[U-Boot] [PATCH v2 0/13] Fixes on gdsys boards and some new functionality
Changes in v2: - make sha256 support optional - move ihs_i2c to drivers/i2c - split unrelated changes - use defines for I2C bus numbers
Dirk Eibach (13): board: controlcenterd: Fix pci access board: gdsys: Adapt sdhc_boot.c to mmc_get_env_addr API change board: controlcenterd: Use new API for setting i2c bus board: iocon: Support DisplayPort hardware i2c: IHS I2C master driver board: gdsys: Fix dlvision-10g I2C configuration board: gdsys: Increase iocon and dlv10g version string board: gdsys: Configure bridge on DP501 to support DDC only board: gdsys: Make gdsys osd hardware detection more robust board: gdsys: Enable scrambling on DP501 board: iocon: Modify iocon hardware startup board: gdsys: Remove commands to reduce footprint fit: make sha256 support optional
board/gdsys/405ep/iocon.c | 14 ++- board/gdsys/common/Makefile | 2 +- board/gdsys/common/dp501.c | 35 ++++-- board/gdsys/common/osd.c | 189 +++++++++++++++---------------- board/gdsys/p1022/controlcenterd-id.c | 13 ++- board/gdsys/p1022/controlcenterd.c | 6 +- board/gdsys/p1022/sdhc_boot.c | 2 +- drivers/i2c/Makefile | 1 + drivers/i2c/ihs_i2c.c | 203 ++++++++++++++++++++++++++++++++++ include/configs/controlcenterd.h | 7 +- include/configs/dlvision-10g.h | 29 ++++- include/configs/io.h | 8 +- include/configs/iocon.h | 35 ++++-- include/configs/neo.h | 9 +- include/gdsys_fpga.h | 25 ++--- include/image.h | 5 + 16 files changed, 434 insertions(+), 149 deletions(-) create mode 100644 drivers/i2c/ihs_i2c.c
readl was called with values instead of pointers to these values. Why this ever did work is a mystery...
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
Changes in v2: None
board/gdsys/p1022/controlcenterd.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/gdsys/p1022/controlcenterd.c b/board/gdsys/p1022/controlcenterd.c index 8ccd9ce..0a3517d 100644 --- a/board/gdsys/p1022/controlcenterd.c +++ b/board/gdsys/p1022/controlcenterd.c @@ -386,9 +386,9 @@ static void hydra_initialize(void) fpga = pci_map_bar(devno, PCI_BASE_ADDRESS_0, PCI_REGION_MEM);
- versions = readl(fpga->versions); - fpga_version = readl(fpga->fpga_version); - fpga_features = readl(fpga->fpga_features); + versions = readl(&fpga->versions); + fpga_version = readl(&fpga->fpga_version); + fpga_features = readl(&fpga->fpga_features);
hardware_version = versions & 0xf; feature_uart_channels = (fpga_features >> 6) & 0x1f;
Changes in v2: None
board/gdsys/p1022/sdhc_boot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gdsys/p1022/sdhc_boot.c b/board/gdsys/p1022/sdhc_boot.c index e432318..fd0e910 100644 --- a/board/gdsys/p1022/sdhc_boot.c +++ b/board/gdsys/p1022/sdhc_boot.c @@ -32,7 +32,7 @@ #define ESDHC_BOOT_IMAGE_SIZE 0x48 #define ESDHC_BOOT_IMAGE_ADDR 0x50
-int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) +int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) { u8 *tmp_buf; u32 blklen, code_offset, code_len, n;
Changes in v2: - use defines for I2C bus numbers
board/gdsys/p1022/controlcenterd-id.c | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/board/gdsys/p1022/controlcenterd-id.c b/board/gdsys/p1022/controlcenterd-id.c index 3fca3c5..419fc2e 100644 --- a/board/gdsys/p1022/controlcenterd-id.c +++ b/board/gdsys/p1022/controlcenterd-id.c @@ -86,6 +86,11 @@ enum { ESDHC_BOOT_IMAGE_ENTRY_OFS = 0x60, };
+enum { + I2C_SOC_0 = 0, + I2C_SOC_1 = 1, +}; + struct key_program { uint32_t magic; uint32_t code_crc; @@ -1156,7 +1161,7 @@ static void ccdm_hang(void) int j; #endif
- I2C_SET_BUS(0); + I2C_SET_BUS(I2C_SOC_0); pca9698_direction_output(0x22, 0, 0); /* Finder */ pca9698_direction_output(0x22, 4, 0); /* Status */
@@ -1189,8 +1194,8 @@ int startup_ccdm_id_module(void) int result = 0; unsigned int orig_i2c_bus;
- orig_i2c_bus = I2C_GET_BUS(); - I2C_SET_BUS(1); + orig_i2c_bus = i2c_get_bus_num(); + i2c_set_bus_num(I2C_SOC_1);
/* goto end; */
@@ -1216,7 +1221,7 @@ int startup_ccdm_id_module(void) failure: result = 1; end: - I2C_SET_BUS(orig_i2c_bus); + i2c_set_bus_num(orig_i2c_bus); if (result) ccdm_hang();
There is a new iocon hardware flavor, supporting DisplayPort finally.
