[U-Boot] [PATCH 0/5] device model bringup of hsmmc on am335x bone black and gp evm
This patch seires enables omap_hsmmc to adopt driver model. This has been tested on AM335x beagle bone black and GP EVM (logs [1]). Also pushed a branch for testing [2]
[1]: http://pastebin.ubuntu.com/12417667/ [2]: git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git mmc-dm
TODO: Gpio get is always returning zero, so I have dropped request GPIO for card detect. Even tried with non-dm gpio driver and it is broken. Also non of the TI platforms uses card detect GPIO for hsmmc in u-boot, so dropped parsing DT for card detect and write protect gpio. Card detect and write protect can be added after fixing the omap gpio driver.
Mugunthan V N (5): omap_hsmmc: update struct hsmmc to accomodate base address from DT am335x_evm: mmc: do not define DM_MMC for spl drivers: mmc: omap_hsmmc: convert driver to adopt device driver model defconfig: am335x: bbb: enable ethernet driver model defconfig: am335x: gp_evm: enable ethernet driver model
arch/arm/include/asm/omap_mmc.h | 3 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_gp_evm_defconfig | 1 + drivers/mmc/omap_hsmmc.c | 115 ++++++++++++++++++++++++++++++- include/configs/am335x_evm.h | 8 +++ 5 files changed, 127 insertions(+), 1 deletion(-)
Existing driver gets the actual omap hammc base address + 0x100 bytes as the first 0x100 bytes is not used by the driver. But with DM conversion the base address from DT is different, to accommodate the offset adding res0[0x100] to struct hsmmc.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/include/asm/omap_mmc.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/omap_mmc.h b/arch/arm/include/asm/omap_mmc.h index 617e22f..b69d073 100644 --- a/arch/arm/include/asm/omap_mmc.h +++ b/arch/arm/include/asm/omap_mmc.h @@ -26,6 +26,9 @@ #define OMAP_MMC_H_
struct hsmmc { +#ifdef CONFIG_DM_MMC + unsigned char res0[0x100]; +#endif unsigned char res1[0x10]; unsigned int sysconfig; /* 0x10 */ unsigned int sysstatus; /* 0x14 */
Since spl doesn't support DM currently, do not define DM_MMC for spl build.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- include/configs/am335x_evm.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 56de3d4..6253037 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -328,6 +328,14 @@ #define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" #endif /* CONFIG_USB_MUSB_GADGET */
+/* + * Disable MMC DM for SPL build and can be re-enabled after adding + * DM support in SPL + */ +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_DM_MMC +#endif + #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* Remove other SPL modes. */ #undef CONFIG_SPL_YMODEM_SUPPORT
adopt omap_hsmmc driver to device driver model
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/mmc/omap_hsmmc.c | 115 ++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 114 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index d7b388f..d392302 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -35,6 +35,9 @@ #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> +#include <dm.h> + +DECLARE_GLOBAL_DATA_PTR;
/* simplify defines to OMAP_HSMMC_USE_GPIO */ #if (defined(CONFIG_OMAP_GPIO) && !defined(CONFIG_SPL_BUILD)) || \ @@ -52,9 +55,15 @@ struct omap_hsmmc_data { struct hsmmc *base_addr; struct mmc_config cfg; #ifdef OMAP_HSMMC_USE_GPIO +#ifdef CONFIG_DM_MMC + struct gpio_desc cd_gpio; /* Change Detect GPIO */ + struct gpio_desc wp_gpio; /* Write Protect GPIO */ + bool cd_inverted; +#else int cd_gpio; int wp_gpio; #endif +#endif };
/* If we fail after 1 second wait, something is really bad */ @@ -64,7 +73,7 @@ static int mmc_read_data(struct hsmmc *mmc_base, char *buf, unsigned int size); static int mmc_write_data(struct hsmmc *mmc_base, const char *buf, unsigned int siz);
-#ifdef OMAP_HSMMC_USE_GPIO +#if defined(OMAP_HSMMC_USE_GPIO) && !defined(CONFIG_DM_MMC) static int omap_mmc_setup_gpio_in(int gpio, const char *label) { int ret; @@ -600,6 +609,34 @@ static void omap_hsmmc_set_ios(struct mmc *mmc) }
