[U-Boot] [PATCH 1/3] Revert "ARM: imx6: Disable DDR DRAM calibration DHCOM i.MX6 PDK"
This reverts commit a637fe6f27fd4c19ef9f43a5f871c244581422ac.
The DDR DRAM calibration was enhanced by write leveling correction code. It can be used with T-topology now.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.de --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index dffe4eb..beda389 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -384,6 +384,10 @@ void board_init_f(ulong dummy) &dhcom6sdl_grp_ioregs); mx6_dram_cfg(&dhcom_ddr_info, &dhcom_mmdc_calib, &dhcom_mem_ddr);
+ /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_dqs_calibration(&dhcom_ddr_info); + /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Preperation for conditional DDR3 initialization based on GPIO codes.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.de --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 40 +++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index beda389..eafb86d 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -208,6 +208,45 @@ static void setup_iomux_boardid(void) SETUP_IOMUX_PADS(hwcode_pads); }
+/* DDR Code */ +static iomux_v3_cfg_t const ddrcode_pads[] = { + IOMUX_PADS(PAD_EIM_A16__GPIO2_IO22 | MUX_PAD_CTRL(GPIO_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A17__GPIO2_IO21 | MUX_PAD_CTRL(GPIO_PAD_CTRL)), +}; + +static void setup_iomux_ddrcode(void) +{ + /* ddr code pins */ + SETUP_IOMUX_PADS(ddrcode_pads); +} + +enum dhcom_ddr3_code { + DH_DDR3_SIZE_256MIB = 0x00, + DH_DDR3_SIZE_512MIB = 0x01, + DH_DDR3_SIZE_1GIB = 0x02, + DH_DDR3_SIZE_2GIB = 0x03 +}; + +#define DDR3_CODE_BIT_0 IMX_GPIO_NR(2, 22) +#define DDR3_CODE_BIT_1 IMX_GPIO_NR(2, 21) + +enum dhcom_ddr3_code dhcom_get_ddr3_code(void) +{ + enum dhcom_ddr3_code ddr3_code; + + gpio_request(DDR3_CODE_BIT_0, "DDR3_CODE_BIT_0"); + gpio_request(DDR3_CODE_BIT_1, "DDR3_CODE_BIT_1"); + + gpio_direction_input(DDR3_CODE_BIT_0); + gpio_direction_input(DDR3_CODE_BIT_1); + + /* 256MB = 0b00; 512MB = 0b01; 1GB = 0b10; 2GB = 0b11 */ + ddr3_code = (!!gpio_get_value(DDR3_CODE_BIT_1) << 1) + | (!!gpio_get_value(DDR3_CODE_BIT_0)); + + return ddr3_code; +} + /* GPIO */ static iomux_v3_cfg_t const gpio_pads[] = { IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(GPIO_PAD_CTRL)), @@ -365,6 +404,7 @@ void board_init_f(ulong dummy) timer_init();
setup_iomux_boardid(); + setup_iomux_ddrcode(); setup_iomux_gpio(); setup_iomux_enet(); setup_iomux_sd();
- IOMUX_PADS(PAD_EIM_A16__GPIO2_IO22 | MUX_PAD_CTRL(GPIO_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A17__GPIO2_IO21 | MUX_PAD_CTRL(GPIO_PAD_CTRL)),
- /* ddr code pins */
- SETUP_IOMUX_PADS(ddrcode_pads);
- DH_DDR3_SIZE_256MIB = 0x00,
- DH_DDR3_SIZE_512MIB = 0x01,
- DH_DDR3_SIZE_1GIB = 0x02,
- DH_DDR3_SIZE_2GIB = 0x03
- enum dhcom_ddr3_code ddr3_code;
- gpio_request(DDR3_CODE_BIT_0, "DDR3_CODE_BIT_0");
- gpio_request(DDR3_CODE_BIT_1, "DDR3_CODE_BIT_1");
- gpio_direction_input(DDR3_CODE_BIT_0);
- gpio_direction_input(DDR3_CODE_BIT_1);
- /* 256MB = 0b00; 512MB = 0b01; 1GB = 0b10; 2GB = 0b11 */
- ddr3_code = (!!gpio_get_value(DDR3_CODE_BIT_1) << 1)
- return ddr3_code;
- setup_iomux_ddrcode(); setup_iomux_gpio(); setup_iomux_enet(); setup_iomux_sd();
