[PATCH v2 0/6] Enable QCOM QCS9100 Ride platform support
The following patch series enables support for QCOM QCS9100 based Ride platform. The QCS9100 SoC is a derivative of SA8775p and hence this series makes use of the SA8775p related code to enable the QCS9100 based Ride platform support.
Use 'make qcs9100_defconfig' to generate '.config'.
--- v2: * Added reviewed-by tags to some of the patches * Add separate patch to bring QCS9100 DT files from Linux * Dropped 'arch/arm/dts/sa8775p-*.dtsi' from first patch and use qcs9100 DT files instead * Added one more range to memory definition * Updated commit log to include linux version from where headers were taken
--- Tengfei Fan (1): arm64: dts: qcom: qcs9100: Add support for the QCS9100 Ride and Ride Rev3 boards
Varadarajan Narayanan (5): dts: qcs9100-ride-r3-u-boot: add override dtsi clk/qcom: add initial clock driver for qcs9100 phy: qcom: Add SA8775 to QMP UFS PHY driver qcom_defconfig: enable SA8775P clock driver configs: add qcs9100_defconfig
arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi | 20 ++ configs/qcom_defconfig | 1 + configs/qcs9100_defconfig | 24 ++ drivers/clk/qcom/Kconfig | 8 + drivers/clk/qcom/Makefile | 1 + drivers/clk/qcom/clock-sa8775p.c | 142 +++++++++++ .../phy/qcom/phy-qcom-qmp-qserdes-com-v5.h | 124 ++++++++++ .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h | 231 ++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp-ufs.c | 171 +++++++++++++ .../src/arm64/qcom/qcs9100-ride-r3.dts | 11 + dts/upstream/src/arm64/qcom/qcs9100-ride.dts | 11 + 11 files changed, 744 insertions(+) create mode 100644 arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi create mode 100644 configs/qcs9100_defconfig create mode 100644 drivers/clk/qcom/clock-sa8775p.c create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride.dts
base-commit: 3bfd12008bef1a8353e7ceaca2cb06cf388527ed
Add device tree support for the QCS9100 Ride and Ride Rev3 boards. The QCS9100 is a variant of the SA8775p, and they are fully compatible with each other. The QCS9100 Ride/Ride Rev3 board is essentially the same as the SA8775p Ride/Ride Rev3 board, with the QCS9100 SoC mounted instead of the SA8775p.
Signed-off-by: Tengfei Fan quic_tengfan@quicinc.com Reviewed-by: Konrad Dybcio konradybcio@kernel.org Link: https://lore.kernel.org/r/20240911-add_qcs9100_support-v2-4-e43a71ceb017@qui... Signed-off-by: Bjorn Andersson andersson@kernel.org
[ upstream commit: 7dcc1dfaa3d1cd3aafed2beb7086ed34fdb22303 ]
(cherry picked from commit db6231faa8ef46e5ff5d5ece0c930a07c6358562) --- dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts | 11 +++++++++++ dts/upstream/src/arm64/qcom/qcs9100-ride.dts | 11 +++++++++++ 2 files changed, 22 insertions(+) create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride.dts
diff --git a/dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts b/dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts new file mode 100644 index 00000000000..759d1ec694b --- /dev/null +++ b/dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2024, Qualcomm Innovation Center, Inc. All rights reserved. + */ +/dts-v1/; + +#include "sa8775p-ride-r3.dts" +/ { + model = "Qualcomm QCS9100 Ride Rev3"; + compatible = "qcom,qcs9100-ride-r3", "qcom,qcs9100", "qcom,sa8775p"; +}; diff --git a/dts/upstream/src/arm64/qcom/qcs9100-ride.dts b/dts/upstream/src/arm64/qcom/qcs9100-ride.dts new file mode 100644 index 00000000000..979462dfec3 --- /dev/null +++ b/dts/upstream/src/arm64/qcom/qcs9100-ride.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2024, Qualcomm Innovation Center, Inc. All rights reserved. + */ +/dts-v1/; + +#include "sa8775p-ride.dts" +/ { + model = "Qualcomm QCS9100 Ride"; + compatible = "qcom,qcs9100-ride", "qcom,qcs9100", "qcom,sa8775p"; +};
On Thu, 9 Jan 2025 at 10:56, Varadarajan Narayanan quic_varada@quicinc.com wrote:
Reviewed-by: Sumit Garg sumit.garg@linaro.org
-Sumit
- Copyright (c) 2024, Qualcomm Innovation Center, Inc. All rights reserved.
+/dts-v1/;
+/dts-v1/;
2.34.1
Add initial support for the QCS9100 (derived from SA8775p) Ride platforms. Define memory layout statically.
Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- v2: Add one more range to memory definition Fix couple of uppercase hex digits Drop arch/arm/dts/sa8775p-*.dtsi and use qcs9100 files --- arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+) create mode 100644 arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi
diff --git a/arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi b/arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi new file mode 100644 index 00000000000..5905dfad18f --- /dev/null +++ b/arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: BSD-3-Clause +/* + * Copyright (c) 2025, Qualcomm Innovation Center, Inc. All rights reserved. + */ + +/ { + /* Will be removed when bootloader updates later */ + memory@80000000 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x3ee00000>, + <0x0 0xc0000000 0x0 0x04d00000>, + <0xd 0x00000000 0x2 0x54100000>, + <0xa 0x80000000 0x1 0x52d00000>, + <0x9 0x00000000 0x1 0x80000000>, + <0x1 0x00000000 0x2 0xf7500000>, + <0x0 0xd0000000 0x0 0x00100000>, + <0x0 0xd3500000 0x0 0x07c00000>, + <0x0 0xdb300000 0x0 0x24d00000>; + }; +};
Add initial set of clocks and resets for enabling U-Boot on QCS9100 based Ride platforms.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- v2: Add 'Reviewed-by: Neil Armstrong' --- drivers/clk/qcom/Kconfig | 8 ++ drivers/clk/qcom/Makefile | 1 + drivers/clk/qcom/clock-sa8775p.c | 142 +++++++++++++++++++++++++++++++ 3 files changed, 151 insertions(+) create mode 100644 drivers/clk/qcom/clock-sa8775p.c
diff --git a/drivers/clk/qcom/Kconfig b/drivers/clk/qcom/Kconfig index d76fca5dba4..ad5797ab85e 100644 --- a/drivers/clk/qcom/Kconfig +++ b/drivers/clk/qcom/Kconfig @@ -103,6 +103,14 @@ config CLK_QCOM_SC7280 on the Snapdragon SC7280 SoC. This driver supports the clocks and resets exposed by the GCC hardware block.