Changes in v2: None
board/gdsys/405ep/iocon.c | 12 +++++ board/gdsys/common/Makefile | 2 +- board/gdsys/common/dp501.c | 33 +++++++++---- board/gdsys/common/osd.c | 112 ++++++++++++++++---------------------------- include/configs/iocon.h | 9 +++- 5 files changed, 83 insertions(+), 85 deletions(-)
diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 7a98e41..079dfb2 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -15,6 +15,7 @@ #include "405ep.h" #include <gdsys_fpga.h>
+#include "../common/dp501.h" #include "../common/osd.h" #include "../common/mclink.h"
@@ -98,6 +99,8 @@ enum { unsigned int mclink_fpgacount; struct ihs_fpga *fpga_ptr[] = CONFIG_SYS_FPGA_PTR;
+int dp501_i2c[] = CONFIG_SYS_DP501_I2C; + static int setup_88e1518(const char *bus, unsigned char addr);
int fpga_set_reg(u32 fpga, u16 *reg, off_t regoff, u16 data) @@ -371,9 +374,18 @@ int last_stage_init(void) u16 fpga_features; int feature_carrier_speed = fpga_features & (1<<4); bool ch0_rgmii2_present = false; + int old_bus = i2c_get_bus_num();
FPGA_GET_REG(0, fpga_features, &fpga_features);
+ /* Turn on Parade DP501 */ + pca9698_direction_output(0x20, 9, 1); + udelay(500000); + + i2c_set_bus_num(dp501_i2c[0]); + dp501_powerup(0x08); + i2c_set_bus_num(old_bus); + if (!legacy) ch0_rgmii2_present = !pca9698_get_value(0x20, 30);
diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index fb841e0..7f8b427 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -8,6 +8,6 @@ obj-$(CONFIG_SYS_FPGA_COMMON) += fpga.o obj-$(CONFIG_IO) += miiphybb.o obj-$(CONFIG_IO64) += miiphybb.o -obj-$(CONFIG_IOCON) += osd.o mclink.o +obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o obj-$(CONFIG_DLVISION_10G) += osd.o obj-$(CONFIG_CONTROLCENTERD) += dp501.o diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index 52f3ea1..e00e589 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -60,8 +60,31 @@ void dp501_powerup(u8 addr) i2c_reg_write(addr, 0x71, 0x20); /* Enable Aux burst write */ dp501_setbits(addr, 0x78, 0x30); /* Disable HPD2 IRQ */ dp501_clrbits(addr, 0x2f, 0x40); /* Link FIFO reset selection */ + +#ifdef CONFIG_SYS_DP501_VCAPCTRL0 + i2c_reg_write(addr, 0x24, CONFIG_SYS_DP501_VCAPCTRL0); +#else i2c_reg_write(addr, 0x24, 0xc0); /* SDR mode 0, ext. H/VSYNC */ +#endif + +#ifdef CONFIG_SYS_DP501_DIFFERENTIAL + i2c_reg_write(addr + 2, 0x24, 0x10); /* clock input differential */ + i2c_reg_write(addr + 2, 0x25, 0x04); + i2c_reg_write(addr + 2, 0x26, 0x10); +#else i2c_reg_write(addr + 2, 0x24, 0x02); /* clock input single ended */ +#endif + + i2c_reg_write(addr + 2, 0x00, 0x18); /* driving strength */ + i2c_reg_write(addr + 2, 0x03, 0x06); /* driving strength */ + i2c_reg_write(addr, 0x2c, 0x00); /* configure N value */ + i2c_reg_write(addr, 0x2d, 0x00); /* configure N value */ + i2c_reg_write(addr, 0x2e, 0x0c); /* configure N value */ + i2c_reg_write(addr, 0x76, 0xff); /* clear all interrupt */ + dp501_setbits(addr, 0x78, 0x03); /* clear all interrupt */ + i2c_reg_write(addr, 0x75, 0xf8); /* aux channel reset */ + i2c_reg_write(addr, 0x75, 0x00); /* clear aux channel reset */ + i2c_reg_write(addr, 0x87, 0x70); /* set retry counter as 7 */
if (dp501_detect_cable_adapter(addr)) { printf("DVI/HDMI cable adapter detected\n"); @@ -69,16 +92,6 @@ void dp501_powerup(u8 addr) dp501_clrbits(addr, 0x00, 0x08); /* DVI/HDMI HDCP operation */ } else { printf("no DVI/HDMI cable adapter detected\n"); - i2c_reg_write(addr + 2, 0x00, 0x18); /* driving strength */ - i2c_reg_write(addr + 2, 0x03, 0x06); /* driving strength */ - i2c_reg_write(addr, 0x2c, 0x00); /* configure N value */ - i2c_reg_write(addr, 0x2d, 0x00); /* configure N value */ - i2c_reg_write(addr, 0x2e, 0x0c); /* configure N value */ - i2c_reg_write(addr, 0x76, 0xff); /* clear all interrupt */ - dp501_setbits(addr, 0x78, 0x03); /* clear all interrupt */ - i2c_reg_write(addr, 0x75, 0xf8); /* aux channel reset */ - i2c_reg_write(addr, 0x75, 0x00); /* clear aux channel reset */ - i2c_reg_write(addr, 0x87, 0x70); /* set retry counter as 7 */ dp501_setbits(addr, 0x00, 0x08); /* for DP HDCP operation */
dp501_link_training(addr); diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index c49cd9a..a839a4e 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -58,45 +58,12 @@ unsigned int max_osd_screen = CONFIG_SYS_OSD_SCREENS - 1; int ch7301_i2c[] = CONFIG_SYS_CH7301_I2C; #endif
-#if defined(CONFIG_SYS_ICS8N3QV01) || defined(CONFIG_SYS_SIL1178) -static void fpga_iic_write(unsigned screen, u8 slave, u8 reg, u8 data) -{ - u16 val; - - do { - FPGA_GET_REG(screen, extended_interrupt, &val); - } while (val & (1 << 12)); - - FPGA_SET_REG(screen, i2c.write_mailbox_ext, reg | (data << 8)); - FPGA_SET_REG(screen, i2c.write_mailbox, 0xc400 | (slave << 1)); -} - -static u8 fpga_iic_read(unsigned screen, u8 slave, u8 reg) -{ - unsigned int ctr = 0; - u16 val; - - do { - FPGA_GET_REG(screen, extended_interrupt, &val); - } while (val & (1 << 12)); - - FPGA_SET_REG(screen, extended_interrupt, 1 << 14); - FPGA_SET_REG(screen, i2c.write_mailbox_ext, reg); - FPGA_SET_REG(screen, i2c.write_mailbox, 0xc000 | (slave << 1)); - - FPGA_GET_REG(screen, extended_interrupt, &val); - while (!(val & (1 << 14))) { - udelay(100000); - if (ctr++ > 5) { - printf("iic receive timeout\n"); - break; - } - FPGA_GET_REG(screen, extended_interrupt, &val); - } +#ifdef CONFIG_SYS_ICS8N3QV01 +int ics8n3qv01_i2c[] = CONFIG_SYS_ICS8N3QV01_I2C; +#endif
- FPGA_GET_REG(screen, i2c.read_mailbox_ext, &val); - return val >> 8; -} +#ifdef CONFIG_SYS_SIL1178 +int sil1178_i2c[] = CONFIG_SYS_SIL1178_I2C; #endif
#ifdef CONFIG_SYS_MPC92469AC @@ -153,7 +120,7 @@ static void mpc92469ac_set(unsigned screen, unsigned int fout)
-static unsigned int ics8n3qv01_get_fout_calc(unsigned screen, unsigned index) +static unsigned int ics8n3qv01_get_fout_calc(unsigned index) { unsigned long long n; unsigned long long mint; @@ -164,11 +131,11 @@ static unsigned int ics8n3qv01_get_fout_calc(unsigned screen, unsigned index) if (index > 3) return 0;
- reg_a = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 0 + index); - reg_b = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 4 + index); - reg_c = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 8 + index); - reg_d = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 12 + index); - reg_f = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 20 + index); + reg_a = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 0 + index); + reg_b = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 4 + index); + reg_c = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 8 + index); + reg_d = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 12 + index); + reg_f = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 20 + index);
