[U-Boot] [U-boot]: MMC: add sdhci generic framework
On.. drivers/mmc/sdhci.c + if (caps & SDHCI_CAN_DO_8BIT) + mmc->host_caps |= MMC_MODE_8BIT;
Here we are setting 8BIT bus width, if the sdhci capabilities register 18 bit is set. Does 18-bit is really denoted for 8-bit bus width, I cound't find it on spec, https://www.sdcard.org/developers/overview/host_controller/simple_spec/Simpl...
Due to this above error even my controller doesn't support 8-bit, it shows a 8-BIT supported.
Request your help, correct me I am wrong.
Thanks, Jagan.
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Jagannadha Sutradharudu Teki <jagannadha.sutradharudu-teki <at> xilinx.com> writes:
bit is set.
spec, https://www.sdcard.org/developers/overview/host_controller/simple_spec/Simpl ified_SD_Host_Controller_Spec.pdf
Dear Jagannadha Sutradharudu Teki,
The current u-boot SD/MMC driver supports the latest SD Specification. You should read version 3.0 of the specification.
a 8-BIT supported.
Thanks, Jagan.
All the best, Rommel
Hi Rommel,
Thanks for your information.
On Tue, May 21, 2013 at 4:20 AM, Rommel Custodio sessyargc+uboot@gmail.com wrote:
bit is set.
OK, i saw the spec thanks. I think we need to add the fix on sdhci, for backward compatibility. Any concerns.
Thanks, Jagan.
Jagan Teki
Rommel Custodio
