[PATCH v2] led: add function naming option from linux
in linux we have the option to create the name of a led optionally through the following properties:
- function - color - function-enumerator
This patch adds support for parsing this properties if there is no label property.
To be as close as possible to linux import the following files from it:
include/dt-bindings/leds/common.h include/linux/uapi/linux/uleds.h
base commit was: commit: b8f52214c61a ("Merge tag 'audit-pr-20241205' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit")
The led name is created in led_post_bind() and we need some storage place for it. Currently this patch prevents to use malloc() instead it stores the name in new member :
char name[LED_MAX_NAME_SIZE];
of struct led_uc_plat. While at it append led tests for the new feature.
Signed-off-by: Heiko Schocher hs@denx.de --- as we introduce a new element in struct led_uc_priv, may we should add this functionality through a new Kconfig option? (Which also would make this optional and save some bytes for boards who do not need this...)
Ignored a lot of checkpatch warnigs for file include/dt-bindings/leds/common.h
WARNING: Block comments use * on subsequent lines +/* Obsolete equivalents: "tpacpi::thinklight" (IBM/Lenovo Thinkpads), + "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ WARNING: Block comments use a trailing */ on a separate line + "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ WARNING: Block comments use * on subsequent lines +/* System LEDs, usually found on system body. + platform::mute (etc) is sometimes seen, :mute would be better */ WARNING: Block comments use a trailing */ on a separate line + platform::mute (etc) is sometimes seen, :mute would be better */ WARNING: Block comments use * on subsequent lines +/* Used RGB notification LEDs common on phones. + Obsolete equivalents: "status-led:{red,green,blue}" (Motorola Droid 4), WARNING: Block comments use a trailing */ on a separate line + "lp5523:{r,g,b}" (Nokia N900) */
as it is copied from linux
Azure build: https://dev.azure.com/hs0298/hs/_build/results?buildId=164&view=results
Changes in v2: - remove unused name variable in function led_get_label() - rebased patch to current HEAD 82d262ae162 ("Merge patch series "MediaTek MT7629 OF_UPSTREAM migration (v2)"")
arch/sandbox/dts/test.dts | 37 +++++++- doc/device-tree-bindings/leds/common.txt | 28 ++++++ drivers/led/led-uclass.c | 70 +++++++++++++- include/dt-bindings/leds/common.h | 114 +++++++++++++++++++++++ include/led.h | 2 + include/linux/uapi/linux/uleds.h | 25 +++++ test/dm/led.c | 22 ++++- test/dm/ofnode.c | 2 +- 8 files changed, 293 insertions(+), 7 deletions(-) create mode 100644 include/dt-bindings/leds/common.h create mode 100644 include/linux/uapi/linux/uleds.h
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index ae52b375ccb..b8f3012873e 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -13,6 +13,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/sandbox-gpio.h> #include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include <dt-bindings/pinctrl/sandbox-pinmux.h> #include <dt-bindings/mux/mux.h>
@@ -820,7 +821,7 @@ gpio-controller; #gpio-cells = <1>; gpio-bank-name = "a"; - sandbox,gpio-count = <20>; + sandbox,gpio-count = <25>; hog_input_active_low { gpio-hog; input; @@ -1010,6 +1011,40 @@ /* label intentionally omitted */ default-state = "off"; }; + + led-20 { + gpios = <&gpio_a 20 0>; + /* label intentionally omitted */ + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + function-enumerator = <20>; + }; + + led-21 { + gpios = <&gpio_a 21 0>; + /* label intentionally omitted */ + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + }; + + led-22 { + gpios = <&gpio_a 22 0>; + /* label intentionally omitted */ + function = LED_FUNCTION_STATUS; + }; + + led-23 { + gpios = <&gpio_a 23 0>; + /* label intentionally omitted */ + color = <LED_COLOR_ID_GREEN>; + }; + + led-24 { + gpios = <&gpio_a 24 0>; + label = "sandbox:function"; + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + }; };
wdt-gpio-toggle { diff --git a/doc/device-tree-bindings/leds/common.txt b/doc/device-tree-bindings/leds/common.txt index 2d88816dd55..10b2cd84113 100644 --- a/doc/device-tree-bindings/leds/common.txt +++ b/doc/device-tree-bindings/leds/common.txt @@ -4,6 +4,21 @@ Optional properties for child nodes: - label : The label for this LED. If omitted, the label is taken from the node name (excluding the unit address).
