[PATCH] pwm: Add PWM driver for SiFive SoC
Adds a PWM driver for PWM chip present in SiFive's HiFive Unleashed SoC This driver is simple port of Linux pwm sifive driver.
Signed-off-by: Yash Shah yash.shah@sifive.com --- drivers/pwm/Kconfig | 6 ++ drivers/pwm/Makefile | 1 + drivers/pwm/pwm-sifive.c | 181 +++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 188 insertions(+) create mode 100644 drivers/pwm/pwm-sifive.c
diff --git a/drivers/pwm/Kconfig b/drivers/pwm/Kconfig index 1f36fc7..d6ea9ee 100644 --- a/drivers/pwm/Kconfig +++ b/drivers/pwm/Kconfig @@ -40,6 +40,12 @@ config PWM_SANDBOX useful. The PWM can be enabled but is not connected to any outputs so this is not very useful.
+config PWM_SIFIVE + bool "Enable support for SiFive PWM" + depends on DM_PWM + help + This PWM is found SiFive's FU540 and other SoCs. + config PWM_TEGRA bool "Enable support for the Tegra PWM" depends on DM_PWM diff --git a/drivers/pwm/Makefile b/drivers/pwm/Makefile index a837c35..e2d4185 100644 --- a/drivers/pwm/Makefile +++ b/drivers/pwm/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_DM_PWM) += pwm-uclass.o
obj-$(CONFIG_PWM_EXYNOS) += exynos_pwm.o obj-$(CONFIG_PWM_IMX) += pwm-imx.o pwm-imx-util.o +obj-$(CONFIG_PWM_SIFIVE) += pwm-sifive.o obj-$(CONFIG_PWM_ROCKCHIP) += rk_pwm.o obj-$(CONFIG_PWM_SANDBOX) += sandbox_pwm.o obj-$(CONFIG_PWM_TEGRA) += tegra_pwm.o diff --git a/drivers/pwm/pwm-sifive.c b/drivers/pwm/pwm-sifive.c new file mode 100644 index 0000000..c54297e --- /dev/null +++ b/drivers/pwm/pwm-sifive.c @@ -0,0 +1,181 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 SiFive, Inc + * For SiFive's PWM IP block documentation please refer Chapter 14 of + * Reference Manual : https://static.dev.sifive.com/FU540-C000-v1.0.pdf + * + * Limitations: + * - When changing both duty cycle and period, we cannot prevent in + * software that the output might produce a period with mixed + * settings (new period length and old duty cycle). + * - The hardware cannot generate a 100% duty cycle. + * - The hardware generates only inverted output. + */ + +#include <common.h> +#include <clk.h> +#include <div64.h> +#include <dm.h> +#include <pwm.h> +#include <regmap.h> +#include <linux/io.h> +#include <linux/log2.h> +#include <linux/bitfield.h> + +/* PWMCFG fields */ +#define PWM_SIFIVE_PWMCFG_SCALE GENMASK(3, 0) +#define PWM_SIFIVE_PWMCFG_STICKY BIT(8) +#define PWM_SIFIVE_PWMCFG_ZERO_CMP BIT(9) +#define PWM_SIFIVE_PWMCFG_DEGLITCH BIT(10) +#define PWM_SIFIVE_PWMCFG_EN_ALWAYS BIT(12) +#define PWM_SIFIVE_PWMCFG_EN_ONCE BIT(13) +#define PWM_SIFIVE_PWMCFG_CENTER BIT(16) +#define PWM_SIFIVE_PWMCFG_GANG BIT(24) +#define PWM_SIFIVE_PWMCFG_IP BIT(28) + +/* PWM_SIFIVE_SIZE_PWMCMP is used to calculate offset for pwmcmpX registers */ +#define PWM_SIFIVE_SIZE_PWMCMP 4 +#define PWM_SIFIVE_CMPWIDTH 16 + +DECLARE_GLOBAL_DATA_PTR; + +struct pwm_sifive_regs { + unsigned long cfg; + unsigned long cnt; + unsigned long pwms; + unsigned long cmp0; +}; + +struct pwm_sifive_data { + struct pwm_sifive_regs regs; +}; + +struct pwm_sifive_priv { + fdt_addr_t base; + ulong freq; + const struct pwm_sifive_data *data; +}; + +static int pwm_sifive_set_invert(struct udevice *dev, uint channel, + bool polarity) +{ + debug("%s: Do not support polarity\n", __func__); + + return 0; +} + +static int pwm_sifive_set_config(struct udevice *dev, uint channel, + uint period_ns, uint duty_ns) +{ + struct pwm_sifive_priv *priv = dev_get_priv(dev); + const struct pwm_sifive_regs *regs = &priv->data->regs; + unsigned long