mint = ((reg_a >> 1) & 0x1f) | (reg_f & 0x20); mfrac = ((reg_a & 0x01) << 17) | (reg_b << 9) | (reg_c << 1) @@ -216,7 +183,7 @@ static void ics8n3qv01_calc_parameters(unsigned int fout, *_n = n; }
-static void ics8n3qv01_set(unsigned screen, unsigned int fout) +static void ics8n3qv01_set(unsigned int fout) { unsigned int n; unsigned int mint; @@ -226,7 +193,7 @@ static void ics8n3qv01_set(unsigned screen, unsigned int fout) long long off_ppm; u8 reg0, reg4, reg8, reg12, reg18, reg20;
- fout_calc = ics8n3qv01_get_fout_calc(screen, 1); + fout_calc = ics8n3qv01_get_fout_calc(1); off_ppm = (fout_calc - ICS8N3QV01_F_DEFAULT_1) * 1000000 / ICS8N3QV01_F_DEFAULT_1; printf(" PLL is off by %lld ppm\n", off_ppm); @@ -234,28 +201,28 @@ static void ics8n3qv01_set(unsigned screen, unsigned int fout) / ICS8N3QV01_F_DEFAULT_1; ics8n3qv01_calc_parameters(fout_prog, &mint, &mfrac, &n);
- reg0 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 0) & 0xc0; + reg0 = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 0) & 0xc0; reg0 |= (mint & 0x1f) << 1; reg0 |= (mfrac >> 17) & 0x01; - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 0, reg0); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 0, reg0);
reg4 = mfrac >> 9; - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 4, reg4); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 4, reg4);
reg8 = mfrac >> 1; - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 8, reg8); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 8, reg8);
reg12 = mfrac << 7; reg12 |= n & 0x7f; - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 12, reg12); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 12, reg12);
- reg18 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 18) & 0x03; + reg18 = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 18) & 0x03; reg18 |= 0x20; - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 18, reg18); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 18, reg18);
- reg20 = fpga_iic_read(screen, ICS8N3QV01_I2C_ADDR, 20) & 0x1f; + reg20 = i2c_reg_read(ICS8N3QV01_I2C_ADDR, 20) & 0x1f; reg20 |= mint & (1 << 5); - fpga_iic_write(screen, ICS8N3QV01_I2C_ADDR, 20, reg20); + i2c_reg_write(ICS8N3QV01_I2C_ADDR, 20, reg20); } #endif
@@ -315,9 +282,7 @@ int osd_probe(unsigned screen) u16 version; u16 features; u8 value; -#ifdef CONFIG_SYS_CH7301 int old_bus = i2c_get_bus_num(); -#endif
FPGA_GET_REG(0, osd.version, &version); FPGA_GET_REG(0, osd.features, &features); @@ -345,7 +310,6 @@ int osd_probe(unsigned screen) i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); - i2c_set_bus_num(old_bus); #endif
#ifdef CONFIG_SYS_MPC92469AC @@ -353,29 +317,31 @@ int osd_probe(unsigned screen) #endif
#ifdef CONFIG_SYS_ICS8N3QV01 - ics8n3qv01_set(screen, PIXCLK_640_480_60); + i2c_set_bus_num(ics8n3qv01_i2c[screen]); + ics8n3qv01_set(PIXCLK_640_480_60); #endif
#ifdef CONFIG_SYS_SIL1178 - value = fpga_iic_read(screen, SIL1178_SLAVE_I2C_ADDRESS, 0x02); + i2c_set_bus_num(sil1178_i2c[screen]); + value = i2c_reg_read(SIL1178_SLAVE_I2C_ADDRESS, 0x02); if (value != 0x06) { - printf(" Probing CH7301 SIL1178, DEV_IDL %02x\n", value); + printf(" Probing SIL1178, DEV_IDL %02x\n", value); + i2c_set_bus_num(old_bus); return -1; } /* magic initialization sequence adapted from datasheet */ - fpga_iic_write(screen, SIL1178_SLAVE_I2C_ADDRESS, 0x08, 0x36); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x44); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x4c); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0e, 0x10); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0a, 0x80); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x09, 0x30); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0c, 0x89); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x0d, 0x60); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x36); - fpga_iic_write(screen, SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x37); + i2c_reg_write(SIL1178_SLAVE_I2C_ADDRESS, 0x08, 0x36); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x44); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x4c); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0e, 0x10); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0a, 0x80); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x09, 0x30); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0c, 0x89); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0d, 0x60); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x36); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x37); #endif
- FPGA_SET_REG(screen, videocontrol, 0x0002); FPGA_SET_REG(screen, osd.control, 0x0049);
FPGA_SET_REG(screen, osd.xy_size, ((32 - 1) << 8) | (16 - 1)); @@ -385,6 +351,8 @@ int osd_probe(unsigned screen) if (screen > max_osd_screen) max_osd_screen = screen;
+ i2c_set_bus_num(old_bus); + return 0; }
diff --git a/include/configs/iocon.h b/include/configs/iocon.h index f36c2a3..5636f38 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -121,7 +121,9 @@ #define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F
+#define CONFIG_SYS_ICS8N3QV01_I2C {1, 2, 3, 4} #define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} +#define CONFIG_SYS_DP501_I2C {1, 2, 3, 4}
#ifndef __ASSEMBLY__ void fpga_gpio_set(unsigned int bus, int pin); @@ -146,6 +148,8 @@ int fpga_gpio_get(unsigned int bus, int pin); fpga_gpio_set(I2C_ADAP_HWNR, 0x0020); \ else \ fpga_gpio_clear(I2C_ADAP_HWNR, 0x0020); \ + while (!!fpga_gpio_get(I2C_ADAP_HWNR, 0x0020) != !!bit) \ + ; \ } while (0) #define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */
@@ -153,7 +157,6 @@ int fpga_gpio_get(unsigned int bus, int pin); * OSD hardware */ #define CONFIG_SYS_MPC92469AC -#define CONFIG_SYS_CH7301
/* * FLASH organization @@ -282,9 +285,11 @@ int fpga_gpio_get(unsigned int bus, int pin); /* * OSD Setup */ +#define CONFIG_SYS_ICS8N3QV01 #define CONFIG_SYS_MPC92469AC -#define CONFIG_SYS_CH7301 #define CONFIG_SYS_OSD_SCREENS 1 +#define CONFIG_SYS_DP501_DIFFERENTIAL +#define CONFIG_SYS_DP501_VCAPCTRL0 0x01 /* DDR mode 0, DE for H/VSYNC */
#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ #define CONFIG_BITBANGMII_MULTI
IHS I2C master support was merely a hack in the osd driver. Now it is a proper u-boot I2C framework driver, supporting the v2.00 master features.