+- function: + LED function. Use one of the LED_FUNCTION_* prefixed definitions + from the header include/dt-bindings/leds/common.h. If there is no + matching LED_FUNCTION available, add a new one. + +- color: + Color of the LED. Use one of the LED_COLOR_ID_* prefixed definitions from + the header include/dt-bindings/leds/common.h. If there is no matching + LED_COLOR_ID available, add a new one. + +- function-enumerator: + optional + Integer to be used when more than one instance of the same function is + needed, differing only with an ordinal number. + - linux,default-trigger : This parameter, if present, is a string defining the trigger assigned to the LED. Current triggers are: "backlight" - LED will act as a back-light, controlled by the framebuffer @@ -21,3 +36,16 @@ system-status { linux,default-trigger = "heartbeat"; ... }; + +led-0 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + function-enumerator = <20>; + ... +}; + +led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_YELLOW>; + ... +}; diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index 760750568c0..27ef890ed0a 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -13,6 +13,25 @@ #include <dm/lists.h> #include <dm/root.h> #include <dm/uclass-internal.h> +#include <dt-bindings/leds/common.h> + +static const char * const led_colors[LED_COLOR_ID_MAX] = { + [LED_COLOR_ID_WHITE] = "white", + [LED_COLOR_ID_RED] = "red", + [LED_COLOR_ID_GREEN] = "green", + [LED_COLOR_ID_BLUE] = "blue", + [LED_COLOR_ID_AMBER] = "amber", + [LED_COLOR_ID_VIOLET] = "violet", + [LED_COLOR_ID_YELLOW] = "yellow", + [LED_COLOR_ID_IR] = "ir", + [LED_COLOR_ID_MULTI] = "multicolor", + [LED_COLOR_ID_RGB] = "rgb", + [LED_COLOR_ID_PURPLE] = "purple", + [LED_COLOR_ID_ORANGE] = "orange", + [LED_COLOR_ID_PINK] = "pink", + [LED_COLOR_ID_CYAN] = "cyan", + [LED_COLOR_ID_LIME] = "lime", +};
int led_bind_generic(struct udevice *parent, const char *driver_name) { @@ -232,11 +251,54 @@ int led_activity_blink(void) #endif #endif
-static const char *led_get_label(ofnode node) +static const char *led_get_function_name(struct udevice *dev) +{ + struct led_uc_plat *uc_plat; + const char *func; + u32 color; + u32 enumerator; + int ret; + int cp; + + if (!dev) + return NULL; + + uc_plat = dev_get_uclass_plat(dev); + if (!uc_plat) + return NULL; + + if (uc_plat->label) + return uc_plat->label; + + /* Now try to detect function label name */ + func = dev_read_string(dev, "function"); + cp = dev_read_u32(dev, "color", &color); + if (cp == 0 || func) { + ret = dev_read_u32(dev, "function-enumerator", &enumerator); + if (!ret) { + snprintf(uc_plat->name, LED_MAX_NAME_SIZE, + "%s:%s-%d", + cp ? "" : led_colors[color], + func ? func : "", enumerator); + } else { + snprintf(uc_plat->name, LED_MAX_NAME_SIZE, + "%s:%s", + cp ? "" : led_colors[color], + func ? func : ""); + } + uc_plat->label = uc_plat->name; + } + + return uc_plat->label; +} + +static const char *led_get_label(struct udevice *dev, ofnode node) { const char *label;
label = ofnode_read_string(node, "label"); + if (!label) + label = led_get_function_name(dev); if (!label && !ofnode_read_string(node, "compatible")) label = ofnode_get_name(node);
@@ -249,7 +311,7 @@ static int led_post_bind(struct udevice *dev) const char *default_state;
if (!uc_plat->label) - uc_plat->label = led_get_label(dev_ofnode(dev)); + uc_plat->label = led_get_label(dev, dev_ofnode(dev));
uc_plat->default_state = LEDST_COUNT;
@@ -314,14 +376,14 @@ static int led_init(struct uclass *uc) #ifdef CONFIG_LED_BOOT ret = ofnode_options_get_by_phandle("boot-led", &led_node); if (!ret) - priv->boot_led_label = led_get_label(led_node); + priv->boot_led_label = led_get_label(NULL, led_node); priv->boot_led_period = ofnode_options_read_int("boot-led-period-ms", 250); #endif
