[U-Boot] [PATCH 0/9] Exynos4: add support for device tree
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board_exynos4.c file is created for all functions common for Exynos4 boards. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
This patch set is based on patchset: [PATCH V2 0/8] arm: add runtime envs describing build http://patchwork.ozlabs.org/patch/313277/ ... http://patchwork.ozlabs.org/patch/313271/
Piotr Wilczek (9): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT arm:exynos: add common board file for exynos 4 board:origen:fdt: Enable device tree on Origen board:universal:fdt: Enable device tree on Universal trats:fdt: Enable device tree on Trats board:trats2:fdt: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 21 ++ arch/arm/dts/exynos4.dtsi | 139 ++++++++ arch/arm/include/asm/arch-exynos/mipi_dsim.h | 3 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/Makefile | 1 + board/samsung/common/board_exynos4.c | 83 +++++ board/samsung/dts/exynos4210-origen.dts | 45 +++ board/samsung/dts/exynos4210-trats.dts | 120 +++++++ board/samsung/dts/exynos4210-universal_c210.dts | 83 +++++ board/samsung/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++ board/samsung/origen/origen.c | 86 +---- board/samsung/trats/trats.c | 176 +-------- board/samsung/trats2/trats2.c | 216 +---------- board/samsung/universal_c210/universal.c | 178 +++------- drivers/mmc/s5p_sdhci.c | 130 ++++++- drivers/video/exynos_fb.c | 19 + drivers/video/exynos_mipi_dsi.c | 98 +++++ include/configs/exynos4-dt.h | 170 +++++++++ include/configs/origen.h | 103 ++---- include/configs/s5pc210_universal.h | 128 +------ include/configs/trats.h | 177 ++------- include/configs/trats2.h | 199 +---------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 25 files changed, 1511 insertions(+), 1114 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 board/samsung/common/board_exynos4.c create mode 100644 board/samsung/dts/exynos4210-origen.dts create mode 100644 board/samsung/dts/exynos4210-trats.dts create mode 100644 board/samsung/dts/exynos4210-universal_c210.dts create mode 100644 board/samsung/dts/exynos4412-trats2.dts create mode 100644 include/configs/exynos4-dt.h
This patch adds api to decode peripheral id based in interrupt number.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- arch/arm/cpu/armv7/exynos/pinmux.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 904177a..3201d53 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -741,6 +741,25 @@ int exynos_pinmux_config(int peripheral, int flags) }
#ifdef CONFIG_OF_CONTROL + +static int exynos4_pinmux_decode_periph_id(const void *blob, int node) +{ + int err; + u32 cell[3]; + + err = fdtdec_get_int_array(blob, node, "interrupts", cell, + ARRAY_SIZE(cell)); + if (err) + return PERIPH_ID_NONE; + + /* check for invalid peripheral id */ + if ((PERIPH_ID_SDMMC4 > cell[1]) || (cell[1] < PERIPH_ID_UART0)) + return cell[1]; + + debug(" invalid peripheral id\n"); + return PERIPH_ID_NONE; +} + static int exynos5_pinmux_decode_periph_id(const void *blob, int node) { int err; @@ -763,6 +782,8 @@ int pinmux_decode_periph_id(const void *blob, int node) { if (cpu_is_exynos5()) return exynos5_pinmux_decode_periph_id(blob, node); + else if (cpu_is_exynos4()) + return exynos4_pinmux_decode_periph_id(blob, node); else return PERIPH_ID_NONE; }
Hi, Piotr.
Remove the white space.
- int err;
- u32 cell[3];
- err = fdtdec_get_int_array(blob, node, "interrupts", cell,
ARRAY_SIZE(cell));
- if (err)
- /* check for invalid peripheral id */
- if ((PERIPH_ID_SDMMC4 > cell[1]) || (cell[1] < PERIPH_ID_UART0))
What's condition checking? i didn't understand this. PERIPH_ID_SDMMC > cell[1] or PERIPH_ID_UART0 > cell[1] is valid?
Best Regards, Jaehoon Chung
return cell[1];
- debug(" invalid peripheral id\n");
- return PERIPH_ID_NONE;
- else if (cpu_is_exynos4())
else return PERIPH_ID_NONE;return exynos4_pinmux_decode_periph_id(blob, node);
Hi Jaehoon,
Thanks for review. Please comments below.
-----Original Message-----
Hi, Piotr.
number.
Ok.
+static int exynos4_pinmux_decode_periph_id(const void *blob, int +node) {
- int err;
- u32 cell[3];
ARRAY_SIZE(cell));
- if (err)
It supposed to check if cell[1] is within supported periph_id range and should be like this: If ((cell[1] >= PERIPH_ID_UART0) && (cell[1] < PERIPH_ID_COUNT))
return cell[1];
Best regards, Piotr Wilczek
On 28/01/14 21:13, Piotr Wilczek wrote:
Hi Jaehoon,
Hi, Piotr.
number.
Ok.
- int err;
- u32 cell[3];
ARRAY_SIZE(cell));
- if (err)
I know that you refer to exynos5 stuffs. I think this routine unnecessary.
Thanks, Minkyu Kang.
This patch enables parsing mipi data from device tree. Non device tree case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-exynos/mipi_dsim.h | 3 + drivers/video/exynos_mipi_dsi.c | 98 ++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 4 files changed, 103 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mipi_dsim.h b/arch/arm/include/asm/arch-exynos/mipi_dsim.h index 40aca71..c9e8e06 100644 --- a/arch/arm/include/asm/arch-exynos/mipi_dsim.h +++ b/arch/arm/include/asm/arch-exynos/mipi_dsim.h @@ -12,6 +12,7 @@
#include <linux/list.h> #include <linux/fb.h> +#include <lcd.h>
#define PANEL_NAME_SIZE (32)
@@ -368,8 +369,10 @@ int exynos_mipi_dsi_register_lcd_device(struct mipi_dsim_lcd_device *lcd_dev);
void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd); +void exynos_init_dsim_platform_data(vidinfo_t *vid);
/* panel driver init based on mipi dsi interface */ void s6e8ax0_init(void);
+extern int mipi_power(void); #endif /* _DSIM_H */ diff --git a/drivers/video/exynos_mipi_dsi.c b/drivers/video/exynos_mipi_dsi.c index 8bb8fea..ab15ad6 100644 --- a/drivers/video/exynos_mipi_dsi.c +++ b/drivers/video/exynos_mipi_dsi.c @@ -9,6 +9,8 @@
#include <common.h> #include <malloc.h> +#include <fdtdec.h> +#include <libfdt.h> #include <linux/err.h> #include <asm/arch/dsim.h> #include <asm/arch/mipi_dsim.h> @@ -22,7 +24,12 @@ #define master_to_driver(a) (a->dsim_lcd_drv) #define master_to_device(a) (a->dsim_lcd_dev)
+DECLARE_GLOBAL_DATA_PTR; + static struct exynos_platform_mipi_dsim *dsim_pd; +static struct mipi_dsim_config dsim_config_dt; +static struct exynos_platform_mipi_dsim dsim_platform_data_dt; +static struct mipi_dsim_lcd_device mipi_lcd_device_dt;
struct mipi_dsim_ddi { int bus_id; @@ -238,3 +245,94 @@ void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd)
dsim_pd = pd; } + +#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI); + if (node <= 0) { + printf("exynos_mipi_dsi: Can't get device node for mipi dsi\n"); + return -ENODEV; + } + + dsim_config_dt.e_interface = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_interface", 0); + + dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_virtual_ch", 0); + + dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_pixel_format", 0); + + dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_burst_mode", 0); + + dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_no_data_lane", 0); + + dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_byte_clk", 0); + + dsim_config_dt.hfp = fdtdec_get_int(blob, node, + "samsung,dsim-config-hfp", 0); + + dsim_config_dt.p = fdtdec_get_int(blob, node, + "samsung,dsim-config-p", 0); + dsim_config_dt.m = fdtdec_get_int(blob, node, + "samsung,dsim-config-m", 0); + dsim_config_dt.s = fdtdec_get_int(blob, node, + "samsung,dsim-config-s", 0); + + dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node, + "samsung,dsim-config-pll_stable_time", 0); + + dsim_config_dt.esc_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-esc_clk", 0); + + dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node, + "samsung,dsim-config-stop_holding_cnt", 0); + + dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-bta_timeout", 0); + + dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-rx_timeout", 0); + + mipi_lcd_device_dt.name = fdtdec_get_config_string(blob, + "samsung,dsim-device-name"); + + mipi_lcd_device_dt.id = fdtdec_get_int(blob, node, + "samsung,dsim-device-id", 0); + + mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node, + "samsung,dsim-device-bus_id", 0); + + mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node, + "samsung,dsim-device-reverse_panel", 0); + + return 0; +} + +void exynos_init_dsim_platform_data(vidinfo_t *vid) +{ + if (exynos_dsim_config_parse_dt(gd->fdt_blob)) + debug("Can't get proper dsim config.\n"); + + strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name); + dsim_platform_data_dt.dsim_config = &dsim_config_dt; + dsim_platform_data_dt.mipi_power = mipi_power; + dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl; + dsim_platform_data_dt.lcd_panel_info = (void *)vid; + + mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt; + exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt); + +#ifdef CONFIG_S6E8AX0 + s6e8ax0_init(); +#endif + + dsim_pd = &dsim_platform_data_dt; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 433d6a7..f12b4aa 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -78,6 +78,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ + COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 207314f..46e67ff 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -51,6 +51,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), + COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
dsim_pd = pd; }
- int node;
- node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI);
- if (node <= 0) {
return -ENODEV;
- dsim_config_dt.e_interface = fdtdec_get_int(blob, node,
- dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node,
- dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node,
- dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node,
- dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node,
- dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node,
- dsim_config_dt.hfp = fdtdec_get_int(blob, node,
- dsim_config_dt.p = fdtdec_get_int(blob, node,
- dsim_config_dt.m = fdtdec_get_int(blob, node,
- dsim_config_dt.s = fdtdec_get_int(blob, node,
- dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node,
- dsim_config_dt.esc_clk = fdtdec_get_int(blob, node,
- dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node,
- dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node,
- dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node,
- mipi_lcd_device_dt.name = fdtdec_get_config_string(blob,
- mipi_lcd_device_dt.id = fdtdec_get_int(blob, node,
- mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node,
- mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node,
- if (exynos_dsim_config_parse_dt(gd->fdt_blob))
- strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name);
- dsim_platform_data_dt.dsim_config = &dsim_config_dt;
- dsim_platform_data_dt.mipi_power = mipi_power;
- dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl;
- dsim_platform_data_dt.lcd_panel_info = (void *)vid;
- mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt;
- exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt);
- s6e8ax0_init();
No. Please don't init specific panel at here. looks weird.
- dsim_pd = &dsim_platform_data_dt;
- COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */
- COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
Dear Minkyu Kang,
*lcd_dev);
static struct exynos_platform_mipi_dsim *dsim_pd; +static struct mipi_dsim_config dsim_config_dt; static struct +exynos_platform_mipi_dsim dsim_platform_data_dt; static struct +mipi_dsim_lcd_device mipi_lcd_device_dt;
dsim_pd = pd; }
+#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) {
- int node;
- if (node <= 0) {
dsi\n");
return -ENODEV;
+void exynos_init_dsim_platform_data(vidinfo_t *vid) {
- s6e8ax0_init();
Ok.
usb3.0 */
100644
This patch adds additional data parsing from DTB.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- drivers/video/exynos_fb.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index d4863e8..7e0099f 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -20,6 +20,7 @@ #include <asm/arch/dp_info.h> #include <asm/arch/system.h> #include <asm-generic/errno.h> +#include <libtizen.h>
#include "exynos_fb.h"
@@ -269,6 +270,21 @@ int exynos_fimd_parse_dt(const void *blob) panel_info.dual_lcd_enabled = fdtdec_get_int(blob, node, "samsung,dual-lcd-enabled", 0);
+ panel_info.logo_on = fdtdec_get_int(blob, node, + "samsung,logo-on", 0); + + panel_info.resolution = fdtdec_get_int(blob, node, + "samsung,resolution", 0); + + panel_info.rgb_mode = fdtdec_get_int(blob, node, + "samsung,rgb-mode", 0); + + panel_info.power_on_delay = fdtdec_get_int(blob, node, + "samsung,power-on-delay", 0); + +#ifdef CONFIG_TIZEN + get_tizen_logo_info(&panel_info); +#endif return 0; } #endif @@ -281,6 +297,9 @@ void lcd_ctrl_init(void *lcdbase) #ifdef CONFIG_OF_CONTROL if (exynos_fimd_parse_dt(gd->fdt_blob)) debug("Can't get proper panel info\n"); +#ifdef CONFIG_EXYNOS_MIPI_DSIM + exynos_init_dsim_platform_data(&panel_info); +#endif #else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info);
- panel_info.logo_on = fdtdec_get_int(blob, node,
duplicated.
- panel_info.resolution = fdtdec_get_int(blob, node,
- panel_info.rgb_mode = fdtdec_get_int(blob, node,
- panel_info.power_on_delay = fdtdec_get_int(blob, node,
- get_tizen_logo_info(&panel_info);
It looks strange. Why you load the logo at frame buffer driver?
- exynos_init_dsim_platform_data(&panel_info);
Dear Minkyu Kang,
0);
duplicated.
Ok, will remove it.
0);
Ok, I will move it.
Thanks for review. Piotr Wilczek
This patch enables support for device tree for sdhci driver. Non DT case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-exynos/mmc.h | 7 ++ drivers/mmc/s5p_sdhci.c | 130 +++++++++++++++++++++++++++++++- include/fdtdec.h | 1 + include/sdhci.h | 5 ++ lib/fdtdec.c | 1 + 5 files changed, 143 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 98d6530..0fb6461 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -53,6 +53,8 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
+#define SDHCI_MAX_HOSTS 4 + int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline int s5p_mmc_init(int index, int bus_width) @@ -62,4 +64,9 @@ static inline int s5p_mmc_init(int index, int bus_width)
return s5p_sdhci_init(base, index, bus_width); } + +#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); +#endif + #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 40ff873..7456ee0 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -8,9 +8,15 @@ #include <common.h> #include <malloc.h> #include <sdhci.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/clk.h> - +#include <errno.h> +#ifdef CONFIG_OF_CONTROL +#include <asm/arch/pinmux.h> +#endif static char *S5P_NAME = "SAMSUNG SDHCI"; static void s5p_sdhci_set_control_reg(struct sdhci_host *host) { @@ -86,3 +92,125 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
return add_sdhci(host, 52000000, 400000); } + +#ifdef CONFIG_OF_CONTROL +struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; + +static int do_sdhci_init(struct sdhci_host *host) +{ + int dev_id, flag; + int err = 0; + + flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + dev_id = host->index + PERIPH_ID_SDMMC0; + + if (fdt_gpio_isvalid(&host->pwr_gpio)) { + gpio_direction_output(host->pwr_gpio.gpio, 1); + err = exynos_pinmux_config(dev_id, flag); + if (err) { + debug("MMC not configured\n"); + return err; + } + } + + if (fdt_gpio_isvalid(&host->cd_gpio)) { + gpio_direction_output(host->cd_gpio.gpio, 0xf); + if (gpio_get_value(host->cd_gpio.gpio)) + return -ENODEV; + + err = exynos_pinmux_config(dev_id, flag); + if (err) { + printf("external SD not configured\n"); + return err; + } + } + + host->name = S5P_NAME; + + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + host->set_clock = set_mmc_clk; + + host->host_caps = MMC_MODE_HC; + + return add_sdhci(host, 52000000, 400000); +} + +static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) +{ + int bus_width, dev_id; + unsigned int base; + + /* Get device id */ + dev_id = pinmux_decode_periph_id(blob, node); + if (dev_id < PERIPH_ID_SDMMC0) { + debug("MMC: Can't get device id\n"); + return -1; + } + host->index = dev_id - PERIPH_ID_SDMMC0; + + /* Get bus width */ + bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (bus_width <= 0) { + debug("MMC: Can't get bus-width\n"); + return -1; + } + host->bus_width = bus_width; + + /* Get the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("DWMMC: Can't get base address\n"); + return -1; + } + host->ioaddr = (void *)base; + + fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio); + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + + return 0; +} + +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct sdhci_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build sdhci_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &sdhci_host[i]; + + if (sdhci_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_sdhci_init(host); + } + return 0; +} + +int exynos_mmc_init(const void *blob) +{ + int count; + int node_list[SDHCI_MAX_HOSTS]; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + COMPAT_SAMSUNG_EXYNOS_MMC, node_list, + SDHCI_MAX_HOSTS); + + process_nodes(blob, node_list, count); + + return 1; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index f12b4aa..d637f88 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -81,6 +81,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/include/sdhci.h b/include/sdhci.h index 74d06ae..0cba703 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -12,6 +12,7 @@
#include <asm/io.h> #include <mmc.h> +#include <fdtdec.h>
/* * Controller registers @@ -244,6 +245,10 @@ struct sdhci_host { const struct sdhci_ops *ops; int index;
+ int bus_width; + struct fdt_gpio_state pwr_gpio; /* Change Detect GPIO */ + struct fdt_gpio_state cd_gpio; /* Change Detect GPIO */ + void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 46e67ff..a88f648 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -54,6 +54,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
Hi, Piotr.
- int dev_id, flag;
- int err = 0;
- flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE;
- dev_id = host->index + PERIPH_ID_SDMMC0;
- if (fdt_gpio_isvalid(&host->pwr_gpio)) {
what's pwr_gpio? Is it used for the both(eMMC and SD card)?
if (err) {
return err;
- if (fdt_gpio_isvalid(&host->cd_gpio)) {
return -ENODEV;
if (err) {
return err;
- host->name = S5P_NAME;
- host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE |
- host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195;
- host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
- host->set_control_reg = &s5p_sdhci_set_control_reg;
- host->set_clock = set_mmc_clk;
- host->host_caps = MMC_MODE_HC;
- return add_sdhci(host, 52000000, 400000);
- int bus_width, dev_id;
- unsigned int base;
- /* Get device id */
- dev_id = pinmux_decode_periph_id(blob, node);
- if (dev_id < PERIPH_ID_SDMMC0) {
Didn't need to check other boundary?
return -1;
- host->index = dev_id - PERIPH_ID_SDMMC0;
- /* Get bus width */
- bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0);
- if (bus_width <= 0) {
return -1;
- host->bus_width = bus_width;
- /* Get the base address from the device node */
- base = fdtdec_get_addr(blob, node, "reg");
- if (!base) {
DWMMC?
return -1;
- host->ioaddr = (void *)base;
- fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio);
- fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio);
- struct sdhci_host *host;
- int i, node;
- debug("%s: count = %d\n", __func__, count);
- /* build sdhci_host[] for each controller */
- for (i = 0; i < count; i++) {
if (node <= 0)
continue;
return -1;
- int count;
- int node_list[SDHCI_MAX_HOSTS];
- count = fdtdec_find_aliases_for_id(blob, "mmc",
SDHCI_MAX_HOSTS);
- process_nodes(blob, node_list, count);
- return 1;
- COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */
- Controller registers
- int bus_width;
- struct fdt_gpio_state pwr_gpio; /* Change Detect GPIO */
pwr_gpio is Change Detect GPIO? I think that Comment is wrong.
- struct fdt_gpio_state cd_gpio; /* Change Detect GPIO */
Maybe Card detect GPIO is right.
- void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages;
- COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"),
how about using "exynos4-mmc" instead of "exynos-mmc"?
Hi Jaehoon,
Hi, Piotr.
+#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); #endif
+92,125
+static int do_sdhci_init(struct sdhci_host *host) {
- int dev_id, flag;
- int err = 0;
PINMUX_FLAG_NONE;
pwr_gpio is used only for eMMC. cd_gpio is used for SD Card.
if (err) {
return err;
return -ENODEV;
if (err) {
return err;
- return add_sdhci(host, 52000000, 400000); }
+static int sdhci_get_config(const void *blob, int node, struct +sdhci_host *host) {
Yes, I should check for the PERIPH_ID_SDMMC3
return -1;
return -1;
- if (!base) {
DWMMC?
MMC
return -1;
+static int process_nodes(const void *blob, int node_list[], int +count) {
- int i, node;
if (node <= 0)
continue;
i);
return -1;
+int exynos_mmc_init(const void *blob) {
- int count;
SDHCI_MAX_HOSTS);
- return 1;
- int bus_width;
Yes, the comment is wrong.
Yes
100644
Is this driver only for Exynos4?
This patch adds common board file for Exynos 4 based boards.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/dts/exynos4.dtsi | 139 +++++++++++++++++++++++++++ board/samsung/common/Makefile | 1 + board/samsung/common/board_exynos4.c | 83 +++++++++++++++++ include/configs/exynos4-dt.h | 170 ++++++++++++++++++++++++++++++++++ 4 files changed, 393 insertions(+) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 board/samsung/common/board_exynos4.c create mode 100644 include/configs/exynos4-dt.h
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi new file mode 100644 index 0000000..38a6919 --- /dev/null +++ b/arch/arm/dts/exynos4.dtsi @@ -0,0 +1,139 @@ +/* + * Samsung's Exynos4 SoC common device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + + serial@13800000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13800000 0x3c>; + id = <0>; + }; + + serial@13810000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13810000 0x3c>; + id = <1>; + }; + + serial@13820000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13820000 0x3c>; + id = <2>; + }; + + serial@13830000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13830000 0x3c>; + id = <3>; + }; + + serial@13840000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13840000 0x3c>; + id = <4>; + }; + + i2c@13860000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <0 0 0>; + }; + + i2c@13870000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <1 1 0>; + }; + + i2c@13880000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <2 2 0>; + }; + + i2c@13890000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <3 3 0>; + }; + + i2c@138a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <4 4 0>; + }; + + i2c@138b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <5 5 0>; + }; + + i2c@138c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <6 6 0>; + }; + + i2c@138d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <7 7 0>; + }; + + sdhci@12510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12510000 0x1000>; + interrupts = <0 75 0>; + }; + + sdhci@12520000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12520000 0x1000>; + interrupts = <0 76 0>; + }; + + sdhci@12530000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12530000 0x1000>; + interrupts = <0 77 0>; + }; + + sdhci@12540000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12540000 0x1000>; + interrupts = <0 78 0>; + }; + + gpio: gpio { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; +}; diff --git a/board/samsung/common/Makefile b/board/samsung/common/Makefile index 7d2bb8c..25f1e40 100644 --- a/board/samsung/common/Makefile +++ b/board/samsung/common/Makefile @@ -12,4 +12,5 @@ obj-$(CONFIG_MISC_COMMON) += misc.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_BOARD_COMMON) += board.o +obj-$(CONFIG_BOARD_COMMON_EXYNOS4) += board_exynos4.o endif diff --git a/board/samsung/common/board_exynos4.c b/board/samsung/common/board_exynos4.c new file mode 100644 index 0000000..2d313e6 --- /dev/null +++ b/board/samsung/common/board_exynos4.c @@ -0,0 +1,83 @@ +/* + * (C) Copyright 2014 SAMSUNG Electronics + * Piotr Wilczek p.wilczek@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <asm/io.h> +#include <asm/arch/board.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/power.h> +#include <power/pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + int i; + u32 addr; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + gd->ram_size += get_ram_size((long *)addr, SDRAM_BANK_SIZE); + } + return 0; +} + +void dram_init_banksize(void) +{ + int i; + u32 addr, size; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + size = get_ram_size((long *)addr, SDRAM_BANK_SIZE); + + gd->bd->bi_dram[i].start = addr; + gd->bd->bi_dram[i].size = size; + } +} + +int board_init(void) +{ +#ifdef CONFIG_SYS_SPL_ARGS_ADDR + gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; +#else + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; +#endif + + return exynos_init(); +} + +#ifdef CONFIG_OF_CONTROL +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int ret; + + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); + + return ret; +} +#endif +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + printf("Board: %s\n", board_name ? board_name : "Unknown board"); + + return 0; +} +#endif +#endif diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h new file mode 100644 index 0000000..aa941f3 --- /dev/null +++ b/include/configs/exynos4-dt.h @@ -0,0 +1,170 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS4 /* which is in a Exynos5 Family */ +#define CONFIG_TIZEN /* TIZEN lib */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON_EXYNOS4 + +/* Enable fdt support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_EMBED + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* input clock of PLL: EXYNOS4 boards have 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#include <asm/sizes.h> +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M)) + +/* select serial console configuration */ +#define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_SDHCI +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_MMC_DEFAULT_DEV 0 + +/* PWM */ +#define CONFIG_PWM + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_ONENAND +#undef CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MMC +#define CONFIG_CMD_DFU +#define CONFIG_CMD_GPT +#define CONFIG_CMD_PMIC +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* FAT */ +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* EXT4 */ +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE + +/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET + +/* TIZEN THOR downloader support */ +#define CONFIG_CMD_THOR_DOWNLOAD +#define CONFIG_THOR_FUNCTION + +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK + +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_GADGET_MASS_STORAGE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +/* Enable Time Command */ +#define CONFIG_CMD_TIME + +#define CONFIG_CMD_BOOTZ + +#endif /* __CONFIG_H */
- Samsung's Exynos4 SoC common device tree source
- Copyright (c) 2014 Samsung Electronics Co., Ltd.
- serial@13800000 {
id = <0>;
- serial@13810000 {
id = <1>;
- serial@13820000 {
id = <2>;
- serial@13830000 {
id = <3>;
- serial@13840000 {
id = <4>;
- i2c@13860000 {
#size-cells = <0>;
- i2c@13870000 {
#size-cells = <0>;
- i2c@13880000 {
#size-cells = <0>;
- i2c@13890000 {
#size-cells = <0>;
- i2c@138a0000 {
#size-cells = <0>;
- i2c@138b0000 {
#size-cells = <0>;
- i2c@138c0000 {
#size-cells = <0>;
- i2c@138d0000 {
#size-cells = <0>;
- sdhci@12510000 {
#size-cells = <0>;
- sdhci@12520000 {
#size-cells = <0>;
- sdhci@12530000 {
#size-cells = <0>;
- sdhci@12540000 {
#size-cells = <0>;
- gpio: gpio {
gpio-controller;
#gpio-cells = <2>;
I don't understand why need exynos4 common board file. There's already exist board.c that is common board file for samsung.
- (C) Copyright 2014 SAMSUNG Electronics
- Piotr Wilczek p.wilczek@samsung.com
- int i;
- u32 addr;
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
- int i;
- u32 addr, size;
- gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR;
+#else
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- return exynos_init();
- int ret;
- /* mmc initializattion for available channels */
- ret = exynos_mmc_init(gd->fdt_blob);
- if (ret)
- return ret;
- const char *board_name;
- board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL);
- printf("Board: %s\n", board_name ? board_name : "Unknown board");
- Copyright (C) 2014 Samsung Electronics
- Configuration settings for the SAMSUNG EXYNOS5 board.
It's a board specific.
ditto.
I think you should re-arrange what is common feature (it means soc specific) and what is board specific. It looks confused to me. Please fix it.
Dear Minkyu Kang,
-----Original Message----- From: Minkyu Kang [mailto:mk7.kang@samsung.com] Sent: Friday, February 07, 2014 8:53 AM To: Piotr Wilczek Cc: u-boot@lists.denx.de; Kyungmin Park; Lukasz Majewski; Jaehoon Chung; Inha Song; Chanho Park Subject: Re: [PATCH 5/9] arm:exynos: add common board file for exynos 4
new
- serial@13800000 {
id = <0>;
- serial@13810000 {
id = <1>;
- serial@13820000 {
id = <2>;
- serial@13830000 {
id = <3>;
- serial@13840000 {
id = <4>;
- i2c@13860000 {
#size-cells = <0>;
- i2c@13870000 {
#size-cells = <0>;
- i2c@13880000 {
#size-cells = <0>;
- i2c@13890000 {
#size-cells = <0>;
- i2c@138a0000 {
#size-cells = <0>;
- i2c@138b0000 {
#size-cells = <0>;
- i2c@138c0000 {
#size-cells = <0>;
- i2c@138d0000 {
#size-cells = <0>;
- sdhci@12510000 {
#size-cells = <0>;
- sdhci@12520000 {
#size-cells = <0>;
- sdhci@12530000 {
#size-cells = <0>;
- sdhci@12540000 {
#size-cells = <0>;
- gpio: gpio {
gpio-controller;
#gpio-cells = <2>;
Because in the board.c file, both common and board specific functions are added. Max 77686, eth, power, board late initialization functions are board specific. If they are removed, I will be able to use the board.c file.
- int i;
- u32 addr;
SDRAM_BANK_SIZE);
- int i;
- u32 addr, size;
- gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; #else
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; #endif
- int ret;
- if (ret)
- return ret;
Family */
Ok.
SZ_1M))
+/* select serial console configuration */ #define CONFIG_SERIAL2
ditto.
Ok.
On 07/02/14 17:40, Piotr Wilczek wrote:
Dear Minkyu Kang,
It seems to be wrapped with ifdef. I think there's no problems to use same file.
-----Original Message----- From: Minkyu Kang [mailto:mk7.kang@samsung.com] Sent: Friday, February 07, 2014 10:48 AM To: Piotr Wilczek Cc: u-boot@lists.denx.de; 'Kyungmin Park'; Lukasz Majewski; 'Jaehoon Chung'; 'Inha Song'; 'Chanho Park' Subject: Re: [PATCH 5/9] arm:exynos: add common board file for exynos 4
Dear Minkyu Kang,
exynos
4
Max77686 init implementation is different for Trats2 and ifdef will not help here. I think that max77686_init() function should be removed from the board.c file.
Other board specific initializations I can resolve in the way it was done in board_init() function, if that's the preferred way.
Best regrds, Piotr Wilczek
Dear Piotr,
It's up to you.