Best regards, Stefano Babic
Support 1GIB + 2GIB DDR3 with 64bit bus width and 512MIB + 1GIB with 32bit bus width
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.de --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 191 +++++++++++++++++++++++++++--- 1 file changed, 173 insertions(+), 18 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index eafb86d..04e9eab 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -136,7 +136,31 @@ static const struct mx6sdl_iomux_grp_regs dhcom6sdl_grp_ioregs = { .grp_b7ds = 0x00000030, };
-static const struct mx6_mmdc_calibration dhcom_mmdc_calib = { +static const struct mx6_mmdc_calibration dhcom_mmdc_calib_4x4g_1066 = { + .p0_mpwldectrl0 = 0x00150019, + .p0_mpwldectrl1 = 0x001C000B, + .p1_mpwldectrl0 = 0x00020018, + .p1_mpwldectrl1 = 0x0002000C, + .p0_mpdgctrl0 = 0x43140320, + .p0_mpdgctrl1 = 0x03080304, + .p1_mpdgctrl0 = 0x43180320, + .p1_mpdgctrl1 = 0x03100254, + .p0_mprddlctl = 0x4830383C, + .p1_mprddlctl = 0x3836323E, + .p0_mpwrdlctl = 0x3E444642, + .p1_mpwrdlctl = 0x42344442, +}; + +static const struct mx6_mmdc_calibration dhcom_mmdc_calib_2x4g_800 = { + .p0_mpwldectrl0 = 0x0040003C, + .p0_mpwldectrl1 = 0x0032003E, + .p0_mpdgctrl0 = 0x42350231, + .p0_mpdgctrl1 = 0x021A0218, + .p0_mprddlctl = 0x4B4B4E49, + .p0_mpwrdlctl = 0x3F3F3035, +}; + +static const struct mx6_mmdc_calibration dhcom_mmdc_calib_4x2g_1066 = { .p0_mpwldectrl0 = 0x0011000E, .p0_mpwldectrl1 = 0x000E001B, .p1_mpwldectrl0 = 0x00190015, @@ -151,23 +175,89 @@ static const struct mx6_mmdc_calibration dhcom_mmdc_calib = { .p1_mpwrdlctl = 0x473E4A3B, };
-static const struct mx6_ddr3_cfg dhcom_mem_ddr = { +static const struct mx6_mmdc_calibration dhcom_mmdc_calib_4x2g_800 = { + .p0_mpwldectrl0 = 0x003A003A, + .p0_mpwldectrl1 = 0x0030002F, + .p1_mpwldectrl0 = 0x002F0038, + .p1_mpwldectrl1 = 0x00270039, + .p0_mpdgctrl0 = 0x420F020F, + .p0_mpdgctrl1 = 0x01760175, + .p1_mpdgctrl0 = 0x41640171, + .p1_mpdgctrl1 = 0x015E0160, + .p0_mprddlctl = 0x45464B4A, + .p1_mprddlctl = 0x49484A46, + .p0_mpwrdlctl = 0x40402E32, + .p1_mpwrdlctl = 0x3A3A3231, +}; + +static const struct mx6_mmdc_calibration dhcom_mmdc_calib_2x2g_800 = { + .p0_mpwldectrl0 = 0x0040003C, + .p0_mpwldectrl1 = 0x0032003E, + .p0_mpdgctrl0 = 0x42350231, + .p0_mpdgctrl1 = 0x021A0218, + .p0_mprddlctl = 0x4B4B4E49, + .p0_mpwrdlctl = 0x3F3F3035, +}; + +/* + * 2 Gbit DDR3 memory + * - NANYA #NT5CC128M16IP-DII + * - NANYA #NT5CB128M16FP-DII + */ +static const struct mx6_ddr3_cfg dhcom_mem_ddr_2g = { .mem_speed = 1600, .density = 2, - .width = 64, + .width = 16, .banks = 8, .rowaddr = 14, .coladdr = 10, .pagesz = 2, - .trcd = 1312, + .trcd = 1375, .trcmin = 5863, .trasmin = 3750, };
