[PATCH 0/2] AM64: Add support for USB
Add support for USB 3.0 TYPE A port on AM642 SK board
The following series of patches are dependent on, - https://patchwork.ozlabs.org/project/uboot/list/?series=268093 - https://patchwork.ozlabs.org/project/uboot/list/?series=268092
Aswath Govindraju (1): configs: am64x_evm_*_defconfig: Add configs to enable serdes for USB 3.0 support
Kishon Vijay Abraham I (1): arm: dts: am642-sk: Add and Enable USB SuperSpeed Host Port in SPL
arch/arm/dts/k3-am642-r5-sk.dts | 40 ++++++++++++++++++++++++++++ arch/arm/dts/k3-am642-sk-u-boot.dtsi | 33 +++++++++++++++++++++++ configs/am64x_evm_a53_defconfig | 15 +++++++++++ configs/am64x_evm_r5_defconfig | 13 +++++++++ 4 files changed, 101 insertions(+)
Add and Enable USB SuperSpeed Host Port in SPL.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- arch/arm/dts/k3-am642-r5-sk.dts | 40 ++++++++++++++++++++++++++++ arch/arm/dts/k3-am642-sk-u-boot.dtsi | 33 +++++++++++++++++++++++ 2 files changed, 73 insertions(+)
diff --git a/arch/arm/dts/k3-am642-r5-sk.dts b/arch/arm/dts/k3-am642-r5-sk.dts index 79eff8259f94..71fcf61ff9fb 100644 --- a/arch/arm/dts/k3-am642-r5-sk.dts +++ b/arch/arm/dts/k3-am642-r5-sk.dts @@ -5,6 +5,8 @@
/dts-v1/;
+#include <dt-bindings/mux/ti-serdes.h> +#include <dt-bindings/phy/phy.h> #include "k3-am642.dtsi" #include "k3-am64-sk-lp4-1333MTs.dtsi" #include "k3-am64-ddr.dtsi" @@ -107,6 +109,13 @@ AM64X_IOPAD(0x029c, PIN_INPUT_PULLUP, 0) /* (C20) MMC1_SDWP */ >; }; + + main_usb0_pins_default: main-usb0-pins-default { + u-boot,dm-spl; + pinctrl-single,pins = < + AM64X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (E19) USB0_DRVVBUS */ + >; + }; };
&dmsc { @@ -142,4 +151,35 @@ pinctrl-0 = <&main_mmc1_pins_default>; };
+&serdes_ln_ctrl { + idle-states = <AM64_SERDES0_LANE0_USB>; +}; + +&serdes_wiz0 { + status = "okay"; +}; + +&serdes0 { + serdes0_usb_link: link@0 { + reg = <0>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz0 1>; + }; +}; + +&usbss0 { + ti,vbus-divider; +}; + +&usb0 { + dr_mode = "host"; + maximum-speed = "super-speed"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb0_pins_default>; + phys = <&serdes0_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + #include "k3-am642-sk-u-boot.dtsi" diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index efbcfb36e92a..95cf52c37fab 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -110,3 +110,36 @@ &cpsw_port2 { status = "disabled"; }; + +&main_usb0_pins_default { + u-boot,dm-spl; +}; + +&serdes_ln_ctrl { + u-boot,mux-autoprobe; +}; + +&usbss0 { + u-boot,dm-spl; +}; + +&usb0 { + dr_mode = "host"; + u-boot,dm-spl; +}; + +&serdes_wiz0 { + u-boot,dm-spl; +}; + +&serdes0_usb_link { + u-boot,dm-spl; +}; + +&serdes0 { + u-boot,dm-spl; +}; + +&serdes_refclk { + u-boot,dm-spl; +};
Add configs to enable serdes for USB 3.0 support.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- configs/am64x_evm_a53_defconfig | 15 +++++++++++++++ configs/am64x_evm_r5_defconfig | 13 +++++++++++++ 2 files changed, 28 insertions(+)
diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index d157403d84cb..388b3530d0b9 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y +CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x8000 @@ -34,6 +35,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y +CONFIG_SPL_DM_GPIO=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y @@ -70,10 +72,14 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_CLK_CCF=y +CONFIG_SPL_CLK_CCF=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y @@ -84,6 +90,7 @@ CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_DM_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_SUPPORT_EMMC_BOOT=y @@ -96,10 +103,18 @@ CONFIG_MMC_SDHCI_AM654=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_MULTIPLEXER=y +CONFIG_MUX_MMIO=y CONFIG_PHY_TI_DP83867=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_PHY_CADENCE_TORRENT=y +CONFIG_SPL_PHY_CADENCE_TORRENT=y +CONFIG_PHY_J721E_WIZ=y +CONFIG_SPL_PHY_J721E_WIZ=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 5b04f18a635a..0f49b5d7cb6e 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_GPIO=y CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-am642-r5-evm" CONFIG_SPL_TEXT_BASE=0x70000000 @@ -76,10 +77,14 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_CLK_CCF=y +CONFIG_SPL_CLK_CCF=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y @@ -97,6 +102,14 @@ CONFIG_MMC_SDHCI_AM654=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_PHY_CADENCE_SIERRA=y +CONFIG_SPL_PHY_CADENCE_SIERRA=y +CONFIG_PHY_CADENCE_TORRENT=y +CONFIG_SPL_PHY_CADENCE_TORRENT=y +CONFIG_PHY_J721E_WIZ=y +CONFIG_SPL_PHY_J721E_WIZ=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y
Aswath Govindraju