This patch enables to run Origen board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/dts/exynos4210-origen.dts | 45 ++++++++++++++ board/samsung/origen/origen.c | 86 +++++--------------------- include/configs/origen.h | 103 +++++++------------------------ 3 files changed, 85 insertions(+), 149 deletions(-) create mode 100644 board/samsung/dts/exynos4210-origen.dts
diff --git a/board/samsung/dts/exynos4210-origen.dts b/board/samsung/dts/exynos4210-origen.dts new file mode 100644 index 0000000..5c9d2ae --- /dev/null +++ b/board/samsung/dts/exynos4210-origen.dts @@ -0,0 +1,45 @@ +/* + * Samsung's Exynos4210 based Origen board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "skeleton.dtsi" +/include/ "exynos4.dtsi" + +/ { + model = "Insignal Origen evaluation board based on Exynos4210"; + compatible = "insignal,origen", "samsung,exynos4210"; + + chosen { + bootargs =""; + }; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + status = "disabled"; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 15f77ca..5873770 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -11,17 +11,22 @@ #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> +#include <usb.h>
DECLARE_GLOBAL_DATA_PTR; struct exynos4_gpio_part1 *gpio1; struct exynos4_gpio_part2 *gpio2;
-int board_init(void) +u32 get_board_rev(void) +{ + return 0; +} + +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
- gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; }
@@ -56,84 +61,27 @@ static int board_uart_init(void) return 0; }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } - return err; -} -#endif - -int dram_init(void) +int board_usb_init(int index, enum usb_init_type init) { - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) - + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) - + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) - + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - return 0; }
-void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ - PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ - PHYS_SDRAM_2_SIZE); - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ - PHYS_SDRAM_3_SIZE); - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ - PHYS_SDRAM_4_SIZE); -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) { - printf("\nBoard: ORIGEN\n"); return 0; } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) { - int i, err; - - /* - * MMC2 SD card GPIO: - * - * GPK2[0] SD_2_CLK(2) - * GPK2[1] SD_2_CMD(2) - * GPK2[2] SD_2_CDn - * GPK2[3:6] SD_2_DATA[0:3](2) - */ - for (i = 0; i < 7; i++) { - /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); - - /* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); - - /* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); - continue; - } - - /* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); + int err; + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; } - - err = s5p_mmc_init(2, 4); return err; } #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index f46b833..77e1938 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -6,34 +6,36 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_ORIGEN_H +#define __CONFIG_ORIGEN_H + +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "ORIGEN # " + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-origen
/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* SAMSUNG core */ -#define CONFIG_S5P 1 /* S5P Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/ +#undef CONFIG_TIZEN
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_DCACHE_OFF 1
+/* ORIGEN has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: ORIGEN has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_TEXT_BASE 0x43E00000
#define CONFIG_MACH_TYPE MACH_TYPE_ORIGEN
@@ -42,79 +44,21 @@ #define S5P_CHECK_DIDLE 0xBAD00000 #define S5P_CHECK_LPA 0xABAD0000
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) - -/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 -#define EXYNOS4_DEFAULT_UART_OFFSET 0x020000 - -#define CONFIG_SKIP_LOWLEVEL_INIT - -/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* Command definition*/ -#include <config_cmd_default.h> - #undef CONFIG_CMD_PING #define CONFIG_CMD_ELF #define CONFIG_CMD_DHCP -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
#define CONFIG_SPL_TEXT_BASE 0x02021410
+#undef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "ORIGEN # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -/* ORIGEN has 4 bank of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#define CONFIG_CLK_1000_400_200 @@ -122,17 +66,17 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 +#undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#undef CONFIG_ENV_OFFSET #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
+#undef CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SYS_INIT_SP_ADDR 0x02040000
/* U-boot copy size from boot Media to DRAM.*/ @@ -140,7 +84,6 @@ #define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) #define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512)
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT +#undef CONFIG_CMD_I2C
This patch enables to run Universal board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/dts/exynos4210-universal_c210.dts | 83 +++++++++++ board/samsung/universal_c210/universal.c | 178 ++++++----------------- include/configs/s5pc210_universal.h | 128 +++------------- 3 files changed, 144 insertions(+), 245 deletions(-) create mode 100644 board/samsung/dts/exynos4210-universal_c210.dts
diff --git a/board/samsung/dts/exynos4210-universal_c210.dts b/board/samsung/dts/exynos4210-universal_c210.dts new file mode 100644 index 0000000..1cdd981 --- /dev/null +++ b/board/samsung/dts/exynos4210-universal_c210.dts @@ -0,0 +1,83 @@ +/* + * Samsung's Exynos4210 based Universal C210 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Universal C210 based on Exynos4210 rev0"; + compatible = "samsung,universal_c210", "samsung,exynos4210"; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <480>; + samsung,vl-row = <800>; + samsung,vl-width = <480>; + samsung,vl-height = <800>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <2>; + samsung,vl-hbpd = <16>; + samsung,vl-hfpd = <16>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <8>; + samsung,vl-vfpd = <8>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,pclk_name = <1>; + samsung,sclk_div = <1>; + + samsung,winid = <0>; + samsung,power-on-delay = <10000>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <0>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; +}; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 5ce74b7..7668e33 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -13,16 +13,16 @@ #include <asm/gpio.h> #include <asm/arch/adc.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> -#include <libtizen.h> #include <ld9040.h> #include <power/pmic.h> +#include <usb.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> #include <power/max8998_pmic.h> #include <samsung/misc.h> +#include <usb_mass_storage.h>
@@ -50,7 +50,7 @@ int power_init_board(void) * For PMIC the I2C bus is named as I2C5, but it is connected * to logical I2C adapter 0 */ - ret = pmic_init(I2C_5); + ret = pmic_init(I2C_0); if (ret) return ret;
@@ -59,22 +59,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; -} - static unsigned short get_adc_value(int channel) { struct s5p_adc *adc = (struct s5p_adc *)samsung_get_base_adc(); @@ -159,71 +143,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tUniversal C210\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int err; - - switch (get_hwrev()) { - case 0: - /* - * Set the low to enable LDO_EN - * But when you use the test board for eMMC booting - * you should set it HIGH since it removes the inverter - */ - /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); - break; - default: - /* - * Default reset state is High and there's no inverter - * But set it as HIGH to ensure - */ - /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); - break; - } - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; - -} -#endif - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -271,6 +190,19 @@ struct s3c_plat_otg_data s5pc210_otg_data = { }; #endif
+int board_usb_init(int index, enum usb_init_type init) +{ + debug("USB_udc_probe\n"); + return s3c_udc_probe(&s5pc210_otg_data); +} + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + return 0; +} +#endif + int board_early_init_f(void) { wdt_stop(); @@ -412,6 +344,11 @@ void exynos_cfg_lcd_gpio(void) spi_init(); }
+int mipi_power(void) +{ + return 0; +} + void exynos_reset_lcd(void) { s5p_gpio_set_value(&gpio2->y4, 5, 1); @@ -436,39 +373,6 @@ void exynos_lcd_power_on(void) pmic_set_output(p, MAX8998_REG_ONOFF2, MAX8998_LDO7, LDO_ON); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 480, - .vl_row = 800, - .vl_width = 480, - .vl_height = 800, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_HIGH, - .vl_vsp = CONFIG_SYS_HIGH, - .vl_dp = CONFIG_SYS_HIGH, - - .vl_bpix = 4, /* Bits per pixel */ - - /* LD9040 LCD Panel */ - .vl_hspw = 2, - .vl_hbpd = 16, - .vl_hfpd = 16, - - .vl_vspw = 2, - .vl_vbpd = 8, - .vl_vfpd = 8, - .vl_cmd_allow_len = 0xf, - - .win_id = 0, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 10000, - .reset_delay = 10000, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 0, -}; - void exynos_cfg_ldo(void) { ld9040_cfg_ldo(); @@ -479,30 +383,32 @@ void exynos_enable_ldo(unsigned int onoff) ld9040_enable_ldo(onoff); }
-void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - setenv("lcdinfo", "lcd=ld9040"); -} - -int board_init(void) +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + switch (get_hwrev()) { + case 0: + /* + * Set the low to enable LDO_EN + * But when you use the test board for eMMC booting + * you should set it HIGH since it removes the inverter + */ + /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + s5p_gpio_direction_output(&gpio1->e3, 6, 0); + break; + default: + /* + * Default reset state is High and there's no inverter + * But set it as HIGH to ensure + */ + /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + s5p_gpio_direction_output(&gpio1->e1, 3, 1); + break; + }
#ifdef CONFIG_SOFT_SPI soft_spi_init(); diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 67921e9..e097ea3 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -7,78 +7,31 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_UNIVERSAL_H +#define __CONFIG_UNIVERSAL_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_EXYNOS4210 1 /* which is in a EXYNOS4210 */ -#define CONFIG_UNIVERSAL 1 /* working with Universal */ -#define CONFIG_TIZEN 1 /* TIZEN lib */ +#include <configs/exynos4-dt.h>
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-universal_c210
/* Keep L2 Cache Disabled */ #define CONFIG_SYS_L2CACHE_OFF 1
+/* Universal has 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x44800000
-/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) - -/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH 1 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_TEXT_BASE 0x44800000
#define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS @@ -106,10 +59,6 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" - #define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9" @@ -120,10 +69,6 @@
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -187,47 +132,10 @@ "mmcrootpart=3\0" \ "opts=always_resume=1"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Universal # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* Universal has 2 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION 1 - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_CACHELINE_SIZE 32 - #include <asm/arch/gpio.h> /* * I2C Settings @@ -307,8 +215,10 @@ int universal_spi_read(void); #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP #define CONFIG_LD9040 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
+#define LCD_XRES 480 +#define LCD_YRES 800 + #endif /* __CONFIG_H */
This patch enables to run Trats board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- board/samsung/dts/exynos4210-trats.dts | 120 ++++++++++++++++++++++ board/samsung/trats/trats.c | 176 +------------------------------ include/configs/trats.h | 177 ++++---------------------------- 3 files changed, 144 insertions(+), 329 deletions(-) create mode 100644 board/samsung/dts/exynos4210-trats.dts
diff --git a/board/samsung/dts/exynos4210-trats.dts b/board/samsung/dts/exynos4210-trats.dts new file mode 100644 index 0000000..976c6ee --- /dev/null +++ b/board/samsung/dts/exynos4210-trats.dts @@ -0,0 +1,120 @@ +/* + * Samsung's Exynos4210 based Trats board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats based on Exynos4210"; + compatible = "samsung,trats", "samsung,exynos4210"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index b725505..9e4554a 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -12,17 +12,14 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> -#include <asm/arch/clk.h> #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> #include <power/pmic.h> #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> -#include <libtizen.h> #include <power/max8997_muic.h> #include <power/battery.h> #include <power/max17042_fg.h> @@ -46,10 +43,8 @@ u32 get_board_rev(void) static void check_hw_revision(void); struct s3c_plat_otg_data s5pc210_otg_data;
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
@@ -350,28 +345,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - static unsigned int get_hw_revision(void) { struct exynos4_gpio_part1 *gpio = @@ -404,55 +377,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int err; - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; -} -#endif
#ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) @@ -648,7 +572,7 @@ void exynos_reset_lcd(void) s5p_gpio_direction_output(&gpio2->y4, 5, 1); }
-static int lcd_power(void) +int lcd_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -671,46 +595,7 @@ static int lcd_power(void) return 0; }
-static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim s6e8ax0_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&s6e8ax0_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -733,61 +618,6 @@ static int mipi_power(void) return 0; }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 1, -}; - -void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1, - vid->resolution = HD_RESOLUTION, - vid->rgb_mode = MODE_RGB_P, - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - mipi_lcd_device.reverse_panel = 1; - - strcpy(s6e8ax0_platform_data.lcd_panel_name, mipi_lcd_device.name); - s6e8ax0_platform_data.lcd_power = lcd_power; - s6e8ax0_platform_data.mipi_power = mipi_power; - s6e8ax0_platform_data.phy_enable = set_mipi_phy_ctrl; - s6e8ax0_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - s6e8ax0_init(); - exynos_set_dsim_platform_data(&s6e8ax0_platform_data); - - setenv("lcdinfo", "lcd=s6e8ax0"); -} - #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { diff --git a/include/configs/trats.h b/include/configs/trats.h index 7bd1584..0131bad 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -7,115 +7,38 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS_H +#define __CONFIG_TRATS_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_EXYNOS4210 /* which is in a EXYNOS4210 */ -#define CONFIG_TRATS /* working with TRATS */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h>
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_TRATS
-#ifndef CONFIG_SYS_L2CACHE_OFF -#define CONFIG_SYS_L2_PL310 -#define CONFIG_SYS_PL310_BASE 0x10502000 -#endif +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-trats
+/* TRATS has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x63300000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SYS_TEXT_BASE 0x63300000
/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ #define MACH_TYPE_TRATS 3928 #define CONFIG_MACH_TYPE MACH_TYPE_TRATS
-#include <asm/sizes.h> -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M)) - -/* select serial console configuration */ -#define CONFIG_SERIAL2 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA - -/* PWM */ -#define CONFIG_PWM - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_ONENAND -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_SETEXPR - -/* FAT */ -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot"
-#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
@@ -146,8 +69,6 @@ ""PARTS_ROOT" part 0 5\0"
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -221,59 +142,12 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
- -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TRATS # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* TRATS has 4 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE /* Falcon mode definitions */ #define CONFIG_CMD_SPL -#define CONFIG_SYS_SPL_ARGS_ADDR PHYS_SDRAM_1 + 0x100 +#define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
-/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_CACHELINE_SIZE 32 +/* I2C */ +#include <asm/arch/gpio.h>
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 @@ -286,12 +160,11 @@ #define CONFIG_SOFT_I2C_READ_REPEATED_START #define CONFIG_SYS_I2C_INIT_BOARD
-#include <asm/arch/gpio.h> - /* I2C FG */ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0)
+/* POWER */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX8997 @@ -302,11 +175,6 @@ #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -346,10 +214,7 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
-#define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE - -/* Pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 +#define LCD_XRES 720 +#define LCD_YRES 1280
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- board/samsung/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++++++ board/samsung/trats2/trats2.c | 216 +-------------- include/configs/trats2.h | 199 ++------------ 3 files changed, 459 insertions(+), 390 deletions(-) create mode 100644 board/samsung/dts/exynos4412-trats2.dts
diff --git a/board/samsung/dts/exynos4412-trats2.dts b/board/samsung/dts/exynos4412-trats2.dts new file mode 100644 index 0000000..c8f847c --- /dev/null +++ b/board/samsung/dts/exynos4412-trats2.dts @@ -0,0 +1,434 @@ +/* + * Samsung's Exynos4412 based Trats2 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats2 based on Exynos4412"; + compatible = "samsung,trats2", "samsung,exynos4412"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12510000"; + }; + + i2c@138d0000 { + samsung,i2c-sda-delay = <100>; + samsung,i2c-slave-addr = <0x10>; + samsung,i2c-max-bus-freq = <100000>; + status = "okay"; + + max77686_pmic@09 { + compatible = "maxim,max77686_pmic"; + interrupts = <7 0>; + reg = <0x09 0 0>; + #clock-cells = <1>; + + voltage-regulators { + ldo1_reg: ldo1 { + regulator-compatible = "LDO1"; + regulator-name = "VALIVE_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo2_reg: ldo2 { + regulator-compatible = "LDO2"; + regulator-name = "VM1M2_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo3_reg: ldo3 { + regulator-compatible = "LDO3"; + regulator-name = "VCC_1.8V_AP"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo4_reg: ldo4 { + regulator-compatible = "LDO4"; + regulator-name = "VCC_2.8V_AP"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo5_reg: ldo5 { + regulator-compatible = "LDO5"; + regulator-name = "VCC_1.8V_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo6_reg: ldo6 { + regulator-compatible = "LDO6"; + regulator-name = "VMPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo7_reg: ldo7 { + regulator-compatible = "LDO7"; + regulator-name = "VPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo8_reg: ldo8 { + regulator-compatible = "LDO8"; + regulator-name = "VMIPI_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo9_reg: ldo9 { + regulator-compatible = "LDO9"; + regulator-name = "CAM_ISP_MIPI_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo10_reg: ldo10 { + regulator-compatible = "LDO10"; + regulator-name = "VMIPI_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo11_reg: ldo11 { + regulator-compatible = "LDO11"; + regulator-name = "VABB1_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo12_reg: ldo12 { + regulator-compatible = "LDO12"; + regulator-name = "VUOTG_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-off; + }; + + ldo13_reg: ldo13 { + regulator-compatible = "LDO13"; + regulator-name = "NFC_AVDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo14_reg: ldo14 { + regulator-compatible = "LDO14"; + regulator-name = "VABB2_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo15_reg: ldo15 { + regulator-compatible = "LDO15"; + regulator-name = "VHSIC_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo16_reg: ldo16 { + regulator-compatible = "LDO16"; + regulator-name = "VHSIC_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo17_reg: ldo17 { + regulator-compatible = "LDO17"; + regulator-name = "CAM_SENSOR_CORE_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo18_reg: ldo18 { + regulator-compatible = "LDO18"; + regulator-name = "CAM_ISP_SEN_IO_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo19_reg: ldo19 { + regulator-compatible = "LDO19"; + regulator-name = "VT_CAM_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo20_reg: ldo20 { + regulator-compatible = "LDO20"; + regulator-name = "VDDQ_PRE_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo21_reg: ldo21 { + regulator-compatible = "LDO21"; + regulator-name = "VTF_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo22_reg: ldo22 { + regulator-compatible = "LDO22"; + regulator-name = "VMEM_VDD_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo23_reg: ldo23 { + regulator-compatible = "LDO23"; + regulator-name = "TSP_AVDD_3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-mem-idle; + }; + + ldo24_reg: ldo24 { + regulator-compatible = "LDO24"; + regulator-name = "TSP_VDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo25_reg: ldo25 { + regulator-compatible = "LDO25"; + regulator-name = "LCD_VCC_3.3V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo26_reg: ldo26 { + regulator-compatible = "LDO26"; + regulator-name = "MOTOR_VCC_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-idle; + }; + + buck1_reg: buck1 { + regulator-compatible = "BUCK1"; + regulator-name = "vdd_mif"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck2_reg: buck2 { + regulator-compatible = "BUCK2"; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck3_reg: buck3 { + regulator-compatible = "BUCK3"; + regulator-name = "vdd_int"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck4_reg: buck4 { + regulator-compatible = "BUCK4"; + regulator-name = "vdd_g3d"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-mem-off; + }; + + buck5_reg: buck5 { + regulator-compatible = "BUCK5"; + regulator-name = "VMEM_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + buck6_reg: buck6 { + regulator-compatible = "BUCK6"; + regulator-name = "VCC_SUB_1.35V"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + buck7_reg: buck7 { + regulator-compatible = "BUCK7"; + regulator-name = "VCC_SUB_2.0V"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + buck8_reg: buck8 { + regulator-compatible = "BUCK8"; + regulator-name = "VMEM_VDDF_3.0V"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-mem-off; + }; + + buck9_reg: buck9 { + regulator-compatible = "BUCK9"; + regulator-name = "CAM_ISP_CORE_1.2V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; + regulator-mem-off; + }; + }; + }; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2004002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20C6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index c17c24d..108d0f8 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,13 +8,6 @@
#include <common.h> #include <lcd.h> -#include <asm/io.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> -#include <asm/arch/power.h> -#include <asm/arch/clk.h> -#include <asm/arch/clock.h> -#include <asm/arch/mipi_dsim.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> #include <power/pmic.h> @@ -23,7 +16,6 @@ #include <power/max77693_pmic.h> #include <power/max77693_muic.h> #include <power/max77693_fg.h> -#include <libtizen.h> #include <errno.h> #include <usb.h> #include <usb/s3c_udc.h> @@ -69,16 +61,6 @@ static void check_hw_revision(void) board_rev = modelrev << 8; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS2\n"); - printf("HW Revision:\t0x%04x\n", board_rev); - - return 0; -} -#endif - u32 get_board_rev(void) { return board_rev; @@ -158,26 +140,21 @@ int get_soft_i2c_sda_pin(void)
int board_early_init_f(void) { - check_hw_revision(); board_external_gpio_init();
- gd->flags |= GD_FLG_DISABLE_CONSOLE; +#ifdef CONFIG_SYS_I2C_INIT_BOARD + board_i2c_init(gd->fdt_blob); +#endif
return 0; }
static int pmic_init_max77686(void);
-int board_init(void) +int exynos_init(void) { - struct exynos4_power *pwr = - (struct exynos4_power *)samsung_get_base_power(); - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - /* workaround: clear INFORM4..5 */ - writel(0, (unsigned int)&pwr->inform4); - writel(0, (unsigned int)&pwr->inform5); + check_hw_revision(); + printf("HW Revision:\t0x%04x\n", board_rev);
return 0; } @@ -248,90 +225,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - u32 size_mb; - - size_mb = (get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)) >> 20; - - gd->ram_size = size_mb << 20; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - -int board_mmc_init(bd_t *bis) -{ - int err0, err2 = 0; - - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio2->k0, 2, 1); - s5p_gpio_set_pull(&gpio2->k0, 2, GPIO_PULL_NONE); - - /* - * eMMC GPIO: - * SDR 8-bit@48MHz at MMC0 - * GPK0[0] SD_0_CLK(2) - * GPK0[1] SD_0_CMD(2) - * GPK0[2] SD_0_CDn -> Not used - * GPK0[3:6] SD_0_DATA[0:3](2) - * GPK1[3:6] SD_0_DATA[0:3](3) - * - * DDR 4-bit@26MHz at MMC4 - * GPK0[0] SD_4_CLK(3) - * GPK0[1] SD_4_CMD(3) - * GPK0[2] SD_4_CDn -> Not used - * GPK0[3:6] SD_4_DATA[0:3](3) - * GPK1[3:6] SD_4_DATA[4:7](4) - */ - - err0 = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - if (err0) - debug("SDMMC0 not configured\n"); - else - err0 = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err2) - debug("SDMMC2 not configured\n"); - else - err2 = s5p_mmc_init(2, 4); - } - - return err0 & err2; -} - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -479,46 +372,7 @@ static int pmic_init_max77686(void) */
#ifdef CONFIG_LCD -static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim dsim_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&dsim_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
@@ -555,62 +409,6 @@ void exynos_reset_lcd(void) udelay(10); s5p_gpio_set_value(&gpio1->f2, 1, 1); } - -vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - .mipi_enabled = 1, - - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 25, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, -}; - -void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - - vid->power_on_delay = 30; - - mipi_lcd_device.reverse_panel = 1; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - strcpy(dsim_platform_data.lcd_panel_name, mipi_lcd_device.name); - dsim_platform_data.mipi_power = mipi_power; - dsim_platform_data.phy_enable = set_mipi_phy_ctrl; - dsim_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - - s6e8ax0_init(); - - exynos_set_dsim_platform_data(&dsim_platform_data); -} #endif /* LCD */
#ifdef CONFIG_MISC_INIT_R diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 28270fe..0ac885a 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -8,147 +8,32 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS2_H +#define __CONFIG_TRATS2_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_TIZEN /* TIZEN lib */ - -#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <configs/exynos4-dt.h>
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO - -#define CONFIG_SKIP_LOWLEVEL_INIT - -#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */
-#ifndef CONFIG_SYS_L2CACHE_OFF -#define CONFIG_SYS_L2_PL310 -#define CONFIG_SYS_PL310_BASE 0x10502000 -#endif +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4412-trats2
-#define CONFIG_NR_DRAM_BANKS 4 -#define PHYS_SDRAM_1 0x40000000 /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_3 0x60000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_3_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_4 0x70000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_4_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_END 0x80000000 +/* TRATS2 has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) #define CONFIG_SYS_TEXT_BASE 0x78100000
-#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG - -/* MACH_TYPE_TRATS2 */ -#define MACH_TYPE_TRATS2 3765 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS2 - -#define CONFIG_DISPLAY_CPUINFO - -#include <asm/sizes.h> -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M)) - -/* select serial console configuration */ -#define CONFIG_SERIAL2 - -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - -#define CONFIG_CMDLINE_EDITING - -#define CONFIG_BAUDRATE 115200 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ECHO -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NAND -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_SOURCE -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_PMIC - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -/* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ -#undef CONFIG_CMD_NET - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA -#define CONFIG_MMC_DEFAULT_DEV 0 - -/* PWM */ -#define CONFIG_PWM - -#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot"
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -240,46 +125,6 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - - GENERATED_GBL_DATA_SIZE) - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_BOARD_EARLY_INIT_F - /* I2C */ #include <asm/arch/gpio.h>
@@ -312,11 +157,6 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -356,10 +196,7 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
- Samsung's Exynos4412 based Trats2 board device tree source
- Copyright (c) 2014 Samsung Electronics Co., Ltd.
- model = "Samsung Trats2 based on Exynos4412";
- compatible = "samsung,trats2", "samsung,exynos4412";
- config {
- aliases {
mmc2 isn't 0x12510000.
- i2c@138d0000 {
status = "okay";
max77686_pmic@09 {
interrupts = <7 0>;
reg = <0x09 0 0>;
#clock-cells = <1>;
ldo1_reg: ldo1 {
regulator-mem-on;
ldo2_reg: ldo2 {
regulator-mem-on;
ldo3_reg: ldo3 {
regulator-mem-on;
ldo4_reg: ldo4 {
regulator-mem-on;
ldo5_reg: ldo5 {
regulator-mem-on;
ldo6_reg: ldo6 {
regulator-mem-on;
ldo7_reg: ldo7 {
regulator-mem-on;
ldo8_reg: ldo8 {
regulator-mem-off;
ldo9_reg: ldo9 {
regulator-mem-idle;
ldo10_reg: ldo10 {
regulator-mem-off;
ldo11_reg: ldo11 {
regulator-mem-off;
ldo12_reg: ldo12 {
regulator-mem-off;
ldo13_reg: ldo13 {
regulator-mem-idle;
ldo14_reg: ldo14 {
regulator-mem-off;
ldo15_reg: ldo15 {
regulator-mem-off;
ldo16_reg: ldo16 {
regulator-mem-off;
ldo17_reg: ldo17 {
regulator-mem-idle;
ldo18_reg: ldo18 {
regulator-mem-idle;
ldo19_reg: ldo19 {
regulator-mem-idle;
ldo20_reg: ldo20 {
regulator-mem-idle;
ldo21_reg: ldo21 {
regulator-mem-idle;
ldo22_reg: ldo22 {
regulator-mem-off;
ldo23_reg: ldo23 {
regulator-mem-idle;
ldo24_reg: ldo24 {
regulator-mem-idle;
ldo25_reg: ldo25 {
regulator-mem-idle;
ldo26_reg: ldo26 {
regulator-mem-idle;
buck1_reg: buck1 {
regulator-boot-on;
regulator-mem-off;
buck2_reg: buck2 {
regulator-boot-on;
regulator-mem-off;
buck3_reg: buck3 {
regulator-boot-on;
regulator-mem-off;
buck4_reg: buck4 {
regulator-boot-on;
regulator-mem-off;
buck5_reg: buck5 {
buck6_reg: buck6 {
buck7_reg: buck7 {
buck8_reg: buck8 {
regulator-mem-off;
buck9_reg: buck9 {
regulator-mem-off;
- fimd@11c00000 {
samsung,dp-enabled;
- mipidsi@11c80000 {
- sdhci@12510000 {
- sdhci@12520000 {
- sdhci@12530000 {
- sdhci@12540000 {
-} -#endif
- board_i2c_init(gd->fdt_blob);
return 0; }
- u32 size_mb;
* eMMC GPIO:
* MMC device init
- if (err0)
- else
if (err2)
else
- .hfp = 1,
- .p = 3,
- .m = 120,
- .s = 1,
- .id = -1,
- .bus_id = 0,
- .vl_freq = 60,
- .vl_col = 720,
- .vl_row = 1280,
- .vl_width = 720,
- .vl_hspw = 5,
- .vl_hbpd = 10,
- .vl_hfpd = 10,
- .vl_vspw = 2,
- .vl_vbpd = 1,
- .vl_vfpd = 13,
- .init_delay = 0,
- .reset_delay = 0,
- vid->logo_on = 1;
-#endif
- s6e8ax0_init();
-} #endif /* LCD */
- High Level Configuration Options
- (easy to change)
- Command definition
- Miscellaneous configurable options
- FLASH and environment organization
Hi Jaehoon,
- config {
- aliases {
It is 0x12530000, thanks.
Best regards, Piotr Wilczek
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board.c file is reused for all functions common for Exynos4 boards. Board specific files are implemented in the board siles. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
Piotr Wilczek (12): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT board:samsung:common: remove unused max77686 init function board:samsung: move checkboard to common file arm:exynos: add common DTS file for exynos 4 arm:exynos: enble sdhci and misc_init to common board board:origen: Enable device tree on Origen board:universal: Enable device tree on Universal board:trats: Enable device tree on Trats board:trats2: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 17 + arch/arm/dts/exynos4.dtsi | 139 ++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 + arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/board.c | 182 +++------- board/samsung/dts/exynos4210-origen.dts | 45 +++ board/samsung/dts/exynos4210-trats.dts | 120 +++++++ board/samsung/dts/exynos4210-universal_c210.dts | 83 +++++ board/samsung/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++ board/samsung/origen/origen.c | 112 +----- board/samsung/smdk5250/exynos5-dt.c | 15 - board/samsung/smdk5420/smdk5420.c | 15 - board/samsung/trats/trats.c | 213 +---------- board/samsung/trats2/trats2.c | 233 +----------- board/samsung/universal_c210/universal.c | 204 +++-------- drivers/mmc/s5p_sdhci.c | 129 +++++++ drivers/video/exynos_fb.c | 21 ++ drivers/video/exynos_mipi_dsi.c | 96 +++++ include/configs/exynos4-dt.h | 144 ++++++++ include/configs/origen.h | 117 +++--- include/configs/s5pc210_universal.h | 145 +++----- include/configs/trats.h | 192 +++------- include/configs/trats2.h | 198 ++--------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 27 files changed, 1553 insertions(+), 1334 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 board/samsung/dts/exynos4210-origen.dts create mode 100644 board/samsung/dts/exynos4210-trats.dts create mode 100644 board/samsung/dts/exynos4210-universal_c210.dts create mode 100644 board/samsung/dts/exynos4412-trats2.dts create mode 100644 include/configs/exynos4-dt.h
This patch adds api to decode peripheral id based in interrupt number.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - removed incorrectly implemented check for invalid peripheral id; - removed unnecesary white space;
arch/arm/cpu/armv7/exynos/pinmux.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 645c497..8d6e5c1 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -741,6 +741,21 @@ int exynos_pinmux_config(int peripheral, int flags) }
#ifdef CONFIG_OF_CONTROL +static int exynos4_pinmux_decode_periph_id(const void *blob, int node) +{ + int err; + u32 cell[3]; + + err = fdtdec_get_int_array(blob, node, "interrupts", cell, + ARRAY_SIZE(cell)); + if (err) { + debug(" invalid peripheral id\n"); + return PERIPH_ID_NONE; + } + + return cell[1]; +} + static int exynos5_pinmux_decode_periph_id(const void *blob, int node) { int err; @@ -758,6 +773,8 @@ int pinmux_decode_periph_id(const void *blob, int node) { if (cpu_is_exynos5()) return exynos5_pinmux_decode_periph_id(blob, node); + else if (cpu_is_exynos4()) + return exynos4_pinmux_decode_periph_id(blob, node); else return PERIPH_ID_NONE; }
This patch enables parsing mipi data from device tree. Non device tree case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - removed panel specific init function 's6e8ax0_init' to the board file;
arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 ++ drivers/video/exynos_mipi_dsi.c | 96 ++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 4 files changed, 103 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mipi_dsim.h b/arch/arm/include/asm/arch-exynos/mipi_dsim.h index 40aca71..50e5c25 100644 --- a/arch/arm/include/asm/arch-exynos/mipi_dsim.h +++ b/arch/arm/include/asm/arch-exynos/mipi_dsim.h @@ -12,6 +12,7 @@
#include <linux/list.h> #include <linux/fb.h> +#include <lcd.h>
#define PANEL_NAME_SIZE (32)
@@ -368,8 +369,12 @@ int exynos_mipi_dsi_register_lcd_device(struct mipi_dsim_lcd_device *lcd_dev);
void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd); +void exynos_init_dsim_platform_data(vidinfo_t *vid);
/* panel driver init based on mipi dsi interface */ void s6e8ax0_init(void);
+#ifdef CONFIG_OF_CONTROL +extern int mipi_power(void); +#endif #endif /* _DSIM_H */ diff --git a/drivers/video/exynos_mipi_dsi.c b/drivers/video/exynos_mipi_dsi.c index 8bb8fea..6c10f11 100644 --- a/drivers/video/exynos_mipi_dsi.c +++ b/drivers/video/exynos_mipi_dsi.c @@ -9,6 +9,8 @@
#include <common.h> #include <malloc.h> +#include <fdtdec.h> +#include <libfdt.h> #include <linux/err.h> #include <asm/arch/dsim.h> #include <asm/arch/mipi_dsim.h> @@ -22,7 +24,14 @@ #define master_to_driver(a) (a->dsim_lcd_drv) #define master_to_device(a) (a->dsim_lcd_dev)
+DECLARE_GLOBAL_DATA_PTR; + static struct exynos_platform_mipi_dsim *dsim_pd; +#ifdef CONFIG_OF_CONTROL +static struct mipi_dsim_config dsim_config_dt; +static struct exynos_platform_mipi_dsim dsim_platform_data_dt; +static struct mipi_dsim_lcd_device mipi_lcd_device_dt; +#endif
struct mipi_dsim_ddi { int bus_id; @@ -238,3 +247,90 @@ void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd)
dsim_pd = pd; } + +#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI); + if (node <= 0) { + printf("exynos_mipi_dsi: Can't get device node for mipi dsi\n"); + return -ENODEV; + } + + dsim_config_dt.e_interface = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_interface", 0); + + dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_virtual_ch", 0); + + dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_pixel_format", 0); + + dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_burst_mode", 0); + + dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_no_data_lane", 0); + + dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_byte_clk", 0); + + dsim_config_dt.hfp = fdtdec_get_int(blob, node, + "samsung,dsim-config-hfp", 0); + + dsim_config_dt.p = fdtdec_get_int(blob, node, + "samsung,dsim-config-p", 0); + dsim_config_dt.m = fdtdec_get_int(blob, node, + "samsung,dsim-config-m", 0); + dsim_config_dt.s = fdtdec_get_int(blob, node, + "samsung,dsim-config-s", 0); + + dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node, + "samsung,dsim-config-pll_stable_time", 0); + + dsim_config_dt.esc_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-esc_clk", 0); + + dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node, + "samsung,dsim-config-stop_holding_cnt", 0); + + dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-bta_timeout", 0); + + dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-rx_timeout", 0); + + mipi_lcd_device_dt.name = fdtdec_get_config_string(blob, + "samsung,dsim-device-name"); + + mipi_lcd_device_dt.id = fdtdec_get_int(blob, node, + "samsung,dsim-device-id", 0); + + mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node, + "samsung,dsim-device-bus_id", 0); + + mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node, + "samsung,dsim-device-reverse_panel", 0); + + return 0; +} + +void exynos_init_dsim_platform_data(vidinfo_t *vid) +{ + if (exynos_dsim_config_parse_dt(gd->fdt_blob)) + debug("Can't get proper dsim config.\n"); + + strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name); + dsim_platform_data_dt.dsim_config = &dsim_config_dt; + dsim_platform_data_dt.mipi_power = mipi_power; + dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl; + dsim_platform_data_dt.lcd_panel_info = (void *)vid; + + mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt; + exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt); + + dsim_pd = &dsim_platform_data_dt; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 433d6a7..f12b4aa 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -78,6 +78,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ + COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 207314f..46e67ff 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -51,6 +51,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), + COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
This patch adds additional data parsing from DTB and adds the new exynos_lcd_panel_init() function for panel specific initialisation the from board file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - removed duplicate DTB node parsing for panel_info.logo_on; - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file;
drivers/video/exynos_fb.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index 00a0a11..88d9037 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -104,6 +104,13 @@ void __exynos_backlight_reset(void) void exynos_backlight_reset(void) __attribute__((weak, alias("__exynos_backlight_reset")));
+int __exynos_lcd_panel_init(vidinfo_t *vid) +{ + return 0; +} +int exynos_lcd_panel_init(vidinfo_t *vid) + __attribute__((weak, alias("__exynos_lcd_panel_init"))); + static void lcd_panel_on(vidinfo_t *vid) { udelay(vid->init_delay); @@ -269,6 +276,15 @@ int exynos_fimd_parse_dt(const void *blob) panel_info.dual_lcd_enabled = fdtdec_get_int(blob, node, "samsung,dual-lcd-enabled", 0);
+ panel_info.resolution = fdtdec_get_int(blob, node, + "samsung,resolution", 0); + + panel_info.rgb_mode = fdtdec_get_int(blob, node, + "samsung,rgb-mode", 0); + + panel_info.power_on_delay = fdtdec_get_int(blob, node, + "samsung,power-on-delay", 0); + return 0; } #endif @@ -281,10 +297,15 @@ void lcd_ctrl_init(void *lcdbase) #ifdef CONFIG_OF_CONTROL if (exynos_fimd_parse_dt(gd->fdt_blob)) debug("Can't get proper panel info\n"); +#ifdef CONFIG_EXYNOS_MIPI_DSIM + exynos_init_dsim_platform_data(&panel_info); +#endif + exynos_lcd_panel_init(&panel_info); #else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endif + panel_width = panel_info.vl_width; panel_height = panel_info.vl_height;
This patch enables support for device tree for sdhci driver. Non DT case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - fixed checking for SDMMC boundary; - fiex debug message; - fixed comment to 'pwr_gpio' struct filed;
arch/arm/include/asm/arch-exynos/mmc.h | 7 ++ drivers/mmc/s5p_sdhci.c | 129 ++++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + include/sdhci.h | 5 ++ lib/fdtdec.c | 1 + 5 files changed, 143 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 98d6530..0fb6461 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -53,6 +53,8 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
+#define SDHCI_MAX_HOSTS 4 + int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline int s5p_mmc_init(int index, int bus_width) @@ -62,4 +64,9 @@ static inline int s5p_mmc_init(int index, int bus_width)
return s5p_sdhci_init(base, index, bus_width); } + +#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); +#endif + #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 40ff873..ccae4cc 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -8,8 +8,15 @@ #include <common.h> #include <malloc.h> #include <sdhci.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/clk.h> +#include <errno.h> +#ifdef CONFIG_OF_CONTROL +#include <asm/arch/pinmux.h> +#endif
static char *S5P_NAME = "SAMSUNG SDHCI"; static void s5p_sdhci_set_control_reg(struct sdhci_host *host) @@ -86,3 +93,125 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
return add_sdhci(host, 52000000, 400000); } + +#ifdef CONFIG_OF_CONTROL +struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; + +static int do_sdhci_init(struct sdhci_host *host) +{ + int dev_id, flag; + int err = 0; + + flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + dev_id = host->index + PERIPH_ID_SDMMC0; + + if (fdt_gpio_isvalid(&host->pwr_gpio)) { + gpio_direction_output(host->pwr_gpio.gpio, 1); + err = exynos_pinmux_config(dev_id, flag); + if (err) { + debug("MMC not configured\n"); + return err; + } + } + + if (fdt_gpio_isvalid(&host->cd_gpio)) { + gpio_direction_output(host->cd_gpio.gpio, 0xf); + if (gpio_get_value(host->cd_gpio.gpio)) + return -ENODEV; + + err = exynos_pinmux_config(dev_id, flag); + if (err) { + printf("external SD not configured\n"); + return err; + } + } + + host->name = S5P_NAME; + + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + host->set_clock = set_mmc_clk; + + host->host_caps = MMC_MODE_HC; + + return add_sdhci(host, 52000000, 400000); +} + +static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) +{ + int bus_width, dev_id; + unsigned int base; + + /* Get device id */ + dev_id = pinmux_decode_periph_id(blob, node); + if (dev_id < PERIPH_ID_SDMMC0 && dev_id > PERIPH_ID_SDMMC3) { + debug("MMC: Can't get device id\n"); + return -1; + } + host->index = dev_id - PERIPH_ID_SDMMC0; + + /* Get bus width */ + bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (bus_width <= 0) { + debug("MMC: Can't get bus-width\n"); + return -1; + } + host->bus_width = bus_width; + + /* Get the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("MMC: Can't get base address\n"); + return -1; + } + host->ioaddr = (void *)base; + + fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio); + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + + return 0; +} + +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct sdhci_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build sdhci_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &sdhci_host[i]; + + if (sdhci_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_sdhci_init(host); + } + return 0; +} + +int exynos_mmc_init(const void *blob) +{ + int count; + int node_list[SDHCI_MAX_HOSTS]; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + COMPAT_SAMSUNG_EXYNOS_MMC, node_list, + SDHCI_MAX_HOSTS); + + process_nodes(blob, node_list, count); + + return 1; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index f12b4aa..d637f88 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -81,6 +81,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/include/sdhci.h b/include/sdhci.h index 74d06ae..32e04f5 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -12,6 +12,7 @@
#include <asm/io.h> #include <mmc.h> +#include <fdtdec.h>
/* * Controller registers @@ -244,6 +245,10 @@ struct sdhci_host { const struct sdhci_ops *ops; int index;
+ int bus_width; + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state cd_gpio; /* Card Detect GPIO */ + void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 46e67ff..a88f648 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -54,6 +54,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
This patch removes currently unused max77686_init function. Despite being not used, it's implementation is board specific.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - new patch
board/samsung/common/board.c | 120 ------------------------------------------ 1 file changed, 120 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cd873bc..3ac8005 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,7 +22,6 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> -#include <power/max77686_pmic.h>
@@ -160,133 +159,14 @@ static int board_init_cros_ec_devices(const void *blob) } #endif
-#if defined(CONFIG_POWER) -#ifdef CONFIG_POWER_MAX77686 -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -static int max77686_init(void) -{ - struct pmic *p; - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - int power_init_board(void) { int ret = 0;
set_ps_hold_ctrl();
-#ifdef CONFIG_POWER_MAX77686 - ret = max77686_init(); -#endif - return ret; } -#endif
#ifdef CONFIG_OF_CONTROL static int decode_sromc(const void *blob, struct fdt_sromc *config)
Hi Piotr,
MAX77686 is required for 5250, but missed it somehow when adding 5420 support and making a common config file for both. It is my mistake will correct the same You can refer: "[U-Boot] [PATCH V5 0/6] SMDK5420: Add S2MPS11 pmic support to SMDK5420" by Leela Krishna Amudala It adds a generic way for PMIC support. http://lists.denx.de/pipermail/u-boot/2014-January/171113.html
Regards, Rajeshwari
Changes for v2:
- new patch
u32 val;
int ret = 0;
if (ret) {
return -1;
val |= regval;
if (ret) {
return -1;
struct pmic *p;
return -1;
if (!p)
return -ENODEV;
if (pmic_probe(p))
return -1;
return -1;
return -1;
/* VDD_MIF */
return -1;
return -1;
/* VDD_ARM */
return -1;
return -1;
/* VDD_INT */
return -1;
return -1;
/* VDD_G3D */
return -1;
return -1;
/* VDD_LDO2 */
return -1;
/* VDD_LDO3 */
return -1;
/* VDD_LDO5 */
return -1;
/* VDD_LDO10 */
return -1;
-} -#endif
set_ps_hold_ctrl();
-#endif
return ret;
} -#endif
#ifdef CONFIG_OF_CONTROL static int decode_sromc(const void *blob, struct fdt_sromc *config) -- 1.7.9.5
Hi Rajeshwari,
-----Original Message----- From: Rajeshwari Birje [mailto:rajeshwari.birje@gmail.com] Sent: Friday, February 14, 2014 6:32 AM To: Piotr Wilczek Cc: u-boot@lists.denx.de; Jaehoon Chung; Kyungmin Park; Rajeshwari S Shinde Subject: Re: [U-Boot] [PATCH V2 05/12] board:samsung:common: remove unused max77686 init function
Hi Piotr,
MAX77686 is also used at Trats2 so max77686_init must be either generic based on DT or moved to the board file.
