[PATCH v3 0/6] riscv: add support for Milk-V Mars board
The Milk-V Mars board is technically very close to the StarFive VisionFive 2 board.
With this patch series the VisionFive 2 U-Boot SPL will detect that it is running on a Milk-V board and patch the device-tree accordingly. This is the same approach that has been taken to handle the differences between the Visionfive 2 1.2B and 1.3A revisions.
For the mmc card-detect a separate patch has been created: https://lore.kernel.org/u-boot/20240328214615.21501-1-heinrich.schuchardt@ca...
v3: Rephrase last a sentence in doc/board/starfive/visionfive2.rst v2: do not set default fdt for VisionFive 2 do not overwrite /soc/i2c@12050000/eeprom@50/compatible
Heinrich Schuchardt (6): riscv: do not set default fdt for VisionFive 2 eeprom: starfive: function get_product_id_from_eeprom() riscv: set fdtfile on Milk-V Mars board: starfive: support Milk-V Mars board riscv: starfive: avoid including common.h doc: describe Milk-V Mars board
arch/riscv/include/asm/arch-jh7110/eeprom.h | 9 ++ board/starfive/visionfive2/spl.c | 100 ++++++++++++++-- .../visionfive2/starfive_visionfive2.c | 48 +++++--- .../visionfive2/visionfive2-i2c-eeprom.c | 9 +- configs/starfive_visionfive2_defconfig | 1 - doc/board/starfive/index.rst | 1 + doc/board/starfive/milk-v_mars.rst | 111 ++++++++++++++++++ doc/board/starfive/visionfive2.rst | 18 +++ 8 files changed, 268 insertions(+), 29 deletions(-) create mode 100644 doc/board/starfive/milk-v_mars.rst
Currently in set_fdtfile() we set the value of environment variable fdtfile unconditionally. The implies that a value in the environment will be ignored.
With the patch environment variable fdtfile will only be set if it does not yet exist. This requires that CONFIG_DEFAULT_FDT_FILE is not set.
Now the user can either set and save fdtfile interactively or in the U-Boot configuration to overrule the device-tree name chosen based on the hardware in set_fdtfile().
Reported-by: E Shattow lucent@gmail.com Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v3: Rephrase last added sentence in doc/board/starfive/visionfive2.rst v2: new patch --- .../visionfive2/starfive_visionfive2.c | 4 ++++ configs/starfive_visionfive2_defconfig | 1 - doc/board/starfive/visionfive2.rst | 18 ++++++++++++++++++ 3 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index 78e118d5a05..76439179fa7 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -49,6 +49,10 @@ static void set_fdtfile(void) u8 version; const char *fdtfile;
+ fdtfile = env_get("fdtfile"); + if (fdtfile) + return; + version = get_pcb_revision_from_eeprom(); switch (version) { case 'a': diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index 7a3f1d4dbdf..fa80d489f5e 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -40,7 +40,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 debug rootwait earlycon=sbi" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="nvme scan; usb start; setenv fdt_addr ${fdtcontroladdr}; fdt addr ${fdtcontroladdr};" -CONFIG_DEFAULT_FDT_FILE="starfive/jh7110-starfive-visionfive-2.dtb" CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_DISPLAY_CPUINFO=y diff --git a/doc/board/starfive/visionfive2.rst b/doc/board/starfive/visionfive2.rst index abda8ac21bc..2c68df3ce4d 100644 --- a/doc/board/starfive/visionfive2.rst +++ b/doc/board/starfive/visionfive2.rst @@ -71,6 +71,24 @@ Now build the U-Boot SPL and U-Boot proper This will generate the U-Boot SPL image (spl/u-boot-spl.bin.normal.out) as well as the FIT image (u-boot.itb) with OpenSBI and U-Boot.
