[U-Boot] Quick guide to Kconfig
Hi all,
The mainline has switched to Kconfig.
Please make sure to use "make <board>_defconfig" instead of "make <board>_config".
[1] Board Configuration
make <board_name>_defconfig
[2] Modify configuration
make config, make menuconfig, make nconfig, ... etc.
For SPL, make spl/config, make spl/menuconfig, make spl/nconfig, ... etc.
For TPL, make tpl/config, make tpl/menuconfig, make tpl/nconfig, ... etc.
But there are no useful configurations in Kconfig for now.
[3] boards.cfg
We no longer have boards.cfg maintained in the git-repo. But this file is necessary for MAKEALL and buildman. Perhaps it may also be useful for browsing the list of the supported boards.
You can generate an equivalent one by running "tools/genboardscfg.py".
[4] MAKEALL and buildman
They depend on the boards.cfg file.
MAKEALL and buildman automatically generate boards.cfg if it does not exist.
Best Regards Masahiro Yamada
Hi everyone,
can you please give me a hint how to run the menuconfig?
I just downloaded the latest U-Boot from ftp://ftp.denx.de/pub/u-boot/u-boot-latest.tar.bz2 (Version: 2014.07). When entering the /u-boot-2014.07/ directory and hitting "make menuconfig" then, it just tells me that there's no rule to make menuconfig - and so I can't run the configuration tool. Am I in the wrong directory or is it the wrong version?
Regards
Frank
Masahiro Yamada yamada.m@jp.panasonic.com 31.07.14 6.53 Uhr >>>
Hi all,
[3] boards.cfg
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Frank,
On Thu, 31 Jul 2014 08:29:07 +0200 "Frank Ihle" frank.ihle@hs-offenburg.de wrote:
Hi everyone,
Kconfig is not included in u-boot-latest.tar.bz2 (Version: 2014.07); Kconfig was merged into the mainline just ten hours ago!
If you want to try the newest source tree, please do git-clone.
git clone git://git.denx.de/u-boot.git
Hi Masahiro,
thanks! it's running nicely. I see you're running the GUI with lxdialog, and it's nice to see that more and more build systems come together to one "base", which makes it much easier for further developing.
I've just started using it on our project too, but the integration is a pretty tenacious job, as you might know. I would much appreciate it, if you could share any information like tutorials or documentation for a better adaptation of the lxdialog, if that's alright. Because, if we are using U-Boots menuconfig, then we'd like to add extra rows with information on our own.
Kind Regards
Frank
Masahiro Yamada yamada.m@jp.panasonic.com 31.07.14 8.39 Uhr >>>
Hi Frank,
Hi everyone,
On 07/31/2014 06:51 AM, Masahiro Yamada wrote:
Hi all,
I'm a bit confused here, a single "make" will build both the SPL + the regular u-boot binary, so why 2 separate menuconfig commands for them ?
To be a bit more specific, currently for sunxi for some boards (the ones most used by devs) we have both Foo_defconfig and Foo_FEL_defconfig with the latter one being identical to the first one, except that it not only defines SPL (all our builds use SPL) but also SPL_FEL, this changes some compile time settings as well as leads to using a different linker script for the SPL. The end result is a SPL binary which can be loaded through the "FEL" allwinner usb firmware loading / update mechanism, rather then written to a sdcard as our regular builds.
Rather then doubling the amount of defconfigs we have to allow using FEL on any sunxi board, I would like to remove the Foo_FEL_defconfig files and make it possible to do a FEL build by doing something like this:
make Foo_defconfig make menuconfig <select FEL> make
I was planning on taking a shot at this, but the different make menuconfig and make spl/menuconfigs have me somewhat confused (I've a decent knowledge of Kconfig from my kernel work).
Perhaps you can give me some hints on how I can best implement the above ?
Thanks & Regards,
Hans
<select FEL> make
I was hoping that I might eventually be able to do something like make Foo_defconfig CONFIG_SPL_FEL=y or perhaps make Foo_defconfig S:CONFIG_SPL_FEL=y and have it DTRT(tm).
I think part of the problem is that right now we are at "Phase I" of the switch to Kconfig, which is where the board.cfg settings have moved as a string into CONFIG_SYS_EXTRA_OPTIONS. I suppose "Phase II" is that the various maintainers implement proper Kconfig options for their platforms and transition the individual settings over to it. Eventually CONFIG_SYS_EXTRA_OPTIONS goes away.
Eventually (sooner rather than later, I think) we will want to have a first-class Kconfig setting for CONFIG_SPL_FEL and then things like "make spl/menuconfig" would let you enable FEL, I think/hope.
Apologies if I've misunderstood something and am therefore talking nonsense ;-)
Ian.
