[U-Boot] [PATCH v2 0/7] arm: atmel: sama5d3: enable spl boot from SD card
This patch series enable spl boot from SD card, it only can boot u-boot itself.
Changes in v2: - Move spl related code to at91-common folder
Bo Shen (7): arm: atmel: sama5d3: correct the ID for DBGU and PIT arm: atmel: sama5: correct the error define of DIV arm: atmel: the offset of MULA is 18 in sama5d3 arm: atmel: sama5d3: early enable PIO peripherals arm: atmel: add plla and mck initialize function arm: atmel: add ddr2 initialization function spl: mmc: FAT support boot u-boot
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/at91/Makefile | 1 + arch/arm/cpu/armv7/at91/clock.c | 27 ++++++ arch/arm/cpu/armv7/at91/mpddrc.c | 123 +++++++++++++++++++++++++ arch/arm/cpu/armv7/at91/sama5d3_devices.c | 2 +- arch/arm/cpu/armv7/at91/timer.c | 2 +- arch/arm/cpu/at91-common/Makefile | 32 +++++++ arch/arm/cpu/at91-common/spl.c | 39 ++++++++ arch/arm/cpu/at91-common/u-boot-spl.lds | 50 ++++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 4 + arch/arm/include/asm/arch-at91/at91_pmc.h | 8 +- arch/arm/include/asm/arch-at91/atmel_mpddrc.h | 111 ++++++++++++++++++++++ arch/arm/include/asm/arch-at91/spl.h | 17 ++++ board/atmel/sama5d3xek/sama5d3xek.c | 99 ++++++++++++++++++++ include/configs/sama5d3xek.h | 37 ++++++++ spl/Makefile | 4 + 16 files changed, 553 insertions(+), 5 deletions(-) create mode 100644 arch/arm/cpu/armv7/at91/mpddrc.c create mode 100644 arch/arm/cpu/at91-common/Makefile create mode 100644 arch/arm/cpu/at91-common/spl.c create mode 100644 arch/arm/cpu/at91-common/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-at91/atmel_mpddrc.h create mode 100644 arch/arm/include/asm/arch-at91/spl.h
As the DBGU and PIT has its own ID on sama5d3 SoC, while not share with SYS ID. So, correct them.
Signed-off-by: Bo Shen voice.shen@atmel.com
--- Changes in v2: - None
arch/arm/cpu/armv7/at91/sama5d3_devices.c | 2 +- arch/arm/cpu/armv7/at91/timer.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/at91/sama5d3_devices.c b/arch/arm/cpu/armv7/at91/sama5d3_devices.c index 51f0a6d..ebe99d2 100644 --- a/arch/arm/cpu/armv7/at91/sama5d3_devices.c +++ b/arch/arm/cpu/armv7/at91/sama5d3_devices.c @@ -82,7 +82,7 @@ void at91_seriald_hw_init(void) at91_set_a_periph(AT91_PIO_PORTB, 30, 0); /* DRXD */
/* Enable clock */ - at91_periph_clk_enable(ATMEL_ID_SYS); + at91_periph_clk_enable(ATMEL_ID_DBGU); }
#if defined(CONFIG_ATMEL_SPI) diff --git a/arch/arm/cpu/armv7/at91/timer.c b/arch/arm/cpu/armv7/at91/timer.c index 3808aed..e3ebfe0 100644 --- a/arch/arm/cpu/armv7/at91/timer.c +++ b/arch/arm/cpu/armv7/at91/timer.c @@ -60,7 +60,7 @@ int timer_init(void) at91_pit_t *pit = (at91_pit_t *)ATMEL_BASE_PIT;
/* Enable PITC Clock */ - at91_periph_clk_enable(ATMEL_ID_SYS); + at91_periph_clk_enable(ATMEL_ID_PIT);
/* Enable PITC */ writel(TIMER_LOAD_VAL | AT91_PIT_MR_EN , &pit->mr);
Correct the error define of DIV.
