[U-Boot] [PATCH v2] armv7m: Fix larger builds
The branch instruction only has an 11-bit relative target address, which is sometimes not enough.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- v2: - Use W(b) instead of ldr+mov. Using this macro requires CONFIG_ARM_ASM_UNIFIED and CONFIG_THUMB2_KERNEL to be defined. --- arch/arm/cpu/armv7m/Makefile | 3 +++ arch/arm/cpu/armv7m/start.S | 4 +++- 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile index 257fc7f..df1fc95 100644 --- a/arch/arm/cpu/armv7m/Makefile +++ b/arch/arm/cpu/armv7m/Makefile @@ -8,3 +8,6 @@ extra-y := start.o obj-y += cpu.o cache.o mpu.o obj-$(CONFIG_SYS_ARCH_TIMER) += systick-timer.o + +asflags-y += -DCONFIG_ARM_ASM_UNIFIED +asflags-y += -DCONFIG_THUMB2_KERNEL diff --git a/arch/arm/cpu/armv7m/start.S b/arch/arm/cpu/armv7m/start.S index 49f2720..890c773 100644 --- a/arch/arm/cpu/armv7m/start.S +++ b/arch/arm/cpu/armv7m/start.S @@ -5,10 +5,12 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <asm/assembler.h> + .globl reset .type reset, %function reset: - b _main + W(b) _main
.globl c_runtime_cpu_setup c_runtime_cpu_setup:
Reviewed-by: Vikas Manocha vikas.manocha@st.com
Cheers, Vikas
v2:
- b _main
- W(b) _main
.globl c_runtime_cpu_setup c_runtime_cpu_setup: -- 2.7.4
v2:
Lets move these two symbols to Kconfig and select them on CPU_V7M, thanks!
Hi Tom,
v2:
defined.
+asflags-y += -DCONFIG_ARM_ASM_UNIFIED asflags-y += +-DCONFIG_THUMB2_KERNEL
These two symbols come from Linux asm files that have been simply copied over to U-Boot, they are not configuration options in U-Boot. They are used by both CPU_V7M and others.
Perhaps I have misunderstood, but for non-CPU_V7M, since CONFIG_THUMB2_KERNEL depends on CONFIG_SYS_THUMB_BUILD, are you asking me to add Kconfig for CONFIG_SYS_THUMB_BUILD?
Thanks Phil
-- Tom
On Wed, May 31, 2017 at 02:24:13PM +0000, Phil Edworthy wrote:
Hi Tom,
v2:
defined.
No, I'm saying that CONFIG_ARM_ASM_UNIFIED and CONFIG_THUMB2_KERNEL need to get moved to arch/arm/Kconfig and select'd by CPU_V7M, with a comment about how we need these for compatibility with files we copy from the Linux kernel. Then they will be defined automatically.
Phil Edworthy
Vikas MANOCHA