Best regards, Piotr
Regards, Rajeshwari
Changes for v2:
- new patch
u32 val;
int ret = 0;
if (ret) {
reg);
return -1;
val |= regval;
if (ret) {
__func__, reg);
return -1;
struct pmic *p;
return -1;
if (!p)
return -ENODEV;
if (pmic_probe(p))
return -1;
return -1;
return -1;
/* VDD_MIF */
__func__,
return -1;
return -1;
/* VDD_ARM */
__func__,
return -1;
return -1;
/* VDD_INT */
__func__,
return -1;
return -1;
/* VDD_G3D */
__func__,
return -1;
return -1;
/* VDD_LDO2 */
return -1;
/* VDD_LDO3 */
return -1;
/* VDD_LDO5 */
return -1;
/* VDD_LDO10 */
return -1;
-} -#endif
set_ps_hold_ctrl();
-#endif
return ret;
} -#endif
-- Regards, Rajeshwari Shinde
Hi Piotr,
On Fri, Feb 14, 2014 at 3:18 PM, Piotr Wilczek p.wilczek@samsung.com wrote:
Hi Rajeshwari,
Hi Piotr,
Generic in the sense you want all registers to be set and there values have to come from DT file? Which ever you feel OK is fine with me.
Regards, Rajeshwari
Best regards, Piotr
Regards, Rajeshwari
Changes for v2:
- new patch
u32 val;
int ret = 0;
if (ret) {
reg);
return -1;
val |= regval;
if (ret) {
__func__, reg);
return -1;
struct pmic *p;
return -1;
if (!p)
return -ENODEV;
if (pmic_probe(p))
return -1;
return -1;
return -1;
/* VDD_MIF */
__func__,
return -1;
return -1;
/* VDD_ARM */
__func__,
return -1;
return -1;
/* VDD_INT */
__func__,
return -1;
return -1;
/* VDD_G3D */
__func__,
return -1;
return -1;
/* VDD_LDO2 */
return -1;
/* VDD_LDO3 */
return -1;
/* VDD_LDO5 */
return -1;
/* VDD_LDO10 */
return -1;
-} -#endif
set_ps_hold_ctrl();
-#endif
return ret;
} -#endif
Dear Rajeshwari and Piotr,
On 14/02/14 20:40, Rajeshwari Birje wrote:
Hi Piotr,
Hi Rajeshwari,
Hi Piotr,
So.. do you agree to apply this patch? or need another discussion?
Thanks, Minkyu Kang.
Dear Minkyu Kang,
-----Original Message----- From: Minkyu Kang [mailto:mk7.kang@samsung.com] Sent: Saturday, February 22, 2014 8:38 AM To: Rajeshwari Birje; Piotr Wilczek; Rajeshwari S Shinde Cc: Jaehoon Chung; u-boot@lists.denx.de; Kyungmin Park Subject: Re: [U-Boot] [PATCH V2 05/12] board:samsung:common: remove unused max77686 init function
Hi Piotr,
Hi Rajeshwari,
S
Hi Piotr,
values
I will move max77686_init to smdk5250 board file and prepare v3 of this patch series. Do you have any other comments to this series?
On 24/02/14 15:39, Piotr Wilczek wrote:
Dear Minkyu Kang,
Hi Piotr,
Hi Rajeshwari,
S
Hi Piotr,
values
No. looks good to me.
The checkboard function's implementation is common for all DT supporting boards and should be placed in the board common file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Amar amarendra.xt@samsung.com --- Changes for v2: - new patch
board/samsung/common/board.c | 12 ++++++++++++ board/samsung/smdk5250/exynos5-dt.c | 15 --------------- board/samsung/smdk5420/smdk5420.c | 15 --------------- 3 files changed, 12 insertions(+), 30 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 3ac8005..99e2fd3 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -257,7 +257,19 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + printf("Board: %s\n", board_name ? board_name : "unknown"); + + return 0; +} #endif +#endif /* CONFIG_OF_CONTROL */
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 5fb8664..b22fba5 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -45,21 +45,6 @@ int exynos_init(void) return 0; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 3ad2ad0..e4606ec 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -142,18 +142,3 @@ int board_get_revision(void) { return 0; } - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif
Hi Piotr,
This looks fine.
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com
Changes for v2:
- new patch
else
-} -#endif
else
-#endif
1.7.9.5
This patch adds common dtsi file and config header for all Exynos 4 based boards.
Patch additionally adds board specific (weak) functions for board_early_init_f and board_power_init functions.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - reuse existing common board.c file
arch/arm/dts/exynos4.dtsi | 139 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 +++ board/samsung/common/board.c | 20 ++++- include/configs/exynos4-dt.h | 144 ++++++++++++++++++++++++++++++ 4 files changed, 311 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 include/configs/exynos4-dt.h
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi new file mode 100644 index 0000000..38a6919 --- /dev/null +++ b/arch/arm/dts/exynos4.dtsi @@ -0,0 +1,139 @@ +/* + * Samsung's Exynos4 SoC common device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + + serial@13800000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13800000 0x3c>; + id = <0>; + }; + + serial@13810000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13810000 0x3c>; + id = <1>; + }; + + serial@13820000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13820000 0x3c>; + id = <2>; + }; + + serial@13830000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13830000 0x3c>; + id = <3>; + }; + + serial@13840000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13840000 0x3c>; + id = <4>; + }; + + i2c@13860000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <0 0 0>; + }; + + i2c@13870000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <1 1 0>; + }; + + i2c@13880000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <2 2 0>; + }; + + i2c@13890000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <3 3 0>; + }; + + i2c@138a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <4 4 0>; + }; + + i2c@138b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <5 5 0>; + }; + + i2c@138c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <6 6 0>; + }; + + i2c@138d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <7 7 0>; + }; + + sdhci@12510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12510000 0x1000>; + interrupts = <0 75 0>; + }; + + sdhci@12520000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12520000 0x1000>; + interrupts = <0 76 0>; + }; + + sdhci@12530000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12530000 0x1000>; + interrupts = <0 77 0>; + }; + + sdhci@12540000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12540000 0x1000>; + interrupts = <0 78 0>; + }; + + gpio: gpio { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; +}; diff --git a/arch/arm/include/asm/arch-exynos/board.h b/arch/arm/include/asm/arch-exynos/board.h index 243fb12..1b1cd0d 100644 --- a/arch/arm/include/asm/arch-exynos/board.h +++ b/arch/arm/include/asm/arch-exynos/board.h @@ -14,4 +14,16 @@ */ int exynos_init(void);
+/* + * Exynos board specific changes for + * board_early_init_f + */ +int exynos_early_init_f(void); + +/* + * Exynos board specific changes for + * board_power_init + */ +int exynos_power_init(void); + #endif /* EXYNOS_BOARD_H */ diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 99e2fd3..75515d7 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -32,6 +32,20 @@ struct local_info {
static struct local_info local;
+int __exynos_early_init_f(void) +{ + return 0; +} +int exynos_early_init_f(void) + __attribute__((weak, alias("__exynos_early_init_f"))); + +int __exynos_power_init(void) +{ + return 0; +} +int exynos_power_init(void) + __attribute__((weak, alias("__exynos_power_init"))); + #if defined CONFIG_EXYNOS_TMU /* Boot Time Thermal Analysis for SoC temperature threshold breach */ static void boot_temp_check(void) @@ -139,7 +153,7 @@ int board_early_init_f(void) board_i2c_init(gd->fdt_blob); #endif
- return err; + return exynos_early_init_f(); } #endif
@@ -161,11 +175,9 @@ static int board_init_cros_ec_devices(const void *blob)
int power_init_board(void) { - int ret = 0; - set_ps_hold_ctrl();
- return ret; + return exynos_power_init(); }
#ifdef CONFIG_OF_CONTROL diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h new file mode 100644 index 0000000..b1f3729 --- /dev/null +++ b/include/configs/exynos4-dt.h @@ -0,0 +1,144 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS4 /* which is in a Exynos4 Family */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON + +/* Enable fdt support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_EMBED + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* input clock of PLL: EXYNOS4 boards have 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#include <asm/sizes.h> + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_SDHCI +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_MMC_DEFAULT_DEV 0 + +/* PWM */ +#define CONFIG_PWM + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_ONENAND +#undef CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MMC +#define CONFIG_CMD_DFU +#define CONFIG_CMD_GPT +#define CONFIG_CMD_PMIC +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* FAT */ +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* EXT4 */ +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE + +/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET + +/* TIZEN THOR downloader support */ +#define CONFIG_CMD_THOR_DOWNLOAD +#define CONFIG_THOR_FUNCTION + +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK + +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_GADGET_MASS_STORAGE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +#endif /* __CONFIG_H */
This patch enables sdhci initialistion and misc_init_r in common board file for all exynos 4 based boards.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - new patch;
board/samsung/common/board.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 75515d7..f21a6ce 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,6 +22,8 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> +#include <lcd.h> +#include <samsung/misc.h>
@@ -181,6 +183,7 @@ int power_init_board(void) }
#ifdef CONFIG_OF_CONTROL +#ifdef CONFIG_SMC911X static int decode_sromc(const void *blob, struct fdt_sromc *config) { int err; @@ -204,6 +207,7 @@ static int decode_sromc(const void *blob, struct fdt_sromc *config) } return 0; } +#endif
int board_eth_init(bd_t *bis) { @@ -261,10 +265,18 @@ int board_mmc_init(bd_t *bis) { int ret;
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif +#ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); if (ret) debug("dwmmc init failed\n"); +#endif
return ret; } @@ -313,3 +325,21 @@ int arch_early_init_r(void)
return 0; } + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + set_board_info(); +#endif +#ifdef CONFIG_LCD_MENU + keys_init(); + check_boot_mode(); +#endif +#ifdef CONFIG_CMD_BMP + if (panel_info.logo_on) + draw_logo(); +#endif + return 0; +} +#endif
This patch enables to run Origen board on device tree.
Uart, DRAM and MMC init functions are removed as their generic replacements form the common board file are used.
The config file is modified to contain only board specific options.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - no changes;
board/samsung/dts/exynos4210-origen.dts | 45 ++++++++++++ board/samsung/origen/origen.c | 112 +++-------------------------- include/configs/origen.h | 117 +++++++++++-------------------- 3 files changed, 94 insertions(+), 180 deletions(-) create mode 100644 board/samsung/dts/exynos4210-origen.dts
diff --git a/board/samsung/dts/exynos4210-origen.dts b/board/samsung/dts/exynos4210-origen.dts new file mode 100644 index 0000000..5c9d2ae --- /dev/null +++ b/board/samsung/dts/exynos4210-origen.dts @@ -0,0 +1,45 @@ +/* + * Samsung's Exynos4210 based Origen board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "skeleton.dtsi" +/include/ "exynos4.dtsi" + +/ { + model = "Insignal Origen evaluation board based on Exynos4210"; + compatible = "insignal,origen", "samsung,exynos4210"; + + chosen { + bootargs =""; + }; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + status = "disabled"; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 15f77ca..d502f02 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -11,129 +11,35 @@ #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> +#include <usb.h>
DECLARE_GLOBAL_DATA_PTR; -struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2;
-int board_init(void) +u32 get_board_rev(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; }
-static int board_uart_init(void) +int exynos_init(void) { - int err; - - err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); - if (err) { - debug("UART0 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); - if (err) { - debug("UART1 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); - if (err) { - debug("UART2 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); - if (err) { - debug("UART3 not configured\n"); - return err; - } - return 0; }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } - return err; -} -#endif - -int dram_init(void) +int board_usb_init(int index, enum usb_init_type init) { - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) - + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) - + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) - + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - return 0; }
-void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ - PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ - PHYS_SDRAM_2_SIZE); - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ - PHYS_SDRAM_3_SIZE); - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ - PHYS_SDRAM_4_SIZE); -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) { - printf("\nBoard: ORIGEN\n"); return 0; } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) +#ifdef CONFIG_BOARD_EARLY_INIT_F +int exynos_early_init_f(void) { - int i, err; - - /* - * MMC2 SD card GPIO: - * - * GPK2[0] SD_2_CLK(2) - * GPK2[1] SD_2_CMD(2) - * GPK2[2] SD_2_CDn - * GPK2[3:6] SD_2_DATA[0:3](2) - */ - for (i = 0; i < 7; i++) { - /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); - - /* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); - - /* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); - continue; - } - - /* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); - } - - err = s5p_mmc_init(2, 4); - return err; + return 0; } #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index f46b833..2c973cb 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -6,115 +6,79 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_ORIGEN_H +#define __CONFIG_ORIGEN_H + +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "ORIGEN # " + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-origen
/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* SAMSUNG core */ -#define CONFIG_S5P 1 /* S5P Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_DCACHE_OFF 1
+/* ORIGEN has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: ORIGEN has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_TEXT_BASE 0x43E00000
#define CONFIG_MACH_TYPE MACH_TYPE_ORIGEN
-/* Power Down Modes */ -#define S5P_CHECK_SLEEP 0x00000BAD -#define S5P_CHECK_DIDLE 0xBAD00000 -#define S5P_CHECK_LPA 0xABAD0000 - /* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200 -#define EXYNOS4_DEFAULT_UART_OFFSET 0x020000
-#define CONFIG_SKIP_LOWLEVEL_INIT +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE)
-/* PWM */ -#define CONFIG_PWM 1 +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-/* Command definition*/ -#include <config_cmd_default.h> +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000
#undef CONFIG_CMD_PING #define CONFIG_CMD_ELF #define CONFIG_CMD_DHCP -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
#define CONFIG_SPL_TEXT_BASE 0x02021410
+#undef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "ORIGEN # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -/* ORIGEN has 4 bank of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#define CONFIG_CLK_1000_400_200 @@ -122,17 +86,17 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 +#undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#undef CONFIG_ENV_OFFSET #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
+#undef CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SYS_INIT_SP_ADDR 0x02040000
/* U-boot copy size from boot Media to DRAM.*/ @@ -140,7 +104,6 @@ #define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) #define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512)
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT +#undef CONFIG_CMD_I2C
This patch enables to run Universal board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - no changes;
board/samsung/dts/exynos4210-universal_c210.dts | 83 +++++++++ board/samsung/universal_c210/universal.c | 204 ++++++----------------- include/configs/s5pc210_universal.h | 145 +++++----------- 3 files changed, 176 insertions(+), 256 deletions(-) create mode 100644 board/samsung/dts/exynos4210-universal_c210.dts
diff --git a/board/samsung/dts/exynos4210-universal_c210.dts b/board/samsung/dts/exynos4210-universal_c210.dts new file mode 100644 index 0000000..1cdd981 --- /dev/null +++ b/board/samsung/dts/exynos4210-universal_c210.dts @@ -0,0 +1,83 @@ +/* + * Samsung's Exynos4210 based Universal C210 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Universal C210 based on Exynos4210 rev0"; + compatible = "samsung,universal_c210", "samsung,exynos4210"; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <480>; + samsung,vl-row = <800>; + samsung,vl-width = <480>; + samsung,vl-height = <800>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <2>; + samsung,vl-hbpd = <16>; + samsung,vl-hfpd = <16>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <8>; + samsung,vl-vfpd = <8>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,pclk_name = <1>; + samsung,sclk_div = <1>; + + samsung,winid = <0>; + samsung,power-on-delay = <10000>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <0>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; +}; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 96da7e0..82249d3 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -13,16 +13,17 @@ #include <asm/gpio.h> #include <asm/arch/adc.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> -#include <libtizen.h> #include <ld9040.h> #include <power/pmic.h> +#include <usb.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> #include <power/max8998_pmic.h> +#include <libtizen.h> #include <samsung/misc.h> +#include <usb_mass_storage.h>
@@ -42,7 +43,7 @@ static int get_hwrev(void)
static void init_pmic_lcd(void);
-int power_init_board(void) +int exynos_power_init(void) { int ret;
@@ -59,22 +60,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; -} - static unsigned short get_adc_value(int channel) { struct s5p_adc *adc = (struct s5p_adc *)samsung_get_base_adc(); @@ -159,71 +144,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tUniversal C210\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int err; - - switch (get_hwrev()) { - case 0: - /* - * Set the low to enable LDO_EN - * But when you use the test board for eMMC booting - * you should set it HIGH since it removes the inverter - */ - /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); - break; - default: - /* - * Default reset state is High and there's no inverter - * But set it as HIGH to ensure - */ - /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); - break; - } - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; - -} -#endif - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -271,7 +191,20 @@ struct s3c_plat_otg_data s5pc210_otg_data = { }; #endif
-int board_early_init_f(void) +int board_usb_init(int index, enum usb_init_type init) +{ + debug("USB_udc_probe\n"); + return s3c_udc_probe(&s5pc210_otg_data); +} + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + return 0; +} +#endif + +int exynos_early_init_f(void) { wdt_stop();
@@ -412,6 +345,11 @@ void exynos_cfg_lcd_gpio(void) spi_init(); }
+int mipi_power(void) +{ + return 0; +} + void exynos_reset_lcd(void) { s5p_gpio_set_value(&gpio2->y4, 5, 1); @@ -436,39 +374,6 @@ void exynos_lcd_power_on(void) pmic_set_output(p, MAX8998_REG_ONOFF2, MAX8998_LDO7, LDO_ON); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 480, - .vl_row = 800, - .vl_width = 480, - .vl_height = 800, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_HIGH, - .vl_vsp = CONFIG_SYS_HIGH, - .vl_dp = CONFIG_SYS_HIGH, - - .vl_bpix = 4, /* Bits per pixel */ - - /* LD9040 LCD Panel */ - .vl_hspw = 2, - .vl_hbpd = 16, - .vl_hfpd = 16, - - .vl_vspw = 2, - .vl_vbpd = 8, - .vl_vfpd = 8, - .vl_cmd_allow_len = 0xf, - - .win_id = 0, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 10000, - .reset_delay = 10000, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 0, -}; - void exynos_cfg_ldo(void) { ld9040_cfg_ldo(); @@ -479,30 +384,32 @@ void exynos_enable_ldo(unsigned int onoff) ld9040_enable_ldo(onoff); }
-void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - setenv("lcdinfo", "lcd=ld9040"); -} - -int board_init(void) +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + switch (get_hwrev()) { + case 0: + /* + * Set the low to enable LDO_EN + * But when you use the test board for eMMC booting + * you should set it HIGH since it removes the inverter + */ + /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + s5p_gpio_direction_output(&gpio1->e3, 6, 0); + break; + default: + /* + * Default reset state is High and there's no inverter + * But set it as HIGH to ensure + */ + /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + s5p_gpio_direction_output(&gpio1->e1, 3, 1); + break; + }
#ifdef CONFIG_SOFT_SPI soft_spi_init(); @@ -513,20 +420,15 @@ int board_init(void) return 0; }
-#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) +void exynos_lcd_panel_init(vidinfo_t *vid) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); -#endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); +#ifdef CONFIG_TIZEN + get_tizen_logo_info(vid); #endif - return 0; + + /* for LD9040. */ + vid->pclk_name = 1; /* MPLL */ + vid->sclk_div = 1; + + setenv("lcdinfo", "lcd=ld9040"); } -#endif diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 67921e9..a97d4c2 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -7,78 +7,56 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_UNIVERSAL_H +#define __CONFIG_UNIVERSAL_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_EXYNOS4210 1 /* which is in a EXYNOS4210 */ -#define CONFIG_UNIVERSAL 1 /* working with Universal */ -#define CONFIG_TIZEN 1 /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-universal_c210
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_TIZEN /* TIZEN lib */
/* Keep L2 Cache Disabled */ #define CONFIG_SYS_L2CACHE_OFF 1
+/* Universal has 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x44800000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE
-/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH 1 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_TEXT_BASE 0x44800000
#define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS @@ -106,10 +84,6 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" - #define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9" @@ -120,10 +94,6 @@
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -187,47 +157,10 @@ "mmcrootpart=3\0" \ "opts=always_resume=1"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Universal # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* Universal has 2 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION 1 - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_CACHELINE_SIZE 32 - #include <asm/arch/gpio.h> /* * I2C Settings @@ -307,8 +240,10 @@ int universal_spi_read(void); #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP #define CONFIG_LD9040 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
+#define LCD_XRES 480 +#define LCD_YRES 800 + #endif /* __CONFIG_H */
Hello Piotr,
Acked-by: Przemyslaw Marczak p.marczak@samsung.com
This patch enables to run Trats board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- Changes for v2: - no changes;
board/samsung/dts/exynos4210-trats.dts | 120 ++++++++++++++++++ board/samsung/trats/trats.c | 213 ++------------------------------ include/configs/trats.h | 192 +++++++--------------------- 3 files changed, 172 insertions(+), 353 deletions(-) create mode 100644 board/samsung/dts/exynos4210-trats.dts
diff --git a/board/samsung/dts/exynos4210-trats.dts b/board/samsung/dts/exynos4210-trats.dts new file mode 100644 index 0000000..79fdad2 --- /dev/null +++ b/board/samsung/dts/exynos4210-trats.dts @@ -0,0 +1,120 @@ +/* + * Samsung's Exynos4210 based Trats board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats based on Exynos4210"; + compatible = "samsung,trats", "samsung,exynos4210"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index b725505..0f78ec0 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -12,23 +12,20 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> -#include <asm/arch/clk.h> #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> #include <power/pmic.h> #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> -#include <libtizen.h> #include <power/max8997_muic.h> #include <power/battery.h> #include <power/max17042_fg.h> +#include <libtizen.h> #include <usb.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
#include "setup.h"
@@ -46,10 +43,8 @@ u32 get_board_rev(void) static void check_hw_revision(void); struct s3c_plat_otg_data s5pc210_otg_data;
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
@@ -281,7 +276,7 @@ static int pmic_init_max8997(void) return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg, ret; struct power_battery *pb; @@ -350,28 +345,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - static unsigned int get_hw_revision(void) { struct exynos4_gpio_part1 *gpio = @@ -404,55 +377,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int err; - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; -} -#endif
#ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) @@ -599,38 +523,22 @@ static void board_power_init(void) writel(0, (unsigned int)&pwr->arm_core1_configuration); }
-static void board_uart_init(void) +static void exynos_uart_init(void) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); struct exynos4_gpio_part2 *gpio2 = (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int i; - - /* - * UART2 GPIOs - * GPA1CON[0] = UART_2_RXD(2) - * GPA1CON[1] = UART_2_TXD(2) - * GPA1CON[2] = I2C_3_SDA (3) - * GPA1CON[3] = I2C_3_SCL (3) - */ - - for (i = 0; i < 4; i++) { - s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC((i > 1) ? 0x3 : 0x2)); - }
/* UART_SEL GPY4[7] (part2) at EXYNOS4 */ s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); s5p_gpio_direction_output(&gpio2->y4, 7, 1); }
-int board_early_init_f(void) +int exynos_early_init_f(void) { wdt_stop(); pmic_reset(); board_clock_init(); - board_uart_init(); + exynos_uart_init(); board_power_init();
return 0; @@ -648,7 +556,7 @@ void exynos_reset_lcd(void) s5p_gpio_direction_output(&gpio2->y4, 5, 1); }
-static int lcd_power(void) +int lcd_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -671,46 +579,7 @@ static int lcd_power(void) return 0; }
-static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim s6e8ax0_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&s6e8ax0_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -733,75 +602,13 @@ static int mipi_power(void) return 0; }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 1, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1, - vid->resolution = HD_RESOLUTION, - vid->rgb_mode = MODE_RGB_P, - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - mipi_lcd_device.reverse_panel = 1; - - strcpy(s6e8ax0_platform_data.lcd_panel_name, mipi_lcd_device.name); - s6e8ax0_platform_data.lcd_power = lcd_power; - s6e8ax0_platform_data.mipi_power = mipi_power; - s6e8ax0_platform_data.phy_enable = set_mipi_phy_ctrl; - s6e8ax0_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - exynos_set_dsim_platform_data(&s6e8ax0_platform_data); - setenv("lcdinfo", "lcd=s6e8ax0"); -} - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif diff --git a/include/configs/trats.h b/include/configs/trats.h index 718107a..b19622a 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -7,25 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS_H +#define __CONFIG_TRATS_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_EXYNOS4210 /* which is in a EXYNOS4210 */ -#define CONFIG_TRATS /* working with TRATS */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#define CONFIG_TRATS
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-trats + +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -33,90 +27,46 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
+/* TRATS has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_TEXT_BASE 0x63300000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000)
-/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ -#define MACH_TYPE_TRATS 3928 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS +#define CONFIG_SYS_TEXT_BASE 0x63300000
-#include <asm/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200
-/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA - -/* PWM */ -#define CONFIG_PWM - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_ONENAND -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_SETEXPR - -/* FAT */ -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ +#define MACH_TYPE_TRATS 3928 +#define CONFIG_MACH_TYPE MACH_TYPE_TRATS + #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
@@ -151,8 +101,6 @@ "params.bin mmc 0x38 0x8\0"
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -226,59 +174,12 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
- -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TRATS # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* TRATS has 4 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE /* Falcon mode definitions */ #define CONFIG_CMD_SPL -#define CONFIG_SYS_SPL_ARGS_ADDR PHYS_SDRAM_1 + 0x100 - -/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS +#define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_CACHELINE_SIZE 32 +/* I2C */ +#include <asm/arch/gpio.h>
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 @@ -291,12 +192,11 @@ #define CONFIG_SOFT_I2C_READ_REPEATED_START #define CONFIG_SYS_I2C_INIT_BOARD
-#include <asm/arch/gpio.h> - /* I2C FG */ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0)
+/* POWER */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX8997 @@ -307,11 +207,6 @@ #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -351,10 +246,7 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
-#define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE - -/* Pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 +#define LCD_XRES 720 +#define LCD_YRES 1280
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - fixed mmc2 addres in DT;
board/samsung/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++++++ board/samsung/trats2/trats2.c | 233 +---------------- include/configs/trats2.h | 198 +++----------- 3 files changed, 474 insertions(+), 391 deletions(-) create mode 100644 board/samsung/dts/exynos4412-trats2.dts
diff --git a/board/samsung/dts/exynos4412-trats2.dts b/board/samsung/dts/exynos4412-trats2.dts new file mode 100644 index 0000000..d31e780 --- /dev/null +++ b/board/samsung/dts/exynos4412-trats2.dts @@ -0,0 +1,434 @@ +/* + * Samsung's Exynos4412 based Trats2 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats2 based on Exynos4412"; + compatible = "samsung,trats2", "samsung,exynos4412"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + i2c@138d0000 { + samsung,i2c-sda-delay = <100>; + samsung,i2c-slave-addr = <0x10>; + samsung,i2c-max-bus-freq = <100000>; + status = "okay"; + + max77686_pmic@09 { + compatible = "maxim,max77686_pmic"; + interrupts = <7 0>; + reg = <0x09 0 0>; + #clock-cells = <1>; + + voltage-regulators { + ldo1_reg: ldo1 { + regulator-compatible = "LDO1"; + regulator-name = "VALIVE_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo2_reg: ldo2 { + regulator-compatible = "LDO2"; + regulator-name = "VM1M2_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo3_reg: ldo3 { + regulator-compatible = "LDO3"; + regulator-name = "VCC_1.8V_AP"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo4_reg: ldo4 { + regulator-compatible = "LDO4"; + regulator-name = "VCC_2.8V_AP"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo5_reg: ldo5 { + regulator-compatible = "LDO5"; + regulator-name = "VCC_1.8V_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo6_reg: ldo6 { + regulator-compatible = "LDO6"; + regulator-name = "VMPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo7_reg: ldo7 { + regulator-compatible = "LDO7"; + regulator-name = "VPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo8_reg: ldo8 { + regulator-compatible = "LDO8"; + regulator-name = "VMIPI_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo9_reg: ldo9 { + regulator-compatible = "LDO9"; + regulator-name = "CAM_ISP_MIPI_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo10_reg: ldo10 { + regulator-compatible = "LDO10"; + regulator-name = "VMIPI_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo11_reg: ldo11 { + regulator-compatible = "LDO11"; + regulator-name = "VABB1_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo12_reg: ldo12 { + regulator-compatible = "LDO12"; + regulator-name = "VUOTG_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-off; + }; + + ldo13_reg: ldo13 { + regulator-compatible = "LDO13"; + regulator-name = "NFC_AVDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo14_reg: ldo14 { + regulator-compatible = "LDO14"; + regulator-name = "VABB2_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo15_reg: ldo15 { + regulator-compatible = "LDO15"; + regulator-name = "VHSIC_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo16_reg: ldo16 { + regulator-compatible = "LDO16"; + regulator-name = "VHSIC_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo17_reg: ldo17 { + regulator-compatible = "LDO17"; + regulator-name = "CAM_SENSOR_CORE_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo18_reg: ldo18 { + regulator-compatible = "LDO18"; + regulator-name = "CAM_ISP_SEN_IO_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo19_reg: ldo19 { + regulator-compatible = "LDO19"; + regulator-name = "VT_CAM_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo20_reg: ldo20 { + regulator-compatible = "LDO20"; + regulator-name = "VDDQ_PRE_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo21_reg: ldo21 { + regulator-compatible = "LDO21"; + regulator-name = "VTF_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo22_reg: ldo22 { + regulator-compatible = "LDO22"; + regulator-name = "VMEM_VDD_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo23_reg: ldo23 { + regulator-compatible = "LDO23"; + regulator-name = "TSP_AVDD_3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-mem-idle; + }; + + ldo24_reg: ldo24 { + regulator-compatible = "LDO24"; + regulator-name = "TSP_VDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo25_reg: ldo25 { + regulator-compatible = "LDO25"; + regulator-name = "LCD_VCC_3.3V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo26_reg: ldo26 { + regulator-compatible = "LDO26"; + regulator-name = "MOTOR_VCC_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-idle; + }; + + buck1_reg: buck1 { + regulator-compatible = "BUCK1"; + regulator-name = "vdd_mif"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck2_reg: buck2 { + regulator-compatible = "BUCK2"; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck3_reg: buck3 { + regulator-compatible = "BUCK3"; + regulator-name = "vdd_int"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck4_reg: buck4 { + regulator-compatible = "BUCK4"; + regulator-name = "vdd_g3d"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-mem-off; + }; + + buck5_reg: buck5 { + regulator-compatible = "BUCK5"; + regulator-name = "VMEM_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + buck6_reg: buck6 { + regulator-compatible = "BUCK6"; + regulator-name = "VCC_SUB_1.35V"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + buck7_reg: buck7 { + regulator-compatible = "BUCK7"; + regulator-name = "VCC_SUB_2.0V"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + buck8_reg: buck8 { + regulator-compatible = "BUCK8"; + regulator-name = "VMEM_VDDF_3.0V"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-mem-off; + }; + + buck9_reg: buck9 { + regulator-compatible = "BUCK9"; + regulator-name = "CAM_ISP_CORE_1.2V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; + regulator-mem-off; + }; + }; + }; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2004002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20C6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index c17c24d..043bf6b 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,15 +8,9 @@
#include <common.h> #include <lcd.h> -#include <asm/io.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> -#include <asm/arch/power.h> -#include <asm/arch/clk.h> -#include <asm/arch/clock.h> -#include <asm/arch/mipi_dsim.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> +#include <asm/arch/mipi_dsim.h> #include <power/pmic.h> #include <power/max77686_pmic.h> #include <power/battery.h> @@ -28,7 +22,6 @@ #include <usb.h> #include <usb/s3c_udc.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
@@ -69,16 +62,6 @@ static void check_hw_revision(void) board_rev = modelrev << 8; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS2\n"); - printf("HW Revision:\t0x%04x\n", board_rev); - - return 0; -} -#endif - u32 get_board_rev(void) { return board_rev; @@ -156,33 +139,24 @@ int get_soft_i2c_sda_pin(void) } #endif
-int board_early_init_f(void) +int exynos_early_init_f(void) { - check_hw_revision(); board_external_gpio_init();
- gd->flags |= GD_FLG_DISABLE_CONSOLE; - return 0; }
static int pmic_init_max77686(void);
-int board_init(void) +int exynos_init(void) { - struct exynos4_power *pwr = - (struct exynos4_power *)samsung_get_base_power(); - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - /* workaround: clear INFORM4..5 */ - writel(0, (unsigned int)&pwr->inform4); - writel(0, (unsigned int)&pwr->inform5); + check_hw_revision(); + printf("HW Revision:\t0x%04x\n", board_rev);
return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg; struct power_battery *pb; @@ -248,90 +222,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - u32 size_mb; - - size_mb = (get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)) >> 20; - - gd->ram_size = size_mb << 20; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - -int board_mmc_init(bd_t *bis) -{ - int err0, err2 = 0; - - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio2->k0, 2, 1); - s5p_gpio_set_pull(&gpio2->k0, 2, GPIO_PULL_NONE); - - /* - * eMMC GPIO: - * SDR 8-bit@48MHz at MMC0 - * GPK0[0] SD_0_CLK(2) - * GPK0[1] SD_0_CMD(2) - * GPK0[2] SD_0_CDn -> Not used - * GPK0[3:6] SD_0_DATA[0:3](2) - * GPK1[3:6] SD_0_DATA[0:3](3) - * - * DDR 4-bit@26MHz at MMC4 - * GPK0[0] SD_4_CLK(3) - * GPK0[1] SD_4_CMD(3) - * GPK0[2] SD_4_CDn -> Not used - * GPK0[3:6] SD_4_DATA[0:3](3) - * GPK1[3:6] SD_4_DATA[4:7](4) - */ - - err0 = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - if (err0) - debug("SDMMC0 not configured\n"); - else - err0 = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err2) - debug("SDMMC2 not configured\n"); - else - err2 = s5p_mmc_init(2, 4); - } - - return err0 & err2; -} - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -479,46 +369,7 @@ static int pmic_init_max77686(void) */
#ifdef CONFIG_LCD -static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim dsim_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&dsim_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
@@ -556,77 +407,13 @@ void exynos_reset_lcd(void) s5p_gpio_set_value(&gpio1->f2, 1, 1); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - .mipi_enabled = 1, - - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 25, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - - vid->power_on_delay = 30; - - mipi_lcd_device.reverse_panel = 1; - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - - strcpy(dsim_platform_data.lcd_panel_name, mipi_lcd_device.name); - dsim_platform_data.mipi_power = mipi_power; - dsim_platform_data.phy_enable = set_mipi_phy_ctrl; - dsim_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - - exynos_set_dsim_platform_data(&dsim_platform_data); -} -#endif /* LCD */ - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif +#endif /* LCD */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index e30c428..3198580 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -8,27 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS2_H +#define __CONFIG_TRATS2_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_TIZEN /* TIZEN lib */ - -#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <configs/exynos4-dt.h>
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */
-#define CONFIG_SKIP_LOWLEVEL_INIT +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4412-trats2
-#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -36,121 +26,41 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
-#define CONFIG_NR_DRAM_BANKS 4 -#define PHYS_SDRAM_1 0x40000000 /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_3 0x60000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_3_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_4 0x70000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_4_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_END 0x80000000 - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ +/* TRATS2 has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) #define CONFIG_SYS_TEXT_BASE 0x78100000
-#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG - -/* MACH_TYPE_TRATS2 */ -#define MACH_TYPE_TRATS2 3765 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS2 - -#define CONFIG_DISPLAY_CPUINFO - -#include <asm/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ #define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMDLINE_EDITING +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ECHO -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NAND -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_SOURCE -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_PMIC - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -/* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ -#undef CONFIG_CMD_NET - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA -#define CONFIG_MMC_DEFAULT_DEV 0 - -/* PWM */ -#define CONFIG_PWM - -#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +#define CONFIG_SYS_MONITOR_BASE 0x00000000
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -246,46 +156,6 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - - GENERATED_GBL_DATA_SIZE) - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_BOARD_EARLY_INIT_F - /* I2C */ #include <asm/arch/gpio.h>
@@ -318,11 +188,6 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -362,10 +227,7 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board.c file is reused for all functions common for Exynos4 boards. Board specific files are implemented in the board files. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
Changes for v3: - moved max77686 init function to smdk5250 board file - board DTS files moved to arch/arm/dts - rebased on the latest tree
Changes for v2: - removed incorrectly implemented check for invalid peripheral id - removed unnecesary white space - removed panel specific init function 's6e8ax0_init' to the board file - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed - new patch to move checkboard to common file - reuse existing common board.c file - new patch that removes unused max77686_init function - fixed mmc2 addres in DT on Trats2
Piotr Wilczek (12): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT board:samsung: move checkboard to common file arm:exynos: add common DTS file for exynos 4 board:samsung:common: move max77686 init function arm:exynos: enable sdhci and misc_init to common board board:origen: Enable device tree on Origen board:universal: Enable device tree on Universal board:trats: Enable device tree on Trats board:trats2: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 17 ++ arch/arm/dts/Makefile | 5 + arch/arm/dts/exynos4.dtsi | 139 +++++++++ arch/arm/dts/exynos4210-origen.dts | 45 +++ arch/arm/dts/exynos4210-trats.dts | 120 ++++++++ arch/arm/dts/exynos4210-universal_c210.dts | 83 +++++ arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 + arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/board.c | 180 ++++------- board/samsung/origen/origen.c | 112 +------ board/samsung/smdk5250/exynos5-dt.c | 15 - board/samsung/smdk5250/smdk5250.c | 125 ++++++++ board/samsung/smdk5420/smdk5420.c | 15 - board/samsung/trats/trats.c | 213 +------------ board/samsung/trats2/trats2.c | 233 +------------- board/samsung/universal_c210/universal.c | 204 ++++--------- drivers/mmc/s5p_sdhci.c | 129 ++++++++ drivers/video/exynos_fb.c | 21 ++ drivers/video/exynos_mipi_dsi.c | 96 ++++++ include/configs/exynos4-dt.h | 144 +++++++++ include/configs/origen.h | 117 +++----- include/configs/s5pc210_universal.h | 145 +++------ include/configs/trats.h | 192 +++--------- include/configs/trats2.h | 198 ++---------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 29 files changed, 1683 insertions(+), 1332 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 arch/arm/dts/exynos4210-origen.dts create mode 100644 arch/arm/dts/exynos4210-trats.dts create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts create mode 100644 arch/arm/dts/exynos4412-trats2.dts create mode 100644 include/configs/exynos4-dt.h
This patch adds api to decode peripheral id based on interrupt number.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - none
arch/arm/cpu/armv7/exynos/pinmux.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 645c497..8d6e5c1 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -741,6 +741,21 @@ int exynos_pinmux_config(int peripheral, int flags) }
#ifdef CONFIG_OF_CONTROL +static int exynos4_pinmux_decode_periph_id(const void *blob, int node) +{ + int err; + u32 cell[3]; + + err = fdtdec_get_int_array(blob, node, "interrupts", cell, + ARRAY_SIZE(cell)); + if (err) { + debug(" invalid peripheral id\n"); + return PERIPH_ID_NONE; + } + + return cell[1]; +} + static int exynos5_pinmux_decode_periph_id(const void *blob, int node) { int err; @@ -758,6 +773,8 @@ int pinmux_decode_periph_id(const void *blob, int node) { if (cpu_is_exynos5()) return exynos5_pinmux_decode_periph_id(blob, node); + else if (cpu_is_exynos4()) + return exynos4_pinmux_decode_periph_id(blob, node); else return PERIPH_ID_NONE; }
This patch enables parsing mipi data from device tree. Non device tree case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - none
Changes for v2: - removed panel specific init function 's6e8ax0_init' to the board file
arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 ++ drivers/video/exynos_mipi_dsi.c | 96 ++++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 4 files changed, 103 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mipi_dsim.h b/arch/arm/include/asm/arch-exynos/mipi_dsim.h index 40aca71..50e5c25 100644 --- a/arch/arm/include/asm/arch-exynos/mipi_dsim.h +++ b/arch/arm/include/asm/arch-exynos/mipi_dsim.h @@ -12,6 +12,7 @@
#include <linux/list.h> #include <linux/fb.h> +#include <lcd.h>
#define PANEL_NAME_SIZE (32)
@@ -368,8 +369,12 @@ int exynos_mipi_dsi_register_lcd_device(struct mipi_dsim_lcd_device *lcd_dev);
void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd); +void exynos_init_dsim_platform_data(vidinfo_t *vid);
/* panel driver init based on mipi dsi interface */ void s6e8ax0_init(void);
+#ifdef CONFIG_OF_CONTROL +extern int mipi_power(void); +#endif #endif /* _DSIM_H */ diff --git a/drivers/video/exynos_mipi_dsi.c b/drivers/video/exynos_mipi_dsi.c index 8bb8fea..6c10f11 100644 --- a/drivers/video/exynos_mipi_dsi.c +++ b/drivers/video/exynos_mipi_dsi.c @@ -9,6 +9,8 @@
#include <common.h> #include <malloc.h> +#include <fdtdec.h> +#include <libfdt.h> #include <linux/err.h> #include <asm/arch/dsim.h> #include <asm/arch/mipi_dsim.h> @@ -22,7 +24,14 @@ #define master_to_driver(a) (a->dsim_lcd_drv) #define master_to_device(a) (a->dsim_lcd_dev)
+DECLARE_GLOBAL_DATA_PTR; + static struct exynos_platform_mipi_dsim *dsim_pd; +#ifdef CONFIG_OF_CONTROL +static struct mipi_dsim_config dsim_config_dt; +static struct exynos_platform_mipi_dsim dsim_platform_data_dt; +static struct mipi_dsim_lcd_device mipi_lcd_device_dt; +#endif
struct mipi_dsim_ddi { int bus_id; @@ -238,3 +247,90 @@ void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd)
dsim_pd = pd; } + +#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI); + if (node <= 0) { + printf("exynos_mipi_dsi: Can't get device node for mipi dsi\n"); + return -ENODEV; + } + + dsim_config_dt.e_interface = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_interface", 0); + + dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_virtual_ch", 0); + + dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_pixel_format", 0); + + dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_burst_mode", 0); + + dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_no_data_lane", 0); + + dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-e_byte_clk", 0); + + dsim_config_dt.hfp = fdtdec_get_int(blob, node, + "samsung,dsim-config-hfp", 0); + + dsim_config_dt.p = fdtdec_get_int(blob, node, + "samsung,dsim-config-p", 0); + dsim_config_dt.m = fdtdec_get_int(blob, node, + "samsung,dsim-config-m", 0); + dsim_config_dt.s = fdtdec_get_int(blob, node, + "samsung,dsim-config-s", 0); + + dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node, + "samsung,dsim-config-pll_stable_time", 0); + + dsim_config_dt.esc_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-esc_clk", 0); + + dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node, + "samsung,dsim-config-stop_holding_cnt", 0); + + dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-bta_timeout", 0); + + dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-rx_timeout", 0); + + mipi_lcd_device_dt.name = fdtdec_get_config_string(blob, + "samsung,dsim-device-name"); + + mipi_lcd_device_dt.id = fdtdec_get_int(blob, node, + "samsung,dsim-device-id", 0); + + mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node, + "samsung,dsim-device-bus_id", 0); + + mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node, + "samsung,dsim-device-reverse_panel", 0); + + return 0; +} + +void exynos_init_dsim_platform_data(vidinfo_t *vid) +{ + if (exynos_dsim_config_parse_dt(gd->fdt_blob)) + debug("Can't get proper dsim config.\n"); + + strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name); + dsim_platform_data_dt.dsim_config = &dsim_config_dt; + dsim_platform_data_dt.mipi_power = mipi_power; + dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl; + dsim_platform_data_dt.lcd_panel_info = (void *)vid; + + mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt; + exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt); + + dsim_pd = &dsim_platform_data_dt; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 19bab79..bd84c83 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -79,6 +79,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ + COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 1fecab3..c97fad3 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -52,6 +52,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), + COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
Piotr,
DT bindings should usually be free of "_" (underscore) Please use hyphen: "-" On Tue, Feb 25, 2014 at 11:33 PM, Piotr Wilczek p.wilczek@samsung.comwrote:
Changes for v3:
- none
Changes for v2:
dsim_pd = pd;
int node;
if (node <= 0) {
dsi\n");
return -ENODEV;
-- 1.8.3.2
Regards, Ajay Kumar
Hi Ajay,
On 02/27/2014 03:59 PM, Ajay kumar wrote:
Piotr,
I will use hypen.