arch/arm/include/asm/arch-at91/at91_pmc.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index 003920c..ed5462c 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -124,8 +124,8 @@ typedef struct at91_pmc { #define AT91_PMC_MCKR_MDIV_MASK 0x00000300 #endif
-#define AT91_PMC_MCKR_PLLADIV_1 0x00001000 -#define AT91_PMC_MCKR_PLLADIV_2 0x00002000 +#define AT91_PMC_MCKR_PLLADIV_1 0x00000000 +#define AT91_PMC_MCKR_PLLADIV_2 0x00001000
#define AT91_PMC_IXR_MOSCS 0x00000001 #define AT91_PMC_IXR_LOCKA 0x00000002
The offset of MULA field in PLLA register in sama5d3 is 18, and the length only 7 bits.
arch/arm/include/asm/arch-at91/at91_pmc.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index ed5462c..c063213 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -73,7 +73,11 @@ typedef struct at91_pmc { #define AT91_PMC_PLLXR_DIV(x) (x & 0xFF) #define AT91_PMC_PLLXR_PLLCOUNT(x) ((x & 0x3F) << 8) #define AT91_PMC_PLLXR_OUT(x) ((x & 0x03) << 14) +#ifdef CONFIG_SAMA5D3 +#define AT91_PMC_PLLXR_MUL(x) ((x & 0x7F) << 18) +#else #define AT91_PMC_PLLXR_MUL(x) ((x & 0x7FF) << 16) +#endif #define AT91_PMC_PLLAR_29 0x20000000 #define AT91_PMC_PLLBR_USBDIV_1 0x00000000 #define AT91_PMC_PLLBR_USBDIV_2 0x10000000
Enable the PIO peripherals early than other peripherals.
board/atmel/sama5d3xek/sama5d3xek.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index b0965ef..7fa3ae7 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -158,6 +158,9 @@ void lcd_show_board_info(void)
int board_early_init_f(void) { + at91_periph_clk_enable(ATMEL_ID_PIOA | ATMEL_ID_PIOB | ATMEL_ID_PIOC | + ATMEL_ID_PIOD | ATMEL_ID_PIOE); + at91_seriald_hw_init();
Hi Andreas,
Changes in v2:
- None
- at91_periph_clk_enable(ATMEL_ID_PIOA | ATMEL_ID_PIOB | ATMEL_ID_PIOC |
This code is wrong, it should be as following: --->8--- at91_periph_clk_enable(ATMEL_ID_PIOA); at91_periph_clk_enable(ATMEL_ID_PIOB); .... at91_periph_clk_enable(ATMEL_ID_PIOE); ---8<---
Best Regards, Bo Shen
Add plla and mck initialize function.
arch/arm/cpu/armv7/at91/clock.c | 27 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 2 ++ 2 files changed, 29 insertions(+)
diff --git a/arch/arm/cpu/armv7/at91/clock.c b/arch/arm/cpu/armv7/at91/clock.c index 1588e0c..d392f54 100644 --- a/arch/arm/cpu/armv7/at91/clock.c +++ b/arch/arm/cpu/armv7/at91/clock.c @@ -120,3 +120,30 @@ void at91_periph_clk_enable(int id) else writel(1 << id, &pmc->pcer); } + +void at91_plla_init(u32 pllar) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(pllar, &pmc->pllar); + while (!(readl(&pmc->sr) & (AT91_PMC_LOCKA | AT91_PMC_MCKRDY))) + ; +} + +void at91_mck_init(u32 mckr) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + u32 tmp; + + tmp = readl(&pmc->mckr); + tmp &= ~(AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_2); + tmp |= mckr & (AT91_PMC_MCKR_PRES_MASK | + AT91_PMC_MCKR_MDIV_MASK | + AT91_PMC_MCKR_PLLADIV_2); + writel(tmp, &pmc->mckr); + + while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) + ; +} diff --git a/arch/arm/include/asm/arch-at91/at91_common.h b/arch/arm/include/asm/arch-at91/at91_common.h index abcb97d..728a9fb 100644 --- a/arch/arm/include/asm/arch-at91/at91_common.h +++ b/arch/arm/include/asm/arch-at91/at91_common.h @@ -22,5 +22,7 @@ void at91_spi1_hw_init(unsigned long cs_mask); void at91_udp_hw_init(void); void at91_uhp_hw_init(void); void at91_lcd_hw_init(void); +void at91_plla_init(u32 pllar); +void at91_mck_init(u32 mckr);