#ifdef OMAP_HSMMC_USE_GPIO +#ifdef CONFIG_DM_MMC +static int omap_hsmmc_getcd(struct mmc *mmc) +{ + struct omap_hsmmc_data *priv = mmc->priv; + int value; + + value = dm_gpio_get_value(&priv->cd_gpio); + /* if no CD return as 1 */ + if (value < 0) + return 1; + + if (priv->cd_inverted) + return !value; + return value; +} + +static int omap_hsmmc_getwp(struct mmc *mmc) +{ + struct omap_hsmmc_data *priv = mmc->priv; + int value; + + value = dm_gpio_get_value(&priv->wp_gpio); + /* if no WP return as 0 */ + if (value < 0) + return 0; + return value; +} +#else static int omap_hsmmc_getcd(struct mmc *mmc) { struct omap_hsmmc_data *priv_data = mmc->priv; @@ -628,6 +665,7 @@ static int omap_hsmmc_getwp(struct mmc *mmc) return gpio_get_value(wp_gpio); } #endif +#endif
static const struct mmc_ops omap_hsmmc_ops = { .send_cmd = omap_hsmmc_send_cmd, @@ -639,6 +677,7 @@ static const struct mmc_ops omap_hsmmc_ops = { #endif };
+#ifndef CONFIG_DM_MMC int omap_mmc_init(int dev_index, uint host_caps_mask, uint f_max, int cd_gpio, int wp_gpio) { @@ -724,3 +763,77 @@ int omap_mmc_init(int dev_index, uint host_caps_mask, uint f_max, int cd_gpio,
return 0; } +#else +static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) +{ + struct omap_hsmmc_data *priv = dev_get_priv(dev); + const void *fdt = gd->fdt_blob; + int node = dev->of_offset; + struct mmc_config *cfg; + int val; + + priv->base_addr = (struct hsmmc *)dev_get_addr(dev); + cfg = &priv->cfg; + + cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS; + val = fdtdec_get_int(fdt, node, "bus-width", -1); + if (val < 0) { + printf("error: bus-width property missing\n"); + return -ENOENT; + } + + switch (val) { + case 0x8: + cfg->host_caps |= MMC_MODE_8BIT; + case 0x4: + cfg->host_caps |= MMC_MODE_4BIT; + break; + default: + printf("error: invalid bus-width property\n"); + return -ENOENT; + } + + cfg->f_min = 400000; + cfg->f_max = fdtdec_get_int(fdt, node, "max-frequency", 52000000); + cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + + priv->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted"); + + return 0; +} + +static int omap_hsmmc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct omap_hsmmc_data *priv = dev_get_priv(dev); + struct mmc_config *cfg; + struct mmc *mmc; + + cfg = &priv->cfg; + cfg->name = "OMAP SD/MMC"; + cfg->ops = &omap_hsmmc_ops; + + mmc = mmc_create(cfg, priv); + if (mmc == NULL) + return -1; + + upriv->mmc = mmc; + + return 0; +} + +static const struct udevice_id omap_hsmmc_ids[] = { + { .compatible = "ti,omap4-hsmmc" }, + { } +}; + +U_BOOT_DRIVER(omap_hsmmc) = { + .name = "omap_hsmmc", + .id = UCLASS_MMC, + .of_match = omap_hsmmc_ids, + .ofdata_to_platdata = omap_hsmmc_ofdata_to_platdata, + .probe = omap_hsmmc_probe, + .priv_auto_alloc_size = sizeof(struct omap_hsmmc_data), +}; +#endif
[snip]
- { .compatible = "ti,omap4-hsmmc" },
I think we can safely include ti,omap3-hsmmc and ti,am33xx-hsmmc here as well.
[snip]
Will include this and submit a v2 with the other comments in the series.
Regards Mugunthan V N
enable mmc driver model for am335x bbb as omap_hsmmc supports driver model
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am335x_boneblack_vboot_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 117a146..011239b 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT,ENABLE_VBOOT" CONFIG_OF_CONTROL=y CONFIG_SPI_FLASH=y CONFIG_DM_ETH=y +CONFIG_DM_MMC=y
Aside from subject mis-match: Reviewed-by: Tom Rini trini@konsulko.com
enable mmc driver model for am335x gp_evm as omap_hsmmc supports driver model
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am335x_gp_evm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index c87d7a9..50e7d3f 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_SPI_FLASH=y CONFIG_RSA=y CONFIG_DM_ETH=y +CONFIG_DM_MMC=y
Are you going to migrate omap3/omap4/omap5 and any of the other TI devices that use the driver too?
Peter
-- 2.6.0.rc2.10.gf4d9753
In due time, yes. Most other boards there aren't converted to DM period (and I need to see why omap5/dra7xx is now just hanging with DM+GPIO only, that worked when I submitted the patches...).
Tom/All
Any comments on this patch series?
Mugunthan V N
Peter Robinson