Changes for v3:
- none
Changes for v2:
- static struct exynos_platform_mipi_dsim *dsim_pd;
dsim_pd = pd;
int node;
if (node <= 0) {
dsi\n");
return -ENODEV;
-- 1.8.3.2
Regards, Ajay Kumar
Best regards, Piotr Wilczek
This patch adds additional data parsing from DTB and adds the new exynos_lcd_panel_init() function for panel specific initialisation from the board file.
Changes for v2: - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file
drivers/video/exynos_fb.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index 00a0a11..88d9037 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -104,6 +104,13 @@ void __exynos_backlight_reset(void) void exynos_backlight_reset(void) __attribute__((weak, alias("__exynos_backlight_reset")));
+int __exynos_lcd_panel_init(vidinfo_t *vid) +{ + return 0; +} +int exynos_lcd_panel_init(vidinfo_t *vid) + __attribute__((weak, alias("__exynos_lcd_panel_init"))); + static void lcd_panel_on(vidinfo_t *vid) { udelay(vid->init_delay); @@ -269,6 +276,15 @@ int exynos_fimd_parse_dt(const void *blob) panel_info.dual_lcd_enabled = fdtdec_get_int(blob, node, "samsung,dual-lcd-enabled", 0);
+ panel_info.resolution = fdtdec_get_int(blob, node, + "samsung,resolution", 0); + + panel_info.rgb_mode = fdtdec_get_int(blob, node, + "samsung,rgb-mode", 0); + + panel_info.power_on_delay = fdtdec_get_int(blob, node, + "samsung,power-on-delay", 0); + return 0; } #endif @@ -281,10 +297,15 @@ void lcd_ctrl_init(void *lcdbase) #ifdef CONFIG_OF_CONTROL if (exynos_fimd_parse_dt(gd->fdt_blob)) debug("Can't get proper panel info\n"); +#ifdef CONFIG_EXYNOS_MIPI_DSIM + exynos_init_dsim_platform_data(&panel_info); +#endif + exynos_lcd_panel_init(&panel_info); #else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endif + panel_width = panel_info.vl_width; panel_height = panel_info.vl_height;
Hi Piotr, Find my comments inline.
Changes for v3:
- none
Changes for v2:
This is redundant! We already have exynos_cfg_lcd_gpio, exynos_lcd_power_on and other similar functions to support "panel init". Please check board/samsung/smdk5250.c
0);
All the above DT properties are already present in the same file! This are definitely duplicate entries. For passing resolution, please use "samsung,vl-col" and "samsung,vl-row"
This is already present as part of lcd_enable in same file! Please check it.
-- 1.8.3.2
Regards, Ajay Kumar
Piotr,
Adding more comments.
Changes for v3:
- none
Changes for v2:
0);
Ok. I just heard from MIPI-DSI engineer that MIPI-DSI should usually be initialized before FIMD video output starts.
Is that the reason why you are trying to do panel_init here? That seems ok, but definitely you should not be using a new function for that.
Use something like below snippet: ==================== /* exynos_fb.c */ . lcd_ctrl_init() {. . . if(CONFIG_EXYNOS_MIPI...) call lcd_panel_on /* MIPI-DSI to be initialized before FIMD init */ . do exynos_lcd_init() /* FIMD init */ . } . . . . lcd_enable() { . . if(CONFIG_EXYNOS_DP...) call lcd_panel_on /* DP to be initialized after FIMD init */ . . }
#else
#endif
-- 1.8.3.2
Regards, Ajay Kumar
Regards, Ajay Kumar
Hi Ajay,
Thank you for review. Please see answers below.
On 02/27/2014 03:10 PM, Ajay kumar wrote:
Piotr,
Changes for v3:
- none
Changes for v2:
The 'init_panel_info' is used to init lcd panel from he board file. It is called when CONFIG_OF_CONTROL is not defined. When CONFIG_OF_CONTROL is defined then we init panel from DTB data in exynos_fimd_parse_dt function.
However, it may be necessary to do some additional initializations that are optional and board specific. That’s what 'exynos_lcd_panel_init' function is for.
smdk5250.c is compiled when CONFIG_OF_CONTROL is not defined. With CONFIG_OF_CONTROL enabled, the exynos5-dt.c is used but it does not implement 'init_panel_info' so I would get undefined reference to 'init_panel_info'. Tahts another reason that I introduced the above function.
0);
Right, rgb_mode and power_on_delay I was supposed to remove in the previous version but overlooked that, thanks.
Previously HD_RESOLUTION was assigned to panel_info.resolution. It is defined as 0 in libtizen.h.
exynos_lcd_panel_init function is supposed to do only additional (to exynos_fimd_parse_dt) initializations like ex: get_tizen_logo_info.
#else
#endif
-- 1.8.3.2
Regards, Ajay Kumar
Regards, Ajay Kumar
This patch enables support for device tree for sdhci driver. Non DT case is still supported.
Changes for v2: - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed
arch/arm/include/asm/arch-exynos/mmc.h | 7 ++ drivers/mmc/s5p_sdhci.c | 129 +++++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + include/sdhci.h | 5 ++ lib/fdtdec.c | 1 + 5 files changed, 143 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 98d6530..0fb6461 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -53,6 +53,8 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
+#define SDHCI_MAX_HOSTS 4 + int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline int s5p_mmc_init(int index, int bus_width) @@ -62,4 +64,9 @@ static inline int s5p_mmc_init(int index, int bus_width)
return s5p_sdhci_init(base, index, bus_width); } + +#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); +#endif + #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 40ff873..ccae4cc 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -8,8 +8,15 @@ #include <common.h> #include <malloc.h> #include <sdhci.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/clk.h> +#include <errno.h> +#ifdef CONFIG_OF_CONTROL +#include <asm/arch/pinmux.h> +#endif
static char *S5P_NAME = "SAMSUNG SDHCI"; static void s5p_sdhci_set_control_reg(struct sdhci_host *host) @@ -86,3 +93,125 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
return add_sdhci(host, 52000000, 400000); } + +#ifdef CONFIG_OF_CONTROL +struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; + +static int do_sdhci_init(struct sdhci_host *host) +{ + int dev_id, flag; + int err = 0; + + flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + dev_id = host->index + PERIPH_ID_SDMMC0; + + if (fdt_gpio_isvalid(&host->pwr_gpio)) { + gpio_direction_output(host->pwr_gpio.gpio, 1); + err = exynos_pinmux_config(dev_id, flag); + if (err) { + debug("MMC not configured\n"); + return err; + } + } + + if (fdt_gpio_isvalid(&host->cd_gpio)) { + gpio_direction_output(host->cd_gpio.gpio, 0xf); + if (gpio_get_value(host->cd_gpio.gpio)) + return -ENODEV; + + err = exynos_pinmux_config(dev_id, flag); + if (err) { + printf("external SD not configured\n"); + return err; + } + } + + host->name = S5P_NAME; + + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + host->set_clock = set_mmc_clk; + + host->host_caps = MMC_MODE_HC; + + return add_sdhci(host, 52000000, 400000); +} + +static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) +{ + int bus_width, dev_id; + unsigned int base; + + /* Get device id */ + dev_id = pinmux_decode_periph_id(blob, node); + if (dev_id < PERIPH_ID_SDMMC0 && dev_id > PERIPH_ID_SDMMC3) { + debug("MMC: Can't get device id\n"); + return -1; + } + host->index = dev_id - PERIPH_ID_SDMMC0; + + /* Get bus width */ + bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (bus_width <= 0) { + debug("MMC: Can't get bus-width\n"); + return -1; + } + host->bus_width = bus_width; + + /* Get the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("MMC: Can't get base address\n"); + return -1; + } + host->ioaddr = (void *)base; + + fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio); + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + + return 0; +} + +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct sdhci_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build sdhci_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &sdhci_host[i]; + + if (sdhci_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_sdhci_init(host); + } + return 0; +} + +int exynos_mmc_init(const void *blob) +{ + int count; + int node_list[SDHCI_MAX_HOSTS]; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + COMPAT_SAMSUNG_EXYNOS_MMC, node_list, + SDHCI_MAX_HOSTS); + + process_nodes(blob, node_list, count); + + return 1; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index bd84c83..63027bd 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -82,6 +82,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/include/sdhci.h b/include/sdhci.h index 74d06ae..32e04f5 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -12,6 +12,7 @@
#include <asm/io.h> #include <mmc.h> +#include <fdtdec.h>
/* * Controller registers @@ -244,6 +245,10 @@ struct sdhci_host { const struct sdhci_ops *ops; int index;
+ int bus_width; + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state cd_gpio; /* Card Detect GPIO */ + void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index c97fad3..be04598 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -55,6 +55,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
The checkboard function's implementation is common for all DT supporting boards and should be placed in the board common file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Amar amarendra.xt@samsung.com
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes for v3: - none
Changes for v2: - new patch
board/samsung/common/board.c | 12 ++++++++++++ board/samsung/smdk5250/exynos5-dt.c | 15 --------------- board/samsung/smdk5420/smdk5420.c | 15 --------------- 3 files changed, 12 insertions(+), 30 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cd873bc..f8562b2 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -377,7 +377,19 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + printf("Board: %s\n", board_name ? board_name : "unknown"); + + return 0; +} #endif +#endif /* CONFIG_OF_CONTROL */
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 5fb8664..b22fba5 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -45,21 +45,6 @@ int exynos_init(void) return 0; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 3ad2ad0..e4606ec 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -142,18 +142,3 @@ int board_get_revision(void) { return 0; } - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif
This patch adds common dtsi file and config header for all Exynos 4 based boards.
Patch additionaly adds board specific (weak) functions for board_early_init_f and board_power_init functions.
Changes for v2: - reuse existing common board.c file
arch/arm/dts/exynos4.dtsi | 139 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 +++ board/samsung/common/board.c | 18 +++- include/configs/exynos4-dt.h | 144 +++++++++++++++++++++++++++++++ 4 files changed, 311 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 include/configs/exynos4-dt.h
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi new file mode 100644 index 0000000..38a6919 --- /dev/null +++ b/arch/arm/dts/exynos4.dtsi @@ -0,0 +1,139 @@ +/* + * Samsung's Exynos4 SoC common device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + + serial@13800000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13800000 0x3c>; + id = <0>; + }; + + serial@13810000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13810000 0x3c>; + id = <1>; + }; + + serial@13820000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13820000 0x3c>; + id = <2>; + }; + + serial@13830000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13830000 0x3c>; + id = <3>; + }; + + serial@13840000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13840000 0x3c>; + id = <4>; + }; + + i2c@13860000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <0 0 0>; + }; + + i2c@13870000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <1 1 0>; + }; + + i2c@13880000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <2 2 0>; + }; + + i2c@13890000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <3 3 0>; + }; + + i2c@138a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <4 4 0>; + }; + + i2c@138b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <5 5 0>; + }; + + i2c@138c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <6 6 0>; + }; + + i2c@138d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <7 7 0>; + }; + + sdhci@12510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12510000 0x1000>; + interrupts = <0 75 0>; + }; + + sdhci@12520000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12520000 0x1000>; + interrupts = <0 76 0>; + }; + + sdhci@12530000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12530000 0x1000>; + interrupts = <0 77 0>; + }; + + sdhci@12540000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12540000 0x1000>; + interrupts = <0 78 0>; + }; + + gpio: gpio { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; +}; diff --git a/arch/arm/include/asm/arch-exynos/board.h b/arch/arm/include/asm/arch-exynos/board.h index 243fb12..1b1cd0d 100644 --- a/arch/arm/include/asm/arch-exynos/board.h +++ b/arch/arm/include/asm/arch-exynos/board.h @@ -14,4 +14,16 @@ */ int exynos_init(void);
+/* + * Exynos board specific changes for + * board_early_init_f + */ +int exynos_early_init_f(void); + +/* + * Exynos board specific changes for + * board_power_init + */ +int exynos_power_init(void); + #endif /* EXYNOS_BOARD_H */ diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index f8562b2..cf78d36 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -33,6 +33,20 @@ struct local_info {
static struct local_info local;
+int __exynos_early_init_f(void) +{ + return 0; +} +int exynos_early_init_f(void) + __attribute__((weak, alias("__exynos_early_init_f"))); + +int __exynos_power_init(void) +{ + return 0; +} +int exynos_power_init(void) + __attribute__((weak, alias("__exynos_power_init"))); + #if defined CONFIG_EXYNOS_TMU /* Boot Time Thermal Analysis for SoC temperature threshold breach */ static void boot_temp_check(void) @@ -140,7 +154,7 @@ int board_early_init_f(void) board_i2c_init(gd->fdt_blob); #endif
- return err; + return exynos_early_init_f(); } #endif
@@ -284,7 +298,7 @@ int power_init_board(void) ret = max77686_init(); #endif
- return ret; + return exynos_power_init(); } #endif
diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h new file mode 100644 index 0000000..9b6669d --- /dev/null +++ b/include/configs/exynos4-dt.h @@ -0,0 +1,144 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS4 /* which is in a Exynos4 Family */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON + +/* Enable fdt support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* input clock of PLL: EXYNOS4 boards have 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#include <asm/sizes.h> + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_SDHCI +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_MMC_DEFAULT_DEV 0 + +/* PWM */ +#define CONFIG_PWM + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_ONENAND +#undef CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MMC +#define CONFIG_CMD_DFU +#define CONFIG_CMD_GPT +#define CONFIG_CMD_PMIC +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* FAT */ +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* EXT4 */ +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE + +/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET + +/* TIZEN THOR downloader support */ +#define CONFIG_CMD_THOR_DOWNLOAD +#define CONFIG_THOR_FUNCTION + +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK + +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_GADGET_MASS_STORAGE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +#endif /* __CONFIG_H */
This patch moves board specific max77686 init function from common board to smdk5250 board file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Rajeshwari Birje rajeshwari.birje@gmail.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - max77686 init function is moved to smdk5250 board file
board/samsung/common/board.c | 120 ------------------------------------ board/samsung/smdk5250/smdk5250.c | 125 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 125 insertions(+), 120 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cf78d36..a74b044 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,7 +22,6 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> -#include <power/max77686_pmic.h>
@@ -175,129 +174,10 @@ static int board_init_cros_ec_devices(const void *blob) #endif
#if defined(CONFIG_POWER) -#ifdef CONFIG_POWER_MAX77686 -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -static int max77686_init(void) -{ - struct pmic *p; - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - int power_init_board(void) { - int ret = 0; - set_ps_hold_ctrl();
-#ifdef CONFIG_POWER_MAX77686 - ret = max77686_init(); -#endif - return exynos_power_init(); } #endif diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index a69f73d..28a6d9e 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -147,6 +147,131 @@ void board_i2c_init(const void *blob) } }
+#if defined(CONFIG_POWER) +#ifdef CONFIG_POWER_MAX77686 +static int pmic_reg_update(struct pmic *p, int reg, uint regval) +{ + u32 val; + int ret = 0; + + ret = pmic_reg_read(p, reg, &val); + if (ret) { + debug("%s: PMIC %d register read failed\n", __func__, reg); + return -1; + } + val |= regval; + ret = pmic_reg_write(p, reg, val); + if (ret) { + debug("%s: PMIC %d register write failed\n", __func__, reg); + return -1; + } + return 0; +} + +static int max77686_init(void) +{ + struct pmic *p; + + if (pmic_init(I2C_PMIC)) + return -1; + + p = pmic_get("MAX77686_PMIC"); + if (!p) + return -ENODEV; + + if (pmic_probe(p)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, + MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) + return -1; + + /* VDD_MIF */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, + MAX77686_BUCK1OUT_1V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK1OUT); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, + MAX77686_BUCK1CTRL_EN)) + return -1; + + /* VDD_ARM */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, + MAX77686_BUCK2DVS1_1_3V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK2DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, + MAX77686_BUCK2CTRL_ON)) + return -1; + + /* VDD_INT */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, + MAX77686_BUCK3DVS1_1_0125V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK3DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_G3D */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, + MAX77686_BUCK4DVS1_1_2V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK4DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_LDO2 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, + MAX77686_LD02CTRL1_1_5V | EN_LDO)) + return -1; + + /* VDD_LDO3 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, + MAX77686_LD03CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO5 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, + MAX77686_LD05CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO10 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, + MAX77686_LD10CTRL1_1_8V | EN_LDO)) + return -1; + + return 0; +} +#endif /* CONFIG_POWER_MAX77686 */ + +int exynos_power_init(void) +{ + int ret = 0; + +#ifdef CONFIG_POWER_MAX77686 + ret = max77686_init(); +#endif + return ret; +} +#endif /* CONFIG_POWER */ + #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) {
This patch enables sdhci initialisation and misc_init_r in common board file for all exynos 4 based boards.
board/samsung/common/board.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index a74b044..e95e9c4 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,6 +22,8 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> +#include <lcd.h> +#include <samsung/misc.h>
@@ -183,6 +185,7 @@ int power_init_board(void) #endif
#ifdef CONFIG_OF_CONTROL +#ifdef CONFIG_SMC911X static int decode_sromc(const void *blob, struct fdt_sromc *config) { int err; @@ -206,6 +209,7 @@ static int decode_sromc(const void *blob, struct fdt_sromc *config) } return 0; } +#endif
int board_eth_init(bd_t *bis) { @@ -263,10 +267,18 @@ int board_mmc_init(bd_t *bis) { int ret;
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif +#ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); if (ret) debug("dwmmc init failed\n"); +#endif
return ret; } @@ -315,3 +327,21 @@ int arch_early_init_r(void)
return 0; } + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + set_board_info(); +#endif +#ifdef CONFIG_LCD_MENU + keys_init(); + check_boot_mode(); +#endif +#ifdef CONFIG_CMD_BMP + if (panel_info.logo_on) + draw_logo(); +#endif + return 0; +} +#endif
This patch enables to run Origen board on device tree.
Uart, DRAM and MMC init functions are removed as their generic replacements form the common board file are used.
The config file is modified to contain only board specific options.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - dts file moved to arch/arm/dts
Changes for v2: - no changes
arch/arm/dts/Makefile | 2 + arch/arm/dts/exynos4210-origen.dts | 45 ++++++++++++++ board/samsung/origen/origen.c | 112 +++-------------------------------- include/configs/origen.h | 117 +++++++++++++------------------------ 4 files changed, 96 insertions(+), 180 deletions(-) create mode 100644 arch/arm/dts/exynos4210-origen.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2658911..7abca75 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,3 +1,5 @@ +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb + dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts new file mode 100644 index 0000000..5c9d2ae --- /dev/null +++ b/arch/arm/dts/exynos4210-origen.dts @@ -0,0 +1,45 @@ +/* + * Samsung's Exynos4210 based Origen board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "skeleton.dtsi" +/include/ "exynos4.dtsi" + +/ { + model = "Insignal Origen evaluation board based on Exynos4210"; + compatible = "insignal,origen", "samsung,exynos4210"; + + chosen { + bootargs =""; + }; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + status = "disabled"; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 15f77ca..d502f02 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -11,129 +11,35 @@ #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> +#include <usb.h>
DECLARE_GLOBAL_DATA_PTR; -struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2;
-int board_init(void) +u32 get_board_rev(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; }
-static int board_uart_init(void) +int exynos_init(void) { - int err; - - err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); - if (err) { - debug("UART0 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); - if (err) { - debug("UART1 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); - if (err) { - debug("UART2 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); - if (err) { - debug("UART3 not configured\n"); - return err; - } - return 0; }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } - return err; -} -#endif - -int dram_init(void) +int board_usb_init(int index, enum usb_init_type init) { - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) - + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) - + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) - + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - return 0; }
-void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ - PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ - PHYS_SDRAM_2_SIZE); - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ - PHYS_SDRAM_3_SIZE); - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ - PHYS_SDRAM_4_SIZE); -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) { - printf("\nBoard: ORIGEN\n"); return 0; } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) +#ifdef CONFIG_BOARD_EARLY_INIT_F +int exynos_early_init_f(void) { - int i, err; - - /* - * MMC2 SD card GPIO: - * - * GPK2[0] SD_2_CLK(2) - * GPK2[1] SD_2_CMD(2) - * GPK2[2] SD_2_CDn - * GPK2[3:6] SD_2_DATA[0:3](2) - */ - for (i = 0; i < 7; i++) { - /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); - - /* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); - - /* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); - continue; - } - - /* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); - } - - err = s5p_mmc_init(2, 4); - return err; + return 0; } #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index f46b833..2c973cb 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -6,115 +6,79 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_ORIGEN_H +#define __CONFIG_ORIGEN_H + +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "ORIGEN # " + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-origen
/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* SAMSUNG core */ -#define CONFIG_S5P 1 /* S5P Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_DCACHE_OFF 1
+/* ORIGEN has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: ORIGEN has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_TEXT_BASE 0x43E00000
#define CONFIG_MACH_TYPE MACH_TYPE_ORIGEN
-/* Power Down Modes */ -#define S5P_CHECK_SLEEP 0x00000BAD -#define S5P_CHECK_DIDLE 0xBAD00000 -#define S5P_CHECK_LPA 0xABAD0000 - /* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200 -#define EXYNOS4_DEFAULT_UART_OFFSET 0x020000
-#define CONFIG_SKIP_LOWLEVEL_INIT +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE)
-/* PWM */ -#define CONFIG_PWM 1 +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-/* Command definition*/ -#include <config_cmd_default.h> +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000
#undef CONFIG_CMD_PING #define CONFIG_CMD_ELF #define CONFIG_CMD_DHCP -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
#define CONFIG_SPL_TEXT_BASE 0x02021410
+#undef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "ORIGEN # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -/* ORIGEN has 4 bank of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#define CONFIG_CLK_1000_400_200 @@ -122,17 +86,17 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 +#undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#undef CONFIG_ENV_OFFSET #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
+#undef CONFIG_SYS_INIT_SP_ADDR #define CONFIG_SYS_INIT_SP_ADDR 0x02040000
/* U-boot copy size from boot Media to DRAM.*/ @@ -140,7 +104,6 @@ #define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) #define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512)
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT +#undef CONFIG_CMD_I2C
Changes for v3:
Changes for v2:
- no changes
- Samsung's Exynos4210 based Origen board device tree source
- Copyright (c) 2014 Samsung Electronics Co., Ltd.
- model = "Insignal Origen evaluation board based on Exynos4210";
- compatible = "insignal,origen", "samsung,exynos4210";
- chosen {
bootargs ="";
- aliases {
- sdhci@12510000 {
- sdhci@12520000 {
- sdhci@12530000 {
- sdhci@12540000 {
- int err;
- if (err) {
return err;
- if (err) {
return err;
- if (err) {
return err;
- if (err) {
return err;
- int err;
- if (err) {
return err;
- return err;
-} -#endif
PHYS_SDRAM_1_SIZE);
PHYS_SDRAM_2_SIZE);
PHYS_SDRAM_3_SIZE);
PHYS_SDRAM_4_SIZE);
} #endif
- int i, err;
* GPK2[2] SD_2_CDn
continue;
- return err;
Sorry, I didn't catch it at v2 patch. It's better define each boards than undef.
ditto.
ditto.
ditto.
Thanks, Minkyu Kang.