+config CLK_QCOM_SA8775P + bool "Qualcomm SA8775 GCC" + select CLK_QCOM + help + Say Y here to enable support for the Global Clock Controller + on the Snapdragon SA8775 SoC. This driver supports the clocks + and resets exposed by the GCC hardware block. + endmenu
endif diff --git a/drivers/clk/qcom/Makefile b/drivers/clk/qcom/Makefile index ab33f1c5faf..01b541af329 100644 --- a/drivers/clk/qcom/Makefile +++ b/drivers/clk/qcom/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_CLK_QCOM_SM8150) += clock-sm8150.o obj-$(CONFIG_CLK_QCOM_SM8250) += clock-sm8250.o obj-$(CONFIG_CLK_QCOM_SM8550) += clock-sm8550.o obj-$(CONFIG_CLK_QCOM_SM8650) += clock-sm8650.o +obj-$(CONFIG_CLK_QCOM_SA8775P) += clock-sa8775p.o diff --git a/drivers/clk/qcom/clock-sa8775p.c b/drivers/clk/qcom/clock-sa8775p.c new file mode 100644 index 00000000000..e31f24ed4f0 --- /dev/null +++ b/drivers/clk/qcom/clock-sa8775p.c @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Clock drivers for Qualcomm sa8775p + * + * (C) Copyright 2024 Linaro Ltd. + */ + +#include <linux/types.h> +#include <clk-uclass.h> +#include <dm.h> +#include <linux/delay.h> +#include <asm/io.h> +#include <linux/bug.h> +#include <linux/bitops.h> +#include <dt-bindings/clock/qcom,sa8775p-gcc.h> +#include "clock-qcom.h" + +#define USB30_PRIM_MOCK_UTMI_CLK_CMD_RCGR 0xf038 +#define USB30_PRIM_MASTER_CLK_CMD_RCGR 0xf020 + +static ulong sa8775p_set_rate(struct clk *clk, ulong rate) +{ + struct msm_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id < priv->data->num_clks) + debug("%s: %s, requested rate=%ld\n", __func__, + priv->data->clks[clk->id].name, rate); + + switch (clk->id) { + case GCC_USB30_PRIM_MOCK_UTMI_CLK: + WARN(rate != 19200000, "Unexpected rate for USB30_PRIM_MOCK_UTMI_CLK: %lu\n", rate); + clk_rcg_set_rate(priv->base, USB30_PRIM_MOCK_UTMI_CLK_CMD_RCGR, 0, CFG_CLK_SRC_CXO); + return rate; + case GCC_USB30_PRIM_MASTER_CLK: + WARN(rate != 200000000, "Unexpected rate for USB30_PRIM_MASTER_CLK: %lu\n", rate); + clk_rcg_set_rate_mnd(priv->base, USB30_PRIM_MASTER_CLK_CMD_RCGR, + 1, 0, 0, CFG_CLK_SRC_GPLL0_ODD, 8); + clk_rcg_set_rate(priv->base, 0xf064, 0, 0); + return rate; + default: + return 0; + } +} + +static const struct gate_clk sa8775p_clks[] = { + GATE_CLK(GCC_CFG_NOC_USB3_PRIM_AXI_CLK, 0x1b088, 1), + GATE_CLK(GCC_USB30_PRIM_MASTER_CLK, 0x1b018, 1), + GATE_CLK(GCC_AGGRE_USB3_PRIM_AXI_CLK, 0x1b084, 1), + GATE_CLK(GCC_USB30_PRIM_SLEEP_CLK, 0x1b020, 1), + GATE_CLK(GCC_USB30_PRIM_MOCK_UTMI_CLK, 0x1b024, 1), + GATE_CLK(GCC_USB3_PRIM_PHY_AUX_CLK, 0x1b05c, 1), + GATE_CLK(GCC_USB3_PRIM_PHY_COM_AUX_CLK, 0x1b060, 1), +}; + +static int sa8775p_enable(struct clk *clk) +{ + struct msm_clk_priv *priv = dev_get_priv(clk->dev); + + if (priv->data->num_clks < clk->id) { + debug("%s: unknown clk id %lu\n", __func__, clk->id); + return 0; + } + + debug("%s: clk %ld: %s\n", __func__, clk->id, sa8775p_clks[clk->id].name); + + switch (clk->id) { + case GCC_AGGRE_USB3_PRIM_AXI_CLK: + qcom_gate_clk_en(priv, GCC_USB30_PRIM_MASTER_CLK); + fallthrough; + case GCC_USB30_PRIM_MASTER_CLK: + qcom_gate_clk_en(priv, GCC_USB3_PRIM_PHY_AUX_CLK); + qcom_gate_clk_en(priv, GCC_USB3_PRIM_PHY_COM_AUX_CLK); + break; + } + + qcom_gate_clk_en(priv, clk->id); + + return 0; +} + +static const struct qcom_reset_map sa8775p_gcc_resets[] = { + [GCC_CAMERA_BCR] = { 0x32000 }, + [GCC_DISPLAY1_BCR] = { 0xC7000 }, + [GCC_DISPLAY_BCR] = { 0x33000 }, + [GCC_EMAC0_BCR] = { 0xB6000 }, + [GCC_EMAC1_BCR] = { 0xB4000 }, + [GCC_GPU_BCR] = { 0x7D000 }, + [GCC_MMSS_BCR] = { 0x17000 }, + [GCC_PCIE_0_BCR] = { 0xa9000 }, + [GCC_PCIE_0_LINK_DOWN_BCR] = { 0xBF000 }, + [GCC_PCIE_0_NOCSR_COM_PHY_BCR] = { 0xBF008 }, + [GCC_PCIE_0_PHY_BCR] = { 0xAD144 }, + [GCC_PCIE_0_PHY_NOCSR_COM_PHY_BCR] = { 0xBF00C }, + [GCC_PCIE_1_BCR] = { 0x77000 }, + [GCC_PCIE_1_LINK_DOWN_BCR] = { 0xAE084 }, + [GCC_PCIE_1_NOCSR_COM_PHY_BCR] = { 0xAE090 }, + [GCC_PCIE_1_PHY_BCR] = { 0xAE08C }, + [GCC_PCIE_1_PHY_NOCSR_COM_PHY_BCR] = { 0xAE094 }, + [GCC_PDM_BCR] = { 0x3F000 }, + [GCC_QUPV3_WRAPPER_0_BCR] = { 0x23000 }, + [GCC_QUPV3_WRAPPER_1_BCR] = { 0x24000 }, + [GCC_QUPV3_WRAPPER_2_BCR] = { 0x2A000 }, + [GCC_QUPV3_WRAPPER_3_BCR] = { 0xC4000 }, + [GCC_SDCC1_BCR] = { 0x20000 }, + [GCC_TSCSS_BCR] = { 0x21000 }, + [GCC_UFS_CARD_BCR] = { 0x81000 }, + [GCC_UFS_PHY_BCR] = { 0x83000 }, +}; + +static const struct qcom_power_map sa8775p_gdscs[] = { + [UFS_PHY_GDSC] = { 0x83004 }, + [USB30_PRIM_GDSC] = { 0x1B004 }, +}; + +static struct msm_clk_data sa8775_gcc_data = { + .resets = sa8775p_gcc_resets, + .num_resets = ARRAY_SIZE(sa8775p_gcc_resets), + .clks = sa8775p_clks, + .num_clks = ARRAY_SIZE(sa8775p_clks), + + .power_domains = sa8775p_gdscs, + .num_power_domains = ARRAY_SIZE(sa8775p_gdscs), + + .enable = sa8775p_enable, + .set_rate = sa8775p_set_rate, +}; + +static const struct udevice_id gcc_sa8775p_of_match[] = { + { + .compatible = "qcom,sa8775p-gcc", + .data = (ulong)&sa8775_gcc_data, + }, + { } +}; + +U_BOOT_DRIVER(gcc_sa8775p) = { + .name = "gcc_sa8775p", + .id = UCLASS_NOP, + .of_match = gcc_sa8775p_of_match, + .bind = qcom_cc_bind, + .flags = DM_FLAG_PRE_RELOC | DM_FLAG_DEFAULT_PD_CTRL_OFF, +};
Copy PHY tables over from Linux to support SA8775.