Hi Ian,
<select FEL> make
Sorry, we cannot override CONFIG macros from the command line; We have to run "make menuconfig" (or "make spl/menuconfig") and toggle the option.
Exactly.
CONFIG_SYS_EXTRA_OPTIONS is a temporary gimmick to migrate to Kconfig.
Please note this option is marked as "DEPRECATED".
config SYS_EXTRA_OPTIONS string "Extra Options (DEPRECATED)" depends on !SPL_BUILD help The old configuration infrastructure (= mkconfig + boards.cfg) provided the extra options field. If you have something like "HAS_BAR,BAZ=64", the optional options #define CONFIG_HAS #define CONFIG_BAZ 64 will be defined in include/config.h. This option was prepared for the smooth migration from the old configuration to Kconfig. Since this option will be removed sometime, new boards should not use this option.
I do not recommend to use this option for new boards.
Sounds nice, thanks!
On Fri, Aug 01, 2014 at 01:42:15PM +0900, Masahiro Yamada wrote:
Hi Ian,
<select FEL> make
But this is an upstream limitation ;)
Hi Ian,
<select FEL> make
Right, I think it must have been just my wishful thinking that I remembered doing this...
Ian.
Hi Hans,
Hi all,
A single "make <board>_defconfig" will configure both the Normal U-boot and SPL. (It will create .config and additionally spl/.config if SPL is supported )
Likewise a single "make" will build both.
This keeps the same build process as we had prior to Kconfig, except the command name difference between <board>_config and <board>_defconfig.
But "config", "menuconfig", "nconfig", etc. are interactive configuration tools, which can not be run for Normal and SPL at one time.
So I think it is reasonable to allow users to invoke menuconfig and spl/menuconfig separately.
<select FEL> make
Yes, this is exactly what I expect board maintainers.
We had multiple entries in boards.cfg per board (with some differences in the options field) and I generated the correspoing defconfig files.
But I guess it would be painful to maintain lots of defconfigs.
I expect board maintainers will consolidate defconfigs like you are trying to do, and eventually, we will have one defconfig per board in the future.
Sounds good!
I think it is good to add
config FEL bool
or something allowing users to enable/disable it.
If it is a sunxi-specifi option, please add it to arch/arm/cpu/armv7/sunxi/Kconfig or board/sunxi/Kconfig.
On Fri, Aug 01, 2014 at 01:37:54PM +0900, Masahiro Yamada wrote:
[snip]
So I was thinking about this a bit this morning since I have lots of defconfigs I want to merge together as well (see am335x_evm*). I suspect the answer is board maintainers will want a README in their directory. But today we're inconsistent in a few places. First, it's most often board/.../README but we have a few README.somethings (I'm guilty there too. And despite 702e601 we have some board-level (I'd consider at least) details in docs/ still.
Would board/sunxi/README work for the sunxi cases? Or is that going to get too unwieldy?
[snip]
board/sunxi/README will work fine for sunxi documentation as far as I can see right now.
Regards,
Hans
[snip]
A bunch of the sort of thing I imaging would be there probably ought instead to go into Kconfig help sections for the symbols which they are documenting.
Ian.
Hi Tom,
[snip]
I think we don't have to be too strict to "one defconfig per board". Maybe we can have two or three where it is reasonable. Anyway it is a good thing to merge "am335x_evm_uart*" :-)
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Masahiro Yamada Sent: Thursday, July 31, 2014 12:51 PM To: u-boot@lists.denx.de Subject: [U-Boot] Quick guide to Kconfig
Hi all,
Do we have a minimal python version requirement ? Because I can no longer build U-Boot on our build server which still uses python-2.4.x. There are some 2.6+ only syntax in genboardscfg.py and multiconfig.py.
Thanks, Miao
[3] boards.cfg
Hi.
Hi all,
I have no idea about the python version requirement in U-Boot.
It seams not so difficult to rewrite them without "with ... as" and "except ... as" and here are the patches: http://patchwork.ozlabs.org/patch/376215/ http://patchwork.ozlabs.org/patch/376214/
Sorry, tools/genboardscfg.py is not working on Python 2.4 I have to make more effort for that, but I am not sure it is worthwhile.
Is is difficult to install newer Python on your machine?
I can work-around it by installing a newer Python in my home directory and fixing $PATH. I am OK if you think it not necessary to support older versions, I just want to be sure about that.
Thanks, Miao
Hi Masahiro,
On 30 July 2014 22:51, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi all,
Once this thread is complete, do you think you could send a patch to add some docs to the source tree?
On Mon, Aug 04, 2014 at 05:15:21AM -0600, Simon Glass wrote:
Hi Masahiro,
Hi all,
I plan to grab the patch already posted to fixup existing docs in place, btw.
participants (7)
Frank Ihle
Hans de Goede
Ian Campbell
Masahiro Yamada
Yan, Miao
