[U-Boot] [PATCH 17/22] ppc4xx: remove some CPCI405 variants
only keep CPCI4052
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- arch/powerpc/cpu/ppc4xx/Kconfig | 9 - board/esd/cpci405/Kconfig | 39 ---- configs/CPCI405AB_defconfig | 3 - configs/CPCI405DT_defconfig | 3 - configs/CPCI405_defconfig | 3 - doc/README.scrapyard | 3 + include/configs/CPCI405.h | 320 --------------------------------- include/configs/CPCI405AB.h | 373 -------------------------------------- include/configs/CPCI405DT.h | 376 --------------------------------------- 9 files changed, 3 insertions(+), 1126 deletions(-) delete mode 100644 configs/CPCI405AB_defconfig delete mode 100644 configs/CPCI405DT_defconfig delete mode 100644 configs/CPCI405_defconfig delete mode 100644 include/configs/CPCI405.h delete mode 100644 include/configs/CPCI405AB.h delete mode 100644 include/configs/CPCI405DT.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index e7163c1..a40ae3b 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -110,18 +110,9 @@ config TARGET_PPCHAMELEONEVB config TARGET_CPCI2DP bool "Support CPCI2DP"
-config TARGET_CPCI405 - bool "Support CPCI405" - config TARGET_CPCI4052 bool "Support CPCI4052"
-config TARGET_CPCI405AB - bool "Support CPCI405AB" - -config TARGET_CPCI405DT - bool "Support CPCI405DT" - config TARGET_PLU405 bool "Support PLU405"
diff --git a/board/esd/cpci405/Kconfig b/board/esd/cpci405/Kconfig index bc56907..0df2755 100644 --- a/board/esd/cpci405/Kconfig +++ b/board/esd/cpci405/Kconfig @@ -1,16 +1,3 @@ -if TARGET_CPCI405 - -config SYS_BOARD - default "cpci405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "CPCI405" - -endif - if TARGET_CPCI4052
config SYS_BOARD @@ -23,29 +10,3 @@ config SYS_CONFIG_NAME default "CPCI4052"
endif - -if TARGET_CPCI405AB - -config SYS_BOARD - default "cpci405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "CPCI405AB" - -endif - -if TARGET_CPCI405DT - -config SYS_BOARD - default "cpci405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "CPCI405DT" - -endif diff --git a/configs/CPCI405AB_defconfig b/configs/CPCI405AB_defconfig deleted file mode 100644 index 6550fd1..0000000 --- a/configs/CPCI405AB_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_CPCI405AB=y diff --git a/configs/CPCI405DT_defconfig b/configs/CPCI405DT_defconfig deleted file mode 100644 index b61f65c..0000000 --- a/configs/CPCI405DT_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_CPCI405DT=y diff --git a/configs/CPCI405_defconfig b/configs/CPCI405_defconfig deleted file mode 100644 index 1638e2b..0000000 --- a/configs/CPCI405_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_CPCI405=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 69daaab..9172f6c 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,9 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +CPCI405 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu +CPCI405DT ppc4xx 405gpr - - Matthias Fuchs matthias.fuchs@esd.eu +CPCI405AB ppc4xx 405gpr - - Matthias Fuchs matthias.fuchs@esd.eu G2000 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu WUH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu VOH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu diff --git a/include/configs/CPCI405.h b/include/configs/CPCI405.h deleted file mode 100644 index 34252d4..0000000 --- a/include/configs/CPCI405.h +++ /dev/null @@ -1,320 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405GP 1 /* This is a PPC405 CPU */ -#define CONFIG_CPCI405 1 /* ...on a CPCI405 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33000000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */ - -#undef CONFIG_HAS_ETH1 - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_ELF -#define CONFIG_CMD_MII -#define CONFIG_CMD_EEPROM - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_SUPPORT_VFAT - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_LOOPW 1 /* enable loopw command */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config*/ - -#define CONFIG_PCI_BOOTDELAY 0 /* enable pci bootdelay variable*/ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID2 0x0406 /* PCI Device ID: CPCI-405-A */ -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI (bd->bi_memsize) /* host use this pci address */ - -#define CONFIG_PCI_4xx_PTM_OVERWRITE 1 /* overwrite PTMx settings by env */ - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ -#undef CONFIG_IDE_LED /* no led for ide supported */ -#undef CONFIG_IDE_RESET /* no reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE busses */ -#define CONFIG_SYS_IDE_MAXDEVICE (CONFIG_SYS_IDE_MAXBUS*1) /* max. 1 drives per IDE bus */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xF0100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (~(CONFIG_SYS_TEXT_BASE) + 1) -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xf0200000 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE (32*1024) /* NVRAM size */ -#define CONFIG_SYS_VXWORKS_MAC_PTR (CONFIG_SYS_NVRAM_BASE_ADDR+0x6900) /* VxWorks eth-addr*/ - -#if 1 /* Use NVRAM for environment variables */ -/*----------------------------------------------------------------------- - * NVRAM organization - */ -#define CONFIG_ENV_IS_IN_NVRAM 1 /* use NVRAM for environment vars */ -#define CONFIG_ENV_SIZE 0x1000 /* Size of Environment vars */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_NVRAM_BASE_ADDR+CONFIG_SYS_NVRAM_SIZE-CONFIG_ENV_SIZE) /* Env */ - -#else /* Use EEPROM for environment variables */ - -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x400 /* 1024 bytes may be used for env vars */ - /* total size of a CAT24WC08 is 1024 bytes */ -#endif - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC08) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF800000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0xFFC00000 /* FLASH bank #1 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (Flash Bank 1) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR 0xFF85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 2 (CAN0, 1, 2, Codeswitch) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 3 (CompactFlash IDE) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB3CR 0xF011A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ - -/* Memory Bank 4 (NVRAM) initialization */ -#define CONFIG_SYS_EBC_PB4AP 0x01005280 /* TWT=2,WBN=1,WBF=1,TH=1,SOR=1 */ -#define CONFIG_SYS_EBC_PB4CR 0xF0218000 /* BAS=0xF02,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 5 (Quart) initialization */ -#define CONFIG_SYS_EBC_PB5AP 0x04005B80 /* TWT=8,WBN=1,WBF=1,TH=5,RE=1,SOR=1*/ -#define CONFIG_SYS_EBC_PB5CR 0xF0318000 /* BAS=0xF03,BS=1MB,BU=R/W,BW=8bit */ - -/*----------------------------------------------------------------------- - * FPGA stuff - */ - -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* FPGA program pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00400000 /* FPGA init pin (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00800000 /* FPGA done pin (ppc input) */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -#if 1 /* test-only */ -#define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */ - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ -#else -#define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ -#endif -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405AB.h b/include/configs/CPCI405AB.h deleted file mode 100644 index 7d58e9d..0000000 --- a/include/configs/CPCI405AB.h +++ /dev/null @@ -1,373 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405GP 1 /* This is a PPC405 CPU */ -#define CONFIG_CPCI405 1 /* ...on a CPCI405 board */ -#define CONFIG_CPCI405_VER2 1 /* ...version 2 */ -#define CONFIG_CPCI405AB 1 /* ...and special AB version */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#undef CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */ - -#undef CONFIG_HAS_ETH1 - -#define CONFIG_RTC_M48T35A 1 /* ST