[U-Boot] [PATCH] mx28evk: Scan only first 512 MB of DRAM to avoid memory wraparound
Scan only first 512 MB of DRAM to avoid memory wraparound.
This fixes mx28evk boot and it follows the same idea of commit 19a2066b57 (M28: Scan only first 512 MB of DRAM to avoid memory wraparound)
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx28evk.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 0c18e50..a4ea12d 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -75,7 +75,7 @@ */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ -#define PHYS_SDRAM_1_SIZE 0x40000000 /* Max 1 GB RAM */ +#define PHYS_SDRAM_1_SIZE 0x20000000 /* Max 512MB RAM */ #define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ #define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ #define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */
Dear Fabio Estevam,
Thanks, sorry for the breakage.
Acked-by: Marek Vasut marex@denx.de
btw. I think Otavio was working on some common config, wasn't he? btw2. won't there ever be MX28EVK with more than 512MB of DRAM?
malloc */
Best regards, Marek Vasut
Yes, I think Otavio is working on that.
I don't think there will be other revision of mx28evk board.
Regards,
Fabio Estevam
Dear Fabio Estevam,
That'd be so cool ... :)
All right, this approach is valid then. Btw. Fabio, can you verify that you don't see any memory aliasing now (just to avoid trouble).
Regards,
Fabio Estevam
How can I verify this, please?
Regards,
Fabio Estevam
Dear Fabio Estevam,
Try writing some pattern into DRAM at "offset-sizeof(pattern area)" and try reading it from "2*offset + sizeof(pattern area)" ... try doing the same for 4*offset etc.
You might also be able to read data from memory behind what uboot considers as detected DRAM which will have the same contents as the detected DRAM etc.
Regards,
Fabio Estevam
Actually I think it would be better to define the total size of RAM for mx28evk as 128MB.
Do you agree?
Regards,
Fabio Estevam
Dear Fabio Estevam,
Do you agree?
Yes, it's fine with me.
Regards,
Fabio Estevam
Dear Fabio Estevam,
Actually I think this should not be needed. Such wrap-arounds are supposed to be detected by get_ram_size(), which should result in properly sized RAM mappings.
Why is this failing here?
Fabio Estevam
