[PATCH] phy: rockchip: inno-hdmi: Fix missing readl base addr
inno_poll passes the reg offset that is used by readl_poll_sleep_timeout without any base addr.
Fix it.
Bug: inno_hdmi_phy phy@ff430000: Pre-PLL locking failed inno_hdmi_phy phy@ff430000: PHY: Failed to power on phy@ff430000: -110. failed to power on phy (ret=-110) inno_hdmi_phy phy@ff430000: Pre-PLL locking failed inno_hdmi_phy phy@ff430000: PHY: Failed to power on phy@ff430000: -110. failed to power on phy (ret=-110)
Fixes: aa2271184603 ("phy: rockchip: Add Rockchip INNO HDMI PHY driver") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Jagan Teki jagan@edgeble.ai --- drivers/phy/rockchip/phy-rockchip-inno-hdmi.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-hdmi.c b/drivers/phy/rockchip/phy-rockchip-inno-hdmi.c index 3bb1a254ff..7459779dff 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-hdmi.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-hdmi.c @@ -432,8 +432,8 @@ static inline void inno_update_bits(struct inno_hdmi_phy *inno, u8 reg, inno_write(inno, reg, tmp); }
-#define inno_poll(reg, val, cond, sleep_us, timeout_us) \ - readl_poll_sleep_timeout((reg) * 4, val, cond, sleep_us, timeout_us) +#define inno_poll(inno, reg, val, cond, sleep_us, timeout_us) \ + readl_poll_sleep_timeout((inno)->regs + ((reg) * 4), val, cond, sleep_us, timeout_us)
static unsigned long inno_hdmi_phy_get_tmdsclk(struct inno_hdmi_phy *inno, unsigned long rate) @@ -575,7 +575,7 @@ inno_hdmi_phy_rk3328_clk_set_rate(struct phy *phy, inno_update_bits(inno, 0xa0, RK3328_PRE_PLL_POWER_DOWN, 0);
/* Wait for Pre-PLL lock */ - ret = inno_poll(0xa9, val, val & RK3328_PRE_PLL_LOCK_STATUS, + ret = inno_poll(inno, 0xa9, val, val & RK3328_PRE_PLL_LOCK_STATUS, 1000, 10000); if (ret) { dev_err(phy->dev, "Pre-PLL locking failed\n"); @@ -674,7 +674,7 @@ inno_hdmi_phy_rk3328_power_on(struct phy *phy, RK3328_TMDS_DRIVER_ENABLE);
/* Wait for post PLL lock */ - ret = inno_poll(0xaf, v, v & RK3328_POST_PLL_LOCK_STATUS, + ret = inno_poll(inno, 0xaf, v, v & RK3328_POST_PLL_LOCK_STATUS, 1000, 10000); if (ret) { dev_err(phy->dev, "Post-PLL locking failed\n");
Fix it.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- ret = inno_poll(inno, 0xa9, val, val & RK3328_PRE_PLL_LOCK_STATUS, 1000, 10000); if (ret) { dev_err(phy->dev, "Pre-PLL locking failed\n");
- ret = inno_poll(inno, 0xaf, v, v & RK3328_POST_PLL_LOCK_STATUS, 1000, 10000); if (ret) { dev_err(phy->dev, "Post-PLL locking failed\n");
Jagan Teki
Kever Yang