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tag/?h=v6...
Reviewed-by: Caleb Connolly caleb.connolly@linaro.org Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- v2: Added 'Reviewed-by: Neil Armstrong' and 'Caleb Connolly' Added Linux version info --- .../phy/qcom/phy-qcom-qmp-qserdes-com-v5.h | 124 ++++++++++ .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h | 231 ++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp-ufs.c | 171 +++++++++++++ 3 files changed, 526 insertions(+) create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h
diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h new file mode 100644 index 00000000000..c8afdf7bc1e --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h @@ -0,0 +1,124 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_COM_V5_H_ +#define QCOM_PHY_QMP_QSERDES_COM_V5_H_ + +/* Only for QMP V5 PHY - QSERDES COM registers */ +#define QSERDES_V5_COM_ATB_SEL1 0x000 +#define QSERDES_V5_COM_ATB_SEL2 0x004 +#define QSERDES_V5_COM_FREQ_UPDATE 0x008 +#define QSERDES_V5_COM_BG_TIMER 0x00c +#define QSERDES_V5_COM_SSC_EN_CENTER 0x010 +#define QSERDES_V5_COM_SSC_ADJ_PER1 0x014 +#define QSERDES_V5_COM_SSC_ADJ_PER2 0x018 +#define QSERDES_V5_COM_SSC_PER1 0x01c +#define QSERDES_V5_COM_SSC_PER2 0x020 +#define QSERDES_V5_COM_SSC_STEP_SIZE1_MODE0 0x024 +#define QSERDES_V5_COM_SSC_STEP_SIZE2_MODE0 0x028 +#define QSERDES_V5_COM_SSC_STEP_SIZE3_MODE0 0x02c +#define QSERDES_V5_COM_SSC_STEP_SIZE1_MODE1 0x030 +#define QSERDES_V5_COM_SSC_STEP_SIZE2_MODE1 0x034 +#define QSERDES_V5_COM_SSC_STEP_SIZE3_MODE1 0x038 +#define QSERDES_V5_COM_POST_DIV 0x03c +#define QSERDES_V5_COM_POST_DIV_MUX 0x040 +#define QSERDES_V5_COM_BIAS_EN_CLKBUFLR_EN 0x044 +#define QSERDES_V5_COM_CLK_ENABLE1 0x048 +#define QSERDES_V5_COM_SYS_CLK_CTRL 0x04c +#define QSERDES_V5_COM_SYSCLK_BUF_ENABLE 0x050 +#define QSERDES_V5_COM_PLL_EN 0x054 +#define QSERDES_V5_COM_PLL_IVCO 0x058 +#define QSERDES_V5_COM_CMN_IETRIM 0x05c +#define QSERDES_V5_COM_CMN_IPTRIM 0x060 +#define QSERDES_V5_COM_EP_CLOCK_DETECT_CTRL 0x064 +#define QSERDES_V5_COM_SYSCLK_DET_COMP_STATUS 0x068 +#define QSERDES_V5_COM_CLK_EP_DIV_MODE0 0x06c +#define QSERDES_V5_COM_CLK_EP_DIV_MODE1 0x070 +#define QSERDES_V5_COM_CP_CTRL_MODE0 0x074 +#define QSERDES_V5_COM_CP_CTRL_MODE1 0x078 +#define QSERDES_V5_COM_PLL_RCTRL_MODE0 0x07c +#define QSERDES_V5_COM_PLL_RCTRL_MODE1 0x080 +#define QSERDES_V5_COM_PLL_CCTRL_MODE0 0x084 +#define QSERDES_V5_COM_PLL_CCTRL_MODE1 0x088 +#define QSERDES_V5_COM_PLL_CNTRL 0x08c +#define QSERDES_V5_COM_BIAS_EN_CTRL_BY_PSM 0x090 +#define QSERDES_V5_COM_SYSCLK_EN_SEL 0x094 +#define QSERDES_V5_COM_CML_SYSCLK_SEL 0x098 +#define QSERDES_V5_COM_RESETSM_CNTRL 0x09c +#define QSERDES_V5_COM_RESETSM_CNTRL2 0x0a0 +#define QSERDES_V5_COM_LOCK_CMP_EN 0x0a4 +#define QSERDES_V5_COM_LOCK_CMP_CFG 0x0a8 +#define QSERDES_V5_COM_LOCK_CMP1_MODE0 0x0ac +#define QSERDES_V5_COM_LOCK_CMP2_MODE0 0x0b0 +#define QSERDES_V5_COM_LOCK_CMP1_MODE1 0x0b4 +#define QSERDES_V5_COM_LOCK_CMP2_MODE1 0x0b8 +#define QSERDES_V5_COM_DEC_START_MODE0 0x0bc +#define QSERDES_V5_COM_DEC_START_MSB_MODE0 0x0c0 +#define QSERDES_V5_COM_DEC_START_MODE1 0x0c4 +#define QSERDES_V5_COM_DEC_START_MSB_MODE1 0x0c8 +#define QSERDES_V5_COM_DIV_FRAC_START1_MODE0 0x0cc +#define QSERDES_V5_COM_DIV_FRAC_START2_MODE0 0x0d0 +#define QSERDES_V5_COM_DIV_FRAC_START3_MODE0 0x0d4 +#define QSERDES_V5_COM_DIV_FRAC_START1_MODE1 0x0d8 +#define QSERDES_V5_COM_DIV_FRAC_START2_MODE1 0x0dc +#define QSERDES_V5_COM_DIV_FRAC_START3_MODE1 0x0e0 +#define QSERDES_V5_COM_INTEGLOOP_INITVAL 0x0e4 +#define QSERDES_V5_COM_INTEGLOOP_EN 0x0e8 +#define QSERDES_V5_COM_INTEGLOOP_GAIN0_MODE0 0x0ec +#define QSERDES_V5_COM_INTEGLOOP_GAIN1_MODE0 0x0f0 +#define QSERDES_V5_COM_INTEGLOOP_GAIN0_MODE1 0x0f4 +#define QSERDES_V5_COM_INTEGLOOP_GAIN1_MODE1 0x0f8 +#define QSERDES_V5_COM_INTEGLOOP_P_PATH_GAIN0 0x0fc +#define QSERDES_V5_COM_INTEGLOOP_P_PATH_GAIN1 0x100 +#define QSERDES_V5_COM_VCOCAL_DEADMAN_CTRL 0x104 +#define QSERDES_V5_COM_VCO_TUNE_CTRL 0x108 +#define QSERDES_V5_COM_VCO_TUNE_MAP 0x10c +#define QSERDES_V5_COM_VCO_TUNE1_MODE0 0x110 +#define QSERDES_V5_COM_VCO_TUNE2_MODE0 0x114 +#define QSERDES_V5_COM_VCO_TUNE1_MODE1 0x118 +#define QSERDES_V5_COM_VCO_TUNE2_MODE1 0x11c +#define QSERDES_V5_COM_VCO_TUNE_INITVAL1 0x120 +#define QSERDES_V5_COM_VCO_TUNE_INITVAL2 0x124 +#define QSERDES_V5_COM_VCO_TUNE_MINVAL1 0x128 +#define QSERDES_V5_COM_VCO_TUNE_MINVAL2 0x12c +#define QSERDES_V5_COM_VCO_TUNE_MAXVAL1 0x130 +#define QSERDES_V5_COM_VCO_TUNE_MAXVAL2 0x134 +#define QSERDES_V5_COM_VCO_TUNE_TIMER1 0x138 +#define QSERDES_V5_COM_VCO_TUNE_TIMER2 0x13c +#define QSERDES_V5_COM_CMN_STATUS 0x140 +#define QSERDES_V5_COM_RESET_SM_STATUS 0x144 +#define QSERDES_V5_COM_RESTRIM_CODE_STATUS 0x148 +#define