[PATCH v2 07/11] rockchip: spl: allow more boot devices
Rockchip SoCs have more boot device options then currently included in the function spl_boot_device(). Make this function generic for SPI and NAND.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
This patch should replace a patch in the serie called: [PATCH v1 02/17] rockchip: spl: allow more boot devices https://lore.kernel.org/u-boot/20220508150825.21711-3-jbx6244@gmail.com/
Changed: replace #elseif by #elif --- arch/arm/mach-rockchip/spl.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index ceef9d91..aab3804f 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -53,13 +53,16 @@ u32 spl_boot_device(void) { u32 boot_device = BOOT_DEVICE_MMC1;
-#if defined(CONFIG_TARGET_CHROMEBOOK_JERRY) || \ +#if defined(CONFIG_SPI_BOOT) || \ + defined(CONFIG_TARGET_CHROMEBOOK_JERRY) || \ defined(CONFIG_TARGET_CHROMEBIT_MICKEY) || \ defined(CONFIG_TARGET_CHROMEBOOK_MINNIE) || \ defined(CONFIG_TARGET_CHROMEBOOK_SPEEDY) || \ defined(CONFIG_TARGET_CHROMEBOOK_BOB) || \ defined(CONFIG_TARGET_CHROMEBOOK_KEVIN) return BOOT_DEVICE_SPI; +#elif defined(CONFIG_NAND_BOOT) + return BOOT_DEVICE_NAND; #endif if (CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM)) return BOOT_DEVICE_BOOTROM;
Johan Jonker