-static const struct mx6_ddr_sysinfo dhcom_ddr_info = { +/* + * 4 Gbit DDR3 memory + * - Intelligent Memory #IM4G16D3EABG-125I + */ +static const struct mx6_ddr3_cfg dhcom_mem_ddr_4g = { + .mem_speed = 1600, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +/* DDR3 64bit */ +static const struct mx6_ddr_sysinfo dhcom_ddr_64bit = { /* width of data bus:0=16,1=32,2=64 */ .dsize = 2, - .cs_density = 16, + .cs_density = 32, + .ncs = 1, /* single chip select */ + .cs1_mirror = 1, + .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */ + .rtt_nom = 1, /* DDR3_RTT_60_OHM, RTT_Nom = RZQ/4 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .refsel = 1, /* Refresh cycles at 32KHz */ + .refr = 3, /* 4 refresh commands per refresh cycle */ +}; + +/* DDR3 32bit */ +static const struct mx6_ddr_sysinfo dhcom_ddr_32bit = { + /* width of data bus:0=16,1=32,2=64 */ + .dsize = 1, + .cs_density = 32, .ncs = 1, /* single chip select */ .cs1_mirror = 1, .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */ @@ -392,6 +482,81 @@ static void setup_iomux_usb(void) SETUP_IOMUX_PADS(usb_pads); }
+ +/* DRAM */ +static void dhcom_spl_dram_init(void) +{ + enum dhcom_ddr3_code ddr3_code = dhcom_get_ddr3_code(); + + if (is_mx6dq()) { + mx6dq_dram_iocfg(64, &dhcom6dq_ddr_ioregs, + &dhcom6dq_grp_ioregs); + switch (ddr3_code) { + default: + printf("imx6qd: unsupported ddr3 code %d\n", ddr3_code); + printf(" choosing 1024 MB\n"); + /* fall through */ + case DH_DDR3_SIZE_1GIB: + mx6_dram_cfg(&dhcom_ddr_64bit, + &dhcom_mmdc_calib_4x2g_1066, + &dhcom_mem_ddr_2g); + break; + case DH_DDR3_SIZE_2GIB: + mx6_dram_cfg(&dhcom_ddr_64bit, + &dhcom_mmdc_calib_4x4g_1066, + &dhcom_mem_ddr_4g); + break; + } + + /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_dqs_calibration(&dhcom_ddr_64bit); + + } else if (is_cpu_type(MXC_CPU_MX6DL)) { + mx6sdl_dram_iocfg(64, &dhcom6sdl_ddr_ioregs, + &dhcom6sdl_grp_ioregs); + switch (ddr3_code) { + default: + printf("imx6dl: unsupported ddr3 code %d\n", ddr3_code); + printf(" choosing 1024 MB\n"); + /* fall through */ + case DH_DDR3_SIZE_1GIB: + mx6_dram_cfg(&dhcom_ddr_64bit, + &dhcom_mmdc_calib_4x2g_800, + &dhcom_mem_ddr_2g); + break; + } + + /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_dqs_calibration(&dhcom_ddr_64bit); + + } else if (is_cpu_type(MXC_CPU_MX6SOLO)) { + mx6sdl_dram_iocfg(32, &dhcom6sdl_ddr_ioregs, + &dhcom6sdl_grp_ioregs); + switch (ddr3_code) { + default: + printf("imx6s: unsupported ddr3 code %d\n", ddr3_code); + printf(" choosing 512 MB\n"); + /* fall through */ + case DH_DDR3_SIZE_512MIB: + mx6_dram_cfg(&dhcom_ddr_32bit, + &dhcom_mmdc_calib_2x2g_800, + &dhcom_mem_ddr_2g); + break; + case DH_DDR3_SIZE_1GIB: + mx6_dram_cfg(&dhcom_ddr_32bit, + &dhcom_mmdc_calib_2x4g_800, + &dhcom_mem_ddr_4g); + break; + } + + /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_dqs_calibration(&dhcom_ddr_32bit); + } +} + void board_init_f(ulong dummy) { /* setup AIPS and disable watchdog */ @@ -415,18 +580,8 @@ void board_init_f(ulong dummy) /* UART clocks enabled and gd valid - init serial console */ preloader_console_init();
- /* Start the DDR DRAM */ - if (is_mx6dq()) - mx6dq_dram_iocfg(dhcom_mem_ddr.width, &dhcom6dq_ddr_ioregs, - &dhcom6dq_grp_ioregs); - else - mx6sdl_dram_iocfg(dhcom_mem_ddr.width, &dhcom6sdl_ddr_ioregs, - &dhcom6sdl_grp_ioregs); - mx6_dram_cfg(&dhcom_ddr_info, &dhcom_mmdc_calib, &dhcom_mem_ddr); - - /* Perform DDR DRAM calibration */ - udelay(100); - mmdc_do_dqs_calibration(&dhcom_ddr_info); + /* DDR3 initialization */ + dhcom_spl_dram_init();
- .p0_mpwldectrl0 = 0x00150019,
- .p0_mpwldectrl1 = 0x001C000B,
- .p1_mpwldectrl0 = 0x00020018,