QSERDES_V5_COM_PLLCAL_CODE1_STATUS 0x14c +#define QSERDES_V5_COM_PLLCAL_CODE2_STATUS 0x150 +#define QSERDES_V5_COM_CLK_SELECT 0x154 +#define QSERDES_V5_COM_HSCLK_SEL 0x158 +#define QSERDES_V5_COM_HSCLK_HS_SWITCH_SEL 0x15c +#define QSERDES_V5_COM_INTEGLOOP_BINCODE_STATUS 0x160 +#define QSERDES_V5_COM_PLL_ANALOG 0x164 +#define QSERDES_V5_COM_CORECLK_DIV_MODE0 0x168 +#define QSERDES_V5_COM_CORECLK_DIV_MODE1 0x16c +#define QSERDES_V5_COM_SW_RESET 0x170 +#define QSERDES_V5_COM_CORE_CLK_EN 0x174 +#define QSERDES_V5_COM_C_READY_STATUS 0x178 +#define QSERDES_V5_COM_CMN_CONFIG 0x17c +#define QSERDES_V5_COM_CMN_RATE_OVERRIDE 0x180 +#define QSERDES_V5_COM_SVS_MODE_CLK_SEL 0x184 +#define QSERDES_V5_COM_DEBUG_BUS0 0x188 +#define QSERDES_V5_COM_DEBUG_BUS1 0x18c +#define QSERDES_V5_COM_DEBUG_BUS2 0x190 +#define QSERDES_V5_COM_DEBUG_BUS3 0x194 +#define QSERDES_V5_COM_DEBUG_BUS_SEL 0x198 +#define QSERDES_V5_COM_CMN_MISC1 0x19c +#define QSERDES_V5_COM_CMN_MODE 0x1a0 +#define QSERDES_V5_COM_CMN_MODE_CONTD 0x1a4 +#define QSERDES_V5_COM_VCO_DC_LEVEL_CTRL 0x1a8 +#define QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE1_MODE0 0x1ac +#define QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE2_MODE0 0x1b0 +#define QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE1_MODE1 0x1b4 +#define QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE2_MODE1 0x1b8 +#define QSERDES_V5_COM_BIN_VCOCAL_HSCLK_SEL 0x1bc +#define QSERDES_V5_COM_RESERVED_1 0x1c0 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h new file mode 100644 index 00000000000..fe8f3e330d0 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h @@ -0,0 +1,231 @@ + +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_TXRX_V5_H_ +#define QCOM_PHY_QMP_QSERDES_TXRX_V5_H_ + +/* Only for QMP V5 PHY - TX registers */ +#define QSERDES_V5_TX_BIST_MODE_LANENO 0x000 +#define QSERDES_V5_TX_BIST_INVERT 0x004 +#define QSERDES_V5_TX_CLKBUF_ENABLE 0x008 +#define QSERDES_V5_TX_TX_EMP_POST1_LVL 0x00c +#define QSERDES_V5_TX_TX_IDLE_LVL_LARGE_AMP 0x010 +#define QSERDES_V5_TX_TX_DRV_LVL 0x014 +#define QSERDES_V5_TX_TX_DRV_LVL_OFFSET 0x018 +#define QSERDES_V5_TX_RESET_TSYNC_EN 0x01c +#define QSERDES_V5_TX_PRE_STALL_LDO_BOOST_EN 0x020 +#define QSERDES_V5_TX_TX_BAND 0x024 +#define QSERDES_V5_TX_SLEW_CNTL 0x028 +#define QSERDES_V5_TX_INTERFACE_SELECT 0x02c +#define QSERDES_V5_TX_LPB_EN 0x030 +#define QSERDES_V5_TX_RES_CODE_LANE_TX 0x034 +#define QSERDES_V5_TX_RES_CODE_LANE_RX 0x038 +#define QSERDES_V5_TX_RES_CODE_LANE_OFFSET_TX 0x03c +#define QSERDES_V5_TX_RES_CODE_LANE_OFFSET_RX 0x040 +#define QSERDES_V5_TX_PERL_LENGTH1 0x044 +#define QSERDES_V5_TX_PERL_LENGTH2 0x048 +#define QSERDES_V5_TX_SERDES_BYP_EN_OUT 0x04c +#define QSERDES_V5_TX_DEBUG_BUS_SEL 0x050 +#define QSERDES_V5_TX_TRANSCEIVER_BIAS_EN 0x054 +#define QSERDES_V5_TX_HIGHZ_DRVR_EN 0x058 +#define QSERDES_V5_TX_TX_POL_INV 0x05c +#define QSERDES_V5_TX_PARRATE_REC_DETECT_IDLE_EN 0x060 +#define QSERDES_V5_TX_BIST_PATTERN1 0x064 +#define QSERDES_V5_TX_BIST_PATTERN2 0x068 +#define QSERDES_V5_TX_BIST_PATTERN3 0x06c +#define QSERDES_V5_TX_BIST_PATTERN4 0x070 +#define QSERDES_V5_TX_BIST_PATTERN5 0x074 +#define QSERDES_V5_TX_BIST_PATTERN6 0x078 +#define QSERDES_V5_TX_BIST_PATTERN7 0x07c +#define QSERDES_V5_TX_BIST_PATTERN8 0x080 +#define QSERDES_V5_TX_LANE_MODE_1 0x084 +#define QSERDES_V5_TX_LANE_MODE_2 0x088 +#define QSERDES_V5_TX_LANE_MODE_3 0x08c +#define QSERDES_V5_TX_LANE_MODE_4 0x090 +#define QSERDES_V5_TX_LANE_MODE_5 0x094 +#define QSERDES_V5_TX_ATB_SEL1 0x098 +#define QSERDES_V5_TX_ATB_SEL2 0x09c +#define QSERDES_V5_TX_RCV_DETECT_LVL 0x0a0 +#define QSERDES_V5_TX_RCV_DETECT_LVL_2 0x0a4 +#define QSERDES_V5_TX_PRBS_SEED1 0x0a8 +#define QSERDES_V5_TX_PRBS_SEED2 0x0ac +#define QSERDES_V5_TX_PRBS_SEED3 0x0b0 +#define QSERDES_V5_TX_PRBS_SEED4 0x0b4 +#define QSERDES_V5_TX_RESET_GEN 0x0b8 +#define QSERDES_V5_TX_RESET_GEN_MUXES 0x0bc +#define QSERDES_V5_TX_TRAN_DRVR_EMP_EN 0x0c0 +#define QSERDES_V5_TX_TX_INTERFACE_MODE 0x0c4 +#define QSERDES_V5_TX_VMODE_CTRL1 0x0c8 +#define QSERDES_V5_TX_ALOG_OBSV_BUS_CTRL_1 0x0cc +#define QSERDES_V5_TX_BIST_STATUS 0x0d0 +#define QSERDES_V5_TX_BIST_ERROR_COUNT1 0x0d4 +#define QSERDES_V5_TX_BIST_ERROR_COUNT2 0x0d8 +#define QSERDES_V5_TX_ALOG_OBSV_BUS_STATUS_1 0x0dc +#define QSERDES_V5_TX_LANE_DIG_CONFIG 0x0e0 +#define QSERDES_V5_TX_PI_QEC_CTRL 0x0e4 +#define QSERDES_V5_TX_PRE_EMPH 0x0e8 +#define QSERDES_V5_TX_SW_RESET 0x0ec +#define QSERDES_V5_TX_DCC_OFFSET 0x0f0 +#define QSERDES_V5_TX_DCC_CMUX_POSTCAL_OFFSET 0x0f4 +#define QSERDES_V5_TX_DCC_CMUX_CAL_CTRL1 0x0f8 +#define QSERDES_V5_TX_DCC_CMUX_CAL_CTRL2 0x0fc +#define QSERDES_V5_TX_DIG_BKUP_CTRL 0x100 +#define QSERDES_V5_TX_DEBUG_BUS0 0x104 +#define QSERDES_V5_TX_DEBUG_BUS1 0x108 +#define QSERDES_V5_TX_DEBUG_BUS2 0x10c +#define QSERDES_V5_TX_DEBUG_BUS3 0x110 +#define QSERDES_V5_TX_READ_EQCODE 0x114 +#define QSERDES_V5_TX_READ_OFFSETCODE 0x118 +#define QSERDES_V5_TX_IA_ERROR_COUNTER_LOW 0x11c +#define QSERDES_V5_TX_IA_ERROR_COUNTER_HIGH 0x120 +#define QSERDES_V5_TX_VGA_READ_CODE 0x124 +#define QSERDES_V5_TX_VTH_READ_CODE 0x128 +#define QSERDES_V5_TX_DFE_TAP1_READ_CODE 0x12c +#define QSERDES_V5_TX_DFE_TAP2_READ_CODE 0x130 +#define QSERDES_V5_TX_IDAC_STATUS_I 0x134 +#define QSERDES_V5_TX_IDAC_STATUS_IBAR 0x138 +#define QSERDES_V5_TX_IDAC_STATUS_Q 0x13c +#define QSERDES_V5_TX_IDAC_STATUS_QBAR 0x140 +#define QSERDES_V5_TX_IDAC_STATUS_A 0x144 +#define QSERDES_V5_TX_IDAC_STATUS_ABAR 0x148 +#define QSERDES_V5_TX_IDAC_STATUS_SM_ON 0x14c +#define QSERDES_V5_TX_IDAC_STATUS_CAL_DONE 0x150 +#define QSERDES_V5_TX_IDAC_STATUS_SIGNERROR 0x154 +#define QSERDES_V5_TX_DCC_CAL_STATUS 0x158 +#define QSERDES_V5_TX_DCC_READ_CODE_STATUS 0x15c + +/* Only for QMP V5 PHY - RX registers */ +#define QSERDES_V5_RX_UCDR_FO_GAIN_HALF 0x000 +#define QSERDES_V5_RX_UCDR_FO_GAIN_QUARTER 0x004 +#define QSERDES_V5_RX_UCDR_FO_GAIN 0x008 +#define QSERDES_V5_RX_UCDR_SO_GAIN_HALF 0x00c +#define QSERDES_V5_RX_UCDR_SO_GAIN_QUARTER 0x010 +#define QSERDES_V5_RX_UCDR_SO_GAIN 0x014 +#define QSERDES_V5_RX_UCDR_SVS_FO_GAIN_HALF 0x018 +#define QSERDES_V5_RX_UCDR_SVS_FO_GAIN_QUARTER 0x01c +#define QSERDES_V5_RX_UCDR_SVS_FO_GAIN 0x020 +#define QSERDES_V5_RX_UCDR_SVS_SO_GAIN_HALF 0x024 +#define QSERDES_V5_RX_UCDR_SVS_SO_GAIN_QUARTER 0x028 +#define QSERDES_V5_RX_UCDR_SVS_SO_GAIN 0x02c +#define QSERDES_V5_RX_UCDR_FASTLOCK_FO_GAIN 0x030 +#define QSERDES_V5_RX_UCDR_SO_SATURATION_AND_ENABLE 0x034 +#define QSERDES_V5_RX_UCDR_FO_TO_SO_DELAY 0x038 +#define QSERDES_V5_RX_UCDR_FASTLOCK_COUNT_LOW 0x03c +#define QSERDES_V5_RX_UCDR_FASTLOCK_COUNT_HIGH 0x040 +#define QSERDES_V5_RX_UCDR_PI_CONTROLS 0x044 +#define QSERDES_V5_RX_UCDR_PI_CTRL2 0x048 +#define QSERDES_V5_RX_UCDR_SB2_THRESH1 0x04c +#define QSERDES_V5_RX_UCDR_SB2_THRESH2 0x050 +#define QSERDES_V5_RX_UCDR_SB2_GAIN1 0x054 +#define QSERDES_V5_RX_UCDR_SB2_GAIN2 0x058 +#define QSERDES_V5_RX_AUX_CONTROL 0x05c +#define QSERDES_V5_RX_AUX_DATA_TCOARSE_TFINE 0x060 +#define QSERDES_V5_RX_RCLK_AUXDATA_SEL 0x064 +#define QSERDES_V5_RX_AC_JTAG_ENABLE 0x068 +#define QSERDES_V5_RX_AC_JTAG_INITP 0x06c +#define QSERDES_V5_RX_AC_JTAG_INITN 0x070 +#define QSERDES_V5_RX_AC_JTAG_LVL 0x074 +#define QSERDES_V5_RX_AC_JTAG_MODE 0x078 +#define QSERDES_V5_RX_AC_JTAG_RESET 0x07c +#define QSERDES_V5_RX_RX_TERM_BW 0x080 +#define QSERDES_V5_RX_RX_RCVR_IQ_EN 0x084 +#define QSERDES_V5_RX_RX_IDAC_I_DC_OFFSETS 0x088 +#define QSERDES_V5_RX_RX_IDAC_IBAR_DC_OFFSETS 0x08c +#define QSERDES_V5_RX_RX_IDAC_Q_DC_OFFSETS 0x090 +#define QSERDES_V5_RX_RX_IDAC_QBAR_DC_OFFSETS 0x094 +#define QSERDES_V5_RX_RX_IDAC_A_DC_OFFSETS 0x098 +#define QSERDES_V5_RX_RX_IDAC_ABAR_DC_OFFSETS 0x09c +#define QSERDES_V5_RX_RX_IDAC_EN 0x0a0 +#define QSERDES_V5_RX_RX_IDAC_ENABLES 0x0a4 +#define QSERDES_V5_RX_RX_IDAC_SIGN 0x0a8 +#define QSERDES_V5_RX_RX_HIGHZ_HIGHRATE 0x0ac +#define QSERDES_V5_RX_RX_TERM_AC_BYPASS_DC_COUPLE_OFFSET 0x0b0 +#define QSERDES_V5_RX_DFE_1 0x0b4 +#define QSERDES_V5_RX_DFE_2 0x0b8 +#define QSERDES_V5_RX_DFE_3 0x0bc +#define QSERDES_V5_RX_DFE_4 0x0c0 +#define QSERDES_V5_RX_TX_ADAPT_PRE_THRESH1 0x0c4 +#define QSERDES_V5_RX_TX_ADAPT_PRE_THRESH2 0x0c8 +#define QSERDES_V5_RX_TX_ADAPT_POST_THRESH 0x0cc +#define QSERDES_V5_RX_TX_ADAPT_MAIN_THRESH 0x0d0 +#define QSERDES_V5_RX_VGA_CAL_CNTRL1 0x0d4 +#define QSERDES_V5_RX_VGA_CAL_CNTRL2 0x0d8 +#define QSERDES_V5_RX_GM_CAL 0x0dc +#define QSERDES_V5_RX_RX_VGA_GAIN2_LSB 0x0e0 +#define QSERDES_V5_RX_RX_VGA_GAIN2_MSB 0x0e4 +#define QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL1 0x0e8 +#define QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL2 0x0ec +#define QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL3 0x0f0 +#define QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL4 0x0f4 +#define QSERDES_V5_RX_RX_IDAC_TSETTLE_LOW 0x0f8 +#define QSERDES_V5_RX_RX_IDAC_TSETTLE_HIGH 0x0fc +#define QSERDES_V5_RX_RX_IDAC_MEASURE_TIME 0x100 +#define QSERDES_V5_RX_RX_IDAC_ACCUMULATOR 0x104 +#define QSERDES_V5_RX_RX_EQ_OFFSET_LSB 0x108 +#define QSERDES_V5_RX_RX_EQ_OFFSET_MSB 0x10c +#define QSERDES_V5_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1 0x110 +#define QSERDES_V5_RX_RX_OFFSET_ADAPTOR_CNTRL2 0x114 +#define QSERDES_V5_RX_SIGDET_ENABLES 0x118 +#define QSERDES_V5_RX_SIGDET_CNTRL 0x11c +#define QSERDES_V5_RX_SIGDET_LVL 0x120 +#define QSERDES_V5_RX_SIGDET_DEGLITCH_CNTRL 0x124 +#define QSERDES_V5_RX_RX_BAND 0x128 +#define QSERDES_V5_RX_CDR_FREEZE_UP_DN 0x12c +#define QSERDES_V5_RX_CDR_RESET_OVERRIDE 0x130 +#define QSERDES_V5_RX_RX_INTERFACE_MODE 0x134 +#define QSERDES_V5_RX_JITTER_GEN_MODE 