Changes in v2: - move ihs_i2c to drivers/i2c - split unrelated changes
drivers/i2c/Makefile | 1 + drivers/i2c/ihs_i2c.c | 204 +++++++++++++++++++++++++++++++++++++++++ include/configs/dlvision-10g.h | 11 +++ include/configs/iocon.h | 23 ++++- include/gdsys_fpga.h | 25 +++-- 5 files changed, 246 insertions(+), 18 deletions(-) create mode 100644 drivers/i2c/ihs_i2c.c
diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index e33586d..96bd45d 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -18,6 +18,7 @@ obj-$(CONFIG_SYS_I2C) += i2c_core.o obj-$(CONFIG_SYS_I2C_DAVINCI) += davinci_i2c.o obj-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o obj-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o +obj-$(CONFIG_SYS_I2C_IHS) += ihs_i2c.o obj-$(CONFIG_SYS_I2C_KONA) += kona_i2c.o obj-$(CONFIG_SYS_I2C_MXC) += mxc_i2c.o obj-$(CONFIG_SYS_I2C_OMAP24XX) += omap24xx_i2c.o diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c new file mode 100644 index 0000000..ecc5856 --- /dev/null +++ b/drivers/i2c/ihs_i2c.c @@ -0,0 +1,204 @@ +/* + * (C) Copyright 2013 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <gdsys_fpga.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum { + I2CINT_ERROR_EV = 1 << 13, + I2CINT_TRANSMIT_EV = 1 << 14, + I2CINT_RECEIVE_EV = 1 << 15, +}; + +enum { + I2CMB_WRITE = 1 << 10, + I2CMB_2BYTE = 1 << 11, + I2CMB_HOLD_BUS = 1 << 13, + I2CMB_NATIVE = 2 << 14, +}; + +static int wait_for_int(bool read) +{ + u16 val; + unsigned int ctr = 0; + + FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + while (!(val & (I2CINT_ERROR_EV + | (read ? I2CINT_RECEIVE_EV : I2CINT_TRANSMIT_EV)))) { + udelay(10); + if (ctr++ > 5000) { + printf("I2C timeout\n"); + return 1; + } + FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + } + + return (val & I2CINT_ERROR_EV) ? 1 : 0; +} + +static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read, + bool is_last) +{ + u16 val; + + FPGA_SET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, I2CINT_ERROR_EV + | I2CINT_RECEIVE_EV | I2CINT_TRANSMIT_EV); + FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + + if (!read && len) { + val = buffer[0]; + + if (len > 1) + val |= buffer[1] << 8; + FPGA_SET_REG(I2C_ADAP_HWNR, i2c.write_mailbox_ext, val); + } + + FPGA_SET_REG(I2C_ADAP_HWNR, i2c.write_mailbox, + I2CMB_NATIVE + | (read ? 0 : I2CMB_WRITE) + | (chip << 1) + | ((len > 1) ? I2CMB_2BYTE : 0) + | (is_last ? 0 : I2CMB_HOLD_BUS)); + + if (wait_for_int(read)) + return 1; + + if (read) { + FPGA_GET_REG(I2C_ADAP_HWNR, i2c.read_mailbox_ext, &val); + buffer[0] = val & 0xff; + if (len > 1) + buffer[1] = val >> 8; + } + + return 0; +} + +static int ihs_i2c_address(uchar chip, uint addr, int alen, bool hold_bus) +{ + int shift = (alen-1) * 8; + + while (alen) { + int transfer = MIN(alen, 2); + uchar buf[2]; + bool is_last = alen <= transfer; + + buf[0] = addr >> shift; + if (alen > 1) + buf[1] = addr >> (shift - 8); + + if (ihs_i2c_transfer(chip, buf, transfer, false, + hold_bus ? false : is_last)) + return 1; + + shift -= 16; + alen -= transfer; + } + + return 0; +} + +static int ihs_i2c_access(struct i2c_adapter *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len, bool read) +{ + if (len <= 0) + return 1; + + if (ihs_i2c_address(chip, addr, alen, !read)) + return 1; + + while (len) { + int transfer = MIN(len, 2); + + if (ihs_i2c_transfer(chip, buffer, transfer, read, + len <= transfer)) + return 1; + + buffer += transfer; + addr += transfer; + len -= transfer; + } + + return 0; +} + + +static void ihs_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) +{ +#ifdef CONFIG_SYS_I2C_INIT_BOARD + /* + * Call board specific i2c bus reset routine before accessing the + * environment, which might be in a chip on that bus. For details + * about this problem see doc/I2C_Edge_Conditions. + */ + i2c_init_board(); +#endif +} + +static int ihs_i2c_probe(struct i2c_adapter *adap, uchar chip) +{ + uchar buffer[2]; + + if (ihs_i2c_transfer(chip, buffer, 0, true, true)) + return 1; + + return 0; +} + +static int ihs_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +{ + return ihs_i2c_access(adap, chip, addr, alen, buffer, len, true); +} + +static int ihs_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, + int alen, uchar *buffer, int len) +{ + return ihs_i2c_access(adap, chip, addr, alen, buffer, len, false); +} + +static unsigned int ihs_i2c_set_bus_speed(struct i2c_adapter *adap, + unsigned int speed) +{ + if (speed != adap->speed) + return 1; + return speed; +} + +/* + * Register IHS i2c adapters + */ +#ifdef CONFIG_SYS_I2C_IHS_CH0 +U_BOOT_I2C_ADAP_COMPLETE(ihs0, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_0, + CONFIG_SYS_I2C_IHS_SLAVE_0, 0) +#endif +#ifdef CONFIG_SYS_I2C_IHS_CH1 +U_BOOT_I2C_ADAP_COMPLETE(ihs1, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_1, + CONFIG_SYS_I2C_IHS_SLAVE_1, 1) +#endif +#ifdef CONFIG_SYS_I2C_IHS_CH2 +U_BOOT_I2C_ADAP_COMPLETE(ihs2, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_2, + CONFIG_SYS_I2C_IHS_SLAVE_2, 2) +#endif +#ifdef CONFIG_SYS_I2C_IHS_CH3 +U_BOOT_I2C_ADAP_COMPLETE(ihs3, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_3, + CONFIG_SYS_I2C_IHS_SLAVE_3, 3) +#endif diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 7877897..05a97bf 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -99,7 +99,18 @@ */ #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 100000