#endif /* AT91_COMMON_H */
The MPDDRC supports different type of SDRAM This patch add ddr2 initialization function
arch/arm/cpu/armv7/at91/Makefile | 1 + arch/arm/cpu/armv7/at91/mpddrc.c | 123 +++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/atmel_mpddrc.h | 111 ++++++++++++++++++++++ 3 files changed, 235 insertions(+) create mode 100644 arch/arm/cpu/armv7/at91/mpddrc.c create mode 100644 arch/arm/include/asm/arch-at91/atmel_mpddrc.h
diff --git a/arch/arm/cpu/armv7/at91/Makefile b/arch/arm/cpu/armv7/at91/Makefile index 90b9bd6..4a02d06 100644 --- a/arch/arm/cpu/armv7/at91/Makefile +++ b/arch/arm/cpu/armv7/at91/Makefile @@ -17,6 +17,7 @@ COBJS-y += clock.o COBJS-y += cpu.o COBJS-y += reset.o COBJS-y += timer.o +COBJS-$(CONFIG_SPL_BUILD) += mpddrc.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) diff --git a/arch/arm/cpu/armv7/at91/mpddrc.c b/arch/arm/cpu/armv7/at91/mpddrc.c new file mode 100644 index 0000000..1abde1e --- /dev/null +++ b/arch/arm/cpu/armv7/at91/mpddrc.c @@ -0,0 +1,123 @@ +/* + * Copyright (C) 2013 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/atmel_mpddrc.h> + +static void atmel_mpddr_op(int mode, u32 ram_address) +{ + struct atmel_mpddr *mpddr = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + + writel(mode, &mpddr->mr); + writel(0, ram_address); +} + +int ddr2_init(u32 ram_address, struct atmel_mpddr *mpddr_value) +{ + struct atmel_mpddr *mpddr = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + u32 ba_off, cr; + + /* Compute bank offset according to NC in configuration register */ + ba_off = (mpddr_value->cr & ATMEL_MPDDRC_CR_NC_MASK) + 9; + if (!(mpddr_value->cr & ATMEL_MPDDRC_CR_DECOD_INTERLEAVED)) + ba_off += ((mpddr->cr & ATMEL_MPDDRC_CR_NR_MASK) >> 2) + 11; + + ba_off += (mpddr_value->mdr & ATMEL_MPDDRC_MDR_DBW_MASK) ? 1 : 2; + + /* Program the memory device type into the memory device register */ + writel(mpddr_value->mdr, &mpddr->mdr); + + /* Program the configuration register */ + writel(mpddr_value->cr, &mpddr->cr); + + /* Program the timing register */ + writel(mpddr_value->tp0r, &mpddr->tp0r); + writel(mpddr_value->tp1r, &mpddr->tp1r); + writel(mpddr_value->tp2r, &mpddr->tp2r); + + /* Issue a NOP command */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_NOP_CMD, ram_address); + + /* A 200 us is provided to precede any signal toggle */ + udelay(200); + + /* Issue a NOP command */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_NOP_CMD, ram_address); + + /* Issue an all banks precharge command */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_PRCGALL_CMD, ram_address); + + /* Issue an extended mode register set(EMRS2) to choose operation */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_EXT_LMR_CMD, + ram_address + (0x2 << ba_off)); + + /* Issue an extended mode register