[PATCH] cmd: mmc: Support mmc hwpartition user enh start -
Add option to extend the hardware partition to the maximum size by using the '-' dash sign instead of $cnt parameter. This is useful in case we want to switch the entire eMMC user area into pSLC mode, especially in case the device may be populated with different size eMMCs. With this change, we do not have to calculate the number of blocks of the user area manually.
To switch the pSLC mode for user area, use e.g. the following. WARNING: This is a one-time irreversible change. => mmc hwpartition user enh 0 - wrrel on complete
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- cmd/mmc.c | 32 ++++++++++++++++++++++++++++---- 1 file changed, 28 insertions(+), 4 deletions(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index c67ad762422..b6bb951347d 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -560,7 +560,32 @@ static int do_mmc_list(struct cmd_tbl *cmdtp, int flag, }
#if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) -static int parse_hwpart_user(struct mmc_hwpart_conf *pconf, +static void parse_hwpart_user_enh_size(struct mmc *mmc, + struct mmc_hwpart_conf *pconf, + char *argv) +{ + int ret; + + pconf->user.enh_size = 0; + + if (!strcmp(argv, "-")) { /* The rest of eMMC */ + ALLOC_CACHE_ALIGN_BUFFER(u8, ext_csd, MMC_MAX_BLOCK_LEN); + ret = mmc_send_ext_csd(mmc, ext_csd); + if (ret) + return; + pconf->user.enh_size = + ((ext_csd[EXT_CSD_MAX_ENH_SIZE_MULT+2] << 16) + + (ext_csd[EXT_CSD_MAX_ENH_SIZE_MULT+1] << 8) + + ext_csd[EXT_CSD_MAX_ENH_SIZE_MULT]) * 1024 * + ext_csd[EXT_CSD_HC_ERASE_GRP_SIZE] * + ext_csd[EXT_CSD_HC_WP_GRP_SIZE]; + pconf->user.enh_size -= pconf->user.enh_start; + } else { + pconf->user.enh_size = dectoul(argv, NULL); + } +} + +static int parse_hwpart_user(struct mmc *mmc, struct mmc_hwpart_conf *pconf, int argc, char *const argv[]) { int i = 0; @@ -573,8 +598,7 @@ static int parse_hwpart_user(struct mmc_hwpart_conf *pconf, return -1; pconf->user.enh_start = dectoul(argv[i + 1], NULL); - pconf->user.enh_size = - dectoul(argv[i + 2], NULL); + parse_hwpart_user_enh_size(mmc, pconf, argv[i + 2]); i += 3; } else if (!strcmp(argv[i], "wrrel")) { if (i + 1 >= argc) @@ -646,7 +670,7 @@ static int do_mmc_hwpartition(struct cmd_tbl *cmdtp, int flag, while (i < argc) { if (!strcmp(argv[i], "user")) { i++; - r = parse_hwpart_user(&pconf, argc-i, &argv[i]); + r = parse_hwpart_user(mmc, &pconf, argc-i, &argv[i]); if (r < 0) return CMD_RET_USAGE; i += r;
char *argv)
- int ret;
- pconf->user.enh_size = 0;
- if (!strcmp(argv, "-")) { /* The rest of eMMC */
if (ret)
return;
space before/after "+"
Ditto
Hardcode HC_WP_GRP_SIZE to 1024? Per spec:
(GP_SIZE_MULT_X_2 * 2^16 + GP_SIZE_MULT_X_1 * 2^8 + GP_SIZE_MULT_X_0 * 2^0) * HC_WP_GRP_SIZE * HC_ERASE_GRP_SIZE * 512kBytes
Thanks, Peng.
- } else {
} else if (!strcmp(argv[i], "wrrel")) { if (i + 1 >= argc)parse_hwpart_user_enh_size(mmc, pconf, argv[i + 2]); i += 3;
diff --git a/cmd/mmc.c b/cmd/mmc.c index c67ad762422..b6bb951347d 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -560,7 +560,32 @@ static int do_mmc_list(struct cmd_tbl *cmdtp, int flag, } #if CONFIG_IS_ENABLED(MMC_HW_PARTITIONING) -static int parse_hwpart_user(struct mmc_hwpart_conf *pconf, +static void parse_hwpart_user_enh_size(struct mmc *mmc, + struct mmc_hwpart_conf *pconf, + char *argv) +{ + int ret;
Ditto
That "1024" above is that "* 512kBytes" part, in 512 Byte block units.
Peng Fan (OSS)