+#define CONFIG_SYS_I2C_IHS +#define CONFIG_SYS_I2C_IHS_CH0 +#define CONFIG_SYS_I2C_IHS_SPEED_0 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0 0x7F +#define CONFIG_SYS_I2C_IHS_CH1 +#define CONFIG_SYS_I2C_IHS_SPEED_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1 0x7F + +#define CONFIG_SYS_SPD_BUS_NUM 2 + /* Temp sensor/hwmon/dtt */ +#define CONFIG_SYS_DTT_BUS_NUM 2 #define CONFIG_DTT_LM63 1 /* National LM63 */ #define CONFIG_DTT_SENSORS { 0x4c, 0x4e, 0x18 } /* Sensor addresses */ #define CONFIG_DTT_PWM_LOOKUPTABLE \ diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 5636f38..36b4b55 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -99,12 +99,27 @@ #define CONFIG_SYS_I2C_PPC4XX_CH0 #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 #define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F +#define CONFIG_SYS_I2C_IHS
#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_SPD_BUS_NUM 4
#define CONFIG_PCA953X /* NXP PCA9554 */ #define CONFIG_PCA9698 /* NXP PCA9698 */
+#define CONFIG_SYS_I2C_IHS_CH0 +#define CONFIG_SYS_I2C_IHS_SPEED_0 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0 0x7F +#define CONFIG_SYS_I2C_IHS_CH1 +#define CONFIG_SYS_I2C_IHS_SPEED_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH2 +#define CONFIG_SYS_I2C_IHS_SPEED_2 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_2 0x7F +#define CONFIG_SYS_I2C_IHS_CH3 +#define CONFIG_SYS_I2C_IHS_SPEED_3 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_3 0x7F + /* * Software (bit-bang) I2C driver configuration */ @@ -121,9 +136,9 @@ #define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F
-#define CONFIG_SYS_ICS8N3QV01_I2C {1, 2, 3, 4} -#define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} -#define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} +#define CONFIG_SYS_CH7301_I2C {5, 6, 7, 8} +#define CONFIG_SYS_DP501_I2C {0, 1, 2, 3}
#ifndef __ASSEMBLY__ void fpga_gpio_set(unsigned int bus, int pin); @@ -148,8 +163,6 @@ int fpga_gpio_get(unsigned int bus, int pin); fpga_gpio_set(I2C_ADAP_HWNR, 0x0020); \ else \ fpga_gpio_clear(I2C_ADAP_HWNR, 0x0020); \ - while (!!fpga_gpio_get(I2C_ADAP_HWNR, 0x0020) != !!bit) \ - ; \ } while (0) #define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */
diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 85ddbcb..276a01e 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -43,10 +43,12 @@ struct ihs_gpio { };
struct ihs_i2c { - u16 write_mailbox; + u16 interrupt_status; + u16 interrupt_enable; u16 write_mailbox_ext; - u16 read_mailbox; + u16 write_mailbox; u16 read_mailbox_ext; + u16 read_mailbox; };
struct ihs_osd { @@ -84,7 +86,6 @@ struct ihs_fpga { #endif
#ifdef CONFIG_IO64 - struct ihs_fpga_channel { u16 status_int; u16 config_int; @@ -121,9 +122,9 @@ struct ihs_fpga { u16 reserved_0[6]; /* 0x0008 */ struct ihs_gpio gpio; /* 0x0014 */ u16 mpc3w_control; /* 0x001a */ - u16 reserved_1[19]; /* 0x001c */ - u16 videocontrol; /* 0x0042 */ - u16 reserved_2[14]; /* 0x0044 */ + u16 reserved_1[18]; /* 0x001c */ + struct ihs_i2c i2c; /* 0x0040 */ + u16 reserved_2[10]; /* 0x004c */ u16 mc_int; /* 0x0060 */ u16 mc_int_en; /* 0x0062 */ u16 mc_status; /* 0x0064 */ @@ -150,15 +151,13 @@ struct ihs_fpga { u16 fpga_features; /* 0x0006 */ u16 reserved_0[10]; /* 0x0008 */ u16 extended_interrupt; /* 0x001c */ - u16 reserved_1[9]; /* 0x001e */ - struct ihs_i2c i2c; /* 0x0030 */ - u16 reserved_2[16]; /* 0x0038 */ + u16 reserved_1[29]; /* 0x001e */ u16 mpc3w_control; /* 0x0058 */ - u16 reserved_3[34]; /* 0x005a */ - u16 videocontrol; /* 0x009e */ - u16 reserved_4[176]; /* 0x00a0 */ + u16 reserved_2[3]; /* 0x005a */ + struct ihs_i2c i2c; /* 0x0060 */ + u16 reserved_3[205]; /* 0x0066 */ struct ihs_osd osd; /* 0x0200 */ - u16 reserved_5[761]; /* 0x020e */ + u16 reserved_4[761]; /* 0x020e */ u16 videomem[31736]; /* 0x0800 */ }; #endif
Hello Dirk,
Am 02.07.2014 09:31, schrieb dirk.eibach@gdsys.cc:
Signed-off-by: Dirk Eibachdirk.eibach@gdsys.cc
Changes in v2:
Please add a small entry in README, which describes your new config defines, thanks!