+Device-tree selection +~~~~~~~~~~~~~~~~~~~~~ + +Depending on the board version U-Boot set variable $fdtfile to either +starfive/jh7110-starfive-visionfive-2-v1.2a.dtb or +starfive/jh7110-starfive-visionfive-2-v1.3b.dtb. + +To overrule this selection the variable can be set manually and saved in the +environment + +:: + + setenv fdtfile my_device-tree.dtb + env save + +or the configuration variable CONFIG_DEFAULT_FDT_FILE can be used to provide +a default value. + Flashing ~~~~~~~~
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Export a function get_product_id_from_eeprom() to read the product ID. This value can be used for fixing up the device-tree on JH7110 based products.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- v3: no change v2: no change --- arch/riscv/include/asm/arch-jh7110/eeprom.h | 9 +++++++++ board/starfive/visionfive2/visionfive2-i2c-eeprom.c | 8 ++++++++ 2 files changed, 17 insertions(+)
diff --git a/arch/riscv/include/asm/arch-jh7110/eeprom.h b/arch/riscv/include/asm/arch-jh7110/eeprom.h index d2776d5b6cb..62d184aeb57 100644 --- a/arch/riscv/include/asm/arch-jh7110/eeprom.h +++ b/arch/riscv/include/asm/arch-jh7110/eeprom.h @@ -12,4 +12,13 @@ u8 get_pcb_revision_from_eeprom(void); u32 get_ddr_size_from_eeprom(void);
+/** + * get_product_id_from_eeprom - get product ID string + * + * A string like "VF7110A1-2228-D008E000-00000001" is returned. + * + * Return: product ID string + */ +const char *get_product_id_from_eeprom(void); + #endif /* _ASM_RISCV_EEPROM_H */ diff --git a/board/starfive/visionfive2/visionfive2-i2c-eeprom.c b/board/starfive/visionfive2/visionfive2-i2c-eeprom.c index c36de1a5125..a9f4376c8e1 100644 --- a/board/starfive/visionfive2/visionfive2-i2c-eeprom.c +++ b/board/starfive/visionfive2/visionfive2-i2c-eeprom.c @@ -405,6 +405,14 @@ static void set_product_id(char *string) update_crc(); }
+const char *get_product_id_from_eeprom(void) +{ + if (read_eeprom()) + return NULL; + + return pbuf.eeprom.atom1.data.pstr; +} + int do_mac(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { char *cmd;
Set environment variable fdtfile to the correct value for the Milk-V Mars board.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- v3: no change v2: rebase patch --- .../visionfive2/starfive_visionfive2.c | 43 +++++++++++++------ 1 file changed, 30 insertions(+), 13 deletions(-)
diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index 76439179fa7..5ae8b850280 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -9,6 +9,7 @@ #include <dm.h> #include <fdt_support.h> #include <env.h> +#include <log.h> #include <asm/arch/eeprom.h> #include <asm/io.h> #include <asm/sections.h> @@ -17,6 +18,8 @@ DECLARE_GLOBAL_DATA_PTR; #define JH7110_L2_PREFETCHER_BASE_ADDR 0x2030000 #define JH7110_L2_PREFETCHER_HART_OFFSET 0x2000 +#define FDTFILE_MILK_V_MARS \ + "starfive/jh7110-milkv-mars.dtb" #define FDTFILE_VISIONFIVE2_1_2A \ "starfive/jh7110-starfive-visionfive-2-v1.2a.dtb" #define FDTFILE_VISIONFIVE2_1_3B \ @@ -48,24 +51,38 @@ static void set_fdtfile(void) { u8 version; const char *fdtfile; + const char *product_id;
fdtfile = env_get("fdtfile"); if (fdtfile) return;
- version = get_pcb_revision_from_eeprom(); - switch (version) { - case 'a': - case 'A': - fdtfile = FDTFILE_VISIONFIVE2_1_2A; - break; - - case 'b': - case 'B': - default: - fdtfile = FDTFILE_VISIONFIVE2_1_3B; - break; - }; + product_id = get_product_id_from_eeprom(); + if (!product_id) { + log_err("Can't read EEPROM\n"); + return; + } + if (!strncmp(product_id, "MARS", 4)) { + fdtfile = FDTFILE_MILK_V_MARS; + } else if (!strncmp(product_id, "VF7110", 6)) { + version = get_pcb_revision_from_eeprom(); + + switch (version) { + case 'a': + case 'A': + fdtfile = FDTFILE_VISIONFIVE2_1_2A; + break; + + case 'b': + case 'B': + default: + fdtfile = FDTFILE_VISIONFIVE2_1_3B; + break; + } + } else { + log_err("Unknown product\n"); + return; + }
env_set("fdtfile", fdtfile); }
The differences between the Milk-V Mars board and the VisionFive 2 board are small enough that we can support both using the same U-Boot build.