#ifdef CONFIG_LED_ACTIVITY ret = ofnode_options_get_by_phandle("activity-led", &led_node); if (!ret) - priv->activity_led_label = led_get_label(led_node); + priv->activity_led_label = led_get_label(NULL, led_node); priv->activity_led_period = ofnode_options_read_int("activity-led-period-ms", 250); #endif diff --git a/include/dt-bindings/leds/common.h b/include/dt-bindings/leds/common.h new file mode 100644 index 00000000000..4f017bea012 --- /dev/null +++ b/include/dt-bindings/leds/common.h @@ -0,0 +1,114 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides macros for the common LEDs device tree bindings. + * + * Copyright (C) 2015, Samsung Electronics Co., Ltd. + * Author: Jacek Anaszewski j.anaszewski@samsung.com + * + * Copyright (C) 2019 Jacek Anaszewski jacek.anaszewski@gmail.com + * Copyright (C) 2020 Pavel Machek pavel@ucw.cz + */ + +#ifndef __DT_BINDINGS_LEDS_H +#define __DT_BINDINGS_LEDS_H + +/* External trigger type */ +#define LEDS_TRIG_TYPE_EDGE 0 +#define LEDS_TRIG_TYPE_LEVEL 1 + +/* Boost modes */ +#define LEDS_BOOST_OFF 0 +#define LEDS_BOOST_ADAPTIVE 1 +#define LEDS_BOOST_FIXED 2 + +/* Standard LED colors */ +#define LED_COLOR_ID_WHITE 0 +#define LED_COLOR_ID_RED 1 +#define LED_COLOR_ID_GREEN 2 +#define LED_COLOR_ID_BLUE 3 +#define LED_COLOR_ID_AMBER 4 +#define LED_COLOR_ID_VIOLET 5 +#define LED_COLOR_ID_YELLOW 6 +#define LED_COLOR_ID_IR 7 +#define LED_COLOR_ID_MULTI 8 /* For multicolor LEDs */ +#define LED_COLOR_ID_RGB 9 /* For multicolor LEDs that can do arbitrary color, + so this would include RGBW and similar */ +#define LED_COLOR_ID_PURPLE 10 +#define LED_COLOR_ID_ORANGE 11 +#define LED_COLOR_ID_PINK 12 +#define LED_COLOR_ID_CYAN 13 +#define LED_COLOR_ID_LIME 14 +#define LED_COLOR_ID_MAX 15 + +/* Standard LED functions */ +/* Keyboard LEDs, usually it would be input4::capslock etc. */ +/* Obsolete equivalent: "shift-key-light" */ +#define LED_FUNCTION_CAPSLOCK "capslock" +#define LED_FUNCTION_SCROLLLOCK "scrolllock" +#define LED_FUNCTION_NUMLOCK "numlock" +#define LED_FUNCTION_FNLOCK "fnlock" +/* Obsolete equivalents: "tpacpi::thinklight" (IBM/Lenovo Thinkpads), + "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ +#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" + +/* System LEDs, usually found on system body. + platform::mute (etc) is sometimes seen, :mute would be better */ +#define LED_FUNCTION_POWER "power" +#define LED_FUNCTION_DISK "disk" + +/* Obsolete: "platform:*:charging" (allwinner sun50i) */ +#define LED_FUNCTION_CHARGING "charging" +/* Used RGB notification LEDs common on phones. + Obsolete equivalents: "status-led:{red,green,blue}" (Motorola Droid 4), + "lp5523:{r,g,b}" (Nokia N900) */ +#define LED_FUNCTION_STATUS "status" + +#define LED_FUNCTION_MICMUTE "micmute" +#define LED_FUNCTION_MUTE "mute" + +/* Used for player LEDs as found on game controllers from e.g. Nintendo, Sony. */ +#define LED_FUNCTION_PLAYER1 "player-1" +#define LED_FUNCTION_PLAYER2 "player-2" +#define LED_FUNCTION_PLAYER3 "player-3" +#define LED_FUNCTION_PLAYER4 "player-4" +#define LED_FUNCTION_PLAYER5 "player-5" + +/* Miscelleaus functions. Use functions above if you can. */ +#define LED_FUNCTION_ACTIVITY "activity" +#define LED_FUNCTION_ALARM "alarm" +#define LED_FUNCTION_BACKLIGHT "backlight" +#define LED_FUNCTION_BLUETOOTH "bluetooth" +#define LED_FUNCTION_BOOT "boot" +#define LED_FUNCTION_CPU "cpu" +#define LED_FUNCTION_DEBUG "debug" +#define LED_FUNCTION_DISK_ACTIVITY "disk-activity" +#define LED_FUNCTION_DISK_ERR "disk-err" +#define LED_FUNCTION_DISK_READ "disk-read" +#define LED_FUNCTION_DISK_WRITE "disk-write" +#define LED_FUNCTION_FAULT "fault" +#define LED_FUNCTION_FLASH "flash" +#define LED_FUNCTION_HEARTBEAT "heartbeat" +#define LED_FUNCTION_INDICATOR "indicator" +#define LED_FUNCTION_LAN "lan" +#define LED_FUNCTION_MAIL "mail" +#define LED_FUNCTION_MOBILE "mobile" +#define LED_FUNCTION_MTD "mtd" +#define LED_FUNCTION_PANIC "panic" +#define LED_FUNCTION_PROGRAMMING "programming" +#define LED_FUNCTION_RX "rx" +#define LED_FUNCTION_SD "sd" +#define LED_FUNCTION_SPEED_LAN "speed-lan" +#define LED_FUNCTION_SPEED_WAN "speed-wan" +#define LED_FUNCTION_STANDBY "standby" +#define LED_FUNCTION_TORCH "torch" +#define LED_FUNCTION_TX "tx" +#define LED_FUNCTION_USB "usb" +#define LED_FUNCTION_WAN "wan" +#define LED_FUNCTION_WAN_ONLINE "wan-online" +#define LED_FUNCTION_WLAN "wlan" +#define LED_FUNCTION_WLAN_2GHZ "wlan-2ghz" +#define LED_FUNCTION_WLAN_5GHZ "wlan-5ghz" +#define LED_FUNCTION_WLAN_6GHZ "wlan-6ghz" +#define LED_FUNCTION_WPS "wps" + +#endif /* __DT_BINDINGS_LEDS_H */ diff --git a/include/led.h b/include/led.h index 64247cd3a70..ba42a5f69d2 100644 --- a/include/led.h +++ b/include/led.h @@ -10,6 +10,7 @@ #include <stdbool.h> #include <cyclic.h> #include <dm/ofnode.h> +#include <linux/uapi/linux/uleds.h>
/** * DOC: Overview @@ -86,6 +87,7 @@ struct led_sw_blink { struct led_uc_plat { const char *label; enum led_state_t default_state; + char name[LED_MAX_NAME_SIZE]; #ifdef CONFIG_LED_SW_BLINK struct led_sw_blink *sw_blink; #endif diff --git a/include/linux/uapi/linux/uleds.h b/include/linux/uapi/linux/uleds.h new file mode 100644 index 00000000000..4d32a39965f --- /dev/null +++ b/include/linux/uapi/linux/uleds.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ WITH Linux-syscall-note */ +/* + * Userspace driver support for the LED subsystem + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#ifndef _UAPI__ULEDS_H_ +#define _UAPI__ULEDS_H_ + +#define LED_MAX_NAME_SIZE 64 + +struct uleds_user_dev { + char name[LED_MAX_NAME_SIZE]; + int max_brightness; +}; + +#endif /* _UAPI__ULEDS_H_ */ diff --git a/test/dm/led.c b/test/dm/led.c index e5b86326c3a..36652c2833a 100644 --- a/test/dm/led.c +++ b/test/dm/led.c @@ -20,7 +20,12 @@ static int dm_test_led_base(struct unit_test_state *uts) ut_assertok(uclass_get_device(UCLASS_LED, 1, &dev)); ut_assertok(uclass_get_device(UCLASS_LED, 2, &dev)); ut_assertok(uclass_get_device(UCLASS_LED, 3, &dev)); - ut_asserteq(-ENODEV, uclass_get_device(UCLASS_LED, 4, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 4, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 5, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 6, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 7, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 8, &dev)); + ut_asserteq(-ENODEV, uclass_get_device(UCLASS_LED, 9, &dev));
return 0; } @@ -110,6 +115,21 @@ static int dm_test_led_label(struct unit_test_state *uts)
ut_asserteq(-ENODEV, led_get_by_label("sandbox:blue", &dev));
+ /* Test if function, color and function-enumerator naming works */ + ut_assertok(led_get_by_label("red:status-20", &dev)); + + /* Test if function, color naming works */ + ut_assertok(led_get_by_label("green:status", &dev)); + + /* Test if function, without color naming works */ + ut_assertok(led_get_by_label(":status", &dev)); + + /* Test if color without function naming works */ + ut_assertok(led_get_by_label("green:", &dev)); + + /* Test if function, color naming is ignored if label is found */ + ut_assertok(led_get_by_label("sandbox:function", &dev)); + return 0; } DM_TEST(dm_test_led_label, UTF_SCAN_PDATA | UTF_SCAN_FDT); diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index f16b643fa3f..72f4e80f637 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -1580,7 +1580,7 @@ static int dm_test_ofnode_delete(struct unit_test_state *uts) ut_assert(!ofnode_valid(node)); ut_assert(!ofnode_valid(ofnode_path("/leds/default_on")));
- ut_asserteq(2, ofnode_get_child_count(ofnode_path("/leds"))); + ut_asserteq(7, ofnode_get_child_count(ofnode_path("/leds")));
return 0; }
- function
- color
I think you missed my message on v1 saying we need to just use dts/upstream/ for these.
Hi Tom,
- function
- color
hups... Indeed ... sorry!
Look ASAP into it...
bye, Heiko
Heiko Schocher