- .p1_mpwldectrl1 = 0x0002000C,
- .p0_mpdgctrl0 = 0x43140320,
- .p0_mpdgctrl1 = 0x03080304,
- .p1_mpdgctrl0 = 0x43180320,
- .p1_mpdgctrl1 = 0x03100254,
- .p0_mprddlctl = 0x4830383C,
- .p1_mprddlctl = 0x3836323E,
- .p0_mpwrdlctl = 0x3E444642,
- .p1_mpwrdlctl = 0x42344442,
- .p0_mpwldectrl0 = 0x0040003C,
- .p0_mpwldectrl1 = 0x0032003E,
- .p0_mpdgctrl0 = 0x42350231,
- .p0_mpdgctrl1 = 0x021A0218,
- .p0_mprddlctl = 0x4B4B4E49,
- .p0_mpwrdlctl = 0x3F3F3035,
- .p0_mpwldectrl0 = 0x003A003A,
- .p0_mpwldectrl1 = 0x0030002F,
- .p1_mpwldectrl0 = 0x002F0038,
- .p1_mpwldectrl1 = 0x00270039,
- .p0_mpdgctrl0 = 0x420F020F,
- .p0_mpdgctrl1 = 0x01760175,
- .p1_mpdgctrl0 = 0x41640171,
- .p1_mpdgctrl1 = 0x015E0160,
- .p0_mprddlctl = 0x45464B4A,
- .p1_mprddlctl = 0x49484A46,
- .p0_mpwrdlctl = 0x40402E32,
- .p1_mpwrdlctl = 0x3A3A3231,
- 2 Gbit DDR3 memory
- .width = 64,
- .width = 16, .banks = 8, .rowaddr = 14, .coladdr = 10, .pagesz = 2,
- .trcd = 1312,
- .trcd = 1375, .trcmin = 5863, .trasmin = 3750,
- 4 Gbit DDR3 memory
- .mem_speed = 1600,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- .cs_density = 16,
- .cs_density = 32,
- .ncs = 1, /* single chip select */
- .cs1_mirror = 1,
- .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */
- .rtt_nom = 1, /* DDR3_RTT_60_OHM, RTT_Nom = RZQ/4 */
- .walat = 1, /* Write additional latency */
- .ralat = 5, /* Read additional latency */
- .mif3_mode = 3, /* Command prediction working mode */
- .bi_on = 1, /* Bank interleaving enabled */
- .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
- .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
- .refsel = 1, /* Refresh cycles at 32KHz */
- .refr = 3, /* 4 refresh commands per refresh cycle */
- /* width of data bus:0=16,1=32,2=64 */
- .dsize = 1,
- .cs_density = 32, .ncs = 1, /* single chip select */ .cs1_mirror = 1, .rtt_wr = 1, /* DDR3_RTT_60_OHM, RTT_Wr = RZQ/4 */
- enum dhcom_ddr3_code ddr3_code = dhcom_get_ddr3_code();
- if (is_mx6dq()) {
default:
/* fall through */
&dhcom_mem_ddr_2g);
break;
&dhcom_mem_ddr_4g);
break;
udelay(100);
- } else if (is_cpu_type(MXC_CPU_MX6DL)) {
default:
/* fall through */
&dhcom_mem_ddr_2g);
break;
udelay(100);
- } else if (is_cpu_type(MXC_CPU_MX6SOLO)) {
default:
/* fall through */
&dhcom_mem_ddr_2g);
break;
&dhcom_mem_ddr_4g);
break;
udelay(100);
- if (is_mx6dq())
- else
- udelay(100);
This patch causes memory instability on 1GiB MX6Q part.
Can you check that and fix it ? Thanks.
Hello Marek,
Can you tell me more about the error? How do you test this? Did you run a git bisect?
We did tests in a climate chamber with this configuration (with the MX6Q and all others).
I think there is only one change that could make a difference:
static const struct mx6_ddr3_cfg dhcom_mem_ddr_2g = { ... - .trcd = 1312, + .trcd = 1375, ....
Best Regards, Ludwig Zenz
On 10/11/2018 09:09 AM, Ludwig Zenz wrote:
Hello Marek,
Hello Ludwig,
.trcd = 1312,
.trcd = 1375,
In this particular case, the board exhibited random instability. Try running memtester in linux for a few days, maybe some board that you have will start exhibiting this too.
- udelay(100);
- /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Ludwig Zenz
Stefano Babic