set(EMRS3) to set EMSR to 0 */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_EXT_LMR_CMD, + ram_address + (0x3 << ba_off)); + + /* + * Issue an extended mode register set(EMRS1) to enable DLL and + * program D.I.C (output driver impedance control) + */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_EXT_LMR_CMD, + ram_address + (0x1 << ba_off)); + + /* Enable DLL reset */ + cr = readl(&mpddr->cr); + writel(cr | ATMEL_MPDDRC_CR_EN_RESET_DLL, &mpddr->cr); + + /* A mode register set(MRS) cycle is issued to reset DLL */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_LMR_CMD, ram_address); + + /* Issue an all banks precharge command */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_PRCGALL_CMD, ram_address); + + /* Two auto-refresh (CBR) cycles are provided */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_RFSH_CMD, ram_address); + atmel_mpddr_op(ATMEL_MPDDRC_MR_RFSH_CMD, ram_address); + + /* Disable DLL reset */ + cr = readl(&mpddr->cr); + writel(cr & (~ATMEL_MPDDRC_CR_EN_RESET_DLL), &mpddr->cr); + + /* A mode register set (MRS) cycle is issued to disable DLL reset */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_LMR_CMD, ram_address); + + /* Set OCD calibration in defautl state */ + cr = readl(&mpddr->cr); + writel(cr | ATMEL_MPDDRC_CR_OCD_DEFAULT, &mpddr->cr); + + /* + * An extended mode register set (EMRS1) cycle is issued + * to OCD default value + */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_EXT_LMR_CMD, + ram_address + (0x1 << ba_off)); + + /* OCD calibration mode exit */ + cr = readl(&mpddr->cr); + writel(cr & (~ATMEL_MPDDRC_CR_OCD_DEFAULT), &mpddr->cr); + + /* + * An extended mode register set (EMRS1) cycle is issued + * to enable OCD exit + */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_EXT_LMR_CMD, + ram_address + (0x1 << ba_off)); + + /* A nornal mode command is provided */ + atmel_mpddr_op(ATMEL_MPDDRC_MR_NORMAL_CMD, ram_address); + + /* Perform a write access to any DDR2-SDRAM address */ + writel(0, ram_address); + + /* Write the refresh rate */ + writel(mpddr_value->rtr, &mpddr->rtr); + + return 0; +} diff --git a/arch/arm/include/asm/arch-at91/atmel_mpddrc.h b/arch/arm/include/asm/arch-at91/atmel_mpddrc.h new file mode 100644 index 0000000..abd8b68 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/atmel_mpddrc.h @@ -0,0 +1,111 @@ +/* + * Copyright (C) 2013 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ATMEL_MPDDRC_H__ +#define __ATMEL_MPDDRC_H__ + +struct atmel_mpddr { + u32 mr; + u32 rtr; + u32 cr; + u32 tp0r; + u32 tp1r; + u32 tp2r; + u32 reserved[2]; + u32 mdr; +}; + +int ddr2_init(unsigned int ram_address, + struct atmel_mpddr *mpddr); + +/* bit field in mode register */ +#define ATMEL_MPDDRC_MR_NORMAL_CMD 0x0 +#define ATMEL_MPDDRC_MR_NOP_CMD 0x1 +#define ATMEL_MPDDRC_MR_PRCGALL_CMD 0x2 +#define ATMEL_MPDDRC_MR_LMR_CMD 0x3 +#define ATMEL_MPDDRC_MR_RFSH_CMD 0x4 +#define ATMEL_MPDDRC_MR_EXT_LMR_CMD 0x5 +#define ATMEL_MPDDRC_MR_DEEP_CMD 0x6 +#define ATMEL_MPDDRC_MR_LPDDR2_CMD 0x7 + +/* bit field in configuration register */ +#define ATMEL_MPDDRC_CR_NC_MASK 0x3 +#define ATMEL_MPDDRC_CR_NC_COL_9 