0x138 +#define QSERDES_V5_RX_SJ_AMP1 0x13c +#define QSERDES_V5_RX_SJ_AMP2 0x140 +#define QSERDES_V5_RX_SJ_PER1 0x144 +#define QSERDES_V5_RX_SJ_PER2 0x148 +#define QSERDES_V5_RX_PPM_OFFSET1 0x14c +#define QSERDES_V5_RX_PPM_OFFSET2 0x150 +#define QSERDES_V5_RX_SIGN_PPM_PERIOD1 0x154 +#define QSERDES_V5_RX_SIGN_PPM_PERIOD2 0x158 +#define QSERDES_V5_RX_RX_MODE_00_LOW 0x15c +#define QSERDES_V5_RX_RX_MODE_00_HIGH 0x160 +#define QSERDES_V5_RX_RX_MODE_00_HIGH2 0x164 +#define QSERDES_V5_RX_RX_MODE_00_HIGH3 0x168 +#define QSERDES_V5_RX_RX_MODE_00_HIGH4 0x16c +#define QSERDES_V5_RX_RX_MODE_01_LOW 0x170 +#define QSERDES_V5_RX_RX_MODE_01_HIGH 0x174 +#define QSERDES_V5_RX_RX_MODE_01_HIGH2 0x178 +#define QSERDES_V5_RX_RX_MODE_01_HIGH3 0x17c +#define QSERDES_V5_RX_RX_MODE_01_HIGH4 0x180 +#define QSERDES_V5_RX_RX_MODE_10_LOW 0x184 +#define QSERDES_V5_RX_RX_MODE_10_HIGH 0x188 +#define QSERDES_V5_RX_RX_MODE_10_HIGH2 0x18c +#define QSERDES_V5_RX_RX_MODE_10_HIGH3 0x190 +#define QSERDES_V5_RX_RX_MODE_10_HIGH4 0x194 +#define QSERDES_V5_RX_PHPRE_CTRL 0x198 +#define QSERDES_V5_RX_PHPRE_INITVAL 0x19c +#define QSERDES_V5_RX_DFE_EN_TIMER 0x1a0 +#define QSERDES_V5_RX_DFE_CTLE_POST_CAL_OFFSET 0x1a4 +#define QSERDES_V5_RX_DCC_CTRL1 0x1a8 +#define QSERDES_V5_RX_DCC_CTRL2 0x1ac +#define QSERDES_V5_RX_VTH_CODE 0x1b0 +#define QSERDES_V5_RX_VTH_MIN_THRESH 0x1b4 +#define QSERDES_V5_RX_VTH_MAX_THRESH 0x1b8 +#define QSERDES_V5_RX_ALOG_OBSV_BUS_CTRL_1 0x1bc +#define QSERDES_V5_RX_PI_CTRL1 0x1c0 +#define QSERDES_V5_RX_PI_CTRL2 0x1c4 +#define QSERDES_V5_RX_PI_QUAD 0x1c8 +#define QSERDES_V5_RX_IDATA1 0x1cc +#define QSERDES_V5_RX_IDATA2 0x1d0 +#define QSERDES_V5_RX_AUX_DATA1 0x1d4 +#define QSERDES_V5_RX_AUX_DATA2 0x1d8 +#define QSERDES_V5_RX_AC_JTAG_OUTP 0x1dc +#define QSERDES_V5_RX_AC_JTAG_OUTN 0x1e0 +#define QSERDES_V5_RX_RX_SIGDET 0x1e4 +#define QSERDES_V5_RX_ALOG_OBSV_BUS_STATUS_1 0x1e8 + +/* Only for QMP V5 UFS ? */ +#define QSERDES_V5_TX_PWM_GEAR_1_DIVIDER_BAND0_1 0x178 +#define QSERDES_V5_TX_PWM_GEAR_2_DIVIDER_BAND0_1 0x17c +#define QSERDES_V5_TX_PWM_GEAR_3_DIVIDER_BAND0_1 0x180 +#define QSERDES_V5_TX_PWM_GEAR_4_DIVIDER_BAND0_1 0x184 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-ufs.c b/drivers/phy/qcom/phy-qcom-qmp-ufs.c index 5c90d60e7d1..449b9767778 100644 --- a/drivers/phy/qcom/phy-qcom-qmp-ufs.c +++ b/drivers/phy/qcom/phy-qcom-qmp-ufs.c @@ -33,8 +33,10 @@ #include "phy-qcom-qmp-pcs-ufs-v6.h"
#include "phy-qcom-qmp-qserdes-com-v4.h" +#include "phy-qcom-qmp-qserdes-com-v5.h" #include "phy-qcom-qmp-qserdes-com-v6.h" #include "phy-qcom-qmp-qserdes-txrx-v4.h" +#include "phy-qcom-qmp-qserdes-txrx-v5.h" #include "phy-qcom-qmp-qserdes-txrx-ufs-v6.h"
/* QPHY_SW_RESET bit */ @@ -97,6 +99,13 @@ static const unsigned int ufsphy_v4_regs_layout[QPHY_LAYOUT_SIZE] = { [QPHY_PCS_POWER_DOWN_CONTROL] = QPHY_V4_PCS_UFS_POWER_DOWN_CONTROL, };
+static const unsigned int ufsphy_v5_regs_layout[QPHY_LAYOUT_SIZE] = { + [QPHY_START_CTRL] = QPHY_V5_PCS_UFS_PHY_START, + [QPHY_PCS_READY_STATUS] = QPHY_V5_PCS_UFS_READY_STATUS, + [QPHY_SW_RESET] = QPHY_V5_PCS_UFS_SW_RESET, + [QPHY_PCS_POWER_DOWN_CONTROL] = QPHY_V5_PCS_UFS_POWER_DOWN_CONTROL, +}; + static const unsigned int ufsphy_v6_regs_layout[QPHY_LAYOUT_SIZE] = { [QPHY_START_CTRL] = QPHY_V6_PCS_UFS_PHY_START, [QPHY_PCS_READY_STATUS] = QPHY_V6_PCS_UFS_READY_STATUS, @@ -458,6 +467,128 @@ static const struct qmp_ufs_init_tbl sm8650_ufsphy_rx[] = { QMP_PHY_INIT_CFG(QSERDES_UFS_V6_RX_DLL0_FTUNE_CTRL, 0x30), };
+static const struct qmp_ufs_init_tbl sm8350_ufsphy_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_COM_SYSCLK_EN_SEL, 0xd9), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_HSCLK_SEL, 0x11), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_HSCLK_HS_SWITCH_SEL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_LOCK_CMP_EN, 0x42), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_VCO_TUNE_MAP, 0x02), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_PLL_IVCO, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_VCO_TUNE_INITVAL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_BIN_VCOCAL_HSCLK_SEL, 0x11), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_DEC_START_MODE0, 0x82), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_CP_CTRL_MODE0, 0x14), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_PLL_RCTRL_MODE0, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_PLL_CCTRL_MODE0, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_LOCK_CMP1_MODE0, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_LOCK_CMP2_MODE0, 0x19), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE1_MODE0, 0xac), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE2_MODE0, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_DEC_START_MODE1, 