[U-Boot] [PATCH 1/2] ARM: dts: uniphier: sync with Linux 5.1-rc4
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ld11.dtsi | 4 +- arch/arm/dts/uniphier-ld20.dtsi | 66 +++++++++++++++++++++++++----- arch/arm/dts/uniphier-ld4.dtsi | 14 +++++++ arch/arm/dts/uniphier-pro4.dtsi | 16 ++++++++ arch/arm/dts/uniphier-pxs2.dtsi | 6 ++- arch/arm/dts/uniphier-pxs3-ref.dts | 4 ++ arch/arm/dts/uniphier-pxs3.dtsi | 55 +++++++++++++++++++++++-- arch/arm/dts/uniphier-sld8.dtsi | 14 +++++++ 8 files changed, 160 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index 31ba52b14e..a3cd475b48 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -33,7 +33,7 @@
cpu0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x000>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -42,7 +42,7 @@
cpu1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x001>; clocks = <&sys_clk 33>; enable-method = "psci"; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index b9ed613ace..baf2326836 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -43,7 +43,7 @@
cpu0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a72", "arm,armv8"; + compatible = "arm,cortex-a72"; reg = <0 0x000>; clocks = <&sys_clk 32>; enable-method = "psci"; @@ -53,7 +53,7 @@
cpu1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a72", "arm,armv8"; + compatible = "arm,cortex-a72"; reg = <0 0x001>; clocks = <&sys_clk 32>; enable-method = "psci"; @@ -63,7 +63,7 @@
cpu2: cpu@100 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x100>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -73,7 +73,7 @@
cpu3: cpu@101 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x101>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -206,13 +206,10 @@ cooling-maps { map0 { trip = <&cpu_alert>; - cooling-device = <&cpu0 - THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - map1 { - trip = <&cpu_alert>; - cooling-device = <&cpu2 - THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; @@ -891,6 +888,53 @@ }; };
+ pcie: pcie@66000000 { + compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; + status = "disabled"; + reg-names = "dbi", "link", "config"; + reg = <0x66000000 0x1000>, <0x66010000 0x10000>, + <0x2fff0000 0x10000>; + #address-cells = <3>; + #size-cells = <2>; + clocks = <&sys_clk 24>; + resets = <&sys_rst 24>; + num-lanes = <1>; + num-viewport = <1>; + bus-range = <0x0 0xff>; + device_type = "pci"; + ranges = + /* downstream I/O */ + <0x81000000 0 0x00000000 0x2ffe0000 0 0x00010000>, + /* non-prefetchable memory */ + <0x82000000 0 0x20000000 0x20000000 0 0x0ffe0000>; + #interrupt-cells = <1>; + interrupt-names = "dma", "msi"; + interrupts = <0 224 4>, <0 225 4>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie_intc 0>, /* INTA */ + <0 0 0 2 &pcie_intc 1>, /* INTB */ + <0 0 0 3 &pcie_intc 2>, /* INTC */ + <0 0 0 4 &pcie_intc 3>; /* INTD */ + phy-names = "pcie-phy"; + phys = <&pcie_phy>; + + pcie_intc: legacy-interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <0 226 4>; + }; + }; + + pcie_phy: phy@66038000 { + compatible = "socionext,uniphier-ld20-pcie-phy"; + reg = <0x66038000 0x4000>; + #phy-cells = <0>; + clocks = <&sys_clk 24>; + resets = <&sys_rst 24>; + socionext,syscon = <&soc_glue>; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index b73d594b6d..c2706cef0b 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -235,6 +235,16 @@ }; };
+ dmac: dma-controller@5a000000 { + compatible = "socionext,uniphier-mio-dmac"; + reg = <0x5a000000 0x1000>; + interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, + <0 71 4>, <0 72 4>, <0 73 4>; + clocks = <&mio_clk 7>; + resets = <&mio_rst 7>; + #dma-cells = <1>; + }; + sd: sdhc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; @@ -246,6 +256,8 @@ clocks = <&mio_clk 0>; reset-names = "host", "bridge"; resets = <&mio_rst 0>, <&mio_rst 3>; + dma-names = "rx-tx"; + dmas = <&dmac 4>; bus-width = <4>; cap-sd-highspeed; sd-uhs-sdr12; @@ -263,6 +275,8 @@ clocks = <&mio_clk 1>; reset-names = "host", "bridge", "hw"; resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; + dma-names = "rx-tx"; + dmas = <&dmac 6>; bus-width = <8>; cap-mmc-highspeed; cap-mmc-hw-reset; diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index ef342088e1..d090fc7e2d 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -269,6 +269,16 @@ }; };