0x0 +#define ATMEL_MPDDRC_CR_NC_COL_10 0x1 +#define ATMEL_MPDDRC_CR_NC_COL_11 0x2 +#define ATMEL_MPDDRC_CR_NC_COL_12 0x3 +#define ATMEL_MPDDRC_CR_NR_MASK (0x3 << 2) +#define ATMEL_MPDDRC_CR_NR_ROW_11 (0x0 << 2) +#define ATMEL_MPDDRC_CR_NR_ROW_12 (0x1 << 2) +#define ATMEL_MPDDRC_CR_NR_ROW_13 (0x2 << 2) +#define ATMEL_MPDDRC_CR_NR_ROW_14 (0x3 << 2) +#define ATMEL_MPDDRC_CR_CAS (0x7 << 4) +#define ATMEL_MPDDRC_CR_CAS_2 (0x2 << 4) +#define ATMEL_MPDDRC_CR_CAS_3 (0x3 << 4) +#define ATMEL_MPDDRC_CR_CAS_4 (0x4 << 4) +#define ATMEL_MPDDRC_CR_CAS_5 (0x5 << 4) +#define ATMEL_MPDDRC_CR_CAS_6 (0x6 << 4) +#define ATMEL_MPDDRC_CR_EN_RESET_DLL (0x1 << 7) +#define ATMEL_MPDDRC_CR_DIC_DS (0x1 << 8) +#define ATMEL_MPDDRC_CR_DIS_DLL (0x1 << 9) +#define ATMEL_MPDDRC_CR_OCD_DEFAULT (0x7 << 12) +#define ATMEL_MPDDRC_CR_EN_ENRDM (0x1 << 17) +#define ATMEL_MPDDRC_CR_NB_8BANKS (0x1 << 20) +#define ATMEL_MPDDRC_CR_DIS_NDQS (0x1 << 21) +#define ATMEL_MPDDRC_CR_DECOD_INTERLEAVED (0x1 << 22) +#define ATMEL_MPDDRC_CR_UNAL_SUPPORTED (0x1 << 23) + +/* bit field in timing parameter 0 register */ +#define ATMEL_MPDDRC_TP0R_TRAS_OFFSET 0 +#define ATMEL_MPDDRC_TP0R_TRAS_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TRCD_OFFSET 4 +#define ATMEL_MPDDRC_TP0R_TRCD_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TWR_OFFSET 8 +#define ATMEL_MPDDRC_TP0R_TWR_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TRC_OFFSET 12 +#define ATMEL_MPDDRC_TP0R_TRC_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TRP_OFFSET 16 +#define ATMEL_MPDDRC_TP0R_TRP_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TRRD_OFFSET 20 +#define ATMEL_MPDDRC_TP0R_TRRD_MASK 0xf +#define ATMEL_MPDDRC_TP0R_TWTR_OFFSET 24 +#define ATMEL_MPDDRC_TP0R_TWTR_MASK 0x7 +#define ATMEL_MPDDRC_TP0R_RDC_WRRD_OFFSET 27 +#define ATMEL_MPDDRC_TP0R_RDC_WRRD_MASK 0x1 +#define ATMEL_MPDDRC_TP0R_TMRD_OFFSET 28 +#define ATMEL_MPDDRC_TP0R_TMRD_MASK 0xf + +/* bit field in timing parameter 1 register */ +#define ATMEL_MPDDRC_TP1R_TRFC_OFFSET 0 +#define ATMEL_MPDDRC_TP1R_TRFC_MASK 0x7f +#define ATMEL_MPDDRC_TP1R_TXSNR_OFFSET 8 +#define ATMEL_MPDDRC_TP1R_TXSNR_MASK 0xff +#define ATMEL_MPDDRC_TP1R_TXSRD_OFFSET 16 +#define ATMEL_MPDDRC_TP1R_TXSRD_MASK 0xff +#define ATMEL_MPDDRC_TP1R_TXP_OFFSET 24 +#define ATMEL_MPDDRC_TP1R_TXP_MASK 0xf + +/* bit field in timing parameter 2 register */ +#define ATMEL_MPDDRC_TP2R_TXARD_OFFSET 0 +#define ATMEL_MPDDRC_TP2R_TXARD_MASK 0xf +#define ATMEL_MPDDRC_TP2R_TXARDS_OFFSET 4 +#define ATMEL_MPDDRC_TP2R_TXARDS_MASK 0xf +#define ATMEL_MPDDRC_TP2R_TRPA_OFFSET 8 +#define ATMEL_MPDDRC_TP2R_TRPA_MASK 0xf +#define ATMEL_MPDDRC_TP2R_TRTP_OFFSET 12 +#define ATMEL_MPDDRC_TP2R_TRTP_MASK 0x7 +#define ATMEL_MPDDRC_TP2R_TFAW_OFFSET 16 +#define ATMEL_MPDDRC_TP2R_TFAW_MASK 0xf + +/* bit field in Memory Device Register */ +#define ATMEL_MPDDRC_MDR_LPDDR_SDRAM 0x3 +#define ATMEL_MPDDRC_MDR_DDR2_SDRAM 0x6 +#define ATMEL_MPDDRC_MDR_DBW_MASK (0x1 << 4) +#define ATMEL_MPDDRC_MDR_DBW_32BITS (0x0 << 4) +#define ATMEL_MPDDRC_MDR_DBW_16BITS (0x1 << 4) + +#endif
Enable SPL support which can load u-boot from SD card in FAT format.