0x98), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_CP_CTRL_MODE1, 0x14), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_PLL_RCTRL_MODE1, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_PLL_CCTRL_MODE1, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_LOCK_CMP1_MODE1, 0x65), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_LOCK_CMP2_MODE1, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE1_MODE1, 0xdd), + QMP_PHY_INIT_CFG(QSERDES_V5_COM_BIN_VCOCAL_CMP_CODE2_MODE1, 0x23), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_hs_b_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_COM_VCO_TUNE_MAP, 0x06), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_TX_PWM_GEAR_1_DIVIDER_BAND0_1, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_PWM_GEAR_2_DIVIDER_BAND0_1, 0x03), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_PWM_GEAR_3_DIVIDER_BAND0_1, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_PWM_GEAR_4_DIVIDER_BAND0_1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_LANE_MODE_1, 0xf5), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_LANE_MODE_3, 0x3f), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_RES_CODE_LANE_OFFSET_TX, 0x09), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_RES_CODE_LANE_OFFSET_RX, 0x09), + QMP_PHY_INIT_CFG(QSERDES_V5_TX_TRAN_DRVR_EMP_EN, 0x0c), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_RX_SIGDET_LVL, 0x24), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_SIGDET_CNTRL, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_SIGDET_DEGLITCH_CNTRL, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_BAND, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_FASTLOCK_FO_GAIN, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_SO_SATURATION_AND_ENABLE, 0x5a), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_PI_CONTROLS, 0xf1), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_FASTLOCK_COUNT_LOW, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_PI_CTRL2, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_FO_GAIN, 0x0e), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_SO_GAIN, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_TERM_BW, 0x1b), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL1, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL2, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL3, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL4, 0x1a), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1, 0x17), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_OFFSET_ADAPTOR_CNTRL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_MEASURE_TIME, 0x10), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_TSETTLE_LOW, 0xc0), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_TSETTLE_HIGH, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_LOW, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH2, 0xed), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH4, 0x3c), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_LOW, 0xe0), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH2, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH4, 0xb7), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_10_LOW, 0xe0), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_10_HIGH, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_10_HIGH2, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_10_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_10_HIGH4, 0xb7), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_DCC_CTRL1, 0x0c), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_RX_SIGDET_CTRL2, 0x6d), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_TX_LARGE_AMP_DRV_LVL, 0x0a), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_TX_SMALL_AMP_DRV_LVL, 0x02), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_TX_MID_TERM_CTRL1, 0x43), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_DEBUG_BUS_CLKSEL, 0x1f), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_RX_MIN_HIBERN8_TIME, 0xff), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_RX_SIGDET_CTRL1, 0x0e), + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_MULTI_LANE_CTRL1, 0x02), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_g4_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_TX_LANE_MODE_1, 0xe5), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_g4_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_V5_RX_UCDR_PI_CTRL2, 0x81), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_TERM_BW, 0x6f), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL3, 0x4a), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_EQU_ADAPTOR_CNTRL4, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_MEASURE_TIME, 