[U-Boot] [u-boot] spi/arm-pl022: Add support for ARM PL022 spi controller
This patch adds the support for the ARM PL022 SPI controller for the standard variant (0x00041022), which has a 16bit wide and 8 locations deep TX/RX FIFO.
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Vipin Kumar vipin.kumar@st.com --- This driver has been tested on the ST SPEAr1340 evaluation board. Patch has just been rebased on http://git.denx.de/u-boot-spi.git master branch and can be cleanly applied there.
Armando
drivers/spi/Makefile | 1 + drivers/spi/pl022_spi.c | 308 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 309 insertions(+) create mode 100644 drivers/spi/pl022_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d08609e..b6443b1 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -47,6 +47,7 @@ COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_MXS_SPI) += mxs_spi.o COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o +COBJS-$(CONFIG_PL022_SPI) += pl022_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c new file mode 100644 index 0000000..3ea769a --- /dev/null +++ b/drivers/spi/pl022_spi.c @@ -0,0 +1,308 @@ +/* + * (C) Copyright 2012 + * Armando Visconti, ST Microelectronics, armando.visconti@st.com. + * + * Driver for ARM PL022 SPI Controller. Based on atmel_spi.c + * by Atmel Corporation. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* SSP registers mapping */ +#define SSP_CR0 0x000 +#define SSP_CR1 0x004 +#define SSP_DR 0x008 +#define SSP_SR 0x00C +#define SSP_CPSR 0x010 +#define SSP_IMSC 0x014 +#define SSP_RIS 0x018 +#define SSP_MIS 0x01C +#define SSP_ICR 0x020 +#define SSP_DMACR 0x024 +#define SSP_ITCR 0x080 +#define SSP_ITIP 0x084 +#define SSP_ITOP 0x088 +#define SSP_TDR 0x08C + +#define SSP_PID0 0xFE0 +#define SSP_PID1 0xFE4 +#define SSP_PID2 0xFE8 +#define SSP_PID3 0xFEC + +#define SSP_CID0 0xFF0 +#define SSP_CID1 0xFF4 +#define SSP_CID2 0xFF8 +#define SSP_CID3 0xFFC + +/* SSP Control Register 0 - SSP_CR0 */ +#define SSP_CR0_SPO (0x1 << 6) +#define SSP_CR0_SPH (0x1 << 7) +#define SSP_CR0_8BIT_MODE (0x07) +#define SSP_SCR_MAX (0xFF) +#define SSP_SCR_SHFT 8 + +/* SSP Control Register 0 - SSP_CR1 */ +#define SSP_CR1_MASK_SSE (0x1 << 1) + +#define SSP_CPSR_MAX (0xFE) + +/* SSP Status Register - SSP_SR */ +#define SSP_SR_MASK_TFE (0x1 << 0) /* Transmit FIFO empty */ +#define SSP_SR_MASK_TNF (0x1 << 1) /* Transmit FIFO not full */ +#define SSP_SR_MASK_RNE (0x1 << 2) /* Receive FIFO not empty */ +#define SSP_SR_MASK_RFF (0x1 << 3) /* Receive FIFO full */ +#define SSP_SR_MASK_BSY (0x1 << 4) /* Busy Flag */ + +struct pl022_spi_slave { + struct spi_slave slave; + void *regs; + unsigned int freq; +}; + +static inline struct pl022_spi_slave *to_pl022_spi(struct spi_slave *slave) +{ + return container_of(slave, struct pl022_spi_slave, slave); +} + +/* + * Following three functions should be provided by the + * board support package. + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) + __attribute__((weak, alias("__spi_cs_is_valid"))); +void spi_cs_activate(struct spi_slave *slave) + __attribute__((weak, alias("__spi_cs_activate"))); +void spi_cs_deactivate(struct spi_slave *slave) + __attribute__((weak, alias("__spi_cs_deactivate"))); + +int __spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void __spi_cs_activate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void __spi_cs_deactivate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_init() +{ + /* do nothing */ +} + +/* + * ARM PL022 exists in different 'flavors'. + * This drivers currently support the standard variant (0x00041022), that has a + * 16bit wide and 8 locations deep TX/RX FIFO. + */ +static int pl022_is_supported(struct pl022_spi_slave *ps) +{ + /* PL022 version is 0x00041022 */ + if ((readw(ps->regs + SSP_PID0) == 0x22) && + (readw(ps->regs + SSP_PID1) == 0x10) && + ((readw(ps->regs + SSP_PID2) & 0xf) == 0x04) && + (readw(ps->regs + SSP_PID3) == 0x00)) + return 1; + + return 0; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct pl022_spi_slave *ps; + u16 scr = 1, prescaler, cr0 = 0, cpsr = 0; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ps = malloc(sizeof(*ps)); + if (!ps) + return NULL; + + ps->slave.bus = bus; + ps->slave.cs = cs; + ps->freq = max_hz; + + switch (bus) { + case 0: + ps->regs = (void *)CONFIG_SYS_SPI_BASE; + break; +#ifdef CONFIG_SYS_SPI_BASE1 + case 1: + ps->regs = (void *)CONFIG_SYS_SPI_BASE1; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE2 + case 2: + ps->regs = (void *)CONFIG_SYS_SPI_BASE2; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE3 + case 3: + ps->regs = (void *)CONFIG_SYS_SPI_BASE3; + break; +#endif + default: + free(ps); + return NULL; + } + + /* Check the PL022 version */ + if (!pl022_is_supported(ps)) { + free(ps); + return NULL; + } + + /* Set requested polarity and 8bit mode */ + cr0 = SSP_CR0_8BIT_MODE; + cr0 |= (mode & SPI_CPHA) ? SSP_CR0_SPH : 0; + cr0 |= (mode & SPI_CPOL) ? SSP_CR0_SPO : 0; + + writew(cr0, ps->regs + SSP_CR0); + + /* Program the SSPClk frequency */ + prescaler = CONFIG_SYS_SPI_CLK / ps->freq; + + if (prescaler <= 0xFF) + cpsr = prescaler; + else { + for (scr = 1; scr <= SSP_SCR_MAX; scr++) { + if (!(prescaler % scr)) { + cpsr = prescaler / scr; + if (cpsr <= SSP_CPSR_MAX) + break; + } + } + + if (scr > SSP_SCR_MAX) { + scr = SSP_SCR_MAX; + cpsr = prescaler / scr; + cpsr &= SSP_CPSR_MAX; + } + } + + if (cpsr & 0x1) + cpsr++; + + writew(cpsr, ps->regs + SSP_CPSR); + cr0 = readw(ps->regs + SSP_CR0); + writew(cr0 | (scr - 1) << SSP_SCR_SHFT, ps->regs + SSP_CR0); + + return &ps->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + + free(ps); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + + /* Enable the SPI hardware */ + writew(readw(ps->regs + SSP_CR1) | SSP_CR1_MASK_SSE, + ps->regs + SSP_CR1); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + + /* Disable the SPI hardware */ + writew(0x0, ps->regs + SSP_CR1); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + u32 len_tx = 0, len_rx = 0, len; + u32 ret = 0; + const u8 *txp = dout; + u8 *rxp = din, value; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + goto out; + + /* + * TODO: The controller can do non-multiple-of-8 bit + * transfers, but this driver currently doesn't support it. + * + * It's also not clear how such transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface. + */ + if (bitlen % 8) { + ret = -1; + + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + goto out; + } + + len = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + while (len_tx < len) { + if (readw(ps->regs + SSP_SR) & SSP_SR_MASK_TNF) { + value = (txp != NULL) ? *txp++ : 0; + writew(value, ps->regs + SSP_DR); + len_tx++; + } + + if (readw(ps->regs + SSP_SR) & SSP_SR_MASK_RNE) { + value = readw(ps->regs + SSP_DR); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + while (len_rx < len_tx) { + if (readw(ps->regs + SSP_SR) & SSP_SR_MASK_RNE) { + value = readw(ps->regs + SSP_DR); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + +out: + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
Is this the v4? I sent some comment for v3 on same driver.
Thanks, Jagan.
On Mon, Jun 3, 2013 at 1:54 PM, Armando Visconti armando.visconti@st.com wrote:
Armando
- (C) Copyright 2012
- Armando Visconti, ST Microelectronics, armando.visconti@st.com.
- Driver for ARM PL022 SPI Controller. Based on atmel_spi.c
- by Atmel Corporation.
- MA 02111-1307 USA
void *regs;
unsigned int freq;
- Following three functions should be provided by the
- board support package.
return 1;
/* do nothing */
/* do nothing */
+void spi_init() +{
/* do nothing */
- ARM PL022 exists in different 'flavors'.
- This drivers currently support the standard variant (0x00041022), that has a
- 16bit wide and 8 locations deep TX/RX FIFO.
return 1;
return NULL;
if (!ps)
return NULL;
ps->slave.cs = cs;
ps->freq = max_hz;
switch (bus) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
default:
free(ps);
return NULL;
free(ps);
return NULL;
cpsr = prescaler;
else {
break;
scr = SSP_SCR_MAX;
if (cpsr & 0x1)
cpsr++;
return &ps->slave;
free(ps);
u32 ret = 0;
if (bitlen == 0)
goto out;
if (bitlen % 8) {
ret = -1;
goto out;
len = bitlen / 8;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
return ret;
1.7.11.7
I completely lost the original thread... I will re-start from V3...
Pls discard this noisy thread,
Please check the below thread for earlier v3 http://patchwork.ozlabs.org/patch/205814/
-- Thanks, Jagan.
Thx Jagan,
I have a v4 ready, where I just corrected the checkpatch errors.
Nevertheless, I failed to find your comments over the v3. Can you possibly send to me the link to the discussion thread?
Thx, Arm
Armando Visconti
Jagan Teki