Beside of this, your driver looks Ok to me, thanks!
bye, Heiko
PPC4xx config options were not complete. ICS8N3QV01 and SIL1178 needed some more configuration.
Changes in v2: None
include/configs/dlvision-10g.h | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 05a97bf..16895bf 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -97,7 +97,10 @@ /* * I2C stuff */ +#define CONFIG_SYS_I2C_PPC4XX +#define CONFIG_SYS_I2C_PPC4XX_CH0 #define CONFIG_SYS_I2C_PPC4XX_SPEED_0 100000 +#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F
#define CONFIG_SYS_I2C_IHS #define CONFIG_SYS_I2C_IHS_CH0 @@ -118,6 +121,11 @@ { 54, 27 }, { 56, 31 }, { 58, 36 }, { 60, 40 } } #define CONFIG_DTT_TACH_LIMIT 0xa10
+#define CONFIG_SYS_ICS8N3QV01 +#define CONFIG_SYS_ICS8N3QV01_I2C {0, 1} +#define CONFIG_SYS_SIL1178 +#define CONFIG_SYS_SIL1178_I2C {0, 1} + /* EBC peripherals */
#define CONFIG_SYS_FLASH_BASE 0xFC000000 @@ -317,9 +325,7 @@ /* * OSD Setup */ -#define CONFIG_SYS_ICS8N3QV01 #define CONFIG_SYS_MPC92469AC -#define CONFIG_SYS_SIL1178 #define CONFIG_SYS_OSD_SCREENS CONFIG_SYS_FPGA_COUNT
#endif /* __CONFIG_H */
Changes in v2: None
include/configs/dlvision-10g.h | 2 +- include/configs/iocon.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 16895bf..c2289ce 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -17,7 +17,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME dlvsion-10g -#define CONFIG_IDENT_STRING " dlvision-10g 0.05" +#define CONFIG_IDENT_STRING " dlvision-10g 0.06" #include "amcc-common.h"
#define CONFIG_BOARD_EARLY_INIT_F diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 36b4b55..1aebab3 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -17,7 +17,7 @@ * Include common defines/options for all AMCC eval boards */ #define CONFIG_HOSTNAME iocon -#define CONFIG_IDENT_STRING " iocon 0.05" +#define CONFIG_IDENT_STRING " iocon 0.06" #include "amcc-common.h"
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts.
Changes in v2: None
board/gdsys/common/dp501.c | 1 + include/configs/controlcenterd.h | 7 ++++--- 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index e00e589..7958bae 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -54,6 +54,7 @@ static void dp501_link_training(u8 addr) void dp501_powerup(u8 addr) { dp501_clrbits(addr, 0x0a, 0x30); /* power on encoder */ + dp501_setbits(addr, 0x0a, 0x0e); /* block HDCP and MCCS on I2C bride*/ i2c_reg_write(addr, 0x27, 0x30); /* Hardware auto detect DVO timing */ dp501_setbits(addr, 0x72, 0x80); /* DPCD read enable */ dp501_setbits(addr, 0x30, 0x20); /* RS polynomial select */ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 868813f..ec3145f 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -199,9 +199,10 @@ #define CONFIG_SYS_FSL_I2C2_SPEED 400000 #define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 -/* Probing DP501 I2C-Bridge will hang */ -#define CONFIG_SYS_I2C_NOPROBES { {0, 0x30}, {0, 0x37}, {0, 0x3a}, \ - {0, 0x3b}, {0, 0x50} } + +#ifndef CONFIG_TRAILBLAZER +#define CONFIG_CMD_I2C +#endif
Changes in v2: None
board/gdsys/405ep/iocon.c | 17 ++----- board/gdsys/common/osd.c | 113 +++++++++++++++++++++++++++-------------- drivers/i2c/ihs_i2c.c | 1 - include/configs/dlvision-10g.h | 2 - include/configs/iocon.h | 6 --- 5 files changed, 79 insertions(+), 60 deletions(-)
diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 079dfb2..6ae15e1 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -15,7 +15,6 @@ #include "405ep.h" #include <gdsys_fpga.h>
-#include "../common/dp501.h" #include "../common/osd.h" #include "../common/mclink.h"
@@ -99,8 +98,6 @@ enum { unsigned int mclink_fpgacount; struct ihs_fpga *fpga_ptr[] = CONFIG_SYS_FPGA_PTR;
-int dp501_i2c[] = CONFIG_SYS_DP501_I2C; - static int setup_88e1518(const char *bus, unsigned char addr);
int fpga_set_reg(u32 fpga, u16 *reg, off_t regoff, u16 data) @@ -374,20 +371,16 @@ int last_stage_init(void) u16 fpga_features; int feature_carrier_speed = fpga_features & (1<<4); bool ch0_rgmii2_present = false; - int old_bus = i2c_get_bus_num();
- /* Turn on Parade DP501 */ - pca9698_direction_output(0x20, 9, 1); - udelay(500000); - - i2c_set_bus_num(dp501_i2c[0]); - dp501_powerup(0x08); - i2c_set_bus_num(old_bus); + if (!legacy) { + /* Turn on Parade DP501 */ + pca9698_direction_output(0x20, 9, 1); + udelay(500000);
- if (!legacy) ch0_rgmii2_present = !pca9698_get_value(0x20, 30); + }
print_fpga_info(0, ch0_rgmii2_present); osd_probe(0); diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index a839a4e..1c765e4 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -9,6 +9,7 @@ #include <i2c.h> #include <malloc.h>
+#include "dp501.h" #include <gdsys_fpga.h>
#define CH7301_I2C_ADDR 0x75 @@ -24,6 +25,8 @@ #define SIL1178_MASTER_I2C_ADDRESS 0x38 #define SIL1178_SLAVE_I2C_ADDRESS 0x39
+#define DP501_I2C_ADDR 0x08 + #define PIXCLK_640_480_60 25180000
enum { @@ -54,18 +57,23 @@ u16 *buf;
-#ifdef CONFIG_SYS_CH7301 -int ch7301_i2c[] = CONFIG_SYS_CH7301_I2C; +#ifdef CONFIG_SYS_ICS8N3QV01_I2C +int ics8n3qv01_i2c[] = CONFIG_SYS_ICS8N3QV01_I2C; #endif
-#ifdef CONFIG_SYS_ICS8N3QV01 -int ics8n3qv01_i2c[] = CONFIG_SYS_ICS8N3QV01_I2C; +#ifdef CONFIG_SYS_CH7301_I2C +int ch7301_i2c[] = CONFIG_SYS_CH7301_I2C; #endif
-#ifdef CONFIG_SYS_SIL1178 +#ifdef CONFIG_SYS_SIL1178_I2C int sil1178_i2c[] = CONFIG_SYS_SIL1178_I2C; #endif
+#ifdef CONFIG_SYS_DP501_I2C +int dp501_i2c[] = CONFIG_SYS_DP501_I2C; +#endif + + #ifdef CONFIG_SYS_MPC92469AC static void mpc92469ac_calc_parameters(unsigned int fout, unsigned int *post_div, unsigned int *feedback_div) @@ -118,7 +126,7 @@ static void mpc92469ac_set(unsigned screen, unsigned int fout) } #endif