This patch enables to run Universal board on device tree.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com --- Changes for v3: - dts file moved to arch/arm/dts
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-universal_c210.dts | 83 ++++++++++++ board/samsung/universal_c210/universal.c | 204 ++++++++--------------------- include/configs/s5pc210_universal.h | 145 ++++++-------------- 4 files changed, 178 insertions(+), 257 deletions(-) create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7abca75..d30954c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,4 +1,5 @@ -dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ + exynos4210-universal_c210.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts new file mode 100644 index 0000000..1cdd981 --- /dev/null +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -0,0 +1,83 @@ +/* + * Samsung's Exynos4210 based Universal C210 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Universal C210 based on Exynos4210 rev0"; + compatible = "samsung,universal_c210", "samsung,exynos4210"; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <480>; + samsung,vl-row = <800>; + samsung,vl-width = <480>; + samsung,vl-height = <800>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <2>; + samsung,vl-hbpd = <16>; + samsung,vl-hfpd = <16>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <8>; + samsung,vl-vfpd = <8>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,pclk_name = <1>; + samsung,sclk_div = <1>; + + samsung,winid = <0>; + samsung,power-on-delay = <10000>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <0>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; +}; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 96da7e0..82249d3 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -13,16 +13,17 @@ #include <asm/gpio.h> #include <asm/arch/adc.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> -#include <libtizen.h> #include <ld9040.h> #include <power/pmic.h> +#include <usb.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> #include <power/max8998_pmic.h> +#include <libtizen.h> #include <samsung/misc.h> +#include <usb_mass_storage.h>
@@ -42,7 +43,7 @@ static int get_hwrev(void)
static void init_pmic_lcd(void);
-int power_init_board(void) +int exynos_power_init(void) { int ret;
@@ -59,22 +60,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; -} - static unsigned short get_adc_value(int channel) { struct s5p_adc *adc = (struct s5p_adc *)samsung_get_base_adc(); @@ -159,71 +144,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tUniversal C210\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int err; - - switch (get_hwrev()) { - case 0: - /* - * Set the low to enable LDO_EN - * But when you use the test board for eMMC booting - * you should set it HIGH since it removes the inverter - */ - /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); - break; - default: - /* - * Default reset state is High and there's no inverter - * But set it as HIGH to ensure - */ - /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); - break; - } - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; - -} -#endif - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -271,7 +191,20 @@ struct s3c_plat_otg_data s5pc210_otg_data = { }; #endif
-int board_early_init_f(void) +int board_usb_init(int index, enum usb_init_type init) +{ + debug("USB_udc_probe\n"); + return s3c_udc_probe(&s5pc210_otg_data); +} + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + return 0; +} +#endif + +int exynos_early_init_f(void) { wdt_stop();
@@ -412,6 +345,11 @@ void exynos_cfg_lcd_gpio(void) spi_init(); }
+int mipi_power(void) +{ + return 0; +} + void exynos_reset_lcd(void) { s5p_gpio_set_value(&gpio2->y4, 5, 1); @@ -436,39 +374,6 @@ void exynos_lcd_power_on(void) pmic_set_output(p, MAX8998_REG_ONOFF2, MAX8998_LDO7, LDO_ON); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 480, - .vl_row = 800, - .vl_width = 480, - .vl_height = 800, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_HIGH, - .vl_vsp = CONFIG_SYS_HIGH, - .vl_dp = CONFIG_SYS_HIGH, - - .vl_bpix = 4, /* Bits per pixel */ - - /* LD9040 LCD Panel */ - .vl_hspw = 2, - .vl_hbpd = 16, - .vl_hfpd = 16, - - .vl_vspw = 2, - .vl_vbpd = 8, - .vl_vfpd = 8, - .vl_cmd_allow_len = 0xf, - - .win_id = 0, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 10000, - .reset_delay = 10000, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 0, -}; - void exynos_cfg_ldo(void) { ld9040_cfg_ldo(); @@ -479,30 +384,32 @@ void exynos_enable_ldo(unsigned int onoff) ld9040_enable_ldo(onoff); }
-void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - setenv("lcdinfo", "lcd=ld9040"); -} - -int board_init(void) +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + switch (get_hwrev()) { + case 0: + /* + * Set the low to enable LDO_EN + * But when you use the test board for eMMC booting + * you should set it HIGH since it removes the inverter + */ + /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + s5p_gpio_direction_output(&gpio1->e3, 6, 0); + break; + default: + /* + * Default reset state is High and there's no inverter + * But set it as HIGH to ensure + */ + /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + s5p_gpio_direction_output(&gpio1->e1, 3, 1); + break; + }
#ifdef CONFIG_SOFT_SPI soft_spi_init(); @@ -513,20 +420,15 @@ int board_init(void) return 0; }
-#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) +void exynos_lcd_panel_init(vidinfo_t *vid) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); -#endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); +#ifdef CONFIG_TIZEN + get_tizen_logo_info(vid); #endif - return 0; + + /* for LD9040. */ + vid->pclk_name = 1; /* MPLL */ + vid->sclk_div = 1; + + setenv("lcdinfo", "lcd=ld9040"); } -#endif diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 67921e9..a97d4c2 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -7,78 +7,56 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_UNIVERSAL_H +#define __CONFIG_UNIVERSAL_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_EXYNOS4210 1 /* which is in a EXYNOS4210 */ -#define CONFIG_UNIVERSAL 1 /* working with Universal */ -#define CONFIG_TIZEN 1 /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-universal_c210
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_TIZEN /* TIZEN lib */
/* Keep L2 Cache Disabled */ #define CONFIG_SYS_L2CACHE_OFF 1
+/* Universal has 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x44800000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE
-/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH 1 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_TEXT_BASE 0x44800000
#define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS @@ -106,10 +84,6 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" - #define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9" @@ -120,10 +94,6 @@
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -187,47 +157,10 @@ "mmcrootpart=3\0" \ "opts=always_resume=1"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Universal # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* Universal has 2 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION 1 - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_CACHELINE_SIZE 32 - #include <asm/arch/gpio.h> /* * I2C Settings @@ -307,8 +240,10 @@ int universal_spi_read(void); #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP #define CONFIG_LD9040 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
+#define LCD_XRES 480 +#define LCD_YRES 800 + #endif /* __CONFIG_H */
This patch enables to run Trats board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- Changes for v3: - dts file moved to arch/arm/dts
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-trats.dts | 120 +++++++++++++++++++++ board/samsung/trats/trats.c | 213 ++------------------------------------ include/configs/trats.h | 192 ++++++++-------------------------- 4 files changed, 174 insertions(+), 354 deletions(-) create mode 100644 arch/arm/dts/exynos4210-trats.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d30954c..20c081e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,5 +1,6 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ - exynos4210-universal_c210.dtb + exynos4210-universal_c210.dtb \ + exynos4210-trats.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts new file mode 100644 index 0000000..79fdad2 --- /dev/null +++ b/arch/arm/dts/exynos4210-trats.dts @@ -0,0 +1,120 @@ +/* + * Samsung's Exynos4210 based Trats board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats based on Exynos4210"; + compatible = "samsung,trats", "samsung,exynos4210"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index b725505..0f78ec0 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -12,23 +12,20 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> -#include <asm/arch/clk.h> #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> #include <power/pmic.h> #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> -#include <libtizen.h> #include <power/max8997_muic.h> #include <power/battery.h> #include <power/max17042_fg.h> +#include <libtizen.h> #include <usb.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
#include "setup.h"
@@ -46,10 +43,8 @@ u32 get_board_rev(void) static void check_hw_revision(void); struct s3c_plat_otg_data s5pc210_otg_data;
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
@@ -281,7 +276,7 @@ static int pmic_init_max8997(void) return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg, ret; struct power_battery *pb; @@ -350,28 +345,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - static unsigned int get_hw_revision(void) { struct exynos4_gpio_part1 *gpio = @@ -404,55 +377,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int err; - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; -} -#endif
#ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) @@ -599,38 +523,22 @@ static void board_power_init(void) writel(0, (unsigned int)&pwr->arm_core1_configuration); }
-static void board_uart_init(void) +static void exynos_uart_init(void) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); struct exynos4_gpio_part2 *gpio2 = (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int i; - - /* - * UART2 GPIOs - * GPA1CON[0] = UART_2_RXD(2) - * GPA1CON[1] = UART_2_TXD(2) - * GPA1CON[2] = I2C_3_SDA (3) - * GPA1CON[3] = I2C_3_SCL (3) - */ - - for (i = 0; i < 4; i++) { - s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC((i > 1) ? 0x3 : 0x2)); - }
/* UART_SEL GPY4[7] (part2) at EXYNOS4 */ s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); s5p_gpio_direction_output(&gpio2->y4, 7, 1); }
-int board_early_init_f(void) +int exynos_early_init_f(void) { wdt_stop(); pmic_reset(); board_clock_init(); - board_uart_init(); + exynos_uart_init(); board_power_init();
return 0; @@ -648,7 +556,7 @@ void exynos_reset_lcd(void) s5p_gpio_direction_output(&gpio2->y4, 5, 1); }
-static int lcd_power(void) +int lcd_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -671,46 +579,7 @@ static int lcd_power(void) return 0; }
-static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim s6e8ax0_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&s6e8ax0_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -733,75 +602,13 @@ static int mipi_power(void) return 0; }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 1, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1, - vid->resolution = HD_RESOLUTION, - vid->rgb_mode = MODE_RGB_P, - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - mipi_lcd_device.reverse_panel = 1; - - strcpy(s6e8ax0_platform_data.lcd_panel_name, mipi_lcd_device.name); - s6e8ax0_platform_data.lcd_power = lcd_power; - s6e8ax0_platform_data.mipi_power = mipi_power; - s6e8ax0_platform_data.phy_enable = set_mipi_phy_ctrl; - s6e8ax0_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - exynos_set_dsim_platform_data(&s6e8ax0_platform_data); - setenv("lcdinfo", "lcd=s6e8ax0"); -} - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif diff --git a/include/configs/trats.h b/include/configs/trats.h index 718107a..b19622a 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -7,25 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS_H +#define __CONFIG_TRATS_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_EXYNOS4210 /* which is in a EXYNOS4210 */ -#define CONFIG_TRATS /* working with TRATS */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#define CONFIG_TRATS
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-trats + +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -33,90 +27,46 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
+/* TRATS has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_TEXT_BASE 0x63300000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000)
-/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ -#define MACH_TYPE_TRATS 3928 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS +#define CONFIG_SYS_TEXT_BASE 0x63300000
-#include <asm/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200
-/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA - -/* PWM */ -#define CONFIG_PWM - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_ONENAND -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_SETEXPR - -/* FAT */ -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ +#define MACH_TYPE_TRATS 3928 +#define CONFIG_MACH_TYPE MACH_TYPE_TRATS + #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
@@ -151,8 +101,6 @@ "params.bin mmc 0x38 0x8\0"
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -226,59 +174,12 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
- -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TRATS # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* TRATS has 4 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE /* Falcon mode definitions */ #define CONFIG_CMD_SPL -#define CONFIG_SYS_SPL_ARGS_ADDR PHYS_SDRAM_1 + 0x100 - -/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS +#define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_CACHELINE_SIZE 32 +/* I2C */ +#include <asm/arch/gpio.h>
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 @@ -291,12 +192,11 @@ #define CONFIG_SOFT_I2C_READ_REPEATED_START #define CONFIG_SYS_I2C_INIT_BOARD
-#include <asm/arch/gpio.h> - /* I2C FG */ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0)
+/* POWER */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX8997 @@ -307,11 +207,6 @@ #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -351,10 +246,7 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
-#define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE - -/* Pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 +#define LCD_XRES 720 +#define LCD_YRES 1280
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - dts file moved to arch/arm/dts
Changes for v2: - fixed mmc2 address in DT
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++++++++++++ board/samsung/trats2/trats2.c | 233 +------------------- include/configs/trats2.h | 198 +++-------------- 4 files changed, 476 insertions(+), 392 deletions(-) create mode 100644 arch/arm/dts/exynos4412-trats2.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 20c081e..fa6f496 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,6 +1,7 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ exynos4210-universal_c210.dtb \ - exynos4210-trats.dtb + exynos4210-trats.dtb \ + exynos4412-trats2.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts new file mode 100644 index 0000000..d31e780 --- /dev/null +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -0,0 +1,434 @@ +/* + * Samsung's Exynos4412 based Trats2 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats2 based on Exynos4412"; + compatible = "samsung,trats2", "samsung,exynos4412"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + i2c@138d0000 { + samsung,i2c-sda-delay = <100>; + samsung,i2c-slave-addr = <0x10>; + samsung,i2c-max-bus-freq = <100000>; + status = "okay"; + + max77686_pmic@09 { + compatible = "maxim,max77686_pmic"; + interrupts = <7 0>; + reg = <0x09 0 0>; + #clock-cells = <1>; + + voltage-regulators { + ldo1_reg: ldo1 { + regulator-compatible = "LDO1"; + regulator-name = "VALIVE_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo2_reg: ldo2 { + regulator-compatible = "LDO2"; + regulator-name = "VM1M2_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo3_reg: ldo3 { + regulator-compatible = "LDO3"; + regulator-name = "VCC_1.8V_AP"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo4_reg: ldo4 { + regulator-compatible = "LDO4"; + regulator-name = "VCC_2.8V_AP"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo5_reg: ldo5 { + regulator-compatible = "LDO5"; + regulator-name = "VCC_1.8V_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo6_reg: ldo6 { + regulator-compatible = "LDO6"; + regulator-name = "VMPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo7_reg: ldo7 { + regulator-compatible = "LDO7"; + regulator-name = "VPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo8_reg: ldo8 { + regulator-compatible = "LDO8"; + regulator-name = "VMIPI_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo9_reg: ldo9 { + regulator-compatible = "LDO9"; + regulator-name = "CAM_ISP_MIPI_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo10_reg: ldo10 { + regulator-compatible = "LDO10"; + regulator-name = "VMIPI_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo11_reg: ldo11 { + regulator-compatible = "LDO11"; + regulator-name = "VABB1_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo12_reg: ldo12 { + regulator-compatible = "LDO12"; + regulator-name = "VUOTG_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-off; + }; + + ldo13_reg: ldo13 { + regulator-compatible = "LDO13"; + regulator-name = "NFC_AVDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo14_reg: ldo14 { + regulator-compatible = "LDO14"; + regulator-name = "VABB2_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo15_reg: ldo15 { + regulator-compatible = "LDO15"; + regulator-name = "VHSIC_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo16_reg: ldo16 { + regulator-compatible = "LDO16"; + regulator-name = "VHSIC_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo17_reg: ldo17 { + regulator-compatible = "LDO17"; + regulator-name = "CAM_SENSOR_CORE_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo18_reg: ldo18 { + regulator-compatible = "LDO18"; + regulator-name = "CAM_ISP_SEN_IO_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo19_reg: ldo19 { + regulator-compatible = "LDO19"; + regulator-name = "VT_CAM_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo20_reg: ldo20 { + regulator-compatible = "LDO20"; + regulator-name = "VDDQ_PRE_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo21_reg: ldo21 { + regulator-compatible = "LDO21"; + regulator-name = "VTF_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo22_reg: ldo22 { + regulator-compatible = "LDO22"; + regulator-name = "VMEM_VDD_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo23_reg: ldo23 { + regulator-compatible = "LDO23"; + regulator-name = "TSP_AVDD_3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-mem-idle; + }; + + ldo24_reg: ldo24 { + regulator-compatible = "LDO24"; + regulator-name = "TSP_VDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo25_reg: ldo25 { + regulator-compatible = "LDO25"; + regulator-name = "LCD_VCC_3.3V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo26_reg: ldo26 { + regulator-compatible = "LDO26"; + regulator-name = "MOTOR_VCC_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-idle; + }; + + buck1_reg: buck1 { + regulator-compatible = "BUCK1"; + regulator-name = "vdd_mif"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck2_reg: buck2 { + regulator-compatible = "BUCK2"; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck3_reg: buck3 { + regulator-compatible = "BUCK3"; + regulator-name = "vdd_int"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck4_reg: buck4 { + regulator-compatible = "BUCK4"; + regulator-name = "vdd_g3d"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-mem-off; + }; + + buck5_reg: buck5 { + regulator-compatible = "BUCK5"; + regulator-name = "VMEM_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + buck6_reg: buck6 { + regulator-compatible = "BUCK6"; + regulator-name = "VCC_SUB_1.35V"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + buck7_reg: buck7 { + regulator-compatible = "BUCK7"; + regulator-name = "VCC_SUB_2.0V"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + buck8_reg: buck8 { + regulator-compatible = "BUCK8"; + regulator-name = "VMEM_VDDF_3.0V"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-mem-off; + }; + + buck9_reg: buck9 { + regulator-compatible = "BUCK9"; + regulator-name = "CAM_ISP_CORE_1.2V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; + regulator-mem-off; + }; + }; + }; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e_interface = <1>; + samsung,dsim-config-e_virtual_ch = <0>; + samsung,dsim-config-e_pixel_format = <7>; + samsung,dsim-config-e_burst_mode = <1>; + samsung,dsim-config-e_no_data_lane = <3>; + samsung,dsim-config-e_byte_clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll_stable_time = <500>; + samsung,dsim-config-esc_clk = <20000000>; + samsung,dsim-config-stop_holding_cnt = <0x7ff>; + samsung,dsim-config-bta_timeout = <0xff>; + samsung,dsim-config-rx_timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus_id = <0>; + + samsung,dsim-device-reverse_panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2004002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20C6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index c17c24d..043bf6b 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,15 +8,9 @@
#include <common.h> #include <lcd.h> -#include <asm/io.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> -#include <asm/arch/power.h> -#include <asm/arch/clk.h> -#include <asm/arch/clock.h> -#include <asm/arch/mipi_dsim.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> +#include <asm/arch/mipi_dsim.h> #include <power/pmic.h> #include <power/max77686_pmic.h> #include <power/battery.h> @@ -28,7 +22,6 @@ #include <usb.h> #include <usb/s3c_udc.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
@@ -69,16 +62,6 @@ static void check_hw_revision(void) board_rev = modelrev << 8; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS2\n"); - printf("HW Revision:\t0x%04x\n", board_rev); - - return 0; -} -#endif - u32 get_board_rev(void) { return board_rev; @@ -156,33 +139,24 @@ int get_soft_i2c_sda_pin(void) } #endif
-int board_early_init_f(void) +int exynos_early_init_f(void) { - check_hw_revision(); board_external_gpio_init();
- gd->flags |= GD_FLG_DISABLE_CONSOLE; - return 0; }
static int pmic_init_max77686(void);
-int board_init(void) +int exynos_init(void) { - struct exynos4_power *pwr = - (struct exynos4_power *)samsung_get_base_power(); - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - /* workaround: clear INFORM4..5 */ - writel(0, (unsigned int)&pwr->inform4); - writel(0, (unsigned int)&pwr->inform5); + check_hw_revision(); + printf("HW Revision:\t0x%04x\n", board_rev);
return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg; struct power_battery *pb; @@ -248,90 +222,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - u32 size_mb; - - size_mb = (get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)) >> 20; - - gd->ram_size = size_mb << 20; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - -int board_mmc_init(bd_t *bis) -{ - int err0, err2 = 0; - - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio2->k0, 2, 1); - s5p_gpio_set_pull(&gpio2->k0, 2, GPIO_PULL_NONE); - - /* - * eMMC GPIO: - * SDR 8-bit@48MHz at MMC0 - * GPK0[0] SD_0_CLK(2) - * GPK0[1] SD_0_CMD(2) - * GPK0[2] SD_0_CDn -> Not used - * GPK0[3:6] SD_0_DATA[0:3](2) - * GPK1[3:6] SD_0_DATA[0:3](3) - * - * DDR 4-bit@26MHz at MMC4 - * GPK0[0] SD_4_CLK(3) - * GPK0[1] SD_4_CMD(3) - * GPK0[2] SD_4_CDn -> Not used - * GPK0[3:6] SD_4_DATA[0:3](3) - * GPK1[3:6] SD_4_DATA[4:7](4) - */ - - err0 = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - if (err0) - debug("SDMMC0 not configured\n"); - else - err0 = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err2) - debug("SDMMC2 not configured\n"); - else - err2 = s5p_mmc_init(2, 4); - } - - return err0 & err2; -} - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -479,46 +369,7 @@ static int pmic_init_max77686(void) */
#ifdef CONFIG_LCD -static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim dsim_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&dsim_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
@@ -556,77 +407,13 @@ void exynos_reset_lcd(void) s5p_gpio_set_value(&gpio1->f2, 1, 1); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - .mipi_enabled = 1, - - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 25, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - - vid->power_on_delay = 30; - - mipi_lcd_device.reverse_panel = 1; - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - - strcpy(dsim_platform_data.lcd_panel_name, mipi_lcd_device.name); - dsim_platform_data.mipi_power = mipi_power; - dsim_platform_data.phy_enable = set_mipi_phy_ctrl; - dsim_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - - exynos_set_dsim_platform_data(&dsim_platform_data); -} -#endif /* LCD */ - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif +#endif /* LCD */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index e30c428..3198580 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -8,27 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS2_H +#define __CONFIG_TRATS2_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_TIZEN /* TIZEN lib */ - -#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <configs/exynos4-dt.h>
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */
-#define CONFIG_SKIP_LOWLEVEL_INIT +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4412-trats2
-#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -36,121 +26,41 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
-#define CONFIG_NR_DRAM_BANKS 4 -#define PHYS_SDRAM_1 0x40000000 /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_3 0x60000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_3_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_4 0x70000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_4_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_END 0x80000000 - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ +/* TRATS2 has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) #define CONFIG_SYS_TEXT_BASE 0x78100000
-#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG - -/* MACH_TYPE_TRATS2 */ -#define MACH_TYPE_TRATS2 3765 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS2 - -#define CONFIG_DISPLAY_CPUINFO - -#include <asm/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ #define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMDLINE_EDITING +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ECHO -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NAND -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_SOURCE -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_PMIC - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -/* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ -#undef CONFIG_CMD_NET - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA -#define CONFIG_MMC_DEFAULT_DEV 0 - -/* PWM */ -#define CONFIG_PWM - -#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +#define CONFIG_SYS_MONITOR_BASE 0x00000000
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -246,46 +156,6 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - - GENERATED_GBL_DATA_SIZE) - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_BOARD_EARLY_INIT_F - /* I2C */ #include <asm/arch/gpio.h>
@@ -318,11 +188,6 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -362,10 +227,7 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board.c file is reused for all functions common for Exynos4 boards. Board specific files are implemented in the board files. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
This patch series depends on: [U-Boot] sizes.h - consolidate for all architectures http://patchwork.ozlabs.org/patch/324427/
Changes for v4: - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board - use "-" hypen in DT bindings - remove duplicated DT properties at exynos_fb.c file
Changes for v3: - moved max77686 init function to smdk5250 board file - board DTS files moved to arch/arm/dts - rebased on the latest tree
Changes for v2: - removed incorrectly implemented check for invalid peripheral id - removed unnecesary white space - removed panel specific init function 's6e8ax0_init' to the board file - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed - new patch to move checkboard to common file - reuse existing common board.c file - new patch that removes unused max77686_init function - fixed mmc2 addres in DT on Trats2
Piotr Wilczek (12): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT board:samsung: move checkboard to common file arm:exynos: add common DTS file for exynos 4 board:samsung:common: move max77686 init function arm:exynos: enable sdhci and misc_init to common board board:origen: Enable device tree on Origen board:universal: Enable device tree on Universal board:trats: Enable device tree on Trats board:trats2: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 17 ++ arch/arm/dts/Makefile | 5 + arch/arm/dts/exynos4.dtsi | 138 +++++++++ arch/arm/dts/exynos4210-origen.dts | 45 +++ arch/arm/dts/exynos4210-trats.dts | 120 ++++++++ arch/arm/dts/exynos4210-universal_c210.dts | 83 +++++ arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 + arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/board.c | 180 ++++------- board/samsung/origen/origen.c | 112 +------ board/samsung/smdk5250/exynos5-dt.c | 15 - board/samsung/smdk5250/smdk5250.c | 125 ++++++++ board/samsung/smdk5420/smdk5420.c | 15 - board/samsung/trats/trats.c | 213 +------------ board/samsung/trats2/trats2.c | 233 +------------- board/samsung/universal_c210/universal.c | 204 ++++--------- drivers/mmc/s5p_sdhci.c | 129 ++++++++ drivers/video/exynos_fb.c | 15 + drivers/video/exynos_mipi_dsi.c | 96 ++++++ include/configs/exynos4-dt.h | 138 +++++++++ include/configs/origen.h | 110 ++----- include/configs/s5pc210_universal.h | 152 +++------- include/configs/trats.h | 206 ++++--------- include/configs/trats2.h | 204 +++---------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 29 files changed, 1686 insertions(+), 1336 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 arch/arm/dts/exynos4210-origen.dts create mode 100644 arch/arm/dts/exynos4210-trats.dts create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts create mode 100644 arch/arm/dts/exynos4412-trats2.dts create mode 100644 include/configs/exynos4-dt.h
This patch adds api to decode peripheral id based on interrupt number.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - none
Changes for v3: - none
arch/arm/cpu/armv7/exynos/pinmux.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 645c497..8d6e5c1 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -741,6 +741,21 @@ int exynos_pinmux_config(int peripheral, int flags) }
#ifdef CONFIG_OF_CONTROL +static int exynos4_pinmux_decode_periph_id(const void *blob, int node) +{ + int err; + u32 cell[3]; + + err = fdtdec_get_int_array(blob, node, "interrupts", cell, + ARRAY_SIZE(cell)); + if (err) { + debug(" invalid peripheral id\n"); + return PERIPH_ID_NONE; + } + + return cell[1]; +} + static int exynos5_pinmux_decode_periph_id(const void *blob, int node) { int err; @@ -758,6 +773,8 @@ int pinmux_decode_periph_id(const void *blob, int node) { if (cpu_is_exynos5()) return exynos5_pinmux_decode_periph_id(blob, node); + else if (cpu_is_exynos4()) + return exynos4_pinmux_decode_periph_id(blob, node); else return PERIPH_ID_NONE; }
This patch enables parsing mipi data from device tree. Non device tree case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - use "-" hypen for DT bindings
Changes for v2: - removed panel specific init function 's6e8ax0_init' to the board file
arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 ++ drivers/video/exynos_mipi_dsi.c | 96 ++++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 4 files changed, 103 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mipi_dsim.h b/arch/arm/include/asm/arch-exynos/mipi_dsim.h index 40aca71..50e5c25 100644 --- a/arch/arm/include/asm/arch-exynos/mipi_dsim.h +++ b/arch/arm/include/asm/arch-exynos/mipi_dsim.h @@ -12,6 +12,7 @@
#include <linux/list.h> #include <linux/fb.h> +#include <lcd.h>
#define PANEL_NAME_SIZE (32)
@@ -368,8 +369,12 @@ int exynos_mipi_dsi_register_lcd_device(struct mipi_dsim_lcd_device *lcd_dev);
void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd); +void exynos_init_dsim_platform_data(vidinfo_t *vid);
/* panel driver init based on mipi dsi interface */ void s6e8ax0_init(void);
+#ifdef CONFIG_OF_CONTROL +extern int mipi_power(void); +#endif #endif /* _DSIM_H */ diff --git a/drivers/video/exynos_mipi_dsi.c b/drivers/video/exynos_mipi_dsi.c index 8bb8fea..7dd4652 100644 --- a/drivers/video/exynos_mipi_dsi.c +++ b/drivers/video/exynos_mipi_dsi.c @@ -9,6 +9,8 @@
#include <common.h> #include <malloc.h> +#include <fdtdec.h> +#include <libfdt.h> #include <linux/err.h> #include <asm/arch/dsim.h> #include <asm/arch/mipi_dsim.h> @@ -22,7 +24,14 @@ #define master_to_driver(a) (a->dsim_lcd_drv) #define master_to_device(a) (a->dsim_lcd_dev)
+DECLARE_GLOBAL_DATA_PTR; + static struct exynos_platform_mipi_dsim *dsim_pd; +#ifdef CONFIG_OF_CONTROL +static struct mipi_dsim_config dsim_config_dt; +static struct exynos_platform_mipi_dsim dsim_platform_data_dt; +static struct mipi_dsim_lcd_device mipi_lcd_device_dt; +#endif
struct mipi_dsim_ddi { int bus_id; @@ -238,3 +247,90 @@ void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd)
dsim_pd = pd; } + +#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI); + if (node <= 0) { + printf("exynos_mipi_dsi: Can't get device node for mipi dsi\n"); + return -ENODEV; + } + + dsim_config_dt.e_interface = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-interface", 0); + + dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-virtual-ch", 0); + + dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-pixel-format", 0); + + dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-burst-mode", 0); + + dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-no-data-lane", 0); + + dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-byte-clk", 0); + + dsim_config_dt.hfp = fdtdec_get_int(blob, node, + "samsung,dsim-config-hfp", 0); + + dsim_config_dt.p = fdtdec_get_int(blob, node, + "samsung,dsim-config-p", 0); + dsim_config_dt.m = fdtdec_get_int(blob, node, + "samsung,dsim-config-m", 0); + dsim_config_dt.s = fdtdec_get_int(blob, node, + "samsung,dsim-config-s", 0); + + dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node, + "samsung,dsim-config-pll-stable-time", 0); + + dsim_config_dt.esc_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-esc-clk", 0); + + dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node, + "samsung,dsim-config-stop-holding-cnt", 0); + + dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-bta-timeout", 0); + + dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-rx-timeout", 0); + + mipi_lcd_device_dt.name = fdtdec_get_config_string(blob, + "samsung,dsim-device-name"); + + mipi_lcd_device_dt.id = fdtdec_get_int(blob, node, + "samsung,dsim-device-id", 0); + + mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node, + "samsung,dsim-device-bus_id", 0); + + mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node, + "samsung,dsim-device-reverse-panel", 0); + + return 0; +} + +void exynos_init_dsim_platform_data(vidinfo_t *vid) +{ + if (exynos_dsim_config_parse_dt(gd->fdt_blob)) + debug("Can't get proper dsim config.\n"); + + strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name); + dsim_platform_data_dt.dsim_config = &dsim_config_dt; + dsim_platform_data_dt.mipi_power = mipi_power; + dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl; + dsim_platform_data_dt.lcd_panel_info = (void *)vid; + + mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt; + exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt); + + dsim_pd = &dsim_platform_data_dt; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 19bab79..bd84c83 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -79,6 +79,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ + COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 1fecab3..c97fad3 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -52,6 +52,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), + COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
Piotr,
You need to add the documentation for the bindings you create. Please add a exynos_mipi_dsi.txt file under the directory: doc/device-tree-bindings/video/
Regards, Ajay Kumar
Changes for v4:
Changes for v3:
- none
Changes for v2:
dsim_pd = pd;
int node;
if (node <= 0) {
dsi\n");
return -ENODEV;
-- 1.8.3.2
Hi Ajay,
On 03/05/2014 07:16 AM, Ajay kumar wrote:
Piotr,
Yes, I completely overlook that, thanks.
Best regards, Piotr Wilczek
Regards, Ajay Kumar
Changes for v4:
Changes for v3:
- none
Changes for v2:
- static struct exynos_platform_mipi_dsim *dsim_pd;
dsim_pd = pd;
int node;
if (node <= 0) {
dsi\n");
return -ENODEV;
-- 1.8.3.2
This patch adds additional data parsing from DTB and adds the new exynos_lcd_panel_init() function for panel specific initialisation from the board file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - remove duplicated DT properties at exynos_fb.c file
Changes for v2: - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file
drivers/video/exynos_fb.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index 00a0a11..77a3186 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -104,6 +104,13 @@ void __exynos_backlight_reset(void) void exynos_backlight_reset(void) __attribute__((weak, alias("__exynos_backlight_reset")));
+int __exynos_lcd_panel_init(vidinfo_t *vid) +{ + return 0; +} +int exynos_lcd_panel_init(vidinfo_t *vid) + __attribute__((weak, alias("__exynos_lcd_panel_init"))); + static void lcd_panel_on(vidinfo_t *vid) { udelay(vid->init_delay); @@ -269,6 +276,9 @@ int exynos_fimd_parse_dt(const void *blob) panel_info.dual_lcd_enabled = fdtdec_get_int(blob, node, "samsung,dual-lcd-enabled", 0);
+ panel_info.resolution = fdtdec_get_int(blob, node, + "samsung,resolution", 0); + return 0; } #endif @@ -281,10 +291,15 @@ void lcd_ctrl_init(void *lcdbase) #ifdef CONFIG_OF_CONTROL if (exynos_fimd_parse_dt(gd->fdt_blob)) debug("Can't get proper panel info\n"); +#ifdef CONFIG_EXYNOS_MIPI_DSIM + exynos_init_dsim_platform_data(&panel_info); +#endif + exynos_lcd_panel_init(&panel_info); #else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endif + panel_width = panel_info.vl_width; panel_height = panel_info.vl_height;
Piotr,
Sorry for late reply. Can you change the name of exynos_lcd_panel_init to exynos_lcd_misc_init. panel_init definitely gives a wrong meaning.
And, can you let me know where you are actually using "panel_info.resolution"? Is it needed for FIMD or is it needed by MIPI-DSI? If it is MIPI specific, then it should come as a DT entry from MIPI-DSI node.
Also, if you add a new DT entry, please update the following file: doc/device-tree-bindings/video/exynos-fb.txt
Regards, Ajay Kumar
Changes for v4:
Changes for v3:
- none
Changes for v2:
-- 1.8.3.2
Hi Ajay,
On 03/05/2014 07:06 AM, Ajay kumar wrote:
Piotr,
Yes, I can.
Well, it looks like it is not used any more. I will remove it completely.
Ok.
Regards, Ajay Kumar
Changes for v4:
Changes for v3:
- none
Changes for v2:
- static void lcd_panel_on(vidinfo_t *vid) { udelay(vid->init_delay);
} #endifreturn 0;
#else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endifexynos_lcd_panel_init(&panel_info);
-- 1.8.3.2
This patch enables support for device tree for sdhci driver. Non DT case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - none
Changes for v2: - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed
arch/arm/include/asm/arch-exynos/mmc.h | 7 ++ drivers/mmc/s5p_sdhci.c | 129 +++++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + include/sdhci.h | 5 ++ lib/fdtdec.c | 1 + 5 files changed, 143 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 98d6530..0fb6461 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -53,6 +53,8 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
+#define SDHCI_MAX_HOSTS 4 + int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline int s5p_mmc_init(int index, int bus_width) @@ -62,4 +64,9 @@ static inline int s5p_mmc_init(int index, int bus_width)
return s5p_sdhci_init(base, index, bus_width); } + +#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); +#endif + #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 40ff873..ccae4cc 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -8,8 +8,15 @@ #include <common.h> #include <malloc.h> #include <sdhci.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/clk.h> +#include <errno.h> +#ifdef CONFIG_OF_CONTROL +#include <asm/arch/pinmux.h> +#endif
static char *S5P_NAME = "SAMSUNG SDHCI"; static void s5p_sdhci_set_control_reg(struct sdhci_host *host) @@ -86,3 +93,125 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
return add_sdhci(host, 52000000, 400000); } + +#ifdef CONFIG_OF_CONTROL +struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; + +static int do_sdhci_init(struct sdhci_host *host) +{ + int dev_id, flag; + int err = 0; + + flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + dev_id = host->index + PERIPH_ID_SDMMC0; + + if (fdt_gpio_isvalid(&host->pwr_gpio)) { + gpio_direction_output(host->pwr_gpio.gpio, 1); + err = exynos_pinmux_config(dev_id, flag); + if (err) { + debug("MMC not configured\n"); + return err; + } + } + + if (fdt_gpio_isvalid(&host->cd_gpio)) { + gpio_direction_output(host->cd_gpio.gpio, 0xf); + if (gpio_get_value(host->cd_gpio.gpio)) + return -ENODEV; + + err = exynos_pinmux_config(dev_id, flag); + if (err) { + printf("external SD not configured\n"); + return err; + } + } + + host->name = S5P_NAME; + + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + host->set_clock = set_mmc_clk; + + host->host_caps = MMC_MODE_HC; + + return add_sdhci(host, 52000000, 400000); +} + +static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) +{ + int bus_width, dev_id; + unsigned int base; + + /* Get device id */ + dev_id = pinmux_decode_periph_id(blob, node); + if (dev_id < PERIPH_ID_SDMMC0 && dev_id > PERIPH_ID_SDMMC3) { + debug("MMC: Can't get device id\n"); + return -1; + } + host->index = dev_id - PERIPH_ID_SDMMC0; + + /* Get bus width */ + bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (bus_width <= 0) { + debug("MMC: Can't get bus-width\n"); + return -1; + } + host->bus_width = bus_width; + + /* Get the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("MMC: Can't get base address\n"); + return -1; + } + host->ioaddr = (void *)base; + + fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio); + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + + return 0; +} + +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct sdhci_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build sdhci_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &sdhci_host[i]; + + if (sdhci_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_sdhci_init(host); + } + return 0; +} + +int exynos_mmc_init(const void *blob) +{ + int count; + int node_list[SDHCI_MAX_HOSTS]; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + COMPAT_SAMSUNG_EXYNOS_MMC, node_list, + SDHCI_MAX_HOSTS); + + process_nodes(blob, node_list, count); + + return 1; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index bd84c83..63027bd 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -82,6 +82,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/include/sdhci.h b/include/sdhci.h index 74d06ae..32e04f5 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -12,6 +12,7 @@
#include <asm/io.h> #include <mmc.h> +#include <fdtdec.h>
/* * Controller registers @@ -244,6 +245,10 @@ struct sdhci_host { const struct sdhci_ops *ops; int index;
+ int bus_width; + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state cd_gpio; /* Card Detect GPIO */ + void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index c97fad3..be04598 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -55,6 +55,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
The checkboard function's implementation is common for all DT supporting boards and should be placed in the board common file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Amar amarendra.xt@samsung.com
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes for v4: - none
Changes for v2: - new patch
board/samsung/common/board.c | 12 ++++++++++++ board/samsung/smdk5250/exynos5-dt.c | 15 --------------- board/samsung/smdk5420/smdk5420.c | 15 --------------- 3 files changed, 12 insertions(+), 30 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cd873bc..f8562b2 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -377,7 +377,19 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + printf("Board: %s\n", board_name ? board_name : "unknown"); + + return 0; +} #endif +#endif /* CONFIG_OF_CONTROL */
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 5fb8664..b22fba5 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -45,21 +45,6 @@ int exynos_init(void) return 0; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 3ad2ad0..e4606ec 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -142,18 +142,3 @@ int board_get_revision(void) { return 0; } - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif
This patch adds common dtsi file and config header for all Exynos 4 based boards.
Patch additionaly adds board specific (weak) functions for board_early_init_f and board_power_init functions.
Changes for v2: - reuse existing common board.c file
arch/arm/dts/exynos4.dtsi | 138 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 +++ board/samsung/common/board.c | 18 +++- include/configs/exynos4-dt.h | 138 +++++++++++++++++++++++++++++++ 4 files changed, 304 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 include/configs/exynos4-dt.h
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi new file mode 100644 index 0000000..71dc7eb --- /dev/null +++ b/arch/arm/dts/exynos4.dtsi @@ -0,0 +1,138 @@ +/* + * Samsung's Exynos4 SoC common device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + serial@13800000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13800000 0x3c>; + id = <0>; + }; + + serial@13810000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13810000 0x3c>; + id = <1>; + }; + + serial@13820000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13820000 0x3c>; + id = <2>; + }; + + serial@13830000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13830000 0x3c>; + id = <3>; + }; + + serial@13840000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13840000 0x3c>; + id = <4>; + }; + + i2c@13860000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <0 0 0>; + }; + + i2c@13870000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <1 1 0>; + }; + + i2c@13880000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <2 2 0>; + }; + + i2c@13890000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <3 3 0>; + }; + + i2c@138a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <4 4 0>; + }; + + i2c@138b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <5 5 0>; + }; + + i2c@138c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <6 6 0>; + }; + + i2c@138d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <7 7 0>; + }; + + sdhci@12510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12510000 0x1000>; + interrupts = <0 75 0>; + }; + + sdhci@12520000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12520000 0x1000>; + interrupts = <0 76 0>; + }; + + sdhci@12530000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12530000 0x1000>; + interrupts = <0 77 0>; + }; + + sdhci@12540000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12540000 0x1000>; + interrupts = <0 78 0>; + }; + + gpio: gpio { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; +}; diff --git a/arch/arm/include/asm/arch-exynos/board.h b/arch/arm/include/asm/arch-exynos/board.h index 243fb12..1b1cd0d 100644 --- a/arch/arm/include/asm/arch-exynos/board.h +++ b/arch/arm/include/asm/arch-exynos/board.h @@ -14,4 +14,16 @@ */ int exynos_init(void);
+/* + * Exynos board specific changes for + * board_early_init_f + */ +int exynos_early_init_f(void); + +/* + * Exynos board specific changes for + * board_power_init + */ +int exynos_power_init(void); + #endif /* EXYNOS_BOARD_H */ diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index f8562b2..cf78d36 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -33,6 +33,20 @@ struct local_info {
static struct local_info local;
+int __exynos_early_init_f(void) +{ + return 0; +} +int exynos_early_init_f(void) + __attribute__((weak, alias("__exynos_early_init_f"))); + +int __exynos_power_init(void) +{ + return 0; +} +int exynos_power_init(void) + __attribute__((weak, alias("__exynos_power_init"))); + #if defined CONFIG_EXYNOS_TMU /* Boot Time Thermal Analysis for SoC temperature threshold breach */ static void boot_temp_check(void) @@ -140,7 +154,7 @@ int board_early_init_f(void) board_i2c_init(gd->fdt_blob); #endif
- return err; + return exynos_early_init_f(); } #endif
@@ -284,7 +298,7 @@ int power_init_board(void) ret = max77686_init(); #endif
- return ret; + return exynos_power_init(); } #endif
diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h new file mode 100644 index 0000000..2040bf7 --- /dev/null +++ b/include/configs/exynos4-dt.h @@ -0,0 +1,138 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS4 /* which is in a Exynos4 Family */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON + +/* Enable fdt support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* input clock of PLL: EXYNOS4 boards have 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#include <linux/sizes.h> + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_SDHCI +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_MMC_DEFAULT_DEV 0 + +/* PWM */ +#define CONFIG_PWM + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_ONENAND +#undef CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_MMC +#define CONFIG_CMD_DFU +#define CONFIG_CMD_GPT +#define CONFIG_CMD_PMIC +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* FAT */ +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* EXT4 */ +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE + +/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET + +/* TIZEN THOR downloader support */ +#define CONFIG_CMD_THOR_DOWNLOAD +#define CONFIG_THOR_FUNCTION + +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK + +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_GADGET_MASS_STORAGE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +#endif /* __CONFIG_H */
This patch moves board specific max77686 init function from common board to smdk5250 board file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Rajeshwari Birje rajeshwari.birje@gmail.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - none
Changes for v3: - max77686 init function is moved to smdk5250 board file
board/samsung/common/board.c | 120 ------------------------------------ board/samsung/smdk5250/smdk5250.c | 125 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 125 insertions(+), 120 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cf78d36..a74b044 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,7 +22,6 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> -#include <power/max77686_pmic.h>
@@ -175,129 +174,10 @@ static int board_init_cros_ec_devices(const void *blob) #endif
#if defined(CONFIG_POWER) -#ifdef CONFIG_POWER_MAX77686 -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -static int max77686_init(void) -{ - struct pmic *p; - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - int power_init_board(void) { - int ret = 0; - set_ps_hold_ctrl();
-#ifdef CONFIG_POWER_MAX77686 - ret = max77686_init(); -#endif - return exynos_power_init(); } #endif diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index a69f73d..28a6d9e 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -147,6 +147,131 @@ void board_i2c_init(const void *blob) } }
+#if defined(CONFIG_POWER) +#ifdef CONFIG_POWER_MAX77686 +static int pmic_reg_update(struct pmic *p, int reg, uint regval) +{ + u32 val; + int ret = 0; + + ret = pmic_reg_read(p, reg, &val); + if (ret) { + debug("%s: PMIC %d register read failed\n", __func__, reg); + return -1; + } + val |= regval; + ret = pmic_reg_write(p, reg, val); + if (ret) { + debug("%s: PMIC %d register write failed\n", __func__, reg); + return -1; + } + return 0; +} + +static int max77686_init(void) +{ + struct pmic *p; + + if (pmic_init(I2C_PMIC)) + return -1; + + p = pmic_get("MAX77686_PMIC"); + if (!p) + return -ENODEV; + + if (pmic_probe(p)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, + MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) + return -1; + + /* VDD_MIF */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, + MAX77686_BUCK1OUT_1V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK1OUT); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, + MAX77686_BUCK1CTRL_EN)) + return -1; + + /* VDD_ARM */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, + MAX77686_BUCK2DVS1_1_3V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK2DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, + MAX77686_BUCK2CTRL_ON)) + return -1; + + /* VDD_INT */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, + MAX77686_BUCK3DVS1_1_0125V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK3DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_G3D */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, + MAX77686_BUCK4DVS1_1_2V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK4DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_LDO2 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, + MAX77686_LD02CTRL1_1_5V | EN_LDO)) + return -1; + + /* VDD_LDO3 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, + MAX77686_LD03CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO5 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, + MAX77686_LD05CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO10 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, + MAX77686_LD10CTRL1_1_8V | EN_LDO)) + return -1; + + return 0; +} +#endif /* CONFIG_POWER_MAX77686 */ + +int exynos_power_init(void) +{ + int ret = 0; + +#ifdef CONFIG_POWER_MAX77686 + ret = max77686_init(); +#endif + return ret; +} +#endif /* CONFIG_POWER */ + #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) {
This patch enables sdhci initialisation and misc_init_r in common board file for all exynos 4 based boards.
board/samsung/common/board.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index a74b044..e95e9c4 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,6 +22,8 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> +#include <lcd.h> +#include <samsung/misc.h>
@@ -183,6 +185,7 @@ int power_init_board(void) #endif
#ifdef CONFIG_OF_CONTROL +#ifdef CONFIG_SMC911X static int decode_sromc(const void *blob, struct fdt_sromc *config) { int err; @@ -206,6 +209,7 @@ static int decode_sromc(const void *blob, struct fdt_sromc *config) } return 0; } +#endif
int board_eth_init(bd_t *bis) { @@ -263,10 +267,18 @@ int board_mmc_init(bd_t *bis) { int ret;
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif +#ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); if (ret) debug("dwmmc init failed\n"); +#endif
return ret; } @@ -315,3 +327,21 @@ int arch_early_init_r(void)
return 0; } + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + set_board_info(); +#endif +#ifdef CONFIG_LCD_MENU + keys_init(); + check_boot_mode(); +#endif +#ifdef CONFIG_CMD_BMP + if (panel_info.logo_on) + draw_logo(); +#endif + return 0; +} +#endif
This patch enables to run Origen board on device tree.
