[U-Boot] ARM & u-boot-next pull request
Hi Wolfgang Please pull The following changes since commit 87b4ef560cf2da4ccc9e59711ad1ff7fafe96670: Wolfgang Denk (1): Coding style cleanup; update CHANEGLOG
git://git.denx.de/u-boot-arm.git master
Guennadi Liakhovetski (1): i.MX31: switch to CFG_HZ=1000
Jean-Christophe PLAGNIOL-VILLARD (4): Revert "ARM: set GD_FLG_RELOC for boards skipping relocation to RAM" ARM: set GD_FLG_RELOC at board init move README.imx31 to doc/ and merge with README.mx31 update uImgae FIT multi documentation
README.imx31 | 13 ------ cpu/arm1136/mx31/interrupts.c | 79 ++++++++++++++++++++++++-------------- doc/README.imx31 | 29 ++++++++++++++ doc/README.mx31 | 17 -------- doc/uImage.FIT/multi.its | 2 + include/configs/imx31_litekit.h | 4 +- include/configs/imx31_phycore.h | 2 +- include/configs/mx31ads.h | 4 +- lib_arm/board.c | 19 +-------- 9 files changed, 86 insertions(+), 83 deletions(-) delete mode 100644 README.imx31 create mode 100644 doc/README.imx31 delete mode 100644 doc/README.mx31
And for u-boot-next
The following changes since commit b0f1111d6cda4ff3a4c608fce70383410332eca9: Jean-Christophe PLAGNIOL-VILLARD (1): update uImgae FIT multi documentation
git://git.denx.de/u-boot-arm.git next
Jean-Christophe PLAGNIOL-VILLARD (2): rename CFG_ macros to CONFIG_SYS add tool to check patch and filr for CFG_ present
MAKEALL | 5 + Makefile | 52 +- README | 334 +++++++------- README.nios_CONFIG_SYS_NIOS_CPU | 140 ++++++ api/api_storage.c | 8 +- board/AtmarkTechno/suzaku/flash.c | 2 +- board/BuS/EB+MCF-EV123/EB+MCF-EV123.c | 30 +- board/BuS/EB+MCF-EV123/VCxK.c | 2 +- board/BuS/EB+MCF-EV123/cfm_flash.c | 16 +- board/BuS/EB+MCF-EV123/cfm_flash.h | 2 +- board/BuS/EB+MCF-EV123/flash.c | 20 +- board/BuS/EB+MCF-EV123/mii.c | 12 +- board/LEOX/elpt860/elpt860.c | 52 +- board/LEOX/elpt860/flash.c | 30 +- board/MAI/AmigaOneG3SE/cmd_boota.c | 2 +- board/MAI/AmigaOneG3SE/flash.c | 4 +- board/MAI/AmigaOneG3SE/flash_new.c | 30 +- board/MAI/AmigaOneG3SE/i8259.h | 28 +- board/MAI/AmigaOneG3SE/interrupts.c | 4 +- board/MAI/AmigaOneG3SE/ps2kbd.c | 10 +- board/MAI/AmigaOneG3SE/serial.c | 6 +- board/MAI/AmigaOneG3SE/usb_uhci.c | 2 +- board/Marvell/common/flash.c | 22 +- board/Marvell/common/i2c.c | 8 +- board/Marvell/common/intel_flash.c | 4 +- board/Marvell/common/intel_flash.h | 2 +- board/Marvell/common/misc.S | 18 +- board/Marvell/common/ns16550.c | 6 +- board/Marvell/common/ns16550.h | 2 +- board/Marvell/common/serial.c | 22 +- board/Marvell/db64360/db64360.c | 140 +++--- board/Marvell/db64360/mpsc.c | 6 +- board/Marvell/db64360/pci.c | 20 +- board/Marvell/db64360/sdram_init.c | 28 +- board/Marvell/db64460/db64460.c | 140 +++--- board/Marvell/db64460/mpsc.c | 6 +- board/Marvell/db64460/pci.c | 20 +- board/Marvell/db64460/sdram_init.c | 28 +- board/MigoR/migo_r.c | 6 +- board/RPXClassic/RPXClassic.c | 16 +- board/RPXClassic/eccx.c | 2 +- board/RPXClassic/flash.c | 18 +- board/RPXlite/RPXlite.c | 14 +- board/RPXlite/flash.c | 24 +- board/RPXlite_dw/RPXlite_dw.c | 16 +- board/RPXlite_dw/flash.c | 18 +- board/RRvision/RRvision.c | 26 +- board/RRvision/flash.c | 24 +- board/a3000/a3000.c | 2 +- board/a3000/flash.c | 30 +- board/actux1/actux1.c | 14 +- board/actux1/actux1_hw.h | 22 +- board/actux2/actux2.c | 28 +- board/actux2/actux2_hw.h | 32 +- board/actux3/actux3.c | 40 +- board/actux3/actux3_hw.h | 30 +- board/actux4/actux4.c | 56 ++-- board/actux4/actux4_hw.h | 32 +- board/adder/adder.c | 10 +- board/ads5121/ads5121.c | 136 +++--- board/ads5121/ads5121_diu.c | 4 +- board/ads5121/pci.c | 44 +- board/alaska/alaska.c | 40 +- board/alaska/flash.c | 76 ++-- board/altera/common/AMDLV065D.c | 14 +- board/altera/common/epled.c | 6 +- board/altera/common/flash.c | 12 +- board/altera/dk1c20/dk1c20.c | 6 +- board/altera/dk1c20/flash.c | 8 +- board/altera/dk1s10/flash.c | 6 +- board/altera/dk1s10/vectors.S | 8 +- board/amcc/acadia/acadia.c | 34 +- board/amcc/acadia/cmd_acadia.c | 2 +- board/amcc/acadia/memory.c | 18 +- board/amcc/bamboo/bamboo.c | 22 +- board/amcc/bamboo/config.mk | 2 +- board/amcc/bamboo/flash.c | 12 +- board/amcc/bamboo/init.S | 28 +- board/amcc/bubinga/flash.c | 16 +- board/amcc/canyonlands/bootstrap.c | 2 +- board/amcc/canyonlands/canyonlands.c | 48 +- board/amcc/canyonlands/config.mk | 2 +- board/amcc/canyonlands/init.S | 40 +- board/amcc/common/flash.c | 234 +++++----- board/amcc/ebony/config.mk | 2 +- board/amcc/ebony/ebony.c | 12 +- board/amcc/ebony/flash.c | 12 +- board/amcc/ebony/init.S | 10 +- board/amcc/katmai/config.mk | 2 +- board/amcc/katmai/init.S | 52 +- board/amcc/katmai/katmai.c | 30 +- board/amcc/kilauea/cmd_pll.c | 10 +- board/amcc/kilauea/kilauea.c | 16 +- board/amcc/luan/config.mk | 2 +- board/amcc/luan/flash.c | 10 +- board/amcc/luan/init.S | 10 +- board/amcc/luan/luan.c | 14 +- board/amcc/makalu/cmd_pll.c | 10 +- board/amcc/makalu/makalu.c | 14 +- board/amcc/ocotea/config.mk | 2 +- board/amcc/ocotea/flash.c | 14 +- board/amcc/ocotea/init.S | 10 +- board/amcc/ocotea/ocotea.c | 12 +- board/amcc/ocotea/ocotea.h | 10 +- board/amcc/redwood/config.mk | 2 +- board/amcc/redwood/init.S | 24 +- board/amcc/sequoia/cmd_sequoia.c | 6 +- board/amcc/sequoia/config.mk | 2 +- board/amcc/sequoia/init.S | 28 +- board/amcc/sequoia/sdram.c | 2 +- board/amcc/sequoia/sequoia.c | 38 +- board/amcc/sequoia/u-boot.lds | 2 +- board/amcc/taihu/flash.c | 258 +++++----- board/amcc/taihu/taihu.c | 4 +- board/amcc/taihu/update.c | 2 +- board/amcc/taishan/config.mk | 2 +- board/amcc/taishan/init.S | 10 +- board/amcc/taishan/lcd.c | 10 +- board/amcc/taishan/taishan.c | 22 +- board/amcc/taishan/update.c | 2 +- board/amcc/walnut/flash.c | 8 +- board/amcc/yosemite/config.mk | 2 +- board/amcc/yosemite/init.S | 20 +- board/amcc/yosemite/yosemite.c | 40 +- board/amcc/yucca/config.mk | 2 +- board/amcc/yucca/flash.c | 246 +++++----- board/amcc/yucca/init.S | 60 ++-- board/amcc/yucca/yucca.c | 16 +- board/amirix/ap1000/flash.c | 16 +- board/amirix/ap1000/pci.c | 6 +- board/amirix/ap1000/serial.c | 22 +- board/ap325rxa/ap325rxa.c | 6 +- board/apollon/apollon.c | 2 +- board/apollon/lowlevel_init.S | 2 +- board/apollon/mem.c | 8 +- board/apollon/mem.h | 6 +- board/armadillo/flash.c | 12 +- board/atc/atc.c | 34 +- board/atc/config.mk | 2 +- board/atc/flash.c | 28 +- board/atc/ti113x.c | 8 +- board/atmel/at91cap9adk/at91cap9adk.c | 4 +- board/atmel/at91cap9adk/nand.c | 2 +- board/atmel/at91cap9adk/partition.c | 6 +- board/atmel/at91rm9200dk/flash.c | 26 +- board/atmel/at91rm9200dk/partition.c | 8 +- board/atmel/at91sam9260ek/at91sam9260ek.c | 4 +- board/atmel/at91sam9260ek/nand.c | 2 +- board/atmel/at91sam9260ek/partition.c | 8 +- board/atmel/at91sam9261ek/at91sam9261ek.c | 4 +- board/atmel/at91sam9261ek/nand.c | 2 +- board/atmel/at91sam9261ek/partition.c | 8 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 4 +- board/atmel/at91sam9263ek/nand.c | 2 +- board/atmel/at91sam9263ek/partition.c | 6 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 4 +- board/atmel/at91sam9rlek/nand.c | 2 +- board/atmel/at91sam9rlek/partition.c | 6 +- board/atmel/atstk1000/flash.c | 6 +- board/atum8548/atum8548.c | 110 +++--- board/atum8548/law.c | 14 +- board/atum8548/tlb.c | 20 +- board/barco/barco.c | 14 +- board/barco/barco_svc.h | 12 +- board/barco/early_init.S | 96 ++-- board/barco/flash.c | 18 +- board/bc3450/bc3450.c | 66 ++-- board/bc3450/cmd_bc3450.c | 16 +- board/bf533-ezkit/bf533-ezkit.c | 14 +- board/bf533-ezkit/flash-defines.h | 4 +- board/bf533-ezkit/flash.c | 22 +- board/bf533-ezkit/psd4256.h | 8 +- board/bf533-ezkit/u-boot.lds.S | 4 +- board/bf533-stamp/bf533-stamp.c | 6 +- board/bf533-stamp/u-boot.lds.S | 4 +- board/bf537-stamp/bf537-stamp.c | 14 +- board/bf537-stamp/nand.c | 8 +- board/bf537-stamp/post-memory.c | 8 +- board/bf537-stamp/spi_flash.c | 2 +- board/bf537-stamp/u-boot.lds.S | 4 +- board/bf561-ezkit/bf561-ezkit.c | 10 +- board/bf561-ezkit/u-boot.lds.S | 4 +- board/bmw/README | 40 +- board/bmw/early_init.S | 42 +- board/bmw/flash.c | 18 +- board/bmw/ns16550.c | 6 +- board/bmw/ns16550.h | 2 +- board/bmw/serial.c | 4 +- board/c2mon/c2mon.c | 26 +- board/c2mon/flash.c | 40 +- board/c2mon/pcmcia.c | 22 +- board/canmb/canmb.c | 32 +- board/cerf250/flash.c | 18 +- board/cerf250/lowlevel_init.S | 66 ++-- board/cm4008/flash.c | 18 +- board/cm41xx/flash.c | 18 +- board/cm5200/cm5200.c | 22 +- board/cm5200/cmd_cm5200.c | 8 +- board/cmc_pu2/flash.c | 22 +- board/cmi/cmi.c | 2 +- board/cmi/flash.c | 24 +- board/cobra5272/cobra5272.c | 2 +- board/cobra5272/flash.c | 22 +- board/cobra5272/mii.c | 8 +- board/cogent/README | 8 +- board/cogent/flash.c | 20 +- board/cogent/lcd.c | 4 +- board/cogent/mb.h | 44 +- board/cpc45/cpc45.c | 8 +- board/cpc45/flash.c | 32 +- board/cpc45/pd67290.c | 12 +- board/cpu86/config.mk | 2 +- board/cpu86/cpu86.c | 32 +- board/cpu86/cpu86.h | 26 +- board/cpu86/flash.c | 32 +- board/cpu87/config.mk | 2 +- board/cpu87/cpu87.c | 40 +- board/cpu87/cpu87.h | 26 +- board/cpu87/flash.c | 32 +- board/cradle/flash.c | 18 +- board/cradle/lowlevel_init.S | 86 ++-- board/cray/L1/L1.c | 2 +- board/cray/L1/flash.c | 10 +- board/csb226/flash.c | 18 +- board/csb226/lowlevel_init.S | 66 ++-- board/csb272/csb272.c | 4 +- board/csb272/init.S | 4 +- board/csb472/init.S | 4 +- board/cu824/cu824.c | 2 +- board/cu824/flash.c | 34 +- board/dave/B2/flash.c | 8 +- board/dave/PPChameleonEVB/PPChameleonEVB.c | 14 +- board/dave/PPChameleonEVB/flash.c | 6 +- board/dave/PPChameleonEVB/nand.c | 8 +- board/dave/PPChameleonEVB/u-boot.lds | 2 +- board/dave/common/flash.c | 126 +++--- board/dave/common/fpga.c | 22 +- board/dave/common/pci.c | 22 +- board/davinci/common/misc.c | 10 +- board/davinci/common/psc.c | 4 +- board/davinci/dvevm/dvevm.c | 4 +- board/davinci/schmoogie/schmoogie.c | 12 +- board/davinci/sffsdr/sffsdr.c | 34 +- board/davinci/sonata/sonata.c | 4 +- board/dbau1x00/dbau1x00.c | 6 +- board/dbau1x00/flash.c | 2 +- board/dbau1x00/lowlevel_init.S | 4 +- board/delta/delta.c | 4 +- board/delta/lowlevel_init.S | 10 +- board/delta/nand.c | 20 +- board/dnp1110/flash.c | 18 +- board/eXalion/eXalion.c | 8 +- board/earthlcd/favr-32-ezkit/flash.c | 6 +- board/eltec/bab7xx/asm_init.S | 30 +- board/eltec/bab7xx/bab7xx.c | 10 +- board/eltec/bab7xx/flash.c | 12 +- board/eltec/bab7xx/l2cache.c | 6 +- board/eltec/bab7xx/misc.c | 14 +- board/eltec/bab7xx/pci.c | 32 +- board/eltec/bab7xx/srom.h | 4 +- board/eltec/elppc/asm_init.S | 28 +- board/eltec/elppc/elppc.c | 6 +- board/eltec/elppc/flash.c | 12 +- board/eltec/elppc/misc.c | 16 +- board/eltec/elppc/pci.c | 30 +- board/eltec/elppc/srom.h | 4 +- board/eltec/mhpc/flash.c | 28 +- board/eltec/mhpc/mhpc.c | 24 +- board/emk/common/flash.c | 24 +- board/emk/common/vpd.c | 8 +- board/emk/top5200/top5200.c | 30 +- board/emk/top860/top860.c | 8 +- board/ep7312/flash.c | 16 +- board/ep8248/ep8248.c | 100 ++-- board/ep8260/config.mk | 2 +- board/ep8260/ep8260.c | 60 ++-- board/ep8260/flash.c | 16 +- board/ep8260/mii_phy.c | 4 +- board/ep82xxm/ep82xxm.c | 96 ++-- board/ep88x/ep88x.c | 14 +- board/eric/eric.c | 2 +- board/eric/flash.c | 48 +- board/eric/init.S | 2 +- board/esd/adciop/flash.c | 2 +- board/esd/apc405/apc405.c | 58 ++-- board/esd/ar405/flash.c | 4 +- board/esd/ash405/ash405.c | 8 +- board/esd/ash405/flash.c | 4 +- board/esd/canbt/flash.c | 2 +- board/esd/cms700/cms700.c | 30 +- board/esd/cms700/flash.c | 4 +- board/esd/common/auto_update.c | 6 +- board/esd/common/esd405ep_nand.c | 18 +- board/esd/common/flash.c | 136 +++--- board/esd/common/fpga.c | 18 +- board/esd/common/lcd.c | 34 +- board/esd/common/pci.c | 22 +- board/esd/common/xilinx_jtag/ports.h | 10 +- board/esd/cpci2dp/cpci2dp.c | 28 +- board/esd/cpci2dp/flash.c | 2 +- board/esd/cpci405/cpci405.c | 46 +- board/esd/cpci405/flash.c | 2 +- board/esd/cpci5200/cpci5200.c | 14 +- board/esd/cpci5200/strataflash.c | 22 +- board/esd/cpci750/cpci750.c | 134 +++--- board/esd/cpci750/i2c.c | 8 +- board/esd/cpci750/ide.c | 8 +- board/esd/cpci750/local.h | 2 +- board/esd/cpci750/misc.S | 26 +- board/esd/cpci750/mpsc.c | 6 +- board/esd/cpci750/pci.c | 20 +- board/esd/cpci750/sdram_init.c | 8 +- board/esd/cpciiser4/flash.c | 2 +- board/esd/dasa_sim/cmd_dasa_sim.c | 14 +- board/esd/dasa_sim/flash.c | 2 +- board/esd/dp405/flash.c | 4 +- board/esd/du405/flash.c | 2 +- board/esd/du440/config.mk | 2 +- board/esd/du440/du440.c | 124 +++--- board/esd/du440/du440.h | 20 +- board/esd/du440/init.S | 26 +- board/esd/du440/u-boot.lds | 2 +- board/esd/hh405/flash.c | 4 +- board/esd/hh405/hh405.c | 86 ++-- board/esd/hub405/flash.c | 4 +- board/esd/hub405/hub405.c | 14 +- board/esd/mecp5200/mecp5200.c | 16 +- board/esd/ocrtc/flash.c | 2 +- board/esd/pci405/flash.c | 2 +- board/esd/pci405/pci405.c | 16 +- board/esd/pf5200/flash.c | 24 +- board/esd/pf5200/pf5200.c | 18 +- board/esd/plu405/flash.c | 4 +- board/esd/plu405/plu405.c | 42 +- board/esd/pmc405/pmc405.c | 36 +- board/esd/pmc440/cmd_pmc440.c | 14 +- board/esd/pmc440/config.mk | 2 +- board/esd/pmc440/init.S | 26 +- board/esd/pmc440/pmc440.c | 56 ++-- board/esd/pmc440/pmc440.h | 4 +- board/esd/pmc440/sdram.c | 2 +- board/esd/pmc440/u-boot.lds | 2 +- board/esd/tasreg/flash.c | 8 +- board/esd/tasreg/tasreg.c | 16 +- board/esd/voh405/flash.c | 4 +- board/esd/voh405/voh405.c | 62 ++-- board/esd/vom405/flash.c | 4 +- board/esd/wuh405/flash.c | 4 +- board/esd/wuh405/wuh405.c | 8 +- board/esteem192e/esteem192e.c | 14 +- board/esteem192e/flash.c | 48 +- board/etin/debris/debris.c | 6 +- board/etin/debris/flash.c | 12 +- board/etin/debris/phantom.c | 2 +- board/etin/kvme080/kvme080.c | 30 +- board/etx094/etx094.c | 46 +- board/etx094/flash.c | 50 +- board/evb4510/flash.c | 14 +- board/evb64260/evb64260.c | 94 ++-- board/evb64260/flash.c | 34 +- board/evb64260/intel_flash.c | 4 +- board/evb64260/intel_flash.h | 2 +- board/evb64260/local.h | 2 +- board/evb64260/misc.S | 18 +- board/evb64260/mpsc.c | 2 +- board/evb64260/pci.c | 20 +- board/evb64260/sdram_init.c | 6 +- board/evb64260/serial.c | 36 +- board/exbitgen/flash.c | 24 +- board/exbitgen/init.S | 4 +- board/fads/fads.c | 40 +- board/fads/fads.h | 156 +++--- board/fads/flash.c | 28 +- board/flagadm/flagadm.c | 16 +- board/flagadm/flash.c | 36 +- board/freescale/common/cadmus.c | 12 +- board/freescale/common/fsl_diu_fb.c | 2 +- board/freescale/common/pixis.c | 12 +- board/freescale/common/sys_eeprom.c | 52 +- board/freescale/m52277evb/m52277evb.c | 22 +- board/freescale/m5235evb/m5235evb.c | 10 +- board/freescale/m5235evb/mii.c | 8 +- board/freescale/m5249evb/m5249evb.c | 8 +- board/freescale/m5253demo/flash.c | 38 +- board/freescale/m5253demo/m5253demo.c | 12 +- board/freescale/m5253evbe/m5253evbe.c | 14 +- board/freescale/m5271evb/m5271evb.c | 8 +- board/freescale/m5271evb/mii.c | 10 +- board/freescale/m5272c3/flash.c | 22 +- board/freescale/m5272c3/m5272c3.c | 2 +- board/freescale/m5272c3/mii.c | 8 +- board/freescale/m5275evb/m5275evb.c | 18 +- board/freescale/m5275evb/mii.c | 12 +- board/freescale/m5282evb/m5282evb.c | 10 +- board/freescale/m5282evb/mii.c | 12 +- board/freescale/m5329evb/m5329evb.c | 24 +- board/freescale/m5329evb/mii.c | 8 +- board/freescale/m5329evb/nand.c | 2 +- board/freescale/m5373evb/m5373evb.c | 24 +- board/freescale/m5373evb/mii.c | 8 +- board/freescale/m5373evb/nand.c | 2 +- board/freescale/m54451evb/m54451evb.c | 28 +- board/freescale/m54451evb/mii.c | 12 +- board/freescale/m54455evb/m54455evb.c | 42 +- board/freescale/m54455evb/mii.c | 12 +- board/freescale/m547xevb/m547xevb.c | 34 +- board/freescale/m547xevb/mii.c | 12 +- board/freescale/m548xevb/m548xevb.c | 32 +- board/freescale/m548xevb/mii.c | 12 +- board/freescale/mpc7448hpc2/asm_init.S | 6 +- board/freescale/mpc7448hpc2/mpc7448hpc2.c | 2 +- board/freescale/mpc7448hpc2/tsi108_init.c | 130 +++--- board/freescale/mpc8260ads/flash.c | 40 +- board/freescale/mpc8260ads/mpc8260ads.c | 198 ++++---- board/freescale/mpc8266ads/flash.c | 26 +- board/freescale/mpc8266ads/mpc8266ads.c | 26 +- board/freescale/mpc8313erdb/mpc8313erdb.c | 42 +- board/freescale/mpc8313erdb/sdram.c | 46 +- board/freescale/mpc8315erdb/mpc8315erdb.c | 28 +- board/freescale/mpc8315erdb/sdram.c | 34 +- board/freescale/mpc8323erdb/mpc8323erdb.c | 62 ++-- board/freescale/mpc832xemds/mpc832xemds.c | 36 +- board/freescale/mpc832xemds/pci.c | 48 +- board/freescale/mpc8349emds/mpc8349emds.c | 84 ++-- board/freescale/mpc8349emds/pci.c | 48 +- board/freescale/mpc8349itx/mpc8349itx.c | 64 ++-- board/freescale/mpc8349itx/pci.c | 70 ++-- board/freescale/mpc8360emds/mpc8360emds.c | 84 ++-- board/freescale/mpc8360emds/pci.c | 48 +- board/freescale/mpc8360erdk/mpc8360erdk.c | 58 ++-- board/freescale/mpc8360erdk/nand.c | 4 +- board/freescale/mpc837xemds/mpc837xemds.c | 44 +- board/freescale/mpc837xemds/pci.c | 24 +- board/freescale/mpc837xerdb/mpc837xerdb.c | 50 +- board/freescale/mpc837xerdb/pci.c | 24 +- board/freescale/mpc8536ds/law.c | 18 +- board/freescale/mpc8536ds/mpc8536ds.c | 142 +++--- board/freescale/mpc8536ds/tlb.c | 16 +- board/freescale/mpc8540ads/law.c | 10 +- board/freescale/mpc8540ads/mpc8540ads.c | 62 ++-- board/freescale/mpc8540ads/tlb.c | 28 +- board/freescale/mpc8541cds/law.c | 10 +- board/freescale/mpc8541cds/mpc8541cds.c | 42 +- board/freescale/mpc8541cds/tlb.c | 22 +- board/freescale/mpc8544ds/law.c | 16 +- board/freescale/mpc8544ds/mpc8544ds.c | 124 +++--- board/freescale/mpc8544ds/tlb.c | 20 +- board/freescale/mpc8548cds/law.c | 24 +- board/freescale/mpc8548cds/mpc8548cds.c | 82 ++-- board/freescale/mpc8548cds/tlb.c | 24 +- board/freescale/mpc8555cds/law.c | 10 +- board/freescale/mpc8555cds/mpc8555cds.c | 42 +- board/freescale/mpc8555cds/tlb.c | 22 +- board/freescale/mpc8560ads/law.c | 10 +- board/freescale/mpc8560ads/mpc8560ads.c | 64 ++-- board/freescale/mpc8560ads/tlb.c | 28 +- board/freescale/mpc8568mds/bcsr.c | 14 +- board/freescale/mpc8568mds/law.c | 12 +- board/freescale/mpc8568mds/mpc8568mds.c | 82 ++-- board/freescale/mpc8568mds/tlb.c | 20 +- board/freescale/mpc8572ds/law.c | 14 +- board/freescale/mpc8572ds/mpc8572ds.c | 100 ++-- board/freescale/mpc8572ds/tlb.c | 20 +- board/freescale/mpc8610hpcd/law.c | 16 +- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 74 ++-- board/freescale/mpc8610hpcd/mpc8610hpcd_diu.c | 4 +- board/freescale/mpc8641hpcn/law.c | 16 +- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 86 ++-- board/funkwerk/vovpn-gw/flash.c | 24 +- board/funkwerk/vovpn-gw/vovpn-gw.c | 40 +- board/g2000/g2000.c | 12 +- board/g2000/strataflash.c | 26 +- board/gaisler/gr_cpci_ax2000/u-boot.lds | 2 +- board/gaisler/gr_ep2s60/u-boot.lds | 2 +- board/gaisler/gr_xc3s_1500/u-boot.lds | 2 +- board/gaisler/grsim/u-boot.lds | 2 +- board/gaisler/grsim_leon2/u-boot.lds | 2 +- board/gcplus/flash.c | 18 +- board/gen860t/beeper.c | 10 +- board/gen860t/flash.c | 52 +- board/gen860t/fpga.c | 8 +- board/gen860t/gen860t.c | 12 +- board/genietv/flash.c | 18 +- board/genietv/genietv.c | 46 +- board/gth/ee_access.c | 14 +- board/gth/ee_dev.h | 8 +- board/gth/flash.c | 42 +- board/gth/gth.c | 18 +- board/gth/pcmcia.c | 8 +- board/gth2/flash.c | 2 +- board/gth2/gth2.c | 10 +- board/gth2/lowlevel_init.S | 2 +- board/gw8260/flash.c | 18 +- board/gw8260/gw8260.c | 56 ++-- board/hermes/flash.c | 24 +- board/hermes/hermes.c | 22 +- board/hidden_dragon/early_init.S | 96 ++-- board/hidden_dragon/flash.c | 22 +- board/hidden_dragon/hidden_dragon.c | 2 +- board/hmi1001/hmi1001.c | 22 +- board/hymod/bsp.c | 2 +- board/hymod/eeprom.c | 8 +- board/hymod/env.c | 4 +- board/hymod/flash.c | 28 +- board/hymod/hymod.c | 30 +- board/hymod/input.c | 2 +- board/icecube/flash.c | 26 +- board/icecube/icecube.c | 32 +- board/icu862/flash.c | 26 +- board/icu862/icu862.c | 26 +- board/icu862/pcmcia.c | 24 +- board/idmr/flash.c | 22 +- board/idmr/idmr.c | 10 +- board/idmr/mii.c | 10 +- board/ids8247/config.mk | 2 +- board/ids8247/flash.c | 26 +- board/ids8247/ids8247.c | 22 +- board/impa7/flash.c | 16 +- board/incaip/flash.c | 26 +- board/incaip/incaip.c | 8 +- board/inka4x0/inka4x0.c | 16 +- board/innokom/flash.c | 18 +- board/innokom/lowlevel_init.S | 66 ++-- board/integratorap/flash.c | 18 +- board/integratorap/integratorap.c | 18 +- board/integratorcp/flash.c | 32 +- board/integratorcp/integratorcp.c | 18 +- board/ip860/flash.c | 26 +- board/ip860/ip860.c | 54 ++-- board/iphase4539/flash.c | 30 +- board/iphase4539/iphase4539.c | 10 +- board/ispan/ispan.c | 138 +++--- board/ivm/flash.c | 32 +- board/ivm/ivm.c | 70 ++-- board/ixdp425/flash.c | 18 +- board/ixdp425/ixdp425.c | 20 +- board/jse/flash.c | 10 +- board/jse/jse.c | 18 +- board/jse/sdram.c | 2 +- board/jupiter/jupiter.c | 22 +- board/korat/config.mk | 2 +- board/korat/init.S | 22 +- board/korat/korat.c | 92 ++-- board/korat/u-boot.lds | 2 +- board/kup/common/flash.c | 26 +- board/kup/common/kup.c | 6 +- board/kup/common/load_sernum_ethaddr.c | 16 +- board/kup/common/pcmcia.c | 20 +- board/kup/kup4k/kup4k.c | 24 +- board/kup/kup4x/kup4x.c | 24 +- board/lantec/flash.c | 40 +- board/lantec/lantec.c | 20 +- board/lart/flash.c | 16 +- board/linkstation/avr.c | 8 +- board/linkstation/hwctl.c | 2 +- board/linkstation/ide.c | 4 +- board/linkstation/linkstation.c | 2 +- board/logodl/flash.c | 24 +- board/logodl/logodl.c | 8 +- board/logodl/lowlevel_init.S | 66 ++-- board/lpc2292sodimm/flash.c | 2 +- board/lpd7a40x/flash.c | 18 +- board/lubbock/flash.c | 18 +- board/lubbock/lowlevel_init.S | 66 ++-- board/lwmon/flash.c | 66 ++-- board/lwmon/lwmon.c | 58 ++-- board/lwmon/pcmcia.c | 30 +- board/lwmon5/config.mk | 2 +- board/lwmon5/init.S | 26 +- board/lwmon5/kbd.c | 6 +- board/lwmon5/lwmon5.c | 88 ++-- board/lwmon5/sdram.c | 18 +- board/lwmon5/u-boot.lds | 2 +- board/m501sk/eeprom.c | 16 +- board/matrix_vision/mvbc_p/mvbc_p.c | 12 +- board/matrix_vision/mvblm7/fpga.c | 10 +- board/matrix_vision/mvblm7/mvblm7.c | 38 +- board/matrix_vision/mvblm7/pci.c | 24 +- board/mbx8xx/csr.h | 4 +- board/mbx8xx/flash.c | 18 +- board/mbx8xx/mbx8xx.c | 44 +- board/mbx8xx/pcmcia.c | 8 +- board/mbx8xx/vpd.c | 6 +- board/mcc200/auto_update.c | 6 +- board/mcc200/mcc200.c | 34 +- board/mgcoge/mgcoge.c | 30 +- board/mgsuvd/mgsuvd.c | 16 +- board/ml2/flash.c | 10 +- board/ml2/serial.c | 28 +- board/modnet50/flash.c | 20 +- board/motionpro/motionpro.c | 14 +- board/mousse/flash.c | 2 +- board/mousse/mousse.c | 2 +- board/mousse/mousse.h | 16 +- board/mp2usb/flash.c | 24 +- board/mpc8540eval/flash.c | 38 +- board/mpc8540eval/law.c | 6 +- board/mpc8540eval/mpc8540eval.c | 70 ++-- board/mpc8540eval/tlb.c | 22 +- board/mpl/common/common_util.c | 24 +- board/mpl/common/flash.c | 22 +- board/mpl/common/isa.c | 36 +- board/mpl/common/kbd.c | 10 +- board/mpl/common/usb_uhci.c | 2 +- board/mpl/mip405/mip405.c | 6 +- board/mpl/pati/cmd_pati.c | 4 +- board/mpl/pati/pati.c | 14 +- board/mpl/pip405/pip405.c | 6 +- board/mpl/pip405/pip405.h | 2 +- board/mpl/vcma9/flash.c | 20 +- board/mpr2/mpr2.c | 6 +- board/ms7720se/ms7720se.c | 6 +- board/ms7722se/ms7722se.c | 6 +- board/ms7750se/ms7750se.c | 6 +- board/muas3001/muas3001.c | 32 +- board/mucmc52/mucmc52.c | 62 ++-- board/munices/munices.c | 14 +- board/musenki/flash.c | 42 +- board/musenki/musenki.c | 2 +- board/mvblue/flash.c | 8 +- board/mvblue/mvblue.c | 18 +- board/mx1ads/syncflash.c | 30 +- board/mx1fs2/flash.c | 24 +- board/mx1fs2/lowlevel_init.S | 34 +- board/nc650/flash.c | 46 +- board/nc650/nc650.c | 30 +- board/netphone/flash.c | 28 +- board/netphone/netphone.c | 30 +- board/netphone/phone_console.c | 32 +- board/netstal/hcu4/hcu4.c | 2 +- board/netstal/hcu5/README.txt | 6 +- board/netstal/hcu5/hcu5.c | 24 +- board/netstal/hcu5/init.S | 20 +- board/netstal/hcu5/sdram.c | 6 +- board/netstal/hcu5/u-boot.lds | 2 +- board/netstal/mcu25/mcu25.c | 8 +- board/netstar/flash.c | 26 +- board/netta/codec.c | 6 +- board/netta/dsp.c | 12 +- board/netta/flash.c | 20 +- board/netta/netta.c | 16 +- board/netta/pcmcia.c | 38 +- board/netta2/flash.c | 20 +- board/netta2/netta2.c | 22 +- board/netvia/flash.c | 20 +- board/netvia/netvia.c | 18 +- board/ns9750dev/flash.c | 18 +- board/nx823/flash.c | 32 +- board/nx823/nx823.c | 48 +- board/o2dnt/flash.c | 32 +- board/o2dnt/o2dnt.c | 14 +- board/omap1610inn/flash.c | 24 +- board/omap2420h4/mem.c | 4 +- board/omap2420h4/omap2420h4.c | 18 +- board/omap730p2/flash.c | 18 +- board/oxc/flash.c | 16 +- board/oxc/oxc.c | 30 +- board/pb1x00/flash.c | 2 +- board/pb1x00/pb1x00.c | 6 +- board/pcippc2/cpc710_init_ram.c | 6 +- board/pcippc2/flash.c | 28 +- board/pcippc2/i2c.c | 2 +- board/pcippc2/sconsole.c | 2 +- board/pcippc2/sconsole.h | 2 +- board/pcs440ep/config.mk | 2 +- board/pcs440ep/flash.c | 146 +++--- board/pcs440ep/init.S | 16 +- board/pcs440ep/pcs440ep.c | 30 +- board/pleb2/flash.c | 32 +- board/pleb2/lowlevel_init.S | 84 ++-- board/pm520/flash.c | 38 +- board/pm520/pm520.c | 30 +- board/pm826/flash.c | 18 +- board/pm826/pm826.c | 28 +- board/pm828/flash.c | 18 +- board/pm828/pm828.c | 28 +- board/pm854/law.c | 10 +- board/pm854/pm854.c | 44 +- board/pm854/tlb.c | 22 +- board/pm856/law.c | 10 +- board/pm856/pm856.c | 42 +- board/pm856/tlb.c | 22 +- board/pn62/pn62.c | 2 +- board/ppmc7xx/flash.c | 16 +- board/ppmc7xx/pci.c | 30 +- board/ppmc7xx/ppmc7xx.c | 2 +- board/ppmc8260/ppmc8260.c | 34 +- board/ppmc8260/strataflash.c | 22 +- board/prodrive/alpr/alpr.c | 34 +- board/prodrive/alpr/config.mk | 2 +- board/prodrive/alpr/fpga.c | 70 ++-- board/prodrive/alpr/init.S | 24 +- board/prodrive/alpr/nand.c | 2 +- board/prodrive/common/flash.c | 130 +++--- board/prodrive/common/fpga.c | 10 +- board/prodrive/p3mx/misc.S | 26 +- board/prodrive/p3mx/mpsc.c | 6 +- board/prodrive/p3mx/p3mx.c | 98 ++-- board/prodrive/p3mx/pci.c | 20 +- board/prodrive/p3mx/sdram_init.c | 6 +- board/prodrive/p3p440/config.mk | 2 +- board/prodrive/p3p440/init.S | 12 +- board/prodrive/p3p440/p3p440.c | 32 +- board/prodrive/p3p440/p3p440.h | 10 +- board/prodrive/pdnb3/flash.c | 10 +- board/prodrive/pdnb3/nand.c | 2 +- board/prodrive/pdnb3/pdnb3.c | 64 ++-- board/psyent/common/AMDLV065D.c | 14 +- board/psyent/pk1c20/led.c | 6 +- board/purple/flash.c | 20 +- board/purple/purple.c | 16 +- board/purple/sconsole.c | 2 +- board/purple/sconsole.h | 2 +- board/pxa255_idp/lowlevel_init.S | 66 ++-- board/pxa255_idp/pxa_idp.c | 2 +- board/pxa255_idp/pxa_reg_calcs.out | 30 +- board/pxa255_idp/pxa_reg_calcs.py | 12 +- board/quad100hd/nand.c | 8 +- board/quantum/fpga.c | 10 +- board/quantum/quantum.c | 22 +- board/r2dplus/r2dplus.c | 6 +- board/r360mpi/flash.c | 32 +- board/r360mpi/pcmcia.c | 16 +- board/r360mpi/r360mpi.c | 40 +- board/r7780mp/r7780mp.c | 6 +- board/rattler/rattler.c | 90 ++-- board/rbc823/flash.c | 18 +- board/rbc823/kbd.c | 20 +- board/rbc823/rbc823.c | 32 +- board/rmu/flash.c | 22 +- board/rmu/rmu.c | 16 +- board/rpxsuper/flash.c | 18 +- board/rpxsuper/mii_phy.c | 4 +- board/rpxsuper/rpxsuper.c | 36 +- board/rsdproto/flash.c | 18 +- board/rsdproto/rsdproto.c | 12 +- board/rsk7203/rsk7203.c | 6 +- board/sacsng/clkinit.c | 28 +- board/sacsng/flash.c | 28 +- board/sacsng/sacsng.c | 24 +- board/samsung/smdk6400/smdk6400.c | 6 +- board/sandburst/common/flash.c | 12 +- board/sandburst/common/ppc440gx_i2c.c | 20 +- board/sandburst/common/ppc440gx_i2c.h | 2 +- board/sandburst/common/sb_common.c | 24 +- board/sandburst/karef/config.mk | 2 +- board/sandburst/karef/init.S | 16 +- board/sandburst/karef/karef.c | 22 +- board/sandburst/metrobox/config.mk | 2 +- board/sandburst/metrobox/init.S | 16 +- board/sandburst/metrobox/metrobox.c | 16 +- board/sandpoint/early_init.S | 96 ++-- board/sandpoint/flash.c | 22 +- board/sandpoint/sandpoint.c | 2 +- board/sbc2410x/flash.c | 20 +- board/sbc405/strataflash.c | 26 +- board/sbc8240/flash.c | 10 +- board/sbc8240/sbc8240.c | 8 +- board/sbc8260/flash.c | 18 +- board/sbc8260/sbc8260.c | 22 +- board/sbc8349/pci.c | 78 ++-- board/sbc8349/sbc8349.c | 54 ++-- board/sbc8548/law.c | 8 +- board/sbc8548/sbc8548.c | 104 ++-- board/sbc8548/tlb.c | 22 +- board/sbc8560/law.c | 6 +- board/sbc8560/sbc8560.c | 62 ++-- board/sbc8560/tlb.c | 10 +- board/sbc8641d/law.c | 14 +- board/sbc8641d/sbc8641d.c | 140 +++--- board/sc3/sc3nand.c | 2 +- board/sc520_cdp/flash.c | 6 +- board/sc520_cdp/flash_old.c | 6 +- board/sc520_cdp/sc520_cdp.c | 12 +- board/sc520_spunk/flash.c | 10 +- board/sc520_spunk/sc520_spunk.c | 8 +- board/scb9328/flash.c | 18 +- board/scb9328/lowlevel_init.S | 38 +- board/sh7763rdp/sh7763rdp.c | 6 +- board/sh7785lcr/sh7785lcr.c | 6 +- board/shannon/flash.c | 28 +- board/siemens/CCM/ccm.c | 80 ++-- board/siemens/CCM/flash.c | 38 +- board/siemens/CCM/fpga_ccm.c | 4 +- board/siemens/IAD210/IAD210.c | 26 +- board/siemens/IAD210/atm.c | 24 +- board/siemens/IAD210/atm.h | 4 +- board/siemens/IAD210/flash.c | 18 +- board/siemens/SCM/config.mk | 2 +- board/siemens/SCM/flash.c | 16 +- board/siemens/SCM/fpga_scm.c | 14 +- board/siemens/SCM/scm.c | 74 ++-- board/siemens/SMN42/flash.c | 82 ++-- board/siemens/pcu_e/flash.c | 26 +- board/siemens/pcu_e/pcu_e.c | 122 +++--- board/sixnet/flash.c | 30 +- board/sixnet/sixnet.c | 22 +- board/sl8245/flash.c | 32 +- board/sl8245/sl8245.c | 6 +- board/smdk2400/flash.c | 18 +- board/smdk2410/flash.c | 20 +- board/snmc/qs850/flash.c | 22 +- board/snmc/qs850/qs850.c | 16 +- board/snmc/qs860t/flash.c | 56 ++-- board/snmc/qs860t/qs860t.c | 38 +- board/socrates/law.c | 14 +- board/socrates/nand.c | 2 +- board/socrates/sdram.c | 32 +- board/socrates/socrates.c | 118 +++--- board/socrates/tlb.c | 26 +- board/sorcery/sorcery.c | 2 +- board/spc1920/hpi.c | 16 +- board/spc1920/spc1920.c | 36 +- board/spd8xx/flash.c | 2 +- board/spd8xx/spd8xx.c | 42 +- board/ssv/adnpesc1/adnpesc1.c | 4 +- board/ssv/adnpesc1/config.mk | 2 +- board/ssv/adnpesc1/flash.c | 8 +- board/ssv/adnpesc1/vectors.S | 8 +- board/ssv/common/flash.c | 22 +- board/ssv/common/post.c | 8 +- board/stxgp3/flash.c | 26 +- board/stxgp3/law.c | 10 +- board/stxgp3/stxgp3.c | 14 +- board/stxgp3/tlb.c | 28 +- board/stxssa/law.c | 12 +- board/stxssa/stxssa.c | 14 +- board/stxssa/tlb.c | 22 +- board/stxxtc/stxxtc.c | 18 +- board/svm_sc8xx/flash.c | 54 ++-- board/svm_sc8xx/svm_sc8xx.c | 12 +- board/tb0229/flash.c | 58 ++-- board/tb0229/tb0229.c | 2 +- board/total5200/sdram.c | 28 +- board/total5200/total5200.c | 8 +- board/tqc/tqm5200/cam5200_flash.c | 176 ++++---- board/tqc/tqm5200/cmd_stk52xx.c | 12 +- board/tqc/tqm5200/tqm5200.c | 58 ++-- board/tqc/tqm8260/config.mk | 2 +- board/tqc/tqm8260/flash.c | 16 +- board/tqc/tqm8260/tqm8260.c | 46 +- board/tqc/tqm8272/config.mk | 2 +- board/tqc/tqm8272/nand.c | 20 +- board/tqc/tqm8272/tqm8272.c | 66 ++-- board/tqc/tqm834x/pci.c | 34 +- board/tqc/tqm834x/tqm834x.c | 22 +- board/tqc/tqm85xx/law.c | 16 +- board/tqc/tqm85xx/nand.c | 14 +- board/tqc/tqm85xx/sdram.c | 12 +- board/tqc/tqm85xx/tlb.c | 82 ++-- board/tqc/tqm85xx/tqm85xx.c | 92 ++-- board/tqc/tqm8xx/load_sernum_ethaddr.c | 10 +- board/tqc/tqm8xx/tqm8xx.c | 82 ++-- board/trab/auto_update.c | 6 +- board/trab/flash.c | 28 +- board/trab/memory.c | 6 +- board/trab/trab.c | 8 +- board/trizepsiv/lowlevel_init.S | 94 ++-- board/uc100/pcmcia.c | 18 +- board/uc100/uc100.c | 22 +- board/uc101/uc101.c | 20 +- board/utx8245/flash.c | 32 +- board/utx8245/utx8245.c | 2 +- board/v37/flash.c | 30 +- board/v37/v37.c | 8 +- board/v38b/v38b.c | 18 +- board/versatile/flash.c | 18 +- board/w7o/cmd_vpd.c | 2 +- board/w7o/flash.c | 22 +- board/w7o/init.S | 20 +- board/w7o/post2.c | 8 +- board/w7o/vpd.c | 6 +- board/w7o/w7o.c | 4 +- board/w7o/watchdog.c | 2 +- board/wepep250/flash.c | 18 +- board/westel/amx860/amx860.c | 2 +- board/westel/amx860/flash.c | 40 +- board/xaeniax/flash.c | 18 +- board/xaeniax/lowlevel_init.S | 66 ++-- board/xilinx/ml300/serial.c | 12 +- board/xilinx/ml401/ml401.c | 18 +- board/xilinx/ppc440-generic/u-boot-ram.lds | 2 +- board/xilinx/ppc440-generic/u-boot-rom.lds | 2 +- .../xilinx/ppc440-generic/xilinx_ppc440_generic.c | 2 +- board/xilinx/xilinx_iic/iic_adapter.c | 6 +- board/xilinx/xupv2p/xupv2p.c | 12 +- board/xm250/flash.c | 22 +- board/xm250/lowlevel_init.S | 86 ++-- board/xpedite1k/config.mk | 2 +- board/xpedite1k/flash.c | 12 +- board/xpedite1k/init.S | 12 +- board/xpedite1k/xpedite1k.c | 24 +- board/xsengine/flash.c | 10 +- board/xsengine/lowlevel_init.S | 68 ++-- board/zeus/update.c | 4 +- board/zeus/zeus.c | 44 +- board/zpc1900/zpc1900.c | 60 ++-- board/zylonite/flash.c | 18 +- board/zylonite/lowlevel_init.S | 14 +- board/zylonite/nand.c | 20 +- common/ACEX1K.c | 16 +- common/cmd_autoscript.c | 6 +- common/cmd_bdinfo.c | 30 +- common/cmd_bedbug.c | 2 +- common/cmd_bmp.c | 10 +- common/cmd_boot.c | 2 +- common/cmd_bootm.c | 20 +- common/cmd_date.c | 2 +- common/cmd_diag.c | 2 +- common/cmd_display.c | 8 +- common/cmd_doc.c | 30 +- common/cmd_dtt.c | 2 +- common/cmd_eeprom.c | 86 ++-- common/cmd_elf.c | 8 +- common/cmd_ext2.c | 2 +- common/cmd_fat.c | 2 +- common/cmd_fdc.c | 32 +- common/cmd_fdos.c | 4 +- common/cmd_fdt.c | 4 +- common/cmd_flash.c | 104 ++-- common/cmd_i2c.c | 20 +- common/cmd_ide.c | 156 +++--- common/cmd_immap.c | 12 +- common/cmd_jffs2.c | 10 +- common/cmd_load.c | 40 +- common/cmd_log.c | 2 +- common/cmd_mem.c | 18 +- common/cmd_misc.c | 2 +- common/cmd_mp.c | 2 +- common/cmd_nand.c | 38 +- common/cmd_nvedit.c | 20 +- common/cmd_pci.c | 2 +- common/cmd_pcmcia.c | 4 +- common/cmd_reginfo.c | 6 +- common/cmd_reiser.c | 2 +- common/cmd_sata.c | 14 +- common/cmd_scsi.c | 20 +- common/cmd_usb.c | 2 +- common/command.c | 28 +- common/console.c | 40 +- common/cyclon2.c | 16 +- common/devices.c | 14 +- common/env_common.c | 6 +- common/env_eeprom.c | 10 +- common/env_embedded.c | 8 +- common/env_nvram.c | 14 +- common/flash.c | 14 +- common/hush.c | 14 +- common/image.c | 30 +- common/kgdb.c | 2 +- common/lcd.c | 14 +- common/main.c | 44 +- common/miiphyutil.c | 2 +- common/serial.c | 14 +- common/spartan2.c | 44 +- common/spartan3.c | 44 +- common/usb_kbd.c | 6 +- common/virtex2.c | 68 ++-- cpu/74xx_7xx/cache.S | 4 +- cpu/74xx_7xx/cpu.c | 20 +- cpu/74xx_7xx/interrupts.c | 2 +- cpu/74xx_7xx/kgdb.S | 10 +- cpu/74xx_7xx/speed.c | 4 +- cpu/74xx_7xx/start.S | 176 ++++---- cpu/arm1136/cpu.c | 2 +- cpu/arm1136/mx31/interrupts.c | 10 +- cpu/arm1136/mx31/serial.c | 12 +- cpu/arm1136/omap24xx/interrupts.c | 18 +- cpu/arm1136/start.S | 16 +- cpu/arm1176/s3c64xx/interrupts.c | 4 +- cpu/arm1176/start.S | 26 +- cpu/arm720t/cpu.c | 2 +- cpu/arm720t/interrupts.c | 18 +- cpu/arm720t/lpc2292/flash.c | 4 +- cpu/arm720t/serial.c | 2 +- cpu/arm720t/serial_netarm.c | 2 +- cpu/arm720t/start.S | 12 +- cpu/arm920t/at91rm9200/i2c.c | 6 +- cpu/arm920t/at91rm9200/interrupts.c | 8 +- cpu/arm920t/at91rm9200/lowlevel_init.S | 2 +- cpu/arm920t/at91rm9200/spi.c | 4 +- cpu/arm920t/at91rm9200/usb.c | 4 +- cpu/arm920t/cpu.c | 2 +- cpu/arm920t/imx/interrupts.c | 2 +- cpu/arm920t/interrupts.c | 2 +- cpu/arm920t/s3c24x0/i2c.c | 8 +- cpu/arm920t/s3c24x0/interrupts.c | 2 +- cpu/arm920t/s3c24x0/usb.c | 4 +- cpu/arm920t/start.S | 12 +- cpu/arm925t/cpu.c | 2 +- cpu/arm925t/interrupts.c | 18 +- cpu/arm925t/start.S | 12 +- cpu/arm926ejs/at91/spi.c | 8 +- cpu/arm926ejs/at91/timer.c | 2 +- cpu/arm926ejs/at91/usb.c | 4 +- cpu/arm926ejs/cpu.c | 2 +- cpu/arm926ejs/davinci/i2c.c | 2 +- cpu/arm926ejs/davinci/nand.c | 48 +- cpu/arm926ejs/davinci/timer.c | 8 +- cpu/arm926ejs/omap/timer.c | 18 +- cpu/arm926ejs/start.S | 12 +- cpu/arm926ejs/versatile/timer.c | 20 +- cpu/arm946es/cpu.c | 2 +- cpu/arm946es/interrupts.c | 6 +- cpu/arm946es/start.S | 12 +- cpu/arm_intcm/cpu.c | 2 +- cpu/arm_intcm/start.S | 12 +- cpu/at32ap/at32ap700x/clk.c | 24 +- cpu/at32ap/at32ap700x/gpio.c | 4 +- cpu/at32ap/cache.c | 8 +- cpu/at32ap/cpu.c | 10 +- cpu/at32ap/hsdramc.c | 4 +- cpu/at32ap/interrupts.c | 4 +- cpu/at32ap/start.S | 2 +- cpu/blackfin/interrupts.c | 2 +- cpu/blackfin/start.S | 8 +- cpu/blackfin/traps.c | 4 +- cpu/i386/interrupts.c | 2 +- cpu/i386/sc520.c | 12 +- cpu/i386/sc520_asm.S | 12 +- cpu/i386/start.S | 4 +- cpu/i386/timer.c | 4 +- cpu/ixp/cpu.c | 6 +- cpu/ixp/interrupts.c | 4 +- cpu/ixp/npe/include/npe.h | 6 +- cpu/ixp/npe/npe.c | 12 +- cpu/ixp/serial.c | 12 +- cpu/ixp/start.S | 22 +- cpu/ixp/timer.c | 2 +- cpu/leon2/interrupts.c | 8 +- cpu/leon2/prom.c | 50 +- cpu/leon2/serial.c | 2 +- cpu/leon2/start.S | 36 +- cpu/leon3/cpu_init.c | 20 +- cpu/leon3/interrupts.c | 8 +- cpu/leon3/prom.c | 52 +- cpu/leon3/serial.c | 2 +- cpu/leon3/start.S | 34 +- cpu/lh7a40x/cpu.c | 2 +- cpu/lh7a40x/interrupts.c | 10 +- cpu/lh7a40x/start.S | 12 +- cpu/mcf5227x/cpu_init.c | 58 ++-- cpu/mcf5227x/interrupts.c | 8 +- cpu/mcf5227x/speed.c | 4 +- cpu/mcf5227x/start.S | 28 +- cpu/mcf523x/cpu.c | 2 +- cpu/mcf523x/cpu_init.c | 72 ++-- cpu/mcf523x/interrupts.c | 8 +- cpu/mcf523x/speed.c | 2 +- cpu/mcf523x/start.S | 40 +- cpu/mcf52x2/cpu.c | 14 +- cpu/mcf52x2/cpu_init.c | 356 +++++++------- cpu/mcf52x2/interrupts.c | 14 +- cpu/mcf52x2/speed.c | 12 +- cpu/mcf52x2/start.S | 76 ++-- cpu/mcf532x/cpu.c | 2 +- cpu/mcf532x/cpu_init.c | 50 +- cpu/mcf532x/interrupts.c | 8 +- cpu/mcf532x/speed.c | 4 +- cpu/mcf532x/start.S | 38 +- cpu/mcf5445x/cpu_init.c | 56 ++-- cpu/mcf5445x/dspi.c | 32 +- cpu/mcf5445x/interrupts.c | 8 +- cpu/mcf5445x/pci.c | 62 ++-- cpu/mcf5445x/speed.c | 14 +- cpu/mcf5445x/start.S | 80 ++-- cpu/mcf547x_8x/cpu.c | 2 +- cpu/mcf547x_8x/cpu_init.c | 52 +- cpu/mcf547x_8x/interrupts.c | 8 +- cpu/mcf547x_8x/pci.c | 38 +- cpu/mcf547x_8x/slicetimer.c | 18 +- cpu/mcf547x_8x/speed.c | 2 +- cpu/mcf547x_8x/start.S | 34 +- cpu/microblaze/exception.c | 2 +- cpu/microblaze/interrupts.c | 22 +- cpu/microblaze/start.S | 14 +- cpu/microblaze/timer.c | 12 +- cpu/mips/au1x00_eth.c | 2 +- cpu/mips/au1x00_serial.c | 2 +- cpu/mips/cache.S | 16 +- cpu/mips/cpu.c | 2 +- cpu/mips/start.S | 12 +- cpu/mpc512x/cpu.c | 6 +- cpu/mpc512x/cpu_init.c | 10 +- cpu/mpc512x/i2c.c | 4 +- cpu/mpc512x/interrupts.c | 2 +- cpu/mpc512x/iopin.c | 2 +- cpu/mpc512x/serial.c | 18 +- cpu/mpc512x/speed.c | 4 +- cpu/mpc512x/start.S | 56 ++-- cpu/mpc5xx/cpu.c | 18 +- cpu/mpc5xx/cpu_init.c | 48 +- cpu/mpc5xx/interrupts.c | 12 +- cpu/mpc5xx/serial.c | 12 +- cpu/mpc5xx/speed.c | 4 +- cpu/mpc5xx/spi.c | 16 +- cpu/mpc5xx/start.S | 42 +- cpu/mpc5xxx/cpu.c | 2 +- cpu/mpc5xxx/cpu_init.c | 120 +++--- cpu/mpc5xxx/firmware_sc_task_bestcomm.impl.S | 8 +- cpu/mpc5xxx/i2c.c | 6 +- cpu/mpc5xxx/interrupts.c | 2 +- cpu/mpc5xxx/pci_mpc5200.c | 10 +- cpu/mpc5xxx/serial.c | 4 +- cpu/mpc5xxx/speed.c | 8 +- cpu/mpc5xxx/start.S | 62 ++-- cpu/mpc5xxx/usb.c | 4 +- cpu/mpc8220/cpu.c | 2 +- cpu/mpc8220/cpu_init.c | 64 ++-- cpu/mpc8220/dramSetup.c | 14 +- cpu/mpc8220/interrupts.c | 2 +- cpu/mpc8220/pci.c | 4 +- cpu/mpc8220/speed.c | 14 +- cpu/mpc8220/start.S | 34 +- cpu/mpc824x/cpu.c | 12 +- cpu/mpc824x/cpu_init.c | 230 +++++----- cpu/mpc824x/drivers/epic/epic1.c | 4 +- cpu/mpc824x/drivers/i2c/i2c.c | 4 +- cpu/mpc824x/interrupts.c | 4 +- cpu/mpc824x/start.S | 90 ++-- cpu/mpc8260/commproc.c | 18 +- cpu/mpc8260/cpu.c | 20 +- cpu/mpc8260/cpu_init.c | 106 +++--- cpu/mpc8260/ether_fcc.c | 24 +- cpu/mpc8260/ether_scc.c | 16 +- cpu/mpc8260/i2c.c | 28 +- cpu/mpc8260/interrupts.c | 12 +- cpu/mpc8260/kgdb.S | 8 +- cpu/mpc8260/pci.c | 100 ++-- cpu/mpc8260/serial_scc.c | 14 +- cpu/mpc8260/serial_smc.c | 14 +- cpu/mpc8260/speed.c | 4 +- cpu/mpc8260/spi.c | 20 +- cpu/mpc8260/start.S | 118 +++--- cpu/mpc8260/traps.c | 4 +- cpu/mpc83xx/cpu.c | 16 +- cpu/mpc83xx/cpu_init.c | 202 ++++---- cpu/mpc83xx/ecc.c | 4 +- cpu/mpc83xx/fdt.c | 6 +- cpu/mpc83xx/interrupts.c | 4 +- cpu/mpc83xx/nand_init.c | 40 +- cpu/mpc83xx/pci.c | 8 +- cpu/mpc83xx/qe_io.c | 2 +- cpu/mpc83xx/serdes.c | 2 +- cpu/mpc83xx/spd_sdram.c | 28 +- cpu/mpc83xx/speed.c | 2 +- cpu/mpc83xx/start.S | 246 +++++----- cpu/mpc83xx/traps.c | 4 +- cpu/mpc85xx/commproc.c | 16 +- cpu/mpc85xx/cpu.c | 18 +- cpu/mpc85xx/cpu_init.c | 88 ++-- cpu/mpc85xx/ddr-gen1.c | 4 +- cpu/mpc85xx/ddr-gen2.c | 2 +- cpu/mpc85xx/ddr-gen3.c | 4 +- cpu/mpc85xx/ether_fcc.c | 26 +- cpu/mpc85xx/fdt.c | 6 +- cpu/mpc85xx/interrupts.c | 4 +- cpu/mpc85xx/mp.c | 10 +- cpu/mpc85xx/mpc8536_serdes.c | 4 +- cpu/mpc85xx/pci.c | 62 ++-- cpu/mpc85xx/qe_io.c | 2 +- cpu/mpc85xx/serial_scc.c | 8 +- cpu/mpc85xx/speed.c | 6 +- cpu/mpc85xx/start.S | 48 +- cpu/mpc85xx/tlb.c | 2 +- cpu/mpc85xx/traps.c | 2 +- cpu/mpc86xx/cache.S | 4 +- cpu/mpc86xx/cpu.c | 30 +- cpu/mpc86xx/cpu_init.c | 92 ++-- cpu/mpc86xx/ddr-8641.c | 4 +- cpu/mpc86xx/fdt.c | 4 +- cpu/mpc86xx/interrupts.c | 6 +- cpu/mpc86xx/speed.c | 2 +- cpu/mpc86xx/start.S | 100 ++-- cpu/mpc8xx/commproc.c | 12 +- cpu/mpc8xx/cpu.c | 32 +- cpu/mpc8xx/cpu_init.c | 126 +++--- cpu/mpc8xx/fec.c | 40 +- cpu/mpc8xx/i2c.c | 44 +- cpu/mpc8xx/interrupts.c | 16 +- cpu/mpc8xx/kgdb.S | 8 +- cpu/mpc8xx/lcd.c | 50 +- cpu/mpc8xx/scc.c | 8 +- cpu/mpc8xx/serial.c | 50 +- cpu/mpc8xx/speed.c | 28 +- cpu/mpc8xx/spi.c | 40 +- cpu/mpc8xx/start.S | 22 +- cpu/mpc8xx/upatch.c | 22 +- cpu/mpc8xx/video.c | 10 +- cpu/mpc8xxx/ddr/ddr.h | 14 +- cpu/nios/asmi.c | 6 +- cpu/nios/interrupts.c | 20 +- cpu/nios/serial.c | 8 +- cpu/nios/spi.c | 24 +- cpu/nios/start.S | 16 +- cpu/nios2/cpu.c | 8 +- cpu/nios2/epcs.c | 4 +- cpu/nios2/interrupts.c | 22 +- cpu/nios2/serial.c | 8 +- cpu/nios2/start.S | 24 +- cpu/nios2/sysid.c | 6 +- cpu/ppc4xx/40x_spd_sdram.c | 10 +- cpu/ppc4xx/44x_spd_ddr.c | 22 +- cpu/ppc4xx/44x_spd_ddr2.c | 80 ++-- cpu/ppc4xx/4xx_enet.c | 20 +- cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 8 +- cpu/ppc4xx/4xx_pci.c | 44 +- cpu/ppc4xx/4xx_pcie.c | 144 +++--- cpu/ppc4xx/4xx_uart.c | 44 +- cpu/ppc4xx/cache.S | 4 +- cpu/ppc4xx/commproc.c | 12 +- cpu/ppc4xx/cpu.c | 6 +- cpu/ppc4xx/cpu_init.c | 100 ++-- cpu/ppc4xx/denali_data_eye.c | 2 +- cpu/ppc4xx/denali_spd_ddr2.c | 22 +- cpu/ppc4xx/ecc.c | 4 +- cpu/ppc4xx/ecc.h | 6 +- cpu/ppc4xx/gpio.c | 8 +- cpu/ppc4xx/i2c.c | 24 +- cpu/ppc4xx/ndfc.c | 10 +- cpu/ppc4xx/sdram.c | 46 +- cpu/ppc4xx/sdram.h | 20 +- cpu/ppc4xx/start.S | 344 +++++++------- cpu/ppc4xx/usb.c | 4 +- cpu/ppc4xx/usb_ohci.c | 6 +- cpu/ppc4xx/usbdev.h | 44 +- cpu/pxa/cpu.c | 2 +- cpu/pxa/i2c.c | 8 +- cpu/pxa/interrupts.c | 6 +- cpu/pxa/mmc.c | 10 +- cpu/pxa/pxafb.c | 30 +- cpu/pxa/start.S | 40 +- cpu/pxa/usb.c | 4 +- cpu/s3c44b0/interrupts.c | 6 +- cpu/s3c44b0/start.S | 4 +- cpu/sa1100/cpu.c | 2 +- cpu/sa1100/interrupts.c | 6 +- cpu/sa1100/start.S | 14 +- cpu/sh2/start.S | 4 +- cpu/sh2/time.c | 4 +- cpu/sh3/start.S | 4 +- cpu/sh3/time.c | 4 +- cpu/sh4/start.S | 4 +- cpu/sh4/time.c | 4 +- disk/part.c | 2 +- doc/I2C_Edge_Conditions | 2 +- doc/README.JFFS2 | 12 +- doc/README.JFFS2_NAND | 2 +- doc/README.MBX | 4 +- doc/README.MPC866 | 4 +- doc/README.PIP405 | 34 +- doc/README.PXA_CF | 34 +- doc/README.TQM8260 | 2 +- doc/README.adnpesc1 | 14 +- doc/README.adnpesc1_base32 | 148 +++--- doc/README.alaska8220 | 8 +- doc/README.cmi | 6 +- doc/README.dk1c20_std32 | 104 ++-- doc/README.dk1s10_mldk20 | 78 ++-- doc/README.dk1s10_std32 | 104 ++-- doc/README.dk1s40_std32 | 104 ++-- doc/README.dk20k200_std32 | 60 ++-- doc/README.ebony | 2 +- doc/README.generic_usb_ohci | 14 +- doc/README.lynxkdi | 6 +- doc/README.m52277evb | 26 +- doc/README.m5253evbe | 6 +- doc/README.m5373evb | 36 +- doc/README.m54455evb | 82 ++-- doc/README.m5475evb | 56 ++-- doc/README.m68k | 54 ++-- doc/README.marubun-pcmcia | 16 +- doc/README.mpc8313erdb | 2 +- doc/README.mpc8315erdb | 2 +- doc/README.mpc8641hpcn | 42 +- doc/README.nand | 6 +- doc/README.nios | 42 +- doc/README.nios_CFG_NIOS_CPU | 140 ------ doc/README.ppc440 | 30 +- doc/README.serial_multi | 2 +- doc/README.sha1 | 2 +- doc/README.silent | 2 +- doc/uImage.FIT/command_syntax_extensions.txt | 2 +- drivers/block/ahci.c | 2 +- drivers/block/ata_piix.c | 30 +- drivers/block/ata_piix.h | 2 +- drivers/block/fsl_sata.c | 16 +- drivers/block/sata_sil3114.c | 4 +- drivers/block/sil680.c | 28 +- drivers/block/sym53c8xx.c | 6 +- drivers/block/systemace.c | 28 +- drivers/hwmon/adm1021.c | 4 +- drivers/hwmon/ds1621.c | 10 +- drivers/hwmon/ds1775.c | 6 +- drivers/hwmon/lm73.c | 4 +- drivers/hwmon/lm75.c | 14 +- drivers/hwmon/lm81.c | 6 +- drivers/i2c/fsl_i2c.c | 22 +- drivers/i2c/mxc_i2c.c | 8 +- drivers/i2c/omap1510_i2c.c | 4 +- drivers/i2c/omap24xx_i2c.c | 4 +- drivers/i2c/soft_i2c.c | 28 +- drivers/i2c/tsi108_i2c.c | 20 +- drivers/input/i8042.c | 6 +- drivers/input/keyboard.c | 4 +- drivers/input/ps2ser.c | 12 +- drivers/misc/fsl_law.c | 6 +- drivers/misc/ns87308.c | 72 ++-- drivers/mmc/atmel_mci.c | 22 +- drivers/mtd/cfi_flash.c | 102 ++-- drivers/mtd/dataflash.c | 14 +- drivers/mtd/jedec_flash.c | 8 +- drivers/mtd/nand/fsl_elbc_nand.c | 2 +- drivers/mtd/nand/nand.c | 14 +- drivers/mtd/nand/nand_base.c | 6 +- drivers/mtd/nand/s3c64xx.c | 12 +- drivers/mtd/nand_legacy/nand_legacy.c | 12 +- drivers/mtd/onenand/onenand_uboot.c | 2 +- drivers/mtd/spi/spi_flash_internal.h | 6 +- drivers/mtd/spi/stmicro.c | 2 +- drivers/net/bcm570x.c | 14 +- drivers/net/bfin_mac.c | 2 +- drivers/net/cs8900.c | 6 +- drivers/net/dm9000x.c | 2 +- drivers/net/eepro100.c | 32 +- drivers/net/fsl_mcdmafec.c | 60 ++-- drivers/net/lan91c96.c | 2 +- drivers/net/macb.c | 44 +- drivers/net/mcffec.c | 64 ++-- drivers/net/ne2000.c | 2 +- drivers/net/netarm_eth.c | 4 +- drivers/net/ns7520_eth.c | 4 +- drivers/net/ns9750_eth.c | 4 +- drivers/net/phy/miiphybb.c | 6 +- drivers/net/sk98lin/h/skdrv1st.h | 2 +- drivers/net/sk98lin/h/skgehw.h | 6 +- drivers/net/sk98lin/skgeinit.c | 4 +- drivers/net/sk98lin/u-boot_compat.h | 2 +- drivers/net/smc91111.c | 2 +- drivers/net/tsec.c | 16 +- drivers/net/tsi108_eth.c | 2 +- drivers/net/vsc7385.c | 12 +- drivers/pci/pci.c | 2 +- drivers/pci/pci_auto.c | 8 +- drivers/pci/tsi108_pci.c | 38 +- drivers/pci/w83c553f.c | 4 +- drivers/pcmcia/i82365.c | 12 +- drivers/pcmcia/marubun_pcmcia.c | 32 +- drivers/pcmcia/mpc8xx_pcmcia.c | 32 +- drivers/pcmcia/pxa_pcmcia.c | 12 +- drivers/pcmcia/ti_pci1410a.c | 14 +- drivers/pcmcia/tqm8xx_pcmcia.c | 26 +- drivers/qe/uec.c | 56 ++-- drivers/rtc/ds1306.c | 16 +- drivers/rtc/ds1307.c | 10 +- drivers/rtc/ds1337.c | 8 +- drivers/rtc/ds1374.c | 18 +- drivers/rtc/ds1556.c | 2 +- drivers/rtc/ds164x.c | 2 +- drivers/rtc/ds174x.c | 2 +- drivers/rtc/ds3231.c | 4 +- drivers/rtc/isl1208.c | 4 +- drivers/rtc/m41t11.c | 48 +- drivers/rtc/m41t60.c | 16 +- drivers/rtc/m41t62.c | 6 +- drivers/rtc/m48t35ax.c | 4 +- drivers/rtc/max6900.c | 8 +- drivers/rtc/mc146818.c | 8 +- drivers/rtc/mcfrtc.c | 8 +- drivers/rtc/mpc5xxx.c | 4 +- drivers/rtc/mpc8xx.c | 4 +- drivers/rtc/pcf8563.c | 4 +- drivers/rtc/pl031.c | 8 +- drivers/rtc/rs5c372.c | 12 +- drivers/rtc/rx8025.c | 10 +- drivers/rtc/x1205.c | 4 +- drivers/serial/mcfuart.c | 10 +- drivers/serial/ns16550.c | 4 +- drivers/serial/serial.c | 42 +- drivers/spi/mpc8xxx_spi.c | 4 +- drivers/spi/soft_spi.c | 10 +- drivers/usb/sl811_usb.c | 4 +- drivers/usb/usb_ohci.c | 30 +- drivers/usb/usb_ohci.h | 6 +- drivers/usb/usbdcore_mpc8xx.c | 20 +- drivers/video/ati_radeon_fb.c | 6 +- drivers/video/cfb_console.c | 12 +- drivers/video/ct69000.c | 2 +- drivers/video/mb862xx.c | 2 +- drivers/video/smiLynxEM.c | 6 +- drivers/video/videomodes.c | 2 +- drivers/video/videomodes.h | 4 +- examples/mem_to_mem_idma2intr.c | 8 +- examples/test_burst.c | 12 +- fs/jffs2/jffs2_1pass.c | 14 +- fs/jffs2/jffs2_nand_1pass.c | 10 +- fs/jffs2/jffs2_private.h | 2 +- include/4xx_i2c.h | 4 +- include/altera.h | 16 +- include/api_public.h | 4 +- include/asm-arm/arch-davinci/nand_defs.h | 8 +- include/asm-arm/arch-omap24xx/mem.h | 10 +- include/asm-arm/global_data.h | 2 +- include/asm-avr32/arch-at32ap700x/clk.h | 14 +- include/asm-avr32/global_data.h | 2 +- include/asm-blackfin/blackfin-config-post.h | 6 +- include/asm-blackfin/blackfin-config-pre.h | 8 +- include/asm-blackfin/global_data.h | 2 +- include/asm-i386/global_data.h | 2 +- include/asm-m68k/global_data.h | 2 +- include/asm-m68k/immap.h | 346 +++++++------- include/asm-m68k/immap_5227x.h | 76 ++-- include/asm-m68k/immap_5235.h | 72 ++-- include/asm-m68k/immap_5249.h | 12 +- include/asm-m68k/immap_5253.h | 22 +- include/asm-m68k/immap_5271.h | 72 ++-- include/asm-m68k/immap_5272.h | 36 +- include/asm-m68k/immap_5275.h | 76 ++-- include/asm-m68k/immap_5282.h | 72 ++-- include/asm-m68k/immap_547x_8x.h | 60 ++-- include/asm-m68k/m5249.h | 16 +- include/asm-m68k/m5271.h | 12 +- include/asm-m68k/m5282.h | 412 ++++++++-------- include/asm-microblaze/global_data.h | 2 +- include/asm-mips/global_data.h | 2 +- include/asm-ppc/4xx_pcie.h | 14 +- include/asm-ppc/cache.h | 10 +- include/asm-ppc/cpm_8260.h | 8 +- include/asm-ppc/global_data.h | 6 +- include/asm-ppc/immap_85xx.h | 64 ++-- include/asm-ppc/immap_86xx.h | 8 +- include/asm-ppc/iopin_8260.h | 40 +- include/asm-ppc/iopin_85xx.h | 40 +- include/asm-ppc/iopin_8xx.h | 128 +++--- include/asm-ppc/status_led.h | 6 +- include/asm-sparc/asmmacro.h | 4 +- include/asm-sparc/global_data.h | 2 +- include/asm-sparc/io.h | 2 +- include/ata.h | 10 +- include/command.h | 6 +- include/common.h | 18 +- include/commproc.h | 10 +- include/configs/A3000.h | 222 +++++----- include/configs/ADCIOP.h | 86 ++-- include/configs/ADNPESC1.h | 444 +++++++++--------- include/configs/ADNPESC1_base_32.h | 396 ++++++++-------- include/configs/ADS860.h | 8 +- include/configs/AMX860.h | 104 ++-- include/configs/AP1000.h | 128 +++--- include/configs/APC405.h | 248 +++++----- include/configs/AR405.h | 122 +++--- include/configs/ASH405.h | 210 +++++----- include/configs/ATUM8548.h | 184 ++++---- include/configs/Adder.h | 102 ++-- include/configs/AdderUSB.h | 6 +- include/configs/Alaska8220.h | 194 ++++---- include/configs/AmigaOneG3SE.h | 182 ++++---- include/configs/B2.h | 76 ++-- include/configs/BAB7xx.h | 312 ++++++------ include/configs/BC3450.h | 196 ++++---- include/configs/BMW.h | 206 ++++---- include/configs/CANBT.h | 104 ++-- include/configs/CATcenter.h | 316 +++++++------- include/configs/CCM.h | 190 ++++---- include/configs/CMS700.h | 214 +++++----- include/configs/CPC45.h | 262 ++++++------ include/configs/CPCI2DP.h | 150 +++--- include/configs/CPCI405.h | 186 ++++---- include/configs/CPCI4052.h | 246 +++++----- include/configs/CPCI405AB.h | 254 +++++----- include/configs/CPCI405DT.h | 246 +++++----- include/configs/CPCI750.h | 404 ++++++++-------- include/configs/CPCIISER4.h | 128 +++--- include/configs/CPU86.h | 264 ++++++------ include/configs/CPU87.h | 270 ++++++------ include/configs/CRAYL1.h | 108 +++--- include/configs/CU824.h | 212 +++++----- include/configs/DASA_SIM.h | 84 ++-- include/configs/DB64360.h | 290 ++++++------ include/configs/DB64460.h | 290 ++++++------ include/configs/DK1C20.h | 318 +++++++------- include/configs/DK1C20_safe_32.h | 2 +- include/configs/DK1C20_standard_32.h | 256 +++++----- include/configs/DK1S10.h | 314 +++++++------- include/configs/DK1S10_mtx_ldk_20.h | 178 ++++---- include/configs/DK1S10_safe_32.h | 2 +- include/configs/DK1S10_standard_32.h | 250 +++++----- include/configs/DP405.h | 190 ++++---- include/configs/DU405.h | 168 ++++---- include/configs/DU440.h | 218 +++++----- include/configs/EB+MCF-EV123.h | 168 ++++---- include/configs/ELPPC.h | 204 ++++---- include/configs/ELPT860.h | 136 +++--- include/configs/EP1C20.h | 108 +++--- include/configs/EP1S10.h | 104 ++-- include/configs/EP1S40.h | 104 ++-- include/configs/EP88x.h | 104 ++-- include/configs/ERIC.h | 132 +++--- include/configs/ESTEEM192E.h | 142 +++--- include/configs/ETX094.h | 152 +++--- include/configs/EVB64260.h | 242 +++++----- include/configs/EXBITGEN.h | 104 ++-- include/configs/FADS823.h | 138 +++--- include/configs/FADS850SAR.h | 124 +++--- include/configs/FADS860T.h | 16 +- include/configs/FLAGADM.h | 114 +++--- include/configs/FPS850L.h | 164 ++++---- include/configs/FPS860L.h | 164 ++++---- include/configs/G2000.h | 208 ++++---- include/configs/GEN860T.h | 182 ++++---- include/configs/GENIETV.h | 124 +++--- include/configs/GTH.h | 132 +++--- include/configs/HH405.h | 296 ++++++------ include/configs/HIDDEN_DRAGON.h | 280 ++++++------ include/configs/HMI10.h | 194 ++++---- include/configs/HUB405.h | 216 +++++----- include/configs/IAD210.h | 122 +++--- include/configs/ICU862.h | 174 ++++---- include/configs/IDS8247.h | 202 ++++---- include/configs/IP860.h | 156 +++--- include/configs/IPHASE4539.h | 138 +++--- include/configs/ISPAN.h | 176 ++++---- include/configs/IVML24.h | 202 ++++---- include/configs/IVMS8.h | 190 ++++---- include/configs/IceCube.h | 226 +++++----- include/configs/JSE.h | 132 +++--- include/configs/KAREF.h | 134 +++--- include/configs/KUP4K.h | 170 ++++---- include/configs/KUP4X.h | 164 ++++---- include/configs/LANTEC.h | 120 +++--- include/configs/M52277EVB.h | 122 +++--- include/configs/M5235EVB.h | 126 +++--- include/configs/M5249EVB.h | 114 +++--- include/configs/M5253DEMO.h | 172 ++++---- include/configs/M5253EVBE.h | 144 +++--- include/configs/M5271EVB.h | 104 ++-- include/configs/M5272C3.h | 138 +++--- include/configs/M5275EVB.h | 122 +++--- include/configs/M5282EVB.h | 170 ++++---- include/configs/M5329EVB.h | 148 +++--- include/configs/M5373EVB.h | 150 +++--- include/configs/M54451EVB.h | 180 ++++---- include/configs/M54455EVB.h | 298 ++++++------ include/configs/M5475EVB.h | 198 ++++---- include/configs/M5485EVB.h | 194 ++++---- include/configs/MBX.h | 146 +++--- include/configs/MBX860T.h | 138 +++--- include/configs/METROBOX.h | 130 +++--- include/configs/MHPC.h | 146 +++--- include/configs/MIP405.h | 156 +++--- include/configs/ML2.h | 100 ++-- include/configs/MOUSSE.h | 210 +++++----- include/configs/MPC8260ADS.h | 336 +++++++------- include/configs/MPC8266ADS.h | 234 +++++----- include/configs/MPC8313ERDB.h | 352 +++++++------- include/configs/MPC8315ERDB.h | 310 ++++++------ include/configs/MPC8323ERDB.h | 374 ++++++++-------- include/configs/MPC832XEMDS.h | 382 ++++++++-------- include/configs/MPC8349EMDS.h | 492 ++++++++++---------- include/configs/MPC8349ITX.h | 374 ++++++++-------- include/configs/MPC8360EMDS.h | 404 ++++++++-------- include/configs/MPC8360ERDK.h | 320 +++++++------- include/configs/MPC837XEMDS.h | 342 +++++++------- include/configs/MPC837XERDB.h | 346 +++++++------- include/configs/MPC8536DS.h | 274 ++++++------ include/configs/MPC8540ADS.h | 274 ++++++------ include/configs/MPC8540EVAL.h | 176 ++++---- include/configs/MPC8541CDS.h | 230 +++++----- include/configs/MPC8544DS.h | 226 +++++----- include/configs/MPC8548CDS.h | 268 ++++++------ include/configs/MPC8555CDS.h | 230 +++++----- include/configs/MPC8560ADS.h | 272 ++++++------ include/configs/MPC8568MDS.h | 266 ++++++------ include/configs/MPC8572DS.h | 246 +++++----- include/configs/MPC8610HPCD.h | 344 +++++++------- include/configs/MPC8641HPCN.h | 332 +++++++------- include/configs/MPC86xADS.h | 8 +- include/configs/MPC885ADS.h | 8 +- include/configs/MUSENKI.h | 216 +++++----- include/configs/MVBC_P.h | 118 +++--- include/configs/MVBLM7.h | 298 ++++++------ include/configs/MVBLUE.h | 214 +++++----- include/configs/MVS1.h | 166 ++++---- include/configs/MigoR.h | 80 ++-- include/configs/NC650.h | 168 ++++---- include/configs/NETPHONE.h | 214 +++++----- include/configs/NETTA.h | 218 +++++----- include/configs/NETTA2.h | 202 ++++---- include/configs/NETVIA.h | 150 +++--- include/configs/NSCU.h | 198 ++++---- include/configs/NX823.h | 148 +++--- include/configs/OCRTC.h | 166 ++++---- include/configs/ORSG.h | 166 ++++---- include/configs/OXC.h | 222 +++++----- include/configs/P3G4.h | 214 +++++----- include/configs/PATI.h | 112 +++--- include/configs/PCI405.h | 236 +++++----- include/configs/PCI5441.h | 90 ++-- include/configs/PCIPPC2.h | 136 +++--- include/configs/PCIPPC6.h | 146 +++--- include/configs/PIP405.h | 150 +++--- include/configs/PK1C20.h | 134 +++--- include/configs/PLU405.h | 232 +++++----- include/configs/PM520.h | 180 ++++---- include/configs/PM826.h | 226 +++++----- include/configs/PM828.h | 220 +++++----- include/configs/PM854.h | 180 ++++---- include/configs/PM856.h | 178 ++++---- include/configs/PMC405.h | 186 ++++---- include/configs/PMC440.h | 274 ++++++------ include/configs/PN62.h | 188 ++++---- include/configs/PPChameleonEVB.h | 328 +++++++------- include/configs/QS823.h | 158 ++++---- include/configs/QS850.h | 158 ++++---- include/configs/QS860T.h | 162 ++++---- include/configs/R360MPI.h | 182 ++++---- include/configs/RBC823.h | 172 ++++---- include/configs/RPXClassic.h | 164 ++++---- include/configs/RPXlite.h | 152 +++--- include/configs/RPXlite_DW.h | 158 ++++---- include/configs/RPXsuper.h | 212 +++++----- include/configs/RRvision.h | 170 ++++---- include/configs/Rattler.h | 154 +++--- include/configs/SBC8540.h | 210 +++++----- include/configs/SCM.h | 278 ++++++------ include/configs/SL8245.h | 206 ++++---- include/configs/SM850.h | 166 ++++---- include/configs/SMN42.h | 62 ++-- include/configs/SPD823TS.h | 184 ++++---- include/configs/SX1.h | 72 ++-- include/configs/SXNI855T.h | 148 +++--- include/configs/Sandpoint8240.h | 276 ++++++------ include/configs/Sandpoint8245.h | 284 ++++++------ include/configs/TASREG.h | 184 ++++---- include/configs/TB5200.h | 198 ++++---- include/configs/TK885D.h | 212 +++++----- include/configs/TOP5200.h | 194 ++++---- include/configs/TOP860.h | 144 +++--- include/configs/TQM5200.h | 264 ++++++------ include/configs/TQM823L.h | 188 ++++---- include/configs/TQM823M.h | 188 ++++---- include/configs/TQM8260.h | 218 +++++----- include/configs/TQM8272.h | 300 ++++++------ include/configs/TQM834x.h | 342 +++++++------- include/configs/TQM850L.h | 188 ++++---- include/configs/TQM850M.h | 188 ++++---- include/configs/TQM855L.h | 188 ++++---- include/configs/TQM855M.h | 202 ++++---- include/configs/TQM85xx.h | 306 ++++++------ include/configs/TQM860L.h | 188 ++++---- include/configs/TQM860M.h | 190 ++++---- include/configs/TQM862L.h | 188 ++++---- include/configs/TQM862M.h | 188 ++++---- include/configs/TQM866M.h | 210 +++++----- include/configs/TQM885D.h | 208 ++++---- include/configs/Total5200.h | 194 ++++---- include/configs/VCMA9.h | 76 ++-- include/configs/VOH405.h | 266 ++++++------ include/configs/VOM405.h | 162 ++++---- include/configs/VoVPN-GW.h | 210 +++++----- include/configs/W7OLMC.h | 156 +++--- include/configs/W7OLMG.h | 162 ++++---- include/configs/WUH405.h | 208 ++++---- include/configs/XPEDITE1K.h | 134 +++--- include/configs/Yukon8220.h | 208 ++++---- include/configs/ZPC1900.h | 180 ++++---- include/configs/ZUMA.h | 196 ++++---- include/configs/acadia.h | 196 ++++---- include/configs/actux1.h | 80 ++-- include/configs/actux2.h | 66 ++-- include/configs/actux3.h | 66 ++-- include/configs/actux4.h | 66 ++-- include/configs/ads5121.h | 242 +++++----- include/configs/aev.h | 174 ++++---- include/configs/alpr.h | 184 ++++---- include/configs/amcc-common.h | 58 ++-- include/configs/ap325rxa.h | 96 ++-- include/configs/apollon.h | 76 ++-- include/configs/armadillo.h | 38 +- include/configs/assabet.h | 58 ++-- include/configs/at91cap9adk.h | 68 ++-- include/configs/at91rm9200dk.h | 62 ++-- include/configs/at91sam9260ek.h | 68 ++-- include/configs/at91sam9261ek.h | 64 ++-- include/configs/at91sam9263ek.h | 70 ++-- include/configs/at91sam9rlek.h | 54 ++-- include/configs/atc.h | 194 ++++---- include/configs/atngw100.h | 76 ++-- include/configs/atstk1002.h | 88 ++-- include/configs/atstk1003.h | 84 ++-- include/configs/atstk1004.h | 84 ++-- include/configs/atstk1006.h | 88 ++-- include/configs/bamboo.h | 154 +++--- include/configs/barco.h | 228 +++++----- include/configs/bf533-ezkit.h | 78 ++-- include/configs/bf533-stamp.h | 96 ++-- include/configs/bf537-stamp.h | 134 +++--- include/configs/bf561-ezkit.h | 62 ++-- include/configs/bubinga.h | 126 +++--- include/configs/c2mon.h | 176 ++++---- include/configs/canmb.h | 102 ++-- include/configs/canyonlands.h | 206 ++++---- include/configs/cerf250.h | 118 +++--- include/configs/cm4008.h | 38 +- include/configs/cm41xx.h | 38 +- include/configs/cm5200.h | 116 +++--- include/configs/cmc_pu2.h | 64 ++-- include/configs/cmi_mpc5xx.h | 104 ++-- include/configs/cobra5272.h | 148 +++--- include/configs/cogent_mpc8260.h | 144 +++--- include/configs/cogent_mpc8xx.h | 166 ++++---- include/configs/cpci5200.h | 206 ++++---- include/configs/cradle.h | 128 +++--- include/configs/csb226.h | 162 ++++---- include/configs/csb272.h | 114 +++--- include/configs/csb472.h | 112 +++--- include/configs/csb637.h | 68 ++-- include/configs/davinci_dvevm.h | 96 ++-- include/configs/davinci_schmoogie.h | 64 ++-- include/configs/davinci_sffsdr.h | 78 ++-- include/configs/davinci_sonata.h | 94 ++-- include/configs/dbau1x00.h | 80 ++-- include/configs/debris.h | 258 +++++----- include/configs/delta.h | 90 ++-- include/configs/dnp1110.h | 40 +- include/configs/eXalion.h | 286 ++++++------ include/configs/ebony.h | 74 ++-- include/configs/ep7312.h | 38 +- include/configs/ep8248.h | 178 ++++---- include/configs/ep8260.h | 336 +++++++------- include/configs/ep82xxm.h | 246 +++++----- include/configs/evb4510.h | 46 +- include/configs/favr-32-ezkit.h | 88 ++-- include/configs/gcplus.h | 56 ++-- include/configs/gr_cpci_ax2000.h | 144 +++--- include/configs/gr_ep2s60.h | 132 +++--- include/configs/gr_xc3s_1500.h | 130 +++--- include/configs/grsim.h | 134 +++--- include/configs/grsim_leon2.h | 122 +++--- include/configs/gth2.h | 74 ++-- include/configs/gw8260.h | 248 +++++----- include/configs/hammerhead.h | 76 ++-- include/configs/hcu4.h | 170 ++++---- include/configs/hcu5.h | 210 +++++----- include/configs/hermes.h | 118 +++--- include/configs/hmi1001.h | 170 ++++---- include/configs/hymod.h | 214 +++++----- include/configs/idmr.h | 96 ++-- include/configs/impa7.h | 38 +- include/configs/imx31_litekit.h | 48 +- include/configs/imx31_phycore.h | 60 ++-- include/configs/incaip.h | 50 +- include/configs/inka4x0.h | 146 +++--- include/configs/innokom.h | 120 +++--- include/configs/integratorap.h | 52 +- include/configs/integratorcp.h | 60 ++-- include/configs/ixdp425.h | 64 ++-- include/configs/ixdpg425.h | 86 ++-- include/configs/jupiter.h | 130 +++--- include/configs/katmai.h | 154 +++--- include/configs/kb9202.h | 46 +- include/configs/kilauea.h | 324 +++++++------- include/configs/korat.h | 234 +++++----- include/configs/kvme080.h | 262 ++++++------ include/configs/lart.h | 40 +- include/configs/linkstation.h | 262 ++++++------ include/configs/logodl.h | 116 +++--- include/configs/lpc2292sodimm.h | 40 +- include/configs/lpd7a400-10.h | 12 +- include/configs/lpd7a400.h | 32 +- include/configs/lpd7a404-10.h | 12 +- include/configs/lpd7a404.h | 32 +- include/configs/luan.h | 82 ++-- include/configs/lubbock.h | 118 +++--- include/configs/lwmon.h | 290 ++++++------ include/configs/lwmon5.h | 304 ++++++------ include/configs/m501sk.h | 72 ++-- include/configs/makalu.h | 216 +++++----- include/configs/mcc200.h | 172 ++++---- include/configs/mcu25.h | 178 ++++---- include/configs/mecp5200.h | 162 ++++---- include/configs/mgcoge.h | 152 +++--- include/configs/mgsuvd.h | 120 +++--- include/configs/mimc200.h | 82 ++-- include/configs/ml300.h | 66 ++-- include/configs/ml401.h | 130 +++--- include/configs/ml507.h | 8 +- include/configs/modnet50.h | 44 +- include/configs/motionpro.h | 150 +++--- include/configs/mp2usb.h | 80 ++-- include/configs/mpc7448hpc2.h | 214 +++++----- include/configs/mpr2.h | 52 +- include/configs/ms7720se.h | 82 ++-- include/configs/ms7722se.h | 82 ++-- include/configs/ms7750se.h | 64 ++-- include/configs/muas3001.h | 192 ++++---- include/configs/mucmc52.h | 200 ++++---- include/configs/munices.h | 102 ++-- include/configs/mx1ads.h | 54 ++-- include/configs/mx1fs2.h | 96 ++-- include/configs/mx31ads.h | 46 +- include/configs/netstar.h | 72 ++-- include/configs/ns9750dev.h | 44 +- include/configs/o2dnt.h | 134 +++--- include/configs/ocotea.h | 78 ++-- include/configs/omap1510inn.h | 70 ++-- include/configs/omap1610h2.h | 60 ++-- include/configs/omap1610inn.h | 58 ++-- include/configs/omap2420h4.h | 88 ++-- include/configs/omap5912osk.h | 66 ++-- include/configs/omap730p2.h | 54 ++-- include/configs/p3mx.h | 238 +++++----- include/configs/p3p440.h | 144 +++--- include/configs/pb1x00.h | 72 ++-- include/configs/pcs440ep.h | 172 ++++---- include/configs/pcu_e.h | 226 +++++----- include/configs/pdnb3.h | 162 ++++---- include/configs/pf5200.h | 188 ++++---- include/configs/pleb2.h | 140 +++--- include/configs/ppmc7xx.h | 212 +++++----- include/configs/ppmc8260.h | 250 +++++----- include/configs/purple.h | 56 ++-- include/configs/pxa255_idp.h | 124 +++--- include/configs/qemu-mips.h | 82 ++-- include/configs/quad100hd.h | 170 ++++---- include/configs/quantum.h | 170 ++++---- include/configs/r2dplus.h | 68 ++-- include/configs/r7780mp.h | 98 ++-- include/configs/redwood.h | 80 ++-- include/configs/rmu.h | 168 ++++---- include/configs/rsdproto.h | 176 ++++---- include/configs/rsk7203.h | 58 ++-- include/configs/sacsng.h | 284 ++++++------ include/configs/sbc2410x.h | 50 +- include/configs/sbc405.h | 120 +++--- include/configs/sbc8240.h | 218 +++++----- include/configs/sbc8260.h | 256 +++++----- include/configs/sbc8349.h | 432 +++++++++--------- include/configs/sbc8548.h | 260 +++++----- include/configs/sbc8560.h | 204 ++++---- include/configs/sbc8641d.h | 368 ++++++++-------- include/configs/sc3.h | 224 +++++----- include/configs/sc520_cdp.h | 82 ++-- include/configs/sc520_spunk.h | 92 ++-- include/configs/scb9328.h | 114 +++--- include/configs/sequoia.h | 226 +++++----- include/configs/sh7763rdp.h | 70 ++-- include/configs/sh7785lcr.h | 80 ++-- include/configs/shannon.h | 70 ++-- include/configs/smdk2400.h | 40 +- include/configs/smdk2410.h | 44 +- include/configs/smdk6400.h | 116 +++--- include/configs/smmaco4.h | 164 ++++---- include/configs/socrates.h | 214 +++++----- include/configs/sorcery.h | 146 +++--- include/configs/spc1920.h | 170 ++++---- include/configs/spieval.h | 208 ++++---- include/configs/stxgp3.h | 174 ++++---- include/configs/stxssa.h | 202 ++++---- include/configs/stxxtc.h | 182 ++++---- include/configs/suzaku.h | 52 +- include/configs/svm_sc8xx.h | 214 +++++----- include/configs/taihu.h | 122 +++--- include/configs/taishan.h | 90 ++-- include/configs/tb0229.h | 64 ++-- include/configs/trab.h | 98 ++-- include/configs/trizepsiv.h | 172 ++++---- include/configs/uc100.h | 210 +++++----- include/configs/uc101.h | 186 ++++---- include/configs/utx8245.h | 262 ++++++------ include/configs/v37.h | 164 ++++---- include/configs/v38b.h | 148 +++--- include/configs/v5fx30teval.h | 8 +- include/configs/versatile.h | 56 ++-- include/configs/virtlab2.h | 198 ++++---- include/configs/voiceblue.h | 72 ++-- include/configs/walnut.h | 110 +++--- include/configs/wepep250.h | 56 ++-- include/configs/xaeniax.h | 116 +++--- include/configs/xilinx-ppc440-generic.h | 8 +- include/configs/xilinx-ppc440.h | 62 ++-- include/configs/xm250.h | 146 +++--- include/configs/xsengine.h | 112 +++--- include/configs/xupv2p.h | 112 +++--- include/configs/yosemite.h | 114 +++--- include/configs/yucca.h | 104 ++-- include/configs/zeus.h | 170 ++++---- include/configs/zylonite.h | 72 ++-- include/dataflash.h | 6 +- include/dtt.h | 8 +- include/environment.h | 18 +- include/flash.h | 14 +- include/fpga.h | 10 +- include/galileo/core.h | 4 +- include/i2c.h | 18 +- include/i8042.h | 6 +- include/ide.h | 4 +- include/lcd.h | 4 +- include/lh7a40x.h | 4 +- include/miiphy.h | 2 +- include/mk48t59.h | 4 +- include/mpc106.h | 2 +- include/mpc512x.h | 2 +- include/mpc5xx.h | 2 +- include/mpc5xxx.h | 108 +++--- include/mpc8220.h | 102 ++-- include/mpc824x.h | 2 +- include/mpc86xx.h | 6 +- include/mpc8xx_irq.h | 4 +- include/nand.h | 2 +- include/net.h | 16 +- include/ns16550.h | 12 +- include/ns87308.h | 66 ++-- include/pcmcia.h | 32 +- include/post.h | 44 +- include/ppc405.h | 4 +- include/ppc440.h | 20 +- include/ppc4xx.h | 6 +- include/ppc4xx_enet.h | 18 +- include/ps2mult.h | 2 +- include/radeon.h | 10 +- include/serial.h | 4 +- include/status_led.h | 60 ++-- include/tsec.h | 10 +- include/w83c553f.h | 38 +- include/xilinx.h | 28 +- lib_arm/board.c | 22 +- lib_avr32/board.c | 38 +- lib_blackfin/board.c | 30 +- lib_blackfin/post.c | 4 +- lib_blackfin/tests.c | 76 ++-- lib_generic/vsprintf.c | 12 +- lib_i386/board.c | 4 +- lib_m68k/board.c | 66 ++-- lib_m68k/bootm.c | 4 +- lib_m68k/interrupts.c | 2 +- lib_m68k/time.c | 36 +- lib_microblaze/board.c | 26 +- lib_microblaze/time.c | 2 +- lib_mips/board.c | 34 +- lib_mips/time.c | 6 +- lib_nios/board.c | 22 +- lib_nios/mult.c | 4 +- lib_nios2/board.c | 26 +- lib_nios2/cache.S | 16 +- lib_nios2/mult.c | 4 +- lib_ppc/board.c | 98 ++-- lib_ppc/bootm.c | 18 +- lib_ppc/cache.c | 8 +- lib_ppc/extable.c | 4 +- lib_ppc/interrupts.c | 6 +- lib_ppc/time.c | 2 +- lib_sh/board.c | 20 +- lib_sh/bootm.c | 4 +- lib_sh/time.c | 4 +- lib_sparc/board.c | 68 ++-- lib_sparc/bootm.c | 4 +- nand_spl/board/amcc/acadia/config.mk | 2 +- nand_spl/board/amcc/bamboo/config.mk | 2 +- nand_spl/board/amcc/bamboo/sdram.c | 2 +- nand_spl/board/amcc/canyonlands/config.mk | 2 +- nand_spl/board/amcc/canyonlands/ddr2_fixed.c | 2 +- nand_spl/board/amcc/kilauea/config.mk | 2 +- nand_spl/board/amcc/sequoia/config.mk | 2 +- nand_spl/nand_boot.c | 58 ++-- nand_spl/nand_boot_fsl_elbc.c | 12 +- net/bootp.c | 22 +- net/net.c | 22 +- net/nfs.c | 10 +- net/rarp.c | 4 +- net/sntp.c | 2 +- net/tftp.c | 14 +- onenand_ipl/board/apollon/apollon.c | 4 +- onenand_ipl/onenand_boot.c | 10 +- onenand_ipl/onenand_ipl.h | 4 +- onenand_ipl/onenand_read.c | 2 +- post/board/lwmon/sysmon.c | 10 +- post/board/lwmon5/dsp.c | 4 +- post/board/lwmon5/dspic.c | 12 +- post/board/lwmon5/fpga.c | 6 +- post/board/lwmon5/gdc.c | 4 +- post/board/lwmon5/sysmon.c | 6 +- post/board/lwmon5/watchdog.c | 26 +- post/board/netta/codec.c | 4 +- post/board/netta/dsp.c | 4 +- post/cpu/mpc8xx/cache.c | 4 +- post/cpu/mpc8xx/cache_8xx.S | 4 +- post/cpu/mpc8xx/ether.c | 10 +- post/cpu/mpc8xx/spr.c | 6 +- post/cpu/mpc8xx/uart.c | 30 +- post/cpu/mpc8xx/usb.c | 6 +- post/cpu/mpc8xx/watchdog.c | 4 +- post/cpu/ppc4xx/cache.c | 6 +- post/cpu/ppc4xx/cache_4xx.S | 16 +- post/cpu/ppc4xx/denali_ecc.c | 4 +- post/cpu/ppc4xx/ether.c | 10 +- post/cpu/ppc4xx/ocm.c | 22 +- post/cpu/ppc4xx/spr.c | 4 +- post/cpu/ppc4xx/uart.c | 42 +- post/cpu/ppc4xx/watchdog.c | 4 +- post/drivers/i2c.c | 4 +- post/drivers/memory.c | 10 +- post/drivers/rtc.c | 4 +- post/lib_ppc/andi.c | 2 +- post/lib_ppc/asm.S | 2 +- post/lib_ppc/b.c | 2 +- post/lib_ppc/cmp.c | 2 +- post/lib_ppc/cmpi.c | 2 +- post/lib_ppc/complex.c | 2 +- post/lib_ppc/cpu.c | 4 +- post/lib_ppc/cr.c | 2 +- post/lib_ppc/fpu/20001122-1.c | 4 +- post/lib_ppc/fpu/20010114-2.c | 4 +- post/lib_ppc/fpu/20010226-1.c | 4 +- post/lib_ppc/fpu/980619-1.c | 4 +- post/lib_ppc/fpu/acc1.c | 4 +- post/lib_ppc/fpu/compare-fp-1.c | 4 +- post/lib_ppc/fpu/fpu.c | 4 +- post/lib_ppc/fpu/mul-subnormal-single-1.c | 4 +- post/lib_ppc/load.c | 2 +- post/lib_ppc/multi.c | 2 +- post/lib_ppc/rlwimi.c | 2 +- post/lib_ppc/rlwinm.c | 2 +- post/lib_ppc/rlwnm.c | 2 +- post/lib_ppc/srawi.c | 2 +- post/lib_ppc/store.c | 2 +- post/lib_ppc/string.c | 2 +- post/lib_ppc/three.c | 2 +- post/lib_ppc/threei.c | 2 +- post/lib_ppc/threex.c | 2 +- post/lib_ppc/two.c | 2 +- post/lib_ppc/twox.c | 2 +- post/post.c | 4 +- post/tests.c | 80 ++-- tools/check_old_config.pl | 87 ++++ tools/env/fw_env.c | 4 +- tools/envcrc.c | 14 +- tools/updater/cmd_flash.c | 56 ++-- tools/updater/flash.c | 10 +- tools/updater/flash_hw.c | 28 +- tools/updater/utils.c | 12 +- 2041 files changed, 53931 insertions(+), 53839 deletions(-) create mode 100644 README.nios_CONFIG_SYS_NIOS_CPU delete mode 100644 doc/README.nios_CFG_NIOS_CPU create mode 100755 tools/check_old_config.pl
Best Regards, J.
Dear Jean-Christophe,
Jean-Christophe PLAGNIOL-VILLARD wrote: ...
And for u-boot-next
The following changes since commit b0f1111d6cda4ff3a4c608fce70383410332eca9: Jean-Christophe PLAGNIOL-VILLARD (1): update uImgae FIT multi documentation
git://git.denx.de/u-boot-arm.git next
Do you want me to rebase the OMAP3 patches [1] against u-boot-arm.git next?
If yes, I would select cpu/arm_cortexa8/omap3 for common stuff as discussed earlier [2]. Ok?
If yes, would it be ok to send you the ~11 patches/300k in private mail, or should they go again to mailing list? Except directory change and rebasing against u-boot-arm.git next they would contain no changes compared to the patches already posted.
Thanks
Dirk
[1] http://lists.denx.de/pipermail/u-boot/2008-September/040561.html
[2] http://lists.denx.de/pipermail/u-boot/2008-September/040775.html
On Thu, 18 Sep 2008, Jean-Christophe PLAGNIOL-VILLARD wrote:
Hi Wolfgang Please pull The following changes since commit 87b4ef560cf2da4ccc9e59711ad1ff7fafe96670: Wolfgang Denk (1): Coding style cleanup; update CHANEGLOG
git://git.denx.de/u-boot-arm.git master
Guennadi Liakhovetski (1): i.MX31: switch to CFG_HZ=1000
Jean-Christophe PLAGNIOL-VILLARD (4): Revert "ARM: set GD_FLG_RELOC for boards skipping relocation to RAM" ARM: set GD_FLG_RELOC at board init
This patch's commit doesn't seem right to me. The original patch is:
From: gnusercn gnusercn@gmail.com Date: Tue, 22 Jul 2008 10:35:58 +0800 Subject: [PATCH] Fix bug: in arch-arm, env_get_char dose not work fine in u-boot 1.3.4-rc1
Signed-off-by: gnusercn gnusercn@gmail.com
Ok, the patch was corrputed - it had 4 spaces indentation in all lines instead of TABs, but I don't think this is sufficient reason to commit an otherwise identical patch with a different author and without the original Sob. I think, this is a _very_ bad idea.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
in message Pine.LNX.4.64.0809212104400.7264@axis700.grange Guennadi Liakhovetski wrote:
I agree with Guennadi. Please fix this.
Dear Jean-Christophe PLAGNIOL-VILLARD,
See previous comments. This commit is not OK as is and needs to be fixed.
Ditto.
move README.imx31 to doc/ and merge with README.mx31 update uImgae FIT multi documentation
Please fix the spelling error (s/uImgae/uImage) at least when applying the patch to your repo.
And for u-boot-next
Please do NOT do this. Please always send one pull request message for each pull reauest. Do not bundle several pull requests into one message.
Sorry, this will have to wait until you fixed the previous issues in the ARM master branch.
Dirk Behme