-#ifdef CONFIG_SYS_ICS8N3QV01 +#ifdef CONFIG_SYS_ICS8N3QV01_I2C
static unsigned int ics8n3qv01_get_fout_calc(unsigned index) { @@ -283,6 +291,8 @@ int osd_probe(unsigned screen) u16 features; u8 value; int old_bus = i2c_get_bus_num(); + bool pixclock_present = false; + bool output_driver_present = false;
FPGA_GET_REG(0, osd.version, &version); FPGA_GET_REG(0, osd.features, &features); @@ -297,51 +307,76 @@ int osd_probe(unsigned screen) printf("OSD%d: Digital-OSD version %01d.%02d, %d" "x%d characters\n", screen, version/100, version%100, base_width, base_height);
-#ifdef CONFIG_SYS_CH7301 - i2c_set_bus_num(ch7301_i2c[screen]); - value = i2c_reg_read(CH7301_I2C_ADDR, CH7301_DID); - if (value != 0x17) { - printf(" Probing CH7301 failed, DID %02x\n", value); - i2c_set_bus_num(old_bus); - return -1; - } - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPCP, 0x08); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPD, 0x16); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); -#endif + /* setup pixclock */
#ifdef CONFIG_SYS_MPC92469AC + pixclock_present = true; mpc92469ac_set(screen, PIXCLK_640_480_60); #endif
-#ifdef CONFIG_SYS_ICS8N3QV01 +#ifdef CONFIG_SYS_ICS8N3QV01_I2C i2c_set_bus_num(ics8n3qv01_i2c[screen]); - ics8n3qv01_set(PIXCLK_640_480_60); + if (!i2c_probe(ICS8N3QV01_I2C_ADDR)) { + ics8n3qv01_set(PIXCLK_640_480_60); + pixclock_present = true; + } #endif
-#ifdef CONFIG_SYS_SIL1178 + if (!pixclock_present) + printf(" no pixelclock found\n"); + + /* setup output driver */ + +#ifdef CONFIG_SYS_CH7301_I2C + i2c_set_bus_num(ch7301_i2c[screen]); + if (!i2c_probe(CH7301_I2C_ADDR)) { + value = i2c_reg_read(CH7301_I2C_ADDR, CH7301_DID); + if (value == 0x17) { + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPCP, 0x08); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPD, 0x16); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); + output_driver_present = true; + } + } +#endif + +#ifdef CONFIG_SYS_SIL1178_I2C i2c_set_bus_num(sil1178_i2c[screen]); - value = i2c_reg_read(SIL1178_SLAVE_I2C_ADDRESS, 0x02); - if (value != 0x06) { - printf(" Probing SIL1178, DEV_IDL %02x\n", value); - i2c_set_bus_num(old_bus); - return -1; + if (!i2c_probe(SIL1178_SLAVE_I2C_ADDRESS)) { + value = i2c_reg_read(SIL1178_SLAVE_I2C_ADDRESS, 0x02); + if (value == 0x06) { + /* + * magic initialization sequence, + * adapted from datasheet + */ + i2c_reg_write(SIL1178_SLAVE_I2C_ADDRESS, 0x08, 0x36); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x44); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x4c); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0e, 0x10); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0a, 0x80); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x09, 0x30); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0c, 0x89); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0d, 0x60); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x36); + i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x37); + output_driver_present = true; + } + } +#endif + +#ifdef CONFIG_SYS_DP501_I2C + i2c_set_bus_num(dp501_i2c[screen]); + if (!i2c_probe(DP501_I2C_ADDR)) { + dp501_powerup(DP501_I2C_ADDR); + output_driver_present = true; } - /* magic initialization sequence adapted from datasheet */ - i2c_reg_write(SIL1178_SLAVE_I2C_ADDRESS, 0x08, 0x36); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x44); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0f, 0x4c); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0e, 0x10); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0a, 0x80); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x09, 0x30); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0c, 0x89); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x0d, 0x60); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x36); - i2c_reg_write(SIL1178_MASTER_I2C_ADDRESS, 0x08, 0x37); #endif
+ if (!output_driver_present) + printf(" no output driver found\n"); + FPGA_SET_REG(screen, osd.control, 0x0049);
FPGA_SET_REG(screen, osd.xy_size, ((32 - 1) << 8) | (16 - 1)); diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index ecc5856..fe66ce2 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -34,7 +34,6 @@ static int wait_for_int(bool read) | (read ? I2CINT_RECEIVE_EV : I2CINT_TRANSMIT_EV)))) { udelay(10); if (ctr++ > 5000) { - printf("I2C timeout\n"); return 1; } FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index c2289ce..08ab5c3 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -121,9 +121,7 @@ { 54, 27 }, { 56, 31 }, { 58, 36 }, { 60, 40 } } #define CONFIG_DTT_TACH_LIMIT 0xa10
-#define CONFIG_SYS_ICS8N3QV01 #define CONFIG_SYS_ICS8N3QV01_I2C {0, 1} -#define CONFIG_SYS_SIL1178 #define CONFIG_SYS_SIL1178_I2C {0, 1}
/* EBC peripherals */ diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 1aebab3..1836d12 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -167,11 +167,6 @@ int fpga_gpio_get(unsigned int bus, int pin); #define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */
/* - * OSD hardware - */ -#define CONFIG_SYS_MPC92469AC - -/* * FLASH organization */ #define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ @@ -298,7 +293,6 @@ int fpga_gpio_get(unsigned int bus, int pin); /* * OSD Setup */ -#define CONFIG_SYS_ICS8N3QV01 #define CONFIG_SYS_MPC92469AC #define CONFIG_SYS_OSD_SCREENS 1 #define CONFIG_SYS_DP501_DIFFERENTIAL
For proper displayport performance, scrambling has to be enabled, but is turned off on DP501 by default.
