[PATCH] board: stm32mp1: solve compilation issue when ENV_IS_IN_MMC is deactivated
Solve compilation issue on undefined CONFIG_SYS_MMC_ENV_DEV when CONFIG_ENV_IS_IN_MMC is deactivated on STMicroelectronics boards defconfig
Fixes: 9f97193616f1 ("board: stm32mp1: use CONFIG_SYS_MMC_ENV_DEV when available") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
board/st/stm32mp1/stm32mp1.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 45f2ca81a6..fff1880e5b 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -890,8 +890,10 @@ const char *env_ext4_get_dev_part(void)
int mmc_get_env_dev(void) { - if (CONFIG_SYS_MMC_ENV_DEV >= 0) - return CONFIG_SYS_MMC_ENV_DEV; + const int mmc_env_dev = CONFIG_IS_ENABLED(ENV_IS_IN_MMC, (CONFIG_SYS_MMC_ENV_DEV), (-1)); + + if (mmc_env_dev >= 0) + return mmc_env_dev;
/* use boot instance to select the correct mmc device identifier */ return mmc_get_boot();
Hi Patrick
return mmc_env_dev;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Hi Patrick
return mmc_env_dev;
Applied to u-boot-stm/master
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