Uart, DRAM and MMC init functions are removed as their generic replacements form the common board file are used.
The config file is modified to contain only board specific options.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board
Changes for v3: - dts file moved to arch/arm/dts
Changes for v2: - no changes
arch/arm/dts/Makefile | 2 + arch/arm/dts/exynos4210-origen.dts | 45 +++++++++++++++ board/samsung/origen/origen.c | 112 +++---------------------------------- include/configs/origen.h | 110 ++++++++++-------------------------- 4 files changed, 87 insertions(+), 182 deletions(-) create mode 100644 arch/arm/dts/exynos4210-origen.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2658911..7abca75 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,3 +1,5 @@ +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb + dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts new file mode 100644 index 0000000..5c9d2ae --- /dev/null +++ b/arch/arm/dts/exynos4210-origen.dts @@ -0,0 +1,45 @@ +/* + * Samsung's Exynos4210 based Origen board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "skeleton.dtsi" +/include/ "exynos4.dtsi" + +/ { + model = "Insignal Origen evaluation board based on Exynos4210"; + compatible = "insignal,origen", "samsung,exynos4210"; + + chosen { + bootargs =""; + }; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + status = "disabled"; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 15f77ca..d502f02 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -11,129 +11,35 @@ #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> +#include <usb.h>
DECLARE_GLOBAL_DATA_PTR; -struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2;
-int board_init(void) +u32 get_board_rev(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; }
-static int board_uart_init(void) +int exynos_init(void) { - int err; - - err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); - if (err) { - debug("UART0 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); - if (err) { - debug("UART1 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); - if (err) { - debug("UART2 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); - if (err) { - debug("UART3 not configured\n"); - return err; - } - return 0; }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } - return err; -} -#endif - -int dram_init(void) +int board_usb_init(int index, enum usb_init_type init) { - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) - + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) - + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) - + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - return 0; }
-void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ - PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ - PHYS_SDRAM_2_SIZE); - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ - PHYS_SDRAM_3_SIZE); - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ - PHYS_SDRAM_4_SIZE); -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) { - printf("\nBoard: ORIGEN\n"); return 0; } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) +#ifdef CONFIG_BOARD_EARLY_INIT_F +int exynos_early_init_f(void) { - int i, err; - - /* - * MMC2 SD card GPIO: - * - * GPK2[0] SD_2_CLK(2) - * GPK2[1] SD_2_CMD(2) - * GPK2[2] SD_2_CDn - * GPK2[3:6] SD_2_DATA[0:3](2) - */ - for (i = 0; i < 7; i++) { - /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); - - /* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); - - /* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); - continue; - } - - /* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); - } - - err = s5p_mmc_init(2, 4); - return err; + return 0; } #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index f46b833..8258338 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -6,115 +6,71 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_ORIGEN_H +#define __CONFIG_ORIGEN_H + +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "ORIGEN # " + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-origen
/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* SAMSUNG core */ -#define CONFIG_S5P 1 /* S5P Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_DCACHE_OFF 1
+/* ORIGEN has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: ORIGEN has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_TEXT_BASE 0x43E00000
#define CONFIG_MACH_TYPE MACH_TYPE_ORIGEN
-/* Power Down Modes */ -#define S5P_CHECK_SLEEP 0x00000BAD -#define S5P_CHECK_DIDLE 0xBAD00000 -#define S5P_CHECK_LPA 0xABAD0000 - /* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200 -#define EXYNOS4_DEFAULT_UART_OFFSET 0x020000
-#define CONFIG_SKIP_LOWLEVEL_INIT +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* PWM */ -#define CONFIG_PWM 1 +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* Command definition*/ -#include <config_cmd_default.h> +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000
#undef CONFIG_CMD_PING #define CONFIG_CMD_ELF #define CONFIG_CMD_DHCP -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030 - #define CONFIG_SPL_TEXT_BASE 0x02021410
#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "ORIGEN # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -/* ORIGEN has 4 bank of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#define CONFIG_CLK_1000_400_200 @@ -122,13 +78,12 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024) @@ -140,7 +95,4 @@ #define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) #define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512)
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT - #endif /* __CONFIG_H */
This patch enables to run Universal board on device tree.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com --- Changes for v4: - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-universal_c210.dts | 83 ++++++++++++ board/samsung/universal_c210/universal.c | 204 ++++++++--------------------- include/configs/s5pc210_universal.h | 152 +++++++-------------- 4 files changed, 185 insertions(+), 257 deletions(-) create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7abca75..d30954c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,4 +1,5 @@ -dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ + exynos4210-universal_c210.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts new file mode 100644 index 0000000..1cdd981 --- /dev/null +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -0,0 +1,83 @@ +/* + * Samsung's Exynos4210 based Universal C210 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Universal C210 based on Exynos4210 rev0"; + compatible = "samsung,universal_c210", "samsung,exynos4210"; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <480>; + samsung,vl-row = <800>; + samsung,vl-width = <480>; + samsung,vl-height = <800>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <2>; + samsung,vl-hbpd = <16>; + samsung,vl-hfpd = <16>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <8>; + samsung,vl-vfpd = <8>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,pclk_name = <1>; + samsung,sclk_div = <1>; + + samsung,winid = <0>; + samsung,power-on-delay = <10000>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <0>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; +}; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 96da7e0..82249d3 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -13,16 +13,17 @@ #include <asm/gpio.h> #include <asm/arch/adc.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> -#include <libtizen.h> #include <ld9040.h> #include <power/pmic.h> +#include <usb.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> #include <power/max8998_pmic.h> +#include <libtizen.h> #include <samsung/misc.h> +#include <usb_mass_storage.h>
@@ -42,7 +43,7 @@ static int get_hwrev(void)
static void init_pmic_lcd(void);
-int power_init_board(void) +int exynos_power_init(void) { int ret;
@@ -59,22 +60,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; -} - static unsigned short get_adc_value(int channel) { struct s5p_adc *adc = (struct s5p_adc *)samsung_get_base_adc(); @@ -159,71 +144,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tUniversal C210\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int err; - - switch (get_hwrev()) { - case 0: - /* - * Set the low to enable LDO_EN - * But when you use the test board for eMMC booting - * you should set it HIGH since it removes the inverter - */ - /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); - break; - default: - /* - * Default reset state is High and there's no inverter - * But set it as HIGH to ensure - */ - /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); - break; - } - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; - -} -#endif - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -271,7 +191,20 @@ struct s3c_plat_otg_data s5pc210_otg_data = { }; #endif
-int board_early_init_f(void) +int board_usb_init(int index, enum usb_init_type init) +{ + debug("USB_udc_probe\n"); + return s3c_udc_probe(&s5pc210_otg_data); +} + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + return 0; +} +#endif + +int exynos_early_init_f(void) { wdt_stop();
@@ -412,6 +345,11 @@ void exynos_cfg_lcd_gpio(void) spi_init(); }
+int mipi_power(void) +{ + return 0; +} + void exynos_reset_lcd(void) { s5p_gpio_set_value(&gpio2->y4, 5, 1); @@ -436,39 +374,6 @@ void exynos_lcd_power_on(void) pmic_set_output(p, MAX8998_REG_ONOFF2, MAX8998_LDO7, LDO_ON); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 480, - .vl_row = 800, - .vl_width = 480, - .vl_height = 800, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_HIGH, - .vl_vsp = CONFIG_SYS_HIGH, - .vl_dp = CONFIG_SYS_HIGH, - - .vl_bpix = 4, /* Bits per pixel */ - - /* LD9040 LCD Panel */ - .vl_hspw = 2, - .vl_hbpd = 16, - .vl_hfpd = 16, - - .vl_vspw = 2, - .vl_vbpd = 8, - .vl_vfpd = 8, - .vl_cmd_allow_len = 0xf, - - .win_id = 0, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 10000, - .reset_delay = 10000, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 0, -}; - void exynos_cfg_ldo(void) { ld9040_cfg_ldo(); @@ -479,30 +384,32 @@ void exynos_enable_ldo(unsigned int onoff) ld9040_enable_ldo(onoff); }
-void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - setenv("lcdinfo", "lcd=ld9040"); -} - -int board_init(void) +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + switch (get_hwrev()) { + case 0: + /* + * Set the low to enable LDO_EN + * But when you use the test board for eMMC booting + * you should set it HIGH since it removes the inverter + */ + /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + s5p_gpio_direction_output(&gpio1->e3, 6, 0); + break; + default: + /* + * Default reset state is High and there's no inverter + * But set it as HIGH to ensure + */ + /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + s5p_gpio_direction_output(&gpio1->e1, 3, 1); + break; + }
#ifdef CONFIG_SOFT_SPI soft_spi_init(); @@ -513,20 +420,15 @@ int board_init(void) return 0; }
-#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) +void exynos_lcd_panel_init(vidinfo_t *vid) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); -#endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); +#ifdef CONFIG_TIZEN + get_tizen_logo_info(vid); #endif - return 0; + + /* for LD9040. */ + vid->pclk_name = 1; /* MPLL */ + vid->sclk_div = 1; + + setenv("lcdinfo", "lcd=ld9040"); } -#endif diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 67921e9..2da8871 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -7,78 +7,56 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_UNIVERSAL_H +#define __CONFIG_UNIVERSAL_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_EXYNOS4210 1 /* which is in a EXYNOS4210 */ -#define CONFIG_UNIVERSAL 1 /* working with Universal */ -#define CONFIG_TIZEN 1 /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-universal_c210
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_TIZEN /* TIZEN lib */
/* Keep L2 Cache Disabled */ #define CONFIG_SYS_L2CACHE_OFF 1
+/* Universal has 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x44800000 - -/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH 1 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_TEXT_BASE 0x44800000
#define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS @@ -106,24 +84,21 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" - #define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9"
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + #define CONFIG_ENV_UBIFS_OPTION " rootflags=bulk_read,no_chk_data_crc " #define CONFIG_ENV_FLASHBOOT CONFIG_ENV_UBI_MTD CONFIG_ENV_UBIFS_OPTION \ "${mtdparts}"
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -187,47 +162,10 @@ "mmcrootpart=3\0" \ "opts=always_resume=1"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Universal # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* Universal has 2 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION 1 - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_CACHELINE_SIZE 32 - #include <asm/arch/gpio.h> /* * I2C Settings @@ -235,6 +173,8 @@ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(1, b, 7) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(1, b, 6)
+#define CONFIG_CMD_I2C + #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ #define CONFIG_SYS_I2C_SOFT_SPEED 50000 @@ -307,8 +247,10 @@ int universal_spi_read(void); #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP #define CONFIG_LD9040 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
+#define LCD_XRES 480 +#define LCD_YRES 800 + #endif /* __CONFIG_H */
This patch enables to run Trats board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- Changes for v4: - use "-" hypen in DT bindings - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-trats.dts | 120 +++++++++++++++++++++ board/samsung/trats/trats.c | 213 ++------------------------------------ include/configs/trats.h | 206 ++++++++++-------------------------- 4 files changed, 185 insertions(+), 357 deletions(-) create mode 100644 arch/arm/dts/exynos4210-trats.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d30954c..20c081e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,5 +1,6 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ - exynos4210-universal_c210.dtb + exynos4210-universal_c210.dtb \ + exynos4210-trats.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts new file mode 100644 index 0000000..992e023 --- /dev/null +++ b/arch/arm/dts/exynos4210-trats.dts @@ -0,0 +1,120 @@ +/* + * Samsung's Exynos4210 based Trats board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats based on Exynos4210"; + compatible = "samsung,trats", "samsung,exynos4210"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e-interface = <1>; + samsung,dsim-config-e-virtual-ch = <0>; + samsung,dsim-config-e-pixel-format = <7>; + samsung,dsim-config-e-burst-mode = <1>; + samsung,dsim-config-e-no-data-lane = <3>; + samsung,dsim-config-e-byte-clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll-stable-time = <500>; + samsung,dsim-config-esc-clk = <20000000>; + samsung,dsim-config-stop-holding-cnt = <0x7ff>; + samsung,dsim-config-bta-timeout = <0xff>; + samsung,dsim-config-rx-timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus-id = <0>; + + samsung,dsim-device-reverse-panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index b725505..0f78ec0 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -12,23 +12,20 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> -#include <asm/arch/clk.h> #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> #include <power/pmic.h> #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> -#include <libtizen.h> #include <power/max8997_muic.h> #include <power/battery.h> #include <power/max17042_fg.h> +#include <libtizen.h> #include <usb.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
#include "setup.h"
@@ -46,10 +43,8 @@ u32 get_board_rev(void) static void check_hw_revision(void); struct s3c_plat_otg_data s5pc210_otg_data;
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
@@ -281,7 +276,7 @@ static int pmic_init_max8997(void) return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg, ret; struct power_battery *pb; @@ -350,28 +345,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - static unsigned int get_hw_revision(void) { struct exynos4_gpio_part1 *gpio = @@ -404,55 +377,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int err; - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; -} -#endif
#ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) @@ -599,38 +523,22 @@ static void board_power_init(void) writel(0, (unsigned int)&pwr->arm_core1_configuration); }
-static void board_uart_init(void) +static void exynos_uart_init(void) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); struct exynos4_gpio_part2 *gpio2 = (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int i; - - /* - * UART2 GPIOs - * GPA1CON[0] = UART_2_RXD(2) - * GPA1CON[1] = UART_2_TXD(2) - * GPA1CON[2] = I2C_3_SDA (3) - * GPA1CON[3] = I2C_3_SCL (3) - */ - - for (i = 0; i < 4; i++) { - s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC((i > 1) ? 0x3 : 0x2)); - }
/* UART_SEL GPY4[7] (part2) at EXYNOS4 */ s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); s5p_gpio_direction_output(&gpio2->y4, 7, 1); }
-int board_early_init_f(void) +int exynos_early_init_f(void) { wdt_stop(); pmic_reset(); board_clock_init(); - board_uart_init(); + exynos_uart_init(); board_power_init();
return 0; @@ -648,7 +556,7 @@ void exynos_reset_lcd(void) s5p_gpio_direction_output(&gpio2->y4, 5, 1); }
-static int lcd_power(void) +int lcd_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -671,46 +579,7 @@ static int lcd_power(void) return 0; }
-static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim s6e8ax0_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&s6e8ax0_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -733,75 +602,13 @@ static int mipi_power(void) return 0; }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 1, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1, - vid->resolution = HD_RESOLUTION, - vid->rgb_mode = MODE_RGB_P, - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - mipi_lcd_device.reverse_panel = 1; - - strcpy(s6e8ax0_platform_data.lcd_panel_name, mipi_lcd_device.name); - s6e8ax0_platform_data.lcd_power = lcd_power; - s6e8ax0_platform_data.mipi_power = mipi_power; - s6e8ax0_platform_data.phy_enable = set_mipi_phy_ctrl; - s6e8ax0_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - exynos_set_dsim_platform_data(&s6e8ax0_platform_data); - setenv("lcdinfo", "lcd=s6e8ax0"); -} - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif diff --git a/include/configs/trats.h b/include/configs/trats.h index 7cea259..15630fb 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -7,25 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS_H +#define __CONFIG_TRATS_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_EXYNOS4210 /* which is in a EXYNOS4210 */ -#define CONFIG_TRATS /* working with TRATS */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */ + +#define CONFIG_TRATS
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-trats
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -33,93 +27,60 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
+/* TRATS has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_TEXT_BASE 0x63300000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000)
-/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ -#define MACH_TYPE_TRATS 3928 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS +#define CONFIG_SYS_TEXT_BASE 0x63300000
#include <linux/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200
-/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA - -/* PWM */ -#define CONFIG_PWM - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_ONENAND -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_SETEXPR - -/* FAT */ -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ +#define MACH_TYPE_TRATS 3928 +#define CONFIG_MACH_TYPE MACH_TYPE_TRATS + #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOTLOADER "u-boot" @@ -150,13 +111,6 @@ ""PARTS_UMS" part 0 7;" \ "params.bin mmc 0x38 0x8\0"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - -#define CONFIG_ENV_VARS_UBOOT_CONFIG -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "bootk=" \ "run loaduimage;" \ @@ -226,59 +180,14 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
- -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TRATS # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* TRATS has 4 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE /* Falcon mode definitions */ #define CONFIG_CMD_SPL -#define CONFIG_SYS_SPL_ARGS_ADDR PHYS_SDRAM_1 + 0x100 +#define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
-/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS +/* I2C */ +#include <asm/arch/gpio.h>
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_CMD_I2C
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 @@ -291,12 +200,11 @@ #define CONFIG_SOFT_I2C_READ_REPEATED_START #define CONFIG_SYS_I2C_INIT_BOARD
-#include <asm/arch/gpio.h> - /* I2C FG */ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0)
+/* POWER */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX8997 @@ -307,11 +215,6 @@ #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -351,10 +254,7 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
-#define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE - -/* Pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 +#define LCD_XRES 720 +#define LCD_YRES 1280
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v4: - use "-" hypen in DT bindings - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board
Changes for v2: - fixed mmc2 address in DT
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++++++++++++ board/samsung/trats2/trats2.c | 233 +------------------- include/configs/trats2.h | 204 ++++------------- 4 files changed, 483 insertions(+), 391 deletions(-) create mode 100644 arch/arm/dts/exynos4412-trats2.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 20c081e..fa6f496 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,6 +1,7 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ exynos4210-universal_c210.dtb \ - exynos4210-trats.dtb + exynos4210-trats.dtb \ + exynos4412-trats2.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts new file mode 100644 index 0000000..7d32067 --- /dev/null +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -0,0 +1,434 @@ +/* + * Samsung's Exynos4412 based Trats2 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats2 based on Exynos4412"; + compatible = "samsung,trats2", "samsung,exynos4412"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + i2c@138d0000 { + samsung,i2c-sda-delay = <100>; + samsung,i2c-slave-addr = <0x10>; + samsung,i2c-max-bus-freq = <100000>; + status = "okay"; + + max77686_pmic@09 { + compatible = "maxim,max77686_pmic"; + interrupts = <7 0>; + reg = <0x09 0 0>; + #clock-cells = <1>; + + voltage-regulators { + ldo1_reg: ldo1 { + regulator-compatible = "LDO1"; + regulator-name = "VALIVE_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo2_reg: ldo2 { + regulator-compatible = "LDO2"; + regulator-name = "VM1M2_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo3_reg: ldo3 { + regulator-compatible = "LDO3"; + regulator-name = "VCC_1.8V_AP"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo4_reg: ldo4 { + regulator-compatible = "LDO4"; + regulator-name = "VCC_2.8V_AP"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo5_reg: ldo5 { + regulator-compatible = "LDO5"; + regulator-name = "VCC_1.8V_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo6_reg: ldo6 { + regulator-compatible = "LDO6"; + regulator-name = "VMPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo7_reg: ldo7 { + regulator-compatible = "LDO7"; + regulator-name = "VPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo8_reg: ldo8 { + regulator-compatible = "LDO8"; + regulator-name = "VMIPI_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo9_reg: ldo9 { + regulator-compatible = "LDO9"; + regulator-name = "CAM_ISP_MIPI_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo10_reg: ldo10 { + regulator-compatible = "LDO10"; + regulator-name = "VMIPI_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo11_reg: ldo11 { + regulator-compatible = "LDO11"; + regulator-name = "VABB1_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo12_reg: ldo12 { + regulator-compatible = "LDO12"; + regulator-name = "VUOTG_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-off; + }; + + ldo13_reg: ldo13 { + regulator-compatible = "LDO13"; + regulator-name = "NFC_AVDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo14_reg: ldo14 { + regulator-compatible = "LDO14"; + regulator-name = "VABB2_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo15_reg: ldo15 { + regulator-compatible = "LDO15"; + regulator-name = "VHSIC_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo16_reg: ldo16 { + regulator-compatible = "LDO16"; + regulator-name = "VHSIC_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo17_reg: ldo17 { + regulator-compatible = "LDO17"; + regulator-name = "CAM_SENSOR_CORE_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo18_reg: ldo18 { + regulator-compatible = "LDO18"; + regulator-name = "CAM_ISP_SEN_IO_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo19_reg: ldo19 { + regulator-compatible = "LDO19"; + regulator-name = "VT_CAM_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo20_reg: ldo20 { + regulator-compatible = "LDO20"; + regulator-name = "VDDQ_PRE_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo21_reg: ldo21 { + regulator-compatible = "LDO21"; + regulator-name = "VTF_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo22_reg: ldo22 { + regulator-compatible = "LDO22"; + regulator-name = "VMEM_VDD_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo23_reg: ldo23 { + regulator-compatible = "LDO23"; + regulator-name = "TSP_AVDD_3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-mem-idle; + }; + + ldo24_reg: ldo24 { + regulator-compatible = "LDO24"; + regulator-name = "TSP_VDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo25_reg: ldo25 { + regulator-compatible = "LDO25"; + regulator-name = "LCD_VCC_3.3V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo26_reg: ldo26 { + regulator-compatible = "LDO26"; + regulator-name = "MOTOR_VCC_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-idle; + }; + + buck1_reg: buck1 { + regulator-compatible = "BUCK1"; + regulator-name = "vdd_mif"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck2_reg: buck2 { + regulator-compatible = "BUCK2"; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck3_reg: buck3 { + regulator-compatible = "BUCK3"; + regulator-name = "vdd_int"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck4_reg: buck4 { + regulator-compatible = "BUCK4"; + regulator-name = "vdd_g3d"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-mem-off; + }; + + buck5_reg: buck5 { + regulator-compatible = "BUCK5"; + regulator-name = "VMEM_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + buck6_reg: buck6 { + regulator-compatible = "BUCK6"; + regulator-name = "VCC_SUB_1.35V"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + buck7_reg: buck7 { + regulator-compatible = "BUCK7"; + regulator-name = "VCC_SUB_2.0V"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + buck8_reg: buck8 { + regulator-compatible = "BUCK8"; + regulator-name = "VMEM_VDDF_3.0V"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-mem-off; + }; + + buck9_reg: buck9 { + regulator-compatible = "BUCK9"; + regulator-name = "CAM_ISP_CORE_1.2V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; + regulator-mem-off; + }; + }; + }; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e-interface = <1>; + samsung,dsim-config-e-virtual-ch = <0>; + samsung,dsim-config-e-pixel-format = <7>; + samsung,dsim-config-e-burst-mode = <1>; + samsung,dsim-config-e-no-data-lane = <3>; + samsung,dsim-config-e-byte-clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll-stable-time = <500>; + samsung,dsim-config-esc-clk = <20000000>; + samsung,dsim-config-stop-holding-cnt = <0x7ff>; + samsung,dsim-config-bta-timeout = <0xff>; + samsung,dsim-config-rx-timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus-id = <0>; + + samsung,dsim-device-reverse-panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2004002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20C6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index c17c24d..043bf6b 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,15 +8,9 @@
#include <common.h> #include <lcd.h> -#include <asm/io.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> -#include <asm/arch/power.h> -#include <asm/arch/clk.h> -#include <asm/arch/clock.h> -#include <asm/arch/mipi_dsim.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> +#include <asm/arch/mipi_dsim.h> #include <power/pmic.h> #include <power/max77686_pmic.h> #include <power/battery.h> @@ -28,7 +22,6 @@ #include <usb.h> #include <usb/s3c_udc.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
@@ -69,16 +62,6 @@ static void check_hw_revision(void) board_rev = modelrev << 8; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS2\n"); - printf("HW Revision:\t0x%04x\n", board_rev); - - return 0; -} -#endif - u32 get_board_rev(void) { return board_rev; @@ -156,33 +139,24 @@ int get_soft_i2c_sda_pin(void) } #endif
-int board_early_init_f(void) +int exynos_early_init_f(void) { - check_hw_revision(); board_external_gpio_init();
- gd->flags |= GD_FLG_DISABLE_CONSOLE; - return 0; }
static int pmic_init_max77686(void);
-int board_init(void) +int exynos_init(void) { - struct exynos4_power *pwr = - (struct exynos4_power *)samsung_get_base_power(); - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - /* workaround: clear INFORM4..5 */ - writel(0, (unsigned int)&pwr->inform4); - writel(0, (unsigned int)&pwr->inform5); + check_hw_revision(); + printf("HW Revision:\t0x%04x\n", board_rev);
return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg; struct power_battery *pb; @@ -248,90 +222,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - u32 size_mb; - - size_mb = (get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)) >> 20; - - gd->ram_size = size_mb << 20; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - -int board_mmc_init(bd_t *bis) -{ - int err0, err2 = 0; - - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio2->k0, 2, 1); - s5p_gpio_set_pull(&gpio2->k0, 2, GPIO_PULL_NONE); - - /* - * eMMC GPIO: - * SDR 8-bit@48MHz at MMC0 - * GPK0[0] SD_0_CLK(2) - * GPK0[1] SD_0_CMD(2) - * GPK0[2] SD_0_CDn -> Not used - * GPK0[3:6] SD_0_DATA[0:3](2) - * GPK1[3:6] SD_0_DATA[0:3](3) - * - * DDR 4-bit@26MHz at MMC4 - * GPK0[0] SD_4_CLK(3) - * GPK0[1] SD_4_CMD(3) - * GPK0[2] SD_4_CDn -> Not used - * GPK0[3:6] SD_4_DATA[0:3](3) - * GPK1[3:6] SD_4_DATA[4:7](4) - */ - - err0 = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - if (err0) - debug("SDMMC0 not configured\n"); - else - err0 = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err2) - debug("SDMMC2 not configured\n"); - else - err2 = s5p_mmc_init(2, 4); - } - - return err0 & err2; -} - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -479,46 +369,7 @@ static int pmic_init_max77686(void) */
#ifdef CONFIG_LCD -static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim dsim_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&dsim_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
@@ -556,77 +407,13 @@ void exynos_reset_lcd(void) s5p_gpio_set_value(&gpio1->f2, 1, 1); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - .mipi_enabled = 1, - - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 25, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_panel_init(vidinfo_t *vid) { - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - - vid->power_on_delay = 30; - - mipi_lcd_device.reverse_panel = 1; - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - - strcpy(dsim_platform_data.lcd_panel_name, mipi_lcd_device.name); - dsim_platform_data.mipi_power = mipi_power; - dsim_platform_data.phy_enable = set_mipi_phy_ctrl; - dsim_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - - exynos_set_dsim_platform_data(&dsim_platform_data); -} -#endif /* LCD */ - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif +#endif /* LCD */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 6d389df..8194575 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -8,27 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS2_H +#define __CONFIG_TRATS2_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h>
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */
-#define CONFIG_SKIP_LOWLEVEL_INIT +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4412-trats2
-#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -36,121 +26,47 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
-#define CONFIG_NR_DRAM_BANKS 4 -#define PHYS_SDRAM_1 0x40000000 /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_3 0x60000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_3_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_4 0x70000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_4_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_END 0x80000000 - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ +/* TRATS2 has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) #define CONFIG_SYS_TEXT_BASE 0x78100000
-#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG - -/* MACH_TYPE_TRATS2 */ -#define MACH_TYPE_TRATS2 3765 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS2 - -#define CONFIG_DISPLAY_CPUINFO - #include <linux/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ #define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMDLINE_EDITING +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE)
-/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ECHO -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NAND -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_SOURCE -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_PMIC - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -/* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ -#undef CONFIG_CMD_NET - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA -#define CONFIG_MMC_DEFAULT_DEV 0 - -/* PWM */ -#define CONFIG_PWM - -#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -246,49 +162,11 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - - GENERATED_GBL_DATA_SIZE) - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_BOARD_EARLY_INIT_F - /* I2C */ #include <asm/arch/gpio.h>
+#define CONFIG_CMD_I2C + #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 @@ -318,11 +196,6 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -362,10 +235,7 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board.c file is reused for all functions common for Exynos4 boards. Board specific files are implemented in the board files. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