Changes in v2: None
board/gdsys/common/dp501.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index 7958bae..7eb15ed 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -61,6 +61,7 @@ void dp501_powerup(u8 addr) i2c_reg_write(addr, 0x71, 0x20); /* Enable Aux burst write */ dp501_setbits(addr, 0x78, 0x30); /* Disable HPD2 IRQ */ dp501_clrbits(addr, 0x2f, 0x40); /* Link FIFO reset selection */ + dp501_clrbits(addr, 0x60, 0x20); /* Enable scrambling */
#ifdef CONFIG_SYS_DP501_VCAPCTRL0 i2c_reg_write(addr, 0x24, CONFIG_SYS_DP501_VCAPCTRL0);
To avoid peer "ChReceivePathStatus"-messages on iocon startup, initialize PHYs as soon as possible.
Changes in v2: None
board/gdsys/405ep/iocon.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 6ae15e1..1bac970 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -377,14 +377,10 @@ int last_stage_init(void) if (!legacy) { /* Turn on Parade DP501 */ pca9698_direction_output(0x20, 9, 1); - udelay(500000);
ch0_rgmii2_present = !pca9698_get_value(0x20, 30); }
- print_fpga_info(0, ch0_rgmii2_present); - osd_probe(0); - /* wait for FPGA done */ for (k = 0; k < ARRAY_SIZE(mclink_controllers); ++k) { unsigned int ctr = 0; @@ -413,13 +409,16 @@ int last_stage_init(void) } }
- /* wait for slave-PLLs to be up and running */ + /* give slave-PLLs and Parade DP501 some time to be up and running */ udelay(500000);
mclink_fpgacount = CONFIG_SYS_MCLINK_MAX; slaves = mclink_probe(); mclink_fpgacount = 0;
+ print_fpga_info(0, ch0_rgmii2_present); + osd_probe(0); + if (slaves <= 0) return 0;
Commit "2842c1c fit: add sha256 support" badly increased memory footprint, so some of our boards did not build anymore. Since monitor base must not be changed I removed some commands to save memory.
Maybe making sha256 optional for fit would be an option for the future since it really has some beefy footprint.
Changes in v2: None
include/configs/dlvision-10g.h | 7 ++++++- include/configs/io.h | 7 ++++++- include/configs/iocon.h | 4 ++++ include/configs/neo.h | 8 ++++++-- 4 files changed, 22 insertions(+), 4 deletions(-)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 08ab5c3..2567a22 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -64,9 +64,14 @@ /* * Commands additional to the ones defined in amcc-common.h */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DTT +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_NFS
/* * SDRAM configuration (please see cpu/ppc/sdram.[ch]) diff --git a/include/configs/io.h b/include/configs/io.h index 9da6cc6..649c0fb 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -64,9 +64,14 @@ /* * Commands additional to the ones defined in amcc-common.h */ -#define CONFIG_CMD_CACHE #define CONFIG_CMD_DTT +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_NFS
/* * SDRAM configuration (please see cpu/ppc/sdram.[ch]) diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 1836d12..35ba1bd 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -64,6 +64,10 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_FPGAD #undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_NFS
/* * SDRAM configuration (please see cpu/ppc/sdram.[ch]) diff --git a/include/configs/neo.h b/include/configs/neo.h index d549985..75dc862 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -61,10 +61,14 @@ /* * Commands additional to the ones defined in amcc-common.h */ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DATE #define CONFIG_CMD_DTT +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_ELF +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_IRQ +#undef CONFIG_CMD_NFS
sha256 has some beefy memory footprint. Make it optional for constrained systems.
include/configs/dlvision-10g.h | 1 + include/configs/io.h | 1 + include/configs/iocon.h | 1 + include/configs/neo.h | 1 + include/image.h | 5 +++++ 5 files changed, 9 insertions(+)
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 2567a22..6153a40 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -40,6 +40,7 @@ /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ +#define CONFIG_FIT_DISABLE_SHA256
#define CONFIG_ENV_IS_IN_FLASH /* use FLASH for environment vars */
diff --git a/include/configs/io.h b/include/configs/io.h index 649c0fb..8e32c25 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -40,6 +40,7 @@ /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ +#define CONFIG_FIT_DISABLE_SHA256
diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 35ba1bd..ae05bcb 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -39,6 +39,7 @@ /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ +#define CONFIG_FIT_DISABLE_SHA256
diff --git a/include/configs/neo.h b/include/configs/neo.h index 75dc862..4937730 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -37,6 +37,7 @@ /* new uImage format support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ +#define CONFIG_FIT_DISABLE_SHA256
diff --git a/include/image.h b/include/image.h index b71e4ba..61d5885 100644 --- a/include/image.h +++ b/include/image.h @@ -72,6 +72,11 @@ struct lmb; # define IMAGE_ENABLE_SHA256 1 # endif
+#ifdef CONFIG_FIT_DISABLE_SHA256 +#undef CONFIG_SHA256 +#undef IMAGE_ENABLE_SHA256 +#endif + #ifndef IMAGE_ENABLE_CRC32 #define IMAGE_ENABLE_CRC32 0 #endif
Heiko Schocher
