[U-Boot] [PATCH v2] cmd: crosec: Move cros_ec_decode_region helper to cmd/cros_ec.c
The cros_ec_decode_region() function is only used in combination with the crosec cmds. Move the function to the correct place.
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com Cc: Simon Glass sjg@chromium.org Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: u-boot@lists.denx.de ---
Changes from v1:
* make cros_ec_decode_region static * move over the comments * fixed commit message s/crosec/cros_ec/g
--- cmd/cros_ec.c | 23 +++++++++++++++++++++++ drivers/misc/cros_ec.c | 16 ---------------- include/cros_ec.h | 9 --------- 3 files changed, 23 insertions(+), 25 deletions(-)
diff --git a/cmd/cros_ec.c b/cmd/cros_ec.c index abf11f0..9d42f87 100644 --- a/cmd/cros_ec.c +++ b/cmd/cros_ec.c @@ -20,6 +20,29 @@ static const char * const ec_current_image_name[] = {"unknown", "RO", "RW"}; DECLARE_GLOBAL_DATA_PTR;
/** + * Decode a flash region parameter + * + * @param argc Number of params remaining + * @param argv List of remaining parameters + * @return flash region (EC_FLASH_REGION_...) or -1 on error + */ +static int cros_ec_decode_region(int argc, char * const argv[]) +{ + if (argc > 0) { + if (0 == strcmp(*argv, "rw")) + return EC_FLASH_REGION_RW; + else if (0 == strcmp(*argv, "ro")) + return EC_FLASH_REGION_RO; + + debug("%s: Invalid region '%s'\n", __func__, *argv); + } else { + debug("%s: Missing region parameter\n", __func__); + } + + return -1; +} + +/** * Perform a flash read or write command * * @param dev CROS-EC device to read/write diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index 8073730..759bb46 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -1024,22 +1024,6 @@ int cros_ec_register(struct udevice *dev) return 0; }
-int cros_ec_decode_region(int argc, char * const argv[]) -{ - if (argc > 0) { - if (0 == strcmp(*argv, "rw")) - return EC_FLASH_REGION_RW; - else if (0 == strcmp(*argv, "ro")) - return EC_FLASH_REGION_RO; - - debug("%s: Invalid region '%s'\n", __func__, *argv); - } else { - debug("%s: Missing region parameter\n", __func__); - } - - return -1; -} - int cros_ec_decode_ec_flash(const void *blob, int node, struct fdt_cros_ec *config) { diff --git a/include/cros_ec.h b/include/cros_ec.h index ec7517c..0271f2b 100644 --- a/include/cros_ec.h +++ b/include/cros_ec.h @@ -250,15 +250,6 @@ void cros_ec_dump_data(const char *name, int cmd, const uint8_t *data, int len); */ int cros_ec_calc_checksum(const uint8_t *data, int size);
-/** - * Decode a flash region parameter - * - * @param argc Number of params remaining - * @param argv List of remaining parameters - * @return flash region (EC_FLASH_REGION_...) or -1 on error - */ -int cros_ec_decode_region(int argc, char * const argv[]); - int cros_ec_flash_erase(struct cros_ec_dev *dev, uint32_t offset, uint32_t size);
Changes from v1:
- make cros_ec_decode_region static
- move over the comments
- fixed commit message s/crosec/cros_ec/g
Changes from v1:
Applied to u-boot-dm, thanks!
Moritz Fischer