Electronics M48 timekeeper */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_ELF -#define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_BSP -#define CONFIG_CMD_EEPROM - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_SUPPORT_VFAT - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_CMDLINE_EDITING /* add command line history */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - -#define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config*/ - -#define CONFIG_PCI_BOOTDELAY 0 /* enable pci bootdelay variable*/ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID2 0x0406 /* PCI Device ID: CPCI-405-A */ -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI (bd->bi_memsize) /* host use this pci address */ - -#define CONFIG_PCI_4xx_PTM_OVERWRITE 1 /* overwrite PTMx settings by env */ - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ -#undef CONFIG_IDE_LED /* no led for ide supported */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE busses */ -#define CONFIG_SYS_IDE_MAXDEVICE (CONFIG_SYS_IDE_MAXBUS*1) /* max. 1 drives per IDE bus */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xF0100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFC0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc() */ - -#define CONFIG_PRAM 0 /* use pram variable to overwrite */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -#define CONFIG_OF_LIBFDT -#define CONFIG_OF_BOARD_SETUP - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC32) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 100000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC32 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x01 -#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 /* more than one eeprom used! */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* The Catalyst CAT24WC32 has */ - /* 32 byte page write mode using*/ - /* last 5 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* Use EEPROM for environment variables */ - -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC32 is 4096 bytes */ - -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xf0200000 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE (32*1024) /* NVRAM size */ -#define CONFIG_SYS_VXWORKS_MAC_PTR (CONFIG_SYS_NVRAM_BASE_ADDR+0x6900) /* VxWorks eth-addr*/ - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF800000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0xFFC00000 /* FLASH bank #1 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (Flash Bank 1) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR 0xFF85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 2 (CAN0, 1) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ -#define CONFIG_SYS_LED_ADDR 0xF0000380 - -/* Memory Bank 3 (CompactFlash IDE) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB3CR 0xF011A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ - -/* Memory Bank 4 (NVRAM/RTC) initialization */ -/*#define CONFIG_SYS_EBC_PB4AP 0x01805280 / * TWT=3,WBN=1,WBF=1,TH=1,SOR=1 */ -#define CONFIG_SYS_EBC_PB4AP 0x01805680 /* TWT=3,WBN=1,WBF=1,TH=3,SOR=1 */ -#define CONFIG_SYS_EBC_PB4CR 0xF0218000 /* BAS=0xF02,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 5 (optional Quart) initialization */ -#define CONFIG_SYS_EBC_PB5AP 0x04005B80 /* TWT=8,WBN=1,WBF=1,TH=5,RE=1,SOR=1*/ -#define CONFIG_SYS_EBC_PB5CR 0xF0318000 /* BAS=0xF03,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 6 (FPGA internal) initialization */ -#define CONFIG_SYS_EBC_PB6AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB6CR 0xF041A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ -#define CONFIG_SYS_FPGA_BASE_ADDR 0xF0400000 - -/*----------------------------------------------------------------------- - * FPGA stuff - */ -/* FPGA internal regs */ -#define CONFIG_SYS_FPGA_MODE 0x00 -#define CONFIG_SYS_FPGA_STATUS 0x02 -#define CONFIG_SYS_FPGA_TS 0x04 -#define CONFIG_SYS_FPGA_TS_LOW 0x06 -#define CONFIG_SYS_FPGA_TS_CAP0 