scale_pow; + unsigned long long num; + u32 scale, val = 0, frac; + + debug("%s: period_ns=%u, duty_ns=%u\n", __func__, period_ns, duty_ns); + + /* + * The PWM unit is used with pwmzerocmp=0, so the only way to modify the + * period length is using pwmscale which provides the number of bits the + * counter is shifted before being feed to the comparators. A period + * lasts (1 << (PWM_SIFIVE_CMPWIDTH + pwmscale)) clock ticks. + * (1 << (PWM_SIFIVE_CMPWIDTH + scale)) * 10^9/rate = period + */ + scale_pow = lldiv((uint64_t)priv->freq * period_ns, 1000000000); + scale = clamp(ilog2(scale_pow) - PWM_SIFIVE_CMPWIDTH, 0, 0xf); + val |= FIELD_PREP(PWM_SIFIVE_PWMCFG_SCALE, scale); + + /* + * The problem of output producing mixed setting as mentioned at top, + * occurs here. To minimize the window for this problem, we are + * calculating the register values first and then writing them + * consecutively + */ + num = (u64)duty_ns * (1U << PWM_SIFIVE_CMPWIDTH); + frac = DIV_ROUND_CLOSEST_ULL(num, period_ns); + frac = min(frac, (1U << PWM_SIFIVE_CMPWIDTH) - 1); + + writel(val, (void __iomem *)priv->base + regs->cfg); + writel(frac, (void __iomem *)priv->base + regs->cmp0 + channel * + PWM_SIFIVE_SIZE_PWMCMP); + + return 0; +} + +static int pwm_sifive_set_enable(struct udevice *dev, uint channel, bool enable) +{ + struct pwm_sifive_priv *priv = dev_get_priv(dev); + const struct pwm_sifive_regs *regs = &priv->data->regs; + u32 val; + + debug("%s: Enable '%s'\n", __func__, dev->name); + + if (enable) { + val = readl((void __iomem *)priv->base + regs->cfg); + val |= PWM_SIFIVE_PWMCFG_EN_ALWAYS; + writel(val, (void __iomem *)priv->base + regs->cfg); + } else { + writel(0, (void __iomem *)priv->base + regs->cmp0 + channel * + PWM_SIFIVE_SIZE_PWMCMP); + } + + return 0; +} + +static int pwm_sifive_ofdata_to_platdata(struct udevice *dev) +{ + struct pwm_sifive_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + + return 0; +} + +static int pwm_sifive_probe(struct udevice *dev) +{ + struct pwm_sifive_priv *priv = dev_get_priv(dev); + struct clk clk; + int ret = 0; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) { + debug("%s get clock fail!\n", __func__); + return -EINVAL; + } + + priv->freq = clk_get_rate(&clk); + priv->data = (struct pwm_sifive_data *)dev_get_driver_data(dev); + + return 0; +} + +static const struct pwm_ops pwm_sifive_ops = { + .set_invert = pwm_sifive_set_invert, + .set_config = pwm_sifive_set_config, + .set_enable = pwm_sifive_set_enable, +}; + +static const struct pwm_sifive_data pwm_data = { + .regs = { + .cfg = 0x00, + .cnt = 0x08, + .pwms = 0x10, + .cmp0 = 0x20, + }, +}; + +static const struct udevice_id pwm_sifive_ids[] = { + { .compatible = "sifive,pwm0", .data = (ulong)&pwm_data}, + { } +}; + +U_BOOT_DRIVER(pwm_sifive) = { + .name = "pwm_sifive", + .id = UCLASS_PWM, + .of_match = pwm_sifive_ids, + .ops = &pwm_sifive_ops, + .ofdata_to_platdata = pwm_sifive_ofdata_to_platdata, + .probe = pwm_sifive_probe, + .priv_auto_alloc_size = sizeof(struct pwm_sifive_priv), +};
Hello Yash Shah,
Am 15.04.2020 um 08:32 schrieb Yash Shah:
So please add more information from exatly which linux version this patch is from, see:
https://www.denx.de/wiki/U-Boot/Patches#Attributing_Code_Copyrights_Sign
You introduce a new devicetree node, please add a documentation in doc/device-tree-bindings/pwm/
+config PWM_SIFIVE
- bool "Enable support for SiFive PWM"
- depends on DM_PWM
- help
- config PWM_TEGRA bool "Enable support for the Tegra PWM" depends on DM_PWM
Please keep this list sorted.