This patch series depends on: [U-Boot] sizes.h - consolidate for all architectures http://patchwork.ozlabs.org/patch/324427/
Changes for v5: - add exynos_mipi_dsi.txt file with documented bindings - changed the name of exynos_lcd_panel_init to exynos_lcd_misc_init - removed unused panel_info.resolution binding
Changes for v4: - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board - use "-" hypen in DT bindings - remove duplicated DT properties at exynos_fb.c file
Changes for v3: - moved max77686 init function to smdk5250 board file - board DTS files moved to arch/arm/dts - rebased on the latest tree
Changes for v2: - removed incorrectly implemented check for invalid peripheral id - removed unnecesary white space - removed panel specific init function 's6e8ax0_init' to the board file - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed - new patch to move checkboard to common file - reuse existing common board.c file - new patch that removes unused max77686_init function - fixed mmc2 addres in DT on Trats2
Piotr Wilczek (12): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT board:samsung: move checkboard to common file arm:exynos: add common DTS file for exynos 4 board:samsung:common: move max77686 init function arm:exynos: enable sdhci and misc_init to common board board:origen: Enable device tree on Origen board:universal: Enable device tree on Universal board:trats: Enable device tree on Trats board:trats2: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 17 + arch/arm/dts/Makefile | 5 + arch/arm/dts/exynos4.dtsi | 138 +++++++ arch/arm/dts/exynos4210-origen.dts | 45 +++ arch/arm/dts/exynos4210-trats.dts | 120 ++++++ arch/arm/dts/exynos4210-universal_c210.dts | 83 ++++ arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 + arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/board.c | 180 +++------ board/samsung/origen/origen.c | 112 +----- board/samsung/smdk5250/exynos5-dt.c | 15 - board/samsung/smdk5250/smdk5250.c | 125 ++++++ board/samsung/smdk5420/smdk5420.c | 15 - board/samsung/trats/trats.c | 213 +--------- board/samsung/trats2/trats2.c | 233 +---------- board/samsung/universal_c210/universal.c | 204 +++------- doc/device-tree-bindings/video/exynos_mipi_dsi.txt | 82 ++++ drivers/mmc/s5p_sdhci.c | 129 ++++++ drivers/video/exynos_fb.c | 12 + drivers/video/exynos_mipi_dsi.c | 96 +++++ include/configs/exynos4-dt.h | 138 +++++++ include/configs/origen.h | 110 ++---- include/configs/s5pc210_universal.h | 152 +++----- include/configs/trats.h | 206 +++------- include/configs/trats2.h | 204 ++-------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 30 files changed, 1765 insertions(+), 1336 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 arch/arm/dts/exynos4210-origen.dts create mode 100644 arch/arm/dts/exynos4210-trats.dts create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts create mode 100644 arch/arm/dts/exynos4412-trats2.dts create mode 100644 doc/device-tree-bindings/video/exynos_mipi_dsi.txt create mode 100644 include/configs/exynos4-dt.h
This patch adds api to decode peripheral id based on interrupt number.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - none
Changes for v4: - none
Changes for v3: - none
arch/arm/cpu/armv7/exynos/pinmux.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 645c497..8d6e5c1 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -741,6 +741,21 @@ int exynos_pinmux_config(int peripheral, int flags) }
#ifdef CONFIG_OF_CONTROL +static int exynos4_pinmux_decode_periph_id(const void *blob, int node) +{ + int err; + u32 cell[3]; + + err = fdtdec_get_int_array(blob, node, "interrupts", cell, + ARRAY_SIZE(cell)); + if (err) { + debug(" invalid peripheral id\n"); + return PERIPH_ID_NONE; + } + + return cell[1]; +} + static int exynos5_pinmux_decode_periph_id(const void *blob, int node) { int err; @@ -758,6 +773,8 @@ int pinmux_decode_periph_id(const void *blob, int node) { if (cpu_is_exynos5()) return exynos5_pinmux_decode_periph_id(blob, node); + else if (cpu_is_exynos4()) + return exynos4_pinmux_decode_periph_id(blob, node); else return PERIPH_ID_NONE; }
This patch enables parsing mipi data from device tree. Non device tree case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - add exynos_mipi_dsi.txt file with documented bindings
Changes for v4: - use "-" hypen for DT bindings
Changes for v2: - removed panel specific init function 's6e8ax0_init' to the board file
arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 ++ doc/device-tree-bindings/video/exynos_mipi_dsi.txt | 82 ++++++++++++++++++ drivers/video/exynos_mipi_dsi.c | 96 ++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 5 files changed, 185 insertions(+) create mode 100644 doc/device-tree-bindings/video/exynos_mipi_dsi.txt
diff --git a/arch/arm/include/asm/arch-exynos/mipi_dsim.h b/arch/arm/include/asm/arch-exynos/mipi_dsim.h index 40aca71..50e5c25 100644 --- a/arch/arm/include/asm/arch-exynos/mipi_dsim.h +++ b/arch/arm/include/asm/arch-exynos/mipi_dsim.h @@ -12,6 +12,7 @@
#include <linux/list.h> #include <linux/fb.h> +#include <lcd.h>
#define PANEL_NAME_SIZE (32)
@@ -368,8 +369,12 @@ int exynos_mipi_dsi_register_lcd_device(struct mipi_dsim_lcd_device *lcd_dev);
void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd); +void exynos_init_dsim_platform_data(vidinfo_t *vid);
/* panel driver init based on mipi dsi interface */ void s6e8ax0_init(void);
+#ifdef CONFIG_OF_CONTROL +extern int mipi_power(void); +#endif #endif /* _DSIM_H */ diff --git a/doc/device-tree-bindings/video/exynos_mipi_dsi.txt b/doc/device-tree-bindings/video/exynos_mipi_dsi.txt new file mode 100644 index 0000000..4938ea0 --- /dev/null +++ b/doc/device-tree-bindings/video/exynos_mipi_dsi.txt @@ -0,0 +1,82 @@ +Exynos MIPI-DSIM Controller +========================= + +Required properties: +SOC specific: + compatible: should be "samsung,exynos-mipi-dsi" + reg: Base address of MIPI-DSIM IP. + +Board specific: + samsung,dsim-config-e-interface: interface to be used (RGB interface + for main display or CPU interface for main or sub display). + samsung,dsim-config-e-virtual-ch: virtual channel number that main + or sub display uses. + samsung,dsim-config-e-pixel-format: pixel stream format for main + or sub display. + samsung,dsim-config-e-burst-mode: selects Burst mode in Video mode. + in Non-burst mode, RGB data area is filled with RGB data and + NULL packets, according to input bandwidth of RGB interface. + samsung,dsim-config-e-no-data-lane: data lane count used by Master. + samsung,dsim-config-e-byte-clk: select byte clock source. + It must be DSIM_PLL_OUT_DIV8. + DSIM_EXT_CLK_DIV8 and DSIM_EXT_CLK_BYPASSS are not supported. + samsung,dsim-config-hfp: HFP disable mode. + If set, DSI master ignores HFP area in VIDEO mode. + In command mode, this variable is ignored. + samsung,dsim-config-p: P value for PMS setting. + samsung,dsim-config-m: M value for PMS setting. + samsung,dsim-config-s: S value for PMS setting. + samsung,dsim-config-pll-stable-time: the PLL Timer for stability + of the ganerated clock. + samsung,dsim-config-esc-clk: escape clock frequency for getting + the escape clock prescaler value. + samsung,dsim-config-stop-holding-cnt: the interval value between + transmitting read packet (or write "set_tear_on" command) + and BTA request. After transmitting read packet or write + "set_tear_on" command, BTA requests to D-PHY automatically. + This counter value specifies the interval between them. + samsung,dsim-config-bta-timeout: the timer for BTA. This register + specifies time out from BTA request to change the direction + with respect to Tx escape clock. + samsung,dsim-config-rx-timeout: the timer for LP Rx mode timeout. + this register specifies time out on how long RxValid deasserts, + after RxLpdt asserts with respect to Tx escape clock. + - RxValid specifies Rx data valid indicator. + - RxLpdt specifies an indicator that D-PHY is under RxLpdt mode + - RxValid and RxLpdt specifies signal from D-PHY. + samsung,dsim-device-name: name of the device. + samsung,dsim-device-id: unique device id. + samsung,dsim-device-bus_id: bus id for identifing connected bus + and this bus id should be same as id of mipi_dsim_device. + +Optional properties: + samsung,dsim-device-reverse-panel: reverse panel. + +Example: + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e-interface = <1>; + samsung,dsim-config-e-virtual-ch = <0>; + samsung,dsim-config-e-pixel-format = <7>; + samsung,dsim-config-e-burst-mode = <1>; + samsung,dsim-config-e-no-data-lane = <3>; + samsung,dsim-config-e-byte-clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll-stable-time = <500>; + samsung,dsim-config-esc-clk = <20000000>; + samsung,dsim-config-stop-holding-cnt = <0x7ff>; + samsung,dsim-config-bta-timeout = <0xff>; + samsung,dsim-config-rx-timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus-id = <0>; + + samsung,dsim-device-reverse-panel = <1>; + }; diff --git a/drivers/video/exynos_mipi_dsi.c b/drivers/video/exynos_mipi_dsi.c index 8bb8fea..7dd4652 100644 --- a/drivers/video/exynos_mipi_dsi.c +++ b/drivers/video/exynos_mipi_dsi.c @@ -9,6 +9,8 @@
#include <common.h> #include <malloc.h> +#include <fdtdec.h> +#include <libfdt.h> #include <linux/err.h> #include <asm/arch/dsim.h> #include <asm/arch/mipi_dsim.h> @@ -22,7 +24,14 @@ #define master_to_driver(a) (a->dsim_lcd_drv) #define master_to_device(a) (a->dsim_lcd_dev)
+DECLARE_GLOBAL_DATA_PTR; + static struct exynos_platform_mipi_dsim *dsim_pd; +#ifdef CONFIG_OF_CONTROL +static struct mipi_dsim_config dsim_config_dt; +static struct exynos_platform_mipi_dsim dsim_platform_data_dt; +static struct mipi_dsim_lcd_device mipi_lcd_device_dt; +#endif
struct mipi_dsim_ddi { int bus_id; @@ -238,3 +247,90 @@ void exynos_set_dsim_platform_data(struct exynos_platform_mipi_dsim *pd)
dsim_pd = pd; } + +#ifdef CONFIG_OF_CONTROL +int exynos_dsim_config_parse_dt(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_MIPI_DSI); + if (node <= 0) { + printf("exynos_mipi_dsi: Can't get device node for mipi dsi\n"); + return -ENODEV; + } + + dsim_config_dt.e_interface = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-interface", 0); + + dsim_config_dt.e_virtual_ch = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-virtual-ch", 0); + + dsim_config_dt.e_pixel_format = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-pixel-format", 0); + + dsim_config_dt.e_burst_mode = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-burst-mode", 0); + + dsim_config_dt.e_no_data_lane = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-no-data-lane", 0); + + dsim_config_dt.e_byte_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-e-byte-clk", 0); + + dsim_config_dt.hfp = fdtdec_get_int(blob, node, + "samsung,dsim-config-hfp", 0); + + dsim_config_dt.p = fdtdec_get_int(blob, node, + "samsung,dsim-config-p", 0); + dsim_config_dt.m = fdtdec_get_int(blob, node, + "samsung,dsim-config-m", 0); + dsim_config_dt.s = fdtdec_get_int(blob, node, + "samsung,dsim-config-s", 0); + + dsim_config_dt.pll_stable_time = fdtdec_get_int(blob, node, + "samsung,dsim-config-pll-stable-time", 0); + + dsim_config_dt.esc_clk = fdtdec_get_int(blob, node, + "samsung,dsim-config-esc-clk", 0); + + dsim_config_dt.stop_holding_cnt = fdtdec_get_int(blob, node, + "samsung,dsim-config-stop-holding-cnt", 0); + + dsim_config_dt.bta_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-bta-timeout", 0); + + dsim_config_dt.rx_timeout = fdtdec_get_int(blob, node, + "samsung,dsim-config-rx-timeout", 0); + + mipi_lcd_device_dt.name = fdtdec_get_config_string(blob, + "samsung,dsim-device-name"); + + mipi_lcd_device_dt.id = fdtdec_get_int(blob, node, + "samsung,dsim-device-id", 0); + + mipi_lcd_device_dt.bus_id = fdtdec_get_int(blob, node, + "samsung,dsim-device-bus_id", 0); + + mipi_lcd_device_dt.reverse_panel = fdtdec_get_int(blob, node, + "samsung,dsim-device-reverse-panel", 0); + + return 0; +} + +void exynos_init_dsim_platform_data(vidinfo_t *vid) +{ + if (exynos_dsim_config_parse_dt(gd->fdt_blob)) + debug("Can't get proper dsim config.\n"); + + strcpy(dsim_platform_data_dt.lcd_panel_name, mipi_lcd_device_dt.name); + dsim_platform_data_dt.dsim_config = &dsim_config_dt; + dsim_platform_data_dt.mipi_power = mipi_power; + dsim_platform_data_dt.phy_enable = set_mipi_phy_ctrl; + dsim_platform_data_dt.lcd_panel_info = (void *)vid; + + mipi_lcd_device_dt.platform_data = (void *)&dsim_platform_data_dt; + exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device_dt); + + dsim_pd = &dsim_platform_data_dt; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index 19bab79..bd84c83 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -79,6 +79,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_FIMD, /* Exynos Display controller */ + COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 1fecab3..c97fad3 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -52,6 +52,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_FIMD, "samsung,exynos-fimd"), + COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"),
This patch adds the new exynos_lcd_misc_init() function for optional lcd specific initialisation.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - changed the name of exynos_lcd_panel_init to exynos_lcd_misc_init - removed unused panel_info.resolution binding
Changes for v4: - remove duplicated DT properties at exynos_fb.c file
Changes for v2: - removed duplicate DTB node parsing for panel_info.logo_on - added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file
drivers/video/exynos_fb.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index 00a0a11..e1e0d80 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -104,6 +104,13 @@ void __exynos_backlight_reset(void) void exynos_backlight_reset(void) __attribute__((weak, alias("__exynos_backlight_reset")));
+int __exynos_lcd_misc_init(vidinfo_t *vid) +{ + return 0; +} +int exynos_lcd_misc_init(vidinfo_t *vid) + __attribute__((weak, alias("__exynos_lcd_misc_init"))); + static void lcd_panel_on(vidinfo_t *vid) { udelay(vid->init_delay); @@ -281,10 +288,15 @@ void lcd_ctrl_init(void *lcdbase) #ifdef CONFIG_OF_CONTROL if (exynos_fimd_parse_dt(gd->fdt_blob)) debug("Can't get proper panel info\n"); +#ifdef CONFIG_EXYNOS_MIPI_DSIM + exynos_init_dsim_platform_data(&panel_info); +#endif + exynos_lcd_misc_init(&panel_info); #else /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endif + panel_width = panel_info.vl_width; panel_height = panel_info.vl_height;
This patch enables support for device tree for sdhci driver. Non DT case is still supported.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - none
Changes for v2: - fixed checking for SDMMC boundary - fiex debug message - fixed comment to 'pwr_gpio' struct filed
arch/arm/include/asm/arch-exynos/mmc.h | 7 ++ drivers/mmc/s5p_sdhci.c | 129 +++++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + include/sdhci.h | 5 ++ lib/fdtdec.c | 1 + 5 files changed, 143 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 98d6530..0fb6461 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -53,6 +53,8 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
+#define SDHCI_MAX_HOSTS 4 + int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline int s5p_mmc_init(int index, int bus_width) @@ -62,4 +64,9 @@ static inline int s5p_mmc_init(int index, int bus_width)
return s5p_sdhci_init(base, index, bus_width); } + +#ifdef CONFIG_OF_CONTROL +int exynos_mmc_init(const void *blob); +#endif + #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 40ff873..ccae4cc 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -8,8 +8,15 @@ #include <common.h> #include <malloc.h> #include <sdhci.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/clk.h> +#include <errno.h> +#ifdef CONFIG_OF_CONTROL +#include <asm/arch/pinmux.h> +#endif
static char *S5P_NAME = "SAMSUNG SDHCI"; static void s5p_sdhci_set_control_reg(struct sdhci_host *host) @@ -86,3 +93,125 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
return add_sdhci(host, 52000000, 400000); } + +#ifdef CONFIG_OF_CONTROL +struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; + +static int do_sdhci_init(struct sdhci_host *host) +{ + int dev_id, flag; + int err = 0; + + flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + dev_id = host->index + PERIPH_ID_SDMMC0; + + if (fdt_gpio_isvalid(&host->pwr_gpio)) { + gpio_direction_output(host->pwr_gpio.gpio, 1); + err = exynos_pinmux_config(dev_id, flag); + if (err) { + debug("MMC not configured\n"); + return err; + } + } + + if (fdt_gpio_isvalid(&host->cd_gpio)) { + gpio_direction_output(host->cd_gpio.gpio, 0xf); + if (gpio_get_value(host->cd_gpio.gpio)) + return -ENODEV; + + err = exynos_pinmux_config(dev_id, flag); + if (err) { + printf("external SD not configured\n"); + return err; + } + } + + host->name = S5P_NAME; + + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->set_control_reg = &s5p_sdhci_set_control_reg; + host->set_clock = set_mmc_clk; + + host->host_caps = MMC_MODE_HC; + + return add_sdhci(host, 52000000, 400000); +} + +static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) +{ + int bus_width, dev_id; + unsigned int base; + + /* Get device id */ + dev_id = pinmux_decode_periph_id(blob, node); + if (dev_id < PERIPH_ID_SDMMC0 && dev_id > PERIPH_ID_SDMMC3) { + debug("MMC: Can't get device id\n"); + return -1; + } + host->index = dev_id - PERIPH_ID_SDMMC0; + + /* Get bus width */ + bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (bus_width <= 0) { + debug("MMC: Can't get bus-width\n"); + return -1; + } + host->bus_width = bus_width; + + /* Get the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("MMC: Can't get base address\n"); + return -1; + } + host->ioaddr = (void *)base; + + fdtdec_decode_gpio(blob, node, "pwr-gpios", &host->pwr_gpio); + fdtdec_decode_gpio(blob, node, "cd-gpios", &host->cd_gpio); + + return 0; +} + +static int process_nodes(const void *blob, int node_list[], int count) +{ + struct sdhci_host *host; + int i, node; + + debug("%s: count = %d\n", __func__, count); + + /* build sdhci_host[] for each controller */ + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + + host = &sdhci_host[i]; + + if (sdhci_get_config(blob, node, host)) { + printf("%s: failed to decode dev %d\n", __func__, i); + return -1; + } + do_sdhci_init(host); + } + return 0; +} + +int exynos_mmc_init(const void *blob) +{ + int count; + int node_list[SDHCI_MAX_HOSTS]; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + COMPAT_SAMSUNG_EXYNOS_MMC, node_list, + SDHCI_MAX_HOSTS); + + process_nodes(blob, node_list, count); + + return 1; +} +#endif diff --git a/include/fdtdec.h b/include/fdtdec.h index bd84c83..63027bd 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -82,6 +82,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ + COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/include/sdhci.h b/include/sdhci.h index 74d06ae..32e04f5 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -12,6 +12,7 @@
#include <asm/io.h> #include <mmc.h> +#include <fdtdec.h>
/* * Controller registers @@ -244,6 +245,10 @@ struct sdhci_host { const struct sdhci_ops *ops; int index;
+ int bus_width; + struct fdt_gpio_state pwr_gpio; /* Power GPIO */ + struct fdt_gpio_state cd_gpio; /* Card Detect GPIO */ + void (*set_control_reg)(struct sdhci_host *host); void (*set_clock)(int dev_index, unsigned int div); uint voltages; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index c97fad3..be04598 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -55,6 +55,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), + COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
The checkboard function's implementation is common for all DT supporting boards and should be placed in the board common file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Amar amarendra.xt@samsung.com
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes for v5: - none
Changes for v2: - new patch
board/samsung/common/board.c | 12 ++++++++++++ board/samsung/smdk5250/exynos5-dt.c | 15 --------------- board/samsung/smdk5420/smdk5420.c | 15 --------------- 3 files changed, 12 insertions(+), 30 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cd873bc..f8562b2 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -377,7 +377,19 @@ int board_mmc_init(bd_t *bis) return ret; } #endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + const char *board_name; + + board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + printf("Board: %s\n", board_name ? board_name : "unknown"); + + return 0; +} #endif +#endif /* CONFIG_OF_CONTROL */
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index 5fb8664..b22fba5 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -45,21 +45,6 @@ int exynos_init(void) return 0; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif - #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) { diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 3ad2ad0..e4606ec 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -142,18 +142,3 @@ int board_get_revision(void) { return 0; } - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - const char *board_name; - - board_name = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - if (board_name == NULL) - printf("\nUnknown Board\n"); - else - printf("\nBoard: %s\n", board_name); - - return 0; -} -#endif
This patch adds common dtsi file and config header for all Exynos 4 based boards.
Patch additionaly adds board specific (weak) functions for board_early_init_f and board_power_init functions.
Changes for v2: - reuse existing common board.c file
arch/arm/dts/exynos4.dtsi | 138 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 +++ board/samsung/common/board.c | 18 +++- include/configs/exynos4-dt.h | 138 +++++++++++++++++++++++++++++++ 4 files changed, 304 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 include/configs/exynos4-dt.h
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi new file mode 100644 index 0000000..71dc7eb --- /dev/null +++ b/arch/arm/dts/exynos4.dtsi @@ -0,0 +1,138 @@ +/* + * Samsung's Exynos4 SoC common device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + serial@13800000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13800000 0x3c>; + id = <0>; + }; + + serial@13810000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13810000 0x3c>; + id = <1>; + }; + + serial@13820000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13820000 0x3c>; + id = <2>; + }; + + serial@13830000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13830000 0x3c>; + id = <3>; + }; + + serial@13840000 { + compatible = "samsung,exynos4210-uart"; + reg = <0x13840000 0x3c>; + id = <4>; + }; + + i2c@13860000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <0 0 0>; + }; + + i2c@13870000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <1 1 0>; + }; + + i2c@13880000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <2 2 0>; + }; + + i2c@13890000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <3 3 0>; + }; + + i2c@138a0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <4 4 0>; + }; + + i2c@138b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <5 5 0>; + }; + + i2c@138c0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <6 6 0>; + }; + + i2c@138d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,s3c2440-i2c"; + interrupts = <7 7 0>; + }; + + sdhci@12510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12510000 0x1000>; + interrupts = <0 75 0>; + }; + + sdhci@12520000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12520000 0x1000>; + interrupts = <0 76 0>; + }; + + sdhci@12530000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12530000 0x1000>; + interrupts = <0 77 0>; + }; + + sdhci@12540000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-mmc"; + reg = <0x12540000 0x1000>; + interrupts = <0 78 0>; + }; + + gpio: gpio { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; +}; diff --git a/arch/arm/include/asm/arch-exynos/board.h b/arch/arm/include/asm/arch-exynos/board.h index 243fb12..1b1cd0d 100644 --- a/arch/arm/include/asm/arch-exynos/board.h +++ b/arch/arm/include/asm/arch-exynos/board.h @@ -14,4 +14,16 @@ */ int exynos_init(void);
+/* + * Exynos board specific changes for + * board_early_init_f + */ +int exynos_early_init_f(void); + +/* + * Exynos board specific changes for + * board_power_init + */ +int exynos_power_init(void); + #endif /* EXYNOS_BOARD_H */ diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index f8562b2..cf78d36 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -33,6 +33,20 @@ struct local_info {
static struct local_info local;
+int __exynos_early_init_f(void) +{ + return 0; +} +int exynos_early_init_f(void) + __attribute__((weak, alias("__exynos_early_init_f"))); + +int __exynos_power_init(void) +{ + return 0; +} +int exynos_power_init(void) + __attribute__((weak, alias("__exynos_power_init"))); + #if defined CONFIG_EXYNOS_TMU /* Boot Time Thermal Analysis for SoC temperature threshold breach */ static void boot_temp_check(void) @@ -140,7 +154,7 @@ int board_early_init_f(void) board_i2c_init(gd->fdt_blob); #endif
- return err; + return exynos_early_init_f(); } #endif
@@ -284,7 +298,7 @@ int power_init_board(void) ret = max77686_init(); #endif
- return ret; + return exynos_power_init(); } #endif
diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h new file mode 100644 index 0000000..2040bf7 --- /dev/null +++ b/include/configs/exynos4-dt.h @@ -0,0 +1,138 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * + * Configuration settings for the SAMSUNG EXYNOS5 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS4 /* which is in a Exynos4 Family */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_COMMON + +/* Enable fdt support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* input clock of PLL: EXYNOS4 boards have 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +#include <linux/sizes.h> + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_S5P_SDHCI +#define CONFIG_SDHCI +#define CONFIG_MMC_SDMA +#define CONFIG_MMC_DEFAULT_DEV 0 + +/* PWM */ +#define CONFIG_PWM + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_ONENAND +#undef CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_MMC +#define CONFIG_CMD_DFU +#define CONFIG_CMD_GPT +#define CONFIG_CMD_PMIC +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* FAT */ +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* EXT4 */ +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE + +/* USB Composite download gadget - g_dnl */ +#define CONFIG_USBDOWNLOAD_GADGET + +/* TIZEN THOR downloader support */ +#define CONFIG_CMD_THOR_DOWNLOAD +#define CONFIG_THOR_FUNCTION + +#define CONFIG_DFU_FUNCTION +#define CONFIG_DFU_MMC +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M +#define DFU_DEFAULT_POLL_TIMEOUT 300 + +/* USB Samsung's IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 +#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 +#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM +#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D +#define CONFIG_G_DNL_MANUFACTURER "Samsung" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_S3C_UDC_OTG +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK + +#define CONFIG_CMD_USB_MASS_STORAGE +#define CONFIG_USB_GADGET_MASS_STORAGE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +#endif /* __CONFIG_H */
This patch moves board specific max77686 init function from common board to smdk5250 board file.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Rajeshwari S Shinde rajeshwari.s@samsung.com Cc: Rajeshwari Birje rajeshwari.birje@gmail.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - none
Changes for v3: - max77686 init function is moved to smdk5250 board file
board/samsung/common/board.c | 120 ------------------------------------ board/samsung/smdk5250/smdk5250.c | 125 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 125 insertions(+), 120 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index cf78d36..a74b044 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,7 +22,6 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> -#include <power/max77686_pmic.h>
@@ -175,129 +174,10 @@ static int board_init_cros_ec_devices(const void *blob) #endif
#if defined(CONFIG_POWER) -#ifdef CONFIG_POWER_MAX77686 -static int pmic_reg_update(struct pmic *p, int reg, uint regval) -{ - u32 val; - int ret = 0; - - ret = pmic_reg_read(p, reg, &val); - if (ret) { - debug("%s: PMIC %d register read failed\n", __func__, reg); - return -1; - } - val |= regval; - ret = pmic_reg_write(p, reg, val); - if (ret) { - debug("%s: PMIC %d register write failed\n", __func__, reg); - return -1; - } - return 0; -} - -static int max77686_init(void) -{ - struct pmic *p; - - if (pmic_init(I2C_PMIC)) - return -1; - - p = pmic_get("MAX77686_PMIC"); - if (!p) - return -ENODEV; - - if (pmic_probe(p)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) - return -1; - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, - MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) - return -1; - - /* VDD_MIF */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, - MAX77686_BUCK1OUT_1V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK1OUT); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, - MAX77686_BUCK1CTRL_EN)) - return -1; - - /* VDD_ARM */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, - MAX77686_BUCK2DVS1_1_3V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK2DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, - MAX77686_BUCK2CTRL_ON)) - return -1; - - /* VDD_INT */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, - MAX77686_BUCK3DVS1_1_0125V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK3DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_G3D */ - if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, - MAX77686_BUCK4DVS1_1_2V)) { - debug("%s: PMIC %d register write failed\n", __func__, - MAX77686_REG_PMIC_BUCK4DVS1); - return -1; - } - - if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, - MAX77686_BUCK3CTRL_ON)) - return -1; - - /* VDD_LDO2 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, - MAX77686_LD02CTRL1_1_5V | EN_LDO)) - return -1; - - /* VDD_LDO3 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, - MAX77686_LD03CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO5 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, - MAX77686_LD05CTRL1_1_8V | EN_LDO)) - return -1; - - /* VDD_LDO10 */ - if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, - MAX77686_LD10CTRL1_1_8V | EN_LDO)) - return -1; - - return 0; -} -#endif - int power_init_board(void) { - int ret = 0; - set_ps_hold_ctrl();
-#ifdef CONFIG_POWER_MAX77686 - ret = max77686_init(); -#endif - return exynos_power_init(); } #endif diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index a69f73d..28a6d9e 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -147,6 +147,131 @@ void board_i2c_init(const void *blob) } }
+#if defined(CONFIG_POWER) +#ifdef CONFIG_POWER_MAX77686 +static int pmic_reg_update(struct pmic *p, int reg, uint regval) +{ + u32 val; + int ret = 0; + + ret = pmic_reg_read(p, reg, &val); + if (ret) { + debug("%s: PMIC %d register read failed\n", __func__, reg); + return -1; + } + val |= regval; + ret = pmic_reg_write(p, reg, val); + if (ret) { + debug("%s: PMIC %d register write failed\n", __func__, reg); + return -1; + } + return 0; +} + +static int max77686_init(void) +{ + struct pmic *p; + + if (pmic_init(I2C_PMIC)) + return -1; + + p = pmic_get("MAX77686_PMIC"); + if (!p) + return -ENODEV; + + if (pmic_probe(p)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_32KHZ, MAX77686_32KHCP_EN)) + return -1; + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BBAT, + MAX77686_BBCHOSTEN | MAX77686_BBCVS_3_5V)) + return -1; + + /* VDD_MIF */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK1OUT, + MAX77686_BUCK1OUT_1V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK1OUT); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK1CRTL, + MAX77686_BUCK1CTRL_EN)) + return -1; + + /* VDD_ARM */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK2DVS1, + MAX77686_BUCK2DVS1_1_3V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK2DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK2CTRL1, + MAX77686_BUCK2CTRL_ON)) + return -1; + + /* VDD_INT */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK3DVS1, + MAX77686_BUCK3DVS1_1_0125V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK3DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK3CTRL, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_G3D */ + if (pmic_reg_write(p, MAX77686_REG_PMIC_BUCK4DVS1, + MAX77686_BUCK4DVS1_1_2V)) { + debug("%s: PMIC %d register write failed\n", __func__, + MAX77686_REG_PMIC_BUCK4DVS1); + return -1; + } + + if (pmic_reg_update(p, MAX77686_REG_PMIC_BUCK4CTRL1, + MAX77686_BUCK3CTRL_ON)) + return -1; + + /* VDD_LDO2 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO2CTRL1, + MAX77686_LD02CTRL1_1_5V | EN_LDO)) + return -1; + + /* VDD_LDO3 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO3CTRL1, + MAX77686_LD03CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO5 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO5CTRL1, + MAX77686_LD05CTRL1_1_8V | EN_LDO)) + return -1; + + /* VDD_LDO10 */ + if (pmic_reg_update(p, MAX77686_REG_PMIC_LDO10CTRL1, + MAX77686_LD10CTRL1_1_8V | EN_LDO)) + return -1; + + return 0; +} +#endif /* CONFIG_POWER_MAX77686 */ + +int exynos_power_init(void) +{ + int ret = 0; + +#ifdef CONFIG_POWER_MAX77686 + ret = max77686_init(); +#endif + return ret; +} +#endif /* CONFIG_POWER */ + #ifdef CONFIG_LCD void exynos_cfg_lcd_gpio(void) {
This patch enables sdhci initialisation and misc_init_r in common board file for all exynos 4 based boards.
board/samsung/common/board.c | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index a74b044..e95e9c4 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -22,6 +22,8 @@ #include <asm/arch/power.h> #include <power/pmic.h> #include <asm/arch/sromc.h> +#include <lcd.h> +#include <samsung/misc.h>
@@ -183,6 +185,7 @@ int power_init_board(void) #endif
#ifdef CONFIG_OF_CONTROL +#ifdef CONFIG_SMC911X static int decode_sromc(const void *blob, struct fdt_sromc *config) { int err; @@ -206,6 +209,7 @@ static int decode_sromc(const void *blob, struct fdt_sromc *config) } return 0; } +#endif
int board_eth_init(bd_t *bis) { @@ -263,10 +267,18 @@ int board_mmc_init(bd_t *bis) { int ret;
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif +#ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); if (ret) debug("dwmmc init failed\n"); +#endif
return ret; } @@ -315,3 +327,21 @@ int arch_early_init_r(void)
return 0; } + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + set_board_info(); +#endif +#ifdef CONFIG_LCD_MENU + keys_init(); + check_boot_mode(); +#endif +#ifdef CONFIG_CMD_BMP + if (panel_info.logo_on) + draw_logo(); +#endif + return 0; +} +#endif
This patch enables to run Origen board on device tree.
Uart, DRAM and MMC init functions are removed as their generic replacements form the common board file are used.