--- Changes in v2: - Move spl related code to at91-common folder
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/at91-common/Makefile | 32 +++++++++ arch/arm/cpu/at91-common/spl.c | 39 +++++++++++ arch/arm/cpu/at91-common/u-boot-spl.lds | 50 ++++++++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 2 + arch/arm/include/asm/arch-at91/spl.h | 17 +++++ board/atmel/sama5d3xek/sama5d3xek.c | 96 ++++++++++++++++++++++++++ include/configs/sama5d3xek.h | 37 ++++++++++ spl/Makefile | 4 ++ 9 files changed, 278 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/at91-common/Makefile create mode 100644 arch/arm/cpu/at91-common/spl.c create mode 100644 arch/arm/cpu/at91-common/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-at91/spl.h
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index ee4b021..aea4e8b 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -16,7 +16,7 @@ COBJS += cache_v7.o COBJS += cpu.o COBJS += syslib.o
-ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX),) +ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY),) SOBJS += lowlevel_init.o endif
diff --git a/arch/arm/cpu/at91-common/Makefile b/arch/arm/cpu/at91-common/Makefile new file mode 100644 index 0000000..5c17f80 --- /dev/null +++ b/arch/arm/cpu/at91-common/Makefile @@ -0,0 +1,32 @@ +# +# (C) Copyright 2000-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2013 Atmel Corporation +# Bo Shen voice.shen@atmel.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libat91-common.o + +COBJS-$(CONFIG_SPL_BUILD) += spl.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/at91-common/spl.c b/arch/arm/cpu/at91-common/spl.c new file mode 100644 index 0000000..8276ec4 --- /dev/null +++ b/arch/arm/cpu/at91-common/spl.c @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2013 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_wdt.h> +#include <asm/arch/clk.h> +#include <spl.h> + +static void at91_disable_wdt(void) +{ + struct at91_wdt *wdt = (struct at91_wdt *)ATMEL_BASE_WDT; + + writel(AT91_WDT_MR_WDDIS, &wdt->mr); +} + +void s_init(void) +{ + /* disable watchdog */ + at91_disable_wdt(); + + /* PMC configuration */ + at91_pmc_init(); + + at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK); + + timer_init(); + + board_early_init_f(); + + preloader_console_init(); + + mem_init(); +} diff --git a/arch/arm/cpu/at91-common/u-boot-spl.lds b/arch/arm/cpu/at91-common/u-boot-spl.lds new file mode 100644 index 0000000..038335d --- /dev/null +++ b/arch/arm/cpu/at91-common/u-boot-spl.lds @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * (C) 2013 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE, \ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + arch/arm/cpu/armv7/start.o (.text*) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end = .; + } >.sdram +} diff --git a/arch/arm/include/asm/arch-at91/at91_common.h b/arch/arm/include/asm/arch-at91/at91_common.h index 728a9fb..3ca4d5b 100644 --- a/arch/arm/include/asm/arch-at91/at91_common.h +++ b/arch/arm/include/asm/arch-at91/at91_common.h @@ -24,5 +24,7 @@ void at91_uhp_hw_init(void); void at91_lcd_hw_init(void); void at91_plla_init(u32 pllar); void at91_mck_init(u32 mckr); +void at91_pmc_init(void); +void mem_init(void);
#endif /* AT91_COMMON_H */ diff --git a/arch/arm/include/asm/arch-at91/spl.h b/arch/arm/include/asm/arch-at91/spl.h new file mode 100644 index 0000000..5bbd4fc --- /dev/null +++ b/arch/arm/include/asm/arch-at91/spl.h @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2013 Atmel Corporation + * Bo Shen voice.shen@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_SPL_H_ +#define _ASM_ARCH_SPL_H_ + +enum { + BOOT_DEVICE_MMC1, + BOOT_DEVICE_MMC2, + BOOT_DEVICE_MMC2_2, +}; + +#endif diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index 7fa3ae7..56222ad 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -20,6 +20,9 @@ #include <micrel.h> #include <net.h> #include <netdev.h> +#include <spl.h> +#include <asm/arch/atmel_mpddrc.h> +#include <asm/arch/at91_wdt.h>