0x20), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_TSETTLE_LOW, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_IDAC_TSETTLE_HIGH, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_LOW, 0xbf), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH, 0xbf), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH2, 0x7f), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH3, 0x7f), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_00_HIGH4, 0x2d), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_LOW, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH2, 0xed), + QMP_PHY_INIT_CFG(QSERDES_V5_RX_RX_MODE_01_HIGH4, 0x3c), +}; + +static const struct qmp_ufs_init_tbl sm8350_ufsphy_g4_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V5_PCS_UFS_BIST_FIXED_PAT_CTRL, 0x0a), +}; + static const struct qmp_ufs_init_tbl sm8650_ufsphy_pcs[] = { QMP_PHY_INIT_CFG(QPHY_V6_PCS_UFS_MULTI_LANE_CTRL1, 0x02), QMP_PHY_INIT_CFG(QPHY_V6_PCS_UFS_TX_MID_TERM_CTRL1, 0x43), @@ -690,6 +821,11 @@ static const char * const sdm845_ufs_phy_clk_l[] = { "ref", "ref_aux", };
+/* the primary usb3 phy on sm8250 doesn't have a ref clock */ +static const char * const sm8450_ufs_phy_clk_l[] = { + "qref", "ref", "ref_aux", +}; + /* list of regulators */ static const char * const qmp_ufs_vreg_l[] = { "vdda-phy", "vdda-pll", @@ -909,6 +1045,40 @@ static const struct qmp_ufs_cfg sc7280_ufsphy_cfg = { .regs = ufsphy_v4_regs_layout, };
+static const struct qmp_ufs_cfg sa8775p_ufsphy_cfg = { + .lanes = 2, + + .offsets = &qmp_ufs_offsets, + + .tbls = { + .serdes = sm8350_ufsphy_serdes, + .serdes_num = ARRAY_SIZE(sm8350_ufsphy_serdes), + .tx = sm8350_ufsphy_tx, + .tx_num = ARRAY_SIZE(sm8350_ufsphy_tx), + .rx = sm8350_ufsphy_rx, + .rx_num = ARRAY_SIZE(sm8350_ufsphy_rx), + .pcs = sm8350_ufsphy_pcs, + .pcs_num = ARRAY_SIZE(sm8350_ufsphy_pcs), + }, + .tbls_hs_b = { + .serdes = sm8350_ufsphy_hs_b_serdes, + .serdes_num = ARRAY_SIZE(sm8350_ufsphy_hs_b_serdes), + }, + .tbls_hs_g4 = { + .tx = sm8350_ufsphy_g4_tx, + .tx_num = ARRAY_SIZE(sm8350_ufsphy_g4_tx), + .rx = sm8350_ufsphy_g4_rx, + .rx_num = ARRAY_SIZE(sm8350_ufsphy_g4_rx), + .pcs = sm8350_ufsphy_g4_pcs, + .pcs_num = ARRAY_SIZE(sm8350_ufsphy_g4_pcs), + }, + .clk_list = sm8450_ufs_phy_clk_l, + .num_clks = ARRAY_SIZE(sm8450_ufs_phy_clk_l), + .vreg_list = qmp_ufs_vreg_l, + .num_vregs = ARRAY_SIZE(qmp_ufs_vreg_l), + .regs = ufsphy_v5_regs_layout, +}; + static void qmp_ufs_configure_lane(void __iomem *base, const struct qmp_ufs_init_tbl tbl[], int num, @@ -1295,6 +1465,7 @@ static struct phy_ops qmp_ufs_ops = { };
static const struct udevice_id qmp_ufs_ids[] = { + { .compatible = "qcom,sa8775p-qmp-ufs-phy", .data = (ulong)&sa8775p_ufsphy_cfg, }, { .compatible = "qcom,sdm845-qmp-ufs-phy", .data = (ulong)&sdm845_ufsphy_cfg }, { .compatible = "qcom,sm8150-qmp-ufs-phy", .data = (ulong)&sm8150_ufsphy_cfg }, { .compatible = "qcom,sm8250-qmp-ufs-phy", .data = (ulong)&sm8250_ufsphy_cfg },
Enable the SA8775P clock driver in the Qualcomm defconfig.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- v2: Added 'Reviewed-by: Neil Armstrong' --- configs/qcom_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index cd94315f176..2cd5a5602ea 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -48,6 +48,7 @@ CONFIG_CLK_QCOM_APQ8016=y CONFIG_CLK_QCOM_APQ8096=y CONFIG_CLK_QCOM_QCM2290=y CONFIG_CLK_QCOM_QCS404=y +CONFIG_CLK_QCOM_SA8775P=y CONFIG_CLK_QCOM_SDM845=y CONFIG_CLK_QCOM_SM6115=y CONFIG_CLK_QCOM_SM8150=y
Introduce a defconfig for the Ride R3 and other QCS9100 boards with a dedicated uefi partition. These can replace EDK2 entirely with U-Boot.
Signed-off-by: Varadarajan Narayanan quic_varada@quicinc.com --- v2: Use qcs9100-ride-r3 for default DT instead of sa8775p-ride-r3 --- configs/qcs9100_defconfig | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+) create mode 100644 configs/qcs9100_defconfig
diff --git a/configs/qcs9100_defconfig b/configs/qcs9100_defconfig new file mode 100644 index 00000000000..7e72c64968b --- /dev/null +++ b/configs/qcs9100_defconfig @@ -0,0 +1,24 @@ +# Configuration for building U-Boot to be flashed +# to the uefi partition of QCS9100 based dev boards with +# the "Linux Embedded" partition layout (which have +# a dedicated "uefi" partition for edk2/U-Boot) + +#include "qcom_defconfig" + +# Otherwise buildman thinks this isn't an ARM platform +CONFIG_ARM=y + +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_BASE=0xA8C000 +CONFIG_DEBUG_UART_MSM_GENI=y +CONFIG_DEBUG_UART_CLOCK=14745600 + +# Address where U-Boot will be loaded +CONFIG_TEXT_BASE=0xaf000000 +CONFIG_REMAKE_ELF=y + +CONFIG_DEFAULT_DEVICE_TREE="qcom/qcs9100-ride-r3" + +CONFIG_PHY_QCOM_QMP_UFS=y +CONFIG_QCOM_UFS=y
This is already defined in qcom_defconfig.
Again, these are already defined in qcom_defconfig.
-Sumit
-- 2.34.1
Sumit Garg