The config file is modified to contain only board specific options.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Chander Kashyap k.chander@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - no changes
Changes for v3: - dts file moved to arch/arm/dts
Changes for v2: - no changes
arch/arm/dts/Makefile | 2 + arch/arm/dts/exynos4210-origen.dts | 45 +++++++++++++++ board/samsung/origen/origen.c | 112 +++---------------------------------- include/configs/origen.h | 110 ++++++++++-------------------------- 4 files changed, 87 insertions(+), 182 deletions(-) create mode 100644 arch/arm/dts/exynos4210-origen.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e2fcca5..dad03cf 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,3 +1,5 @@ +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb + dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-smdk5250.dtb \ diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts new file mode 100644 index 0000000..5c9d2ae --- /dev/null +++ b/arch/arm/dts/exynos4210-origen.dts @@ -0,0 +1,45 @@ +/* + * Samsung's Exynos4210 based Origen board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "skeleton.dtsi" +/include/ "exynos4.dtsi" + +/ { + model = "Insignal Origen evaluation board based on Exynos4210"; + compatible = "insignal,origen", "samsung,exynos4210"; + + chosen { + bootargs =""; + }; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + status = "disabled"; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 15f77ca..d502f02 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -11,129 +11,35 @@ #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> +#include <usb.h>
DECLARE_GLOBAL_DATA_PTR; -struct exynos4_gpio_part1 *gpio1; -struct exynos4_gpio_part2 *gpio2;
-int board_init(void) +u32 get_board_rev(void) { - gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; - gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE; - - gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); return 0; }
-static int board_uart_init(void) +int exynos_init(void) { - int err; - - err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); - if (err) { - debug("UART0 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); - if (err) { - debug("UART1 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); - if (err) { - debug("UART2 not configured\n"); - return err; - } - - err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); - if (err) { - debug("UART3 not configured\n"); - return err; - } - return 0; }
-#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - int err; - err = board_uart_init(); - if (err) { - debug("UART init failed\n"); - return err; - } - return err; -} -#endif - -int dram_init(void) +int board_usb_init(int index, enum usb_init_type init) { - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) - + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) - + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) - + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - return 0; }
-void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, \ - PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, \ - PHYS_SDRAM_2_SIZE); - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = get_ram_size((long *)PHYS_SDRAM_3, \ - PHYS_SDRAM_3_SIZE); - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = get_ram_size((long *)PHYS_SDRAM_4, \ - PHYS_SDRAM_4_SIZE); -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) { - printf("\nBoard: ORIGEN\n"); return 0; } #endif
-#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) +#ifdef CONFIG_BOARD_EARLY_INIT_F +int exynos_early_init_f(void) { - int i, err; - - /* - * MMC2 SD card GPIO: - * - * GPK2[0] SD_2_CLK(2) - * GPK2[1] SD_2_CMD(2) - * GPK2[2] SD_2_CDn - * GPK2[3:6] SD_2_DATA[0:3](2) - */ - for (i = 0; i < 7; i++) { - /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); - - /* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); - - /* GPK2[0:1] pull disable */ - if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); - continue; - } - - /* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); - } - - err = s5p_mmc_init(2, 4); - return err; + return 0; } #endif diff --git a/include/configs/origen.h b/include/configs/origen.h index f46b833..8258338 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -6,115 +6,71 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_ORIGEN_H +#define __CONFIG_ORIGEN_H + +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "ORIGEN # " + +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-origen
/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* SAMSUNG core */ -#define CONFIG_S5P 1 /* S5P Family */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F - #define CONFIG_SYS_DCACHE_OFF 1
+/* ORIGEN has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x43E00000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: ORIGEN has 24MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 24000000 +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_TEXT_BASE 0x43E00000
#define CONFIG_MACH_TYPE MACH_TYPE_ORIGEN
-/* Power Down Modes */ -#define S5P_CHECK_SLEEP 0x00000BAD -#define S5P_CHECK_DIDLE 0xBAD00000 -#define S5P_CHECK_LPA 0xABAD0000 - /* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200 -#define EXYNOS4_DEFAULT_UART_OFFSET 0x020000
-#define CONFIG_SKIP_LOWLEVEL_INIT +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-/* SD/MMC configuration */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */
-/* PWM */ -#define CONFIG_PWM 1 +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -/* Command definition*/ -#include <config_cmd_default.h> +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000
#undef CONFIG_CMD_PING #define CONFIG_CMD_ELF #define CONFIG_CMD_DHCP -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT #undef CONFIG_CMD_NET #undef CONFIG_CMD_NFS
-#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030 - #define CONFIG_SPL_TEXT_BASE 0x02021410
#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "ORIGEN # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - -/* ORIGEN has 4 bank of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH 1 -#undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for ORIGEN"
#define CONFIG_CLK_1000_400_200 @@ -122,13 +78,12 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024) @@ -140,7 +95,4 @@ #define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) #define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512)
-/* Enable devicetree support */ -#define CONFIG_OF_LIBFDT - #endif /* __CONFIG_H */
This patch enables to run Universal board on device tree.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com --- Changes for v5: - changed the name of exynos_lcd_panel_init to exynos_lcd_misc_init
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-universal_c210.dts | 83 ++++++++++++ board/samsung/universal_c210/universal.c | 204 ++++++++--------------------- include/configs/s5pc210_universal.h | 152 +++++++-------------- 4 files changed, 185 insertions(+), 257 deletions(-) create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dad03cf..488aec2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,4 +1,5 @@ -dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb +dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ + exynos4210-universal_c210.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts new file mode 100644 index 0000000..1cdd981 --- /dev/null +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -0,0 +1,83 @@ +/* + * Samsung's Exynos4210 based Universal C210 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Universal C210 based on Exynos4210 rev0"; + compatible = "samsung,universal_c210", "samsung,exynos4210"; + + aliases { + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <480>; + samsung,vl-row = <800>; + samsung,vl-width = <480>; + samsung,vl-height = <800>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <2>; + samsung,vl-hbpd = <16>; + samsung,vl-hfpd = <16>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <8>; + samsung,vl-vfpd = <8>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,pclk_name = <1>; + samsung,sclk_div = <1>; + + samsung,winid = <0>; + samsung,power-on-delay = <10000>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <0>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; +}; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 96da7e0..f9d71b6 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -13,16 +13,17 @@ #include <asm/gpio.h> #include <asm/arch/adc.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> -#include <libtizen.h> #include <ld9040.h> #include <power/pmic.h> +#include <usb.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> #include <power/max8998_pmic.h> +#include <libtizen.h> #include <samsung/misc.h> +#include <usb_mass_storage.h>
@@ -42,7 +43,7 @@ static int get_hwrev(void)
static void init_pmic_lcd(void);
-int power_init_board(void) +int exynos_power_init(void) { int ret;
@@ -59,22 +60,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; -} - static unsigned short get_adc_value(int channel) { struct s5p_adc *adc = (struct s5p_adc *)samsung_get_base_adc(); @@ -159,71 +144,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tUniversal C210\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - int err; - - switch (get_hwrev()) { - case 0: - /* - * Set the low to enable LDO_EN - * But when you use the test board for eMMC booting - * you should set it HIGH since it removes the inverter - */ - /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ - s5p_gpio_direction_output(&gpio1->e3, 6, 0); - break; - default: - /* - * Default reset state is High and there's no inverter - * But set it as HIGH to ensure - */ - /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ - s5p_gpio_direction_output(&gpio1->e1, 3, 1); - break; - } - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; - -} -#endif - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -271,7 +191,20 @@ struct s3c_plat_otg_data s5pc210_otg_data = { }; #endif
-int board_early_init_f(void) +int board_usb_init(int index, enum usb_init_type init) +{ + debug("USB_udc_probe\n"); + return s3c_udc_probe(&s5pc210_otg_data); +} + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + return 0; +} +#endif + +int exynos_early_init_f(void) { wdt_stop();
@@ -412,6 +345,11 @@ void exynos_cfg_lcd_gpio(void) spi_init(); }
+int mipi_power(void) +{ + return 0; +} + void exynos_reset_lcd(void) { s5p_gpio_set_value(&gpio2->y4, 5, 1); @@ -436,39 +374,6 @@ void exynos_lcd_power_on(void) pmic_set_output(p, MAX8998_REG_ONOFF2, MAX8998_LDO7, LDO_ON); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 480, - .vl_row = 800, - .vl_width = 480, - .vl_height = 800, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_HIGH, - .vl_vsp = CONFIG_SYS_HIGH, - .vl_dp = CONFIG_SYS_HIGH, - - .vl_bpix = 4, /* Bits per pixel */ - - /* LD9040 LCD Panel */ - .vl_hspw = 2, - .vl_hbpd = 16, - .vl_hfpd = 16, - - .vl_vspw = 2, - .vl_vbpd = 8, - .vl_vfpd = 8, - .vl_cmd_allow_len = 0xf, - - .win_id = 0, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 10000, - .reset_delay = 10000, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 0, -}; - void exynos_cfg_ldo(void) { ld9040_cfg_ldo(); @@ -479,30 +384,32 @@ void exynos_enable_ldo(unsigned int onoff) ld9040_enable_ldo(onoff); }
-void init_panel_info(vidinfo_t *vid) -{ - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - setenv("lcdinfo", "lcd=ld9040"); -} - -int board_init(void) +int exynos_init(void) { gpio1 = (struct exynos4_gpio_part1 *) EXYNOS4_GPIO_PART1_BASE; gpio2 = (struct exynos4_gpio_part2 *) EXYNOS4_GPIO_PART2_BASE;
gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + switch (get_hwrev()) { + case 0: + /* + * Set the low to enable LDO_EN + * But when you use the test board for eMMC booting + * you should set it HIGH since it removes the inverter + */ + /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + s5p_gpio_direction_output(&gpio1->e3, 6, 0); + break; + default: + /* + * Default reset state is High and there's no inverter + * But set it as HIGH to ensure + */ + /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + s5p_gpio_direction_output(&gpio1->e1, 3, 1); + break; + }
#ifdef CONFIG_SOFT_SPI soft_spi_init(); @@ -513,20 +420,15 @@ int board_init(void) return 0; }
-#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) +void exynos_lcd_misc_init(vidinfo_t *vid) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); -#endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); +#ifdef CONFIG_TIZEN + get_tizen_logo_info(vid); #endif - return 0; + + /* for LD9040. */ + vid->pclk_name = 1; /* MPLL */ + vid->sclk_div = 1; + + setenv("lcdinfo", "lcd=ld9040"); } -#endif diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 67921e9..2da8871 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -7,78 +7,56 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_UNIVERSAL_H +#define __CONFIG_UNIVERSAL_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_EXYNOS4210 1 /* which is in a EXYNOS4210 */ -#define CONFIG_UNIVERSAL 1 /* working with Universal */ -#define CONFIG_TIZEN 1 /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-universal_c210
-#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_TIZEN /* TIZEN lib */
/* Keep L2 Cache Disabled */ #define CONFIG_SYS_L2CACHE_OFF 1
+/* Universal has 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 2 #define CONFIG_SYS_SDRAM_BASE 0x40000000 -#define CONFIG_SYS_TEXT_BASE 0x44800000 - -/* input clock of PLL: Universal has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE
-#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
/* select serial console configuration */ -#define CONFIG_SERIAL2 1 /* use SERIAL 2 */ -#define CONFIG_BAUDRATE 115200 - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_SDHCI -#define CONFIG_S5P_SDHCI - -/* PWM */ -#define CONFIG_PWM 1 - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH 1 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_ONENAND -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200 + +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) + +#define CONFIG_SYS_TEXT_BASE 0x44800000
#define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS @@ -106,24 +84,21 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" - #define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9"
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + #define CONFIG_ENV_UBIFS_OPTION " rootflags=bulk_read,no_chk_data_crc " #define CONFIG_ENV_FLASHBOOT CONFIG_ENV_UBI_MTD CONFIG_ENV_UBIFS_OPTION \ "${mtdparts}"
#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -187,47 +162,10 @@ "mmcrootpart=3\0" \ "opts=always_resume=1"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Universal # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* Universal has 2 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SAMSUNG_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x0C000000
-#define CONFIG_ENV_IS_IN_MMC 1 -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10)/* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION 1 - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_CACHELINE_SIZE 32 - #include <asm/arch/gpio.h> /* * I2C Settings @@ -235,6 +173,8 @@ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(1, b, 7) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(1, b, 6)
+#define CONFIG_CMD_I2C + #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ #define CONFIG_SYS_I2C_SOFT_SPEED 50000 @@ -307,8 +247,10 @@ int universal_spi_read(void); #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP #define CONFIG_LD9040 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
+#define LCD_XRES 480 +#define LCD_YRES 800 + #endif /* __CONFIG_H */
This patch enables to run Trats board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Lukasz Majewski l.majewski@samsung.com --- Changes for v5: - changed the name of exynos_lcd_panel_init to exynos_lcd_misc_init
Changes for v4: - use "-" hypen in DT bindings - define CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, CONFIG_CMD_I2C at each board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4210-trats.dts | 120 +++++++++++++++++++++ board/samsung/trats/trats.c | 213 ++------------------------------------ include/configs/trats.h | 206 ++++++++++-------------------------- 4 files changed, 185 insertions(+), 357 deletions(-) create mode 100644 arch/arm/dts/exynos4210-trats.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 488aec2..a853ec6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,5 +1,6 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ - exynos4210-universal_c210.dtb + exynos4210-universal_c210.dtb \ + exynos4210-trats.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts new file mode 100644 index 0000000..992e023 --- /dev/null +++ b/arch/arm/dts/exynos4210-trats.dts @@ -0,0 +1,120 @@ +/* + * Samsung's Exynos4210 based Trats board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats based on Exynos4210"; + compatible = "samsung,trats", "samsung,exynos4210"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <3>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e-interface = <1>; + samsung,dsim-config-e-virtual-ch = <0>; + samsung,dsim-config-e-pixel-format = <7>; + samsung,dsim-config-e-burst-mode = <1>; + samsung,dsim-config-e-no-data-lane = <3>; + samsung,dsim-config-e-byte-clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll-stable-time = <500>; + samsung,dsim-config-esc-clk = <20000000>; + samsung,dsim-config-stop-holding-cnt = <0x7ff>; + samsung,dsim-config-bta-timeout = <0xff>; + samsung,dsim-config-rx-timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus-id = <0>; + + samsung,dsim-device-reverse-panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2008002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20c6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; \ No newline at end of file diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index b725505..7c79e7b 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -12,23 +12,20 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> -#include <asm/arch/clk.h> #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> #include <power/pmic.h> #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> -#include <libtizen.h> #include <power/max8997_muic.h> #include <power/battery.h> #include <power/max17042_fg.h> +#include <libtizen.h> #include <usb.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
#include "setup.h"
@@ -46,10 +43,8 @@ u32 get_board_rev(void) static void check_hw_revision(void); struct s3c_plat_otg_data s5pc210_otg_data;
-int board_init(void) +int exynos_init(void) { - gd->bd->bi_boot_params = CONFIG_SYS_SPL_ARGS_ADDR; - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
@@ -281,7 +276,7 @@ static int pmic_init_max8997(void) return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg, ret; struct power_battery *pb; @@ -350,28 +345,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - static unsigned int get_hw_revision(void) { struct exynos4_gpio_part1 *gpio = @@ -404,55 +377,6 @@ static void check_hw_revision(void) board_rev |= hwrev; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS\n"); - return 0; -} -#endif - -#ifdef CONFIG_GENERIC_MMC -int board_mmc_init(bd_t *bis) -{ - struct exynos4_gpio_part2 *gpio = - (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int err; - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - err = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - if (err) - debug("SDMMC0 not configured\n"); - else - err = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio->x3, 4)) { - err = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err) - debug("SDMMC2 not configured\n"); - else - err = s5p_mmc_init(2, 4); - } - - return err; -} -#endif
#ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) @@ -599,38 +523,22 @@ static void board_power_init(void) writel(0, (unsigned int)&pwr->arm_core1_configuration); }
-static void board_uart_init(void) +static void exynos_uart_init(void) { - struct exynos4_gpio_part1 *gpio1 = - (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); struct exynos4_gpio_part2 *gpio2 = (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); - int i; - - /* - * UART2 GPIOs - * GPA1CON[0] = UART_2_RXD(2) - * GPA1CON[1] = UART_2_TXD(2) - * GPA1CON[2] = I2C_3_SDA (3) - * GPA1CON[3] = I2C_3_SCL (3) - */ - - for (i = 0; i < 4; i++) { - s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC((i > 1) ? 0x3 : 0x2)); - }
/* UART_SEL GPY4[7] (part2) at EXYNOS4 */ s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); s5p_gpio_direction_output(&gpio2->y4, 7, 1); }
-int board_early_init_f(void) +int exynos_early_init_f(void) { wdt_stop(); pmic_reset(); board_clock_init(); - board_uart_init(); + exynos_uart_init(); board_power_init();
return 0; @@ -648,7 +556,7 @@ void exynos_reset_lcd(void) s5p_gpio_direction_output(&gpio2->y4, 5, 1); }
-static int lcd_power(void) +int lcd_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -671,46 +579,7 @@ static int lcd_power(void) return 0; }
-static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim s6e8ax0_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&s6e8ax0_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { int ret = 0; struct pmic *p = pmic_get("MAX8997_PMIC"); @@ -733,75 +602,13 @@ static int mipi_power(void) return 0; }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .mipi_enabled = 1, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_misc_init(vidinfo_t *vid) { - vid->logo_on = 1, - vid->resolution = HD_RESOLUTION, - vid->rgb_mode = MODE_RGB_P, - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - mipi_lcd_device.reverse_panel = 1; - - strcpy(s6e8ax0_platform_data.lcd_panel_name, mipi_lcd_device.name); - s6e8ax0_platform_data.lcd_power = lcd_power; - s6e8ax0_platform_data.mipi_power = mipi_power; - s6e8ax0_platform_data.phy_enable = set_mipi_phy_ctrl; - s6e8ax0_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - exynos_set_dsim_platform_data(&s6e8ax0_platform_data); - setenv("lcdinfo", "lcd=s6e8ax0"); -} - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif diff --git a/include/configs/trats.h b/include/configs/trats.h index 7cea259..15630fb 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -7,25 +7,19 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS_H +#define __CONFIG_TRATS_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_EXYNOS4210 /* which is in a EXYNOS4210 */ -#define CONFIG_TRATS /* working with TRATS */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h> + +#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */ + +#define CONFIG_TRATS
-#include <asm/arch/cpu.h> /* get chip and board defs */ +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4210-trats
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -33,93 +27,60 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
+/* TRATS has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 #define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_TEXT_BASE 0x63300000 +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */
-/* input clock of PLL: TRATS has 24MHz input clock at EXYNOS4210 */ -#define CONFIG_SYS_CLK_FREQ_C210 24000000 -#define CONFIG_SYS_CLK_FREQ CONFIG_SYS_CLK_FREQ_C210 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000)
-/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ -#define MACH_TYPE_TRATS 3928 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS +#define CONFIG_SYS_TEXT_BASE 0x63300000
#include <linux/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ -#define CONFIG_SERIAL2 /* use SERIAL 2 */ +#define CONFIG_SERIAL2 #define CONFIG_BAUDRATE 115200
-/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA - -/* PWM */ -#define CONFIG_PWM - -/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_XIMG -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_ONENAND -#undef CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_SETEXPR - -/* FAT */ -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -#define CONFIG_BOOTDELAY 1 -#define CONFIG_ZERO_BOOTDELAY_CHECK +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ +#define MACH_TYPE_TRATS 3928 +#define CONFIG_MACH_TYPE MACH_TYPE_TRATS + #define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOTLOADER "u-boot" @@ -150,13 +111,6 @@ ""PARTS_UMS" part 0 7;" \ "params.bin mmc 0x38 0x8\0"
-#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - -#define CONFIG_ENV_VARS_UBOOT_CONFIG -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - #define CONFIG_EXTRA_ENV_SETTINGS \ "bootk=" \ "run loaduimage;" \ @@ -226,59 +180,14 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
- -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TRATS # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -/* TRATS has 4 banks of DRAM */ -#define CONFIG_NR_DRAM_BANKS 4 -#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE -#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) -#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE -#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) -#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ - -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE /* Falcon mode definitions */ #define CONFIG_CMD_SPL -#define CONFIG_SYS_SPL_ARGS_ADDR PHYS_SDRAM_1 + 0x100 +#define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
-/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS +/* I2C */ +#include <asm/arch/gpio.h>
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_CMD_I2C
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 @@ -291,12 +200,11 @@ #define CONFIG_SOFT_I2C_READ_REPEATED_START #define CONFIG_SYS_I2C_INIT_BOARD
-#include <asm/arch/gpio.h> - /* I2C FG */ #define CONFIG_SOFT_I2C_GPIO_SCL exynos4_gpio_get(2, y4, 1) #define CONFIG_SOFT_I2C_GPIO_SDA exynos4_gpio_get(2, y4, 0)
+/* POWER */ #define CONFIG_POWER #define CONFIG_POWER_I2C #define CONFIG_POWER_MAX8997 @@ -307,11 +215,6 @@ #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_POWER_BATTERY #define CONFIG_POWER_BATTERY_TRATS -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -351,10 +254,7 @@ #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
-#define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE - -/* Pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 +#define LCD_XRES 720 +#define LCD_YRES 1280
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - changed the name of exynos_lcd_panel_init to exynos_lcd_misc_init
Changes for v2: - fixed mmc2 address in DT
arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++++++++++++++++++ board/samsung/trats2/trats2.c | 233 +------------------- include/configs/trats2.h | 204 ++++------------- 4 files changed, 483 insertions(+), 391 deletions(-) create mode 100644 arch/arm/dts/exynos4412-trats2.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a853ec6..631a9be 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1,6 +1,7 @@ dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ exynos4210-universal_c210.dtb \ - exynos4210-trats.dtb + exynos4210-trats.dtb \ + exynos4412-trats2.dtb
dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts new file mode 100644 index 0000000..7d32067 --- /dev/null +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -0,0 +1,434 @@ +/* + * Samsung's Exynos4412 based Trats2 board device tree source + * + * Copyright (c) 2014 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +/include/ "exynos4.dtsi" + +/ { + model = "Samsung Trats2 based on Exynos4412"; + compatible = "samsung,trats2", "samsung,exynos4412"; + + config { + samsung,dsim-device-name = "s6e8ax0"; + }; + + aliases { + i2c0 = "/i2c@13860000"; + i2c1 = "/i2c@13870000"; + i2c2 = "/i2c@13880000"; + i2c3 = "/i2c@13890000"; + i2c4 = "/i2c@138a0000"; + i2c5 = "/i2c@138b0000"; + i2c6 = "/i2c@138c0000"; + i2c7 = "/i2c@138d0000"; + serial0 = "/serial@13800000"; + console = "/serial@13820000"; + mmc0 = "sdhci@12510000"; + mmc2 = "sdhci@12530000"; + }; + + i2c@138d0000 { + samsung,i2c-sda-delay = <100>; + samsung,i2c-slave-addr = <0x10>; + samsung,i2c-max-bus-freq = <100000>; + status = "okay"; + + max77686_pmic@09 { + compatible = "maxim,max77686_pmic"; + interrupts = <7 0>; + reg = <0x09 0 0>; + #clock-cells = <1>; + + voltage-regulators { + ldo1_reg: ldo1 { + regulator-compatible = "LDO1"; + regulator-name = "VALIVE_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo2_reg: ldo2 { + regulator-compatible = "LDO2"; + regulator-name = "VM1M2_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo3_reg: ldo3 { + regulator-compatible = "LDO3"; + regulator-name = "VCC_1.8V_AP"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo4_reg: ldo4 { + regulator-compatible = "LDO4"; + regulator-name = "VCC_2.8V_AP"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo5_reg: ldo5 { + regulator-compatible = "LDO5"; + regulator-name = "VCC_1.8V_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo6_reg: ldo6 { + regulator-compatible = "LDO6"; + regulator-name = "VMPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo7_reg: ldo7 { + regulator-compatible = "LDO7"; + regulator-name = "VPLL_1.0V_AP"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-mem-on; + }; + + ldo8_reg: ldo8 { + regulator-compatible = "LDO8"; + regulator-name = "VMIPI_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo9_reg: ldo9 { + regulator-compatible = "LDO9"; + regulator-name = "CAM_ISP_MIPI_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo10_reg: ldo10 { + regulator-compatible = "LDO10"; + regulator-name = "VMIPI_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo11_reg: ldo11 { + regulator-compatible = "LDO11"; + regulator-name = "VABB1_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo12_reg: ldo12 { + regulator-compatible = "LDO12"; + regulator-name = "VUOTG_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-off; + }; + + ldo13_reg: ldo13 { + regulator-compatible = "LDO13"; + regulator-name = "NFC_AVDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo14_reg: ldo14 { + regulator-compatible = "LDO14"; + regulator-name = "VABB2_1.95V"; + regulator-min-microvolt = <1950000>; + regulator-max-microvolt = <1950000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo15_reg: ldo15 { + regulator-compatible = "LDO15"; + regulator-name = "VHSIC_1.0V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-mem-off; + }; + + ldo16_reg: ldo16 { + regulator-compatible = "LDO16"; + regulator-name = "VHSIC_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-off; + }; + + ldo17_reg: ldo17 { + regulator-compatible = "LDO17"; + regulator-name = "CAM_SENSOR_CORE_1.2V"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-mem-idle; + }; + + ldo18_reg: ldo18 { + regulator-compatible = "LDO18"; + regulator-name = "CAM_ISP_SEN_IO_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo19_reg: ldo19 { + regulator-compatible = "LDO19"; + regulator-name = "VT_CAM_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo20_reg: ldo20 { + regulator-compatible = "LDO20"; + regulator-name = "VDDQ_PRE_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo21_reg: ldo21 { + regulator-compatible = "LDO21"; + regulator-name = "VTF_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo22_reg: ldo22 { + regulator-compatible = "LDO22"; + regulator-name = "VMEM_VDD_2.8V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + regulator-mem-off; + }; + + ldo23_reg: ldo23 { + regulator-compatible = "LDO23"; + regulator-name = "TSP_AVDD_3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-mem-idle; + }; + + ldo24_reg: ldo24 { + regulator-compatible = "LDO24"; + regulator-name = "TSP_VDD_1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-mem-idle; + }; + + ldo25_reg: ldo25 { + regulator-compatible = "LDO25"; + regulator-name = "LCD_VCC_3.3V"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-mem-idle; + }; + + ldo26_reg: ldo26 { + regulator-compatible = "LDO26"; + regulator-name = "MOTOR_VCC_3.0V"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-mem-idle; + }; + + buck1_reg: buck1 { + regulator-compatible = "BUCK1"; + regulator-name = "vdd_mif"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck2_reg: buck2 { + regulator-compatible = "BUCK2"; + regulator-name = "vdd_arm"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck3_reg: buck3 { + regulator-compatible = "BUCK3"; + regulator-name = "vdd_int"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + regulator-mem-off; + }; + + buck4_reg: buck4 { + regulator-compatible = "BUCK4"; + regulator-name = "vdd_g3d"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-mem-off; + }; + + buck5_reg: buck5 { + regulator-compatible = "BUCK5"; + regulator-name = "VMEM_1.2V_AP"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + buck6_reg: buck6 { + regulator-compatible = "BUCK6"; + regulator-name = "VCC_SUB_1.35V"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + }; + + buck7_reg: buck7 { + regulator-compatible = "BUCK7"; + regulator-name = "VCC_SUB_2.0V"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + buck8_reg: buck8 { + regulator-compatible = "BUCK8"; + regulator-name = "VMEM_VDDF_3.0V"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + regulator-mem-off; + }; + + buck9_reg: buck9 { + regulator-compatible = "BUCK9"; + regulator-name = "CAM_ISP_CORE_1.2V"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; + regulator-mem-off; + }; + }; + }; + }; + + fimd@11c00000 { + compatible = "samsung,exynos-fimd"; + reg = <0x11c00000 0xa4>; + + samsung,vl-freq = <60>; + samsung,vl-col = <720>; + samsung,vl-row = <1280>; + samsung,vl-width = <720>; + samsung,vl-height = <1280>; + + samsung,vl-clkp = <0>; + samsung,vl-oep = <0>; + samsung,vl-hsp = <1>; + samsung,vl-vsp = <1>; + samsung,vl-dp = <1>; + samsung,vl-bpix = <4>; + + samsung,vl-hspw = <5>; + samsung,vl-hbpd = <10>; + samsung,vl-hfpd = <10>; + samsung,vl-vspw = <2>; + samsung,vl-vbpd = <1>; + samsung,vl-vfpd = <13>; + samsung,vl-cmd-allow-len = <0xf>; + + samsung,winid = <0>; + samsung,power-on-delay = <30>; + samsung,interface-mode = <1>; + samsung,mipi-enabled = <1>; + samsung,dp-enabled; + samsung,dual-lcd-enabled; + + samsung,logo-on = <1>; + samsung,resolution = <0>; + samsung,rgb-mode = <0>; + }; + + mipidsi@11c80000 { + compatible = "samsung,exynos-mipi-dsi"; + reg = <0x11c80000 0x5c>; + + samsung,dsim-config-e-interface = <1>; + samsung,dsim-config-e-virtual-ch = <0>; + samsung,dsim-config-e-pixel-format = <7>; + samsung,dsim-config-e-burst-mode = <1>; + samsung,dsim-config-e-no-data-lane = <3>; + samsung,dsim-config-e-byte-clk = <0>; + samsung,dsim-config-hfp = <1>; + + samsung,dsim-config-p = <3>; + samsung,dsim-config-m = <120>; + samsung,dsim-config-s = <1>; + + samsung,dsim-config-pll-stable-time = <500>; + samsung,dsim-config-esc-clk = <20000000>; + samsung,dsim-config-stop-holding-cnt = <0x7ff>; + samsung,dsim-config-bta-timeout = <0xff>; + samsung,dsim-config-rx-timeout = <0xffff>; + + samsung,dsim-device-id = <0xffffffff>; + samsung,dsim-device-bus-id = <0>; + + samsung,dsim-device-reverse-panel = <1>; + }; + + sdhci@12510000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpio 0x2004002 0>; + }; + + sdhci@12520000 { + status = "disabled"; + }; + + sdhci@12530000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpio 0x20C6004 0>; + }; + + sdhci@12540000 { + status = "disabled"; + }; +}; diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index c17c24d..2a6c9f9 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,15 +8,9 @@
#include <common.h> #include <lcd.h> -#include <asm/io.h> -#include <asm/arch/gpio.h> -#include <asm/arch/mmc.h> -#include <asm/arch/power.h> -#include <asm/arch/clk.h> -#include <asm/arch/clock.h> -#include <asm/arch/mipi_dsim.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> +#include <asm/arch/mipi_dsim.h> #include <power/pmic.h> #include <power/max77686_pmic.h> #include <power/battery.h> @@ -28,7 +22,6 @@ #include <usb.h> #include <usb/s3c_udc.h> #include <usb_mass_storage.h> -#include <samsung/misc.h>
@@ -69,16 +62,6 @@ static void check_hw_revision(void) board_rev = modelrev << 8; }
-#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - puts("Board:\tTRATS2\n"); - printf("HW Revision:\t0x%04x\n", board_rev); - - return 0; -} -#endif - u32 get_board_rev(void) { return board_rev; @@ -156,33 +139,24 @@ int get_soft_i2c_sda_pin(void) } #endif
-int board_early_init_f(void) +int exynos_early_init_f(void) { - check_hw_revision(); board_external_gpio_init();
- gd->flags |= GD_FLG_DISABLE_CONSOLE; - return 0; }
static int pmic_init_max77686(void);
-int board_init(void) +int exynos_init(void) { - struct exynos4_power *pwr = - (struct exynos4_power *)samsung_get_base_power(); - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - /* workaround: clear INFORM4..5 */ - writel(0, (unsigned int)&pwr->inform4); - writel(0, (unsigned int)&pwr->inform5); + check_hw_revision(); + printf("HW Revision:\t0x%04x\n", board_rev);
return 0; }
-int power_init_board(void) +int exynos_power_init(void) { int chrg; struct power_battery *pb; @@ -248,90 +222,6 @@ int power_init_board(void) return 0; }
-int dram_init(void) -{ - u32 size_mb; - - size_mb = (get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + - get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + - get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE)) >> 20; - - gd->ram_size = size_mb << 20; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - gd->bd->bi_dram[2].start = PHYS_SDRAM_3; - gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; - gd->bd->bi_dram[3].start = PHYS_SDRAM_4; - gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; -} - -int board_mmc_init(bd_t *bis) -{ - int err0, err2 = 0; - - gpio2 = (struct exynos4x12_gpio_part2 *)samsung_get_base_gpio_part2(); - - /* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ - s5p_gpio_direction_output(&gpio2->k0, 2, 1); - s5p_gpio_set_pull(&gpio2->k0, 2, GPIO_PULL_NONE); - - /* - * eMMC GPIO: - * SDR 8-bit@48MHz at MMC0 - * GPK0[0] SD_0_CLK(2) - * GPK0[1] SD_0_CMD(2) - * GPK0[2] SD_0_CDn -> Not used - * GPK0[3:6] SD_0_DATA[0:3](2) - * GPK1[3:6] SD_0_DATA[0:3](3) - * - * DDR 4-bit@26MHz at MMC4 - * GPK0[0] SD_4_CLK(3) - * GPK0[1] SD_4_CMD(3) - * GPK0[2] SD_4_CDn -> Not used - * GPK0[3:6] SD_4_DATA[0:3](3) - * GPK1[3:6] SD_4_DATA[4:7](4) - */ - - err0 = exynos_pinmux_config(PERIPH_ID_SDMMC0, PINMUX_FLAG_8BIT_MODE); - - /* - * MMC device init - * mmc0 : eMMC (8-bit buswidth) - * mmc2 : SD card (4-bit buswidth) - */ - if (err0) - debug("SDMMC0 not configured\n"); - else - err0 = s5p_mmc_init(0, 8); - - /* T-flash detect */ - s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); - - /* - * Check the T-flash detect pin - * GPX3[4] T-flash detect pin - */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { - err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); - if (err2) - debug("SDMMC2 not configured\n"); - else - err2 = s5p_mmc_init(2, 4); - } - - return err0 & err2; -} - #ifdef CONFIG_USB_GADGET static int s5pc210_phy_control(int on) { @@ -479,46 +369,7 @@ static int pmic_init_max77686(void) */
#ifdef CONFIG_LCD -static struct mipi_dsim_config dsim_config = { - .e_interface = DSIM_VIDEO, - .e_virtual_ch = DSIM_VIRTUAL_CH_0, - .e_pixel_format = DSIM_24BPP_888, - .e_burst_mode = DSIM_BURST_SYNC_EVENT, - .e_no_data_lane = DSIM_DATA_LANE_4, - .e_byte_clk = DSIM_PLL_OUT_DIV8, - .hfp = 1, - - .p = 3, - .m = 120, - .s = 1, - - /* D-PHY PLL stable time spec :min = 200usec ~ max 400usec */ - .pll_stable_time = 500, - - /* escape clk : 10MHz */ - .esc_clk = 20 * 1000000, - - /* stop state holding counter after bta change count 0 ~ 0xfff */ - .stop_holding_cnt = 0x7ff, - /* bta timeout 0 ~ 0xff */ - .bta_timeout = 0xff, - /* lp rx timeout 0 ~ 0xffff */ - .rx_timeout = 0xffff, -}; - -static struct exynos_platform_mipi_dsim dsim_platform_data = { - .lcd_panel_info = NULL, - .dsim_config = &dsim_config, -}; - -static struct mipi_dsim_lcd_device mipi_lcd_device = { - .name = "s6e8ax0", - .id = -1, - .bus_id = 0, - .platform_data = (void *)&dsim_platform_data, -}; - -static int mipi_power(void) +int mipi_power(void) { struct pmic *p = pmic_get("MAX77686_PMIC");
@@ -556,77 +407,13 @@ void exynos_reset_lcd(void) s5p_gpio_set_value(&gpio1->f2, 1, 1); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 720, - .vl_row = 1280, - .vl_width = 720, - .vl_height = 1280, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* Bits per pixel, 2^4 = 16 */ - - /* s6e8ax0 Panel infomation */ - .vl_hspw = 5, - .vl_hbpd = 10, - .vl_hfpd = 10, - - .vl_vspw = 2, - .vl_vbpd = 1, - .vl_vfpd = 13, - .vl_cmd_allow_len = 0xf, - .mipi_enabled = 1, - - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 25, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_misc_init(vidinfo_t *vid) { - vid->logo_on = 1; - vid->resolution = HD_RESOLUTION; - vid->rgb_mode = MODE_RGB_P; - - vid->power_on_delay = 30; - - mipi_lcd_device.reverse_panel = 1; - #ifdef CONFIG_TIZEN get_tizen_logo_info(vid); #endif - - strcpy(dsim_platform_data.lcd_panel_name, mipi_lcd_device.name); - dsim_platform_data.mipi_power = mipi_power; - dsim_platform_data.phy_enable = set_mipi_phy_ctrl; - dsim_platform_data.lcd_panel_info = (void *)vid; - exynos_mipi_dsi_register_lcd_device(&mipi_lcd_device); - +#ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - - exynos_set_dsim_platform_data(&dsim_platform_data); -} -#endif /* LCD */ - -#ifdef CONFIG_MISC_INIT_R -int misc_init_r(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - set_board_info(); -#endif -#ifdef CONFIG_LCD_MENU - keys_init(); - check_boot_mode(); #endif -#ifdef CONFIG_CMD_BMP - if (panel_info.logo_on) - draw_logo(); -#endif - return 0; } -#endif +#endif /* LCD */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 6d389df..8194575 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -8,27 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_TRATS2_H +#define __CONFIG_TRATS2_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* which is in a S5P Family */ -#define CONFIG_EXYNOS4 /* which is in a EXYNOS4XXX */ -#define CONFIG_TIZEN /* TIZEN lib */ +#include <configs/exynos4-dt.h>
-#include <asm/arch/cpu.h> /* get chip and board defs */ - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */
-#define CONFIG_SKIP_LOWLEVEL_INIT +#undef CONFIG_DEFAULT_DEVICE_TREE +#define CONFIG_DEFAULT_DEVICE_TREE exynos4412-trats2
-#define CONFIG_SYS_CACHELINE_SIZE 32 +#define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF @@ -36,121 +26,47 @@ #define CONFIG_SYS_PL310_BASE 0x10502000 #endif
-#define CONFIG_NR_DRAM_BANKS 4 -#define PHYS_SDRAM_1 0x40000000 /* LDDDR2 DMC 0 */ -#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_2 0x50000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_2_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_3 0x60000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_3_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_4 0x70000000 /* LPDDR2 DMC 1 */ -#define PHYS_SDRAM_4_SIZE (256 << 20) /* 256 MB in CS 0 */ -#define PHYS_SDRAM_END 0x80000000 - -#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ +/* TRATS2 has 4 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define SDRAM_BANK_SIZE (256 << 20) /* 256 MB */ +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) #define CONFIG_SYS_TEXT_BASE 0x78100000
-#define CONFIG_SYS_CLK_FREQ 24000000 - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_REVISION_TAG - -/* MACH_TYPE_TRATS2 */ -#define MACH_TYPE_TRATS2 3765 -#define CONFIG_MACH_TYPE MACH_TYPE_TRATS2 - -#define CONFIG_DISPLAY_CPUINFO - #include <linux/sizes.h> /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (80 * SZ_1M))
/* select serial console configuration */ #define CONFIG_SERIAL2 +#define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +/* Console configuration */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMDLINE_EDITING +#define CONFIG_BOOTARGS "Please use defined boot" +#define CONFIG_BOOTCOMMAND "run mmcboot" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ + - GENERATED_GBL_DATA_SIZE)
-/* It should define before config_cmd_default.h */ -#define CONFIG_SYS_NO_FLASH - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ECHO -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NAND -#undef CONFIG_CMD_MISC -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_SOURCE -#undef CONFIG_CMD_XIMG -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MMC -#define CONFIG_CMD_DFU -#define CONFIG_CMD_GPT -#define CONFIG_CMD_PMIC - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE - -/* EXT4 */ -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE - -/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M -#define DFU_DEFAULT_POLL_TIMEOUT 300 -#define CONFIG_DFU_FUNCTION -#define CONFIG_DFU_MMC - -/* TIZEN THOR downloader support */ -#define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION - -/* USB Samsung's IDs */ -#define CONFIG_G_DNL_VENDOR_NUM 0x04E8 -#define CONFIG_G_DNL_PRODUCT_NUM 0x6601 -#define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM -#define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_G_DNL_MANUFACTURER "Samsung" - -/* To use the TFTPBOOT over USB, Please enable the CONFIG_CMD_NET */ -#undef CONFIG_CMD_NET - -/* MMC */ -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_S5P_SDHCI -#define CONFIG_SDHCI -#define CONFIG_MMC_SDMA -#define CONFIG_MMC_DEFAULT_DEV 0 - -/* PWM */ -#define CONFIG_PWM - -#define CONFIG_BOOTARGS "Please use defined boot" -#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV +#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG @@ -246,49 +162,11 @@ "setenv spl_addr_tmp;\0" \ "fdtaddr=40800000\0" \
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5000000) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4800000) - -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - - GENERATED_GBL_DATA_SIZE) - -/* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 -#define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS - -#define CONFIG_BOARD_EARLY_INIT_F - /* I2C */ #include <asm/arch/gpio.h>
+#define CONFIG_CMD_I2C + #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 @@ -318,11 +196,6 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_POWER_MUIC_MAX77693 #define CONFIG_POWER_FG_MAX77693 #define CONFIG_POWER_BATTERY_TRATS2 -#define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_S3C_UDC_OTG -#define CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_GADGET_VBUS_DRAW 2 -#define CONFIG_USB_CABLE_CHECK
/* Common misc for Samsung */ #define CONFIG_MISC_COMMON @@ -362,10 +235,7 @@ int get_soft_i2c_sda_pin(void); #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
On 07/03/14 22:59, Piotr Wilczek wrote:
This patch set enables support for device tree on all Exynos4 based boards.
DT support is enabled on Exynos mipi dsim and sdhci drives. Common board.c file is reused for all functions common for Exynos4 boards. Board specific files are implemented in the board files. Origen, Universal, Trats and Trats2 boards are modifed to support device tree.
This patch series depends on: [U-Boot] sizes.h - consolidate for all architectures http://patchwork.ozlabs.org/patch/324427/
Changes for v5:
- add exynos_mipi_dsi.txt file with documented bindings
- removed unused panel_info.resolution binding
Changes for v4:
- remove duplicated DT properties at exynos_fb.c file
Changes for v3:
- moved max77686 init function to smdk5250 board file
- board DTS files moved to arch/arm/dts
- rebased on the latest tree
Changes for v2:
- removed incorrectly implemented check for invalid peripheral id
- removed unnecesary white space
- removed panel specific init function 's6e8ax0_init' to the board file
- removed duplicate DTB node parsing for panel_info.logo_on
- added (weak) exynos_lcd_panel_init function for panel specific initialisation from board file
- fixed checking for SDMMC boundary
- fiex debug message
- fixed comment to 'pwr_gpio' struct filed
- new patch to move checkboard to common file
- reuse existing common board.c file
- new patch that removes unused max77686_init function
- fixed mmc2 addres in DT on Trats2
Piotr Wilczek (12): exynos4:pinmux:fdt: decode peripheral id video:mipidsim:fdt: Add DT support for mipi dsim driver video:exynos_fb:fdt: add additional fdt data drivers:mmc:sdhci: enable support for DT board:samsung: move checkboard to common file arm:exynos: add common DTS file for exynos 4 board:samsung:common: move max77686 init function arm:exynos: enable sdhci and misc_init to common board board:origen: Enable device tree on Origen board:universal: Enable device tree on Universal board:trats: Enable device tree on Trats board:trats2: Enable device tree on Trats2
arch/arm/cpu/armv7/exynos/pinmux.c | 17 + arch/arm/dts/Makefile | 5 + arch/arm/dts/exynos4.dtsi | 138 +++++++ arch/arm/dts/exynos4210-origen.dts | 45 +++ arch/arm/dts/exynos4210-trats.dts | 120 ++++++ arch/arm/dts/exynos4210-universal_c210.dts | 83 ++++ arch/arm/dts/exynos4412-trats2.dts | 434 +++++++++++++++++++++ arch/arm/include/asm/arch-exynos/board.h | 12 + arch/arm/include/asm/arch-exynos/mipi_dsim.h | 5 + arch/arm/include/asm/arch-exynos/mmc.h | 7 + board/samsung/common/board.c | 180 +++------ board/samsung/origen/origen.c | 112 +----- board/samsung/smdk5250/exynos5-dt.c | 15 - board/samsung/smdk5250/smdk5250.c | 125 ++++++ board/samsung/smdk5420/smdk5420.c | 15 - board/samsung/trats/trats.c | 213 +--------- board/samsung/trats2/trats2.c | 233 +---------- board/samsung/universal_c210/universal.c | 204 +++------- doc/device-tree-bindings/video/exynos_mipi_dsi.txt | 82 ++++ drivers/mmc/s5p_sdhci.c | 129 ++++++ drivers/video/exynos_fb.c | 12 + drivers/video/exynos_mipi_dsi.c | 96 +++++ include/configs/exynos4-dt.h | 138 +++++++ include/configs/origen.h | 110 ++---- include/configs/s5pc210_universal.h | 152 +++----- include/configs/trats.h | 206 +++------- include/configs/trats2.h | 204 ++-------- include/fdtdec.h | 2 + include/sdhci.h | 5 + lib/fdtdec.c | 2 + 30 files changed, 1765 insertions(+), 1336 deletions(-) create mode 100644 arch/arm/dts/exynos4.dtsi create mode 100644 arch/arm/dts/exynos4210-origen.dts create mode 100644 arch/arm/dts/exynos4210-trats.dts create mode 100644 arch/arm/dts/exynos4210-universal_c210.dts create mode 100644 arch/arm/dts/exynos4412-trats2.dts create mode 100644 doc/device-tree-bindings/video/exynos_mipi_dsi.txt create mode 100644 include/configs/exynos4-dt.h
applied to u-boot-samsung.
Thanks, Minkyu Kang.
participants (6)
Ajay kumar
Jaehoon Chung
Minkyu Kang
Piotr Wilczek
Przemyslaw Marczak
Rajeshwari Birje