* The model and compatible property are taken from proposed Linux patches. * The EEPROM is atmel,24c02 according to the vendor U-Boot. * The second Ethernet port is not available.
usb@10100000 does not exist in U-Boot yet. So we don't have to reflect differences in usage here.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- For the mmc card-detect a separate patch has been created: https://lore.kernel.org/u-boot/20240328214615.21501-1-heinrich.schuchardt@ca...
v3: Replace misplaced starfive_verb[i] by milk_v_mars[i]. v2: do not overwrite /soc/i2c@12050000/eeprom@50/compatible --- board/starfive/visionfive2/spl.c | 99 ++++++++++++++++++++++++++++---- 1 file changed, 87 insertions(+), 12 deletions(-)
diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c index 1b49945d11b..e8f97d963a0 100644 --- a/board/starfive/visionfive2/spl.c +++ b/board/starfive/visionfive2/spl.c @@ -27,6 +27,26 @@ struct starfive_vf2_pro { const char *value; };
+static const struct starfive_vf2_pro milk_v_mars[] = { + {"/soc/ethernet@16030000", "starfive,tx-use-rgmii-clk", NULL}, + {"/soc/ethernet@16040000", "starfive,tx-use-rgmii-clk", NULL}, + + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-adj-enabled", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-100-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-1000-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-clk-drv-microamp", "3970"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-data-drv-microamp", "2910"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "rx-internal-delay-ps", "1900"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "tx-internal-delay-ps", "1500"}, +}; + static const struct starfive_vf2_pro starfive_vera[] = { {"/soc/ethernet@16030000/mdio/ethernet-phy@0", "rx-internal-delay-ps", "1900"}, @@ -67,6 +87,49 @@ static const struct starfive_vf2_pro starfive_verb[] = { "tx-internal-delay-ps", "0"}, };
+void spl_fdt_fixup_mars(void *fdt) +{ + static const char compat[] = "milkv,mars\0starfive,jh7110"; + u32 phandle; + u8 i; + int offset; + int ret; + + fdt_setprop(fdt, fdt_path_offset(fdt, "/"), "compatible", compat, sizeof(compat)); + fdt_setprop_string(fdt, fdt_path_offset(fdt, "/"), "model", + "Milk-V Mars"); + + /* gmac0 */ + offset = fdt_path_offset(fdt, "/soc/clock-controller@17000000"); + phandle = fdt_get_phandle(fdt, offset); + offset = fdt_path_offset(fdt, "/soc/ethernet@16030000"); + + fdt_setprop_u32(fdt, offset, "assigned-clocks", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clocks", JH7110_AONCLK_GMAC0_TX); + fdt_setprop_u32(fdt, offset, "assigned-clock-parents", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clock-parents", + JH7110_AONCLK_GMAC0_RMII_RTX); + + /* gmac1 */ + fdt_setprop_string(fdt, fdt_path_offset(fdt, "/soc/ethernet@16040000"), + "status", "disabled"); + + for (i = 0; i < ARRAY_SIZE(milk_v_mars); i++) { + offset = fdt_path_offset(fdt, milk_v_mars[i].path); + + if (milk_v_mars[i].value) + ret = fdt_setprop_u32(fdt, offset, milk_v_mars[i].name, + dectoul(milk_v_mars[i].value, NULL)); + else + ret = fdt_setprop_empty(fdt, offset, milk_v_mars[i].name); + + if (ret) { + pr_err("%s set prop %s fail.\n", __func__, milk_v_mars[i].name); + break; + } + } +} + void spl_fdt_fixup_version_a(void *fdt) { static const char compat[] = "starfive,visionfive-2-v1.2a\0starfive,jh7110"; @@ -167,22 +230,34 @@ void spl_fdt_fixup_version_b(void *fdt) void spl_perform_fixups(struct spl_image_info *spl_image) { u8 version; + const char *product_id;