#ifdef CONFIG_USB_GADGET_ATMEL_USBA #include <asm/arch/atmel_usba_udc.h> @@ -293,3 +296,96 @@ void spi_cs_deactivate(struct spi_slave *slave) } } #endif /* CONFIG_ATMEL_SPI */ + +/* NAND SPL */ +#ifdef CONFIG_SPL_BUILD +void spl_board_init(void) +{ + sama5d3xek_mci_hw_init(); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} + +u32 spl_boot_mode(void) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: + return MMCSD_MODE_FAT; + break; + default: + hang(); + } +} + +void ddr2_conf(struct atmel_mpddr *ddr2) +{ + ddr2->mdr = (ATMEL_MPDDRC_MDR_DBW_32BITS | ATMEL_MPDDRC_MDR_DDR2_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_14 | + ATMEL_MPDDRC_CR_CAS_3 | + ATMEL_MPDDRC_CR_EN_ENRDM | + ATMEL_MPDDRC_CR_NB_8BANKS | + ATMEL_MPDDRC_CR_DIS_NDQS | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_UNAL_SUPPORTED); + + ddr2->rtr = 0x411; + + ddr2->tp0r = (6 << ATMEL_MPDDRC_TP0R_TRAS_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TRCD_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TWR_OFFSET | + 8 << ATMEL_MPDDRC_TP0R_TRC_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TRP_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TRRD_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TWTR_OFFSET | + 2 << ATMEL_MPDDRC_TP0R_TMRD_OFFSET); + + ddr2->tp1r = (2 << ATMEL_MPDDRC_TP1R_TXP_OFFSET | + 200 << ATMEL_MPDDRC_TP1R_TXSRD_OFFSET | + 28 << ATMEL_MPDDRC_TP1R_TXSNR_OFFSET | + 26 << ATMEL_MPDDRC_TP1R_TRFC_OFFSET); + + ddr2->tp2r = (7 << ATMEL_MPDDRC_TP2R_TFAW_OFFSET | + 2 << ATMEL_MPDDRC_TP2R_TRTP_OFFSET | + 2 << ATMEL_MPDDRC_TP2R_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TP2R_TXARDS_OFFSET | + 8 << ATMEL_MPDDRC_TP2R_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct atmel_mpddr ddr2; + + ddr2_conf(&ddr2); + + /* enable MPDDR clock */ + at91_periph_clk_enable(ATMEL_ID_MPDDRC); + writel(0x4, &pmc->scer); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_DDRCS, &ddr2); +} + +void at91_pmc_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + u32 tmp; + + tmp = AT91_PMC_PLLAR_29 | + AT91_PMC_PLLXR_PLLCOUNT(0x3f) | + AT91_PMC_PLLXR_MUL(43) | + AT91_PMC_PLLXR_DIV(1); + at91_plla_init(tmp); + + writel(0x3 << 8, &pmc->pllicpr); + + tmp = AT91_PMC_MCKR_MDIV_4 | + AT91_PMC_MCKR_CSS_PLLA; + at91_mck_init(tmp); +} +#endif diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 79c0068..802f245 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -25,7 +25,10 @@ #define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT
+#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT +#endif + #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
@@ -94,8 +97,12 @@ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_DDRCS #define CONFIG_SYS_SDRAM_SIZE 0x20000000
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR 0x310000 +#else #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) +#endif
/* SerialFlash */ #define CONFIG_CMD_SF @@ -235,4 +242,34 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024)
+/* SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK + +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x10000 + +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SPL_LDSCRIPT arch/arm/cpu/at91-common/u-boot-spl.lds + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x400 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT + #endif diff --git a/spl/Makefile b/spl/Makefile index b366ac2..6dd1e5d 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -123,6 +123,10 @@ ifeq ($(SOC),exynos) LIBS-y += $(CPUDIR)/s5p-common/libs5p-common.o endif
+ifeq ($(SOC),at91) +LIBS-y += arch/$(ARCH)/cpu/at91-common/libat91-common.o +endif + # Add GCC lib ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") PLATFORM_LIBGCC = $(SPLTREE)/arch/$(ARCH)/lib/libgcc.o
Dear Bo Shen,
I am sorry, but both the Subject: and the commit message are totally cryptic to me - what does this mean? Is this a bug fix, or a new feature? Does this affect all systems, or only a few? Which ones?
Please provide a descrip[tion thatg makes clear what the patch is supposed to do.
Thanks.
Hi Wolfgang Denk,
On 11/1/2013 17:18, Wolfgang Denk wrote:
Dear Bo Shen,
Oh, sorry to make you misunderstand for this patch. This patch is for Atmel sama5d3xek board to support SPL boot, which can boot from SD card in FAT file system.
After finished review, I will correct the subject and send this patch again.
Thanks.
Bo Shen