- Copyright (C) 2020 SiFive, Inc
- For SiFive's PWM IP block documentation please refer Chapter 14 of
- Reference Manual : https://static.dev.sifive.com/FU540-C000-v1.0.pdf
- Limitations:
- software that the output might produce a period with mixed
- settings (new period length and old duty cycle).
- unsigned long cfg;
- unsigned long cnt;
- unsigned long pwms;
- unsigned long cmp0;
- struct pwm_sifive_regs regs;
- fdt_addr_t base;
- ulong freq;
- const struct pwm_sifive_data *data;
bool polarity)
- debug("%s: Do not support polarity\n", __func__);
You don;t need this function.
- struct pwm_sifive_priv *priv = dev_get_priv(dev);
- const struct pwm_sifive_regs *regs = &priv->data->regs;
- unsigned long scale_pow;
- unsigned long long num;
- u32 scale, val = 0, frac;
- debug("%s: period_ns=%u, duty_ns=%u\n", __func__, period_ns, duty_ns);
- scale_pow = lldiv((uint64_t)priv->freq * period_ns, 1000000000);
- scale = clamp(ilog2(scale_pow) - PWM_SIFIVE_CMPWIDTH, 0, 0xf);
- val |= FIELD_PREP(PWM_SIFIVE_PWMCFG_SCALE, scale);
* consecutively
- num = (u64)duty_ns * (1U << PWM_SIFIVE_CMPWIDTH);
- frac = DIV_ROUND_CLOSEST_ULL(num, period_ns);
- frac = min(frac, (1U << PWM_SIFIVE_CMPWIDTH) - 1);
- writel(val, (void __iomem *)priv->base + regs->cfg);
Do you really need this cast on each readl/writel call?
- writel(frac, (void __iomem *)priv->base + regs->cmp0 + channel *
- u32 val;
- debug("%s: Enable '%s'\n", __func__, dev->name);
- if (enable) {
- } else {
- priv->base = dev_read_addr(dev);
- struct clk clk;
- int ret = 0;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0) {
return -EINVAL;
- priv->freq = clk_get_rate(&clk);
- priv->data = (struct pwm_sifive_data *)dev_get_driver_data(dev);
- .set_invert = pwm_sifive_set_invert,
- .set_config = pwm_sifive_set_config,
- .set_enable = pwm_sifive_set_enable,
- .regs = {
.cfg = 0x00,
.cnt = 0x08,
.pwms = 0x10,
.cmp0 = 0x20,
- { .compatible = "sifive,pwm0", .data = (ulong)&pwm_data},
- .name = "pwm_sifive",
- .id = UCLASS_PWM,
- .of_match = pwm_sifive_ids,
- .ops = &pwm_sifive_ops,
- .ofdata_to_platdata = pwm_sifive_ofdata_to_platdata,
- .probe = pwm_sifive_probe,
- .priv_auto_alloc_size = sizeof(struct pwm_sifive_priv),
Thanks!
bye, Heiko
-----Original Message----- From: Heiko Schocher hs@denx.de Sent: 15 April 2020 22:34 To: Yash Shah yash.shah@sifive.com Cc: martyn.welch@collabora.co.uk; u-boot@lists.denx.de Subject: Re: [PATCH] pwm: Add PWM driver for SiFive SoC
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Hello Yash Shah,
https://www.denx.de/wiki/U- Boot/Patches#Attributing_Code_Copyrights_Sign
Sure, will refer this doc and send a v2 accordingly.
Will add the dt documentation.
+config PWM_SIFIVE
depends on DM_PWM
help
Sure. My bad.
+https://static.dev.sifive.com/FU540-C000-v1.0.pdf
- Limitations:
registers */
unsigned long cfg;
unsigned long cnt;
unsigned long pwms;
unsigned long cmp0;
fdt_addr_t base;
ulong freq;
const struct pwm_sifive_data *data; };
bool polarity) {
uint period_ns, uint duty_ns) {
- duty_ns);
modify the
the
* consecutively
Will fix this in v2. Thanks for your comments.
- Yash
Heiko Schocher
Yash Shah
