples
Notes
how come?
See also this old patch:
https://patchwork.ozlabs.org/project/uboot/patch/1449255744-25787-1-git-send...
bool resolve = 0; debug("Initial value for argc=%d\n", argc);
resolve = 1;
single-line comment style is /*... */
if (resolve) {
int max_loop = 32;
do {
break;
strdup() ?
if (!value) {
return 1;
return 1;
Could put that in a var to avoid repeating in the next 3 lines:
else
- env_resolve() - resolve to environment variable
- Same as env_set but make deep resolve for variable
- @varname: Variable to adjust
- @value: Value to resolve for the variable, or NULL or "" to delete the variable
- @return 0 if OK, 1 on error
- env_set() - set an environment variable
please add function comment
int env_set(const char *varname, const char *value); long simple_strtol(const char *cp, char **endp, unsigned int base); int strcmp(const char *cs, const char *ct); -- 2.25.1
Can you please add to the env tests?
test/py/tests/test_env.py Regards, Simon
Usage examples
Notes
The high level problem I have with this patch is that we keep going back to "we really need to update to a modern hush (or other shell) rather than patching new features in to our ancient fork".
Yes it will be fine ! Does anybody have information about these plans ? but in any case my patch didn't broke compatibility like next patch
See also this old patch: https://patchwork.ozlabs.org/project/uboot/patch/1449255744-25787-1-git-send...
Can you please add to the env tests? please add function comment ...
tnx for suggestions ... i can make v2 variant for my patch , if no one is against this idea
Usage examples
Notes
-- Tom
Hi Art,
Yes see here: https://docs.google.com/document/d/1YBOMsbM19uSFyoJWnt7-PsOLBaevzQUgV-hiR88a...
We could ask for an update on progress.
I am not against it. But see Tom's comment.
Usage examples
Notes
It is orthogonal to the shell, so far as I can tell.
Art Nikpal
Artem Lapkin
