[U-Boot] [PATCH] mmc/dwmmc: use bounce buffer for data exchange between CPU and MMC controller
Bounce buffer implementation takes care of proper data buffer alignemt and correct flush/invalidation of data cache at once so we no longer depend on input data variety and make sure CPU and MMC controller deal with expected data in case of enabled data cache.
Bounce buffer requires to add its definition (CONFIG_BOUNCE_BUFFER) in board configuration, otherwise corresponding library won't be compiled and linker will fail to build resulting executable.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com
Cc: Mischa Jonker mjonker@synopsys.com Cc: Alim Akhtar alim.akhtar@samsung.com Cc: Rajeshwari Shinde rajeshwari.s@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Amar amarendra.xt@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Andy Fleming afleming@freescale.com --- drivers/mmc/dw_mmc.c | 32 ++++++++++++++++++++++---------- include/configs/arndale.h | 1 + include/configs/exynos5250-dt.h | 1 + 3 files changed, 24 insertions(+), 10 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 19d9b0b..a149d97 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -6,6 +6,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <bouncebuf.h> #include <common.h> #include <malloc.h> #include <mmc.h> @@ -41,11 +42,13 @@ static void dwmci_set_idma_desc(struct dwmci_idmac *idmac, }
static void dwmci_prepare_data(struct dwmci_host *host, - struct mmc_data *data, struct dwmci_idmac *cur_idmac) + struct mmc_data *data, + struct dwmci_idmac *cur_idmac, + void *bounce_buffer) { unsigned long ctrl; unsigned int i = 0, flags, cnt, blk_cnt; - ulong data_start, data_end, start_addr; + ulong data_start, data_end;
blk_cnt = data->blocks; @@ -55,11 +58,6 @@ static void dwmci_prepare_data(struct dwmci_host *host, data_start = (ulong)cur_idmac; dwmci_writel(host, DWMCI_DBADDR, (unsigned int)cur_idmac);
- if (data->flags == MMC_DATA_READ) - start_addr = (unsigned int)data->dest; - else - start_addr = (unsigned int)data->src; - do { flags = DWMCI_IDMAC_OWN | DWMCI_IDMAC_CH ; flags |= (i == 0) ? DWMCI_IDMAC_FS : 0; @@ -70,7 +68,7 @@ static void dwmci_prepare_data(struct dwmci_host *host, cnt = data->blocksize * 8;
dwmci_set_idma_desc(cur_idmac, flags, cnt, - start_addr + (i * PAGE_SIZE)); + (u32)bounce_buffer + (i * PAGE_SIZE));
if (blk_cnt <= 8) break; @@ -117,6 +115,7 @@ static int dwmci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, u32 retry = 10000; u32 mask, ctrl; ulong start = get_timer(0); + struct bounce_buffer bbstate;
while (dwmci_readl(host, DWMCI_STATUS) & DWMCI_BUSY) { if (get_timer(start) > timeout) { @@ -127,8 +126,19 @@ static int dwmci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd,
dwmci_writel(host, DWMCI_RINTSTS, DWMCI_INTMSK_ALL);
- if (data) - dwmci_prepare_data(host, data, cur_idmac); + if (data) { + if (data->flags == MMC_DATA_READ) { + bounce_buffer_start(&bbstate, data->dest, + data->blocksize * + data->blocks, GEN_BB_WRITE); + } else { + bounce_buffer_start(&bbstate, data->src, + data->blocksize * + data->blocks, GEN_BB_READ); + } + dwmci_prepare_data(host, data, cur_idmac, + bbstate.bounce_buffer); + }
dwmci_writel(host, DWMCI_CMDARG, cmd->cmdarg);
@@ -204,6 +214,8 @@ static int dwmci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, ctrl = dwmci_readl(host, DWMCI_CTRL); ctrl &= ~(DWMCI_DMA_EN); dwmci_writel(host, DWMCI_CTRL, ctrl); + + bounce_buffer_stop(&bbstate); }
udelay(100); diff --git a/include/configs/arndale.h b/include/configs/arndale.h index a3cb56b..3d29caf 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -85,6 +85,7 @@ #define CONFIG_DWMMC #define CONFIG_EXYNOS_DWMMC #define CONFIG_SUPPORT_EMMC_BOOT +#define CONFIG_BOUNCE_BUFFER
#define CONFIG_BOARD_EARLY_INIT_F diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 8fb904c..b39bafc 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -102,6 +102,7 @@ #define CONFIG_DWMMC #define CONFIG_EXYNOS_DWMMC #define CONFIG_SUPPORT_EMMC_BOOT +#define CONFIG_BOUNCE_BUFFER
Hi, Alexey.
I have found the build warning. Could you fix it?
dw_mmc.c: In function ‘dwmci_send_cmd’: dw_mmc.c:137:10: warning: passing argument 2 of ‘bounce_buffer_start’ discards ‘const’ qualifier from pointer target type [enabled by default] u-boot-mmc/include/bouncebuf.h:64:5: note: expected ‘void *’ but argument is of type ‘const char *’
Maybe, it needs the type conversion for data->src.
Best Regards, Jaehoon Chung
- else
- if (data)
if (data) {
data->blocksize *
} else {
data->blocksize *
udelay(100);
Alexey Brodkin
Jaehoon Chung