0x10 -#define CONFIG_SYS_FPGA_TS_CAP0_LOW 0x12 -#define CONFIG_SYS_FPGA_TS_CAP1 0x14 -#define CONFIG_SYS_FPGA_TS_CAP1_LOW 0x16 -#define CONFIG_SYS_FPGA_TS_CAP2 0x18 -#define CONFIG_SYS_FPGA_TS_CAP2_LOW 0x1a -#define CONFIG_SYS_FPGA_TS_CAP3 0x1c -#define CONFIG_SYS_FPGA_TS_CAP3_LOW 0x1e - -/* FPGA Mode Reg */ -#define CONFIG_SYS_FPGA_MODE_CF_RESET 0x0001 -#define CONFIG_SYS_FPGA_MODE_DUART_RESET 0x0002 -#define CONFIG_SYS_FPGA_MODE_ENABLE_OUTPUT 0x0004 /* only set on CPCI-405 Ver 3 */ -#define CONFIG_SYS_FPGA_MODE_1WIRE_DIR 0x0100 /* dir=1 -> output */ -#define CONFIG_SYS_FPGA_MODE_SIM_OK_DIR 0x0200 -#define CONFIG_SYS_FPGA_MODE_TESTRIG_FAIL_DIR 0x0400 -#define CONFIG_SYS_FPGA_MODE_1WIRE 0x1000 -#define CONFIG_SYS_FPGA_MODE_SIM_OK 0x2000 /* wired-or net from all devices */ -#define CONFIG_SYS_FPGA_MODE_TESTRIG_FAIL 0x4000 - -/* FPGA Status Reg */ -#define CONFIG_SYS_FPGA_STATUS_DIP0 0x0001 -#define CONFIG_SYS_FPGA_STATUS_DIP1 0x0002 -#define CONFIG_SYS_FPGA_STATUS_DIP2 0x0004 -#define CONFIG_SYS_FPGA_STATUS_FLASH 0x0008 -#define CONFIG_SYS_FPGA_STATUS_1WIRE 0x1000 -#define CONFIG_SYS_FPGA_STATUS_SIM_OK 0x2000 - -#define CONFIG_SYS_FPGA_SPARTAN2 1 /* using Xilinx Spartan 2 now */ -#define CONFIG_SYS_FPGA_MAX_SIZE 128*1024 /* 128kByte is enough for XC2S30 */ - -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* FPGA program pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -#define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */ - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405DT.h b/include/configs/CPCI405DT.h deleted file mode 100644 index c2598a3..0000000 --- a/include/configs/CPCI405DT.h +++ /dev/null @@ -1,376 +0,0 @@ -/* - * (C) Copyright 2001-2004 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405GP 1 /* This is a PPC405 CPU */ -#define CONFIG_CPCI405 1 /* ...on a CPCI405 board */ -#define CONFIG_CPCI405_VER2 1 /* ...version 2 */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */ - -#undef CONFIG_HAS_ETH1 - -#define CONFIG_RTC_M48T35A 1 /* ST Electronics M48 timekeeper */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_ELF -#define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_BSP -#define CONFIG_CMD_EEPROM - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_SUPPORT_VFAT - -#undef CONFIG_AUTO_UPDATE /* autoupdate via compactflash */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_LOOPW 1 /* enable loopw command */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -/* Only interrupt boot if special string is typed */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Autobooting in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#undef CONFIG_AUTOBOOT_STOP_STR /* defined via environment var */ -#define CONFIG_AUTOBOOT_STOP_STR2 "esdesd" /* esd special for esd access*/ - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -#define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ - -/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config*/ - -#define CONFIG_PCI_BOOTDELAY 0 /* enable pci bootdelay variable*/ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID2 0x0406 /* PCI Device ID: CPCI-405-A */ -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI (bd->bi_memsize) /* host use this pci address */ - -#define CONFIG_PCI_4xx_PTM_OVERWRITE 1 /* overwrite PTMx settings by env */ - -/*----------------------------------------------------------------------- - * IDE/ATA stuff - *----------------------------------------------------------------------- - */ -#undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ -#undef CONFIG_IDE_LED /* no led for ide supported */ -#define CONFIG_IDE_RESET 1 /* reset for ide supported */ - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE busses */ -#define CONFIG_SYS_IDE_MAXDEVICE (CONFIG_SYS_IDE_MAXBUS*1) /* max. 1 drives per IDE bus */ - -#define CONFIG_SYS_ATA_BASE_ADDR 0xF0100000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFFC0000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -#if 