- version = get_pcb_revision_from_eeprom(); - switch (version) { - case 'a': - case 'A': - spl_fdt_fixup_version_a(spl_image->fdt_addr); - break; - - case 'b': - case 'B': - default: - spl_fdt_fixup_version_b(spl_image->fdt_addr); + product_id = get_product_id_from_eeprom(); + if (!product_id) { + pr_err("Can't read EEPROM\n"); + return; + } + if (!strncmp(product_id, "MARS", 4)) { + spl_fdt_fixup_mars(spl_image->fdt_addr); + } else if (!strncmp(product_id, "VF7110", 6)) { + version = get_pcb_revision_from_eeprom(); + switch (version) { + case 'a': + case 'A': + spl_fdt_fixup_version_a(spl_image->fdt_addr); + break; + + case 'b': + case 'B': + default: + spl_fdt_fixup_version_b(spl_image->fdt_addr); break; + }; + } else { + pr_err("Unknown product %s\n", product_id); };
- /* Update the memory size which read form eeprom or DT */ + /* Update the memory size which read from eeprom or DT */ fdt_fixup_memory(spl_image->fdt_addr, 0x40000000, gd->ram_size); }
- The model and compatible property are taken from proposed Linux patches.
- The EEPROM is atmel,24c02 according to the vendor U-Boot.
- The second Ethernet port is not available.
The usage of common.h is deprecated. Remove it from board files.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com --- v3: no change v2: no change --- board/starfive/visionfive2/spl.c | 1 - board/starfive/visionfive2/starfive_visionfive2.c | 1 - board/starfive/visionfive2/visionfive2-i2c-eeprom.c | 1 - 3 files changed, 3 deletions(-)
diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c index e8f97d963a0..45848db6d8b 100644 --- a/board/starfive/visionfive2/spl.c +++ b/board/starfive/visionfive2/spl.c @@ -4,7 +4,6 @@ * Author: Yanhong Wangyanhong.wang@starfivetech.com */
-#include <common.h> #include <asm/arch/eeprom.h> #include <asm/arch/gpio.h> #include <asm/arch/regs.h> diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index 5ae8b850280..a86bca533b2 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -4,7 +4,6 @@ * Author: Yanhong Wangyanhong.wang@starfivetech.com */
-#include <common.h> #include <cpu_func.h> #include <dm.h> #include <fdt_support.h> diff --git a/board/starfive/visionfive2/visionfive2-i2c-eeprom.c b/board/starfive/visionfive2/visionfive2-i2c-eeprom.c index a9f4376c8e1..ddef7d61235 100644 --- a/board/starfive/visionfive2/visionfive2-i2c-eeprom.c +++ b/board/starfive/visionfive2/visionfive2-i2c-eeprom.c @@ -4,7 +4,6 @@ * Author: Yanhong Wangyanhong.wang@starfivetech.com */
-#include <common.h> #include <command.h> #include <env.h> #include <i2c.h>
Add instructions to build U-Boot for the Milk-V Mars board
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v3: no change v2: describe how to preset fdtfile --- doc/board/starfive/index.rst | 1 + doc/board/starfive/milk-v_mars.rst | 111 +++++++++++++++++++++++++++++ 2 files changed, 112 insertions(+) create mode 100644 doc/board/starfive/milk-v_mars.rst
diff --git a/doc/board/starfive/index.rst b/doc/board/starfive/index.rst index 0c52dc7b095..2762bf74c11 100644 --- a/doc/board/starfive/index.rst +++ b/doc/board/starfive/index.rst @@ -6,4 +6,5 @@ StarFive .. toctree:: :maxdepth: 1