+ dmac: dma-controller@5a000000 { + compatible = "socionext,uniphier-mio-dmac"; + reg = <0x5a000000 0x1000>; + interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, + <0 71 4>, <0 72 4>, <0 73 4>, <0 74 4>; + clocks = <&mio_clk 7>; + resets = <&mio_rst 7>; + #dma-cells = <1>; + }; + sd: sdhc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; @@ -280,6 +290,8 @@ clocks = <&mio_clk 0>; reset-names = "host", "bridge"; resets = <&mio_rst 0>, <&mio_rst 3>; + dma-names = "rx-tx"; + dmas = <&dmac 4>; bus-width = <4>; cap-sd-highspeed; sd-uhs-sdr12; @@ -297,6 +309,8 @@ clocks = <&mio_clk 1>; reset-names = "host", "bridge", "hw"; resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; + dma-names = "rx-tx"; + dmas = <&dmac 5>; bus-width = <8>; cap-mmc-highspeed; cap-mmc-hw-reset; @@ -313,6 +327,8 @@ clocks = <&mio_clk 2>; reset-names = "host", "bridge"; resets = <&mio_rst 2>, <&mio_rst 5>; + dma-names = "rx-tx"; + dmas = <&dmac 6>; bus-width = <4>; cap-sd-highspeed; }; diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index fa25ffd97f..4e11e85d8d 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -141,8 +141,10 @@ cooling-maps { map { trip = <&cpu_alert>; - cooling-device = <&cpu0 - THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; }; }; diff --git a/arch/arm/dts/uniphier-pxs3-ref.dts b/arch/arm/dts/uniphier-pxs3-ref.dts index 4fb12b8a67..1965e4dfe4 100644 --- a/arch/arm/dts/uniphier-pxs3-ref.dts +++ b/arch/arm/dts/uniphier-pxs3-ref.dts @@ -109,6 +109,10 @@ status = "okay"; };
+&pcie { + status = "okay"; +}; + &nand { status = "okay"; }; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index f629c6a862..961d4d3621 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -39,7 +39,7 @@
cpu0: cpu@0 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x000>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -48,7 +48,7 @@
cpu1: cpu@1 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x001>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -57,7 +57,7 @@
cpu2: cpu@2 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x002>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -66,7 +66,7 @@
cpu3: cpu@3 { device_type = "cpu"; - compatible = "arm,cortex-a53", "arm,armv8"; + compatible = "arm,cortex-a53"; reg = <0 0x003>; clocks = <&sys_clk 33>; enable-method = "psci"; @@ -765,6 +765,53 @@ }; };
+ pcie: pcie@66000000 { + compatible = "socionext,uniphier-pcie", "snps,dw-pcie"; + status = "disabled"; + reg-names = "dbi", "link", "config"; + reg = <0x66000000 0x1000>, <0x66010000 0x10000>, + <0x2fff0000 0x10000>; + #address-cells = <3>; + #size-cells = <2>; + clocks = <&sys_clk 24>; + resets = <&sys_rst 24>; + num-lanes = <1>; + num-viewport = <1>; + bus-range = <0x0 0xff>; + device_type = "pci"; + ranges = + /* downstream I/O */ + <0x81000000 0 0x00000000 0x2ffe0000 0 0x00010000>, + /* non-prefetchable memory */ + <0x82000000 0 0x20000000 0x20000000 0 0x0ffe0000>; + #interrupt-cells = <1>; + interrupt-names = "dma", "msi"; + interrupts = <0 224 4>, <0 225 4>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie_intc 0>, /* INTA */ + <0 0 0 2 &pcie_intc 1>, /* INTB */ + <0 0 0 3 &pcie_intc 2>, /* INTC */ + <0 0 0 4 &pcie_intc 3>; /* INTD */ + phy-names = "pcie-phy"; + phys = <&pcie_phy>; + + pcie_intc: legacy-interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <0 226 4>; + }; + }; + + pcie_phy: phy@66038000 { + compatible = "socionext,uniphier-pxs3-pcie-phy"; + reg = <0x66038000 0x4000>; + #phy-cells = <0>; + clocks = <&sys_clk 24>; + resets = <&sys_rst 24>; + socionext,syscon = <&soc_glue>; + }; + nand: nand@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index f7fcf6b459..efce02768b 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -239,6 +239,16 @@ }; };
+ dmac: dma-controller@5a000000 { + compatible = "socionext,uniphier-mio-dmac"; + reg = <0x5a000000 0x1000>; + interrupts = <0 68 4>, <0 68 4>, <0 69 4>, <0 70 4>, + <0 71 4>, <0 72 4>, <0 73 4>; + clocks = <&mio_clk 7>; + resets = <&mio_rst 7>; + #dma-cells = <1>; + }; + sd: sdhc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; @@ -250,6 +260,8 @@ clocks = <&mio_clk 0>; reset-names = "host", "bridge"; resets = <&mio_rst 0>, <&mio_rst 3>; + dma-names = "rx-tx"; + dmas = <&dmac 4>; bus-width = <4>; cap-sd-highspeed; sd-uhs-sdr12; @@ -267,6 +279,8 @@ clocks = <&mio_clk 1>; reset-names = "host", "bridge", "hw"; resets = <&mio_rst 1>, <&mio_rst 4>, <&mio_rst 6>; + dma-names = "rx-tx"; + dmas = <&dmac 6>; bus-width = <8>; cap-mmc-highspeed; cap-mmc-hw-reset;
configs/uniphier_v8_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 08dfa240c1..e0e4dbd507 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -33,6 +33,7 @@ CONFIG_GPIO_UNIPHIER=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 +CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_MMC_HS200_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_MMC_SDHCI=y
Masahiro Yamada