0 /* Use NVRAM for environment variables */ -/*----------------------------------------------------------------------- - * NVRAM organization - */ -#define CONFIG_ENV_IS_IN_NVRAM 1 /* use NVRAM for environment vars */ -#define CONFIG_ENV_SIZE 0x0ff8 /* Size of Environment vars */ -#define CONFIG_ENV_ADDR \ - (CONFIG_SYS_NVRAM_BASE_ADDR+CONFIG_SYS_NVRAM_SIZE-(CONFIG_ENV_SIZE+8)) /* Env */ - -#else /* Use EEPROM for environment variables */ - -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */ -#endif - -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xf0200000 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE (32*1024) /* NVRAM size */ -#define CONFIG_SYS_VXWORKS_MAC_PTR (CONFIG_SYS_NVRAM_BASE_ADDR+0x6900) /* VxWorks eth-addr*/ - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC16) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFF800000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0xFFC00000 /* FLASH bank #1 */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 1 (Flash Bank 1) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR 0xFF85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 2 (CAN0, 1) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ -#define CONFIG_SYS_LED_ADDR 0xF0000380 - -/* Memory Bank 3 (CompactFlash IDE) initialization */ -#define CONFIG_SYS_EBC_PB3AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB3CR 0xF011A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ - -/* Memory Bank 4 (NVRAM/RTC) initialization */ -/*#define CONFIG_SYS_EBC_PB4AP 0x01805280 / * TWT=3,WBN=1,WBF=1,TH=1,SOR=1 */ -#define CONFIG_SYS_EBC_PB4AP 0x01805680 /* TWT=3,WBN=1,WBF=1,TH=3,SOR=1 */ -#define CONFIG_SYS_EBC_PB4CR 0xF0218000 /* BAS=0xF02,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 5 (optional Quart) initialization */ -#define CONFIG_SYS_EBC_PB5AP 0x04005B80 /* TWT=8,WBN=1,WBF=1,TH=5,RE=1,SOR=1*/ -#define CONFIG_SYS_EBC_PB5CR 0xF0318000 /* BAS=0xF03,BS=1MB,BU=R/W,BW=8bit */ - -/* Memory Bank 6 (FPGA internal) initialization */ -#define CONFIG_SYS_EBC_PB6AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB6CR 0xF041A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ -#define CONFIG_SYS_FPGA_BASE_ADDR 0xF0400000 - -/*----------------------------------------------------------------------- - * FPGA stuff - */ -/* FPGA internal regs */ -#define CONFIG_SYS_FPGA_MODE 0x00 -#define CONFIG_SYS_FPGA_STATUS 0x02 -#define CONFIG_SYS_FPGA_TS 0x04 -#define CONFIG_SYS_FPGA_TS_LOW 0x06 -#define CONFIG_SYS_FPGA_TS_CAP0 0x10 -#define CONFIG_SYS_FPGA_TS_CAP0_LOW 0x12 -#define CONFIG_SYS_FPGA_TS_CAP1 0x14 -#define CONFIG_SYS_FPGA_TS_CAP1_LOW 0x16 -#define CONFIG_SYS_FPGA_TS_CAP2 0x18 -#define CONFIG_SYS_FPGA_TS_CAP2_LOW 0x1a -#define CONFIG_SYS_FPGA_TS_CAP3 0x1c -#define CONFIG_SYS_FPGA_TS_CAP3_LOW 0x1e - -/* FPGA Mode Reg */ -#define CONFIG_SYS_FPGA_MODE_CF_RESET 0x0001 -#define CONFIG_SYS_FPGA_MODE_DUART_RESET 0x0002 -#define CONFIG_SYS_FPGA_MODE_ENABLE_OUTPUT 0x0004 /* only set on CPCI-405 Ver 3 */ -#define CONFIG_SYS_FPGA_MODE_TS_IRQ_ENABLE 0x0100 -#define CONFIG_SYS_FPGA_MODE_TS_IRQ_CLEAR 0x1000 -#define CONFIG_SYS_FPGA_MODE_TS_CLEAR 0x2000 - -/* FPGA Status Reg */ -#define CONFIG_SYS_FPGA_STATUS_DIP0 0x0001 -#define CONFIG_SYS_FPGA_STATUS_DIP1 0x0002 -#define CONFIG_SYS_FPGA_STATUS_DIP2 0x0004 -#define CONFIG_SYS_FPGA_STATUS_FLASH 0x0008 -#define CONFIG_SYS_FPGA_STATUS_TS_IRQ 0x1000 - -#define CONFIG_SYS_FPGA_SPARTAN2 1 /* using Xilinx Spartan 2 now */ -#define CONFIG_SYS_FPGA_MAX_SIZE 32*1024 /* 32kByte is enough for XC2S15 */ - -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* FPGA program pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -#define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */ - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#endif /* __CONFIG_H */
On Mon, Jan 12, 2015 at 10:47:30PM +0100, Matthias Fuchs wrote:
only keep CPCI4052
Matthias Fuchs