+ milk-v_mars.rst visionfive2 diff --git a/doc/board/starfive/milk-v_mars.rst b/doc/board/starfive/milk-v_mars.rst new file mode 100644 index 00000000000..554932ecfd4 --- /dev/null +++ b/doc/board/starfive/milk-v_mars.rst @@ -0,0 +1,111 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Milk-V Mars +=========== + +U-Boot for the Milk-V Mars uses the same U-Boot binaries as the VisionFive 2 +board. In U-Boot SPL the actual board is detected and the device-tree patched +accordingly. + +Building +~~~~~~~~ + +1. Add the RISC-V toolchain to your PATH. +2. Setup ARCH & cross compilation environment variable: + +.. code-block:: none + + export CROSS_COMPILE=<riscv64 toolchain prefix> + +The M-mode software OpenSBI provides the supervisor binary interface (SBI) and +is responsible for the switch to S-Mode. It is a prerequisite to build U-Boot. +Support for the JH7110 was introduced in OpenSBI 1.2. It is recommended to use +a current release. + +.. code-block:: console + + git clone https://github.com/riscv/opensbi.git + cd opensbi + make PLATFORM=generic FW_TEXT_START=0x40000000 FW_OPTIONS=0 + +Now build the U-Boot SPL and U-Boot proper. + +.. code-block:: console + + cd <U-Boot-dir> + make starfive_visionfive2_defconfig + make OPENSBI=$(opensbi_dir)/build/platform/generic/firmware/fw_dynamic.bin + +This will generate the U-Boot SPL image (spl/u-boot-spl.bin.normal.out) as well +as the FIT image (u-boot.itb) with OpenSBI and U-Boot. + +Device-tree selection +~~~~~~~~~~~~~~~~~~~~~ + +Depending on the board version U-Boot set variable $fdtfile to either +starfive/jh7110-starfive-visionfive-2-v1.2a.dtb or +starfive/jh7110-starfive-visionfive-2-v1.3b.dtb. + +To overrule this selection the variable can be set manually and saved in the +environment + +:: + + setenv fdtfile my_device-tree.dtb + env save + +or the configuration variable CONFIG_DEFAULT_FDT_FILE can be used to set to +provide a default value. + +Boot source selection +~~~~~~~~~~~~~~~~~~~~~ + +The board provides the DIP switches MSEL[1:0] to select the boot device out of +SPI flash, eMMC, SD-card, UART. To select booting from SD-card set the DIP +switches MSEL[1:0] to 10. + +Preparing the SD-Card +~~~~~~~~~~~~~~~~~~~~~ + +The device firmware loads U-Boot SPL (u-boot-spl.bin.normal.out) from the +partition with type GUID 2E54B353-1271-4842-806F-E436D6AF6985. You are free +to choose any partition number. + +With the default configuration U-Boot SPL loads the U-Boot FIT image +(u-boot.itb) from partition 2 (CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x2). +When formatting it is recommended to use GUID +BC13C2FF-59E6-4262-A352-B275FD6F7172 for this partition. + +The FIT image (u-boot.itb) is a combination of OpenSBI's fw_dynamic.bin, +u-boot-nodtb.bin and the device tree blob. + +Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch) + +.. code-block:: bash + + sudo sgdisk --clear \ + --set-alignment=2 \ + --new=1:4096:8191 --change-name=1:spl --typecode=1:2E54B353-1271-4842-806F-E436D6AF6985\ + --new=2:8192:16383 --change-name=2:uboot --typecode=2:BC13C2FF-59E6-4262-A352-B275FD6F7172 \ + --new=3:16384:1654784 --change-name=3:system --typecode=3:EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 \ + /dev/sdb + +Copy U-Boot to the SD card + +.. code-block:: bash + + sudo dd if=u-boot-spl.bin.normal.out of=/dev/sdb1 + sudo dd if=u-boot.itb of=/dev/sdb2 + + sudo mount /dev/sdb3 /mnt/ + sudo cp u-boot-spl.bin.normal.out /mnt/ + sudo cp u-boot.itb /mnt/ + sudo cp Image.gz /mnt/ + sudo cp initramfs.cpio.gz /mnt/ + sudo cp jh7110-starfive-visionfive-2.dtb /mnt/ + sudo umount /mnt + +Booting +~~~~~~~ + +Once you plugin the sdcard and power up, you should see the U-Boot prompt.
Leo Liang
